Other Parts Discussed in Thread: PMP, TVP5158
DVRRDK_04.00.00.03/dvr_rdk/Rules.make
modify DDR_MEM := DDR_MEM_2048M
then make -s sys_all
the config_2G.bld file is:
the log is:
Connecting to COM1...
Connected.
U-Boot 2010.06-svn2153 (Nov 04 2013 - 10:02:08)
TI8168-GP rev 2.1
HDVICP clk : 600MHz
L3 Fast clk : 549MHz
HDVPSS clk : 274MHz
Ducati M3 clk : 274MHz
DSP clk : 1000MHz
ARM clk : 1200MHz
DDR clk : 796MHz
------------ PLL Settings --------------
MAIN_N : 56, MAIN_P: 1, OSC_FREQ: 27, FAPLL_K: 8
MAIN_INTFREQ1 : 0xC, MAIN_FRACFREQ1: 0x189374, MAIN_MDIV1: 0x1
MAIN_INTFREQ2 : 0xA, MAIN_FRACFREQ2: 0x147AE1, MAIN_MDIV2: 0x1
MAIN_INTFREQ3 : 0xA, MAIN_FRACFREQ3: 0x147AE1, MAIN_MDIV3: 0x2
MAIN_INTFREQ4 : 0xB, MAIN_FRACFREQ4: 0x0, MAIN_MDIV4: 0x2
MAIN_INTFREQ5 : 0xC, MAIN_FRACFREQ5: 0x189374, MAIN_MDIV5: 0x8
MAIN_MDIV6 : 0x3F
MAIN_MDIV7 : 0x4
--------- DDR PLL ----------
DDR_N : 0x3B
DDR_P : 0x1
DDR_MDIV1 : 0x2
DDR_INTFREQ2 : 0x8
DDDDR_FRACFREQ2R_N : 0xD99999
DDR_MDIV2 : 0x1E
DDR_INTFREQ3 : 0x8
DDR_FRACFREQ3 : 0x0
DDR_MDIV3 : 0x4
DDR_INTFREQ4 : 0xE
DDR_FRACFREQ4 : 0x0
DDR_MDIV4 : 0x4
DDR_INTFREQ5 : 0xE
DDR_FRACFREQ5 : 0x0
DDR_MDIV5 : 0x4
----------EMIF Timings (identical for 0 & 1)-------
EMIF_TIM1 : 0x1779C9FE
EMIF_TIM2 : 0x50608074
EMIF_TIM3 : 0x009F857F
EMIF_SDREF : 0x10001841
EMIF_SDCFG : 0x62A73832
EMIF_PHYCFG : 0x00000110
----------SW LEVEL Info (EMIF 0) -------
RD_DQS_GATE_BYTE_LANE0: 0x00000160
RD_DQS_GATE_BYTE_LANE1: 0x00000178
RD_DQS_GATE_BYTE_LANE2: 0x000001B3
RD_DQS_GATE_BYTE_LANE3: 0x000001D6
WR_DQS_RATIO_BYTE_LANE0: 0x0000007D
WR_DQS_RATIO_BYTE_LANE1: 0x0000008F
WR_DQS_RATIO_BYTE_LANE2: 0x000000A2
WR_DQS_RATIO_BYTE_LANE3: 0x000000B2
RD_DQS_RATIO_BYTE_LANE0: 0x00000037
RD_DQS_RATIO_BYTE_LANE1: 0x00000037
RD_DQS_RATIO_BYTE_LANE2: 0x00000038
RD_DQS_RATIO_BYTE_LANE3: 0x0000003B
WR_DATA_RATIO_BYTE_LANE0: 0x000000BD
WR_DATA_RATIO_BYTE_LANE1: 0x000000CF
WR_DATA_RATIO_BYTE_LANE2: 0x000000E2
WR_DATA_RATIO_BYTE_LANE3: 0x000000F2
----------SW LEVEL Info (EMIF 1) -------
RD_DQS_GATE_BYTE_LANE0: 0x0000015F
RD_DQS_GATE_BYTE_LANE1: 0x00000171
RD_DQS_GATE_BYTE_LANE2: 0x000001B5
RD_DQS_GATE_BYTE_LANE3: 0x000001D3
WR_DQS_RATIO_BYTE_LANE0: 0x0000006F
WR_DQS_RATIO_BYTE_LANE1: 0x00000087
WR_DQS_RATIO_BYTE_LANE2: 0x000000A5
WR_DQS_RATIO_BYTE_LANE3: 0x000000B0
RD_DQS_RATIO_BYTE_LANE0: 0x00000035
RD_DQS_RATIO_BYTE_LANE1: 0x00000043
RD_DQS_RATIO_BYTE_LANE2: 0x0000003F
RD_DQS_RATIO_BYTE_LANE3: 0x00000038
WR_DATA_RATIO_BYTE_LANE0: 0x000000AF
WR_DATA_RATIO_BYTE_LANE1: 0x000000C7
WR_DATA_RATIO_BYTE_LANE2: 0x000000E5
WR_DATA_RATIO_BYTE_LANE3: 0x000000F0
I2C: ready
DRAM: 2 GiB
NAND: HW ECC BCH8 Selected
512 MiB
MMC: OMAP SD/MMC: 0
Net: Detected MACID:84:7e:40:f0:ea:ea
Ethernet PHY: GENERIC @ 0x01
DaVinci EMAC
Hit any key to stop autoboot: 0
Using DaVinci EMAC device
TFTP from server 2.1.1.18; our IP address is 2.1.1.6
Filename 'uImage40'.
Load address: 0x80200000
Loading: #################################################################
done
Bytes transferred = 2567836 (0x272e9c)
## Booting kernel from Legacy Image at 80200000 ...
Image Name: Linux-2.6.37
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2567772 Bytes = 2.4 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Linux version 2.6.37 (wyt@rhel6.4-i386) (gcc version 4.5.3 20110311 (prerelease) (GCC) ) #1 Mon Nov 4 16:03:05 CST 2013
CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: ud8168_dvr
vram size = 20971520 at 0x0
ti81xx_reserve: ### Reserved DDR region @dd700000
reserved size = 20971520 at 0x0
FB: Reserving 20971520 bytes SDRAM for VRAM
Memory policy: ECC disabled, Data cache writeback
OMAP chip is TI8168 2.1
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 145232
Kernel command line: rootdelay=3 console=ttyO2,115200n8 rootwait rw mem=128M mem=472M@0xC0000000 notifyk.vpssm3_sva=0xbfb00000 vram=20M root=/dev/nfs rw nfsroot=2.1.1.18:/home/wyt/rootfs40 ip=2.1.1.7:::::eth0
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 128MB 450MB 1MB = 579MB total
Memory: 582412k/582412k available, 31988k reserved, 461824K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0xc8800000 - 0xf8000000 ( 760 MB)
lowmem : 0xc0000000 - 0xc8000000 ( 128 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.init : 0xc0008000 - 0xc0041000 ( 228 kB)
.text : 0xc0041000 - 0xc04e2000 (4740 kB)
.data : 0xc04e2000 - 0xc052b980 ( 295 kB)
SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:407
IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
Total of 128 interrupts on 1 active controller
GPMC revision 6.0
Trying to install interrupt handler for IRQ400
Trying to install interrupt handler for IRQ401
Trying to install interrupt handler for IRQ402
Trying to install interrupt handler for IRQ403
Trying to install interrupt handler for IRQ404
Trying to install interrupt handler for IRQ405
Trying to install interrupt handler for IRQ406
Trying to install type control for IRQ407
Trying to set irq flags for IRQ407
OMAP clockevent source: GPTIMER1 at 27000000 Hz
Console: colour dummy device 80x30
Calibrating delay loop... 1199.30 BogoMIPS (lpj=5996544)
pid_max: default: 32768 minimum: 301
Security Framework initialized
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
devtmpfs: initialized
TI81XX: Map 0xdd700000 to 0xfe500000 for dram barrier
TI81XX: Map 0x40300000 to 0xfe600000 for sram barrier
omap_voltage_early_init: voltage driver support not added
regulator: core version 0.5
regulator: dummy:
NET: Registered protocol family 16
omap_voltage_domain_lookup: Voltage driver init not yet happened.Faulting!
omap_voltage_add_dev: VDD specified does not exist!
OMAP GPIO hardware version 0.1
omap_mux_init: Add partition: #1: core, flags: 0
3-wired eeprom init done. (H/W ver:00)
_omap_mux_get_by_name: Could not find signal i2c2_scl.i2c2_scl
_omap_mux_get_by_name: Could not find signal i2c2_sda.i2c2_sda
registered ti816x_sr device
Cannot clk_get ck_32
pm_dbg_init: only OMAP3 supported
registered ti81xx_vpss device
registered ti81xx_vidout device
registered ti81xx on-chip HDMI device
registered ti81xx_fb device
bio: create slab <bio-0> at 0
vgaarb: loaded
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
USBSS revision 4ea20809
registerd cppi-dma Intr @ IRQ 17
Cppi41 Init Done
omap_i2c omap_i2c.1: bus 1 rev4.0 at 100 kHz
pmbus 1-0038: no platform data supplied
pmbus: probe of 1-0038 failed with error -5
omap_i2c omap_i2c.2: bus 2 rev4.0 at 100 kHz
Advanced Linux Sound Architecture Driver Version 1.0.23.
Switching to clocksource gp timer
musb-hdrc: version 6.0, host, debug=0
musb-hdrc musb-hdrc.0: dma type: dma-cppi41
MUSB controller-0 revision 4ea20800
musb-hdrc musb-hdrc.0: MUSB HDRC host driver
musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: MUSB HDRC host driver
usb usb1: Manufacturer: Linux 2.6.37 musb-hcd
usb usb1: SerialNumber: musb-hdrc.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
musb-hdrc musb-hdrc.0: USB Host mode controller at c881e000 using DMA, IRQ 18
musb-hdrc musb-hdrc.1: dma type: dma-cppi41
MUSB controller-1 revision 4ea20800
musb-hdrc musb-hdrc.1: MUSB HDRC host driver
musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: MUSB HDRC host driver
usb usb2: Manufacturer: Linux 2.6.37 musb-hcd
usb usb2: SerialNumber: musb-hdrc.1
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
musb-hdrc musb-hdrc.1: USB Host mode controller at c8828800 using DMA, IRQ 19
NET: Registered protocol family 2
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
NetWinder Floating Point Emulator V0.97 (double precision)
PMU: registered new PMU device of type 0
omap-iommu omap-iommu.0: ducati registered
omap-iommu omap-iommu.1: sys registered
highmem bounce pool size: 64 pages
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 235
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0
omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
console [ttyO2] enabled
brd: module loaded
loop: module l ahci
ahci CAP register dump =0x6726ff81
Modified ahci CAP register dump =0x6f26ff81
ahci ahci.0: forcing PORTS_IMPL to 0x3
ahci: SSS flag set, parallel bus scan disabled
ahci ahci.0: AHCI 0001.0100 32 slots 2 ports 3 Gbps 0x3 impl platform mode
ahci ahci.0: flags: ncq sntf stag pm led clo only pmp pio slum part ccc
scsi0 : ahci_platform
scsi1 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a150fff] port 0x100 irq 16
ata2: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a150fff] port 0x180 irq 16
omap2-nand driver initializing
NAND device: Maf ID: 0xad, Chip ID: 0xdc (Hynix, )
erasesize: 0x20000, writesize: 2048, oobsize: 64
omap2-nand: detected x8 NAND flash
Creating 6 MTD partitions on "omap2-nand.0":
0x000000000000-0x000000240000 : "U-Boot"
0x000000240000-0x000000280000 : "U-Boot Env"
0x000000280000-0x000000580000 : "U-Boot Logo"
0x000000580000-0x0000009c0000 : "Kernel"
0x0000009c0000-0x0000109c0000 : "File System"
0x0000109c0000-0x000020000000 : "Reserved"
davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
davinci_mdio davinci_mdio.0: detected phy mask fffffffd
davinci_mdio.0: probed
davinci_mdio davinci_mdio.0: phy[1]: device 0:01, driver unknown
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver dm9601
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mice: PS/2 mouse device common for all mice
rtc-ds1307: probe of 1-0068 failed with error -5
omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0
i2c /dev entries driver
Linux video capture interface: v2.00
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v1.0.0)
OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
ata1: SATA link down (SStatus 0 SControl 300)
hub 2-0:1.0: over-current change on port 1
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
notify_init : notify drivercreated for remote proc id 2 at physical Address 0xbfb00000
usbcore: registered new interface driver snd-usb-audio
Registered tvp5158 audio codec
asoc: tvp5158-hifi <-> davinci-mcasp.0 mapping ok
asoc: tlv320aic3x-hifi <-> davinci-mcasp.2 mapping ok
asoc: HDMI-DAI-CODEC <-> hdmi-dai mapping ok
ALSA device list:
#0: TI81XX_DVR_CARD0
#1: TI81XX_DVR_CARD1
TCP cubic registered
NET: Registered protocol family 17
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
omap_voltage_late_init: Voltage driver support not added
Power Management for TI81XX.
smartreflex smartreflex: Driver initialized
davinci_emac_probe: using random MAC addr: 2e:83:16:d3:bf:d7
omap_rtc omap_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
hub 1-0:1.0: over-current change on port 1
ata2: SATA link down (SStatus 0 SControl 300)
davinci_mdio davinci_mdio.0: resetting idled controller
net eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0:01, id=282f014)
IP-Config: Guessing netmask 255.0.0.0
IP-Config: Complete:
device=eth0, addr=2.1.1.7, mask=255.0.0.0, gw=255.255.255.255,
host=2.1.1.7, domain=, nis-domain=(none),
bootserver=255.255.255.255, rootserver=2.1.1.18, rootpath=
Waiting 3sec before mounting root device...
PHY: 0:01 - Link is Up - 100/Full
VFS: Mounted root (nfs filesystem) on device 0:15.
devtmpfs: mounted
Freeing init memory: 228K
INIT: version 2.88 booting
Mounting /dev/shm :
Mounting /dev/pts :
Mounting other filesystems :
Sync command ...Starting udev
udev[66]: starting version 164
Starting Bootlog daemon: bootlogd.
dm816x login: root
root@dm816x:/#
root@dm816x:/#
root@dm816x:/#
root@dm816x:/# /opt/dvr_rdk/ti816x/bin/remote_debug_client.out 0xbfd00000 &
[1] 491
sys_pri.out --dmm-pri-set HDVICP2 2
[c6xdsp ] Remote Debug Shared Memory @ 0xbfd00000
[m3video] Remote Debug Shared Memory @ 0xbfd10820
[m3vpss ] Remote Debug Shared Memory @ 0xbfd21040
root@dm816x:/#
root@dm816x:/# insmod /opt/dvr_rdk/ti816x/kermod/syslink.ko TRACE=1
SysLink version : 2.20.02.20
SysLink module created on Date:Nov 4 2013 Time:16:03:44
Trace enabled
root@dm816x:/#
root@dm816x:/# usleep 100000
root@dm816x:/# /opt/dvr_rdk/ti816x/bin/sys_pri.out --dmm-pri-set DUCATI 0
Setting DMM priority for [DUCATI ] to [0] ( 0x4e000624 = 0x08000000 )
root@dm816x:/# /opt/dvr_rdk/ti816x/bin/sys_pri.out --dmm-pri-set HDVICP0 2
Setting DMM priority for [HDVICP0 ] to [2] ( 0x4e000634 = 0x0000000a )
root@dm816x:/# /opt/dvr_rdk/ti816x/bin/sys_pri.out --dmm-pri-set HDVICP1 2
Setting DMM priority for [HDVICP1 ] to [2] ( 0x4e000634 = 0x000a0000 )
root@dm816x:/# /opt/dvr_rdk/ti816x/bin/sys_pri.out --dmm-pri-set HDVICP2 2
Setting DMM priority for [HDVICP2 ] to [2] ( 0x4e000634 = 0x00a00000 )
root@dm816x:/#
root@dm816x:/#
root@dm816x:/# /opt/dvr_rdk/ti816x/bin/fw_load.out startup VPSS-M3 /opt/dvr_rdk/ti816x/firmware/dvr_rdk_fw_m3vpss_2048M_512M.xem3
Attached to slave procId 2.
Loaded file /optBUG: Your driver calls ioremap() on system memory. This leads
to architecturally unpredictable behaviour on ARMv6+, and ioremap()
will fail in the next kernel release. Please fix your driver.
/dvr_rdk/ti816x/------------[ cut here ]------------
firmware/dvr_rdkWARNING: at arch/arm/mm/ioremap.c:211 __arm_ioremap_pfn_caller+0x58/0x194()
_fw_m3vpss_2048MModules linked in:_512M.xem3 on sl syslinkave procId 2.
S
tarted slave proBacktrace: cId 2.
[<c004efac>] (dump_backtrace+0x0/0x110) from [<c039ff9c>] (dump_stack+0x18/0x1c)
r6:c04626af r5:000000d3 r4:00000000 r3:60000013
[<c039ff84>] (dump_stack+0x0/0x1c) from [<c00745c4>] (warn_slowpath_common+0x54/0x6c)
[<c0074570>] (warn_slowpath_common+0x0/0x6c) from [<c0074600>] (warn_slowpath_null+0x24/0x2c)
r8:bf0ae0d0 r7:00000002 r6:00000000 r5:00080000 r4:11600000
r3:00000009
[<c00745dc>] (warn_slowpath_null+0x0/0x2c) from [<c0052c6c>] (__arm_ioremap_pfn_caller+0x58/0x194)
[<c0052c14>] (__arm_ioremap_pfn_caller+0x0/0x194) from [<c0052e24>] (__arm_ioremap_caller+0x5c/0x64)
[<c0052dc8>] (__arm_ioremap_caller+0x0/0x64) from [<c0065a98>] (omap_ioremap+0x60/0x64)
r4:80000000
[<c0065a38>] (omap_ioremap+0x0/0x64) from [<bf022b10>] (MemoryOS_map+0xe8/0x1dc [syslink])
r7:00000002 r6:bf0ae16c r5:00000000 r4:c708fd10
[<bf022a28>] (MemoryOS_map+0x0/0x1dc [syslink]) from [<bf003a18>] (_ProcMgr_map+0xcc/0x314 [syslink])
r6:caffe000 r5:00000001 r4:c708fdf0
[<bf00394c>] (_ProcMgr_map+0x0/0x314 [syslink]) from [<bf003cd8>] (ProcMgr_map+0x78/0xd0 [syslink])
[<bf003c60>] (ProcMgr_map+0x0/0xd0 [syslink]) from [<bf012eb4>] (Platform_loadCallback+0x564/0x898 [syslink])
r8:00000001 r7:00000002 r6:00000018 r5:bf0adec4 r4:00000001
[<bf012950>] (Platform_loadCallback+0x0/0x898 [syslink]) from [<bf02e6d4>] (Ipc_control+0x68/0x160 [syslink])
[<bf02e66c>] (Ipc_control+0x0/0x160 [syslink]) from [<bf052740>] (IpcDrv_drvioctl+0xf0/0x574 [syslink])
r7:bed2cbcc r6:bed2cbcc r5:c014f497 r4:00000000
[<bf052650>] (IpcDrv_drvioctl+0x0/0x574 [syslink]) from [<c00d8fd8>] (do_vfs_ioctl+0x4d0/0x544)
[<c00d8b08>] (do_vfs_ioctl+0x0/0x544) from [<c00d90a4>] (sys_ioctl+0x58/0x7c)
r9:c708e000 r8:00000000 r7:00000005 r6:c014f497 r5:bed2cbcc
r4:c6c12200
[<c00d904c>] (sys_ioctl+0x0/0x7c) from [<c004b3c0>] (ret_fast_syscall+0x0/0x30)
r8:c004b568 r7:00000036 r6:c014f497 r5:0007f334 r4:bed2cbcc
---[ end trace 006ad33613bb8473 ]---
[m3vpss ] ***** VPSS Firmware build time 16:14:55 Nov 4 2013 EDG gcc 3.0 mode
[m3vpss ] ***** SYSTEM : Frequency <ORG> - 250000000, <NEW> - 274909088
[m3vpss ] notify_attach rtnVal 0
[m3vpss ] initProxyServer rtnVal 0
[m3vpss ]
[m3vpss ] *** UTILS: CPU KHz = 549818 Khz ***
[m3vpss ]
[m3vpss ] 207: SYSTEM : System Common Init in progress !!!
After Ipc_loadcallback status [0x00000000]
[m3vpss ] 207: SYSTEM: IPC init in progress !!!
[m3vpss ] 207: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 210: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
After Ipc_startcallback status [0x00000000]
root@dm816x:/# [m3vpss ] 1209: SYSTEM: Attaching to [DSP] ...
[m3vpss ] 2209: SYSTEM: Attaching to [DSP] ...
[m3vpss ] 3209: SYSTEM: Attaching to [DSP] ...
thanks.
