On a AM335X device, I would like to enable SSC for the Peripheral PLL. My concern is that the USB_PHY_CLK is taken from same PLL and that USB performance will be affected when jitter is added to its clock.
The PLL runs at 960 MHz, are there any limitations on what SSC-settings (eg. modulation frequency and frequency spread) in order to maintain full performance on USB?
What is maximum permissible modulation frequency and frequency spread in this case?
Are there any other functional blocks that I need to care about when SSC is enabled?
Thank you!
Per
