AlgLink_ScdalgProcessData STOP!!!
Hi
  when I run rdkdvr 4.0 . I will go, but it will be stop after run AlgLink_ScdalgProcessData 18 times.
  When i comment AlgLink_ScdalgProcessData in method: AlgLink_scdAlgProcessTskMain (file: scdLink_processTsk.c)
 it will continue process NEW_DATA message!
before stop the lg is:
[m3vpss ] 20097: DISPLAY: HDDAC(BP0) : 35 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) DropCount:0 DispLatency (Min / Max) = ( 7669 / 0 ) !!!
[m3vpss ] 20098: DISPLAY DRV: HDDAC(BP0) : Q:[2] Display:[2], Repeat:[1], DQ:[0]
[m3vpss ] 20098: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 1, HDDAC(BP0) 1, DVO2(BP1) 0, SDDAC(SEC1) 1
[m3vpss ] System_memPrintHeapStatus called
[m3vpss ] 20098: SYSTEM : FREE SPACE : System Heap = 67128 B, Mbx = 10238 msgs)
[m3vpss ] 20098: SYSTEM : FREE SPACE : SR0 Heap = 56712192 B (54 MB)
[m3vpss ] 20098: SYSTEM : FREE SPACE : Frame Buffer = 126133632 B (120 MB)
[m3vpss ] 20098: SYSTEM : FREE SPACE : Bitstream Buffer = 97727104 B (93 MB)
[m3vpss ] 20099: SYSTEM : FREE SPACE : Tiler Buffer = 127 B (0 MB) - TILER OFF
[m3vpss ] System_memPrintHeapStatus ok
[m3vpss ] 20133: DISPLAY: SDDAC(SEC1): 28 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) DropCount:0 DispLatency (Min / Max) = ( 7669 / 0 ) !!!
[m3vpss ] 20133: DISPLAY DRV: SDDAC(SEC1): Q:[2] Display:[1], Repeat:[0], DQ:[0]
[m3vpss ] pObj->createArgs.numVipInst=1
[m3vpss ] 20236: CAPTURE: Enabled Time Stamping !!!
[m3vpss ] FVID2_start....
[m3vpss ] FVID2_start ok instId=0
[m3vpss ] CAPTURE !!!
[c6xdsp ] ALG SYSTEM_CMD_NEW_DATA!!!
[m3vpss ] IPC_FRAMES_OUT SYSTEM_CMD_NEW_DATA!!!
[c6xdsp ] ALG IN
[c6xdsp ] ALG IN-OUT
[c6xdsp ] ALG IN
note these log is my add:
[c6xdsp ] ALG IN
I realy need help!
who can help me ? thanks very much
  • It looks like you are not freeing scd meta data which is received on A8.Is this dvr rdk demo or your own application .
    Share logs of Vsys_printDetailedStatistics invoked atleast 3 times
  • Hi Badri:
        Thanks you for your  reply and help!
         The Vsys_printDetailedStatistics information is:
    [m3vpss ]
    [m3vpss ] *** [DEI2 ] DEI Statistics ***
    [m3vpss ]
    [m3vpss ] Elasped Time : 11 secs
    [m3vpss ] Total Fields Processed : 0
    [m3vpss ] Total Fields FPS : 0 FPS
    [m3vpss ]
    [m3vpss ]
    [m3vpss ] CH | In Recv In Reject In Process Out[0] Out[1] Out[2] Out[3] Out[4] Skip Out[0] Skip Out[1] Skip Out[2] Skip Out[3] Skip Out[4] User Out[0] User Out[1] User Out[2] User Out[3] User Out[4] Latency
    [m3vpss ] Num | FPS FPS FPS FPS FPS FPS FPS FPS FPS FPS FPS FPS FPS Skip FPS Skip FPS Skip FPS Skip FPS Skip FPS Min / Max
    [m3vpss ] -------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
    [m3vpss ] 0 | 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 255 / 0
    [m3vpss ] 1 | 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 255 / 0
    [m3vpss ] 2 | 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 255 / 0
    [m3vpss ] 3 | 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 255 / 0
    [m3vpss ]
    [m3vpss ]
    [m3vpss ] *** IpcFramesOutRTOS Statistics ***
    [m3vpss ]
    [m3vpss ]
    [m3vpss ]
    [m3vpss ] CH | In Recv In Process In Skip
    [m3vpss ] 0 | 0 0 0
    [m3vpss ] 1 | 0 0 0
    [m3vpss ] 2 | 0 0 0
    [m3vpss ] 3 | 0 0 0
    [m3vpss ] 4 | 0 0 0
    [m3vpss ] 5 | 0 0 0
    [m3vpss ] 6 | 0 0 0
    [m3vpss ] 7 | 0 0 0
    [m3vpss ] 8 | 0 0 0
    [m3vpss ] 9 | 0 0 0
    [m3vpss ] 10 | 0 0 0
    [m3vpss ] 11 | 0 0 0
    [m3vpss ]
    [c6xdsp ]
    [c6xdsp ] *** SCD Statistics ***
    [c6xdsp ]
    [c6xdsp ] Elasped Time : 15 secs
    [c6xdsp ] Total Fields Processed : 0
    [c6xdsp ] Total Fields FPS : 0 FPS
    [c6xdsp ]
    [c6xdsp ]
    [c6xdsp ] CH | In Recv In Process User Skip Process Skip In Process Time
    [c6xdsp ] Num | FPS FPS FPS FPS per frame (msec)
    [c6xdsp ] ----------------------------------------------------------------
    [c6xdsp ] 4 | 0 0 0 0 1
    [c6xdsp ] 5 | 0 0 0 0 1
    [c6xdsp ] 6 | 0 0 0 0 1
    [c6xdsp ] 7 | 0 0 0 0 1
    [c6xdsp ]
    [m3video] 146056: HDVICP-ID:0
    [m3video] All percentage figures are based off totalElapsedTime
    [m3video] totalAcquire2wait :0 %
    [m3video] totalWait2Isr :0 %
    [m3video] totalIsr2Done :0 %
    [m3video] totalWait2Done :0 %
    [m3video] totalDone2Release :0 %
    [m3video] totalAcquire2Release :0 %
    [m3video] totalAcq2acqDelay :0 %
    [m3video] totalElapsedTime in msec : 0
    [m3video] numAccessCnt: 0
    [m3video] IVA-FPS : 0
    [m3video] Average time spent per frame in microsec: 0
    [m3video] 146060: HDVICP-ID:1
    [m3video] 146064: HDVICP-ID:2
    [m3video]
    [m3video] *** ENCODE Statistics ***
    [m3video]
    [m3video] Elasped Time : 146 secs
    [m3video]
    [m3video]
    [m3video] CH | In Recv In Skip In User Out Latency
    [m3video] Num | FPS FPS Skip FPS FPS Min / Max
    [m3video] --------------------------------------------
    [m3video] 0 | 0 0 0 0 0 / 0
    [m3video] 1 | 0 0 0 0 0 / 0
    [m3video] 2 | 0 0 0 0 0 / 0
    [m3video] 3 | 0 0 0 0 0 / 0
    [m3video] 4 | 0 0 0 0 0 / 0
    [m3video] 5 | 0 0 0 0 0 / 0
    [m3video] 6 | 0 0 0 0 0 / 0
    [m3video] 7 | 0 0 0 0 0 / 0
    [m3video] 8 | 0 0 0 0 0 / 0
    [m3video] 9 | 0 0 0 0 0 / 0
    [m3video] 10 | 0 0 0 0 0 / 0
    [m3video] 11 | 0 0 0 0 0 / 0
    [m3video]
    [m3video] Multi Channel Encode Average Submit Batch Size
    [m3video] Max Submit Batch Size : 24
    [m3video] IVAHD_0 Average Batch Size : 0
    [m3video] IVAHD_0 Max achieved Batch Size : 0
    [m3video] IVAHD_1 Average Batch Size : 0
    [m3video] IVAHD_1 Max achieved Batch Size : 0
    [m3video] IVAHD_2 Average Batch Size : 0
    [m3video] IVAHD_2 Max achieved Batch Size : 0
    [m3video]
    [m3video] Multi Channel Encode Batch break Stats
    [m3video] Total Number of Batches created: 0
    [m3video] All numbers are based off total number of Batches created
    [m3video] Batch breaks due to batch sizeexceeding limit: 0 %
    [m3video] Batch breaks due to ReqObj Que being empty: 0 %
    [m3video] Batch breaks due to changed resolution class: 0 %
    [m3video] Batch breaks due to interlace and progressivecontent mix: 0 %
    [m3video] Batch breaks due to channel repeat: 0 %
    [m3video] Batch breaks due to different codec: 0 %
    [m3video]
    [m3video] *** DECODE Statistics ***
    [m3video]
    [m3video] Elasped Time : 41 secs
    [m3video]
    [m3video]
    [m3video] CH | In Recv In User Out
    [m3video] Num | FPS Skip FPS FPS
    [m3video] 0 | 0 0 0
    [m3video] 1 | 0 0 0
    [m3video] 2 | 0 0 0
    [m3video] 3 | 0 0 0
    [m3video]
    [m3video] Multi Channel Decode Average Submit Batch Size
    [m3video]
    [m3video] Multi Channel Decode Batch break Stats
    [m3video]
    [m3vpss ]
    [m3vpss ] 29090: LOAD: CPU: 100.0% HWI: 0.0%, SWI:0.0%
    [m3vpss ]
    [m3vpss ] 29091: LOAD: TSK: MISC : 100.0%
    [m3vpss ]
    [m3video]
    [m3video] 165713: LOAD: CPU: 100.0% HWI: 0.0%, SWI:0.0%
    [m3video]
    [m3video] 165714: LOAD: TSK: MISC : 100.0%
    [m3video]
    [c6xdsp ]
    [c6xdsp ] 29451: LOAD: CPU: 100.0% HWI: 0.0%, SWI:0.0%
    [c6xdsp ]
    [c6xdsp ] 29451: LOAD: TSK: MISC : 100.0%
    [c6xdsp ]
       Ii had do nothing, and I using default SDK source code.
       How should I do?  thanks very much
  • Who can help me ?
  • Log shows ZERO frame captured or encoded .Either log is not correct or issue is unrelated to SCD since I don't see 18 frames processed according to logs.Anyhow check your application code since all DVR RDK demos are tested and there is no issue with SCD
  • Hi Badri:
        Thanks very much!
        I cann't find what cause this error.  can you give me some suggesition?
       can i ignore ZERO Frame?
        Thanks.
  • Is it right?
    SYSTEM_LINK_ID_CAPTURE->SYSTEM_LINK_ID_DEI_0->SYSTEM_VPSS_LINK_ID_DUP->SYSTEM_LINK_ID_NSF->SYSTEM_VPSS_LINK_ID_MERGE->SYSTEM_VPSS_LINK_ID_IPC_OUT_M3_0->SYSTEM_DSP_LINK_ID_IPC_FRAMES_IN_0->SYSTEM_LINK_ID_ALG_0
  • No the chain is wrong. IPC_OUT_M3 cannot be connected to SYSTEM_DSP_LINK_ID_IPC_FRAMES_IN_0.
  • Ok. I will try it. thanks.
  • Hi Badri:
    log is:
     [m3vpss ]  11558: DISPLAY: SDDAC(SEC1): 16 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) DropCount:0 DispLatency (Min / Max) = ( 7669 / 0 ) !!!
     [m3vpss ]  11559: DISPLAY DRV: SDDAC(SEC1): Q:[2] Display:[1], Repeat:[0], DQ:[0]
     [m3vpss ]  11661: CAPTURE: Enabled Time Stamping !!!
     [m3vpss ] ***** VPSS Firmware build time 15:57:19 Nov 18 2013  EDG gcc 3.0 mode
     [m3vpss ] !!!XDC RUNTIME ASSERT FAILED
     [m3vpss ] xdc.runtime.Error @ ti.sysbios.gates.GateMutex: line 97:
     [m3vpss ] assertion failure: A_badContext: bad calling context. See GateMutex API doc for details.
     [c6xdsp ]  ALG SYSTEM_CMD_NEW_DATA!!!  is i add for test..
    can you help me to resolved this problem?
    thanks.
  • It looks like you have added some print statement in ISR. Remove all your code changes including all debug prints and test .
  • Hi Badri:
    this time, there isn't exception.
    but I cann't get normal video data yet.
    the log is:
     [c6xdsp ] SYSTEM_CMD_NEW_DATA ALG_LINK_OSD_CMD_SET_CHANNEL_WIN_PRM!!!
     [m3vpss ]  11181: DISPLAY: HDDAC(BP0) : 47 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) DropCount:0 DispLatency (Min / Max) = ( 7669 / 0 ) !!!
     [m3vpss ]  11181: DISPLAY DRV: HDDAC(BP0) : Q:[2] Display:[2], Repeat:[1], DQ:[0]
     [m3vpss ]  11181: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 1, HDDAC(BP0) 1, DVO2(BP1) 1, SDDAC(SEC1) 0
     [m3vpss ]  11181: SYSTEM  : FREE SPACE : System Heap      = 67128 B, Mbx = 10238 msgs)
     [m3vpss ]  11182: SYSTEM  : FREE SPACE : SR0 Heap         = 56712192 B (54 MB)
     [m3vpss ]  11182: SYSTEM  : FREE SPACE : Frame Buffer     = 126133632 B (120 MB)
     [m3vpss ]  11182: SYSTEM  : FREE SPACE : Bitstream Buffer = 97607296 B (93 MB)
     [m3vpss ] TILER_STATS: CNT :8BIT
     [m3vpss ] TILER_STATS: CNT RESOLUTION:    16384 x 5440
     [m3vpss ] TILER_STATS: BUCKET RESOLUTION: 16384 x 5436
     [m3vpss ] TILER_STATS: NUM FREE BUCKETS:  1
     [m3vpss ] TILER_STATS: NUM USED BUCKETS:  0
     [m3vpss ] TILER_STATS: TOTAL FREE AREA:   89063424 (99 %)
     [m3vpss ] TILER_STATS: TOTAL USED AREA:   0 (0 %)
     [c6xdsp ] ALG IN
     [m3video]  63777: SYSTEM: Opening MsgQ [DSP_MSGQ] ...
     [m3vpss ] TILER_STATS: CNT :16BIT
     [c6xdsp ] ALG IN
     [m3vpss ] TILER_STATS: CNT RESOLUTION:    32768 x 1344
     [m3vpss ] TILER_STATS: BUCKET RESOLUTION: 32768 x 1344
     [c6xdsp ] ALG IN
     [c6xdsp ] ALG IN
     [m3vpss ] TILER_STATS: TOTAL FREE AREA:   44040192 (100 %)
     [c6xdsp ] ALG IN
     [m3vpss ]  11184: SYSTEM  : FREE SPACE : Tiler 8-bit      = 89063424 B (84 MB)  - TILER ON
     [m3vpss ]  11184: SYSTEM  : FREE SPACE : Tiler 16-bit     = 44040192 B (42 MB)  - TILER ON
     [c6xdsp ] ALG IN
     [m3vpss ]  11241: DISPLAY: SDDAC(SEC1): 16 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) DropCount:0 DispLatency (Min / Max) = ( 7669 / 0 ) !!!
     [m3vpss ]  11241: DISPLAY DRV: SDDAC(SEC1): Q:[2] Display:[1], Repeat:[0], DQ:[0]
     [m3vpss ]  11344: CAPTURE: Enabled Time Stamping !!!
  • Hi
       4 hours ago, it down. the log is:
    Jan  4 04:43:05 dm816x daemon.info thttpd[460]: up 3605 seconds, stats for 3605 seconds:
    Jan  4 04:43:05 dm816x daemon.info thttpd[460]:   thttpd - 0 connections (0/sec), 0 max simultaneous, 0 bytes (0/sec), 0 httpd_conns allocated
    Jan  4 04:43:05 dm816x daemon.info thttpd[460]:   map cache - 0 allocated, 0 active (0 bytes), 0 free; hash size: 0; expire age: 1800
    Jan  4 04:43:05 dm816x daemon.info thttpd[460]:   fdwatch - 2224 polls (0.616921/sec)
    Jan  4 04:43:05 dm816x daemon.info thttpd[460]:   timers - 3 allocated, 3 active, 0 free
    Jan  4 05:43:05 dm816x daemon.info thttpd[460]: up 7205 seconds, stats for 3600 seconds:
    Jan  4 05:43:05 dm816x daemon.info thttpd[460]:   thttpd - 0 connections (0/sec), 0 max simultaneous, 0 bytes (0/sec), 0 httpd_conns allocated
    Jan  4 05:43:05 dm816x daemon.info thttpd[460]:   map cache - 0 allocated, 0 active (0 bytes), 0 free; hash size: 0; expire age: 1800
    Jan  4 05:43:05 dm816x daemon.info thttpd[460]:   fdwatch - 1859 polls (0.516389/sec)
    Jan  4 05:43:05 dm816x daemon.info thttpd[460]:   timers - 3 allocated, 3 active, 0 free
    Jan  4 06:43:05 dm816x daemon.info thttpd[460]: up 10805 seconds, stats for 3600 seconds:
    Jan  4 06:43:05 dm816x daemon.info thttpd[460]:   thttpd - 0 connections (0/sec), 0 max simultaneous, 0 bytes (0/sec), 0 httpd_conns allocated
    Jan  4 06:43:05 dm816x daemon.info thttpd[460]:   map cache - 0 allocated, 0 active (0 bytes), 0 free; hash size: 0; expire age: 1800
    Jan  4 06:43:05 dm816x daemon.info thttpd[460]:   fdwatch - 1300 polls (0.361111/sec)
    Jan  4 06:43:05 dm816x daemon.info thttpd[460]:   timers - 3 allocated, 3 active, 0 free
    Jan  4 07:43:05 dm816x daemon.info thttpd[460]: up 14405 seconds, stats for 3600 seconds:
    Jan  4 07:43:05 dm816x daemon.info thttpd[460]:   thttpd - 0 connections (0/sec), 0 max simultaneous, 0 bytes (0/sec), 0 httpd_conns allocated
    Jan  4 07:43:05 dm816x daemon.info thttpd[460]:   map cache - 0 allocated, 0 active (0 bytes), 0 free; hash size: 0; expire age: 1800
    Jan  4 07:43:05 dm816x daemon.info thttpd[460]:   fdwatch - 2789 polls (0.774722/sec)
    Jan  4 07:43:05 dm816x daemon.info thttpd[460]:   timers - 3 allocated, 3 active, 0 free
     [m3vpss ] Unhandled Exception:
     [m3vpss ] Exception occurred in ThreadType_SWI
     [m3vpss ] handle: 0x930b8098.
     [m3vpss ] stack base: 0x930bbda4.
     [m3vpss ] stack size: 0x4000.
     [m3vpss ] R0 = 0x930b8098  R8  = 0x35dbec00
     [m3vpss ] R1 = 0x05500000  R9  = 0x00000001
     [m3vpss ] R2 = 0x00000001  R10 = 0x00002ffc
     [m3vpss ] R3 = 0x00000001  R11 = 0x00000004
     [m3vpss ] R4 = 0x930b8098  R12 = 0x35dd9828
     [m3vpss ] R5 = 0x92c94798  SP(R13) = 0x930bfcc8
     [m3vpss ] R6 = 0x930b7df0  LR(R14) = 0x92c5ef81
     [m3vpss ] R7 = 0x00000000  PC(R15) = 0x05500000
     [m3vpss ] PSR = 0x80000000
     [m3vpss ] ICSR = 0x00400803
     [m3vpss ] MMFSR = 0x00
     [m3vpss ] BFSR = 0x01
     [m3vpss ] UFSR = 0x0000
     [m3vpss ] HFSR = 0x40000000
     [m3vpss ] DFSR = 0x00000000
     [m3vpss ] MMAR = 0xe000ed34
     [m3vpss ] BFAR = 0xe000ed38
     [m3vpss ] AFSR = 0x00000000
     [m3vpss ] Terminating Execution...
    Jan  4 08:43:05 dm816x daemon.info thttpd[460]: up 18005 seconds, stats for 3600 seconds:
    Jan  4 08:43:05 dm816x daemon.info thttpd[460]:   thttpd - 0 connections (0/sec), 0 max simultaneous, 0 bytes (0/sec), 0 httpd_conns allocated
    Jan  4 08:43:05 dm816x daemon.info thttpd[460]:   map cache - 0 allocated, 0 active (0 bytes), 0 free; hash size: 0; expire age: 1800
    Jan  4 08:43:05 dm816x daemon.info thttpd[460]:   fdwatch - 1562 polls (0.433889/sec)
    Jan  4 08:43:05 dm816x daemon.info thttpd[460]:   timers - 3 allocated, 3 active, 0 free
    Jan  4 09:43:05 dm816x daemon.info thttpd[460]: up 21605 seconds, stats for 3600 seconds:
    Jan  4 09:43:05 dm816x daemon.info thttpd[460]:   thttpd - 0 connections (0/sec), 0 max simultaneous, 0 bytes (0/sec), 0 httpd_conns allocated
    Jan  4 09:43:05 dm816x daemon.info thttpd[460]:   map cache - 0 allocated, 0 active (0 bytes), 0 free; hash size: 0; expire age: 1800
    Jan  4 09:43:05 dm816x daemon.info thttpd[460]:   fdwatch - 736 polls (0.204444/sec)
    Jan  4 09:43:05 dm816x daemon.info thttpd[460]:   timers - 3 allocated, 3 active, 0 free
