OMAP5912 to OMAP35xx DSP software migration.
I'm searching from some FAQ and tips and tricks that would give some guidance as to the scope of migrating between OMAP generations (ARM9/55xx to Cortex A8/64x+.)
Currently the most daunting task is scoping the effort to reengineer the 55xx software to run on the 64x+ architecture.  Yes, the code is in C already...
This issue could also be addressed by any generic C5000 to C6000 code migration collateral as well.
DB
  • My 2 cents:
    1. MIPS wise, If your software runs well on 55xx, it shouldn't sweat on a 64x+. Of course, if you need to squeeze MIPS for other applications, that's a different story.
    2. The scope of the effort really depends on how your C code was written. If it's generic ANSI C, maybe all you need to do is re-compile the C code. But if your C code has lots of 55xx tweaks (intrinsics, etc) or makes heavy use of the peripherals, you'll have to re-write your C code.
    3. The scope of the effort also depends on your performance target. The TI compiler for C64+ usually does a decent job generating optimized code. But if you have very tight MIPS budget, the compiler alone may not be enough. You will need to hand-optimize your code.
