Attempting to add custom LCD to OMAP5 DSS (on HDMI)
Other Parts Discussed in Thread: TCA6424
hello,
I'm attempting to add a custom LCD via HDMI for use on the OMAP5 uevm5432 board. Most COTS monitors are working but this is a custom 800x480 LCD. The error I get is:
[ 4.253845] Failed to set PHY power mode to 2
[ 4.254058] omapdss HDMI error: failed to power on device
[ 4.254058] omapdss error: failed to power on
I've enabled FB debugging for EDID support and added some of my own debugging (see below). I was wondering if anyone knew why I cannot power on the PHY?
Build Info: Sep 26 2013 - 14:34:19
OMAP reset reason PRM_RSTST = 0x0001
PMIC reset reason SWOFF_STATUS = 0x00
sram: boot device: EMMC
kernel @ 80008000 (4872360)
ramdisk @ 81000000 (184217)
Device Serial Number: 2E6604F04A020121
booting kernel...
Uncompressing Linux... done, booting the kernel.
[ 0.000000] Booting Linux on physical CPU 0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.4.34-01535-g499e8d5-dirty (bbergan@weapon-linux-bab) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #49 SMP PREEMPT Tue Oct 29 22:07:52 PDT 2013
[ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] Machine: OMAP5 panda board
[ 0.000000] Truncating memory at 0x80000000 to fit in 32-bit physical address space
[ 0.000000] Cannot detect omap type!
[ 0.000000] Reserving 20971520 bytes SDRAM for VRAM
[ 0.000000] cma: CMA: reserved 16 MiB at 93000000
[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000] OMAP4: Map 0x9fe00000 to 0xfe600000 for dram barrier
[ 0.000000] OMAP5432 ES2.0
[ 0.000000] FIXME: omap5 opp layer init
[ 0.000000] PERCPU: Embedded 8 pages/cpu @c1834000 s12032 r8192 d12544 u32768
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 164864
[ 0.000000] Kernel command line: console=ttyO2,115200n8 androidboot.console=ttyO2 omap_wdt.timer_margin=30 vmalloc=496M omapfb.fb_opt=-1,-1,-1,1,1280,720 console=ttyO2,115200n8 mem=1024M androidboot.console=ttyO2 vram=20M omapfb.vram=0:16M earlyprintk androidboot.serialno=2E6604F04A020121 androidboot.bootloader=Texas Instruments Inc Bootloader 1.1.0-g33af7cb4-dir
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 324MB 2MB 323MB 3MB = 652MB total
[ 0.000000] Memory: 630732k/630732k available, 417844k reserved, 333824K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc08e6000 (9080 kB)
[ 0.000000] .init : 0xc08e6000 - 0xc093cf00 ( 348 kB)
[ 0.000000] .data : 0xc093e000 - 0xc09e1ac0 ( 655 kB)
[ 0.000000] .bss : 0xc09e1ae4 - 0xc0b5b4f0 (1511 kB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:626
[ 0.000000] OMAP clockevent source: GPTIMER1 at 32768 Hz
[ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 131071999ms
[ 0.000000] Architected local timer running at 6.14MHz.
[ 0.000183] Calibrating delay loop... 1590.23 BogoMIPS (lpj=6213632)
[ 0.031341] pid_max: default: 32768 minimum: 301
[ 0.031463] Security Framework initialized
[ 0.031555] Mount-cache hash table entries: 512
[ 0.032379] Initializing cgroup subsys debug
[ 0.032409] Initializing cgroup subsys cpuacct
[ 0.032409] Initializing cgroup subsys freezer
[ 0.032409] Initializing cgroup subsys net_cls
[ 0.032470] CPU: Testing write buffer coherency: ok
[ 0.032623] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.032836] hw perfevents: enabled with ARMv7 Cortex-A15 PMU driver, 7 counters available
[ 0.032897] Setting up static identity map for 0x806820f0 - 0x80682148
[ 0.033142] generating sar_ram layout...
[ 0.033447] sar ram layout created
[ 0.111602] CPU1: Booted secondary processor
[ 0.142395] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.142425] CPU1: Unknown IPI message 0x1
[ 0.142486] Brought up 2 CPUs
[ 0.142486] SMP: Total of 2 processors activated (3188.82 BogoMIPS).
[ 0.151885] omap_hwmod: aess: _wait_target_disable failed
[ 0.154724] omap_hwmod: dss_dispc: cannot be enabled (3)
[ 0.157409] omap_hwmod: dss_dsi1_a: cannot be enabled (3)
[ 0.160125] omap_hwmod: dss_dsi1_c: cannot be enabled (3)
[ 0.162811] omap_hwmod: dss_hdmi: cannot be enabled (3)
[ 0.165496] omap_hwmod: dss_rfbi: cannot be enabled (3)
[ 0.169921] omap_hwmod: mcpdm: cannot be enabled (3)
[ 0.170562] omap_hwmod: usb_otg_ss: setting DMADISABLE
[ 0.171813] omap_device: cannot add global notifier for dev PM QoS
[ 0.172363] dummy:
[ 0.173004] NET: Registered protocol family 16
[ 0.174987] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.176788] gpiochip_add: registered GPIOs 0 to 31 on device: gpio
[ 0.176879] OMAP GPIO hardware version 0.1
[ 0.177032] gpiochip_add: registered GPIOs 32 to 63 on device: gpio
[ 0.177276] gpiochip_add: registered GPIOs 64 to 95 on device: gpio
[ 0.177520] gpiochip_add: registered GPIOs 96 to 127 on device: gpio
[ 0.177734] gpiochip_add: registered GPIOs 128 to 159 on device: gpio
[ 0.177978] gpiochip_add: registered GPIOs 160 to 191 on device: gpio
[ 0.178192] gpiochip_add: registered GPIOs 192 to 223 on device: gpio
[ 0.178436] gpiochip_add: registered GPIOs 224 to 255 on device: gpio
[ 0.179534] omap_mux_init: Add partition: #1: core, flags: 4
[ 0.180236] omap_mux_init: Add partition: #2: wkup, flags: 4
[ 0.180603] RED TOUCH: GPIO 197 allocated for IRQ
[ 0.180633] RED TOUCH: GPIO mapped to IRQ 389
[ 0.181610] Failed to get l3_init_clkdm
[ 0.187499] dmm dmm: initialized all PAT entries
[ 0.188385] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.188385] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.192535] OMAP DMA hardware revision 0.0
[ 0.193969] SmartReflex Recalibration delay = 86400000ms
[ 0.193969] SmartReflex Class 1.5 initialized
[ 0.194213] Reprogramming LPDDR2 timings to 532000000 Hz
[ 0.200378] bio: create slab <bio-0> at 0
[ 0.200866] vmmc_supply: 3000 mV
[ 0.201049] vwl1271: 1800 mV
[ 0.201843] SCSI subsystem initialized
[ 0.202026] usbcore: registered new interface driver usbfs
[ 0.202117] usbcore: registered new interface driver hub
[ 0.202209] usbcore: registered new device driver usb
[ 0.210601] i2c-gpio i2c-gpio: using pins 195 (SDA) and 194 (SCL)
[ 0.210784] omap_i2c omap_i2c.1: bus 1 rev2.4.0 at 400 kHz
[ 0.243499] setting trigger mode 8 for irq 39 failed (gic_set_type+0x0/0xe8)
[ 0.243652] palmas 1-0048: twl6035 ES 2.1 detected
[ 0.243957] palmas 1-0048: Muxing GPIO 2, PWM 0, LED 0
[ 0.245025] SMPS45: 600 <--> 1310 mV at 880 mV normal standby
[ 0.245727] SMPS6: 1200 mV normal standby
[ 0.246398] SMPS7: 1800 mV normal standby
[ 0.247222] SMPS8: 600 <--> 1310 mV at 1040 mV normal standby
[ 0.247985] SMPS9: 2100 mV normal standby
[ 0.248504] SMPS10: 5000 mV normal standby
[ 0.248779] LDO1: 2800 mV normal standby
[ 0.249420] LDO2: 2900 mV normal standby
[ 0.249938] LDO3: 3000 mV normal standby
[ 0.250579] LDO4: 1500 mV normal standby
[ 0.251098] LDO5: 1800 mV normal standby
[ 0.251617] LDO6: 1500 mV normal standby
[ 0.252166] LDO7: 1500 mV normal standby
[ 0.252685] LDO8: 1500 mV normal standby
[ 0.253356] LDO9: 1800 <--> 3300 mV at 900 mV normal standby
[ 0.254119] LDOLN: 1800 mV normal standby
[ 0.254638] LDOUSB: 3250 mV normal standby
[ 0.256011] omap_i2c omap_i2c.2: bus 2 rev2.4.0 at 50 kHz
[ 0.256286] omap_i2c omap_i2c.3: bus 3 rev2.4.0 at 400 kHz
[ 0.256469] omap_i2c omap_i2c.4: bus 4 rev2.4.0 at 400 kHz
[ 0.256652] omap_i2c omap_i2c.5: bus 5 rev2.4.0 at 400 kHz
[ 0.258331] gpiochip_add: registered GPIOs 256 to 279 on device: tca6424
[ 0.258453] Linux video capture interface: v2.00
[ 0.258514] sr_init: No PMIC hook to init smartreflex
[ 0.258911] omap-iommu omap-iommu.0: dsp registered
[ 0.258972] omap-iommu omap-iommu.1: ipu registered
[ 0.259155] Advanced Linux Sound Architecture Driver Version 1.0.25.
[ 0.259613] Bluetooth: Core ver 2.16
[ 0.259643] NET: Registered protocol family 31
[ 0.259643] Bluetooth: HCI device and connection manager initialized
[ 0.259674] Bluetooth: HCI socket layer initialized
[ 0.259674] Bluetooth: L2CAP socket layer initialized
[ 0.259704] Bluetooth: SCO socket layer initialized
[ 0.268310] smartreflex smartreflex.0: omap_sr_probe: SmartReflex driver initialized
[ 0.268585] smartreflex smartreflex.1: omap_sr_probe: SmartReflex driver initialized
[ 0.268859] smartreflex smartreflex.2: omap_sr_probe: SmartReflex driver initialized
[ 0.268859] Power Management for TI OMAP4XX/OMAP5XXX devices.
[ 0.268981] ------------[ cut here ]------------
[ 0.268981] WARNING: at arch/arm/mach-omap2/pm4xxx_5xxx.c:750 omap4_pm_init+0x844/0xc34()
[ 0.268981] Enabled DSS->EMIF Static dependency, needs proper rootcause
[ 0.269012] Modules linked in:
[ 0.269012] Backtrace:
[ 0.269042] [<c0017c04>] (dump_backtrace+0x0/0x10c) from [<c0671064>] (dump_stack+0x18/0x1c)
[ 0.269042] r6:000002ee r5:c08f5870 r4:d402dec8 r3:c09a0850
[ 0.269073] [<c067104c>] (dump_stack+0x0/0x1c) from [<c0046464>] (warn_slowpath_common+0x54/0x6c)
[ 0.269104] [<c0046410>] (warn_slowpath_common+0x0/0x6c) from [<c0046520>] (warn_slowpath_fmt+0x38/0x40)
[ 0.269104] r8:00000000 r7:c099db74 r6:c099db44 r5:c099dbd4 r4:00000000
[ 0.269134] r3:00000009
[ 0.269134] [<c00464e8>] (warn_slowpath_fmt+0x0/0x40) from [<c08f5870>] (omap4_pm_init+0x844/0xc34)
[ 0.269165] r3:c09e2ea4 r2:c081b554
[ 0.269165] [<c08f502c>] (omap4_pm_init+0x0/0xc34) from [<c08f1e28>] (omap2_common_pm_subsys_init+0x188/0x21c)
[ 0.269195] [<c08f1ca0>] (omap2_common_pm_subsys_init+0x0/0x21c) from [<c0008698>] (do_one_initcall+0x11c/0x184)
[ 0.269195] r5:00000004 r4:d402c000
[ 0.269226] [<c000857c>] (do_one_initcall+0x0/0x184) from [<c08e698c>] (kernel_init+0x104/0x1c4)
[ 0.269226] [<c08e6888>] (kernel_init+0x0/0x1c4) from [<c004a378>] (do_exit+0x0/0x804)
[ 0.269256] Board Information:
[ 0.269256] Revision : 0000
[ 0.269256] Serial : 0000000000000000
[ 0.269287] SoC Information:
[ 0.269287] CPU : OMAP5432
[ 0.269287] Rev : ES2.0
[ 0.269287] Type : GP
[ 0.269287] Production ID: D0110451-2E6604F0
[ 0.269287] Die ID : 4A020121-00000505-015D616E-0900700F
[ 0.269287]
[ 0.269317] ---[ end trace 41a323a727a49dd3 ]---
[ 0.269531] ------------[ cut here ]------------
[ 0.269561] WARNING: at arch/arm/mach-omap2/pm4xxx_5xxx.c:1235 omap4_pm_init+0xb24/0xc34()
[ 0.269561] omap4_pm_init: EMIF Clock domain denied idle: DDR3 WA
[ 0.269592] Modules linked in:
[ 0.269592] Backtrace:
[ 0.269592] [<c0017c04>] (dump_backtrace+0x0/0x10c) from [<c0671064>] (dump_stack+0x18/0x1c)
[ 0.269622] r6:000004d3 r5:c08f5b50 r4:d402dec8 r3:c09a0850
[ 0.269653] [<c067104c>] (dump_stack+0x0/0x1c) from [<c0046464>] (warn_slowpath_common+0x54/0x6c)
[ 0.269653] [<c0046410>] (warn_slowpath_common+0x0/0x6c) from [<c0046520>] (warn_slowpath_fmt+0x38/0x40)
[ 0.269683] r8:00000000 r7:c099db74 r6:c099db44 r5:00000003 r4:00000000
[ 0.269683] r3:00000009
[ 0.269714] [<c00464e8>] (warn_slowpath_fmt+0x0/0x40) from [<c08f5b50>] (omap4_pm_init+0xb24/0xc34)
[ 0.269714] r3:c0684a68 r2:c081b79c
[ 0.269744] [<c08f502c>] (omap4_pm_init+0x0/0xc34) from [<c08f1e28>] (omap2_common_pm_subsys_init+0x188/0x21c)
[ 0.269775] [<c08f1ca0>] (omap2_common_pm_subsys_init+0x0/0x21c) from [<c0008698>] (do_one_initcall+0x11c/0x184)
[ 0.269775] r5:00000004 r4:d402c000
[ 0.269805] [<c000857c>] (do_one_initcall+0x0/0x184) from [<c08e698c>] (kernel_init+0x104/0x1c4)
[ 0.269805] [<c08e6888>] (kernel_init+0x0/0x1c4) from [<c004a378>] (do_exit+0x0/0x804)
[ 0.269836] Board Information:
[ 0.269836] Revision : 0000
[ 0.269836] Serial : 0000000000000000
[ 0.269836] SoC Information:
[ 0.269866] CPU : OMAP5432
[ 0.269866] Rev : ES2.0
[ 0.269866] Type : GP
[ 0.269866] Production ID: D0110451-2E6604F0
[ 0.269866] Die ID : 4A020121-00000505-015D616E-0900700F
[ 0.269866]
[ 0.269897] ---[ end trace 41a323a727a49dd4 ]---
[ 0.269897] omap_opp_set_min_rate: Missing opp info for hwmod hsi
[ 0.269927] Forcing clock hsi_fclk to minimum rate 192000000
[ 0.269958] omap_opp_set_min_rate: Missing opp info for hwmod ipu_c0
[ 0.269958] Forcing clock dpll_core_h22x2_ck to minimum rate 425600000
[ 0.269989] omap_opp_set_min_rate: Missing opp info for hwmod dsp_c0
[ 0.269989] Forcing clock virt_dpll_dsp_ck to minimum rate 233000000
[ 0.270446] Switching to clocksource arch_sys_counter
[ 0.283996] NET: Registered protocol family 2
[ 0.284179] IP route cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.284576] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.285583] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
[ 0.286773] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.286804] TCP: reno registered
[ 0.286804] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.286834] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.287017] NET: Registered protocol family 1
[ 0.287292] RPC: Registered named UNIX socket transport module.
[ 0.287292] RPC: Registered udp transport module.
[ 0.287292] RPC: Registered tcp transport module.
[ 0.287322] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.287384] usbhs_omap usbhs_omap: ehci_logic_fck failed:-2
[ 0.288177] Trying to unpack rootfs image as initramfs...
[ 0.297149] Freeing initrd memory: 176K
[ 0.297454] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.301818] sr_classp5_calib_work: smartreflex_mpu: Calibration complete: Voltage Nominal=1060000 Calib=1060000 Dyn=1060000 OPP_margin=0 total_margin=0
[ 0.301849] sr_classp5_calib_work: smartreflex_mm: Calibration complete: Voltage Nominal=1120000 Calib=1120000 Dyn=1120000 OPP_margin=0 total_margin=0
[ 0.317413] sr_classp5_calib_work: smartreflex_core: Calibration complete: Voltage Nominal=1040000 Calib=1030000 Dyn=1040000 OPP_margin=0 total_margin=0
[ 0.406829] highmem bounce pool size: 64 pages
[ 0.407623] fuse init (API version 7.18)
[ 0.407745] msgmni has been set to 612
[ 0.409149] io scheduler noop registered
[ 0.409179] io scheduler deadline registered
[ 0.409210] io scheduler cfq registered (default)
[ 0.409942] OMAP DSS rev 6.1
[ 0.430633] dsscomp: initializing.
[ 0.430664] misc dsscomp: found 1 displays and 4 overlays, WB overlay 1
[ 0.431274] omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 104) is a OMAP UART0
[ 0.431579] omap_uart.2: ttyO2 at MMIO 0x48020000 (irq = 106) is a OMAP UART2
[ 1.823516] console [ttyO2] enabled
[ 1.827270] Calling hdmi_hotplug_detect_worker
[ 1.832061] Calling hdmi_read_valid_edid
[ 1.833496] omap_uart.4: ttyO4 at MMIO 0x48066000 (irq = 137) is a OMAP UART4
[ 1.834259] [drm] Initialized drm 1.1.0 20060810
[ 1.834503] omap_ion_probe: adding heap secure_input of type 2 with ba300000@5a00000
[ 1.834533] omap_ion_probe: adding heap tiler of type 4 with b5200000@5100000
[ 1.834564] omap_ion_probe: adding heap nonsecure_tiler of type 4 with b4300000@f00000
[ 1.834594] omap_ion_probe: adding heap system of type 0 with 0@0
[ 1.834625] omap_ion_probe: adding heap tiler_reservation of type 5 with 0@0
[ 1.842071] brd: module loaded
[ 1.845855] loop: module loaded
[ 1.845977] (stk) :sysfs entries created
[ 1.846038] (stk) : debugfs entries created
[ 1.846191] (hci_tty): inside hci_tty_init
[ 1.846313] (hci_tty): allocated 252, 0
[ 1.846343] AK8975 compass driver: init
[ 1.915252] Calling hdmi_read_valid_edid ... ops->read_edid()
[ 1.915405] gccore gccore.0: opp_get_opp_count: device OPP not found (-19)
[ 1.928802] ti_hdmi_5xxx_read_edid
[ 1.932586] Calling hdmi_get_monspecs
[ 1.936492] ========================================
[ 1.941772] Display Information (EDID)
[ 1.945770] ========================================
[ 1.951049] EDID Version 1.3
[ 1.954406] Manufacturer: RED
[ 1.957824] Model: 1010
[ 1.960754] Serial#: 1
[ 1.963531] Year: 2009 Week 1
[ 1.966979] Monitor Name: 5 INCH LCD
[ 1.971038] Serial Number: 001
[ 1.974578] ASCII Block: RED
[ 1.977935] Display Characteristics:
[ 1.981994] Monitor Operating Limits: Detailed Timings
[ 1.988311] 29 MHz 800 816 824 830 480 536 538 594 108mm 64mm -HSync -VSync
[ 1.994934]
[ 1.997924] Supported VESA Modes
[ 2.001647] 640x480@60Hz
[ 2.004943] Manufacturer's mask: 0
[ 2.009124] Standard Timings
[ 2.012481] Extrapolated
[ 2.015197] H: 32-36KHz V: 61-61Hz DCLK: 29MHz
[ 2.020935] Digital Display Input
[ 2.024810] Sync:
[ 2.027740] Max H-size in cm: 10
[ 2.031738] Max V-size in cm: 7
[ 2.035644] Gamma: 1.0
[ 2.038726] DPMS: Active no, Suspend no, Standby no
[ 2.044494] RGB Color Display
[ 2.048217] Chroma
[ 2.050903] RedX: 0.640 RedY: 0.330
[ 2.056213] GreenX: 0.300 GreenY: 0.600
[ 2.060028] NFC Driver for TI WiLink BlueX: 0.150
[ 2.065795] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 2.074554] BlueY: 0.001
[ 2.074951] omap2_mcspi omap2_mcspi.1: master is unqueued, this is deprecated
[ 2.075347] omap2_mcspi omap2_mcspi.2: master is unqueued, this is deprecated
[ 2.075897] omap2_mcspi omap2_mcspi.4: master is unqueued, this is deprecated
[ 2.076171] tun: Universal TUN/TAP device driver, 1.6
[ 2.076202] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 2.077056] usbcore: registered new interface driver asix
[ 2.077117] usbcore: registered new interface driver cdc_ether
[ 2.077209] usbcore: registered new interface driver smsc95xx
[ 2.077239] usbcore: registered new interface driver net1080
[ 2.077301] usbcore: registered new interface driver cdc_subset
[ 2.077362] usbcore: registered new interface driver zaurus
[ 2.077423] usbcore: registered new interface driver cdc_ncm
[ 2.154418] WhiteX: 0.313 WhiteY: 0.329
[ 2.159729] Detailed Timings
[ 2.163085] 29 MHz 800 816 824 830 480 536 538 594 108mm 64mm -HSync -VSync
[ 2.169708]
[ 2.172698] Supported VESA Modes
[ 2.176422] 640x480@60Hz
[ 2.179687] Manufacturer's mask: 0
[ 2.183868] Standard Timings
[ 2.187255] ========================================
[ 2.192535] Video Mode (Before):
[ 2.195953] refresh = 59
[ 2.199493] xres = 800
[ 2.203124] yres = 480
[ 2.206756] pixclock = 33806
[ 2.210571] left margin = 6
[ 2.214050] right margin = 16
[ 2.217590] upper margin = 56
[ 2.221130] lower margin = 56
[ 2.224670] hsync_len = 8
[ 2.228118] vsync_len = 2
[ 2.231567] sync = 0
[ 2.235015] flag = 17
[ 2.238555] vmode = 0
[ 2.242004] Calling hdmi_get_monspecs : Filtering out due to timings
[ 2.248626] Calling hdmi_get_monspecs MODE DB LENGTH = 1
[ 2.309570] Calling hdmi_hotplug_detect_worker
[ 2.314941] HDCP: hdcp_3des_cb: hdcp_keys not loaded = 0
[ 2.314971]
[ 2.339935] Failed to set PHY power mode to 2
[ 2.344726] omapdss HDMI error: failed to power on device
[ 2.350524] omapdss error: failed to power on
[ 2.355316] input: cec_keyboard as /devices/virtual/input/input0
[ 2.872070] PC detected
[ 2.880371] palmas-usb palmas-usb.8: Initialized Palmas USB module
[ 2.887207] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.894500] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 2.900634] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
[ 2.909149] ehci-omap ehci-omap.0: irq 109, io mem 0x4a064c00
[ 2.926757] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 2.932922] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.940093] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.947692] usb usb1: Product: OMAP-EHCI Host Controller
[ 2.953277] usb usb1: Manufacturer: Linux 3.4.34-01535-g499e8d5-dirty ehci_hcd
[ 2.960876] usb usb1: SerialNumber: ehci-omap.0
[ 2.966003] hub 1-0:1.0: USB hub found
[ 2.969940] hub 1-0:1.0: 3 ports detected
[ 3.005065] usbcore: registered new interface driver cdc_wdm
[ 3.011016] Initializing USB Mass Storage driver...
[ 3.016235] usbcore: registered new interface driver usb-storage
[ 3.022552] USB Mass Storage support registered.
[ 3.027465] usbcore: registered new interface driver libusual
[ 3.033569] usbcore: registered new interface driver usbtest
[ 3.039520] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[ 3.046051] file system registered
[ 3.050415] gadget: Mass Storage Function, version: 2009/09/11
[ 3.056671] gadget: Number of LUNs=1
[ 3.060546] lun0: LUN: removable file: (no medium)
[ 3.065856] gadget: android_usb ready
[ 3.301757] usb 1-2: new high-speed USB device number 2 using ehci-omap
[ 3.473968] usb 1-2: New USB device found, idVendor=0424, idProduct=3503
[ 3.481018] usb 1-2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.505187] hub 1-2:1.0: USB hub found
[ 3.515624] mousedev: PS/2 mouse device common for all mice
[ 3.521514] hub 1-2:1.0: 3 ports detected
[ 3.530273] input: palmas_pwron as /devices/platform/omap_i2c.1/i2c-1/1-0048/palmas-pwrbutton.7/input/input1
[ 3.544158] twl_rtc twl_rtc.9: rtc core: registered twl_rtc as rtc0
[ 3.552154] i2c /dev entries driver
[ 3.556243] usbcore: registered new interface driver uvcvideo
[ 3.562316] USB Video Class driver (1.1.1)
[ 3.566711] Driver for 1-wire Dallas network protocol.
[ 3.573394] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 30 sec
[ 3.580718] report_temperature_delayed_work_fn: Fail to set temp
[ 3.587524] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[ 3.623992] usbcore: registered new interface driver usbhid
[ 3.629882] usbhid: USB HID core driver
[ 3.634185] ashmem: initialized
[ 3.637542] logger: created 256K log 'log_main'
[ 3.642486] logger: created 256K log 'log_events'
[ 3.647613] usb 1-3: new high-speed USB device number 3 using ehci-omap
[ 3.655578] logger: created 256K log 'log_radio'
[ 3.663696] logger: created 256K log 'log_system'
[ 3.669158] omap_governor_init: domain cpu slope 118 const -2992
[ 3.675567] omap_governor_init: domain gpu slope 61 const -1558
[ 3.682067] rproc remoteproc0: ipu_c0 is available
[ 3.687225] rproc remoteproc0: Note: remoteproc is still under development and considered experimental.
[ 3.697204] sr_classp5_calib_work: smartreflex_mpu: Calibration complete: Voltage Nominal=1250000 Calib=1250000 Dyn=1250000 OPP_margin=0 total_margin=0
[ 3.711547] rproc remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 3.723419] OMAP HSI: HSI driver version 0.4.4
[ 3.731292] usbcore: registered new interface driver snd-usb-audio
[ 3.739746] aess aess: ABE Firmware version 9560
[ 3.778228] asoc: snd-soc-dummy-dai <-> MultiMedia1 mapping ok
[ 3.785125] asoc: snd-soc-dummy-dai <-> MultiMedia2 mapping ok
[ 3.792297] mmc0: new high speed DDR MMC card at address 0001
[ 3.798919] asoc: snd-soc-dummy-dai <-> Voice mapping ok
[ 3.804687] mmcblk0: mmc0:0001 SEM04G 3.68 GiB
[ 3.809600] mmcblk0boot0: mmc0:0001 SEM04G partition 1 2.00 MiB
[ 3.816040] asoc: snd-soc-dummy-dai <-> Tones mapping ok
[ 3.816040] mmcblk0boot1: mmc0:0001 SEM04G partition 2 2.00 MiB
[ 3.828216] usb 1-3: New USB device found, idVendor=0424, idProduct=9730
[ 3.835571] usb 1-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.843749] asoc: snd-soc-dummy-dai <-> Vibra mapping ok
[ 3.849670] asoc: snd-soc-dummy-dai <-> MODEM mapping ok
[ 3.849700] smsc95xx v1.0.4
[ 3.858612] asoc: snd-soc-dummy-dai <-> MultiMedia1 LP mapping ok
[ 3.865570] asoc: snd-soc-dummy-dai <-> omap-mcbsp.2 mapping ok
[ 3.871826] Alternate GPT is invalid, using primary GPT.
[ 3.877502] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10
[ 3.883178] asoc: twl6040-legacy <-> mcpdm-legacy mapping ok
[ 3.889526] mmcblk0boot1: unknown partition table
[ 3.894836] asoc: dit-hifi <-> mcasp-legacy mapping ok
[ 3.900634] mmcblk0boot0: unknown partition table
[ 3.905975] asoc: dmic-hifi <-> omap-dmic mapping ok
[ 3.911834] asoc: twl6040-dl1 <-> mcpdm-dl1 mapping ok
[ 3.917449] asoc: twl6040-ul <-> mcpdm-ul1 mapping ok
[ 3.923004] asoc: twl6040-dl2 <-> mcpdm-dl2 mapping ok
[ 3.928680] asoc: twl6040-vib <-> mcpdm-vib mapping ok
[ 3.934326] asoc: snd-soc-dummy-dai <-> omap-mcbsp.1 mapping ok
[ 3.940826] asoc: snd-soc-dummy-dai <-> omap-mcbsp.1 mapping ok
[ 3.947296] asoc: snd-soc-dummy-dai <-> omap-mcbsp.2 mapping ok
[ 3.953765] asoc: snd-soc-dummy-dai <-> omap-mcbsp.2 mapping ok
[ 3.960235] asoc: snd-soc-dummy-dai <-> omap-mcbsp.2 mapping ok
[ 3.966705] asoc: dmic-hifi <-> omap-dmic-abe-dai-0 mapping ok
[ 3.973114] asoc: dmic-hifi <-> omap-dmic-abe-dai-1 mapping ok
[ 3.979492] asoc: dmic-hifi <-> omap-dmic-abe-dai-2 mapping ok
[ 3.985931] asoc: snd-soc-dummy-dai <-> omap-abe-vxrec-dai mapping ok
[ 3.992889] asoc: snd-soc-dummy-dai <-> omap-abe-echo-dai mapping ok
[ 4.000244] input: OMAP5EVM Headset Jack as /devices/platform/omap-abe-twl6040/sound/card0/input2
[ 4.010681] omap-abe-twl6040 omap-abe-twl6040: couldn't get AV Switch regulator
[ 4.019073] asoc: omap-hdmi-hifi <-> omap-hdmi-audio-dai mapping ok
[ 4.026031] mmc2: card claims to support voltages below the defined range. These will be ignored.
[ 4.026367] oprofile: using timer interrupt.
[ 4.039886] GACT probability NOT on
[ 4.043579] Mirror/redirect action on
[ 4.047454] u32 classifier
[ 4.050292] Actions configured
[ 4.053894] Netfilter messages via NETLINK v0.30.
[ 4.058929] nf_conntrack version 0.5.0 (10113 buckets, 40452 max)
[ 4.065582] ctnetlink v0.93: registering with nfnetlink.
[ 4.071228] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 4.078613] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 4.078643] smsc95xx 1-3:1.0: eth0: register 'smsc95xx' at usb-ehci-omap.0-3, smsc95xx USB 2.0 Ethernet, 6a:69:b2:79:82:29
[ 4.096496] xt_time: kernel timezone is -0000
[ 4.101287] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 4.106994] arp_tables: (C) 2002 David S. Miller
[ 4.111877] TCP: cubic registered
[ 4.115356] Initializing XFRM netlink socket
[ 4.119934] NET: Registered protocol family 10
[ 4.125122] Mobile IPv6
[ 4.127716] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 4.133514] IPv6 over IPv4 tunneling driver
[ 4.138488] NET: Registered protocol family 17
[ 4.143157] NET: Registered protocol family 15
[ 4.147888] Bridge firewalling registered
[ 4.152191] Bluetooth: RFCOMM TTY layer initialized
[ 4.157318] Bluetooth: RFCOMM socket layer initialized
[ 4.162719] Bluetooth: RFCOMM ver 1.11
[ 4.166656] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 4.172241] Bluetooth: BNEP filters: protocol multicast
[ 4.177795] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.184020] usb 1-2.2: new low-speed USB device number 4 using ehci-omap
[ 4.184112] NET: Registered protocol family 35
[ 4.195770] NET: Registered protocol family 37
[ 4.200439] NET: Registered protocol family 40
[ 4.205444] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 4.213531] ThumbEE CPU extension supported.
[ 4.218017] Registering SWP/SWPB emulation handler
[ 4.223876] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 4.228210] clock: disabling unused clocks to save power
[ 4.228576] Calling hdmi_read_edid
[ 4.228759] HDCP: hdcp_3des_cb: hdcp_keys not loaded = 0
[ 4.228759]
[ 4.228942] Enter ti_hdmi_5xxx_basic_configure
[ 4.228973] Enter hdmi_core_init
[ 4.228973] Brent was here
[ 4.228973] Calling hdmi_wp_video_init_format
[ 4.229003] Calling hdmi_wp_video_config_timing
[ 4.229003] Calling hdmi_wp_video_config_format
[ 4.229003] Calling hdmi_wp_video_config_interface
[ 4.229003] Enter ti_hdmi_5xxx_configure_range
[ 4.229003] Enter hdmi_core_csc_config
[ 4.229034] Enter hdmi_core_aux_infoframe_avi_config
[ 4.229034] Enter hdmi_core_video_config
[ 4.229064] Enter hdmi_core_config_video_packetizer
[ 4.229095] Enter hdmi_core_config_csc
[ 4.229095] Enter hdmi_core_config_video_sampler
[ 4.229095] Enter hdmi_core_aux_infoframe_avi_config
[ 4.229095] hdmi_enable_video_path
[ 4.229431] Calling omapdss_hdmi_read_edid
[ 4.229431] ti_hdmi_5xxx_read_edid
[ 4.242889] Enter ti_hdmi_5xxx_hdcp_disable
[ 4.243041] ========================================
[ 4.243041] Display Information (EDID)
[ 4.243072] ========================================
[ 4.243072] EDID Version 1.3
[ 4.243072] Manufacturer: RED
[ 4.243072] Model: 1010
[ 4.243072] Serial#: 1
[ 4.243072] Year: 2009 Week 1
[ 4.243103] Monitor Name: 5 INCH LCD
[ 4.243103] Serial Number: 001
[ 4.243103] ASCII Block: RED
[ 4.243103] Display Characteristics:
[ 4.243103] Monitor Operating Limits: Detailed Timings
[ 4.243133] 29 MHz 800 816 824 830 480 536 538 594 108mm 64mm -HSync -VSync
[ 4.243133]
[ 4.243133] Supported VESA Modes
[ 4.243133] 640x480@60Hz
[ 4.243164] Manufacturer's mask: 0
[ 4.243164] Standard Timings
[ 4.243164] Extrapolated
[ 4.243164] H: 32-36KHz V: 61-61Hz DCLK: 29MHz
[ 4.243164] Digital Display Input
[ 4.243194] Sync:
[ 4.243194] Max H-size in cm: 10
[ 4.243194] Max V-size in cm: 7
[ 4.243194] Gamma: 1.0
[ 4.243194] DPMS: Active no, Suspend no, Standby no
[ 4.243225] RGB Color Display
[ 4.243225] Chroma
[ 4.243225] RedX: 0.640 RedY: 0.330
[ 4.243225] GreenX: 0.300 GreenY: 0.600
[ 4.243225] BlueX: 0.150 BlueY: 0.001
[ 4.243255] WhiteX: 0.313 WhiteY: 0.329
[ 4.243255] Detailed Timings
[ 4.243255] 29 MHz 800 816 824 830 480 536 538 594 108mm 64mm -HSync -VSync
[ 4.243255]
[ 4.243255] Supported VESA Modes
[ 4.243286] 640x480@60Hz
[ 4.243286] Manufacturer's mask: 0
[ 4.243286] Standard Timings
[ 4.243286] ========================================
[ 4.243438] HDCP: hdcp_3des_cb: hdcp_keys not loaded = 0
[ 4.243438]
[ 4.515899] cannot apply mgr(tv) on inactive device
[ 4.521026] cannot aply mgr(lcd)--invalid device
[ 4.525878] omapfb omapfb: failed to apply dispc config
[ 4.531372] cannot apply mgr(tv) on inactive device
[ 4.536529] omapfb omapfb: failed to apply dispc config
[ 4.542114] cannot aply mgr(lcd2)--invalid device
[ 4.547088] omapfb omapfb: failed to apply dispc config
[ 4.552764] HDCP: hdcp_3des_cb: hdcp_keys not loaded = 0
[ 4.552764]
[ 4.560119] Enter ti_hdmi_5xxx_basic_configure
[ 4.564819] Enter hdmi_core_init
[ 4.568206] Brent was here
[ 4.571044] Calling hdmi_wp_video_init_format
[ 4.575622] Calling hdmi_wp_video_config_timing
[ 4.580383] Calling hdmi_wp_video_config_format
[ 4.585205] Calling hdmi_wp_video_config_interface
[ 4.590240] Enter ti_hdmi_5xxx_configure_range
[ 4.594909] Enter hdmi_core_csc_config
[ 4.598937] Enter hdmi_core_aux_infoframe_avi_config
[ 4.604156] Enter hdmi_core_video_config
[ 4.608337] Enter hdmi_core_config_video_packetizer
[ 4.613464] Enter hdmi_core_config_csc
[ 4.617401] Enter hdmi_core_config_video_sampler
[ 4.622283] mmc2: new high speed SDIO card at address 0001
[ 4.622283] Enter hdmi_core_aux_infoframe_avi_config
[ 4.622283] hdmi_enable_video_path
[ 4.639404] Enter ti_hdmi_5xxx_power_on_cec
[ 4.643859] ti_hdmi_5xxx_audio_config
[ 4.648132] usb 1-2.2: New USB device found, idVendor=04f3, idProduct=0234
[ 4.655364] LDOUSB: incomplete constraints, leaving on
[ 4.660797] usb 1-2.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 4.668518] usb 1-2.2: Product: OM
[ 4.672119] LDOLN: incomplete constraints, leaving on
[ 4.677917] LDO8: incomplete constraints, leaving on
[ 4.683685] LDO6: incomplete constraints, leaving on
[ 4.689147] LDO5: incomplete constraints, leaving on
[ 4.694946] input: OM as /devices/platform/usbhs_omap/ehci-omap.0/usb1/1-2/1-2.2/1-2.2:1.0/input/input3
[ 4.704986] generic-usb 0003:04F3:0234.0001: input: USB HID v1.11 Mouse [OM] on usb-ehci-omap.0-2.2/input0
[ 4.715179] LDO3: incomplete constraints, leaving on
[ 4.721038] SMPS8: incomplete constraints, leaving on
[ 4.726531] SMPS6: incomplete constraints, leaving on
[ 4.732025] SMPS45: incomplete constraints, leaving on
[ 4.737762] input: gpio-keys as /devices/platform/gpio-keys.0/input/input4
[ 4.745880] twl_rtc twl_rtc.9: setting system clock to 2000-01-01 07:43:52 UTC (946712632)
[ 4.754608] ALSA device list:
[ 4.757720] #0: OMAP5EVM
[ 4.760559] #1: OMAPHDMI
[ 4.763671] Freeing init memory: 344K
[ 4.769561] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
[ 4.903411] sr_classp5_calib_work: smartreflex_mpu: Calibration complete: Voltage Nominal=880000 Calib=880000 Dyn=880000 OPP_margin=0 total_margin=0
[ 4.924560] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: (null)
[ 4.940093] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. Opts: (null)
[ 4.957092] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[ 5.004882] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/omap_hsmmc.1/by-name/cache
[ 5.224273] rproc remoteproc0: powering up ipu_c0
[ 5.253570] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts: (null)
[ 5.268646] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[ 5.281921] rproc remoteproc0: Booting fw image ducati-m3-core0.xem3, size 13487335
[ 5.325256] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/omap_hsmmc.1/by-name/userdata
[ 5.351104] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: (null)
[ 5.392089] init: cannot find '/system/bin/rild', disabling 'ril-daemon'
[ 5.399658] HDCP: failed to load keys
[ 5.399688]
[ 5.407226] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
[ 5.454254] Compat-wireless backport release: ol_r8.a5.08
[ 5.462829] Backport based on wl18xx.git ol_r8.a5.13
[ 5.470611] compat.git: wl18xx.git
[ 5.528137] omap-iommu omap-iommu.1: ipu: version 2.1
[ 5.541229] rproc remoteproc0: remote processor ipu_c0 is now up
[ 5.550537] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 5.556365] rproc remoteproc0: registered virtio0 (type 7)
[ 5.626800] cfg80211: Calling CRDA to update world regulatory domain
[ 5.643859] PVR: PVRCore_Init
[ 5.647888] PVR: LinuxMMInit: Maximum page pool size: 10800
[ 5.653869] PVR: PVRSRVDriverProbe(pDevice=d40ea200)
[ 5.659118] PVR: SGX register base: 0x56000000
[ 5.663848] PVR: SGX register size: 65535
[ 5.668151] PVR: SGX IRQ: 53
[ 5.672210] cfg80211: World regulatory domain updated:
[ 5.672790] PVR: EnableSystemClocks: Enabling System Clocks
[ 5.673126] PVR: PVRCore_Init: major device 246
[ 5.688293] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 5.696990] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 5.705200] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 5.713439] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 5.721771] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 5.730010] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 5.964569] PVR: Installing MISR with cookie bf0853c4
[ 5.970153] PVR: Installing device LISR SGX ISR on IRQ 53 with cookie d2a159c0
[ 5.978027] PVR: SysFinalise: Version string: SGX revision = 1.1.6
[ 5.984741] omaplfb: OMAPLFBInitFBDev: Device 2: invalid framebuffer size
[ 5.992034] omaplfb: OMAPLFBInitFBDev: Device 1: invalid framebuffer size
[ 6.058044] EXT4-fs (mmcblk0p8): re-mounted. Opts: (null)
[ 6.089385] wlcore: wl12xx driver version: android-3.4-5AJ.1.4-1535-g499e8d5
[ 6.121582] wlcore: wl18xx driver version: android-3.4-5AJ.1.4-1535-g499e8d5
[ 6.177154] android_usb: already disabled
[ 6.181488] android_usb: already disabled
[ 6.186126] android_usb: already disabled
[ 6.190490] EXT4-fs (mmcblk0p8): re-mounted. Opts: (null)
[ 6.192687] warning: `adbd' uses 32-bit capabilities (legacy support in use)
[ 6.195648] adb_open
[ 6.195648] mtp_bind_config
[ 6.195709] adb_bind_config
shell@android:/ $ [ 6.326538] PVR_K:(Error): PVRSRVOpenDCDeviceKM: no devnode matching index 0 [0, ]
[ 6.445465] android_work: sent uevent USB_STATE=CONNECTED
[ 6.451293] android_work: sent uevent USB_STATE=DISCONNECTED
[ 6.507415] Enter ti_hdmi_5xxx_hdcp_disable
[ 6.511962] android_work: sent uevent USB_STATE=CONNECTED
[ 6.518005] HDCP: hdcp_3des_cb: hdcp_keys not loaded = 0
[ 6.518005]
[ 6.535644] Failed to set PHY power mode to 2
[ 6.540435] omapdss HDMI error: failed to power on device
[ 6.546142] omapdss error: failed to power on
[ 6.558258] android_usb gadget: high-speed config #1: android
[ 6.564483] android_work: sent uevent USB_STATE=CONFIGURED
[ 6.605285] HDCP: hdcp_3des_cb: hdcp_keys not loaded = 0
[ 6.605285]
[ 6.605499] Enter ti_hdmi_5xxx_basic_configure
[ 6.605529] Enter hdmi_core_init
[ 6.605529] Brent was here
[ 6.605529] Calling hdmi_wp_video_init_format
[ 6.605529] Calling hdmi_wp_video_config_timing
[ 6.605560] Calling hdmi_wp_video_config_format
[ 6.605560] Calling hdmi_wp_video_config_interface
[ 6.605560] Enter ti_hdmi_5xxx_configure_range
[ 6.605560] Enter hdmi_core_csc_config
[ 6.605590] Enter hdmi_core_aux_infoframe_avi_config
[ 6.605590] Enter hdmi_core_video_config
[ 6.605621] Enter hdmi_core_config_video_packetizer
[ 6.605621] Enter hdmi_core_config_csc
[ 6.605621] Enter hdmi_core_config_video_sampler
[ 6.605621] Enter hdmi_core_aux_infoframe_avi_config
[ 6.605651] hdmi_enable_video_path
[ 6.622741] Enter ti_hdmi_5xxx_power_on_cec
[ 6.622741] ti_hdmi_5xxx_audio_config
[ 6.739746] PVR_K:(Error): PVRSRVOpenDCDeviceKM: no devnode matching index 0 [0, ]
[ 7.573547] omap-rproc omap-rproc.1: received echo reply from ipu_c0
[ 7.580352] virtio_rpmsg_bus virtio0: creating channel rpmsg-omx1 addr 0x3c
[ 7.588287] rpmsg_omx rpmsg-omx1: new OMX connection srv channel: 1024 -> 60!
[ 7.595916] virtio_rpmsg_bus virtio0: creating channel omaprpc addr 0x3b
[ 8.413024] virtio_rpmsg_bus virtio0: creating channel rpmsg-resmgr addr 0x66
[ 8.434082] rprm_regulator_request: regulator lookup failed, id 1
[ 8.440521] rpmsg_resmgr rpmsg2: request for regulator failed: -22
[ 8.447021] rpmsg_resmgr rpmsg2: resource allocation failed -22!
[ 18.922363] request_suspend_state: wakeup (3->0) at 18917510258 (2000-01-01 07:44:06.671056480 UTC)
[ 27.688415] acc_open
[ 27.690795] acc_release
[ 28.875152] PVR_K:(Error): PVRSRVOpenDCDeviceKM: no devnode matching index 32 [0, ]
[ 29.949096] mtp_open
[ 30.106964] PVR_K:(Error): PVRSRVOpenDCDeviceKM: no devnode matching index 32 [0, ]
[ 30.514007] init: sys_prop: permission denied uid:1003 name:service.bootanim.exit
[ 30.649780] init: Boot Animation exit
[ 30.687286] (hci_tty): inside hci_tty_open (d2a89380, d2a88980)
[ 30.693664] (stc): st_register(4)
[ 30.697235] (stc): chnl_id list empty :4
[ 30.702819] (stk) : st_kim_start
[ 30.817474] (stk) :ldisc_install = 1
[ 30.872161] (stc): st_tty_open
[ 30.875732] (stk) :line discipline installed
[ 30.880340] (stk) :TIInit_11.8.32.bts
[ 31.464141] (stc): add_channel_to_table: id 4
[ 31.468963] (stc): st_register(2)
[ 31.472442] (stc): add_channel_to_table: id 2
[ 31.477142] (stc): st_register(3)
[ 31.480682] (stc): add_channel_to_table: id 3
[ 31.747619] (hci_tty): inside hci_tty_release (d2a89380, d2a88980)
[ 31.754180] (stc): remove_channel_from_table: id 4
[ 31.759246] (stc): remove_channel_from_table: id 2
[ 31.764312] (stc): remove_channel_from_table: id 3
[ 31.769409] (stc): all chnl_ids unregistered
[ 31.774017] (stk) :ldisc_install = 0
[ 31.777770] (stc): st_tty_close
[ 91.258148] request_suspend_state: sleep (0->3) at 91253288424 (2000-01-01 07:45:19.006834483 UTC)
[ 91.267944] DSSCOMP: dsscomp_early_suspend
[ 91.284942] DSSCOMP: blanked screen
[ 91.501312] Enter ti_hdmi_5xxx_hdcp_disable
[ 96.571014] PVR_K:(Error): PVRSRVOpenDCDeviceKM: no devnode matching index 0 [0, ]
  • Issue solved. I had all the HDMI data and clock signals connected properly but the shield/ground wire became disconnected between the LCD and the EVM. When I reconnected the ground and rebooted, the PHY powered up correctly. The LCD is working now.
