aif2LteTestProject payload fail
Hello
I use ccs5.4 and evm6670.
When I run C:\ti\pdk_C6670_1_1_2_6\packages\ti\drv\exampleProjects\aif2LteTestProject
I got unexpected payload problem. How can I solve this problem??
Console printed as below
[C66xx_2] Beginning AIF2 LTE CPRI:
test: CPRI_4X_LTE_20MHZ_2LINK
AIF CPRI mode
link 0 runs at 4x rate
        outbound data type: DL
        outbound data width: 15 bit
        inbound data type: DL
        inbound data width: 15 bit
link 1 runs at 4x rate
link 2 is disabled
link 3 is disabled
link 4 is disabled
link 5 is disabled
[C66xx_1] Beginning AIF2 LTE CPRI:
[C66xx_2] unexpected payload length:8832, 65280
[C66xx_3] Beginning AIF2 LTE CPRI:
[C66xx_1] test: CPRI_4X_LTE_20MHZ_2LINK
[C66xx_2] unexpected payload length:8768, 65280
[C66xx_3] test: CPRI_4X_LTE_20MHZ_2LINK
[C66xx_1] AIF CPRI mode
[C66xx_3] AIF CPRI mode
[C66xx_1] link 0 runs at 4x rate
[C66xx_2] unexpected payload length:8768, 0
[C66xx_3] link 0 runs at 4x rate
[C66xx_1]         outbound data type: DL
[C66xx_3]         outbound data type: DL
[C66xx_1]         outbound data width: 15 bit
[C66xx_3]         outbound data width: 15 bit
[C66xx_1]         inbound data type: DL
[C66xx_3]         inbound data type: DL
[C66xx_1]         inbound data width: 15 bit
[C66xx_3]         inbound data width: 15 bit
[C66xx_1] link 1 runs at 4x rate
[C66xx_3] link 1 runs at 4x rate
[C66xx_1] link 2 is disabled
[C66xx_3] link 2 is disabled
[C66xx_1] link 3 is disabled
[C66xx_2] unexpected payload length:8832, 0
[C66xx_3] link 3 is disabled
[C66xx_1] link 4 is disabled
[C66xx_3] link 4 is disabled
[C66xx_1] link 5 is disabled
[C66xx_3] link 5 is disabled
[C66xx_2] unexpected payload length:8768, 1888
unexpected payload length:8768, 33024
unexpected payload length:8832, 33024
[C66xx_0] Beginning AIF2 LTE CPRI:
[C66xx_1] unexpected payload length:8832, 0
[C66xx_3] unexpected payload length:8832, 0
[C66xx_0] test: CPRI_4X_LTE_20MHZ_2LINK
[C66xx_1] unexpected payload length:8768, 1888
[C66xx_3] unexpected payload length:8768, 1888
[C66xx_0] AIF CPRI mode
[C66xx_0] link 0 runs at 4x rate
[C66xx_0]         outbound data type: DL
[C66xx_0]         outbound data width: 15 bit
[C66xx_0]         inbound data type: DL
[C66xx_0]         inbound data width: 15 bit
[C66xx_1] unexpected payload length:8832, 1888
[C66xx_3] unexpected payload length:8832, 1888
[C66xx_0] link 1 runs at 4x rate
[C66xx_0] link 2 is disabled
[C66xx_0] link 3 is disabled
link 4 is disabled
link 5 is disabled
[C66xx_2]  Number of monolithic packets received in RX queue channel0: 0
 Number of monolithic packets in TX free queue for channel0: 0
 Number of monolithic packets received in RX queue channel1: 0
 Number of monolithic packets in TX free queue for channel1: 0
 Test a) Packet Payload: FAIL on chan:0  symbol:0  received:16  expected:1  position:1
 Test a) Packet Payload: FAIL on chan:0  symbol:1  received:0  expected:65536  position:0
 Test a) Packet Payload: FAIL on chan:0  symbol:2  received:0  expected:131072  position:0
 Test a) Packet Payload: FAIL on chan:0  symbol:3  received:0  expected:196608  position:0
 Test a) Packet Payload: FAIL on chan:0  symbol:4  received:0  expected:262144  position:0
 Test a) Packet Payload: FAIL on chan:0  symbol:5  received:0  expected:327680  position:0
 Test a) Packet Payload: FAIL on chan:0  symbol:6  received:0  expected:393216  position:0
 Test a) Packet Payload: FAIL on chan:0  symbol:7  received:0  expected:458752  position:0
 Test a) Packet Payload: FAIL on chan:0  symbol:8  received:0  expected:524288  position:0
 Test a) Packet Payload: FAIL on chan:0  symbol:9  received:0  expected:589824  position:0
 Test a) Packet Payload: FAIL on chan:0  symbol:10  received:0  expected:655360  position:0
 Test a) Packet Payload: FAIL on chan:0  symbol:11  received:0  expected:720896  position:0
 Test a) Packet Payload: FAIL on chan:0  symbol:12  received:0  expected:786432  position:0
 Test a) Packet Payload: FAIL on chan:0  symbol:13  received:0  expected:851968  position:0
 Test a) Packet Payload: FAIL on chan:0  symbol:14  received:0  expected:917504  position:0
 Test a) Packet Payload: FAIL on chan:0  symbol:15  received:0  expected:983040  position:0
 Test a) Packet Payload: FAIL on chan:0  symbol:16  received:0  expected:1048576  position:0
 Test a) Packet Payload: FAIL on chan:0  symbol:17  received:0  expected:1114112  position:0
 Test a) Packet Payload: FAIL on chan:0  symbol:18  received:0  expected:1179648  position:0
 Test a) Packet Payload: FAIL on chan:0  symbol:19  received:0  expected:1245184  position:0
 Test a) Packet Payload: FAIL on chan:0  symbol:20  received:0  expected:1310720  position:0
 Test a) Packet Payload: FAIL on chan:0  symbol:21  received:0  expected:1376256  position:0
 Test a) Packet Payload: FAIL on chan:0  symbol:22  received:0  expected:1441792  position:0
 Test a) Packet Payload: FAIL on chan:0  symbol:23  received:0  expected:1507328  position:0
 Test a) Packet Payload: FAIL on chan:0  symbol:24  received:0  expected:1572864  position:0
 Test a) Packet Payload: FAIL on chan:0  symbol:25  received:0  expected:1638400  position:0
 Test a) Packet Payload: FAIL on chan:0  symbol:26  received:0  expected:1703936  position:0
 Test a) Packet Payload: FAIL on chan:0  symbol:27  received:0  expected:1769472  position:0
 Test a) Monolithic Packet Data Recv: on chan: 0 are :0
 Test a) Packet Payload: FAIL on chan:1  symbol:0  received:0  expected:16777216  position:0
 Test a) Packet Payload: FAIL on chan:1  symbol:1  received:0  expected:16842752  position:0
 Test a) Packet Payload: FAIL on chan:1  symbol:2  received:0  expected:16908288  position:0
 Test a) Packet Payload: FAIL on chan:1  symbol:3  received:0  expected:16973824  position:0
 Test a) Packet Payload: FAIL on chan:1  symbol:4  received:0  expected:17039360  position:0
 Test a) Packet Payload: FAIL on chan:1  symbol:5  received:0  expected:17104896  position:0
 Test a) Packet Payload: FAIL on chan:1  symbol:6  received:0  expected:17170432  position:0
 Test a) Packet Payload: FAIL on chan:1  symbol:7  received:0  expected:17235968  position:0
 Test a) Packet Payload: FAIL on chan:1  symbol:8  received:0  expected:17301504  position:0
 Test a) Packet Payload: FAIL on chan:1  symbol:9  received:0  expected:17367040  position:0
 Test a) Packet Payload: FAIL on chan:1  symbol:10  received:0  expected:17432576  position:0
 Test a) Packet Payload: FAIL on chan:1  symbol:11  received:0  expected:17498112  position:0
 Test a) Packet Payload: FAIL on chan:1  symbol:12  received:0  expected:17563648  position:0
 Test a) Packet Payload: FAIL on chan:1  symbol:13  received:0  expected:17629184  position:0
 Test a) Packet Payload: FAIL on chan:1  symbol:14  received:0  expected:17694720  position:0
 Test a) Packet Payload: FAIL on chan:1  symbol:15  received:0  expected:17760256  position:0
 Test a) Packet Payload: FAIL on chan:1  symbol:16  received:0  expected:17825792  position:0
 Test a) Packet Payload: FAIL on chan:1  symbol:17  received:0  expected:17891328  position:0
 Test a) Packet Payload: FAIL on chan:1  symbol:18  received:0  expected:17956864  position:0
 Test a) Packet Payload: FAIL on chan:1  symbol:19  received:0  expected:18022400  position:0
 Test a) Packet Payload: FAIL on chan:1  symbol:20  received:0  expected:18087936  position:0
 Test a) Packet Payload: FAIL on chan:1  symbol:21  received:0  expected:18153472  position:0
 Test a) Packet Payload: FAIL on chan:1  symbol:22  received:0  expected:18219008  position:0
 Test a) Packet Payload: FAIL on chan:1  symbol:23  received:0  expected:18284544  position:0
 Test a) Packet Payload: FAIL on chan:1  symbol:24  received:0  expected:18350080  position:0
 Test a) Packet Payload: FAIL on chan:1  symbol:25  received:0  expected:18415616  position:0
 Test a) Packet Payload: FAIL on chan:1  symbol:26  received:0  expected:18481152  position:0
 Test a) Packet Payload: FAIL on chan:1  symbol:27  received:0  expected:18546688  position:0
 Test a) Monolithic Packet Data Recv: on chan: 1 are :0
 Test a) Packet Payload: FAIL on chan:2  symbol:0  received:0  expected:33554432  position:0
 Test a) Packet Payload: FAIL on chan:2  symbol:1  received:0  expected:33619968  position:0
 Test a) Packet Payload: FAIL on chan:2  symbol:2  received:0  expected:33685504  position:0
 Test a) Packet Payload: FAIL on chan:2  symbol:3  received:0  expected:33751040  position:0
 Test a) Packet Payload: FAIL on chan:2  symbol:4  received:0  expected:33816576  position:0
 Test a) Packet Payload: FAIL on chan:2  symbol:5  received:0  expected:33882112  position:0
 Test a) Packet Payload: FAIL on chan:2  symbol:6  received:0  expected:33947648  position:0
 Test a) Packet Payload: FAIL on chan:2  symbol:7  received:0  expected:34013184  position:0
 Test a) Packet Payload: FAIL on chan:2  symbol:8  received:0  expected:34078720  position:0
 Test a) Packet Payload: FAIL on chan:2  symbol:9  received:0  expected:34144256  position:0
 Test a) Packet Payload: FAIL on chan:2  symbol:10  received:0  expected:34209792  position:0
 Test a) Packet Payload: FAIL on chan:2  symbol:11  received:0  expected:34275328  position:0
 Test a) Packet Payload: FAIL on chan:2  symbol:12  received:0  expected:34340864  position:0
 Test a) Packet Payload: FAIL on chan:2  symbol:13  received:0  expected:34406400  position:0
 Test a) Packet Payload: FAIL on chan:2  symbol:14  received:0  expected:34471936  position:0
 Test a) Packet Payload: FAIL on chan:2  symbol:15  received:0  expected:34537472  position:0
 Test a) Packet Payload: FAIL on chan:2  symbol:16  received:0  expected:34603008  position:0
 Test a) Packet Payload: FAIL on chan:2  symbol:17  received:0  expected:34668544  position:0
 Test a) Packet Payload: FAIL on chan:2  symbol:18  received:0  expected:34734080  position:0
 Test a) Packet Payload: FAIL on chan:2  symbol:19  received:0  expected:34799616  position:0
 Test a) Packet Payload: FAIL on chan:2  symbol:20  received:0  expected:34865152  position:0
 Test a) Packet Payload: FAIL on chan:2  symbol:21  received:0  expected:34930688  position:0
 Test a) Packet Payload: FAIL on chan:2  symbol:22  received:0  expected:34996224  position:0
 Test a) Packet Payload: FAIL on chan:2  symbol:23  received:0  expected:35061760  position:0
 Test a) Packet Payload: FAIL on chan:2  symbol:24  received:0  expected:35127296  position:0
 Test a) Packet Payload: FAIL on chan:2  symbol:25  received:0  expected:35192832  position:0
 Test a) Packet Payload: FAIL on chan:2  symbol:26  received:0  expected:35258368  position:0
 Test a) Packet Payload: FAIL on chan:2  symbol:27  received:0  expected:35323904  position:0
 Test a) Monolithic Packet Data Recv: on chan: 2 are :0
 Test a) Packet Payload: FAIL on chan:3  symbol:0  received:0  expected:50331648  position:0
 Test a) Packet Payload: FAIL on chan:3  symbol:1  received:0  expected:50397184  position:0
 Test a) Packet Payload: FAIL on chan:3  symbol:2  received:0  expected:50462720  position:0
 Test a) Packet Payload: FAIL on chan:3  symbol:3  received:0  expected:50528256  position:0
 Test a) Packet Payload: FAIL on chan:3  symbol:4  received:0  expected:50593792  position:0
 Test a) Packet Payload: FAIL on chan:3  symbol:5  received:0  expected:50659328  position:0
 Test a) Packet Payload: FAIL on chan:3  symbol:6  received:0  expected:50724864  position:0
 Test a) Packet Payload: FAIL on chan:3  symbol:7  received:0  expected:50790400  position:0
 Test a) Packet Payload: FAIL on chan:3  symbol:8  received:0  expected:50855936  position:0
 Test a) Packet Payload: FAIL on chan:3  symbol:9  received:0  expected:50921472  position:0
 Test a) Packet Payload: FAIL on chan:3  symbol:10  received:0  expected:50987008  position:0
 Test a) Packet Payload: FAIL on chan:3  symbol:11  received:0  expected:51052544  position:0
 Test a) Packet Payload: FAIL on chan:3  symbol:12  received:0  expected:51118080  position:0
 Test a) Packet Payload: FAIL on chan:3  symbol:13  received:0  expected:51183616  position:0
 Test a) Packet Payload: FAIL on chan:3  symbol:14  received:0  expected:51249152  position:0
 Test a) Packet Payload: FAIL on chan:3  symbol:15  received:0  expected:51314688  position:0
 Test a) Packet Payload: FAIL on chan:3  symbol:16  received:0  expected:51380224  position:0
 Test a) Packet Payload: FAIL on chan:3  symbol:17  received:0  expected:51445760  position:0
 Test a) Packet Payload: FAIL on chan:3  symbol:18  received:0  expected:51511296  position:0
 Test a) Packet Payload: FAIL on chan:3  symbol:19  received:0  expected:51576832  position:0
 Test a) Packet Payload: FAIL on chan:3  symbol:20  received:0  expected:51642368  position:0
 Test a) Packet Payload: FAIL on chan:3  symbol:21  received:0  expected:51707904  position:0
 Test a) Packet Payload: FAIL on chan:3  symbol:22  received:0  expected:51773440  position:0
 Test a) Packet Payload: FAIL on chan:3  symbol:23  received:0  expected:51838976  position:0
 Test a) Packet Payload: FAIL on chan:3  symbol:24  received:0  expected:51904512  position:0
 Test a) Packet Payload: FAIL on chan:3  symbol:25  received:0  expected:51970048  position:0
 Test a) Packet Payload: FAIL on chan:3  symbol:26  received:0  expected:52035584  position:0
 Test a) Packet Payload: FAIL on chan:3  symbol:27  received:0  expected:52101120  position:0
 Test a) Monolithic Packet Data Recv: on chan: 3 are :0
 Test a) Monolithic Packet Data Send/Recv: FAIL
 Test b1) Monolithic Packet Tx Descriptor Counts:0 PASS
 Test b2) Monolithic Packet Tx Complete Descriptor Counts:0 FAIL
 Test b3) Monolithic Packet Rx Descriptor Counts:0 PASS
 Test b4) Monolithic Packet Rx Free Descriptor Counts:0 FAIL
######### AIF2 ERRORS ###########
######### AIF2 INFO ##############
Ending CPRI_4X_LTE_20MHZ_2LINK test
Test: ending AIF2 LTE 20Mhz CPRI PkDMA
Some tests have failed
Thank you.
