Other Parts Discussed in Thread: TCI6636K2H
Need the individual voltage rail power consumption of TCI6636K2H. Is there a spread sheet available to calculate based on the configuration?
Thanks and regards,
Logu.K.S
Thanks and regards,
Logu.K.S
Hey Logu. K.S.,
What you're asking for is the power consumption model for TCI6636 series. It will be available later this year, and is currently under production.
-Kat
Thanks for the reply Kat!!!
We have started the design based on EVM, but the current is too high, mainly AVS core supply.
Will 10A for the CVDD & CVDDT sufficient enough? Datasheet says that CVDD and CVDDT should be connected together.
-Logu
Hey Logu,
Yep, CVDD and CVDDT should be connected together / powered by the same supply. The current limit really depends on what you're doing. I can't tell you how much is being taken at this point on that rail, but I can help you a little bit:
You're probably going to want to look at the EVM manual, it has the maximum power consumption assumptions for it: http://www.advantech.com/Support/TI-EVM/EVMK2HX.aspx
Hope this helps you,
Kat
