Other Parts Discussed in Thread: AM3358
I'm looking for an Orcad PCB Symbol (Cell) for the AM3358. Do you have a recommendation.
I started with the AM3358 Product Page--http://www.ti.com/product/am3358
At the bottom there is a link for a file called AM3358_ZCZ_324.bxl. The Ultra Librarian App uses it to create pads, and symbol drawings for Orcad. The problem is I'm concerned about the Symbols that are produced. The pins don't have a Solder Mask. As such they'll be covered and unusable.
I'm content to hand edit the Pad Files, modify the Orcad Script Files and modify the the componets to be the way I want them to be, but I wanted to check first. Do I misunderstand? Should I be using the files as is? Is there another source? Or am I right. The BXL files that I download are starters. They don't always define things like Solder Mask or Solder Paste and I should use them as a point of departure rather than expect to be able to use them without modification.
Thanks so much for your time and your help.
