We are currently using IPC, but will need to also use EDMA LLD in the same application. Internally EDMA LDD uses DSP's event combiner module in the cfg file:
ECM.eventGroupHwiNum[0] = 7;
ECM.eventGroupHwiNum[1] = 8;
ECM.eventGroupHwiNum[2] = 9;
ECM.eventGroupHwiNum[3] = 10;
However, keeping the above lines in cfg causes Ipc_start() to fail. if we remove the above, QDMA fails with infinite loop.
[C674X_0] waiting for interrupt...
We need an example cfg that shows how to use IPC and EDMA together in the DSP. In particular something along the line:
EventCombiner .events[X].unmask = true;
I need the info in red, that would configure IPC module interrupts properly to the IPC assigned Hwi directly instead of going through the eventcombiner module.
RV
