caplink scEnable problem
Hi all,
I am working on DM8168 with DVRRDK 4.0.
My issue is:
When I run the program first time, it work properly, then exit the program and run it again,
the program is blocked and the m3vpss print "Capture Driver Advanced Statistics" periodically.
The links are connected as below:
ipcBitsOutHost--> ipcBitsInVideo-> Decode--> ipcOutVideo--> ipcInVpss--| |--> SwMs1--> Display1
|-->merge-->select-->|
capture---| |--> SwMs0--> Dup0 -->(1)
|--> Display0
(1)-->|
|--> Nfs--> ipcOutVpss->ipcInVideo-->Encode-->ipcBitsOutVideo-->ipcBitsInHost
Params related to capture are:
capturePrm.numVipInst = gVcapModuleContext.vcapConfig.numChn;
capturePrm.tilerEnable = TRUE;
capturePrm.numExtraBufs = 0;
capturePrm.maxBlindAreasPerCh = 0;
capturePrm.isPalMode = FALSE;
capturePrm.enableSdCrop = FALSE;
capturePrm.doCropInCapture = FALSE;
for (vipInstId = 0; vipInstId < capturePrm.numVipInst; vipInstId++) {
pCaptureInstPrm = &capturePrm.vipInst[vipInstId];
pCaptureInstPrm->vipInstId = (SYSTEM_CAPTURE_INST_VIP0_PORTA + 2 * vipInstId) % SYSTEM_CAPTURE_INST_MAX;
pCaptureInstPrm->videoDecoderId = 0;//SYSTEM_DEVICE_VID_DEC_SII9233A_DRV;
pCaptureInstPrm->inDataFormat = SYSTEM_DF_YUV422P;
pCaptureInstPrm->standard = lnk_prm->m_vcap_prm.m_vid_std[vipInstId];
pCaptureInstPrm->numOutput = 1;
pCaptureInstPrm->numChPerOutput = 1;
pCaptureInstPrm->numBufsPerCh = 16;
pCaptureOutPrm = &pCaptureInstPrm->outParams[0];
pCaptureOutPrm->dataFormat = SYSTEM_DF_YUV420SP_UV;
#if 0
pCaptureOutPrm->scEnable = FALSE;
#else
pCaptureOutPrm->scEnable = TRUE;
f(vipInstId == 0) {
pCaptureOutPrm->scOutWidth = 1440;
pCaptureOutPrm->scOutHeight = 810;
} else if(vipInstId == 1) {
pCaptureOutPrm->scOutWidth = 480;
pCaptureOutPrm->scOutHeight = 270;
#endif
pCaptureOutPrm->outQueId = 0;
Params related to SwMs are:
swMsPrm[0].swMsInstId[0] = SYSTEM_SW_MS_SC_INST_SC5;
swMsPrm[0].swMsInstId[1] = SYSTEM_SW_MS_SC_INST_DEIHQ_SC_NO_DEI;
swMsPrm[0].numSwMsInst = 2;
swMsPrm[0].swMsInstStartWin[0] = 0;
swMsPrm[0].swMsInstStartWin[1] = 3;
swMsPrm[1].swMsInstId[0] = SYSTEM_SW_MS_SC_INST_DEI_SC_NO_DEI;
swMsPrm[1].swMsInstId[1] = SYSTEM_SW_MS_SC_INST_VIP1_SC;
swMsPrm[1].numSwMsInst = 1;
swMsPrm[1].swMsInstStartWin[0] = 0;
swMsPrm[1].swMsInstStartWin[1] = 2;
swMsPrm[0].enableProcessTieWithDisplay = FALSE;
swMsPrm[1].enableProcessTieWithDisplay = FALSE;
swMsPrm[0].includeVipScInDrvPath = FALSE;
swMsPrm[1].includeVipScInDrvPath = FALSE;
If I set pCaptureOutPrm->scEnable to FALSE, this issue will not occur;
I also note that the three registers value are different.
The first time program exit, registers value are:
[m3vpss ] VIP0 : FIQ_STATUS : 0x4810551c = 0x00000000
[m3vpss ] VIP1 : FIQ_STATUS : 0x48105a1c = 0x00000000
[m3vpss ] VPDMA: LIST_BUSY : 0x4810d00c = 0x00000000
The second time I run the program those value changed to:
[m3vpss ] VIP0 : FIQ_STATUS : 0x4810551c = 0x00000010
[m3vpss ] VPDMA: LIST_BUSY : 0x4810d00c = 0x00030000
How can I fix this issue?
Any suggestion will be appreciated.
The detailed logs are attached here
codecs_system_env_init: Initiailze debug module.
codecs_system_env_init: Initiailze task manager.
==================== VSYS PARAM====================
enable_splicing_encode = 1
enable_file_write = 0
==================== VCAP PARAM====================
vcap_chn_num = 1
enable_hdmi_detect = 0
vcap_vid0_std = 18
==================== VENC PARAM====================
venc_chn_num = 1
venc_chn0_width = 1920
venc_chn0_height = 1080
venc_chn0_frame_rate = 60
venc_chn0_frame_interval = 60
venc_chn0_bitrate = 8000000
venc_chn0_profile = 100
venc_chn0_rc_alg = 1
venc_chn0_codec = 66
venc_chn0_field_merge_encode_enable = 0
venc_chn0_trans_t = 2
venc_chn0_rtsp_port = 8554
venc_chn0_rtsp_frame_rate = 60
==================== VDEC PARAM====================
vdec_chn_num = 0
==================== VDIS PARAM====================
vdis_dev_num = 2
vdis_dev0_std = 18
vdis_dev0_mode = 7
vdis_dev1_std = 18
vdis_dev1_mode = 3
img size = 14784.
--------------- CHANNEL DETAILS-------------
Capture Channels => 1
Enc Channels => Primary 1, Secondary 0
Dec Channels => 0
Disp Channels => 0
 VCAP: DEVICE-0 (0x30): Chip ID 0x9233, Rev 0x0033, Firmware 0x0001 !!!
 VCAP: DEVICE-0 (0x30): Detected video (1920x1080@15750Hz, 0) !!!
 VCAP: DEVICE-1 (0x31): Chip ID 0x9233, Rev 0x0033, Firmware 0x0001 !!!
 VCAP: DEVICE-1 (0x31):  NO Video Detected !!!
 0: SYSTEM: System Common Init in progress !!!
 0: SYSTEM: IPC init in progress !!!
 17: SYSTEM: CPU [DSP] syslink proc ID is [0] !!!
 17: SYSTEM: CPU [VIDEO-M3] syslink proc ID is [1] !!!
 17: SYSTEM: CPU [VPSS-M3] syslink proc ID is [2] !!!
 17: SYSTEM: CPU [HOST] syslink proc ID is [3] !!!
 17: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_3] ...
 20: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
 22: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
 24: SYSTEM: Opening MsgQ [DSP_MSGQ] ...
 24: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
 25: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
 26: SYSTEM: Notify register to [DSP] line 0, event 15 ...
 27: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
 28: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
 28: SYSTEM: IPC init DONE !!!
 30: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
 32: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
 34: SYSTEM: ListElem Shared Addr = 0x40e28880
 35: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
 38: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
 40: SYSTEM: ListElem Shared Addr = 0x40e5da80
 41: SYSTEM: Creating ListMP [HOST_IPC_OUT_19] in region 0 ...
 44: SYSTEM: Creating ListMP [HOST_IPC_IN_19] in region 0 ...
 46: SYSTEM: ListElem Shared Addr = 0x40e92c80
 47: SYSTEM: Creating ListMP [HOST_IPC_OUT_20] in region 0 ...
 50: SYSTEM: Creating ListMP [HOST_IPC_IN_20] in region 0 ...
 51: SYSTEM: ListElem Shared Addr = 0x40ed5f80
 52: SYSTEM: Creating ListMP [HOST_IPC_OUT_21] in region 0 ...
 55: SYSTEM: Creating ListMP [HOST_IPC_IN_21] in region 0 ...
 57: SYSTEM: ListElem Shared Addr = 0x40f19280
 75: SYSTEM: System Common Init Done !!!
DEV:2, win[0]: w = 960, h = 540
DEV:2, win[1]: w = 960, h = 540
DEV:2, win[2]: w = 960, h = 540
DEV:2, win[3]: w = 960, h = 540
 [host] HDMI Ctrl :Initializing
 [host] HDMI Ctrl :Initialized
 [host] HDMI Ctrl :Sink Connected
__codecs_osd_initialize: Using user's osa parameters.
[src/codecs_links.c 372 @ Jul 09, 12:55:55] __codecs_decoder_links_create: Enter.
codecs_avsync_set_avs_params: Enter(avs_id=0, swms_id=536870960, disp_id=536870954, chn_nums=19).
codecs_avsync_set_avs_params: Leave(status=0x0).
codecs_avsync_set_avs_params: Enter(avs_id=1, swms_id=536870961, disp_id=536870955, chn_nums=19).
 [m3vpss ]  301316: CAPTURE: Create in progress !!!
 [m3vpss ]  301350: CAPTURE: VIP0 PortA capture mode is [16-bit, Non-mux Embedded Sync] !!!
 [m3vpss ]  UTILS: DMA: Allocated CH (TCC) = 58 (58)
 [m3vpss ]  UTILS: DMA: 0 of 4: Allocated PaRAM = 58 (0x49004740)
 [host]  1568: IPC_BITS_OUT   : Create in progress !!!
 [host] IPC_BITSOUT:BitBuffer Alloc.ChID:0,Size:0x9E3400
 [host]
******* RingBuf 0 created ********
 [host] IPCBITSOUTLINK:Translated Addr Virt:0x42136080 To Phy:0x80000080
 [host]
###Bit buff of size from the SR # 1 : 10368000 / bufsize 1036800, maxQueueDepth 1
 [host] ###Bit buff BasePtr: 42136080 / PhyAddr 80000080
 [host] IPC_BITSOUT:BitBuffer Alloc.ChID:1,Size:0x9E3400
 [host]
******* RingBuf 1 created ********
 [host] IPCBITSOUTLINK:Translated Addr Virt:0x42b19480 To Phy:0x809e3480
 [host]
 [host] ###Bit buff BasePtr: 42B19480 / PhyAddr 809E3480
 [host] IPC_BITSOUT:BitBuffer Alloc.ChID:2,Size:0x9E3400
 [host]
******* RingBuf 2 created ********
 [host] IPCBITSOUTLINK:Translated Addr Virt:0x434fc880 To Phy:0x813c6880
 [host]
 [host] ###Bit buff BasePtr: 434FC880 / PhyAddr 813C6880
 [host] IPC_BITSOUT:BitBuffer Alloc.ChID:3,Size:0x9E3400
 [host]
******* RingBuf 3 created ********
 [host] IPCBITSOUTLINK:Translated Addr Virt:0x43edfc80 To Phy:0x81da9c80
 [host]
 [host] ###Bit buff BasePtr: 43EDFC80 / PhyAddr 81DA9C80
 [host] IPC_BITSOUT:BitBuffer Alloc.ChID:4,Size:0x9E3400
 [host]
******* RingBuf 4 created ********
 [host] IPCBITSOUTLINK:Translated Addr Virt:0x448c3080 To Phy:0x8278d080
 [host]
 [host] ###Bit buff BasePtr: 448C3080 / PhyAddr 8278D080
 [host] IPC_BITSOUT:BitBuffer Alloc.ChID:5,Size:0x9E3400
 [host]
******* RingBuf 5 created ********
 [host] IPCBITSOUTLINK:Translated Addr Virt:0x452a6480 To Phy:0x83170480
 [host]
 [host] ###Bit buff BasePtr: 452A6480 / PhyAddr 83170480
 [host] IPC_BITSOUT:BitBuffer Alloc.ChID:6,Size:0x9E3400
 [host]
******* RingBuf 6 created ********
 [host] IPCBITSOUTLINK:Translated Addr Virt:0x45c89880 To Phy:0x83b53880
 [host]
 [host] ###Bit buff BasePtr: 45C89880 / PhyAddr 83B53880
 [host] IPC_BITSOUT:BitBuffer Alloc.ChID:7,Size:0x9E3400
 [host]
******* RingBuf 7 created ********
 [host] IPCBITSOUTLINK:Translated Addr Virt:0x4666cc80 To Phy:0x84536c80
 [host]
 [host] ###Bit buff BasePtr: 4666CC80 / PhyAddr 84536C80
 [host] IPC_BITSOUT:BitBuffer Alloc.ChID:8,Size:0x9E3400
 [host]
******* RingBuf 8 created ********
 [host] IPCBITSOUTLINK:Translated Addr Virt:0x47050080 To Phy:0x84f1a080
 [host]
 [host] ###Bit buff BasePtr: 47050080 / PhyAddr 84F1A080
 [host] IPC_BITSOUT:BitBuffer Alloc.ChID:9,Size:0x9E3400
 [host]
******* RingBuf 9 created ********
 [host] IPCBITSOUTLINK:Translated Addr Virt:0x47a33480 To Phy:0x858fd480
 [host]
 [host] ###Bit buff BasePtr: 47A33480 / PhyAddr 858FD480
 [host] IPC_BITSOUT:BitBuffer Alloc.ChID:10,Size:0x9E3400
 [host]
******* RingBuf 10 created ********
 [host] IPCBITSOUTLINK:Translated Addr Virt:0x48416880 To Phy:0x862e0880
 [host]
 [host] ###Bit buff BasePtr: 48416880 / PhyAddr 862E0880
 [host] IPC_BITSOUT:BitBuffer Alloc.ChID:11,Size:0x9E3400
 [host]
******* RingBuf 11 created ********
 [host] IPCBITSOUTLINK:Translated Addr Virt:0x48df9c80 To Phy:0x86cc3c80
 [host]
 [host] ###Bit buff BasePtr: 48DF9C80 / PhyAddr 86CC3C80
 [host] IPC_BITSOUT:BitBuffer Alloc.ChID:12,Size:0x9E3400
 [host]
******* RingBuf 12 created ********
 [host] IPCBITSOUTLINK:Translated Addr Virt:0x497dd080 To Phy:0x876a7080
 [host]
 [host] ###Bit buff BasePtr: 497DD080 / PhyAddr 876A7080
 [host] IPC_BITSOUT:BitBuffer Alloc.ChID:13,Size:0x9E3400
 [host]
******* RingBuf 13 created ********
 [host] IPCBITSOUTLINK:Translated Addr Virt:0x4a1c0480 To Phy:0x8808a480
 [host]
 [host] ###Bit buff BasePtr: 4A1C0480 / PhyAddr 8808A480
 [host] IPC_BITSOUT:BitBuffer Alloc.ChID:14,Size:0x9E3400
 [host]
******* RingBuf 14 created ********
 [host] IPCBITSOUTLINK:Translated Addr Virt:0x4aba3880 To Phy:0x88a6d880
 [host]
 [host] ###Bit buff BasePtr: 4ABA3880 / PhyAddr 88A6D880
 [host] IPC_BITSOUT:BitBuffer Alloc.ChID:15,Size:0x9E3400
 [host]
******* RingBuf 15 created ********
 [host] IPCBITSOUTLINK:Translated Addr Virt:0x4b586c80 To Phy:0x89450c80
 [host]
 [host] ###Bit buff BasePtr: 4B586C80 / PhyAddr 89450C80
 [host] IPC_BITSOUT:BitBuffer Alloc.ChID:16,Size:0x9E3400
 [host]
******* RingBuf 16 created ********
 [host] IPCBITSOUTLINK:Translated Addr Virt:0x4bf6a080 To Phy:0x89e34080
 [host]
 [host] ###Bit buff BasePtr: 4BF6A080 / PhyAddr 89E34080
 [host]  1571: IPC_BITS_OUT   : Create Done !!!
 [m3video]  301356: IPC_BITS_IN   : Create in progress !!!
 [m3vpss ]  UTILS: DMA: 1 of 4: Allocated PaRAM = 64 (0x49004800)
 [m3video]  301357: SYSTEM: Opening ListMP [HOST_IPC_OUT_24] ...
 [m3vpss ]  UTILS: DMA: 2 of 4: Allocated PaRAM = 65 (0x49004820)
 [m3video]  301357: SYSTEM: Opening ListMP [HOST_IPC_IN_24] ...
 [m3vpss ]  UTILS: DMA: 3 of 4: Allocated PaRAM = 66 (0x49004840)
 [m3video]  301358: SYSTEM: Opening MsgQ [HOST_MSGQ] ...
 [m3video]  301359: IPC_BITS_IN   : Create Done !!!
 [m3video]  301360: DECODE: Create in progress ... !!!
 [m3vpss ] CAPTURE::HEAPID:0    USED:328
 [m3video] 301361: DECODE: CodecInst and OutFrm bufs are NOT created for CH0
 [m3vpss ] CAPTURE::HEAPID:4    USED:4608000
 [m3video]  301361: DECODE: Creating CH0 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 8000 Kbps ...
 [m3vpss ]  301353: CAPTURE: Create Done !!!
 [m3video] 301361: DECODE: CodecInst and OutFrm bufs are NOT created for CH1
 [m3video]  301362: DECODE: Creating CH1 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 8000 Kbps ...
 [m3video] 301362: DECODE: CodecInst and OutFrm bufs are NOT created for CH2
 [m3video]  301362: DECODE: Creating CH2 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 8000 Kbps ...
 [m3video] 301362: DECODE: CodecInst and OutFrm bufs are NOT created for CH3
 [m3video]  301362: DECODE: Creating CH3 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 8000 Kbps ...
 [m3video] 301362: DECODE: CodecInst and OutFrm bufs are NOT created for CH4
 [m3video]  301362: DECODE: Creating CH4 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 8000 Kbps ...
 [m3video] 301363: DECODE: CodecInst and OutFrm bufs are NOT created for CH5
 [m3video]  301363: DECODE: Creating CH5 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 8000 Kbps ...
 [m3video] 301363: DECODE: CodecInst and OutFrm bufs are NOT created for CH6
 [m3video]  301363: DECODE: Creating CH6 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 8000 Kbps ...
 [m3video] 301363: DECODE: CodecInst and OutFrm bufs are NOT created for CH7
 [m3video]  301363: DECODE: Creating CH7 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 8000 Kbps ...
 [m3vpss ]  301372: IPC_IN_M3   : Create in progress !!!
 [m3video] 301364: DECODE: CodecInst and OutFrm bufs are NOT created for CH8
 [m3vpss ]  301372: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_0] ...
 [m3video]  301364: DECODE: Creating CH8 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 8000 Kbps ...
 [m3vpss ]  301373: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_0] ...
 [m3video] 301364: DECODE: CodecInst and OutFrm bufs are NOT created for CH9
 [m3vpss ]  301373: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
 [m3video]  301364: DECODE: Creating CH9 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 8000 Kbps ...
 [m3video] 301364: DECODE: CodecInst and OutFrm bufs are NOT created for CH10
 [m3video]  301364: DECODE: Creating CH10 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 8000 Kbps ...
 [m3video] 301364: DECODE: CodecInst and OutFrm bufs are NOT created for CH11
 [m3video]  301365: DECODE: Creating CH11 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 8000 Kbps ...
 [m3video] 301365: DECODE: CodecInst and OutFrm bufs are NOT created for CH12
 [m3video]  301365: DECODE: Creating CH12 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 8000 Kbps ...
 [m3video] 301365: DECODE: CodecInst and OutFrm bufs are NOT created for CH13
 [m3video]  301365: DECODE: Creating CH13 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 8000 Kbps ...
 [m3video] 301365: DECODE: CodecInst and OutFrm bufs are NOT created for CH14
 [m3video]  301365: DECODE: Creating CH14 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 8000 Kbps ...
 [m3video] 301366: DECODE: CodecInst and OutFrm bufs are NOT created for CH15
 [m3video]  301366: DECODE: Creating CH15 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 8000 Kbps ...
 [m3video] 301366: DECODE: CodecInst and OutFrm bufs are NOT created for CH16
 [m3video]  301366: DECODE: Creating CH16 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 8000 Kbps ...
 [m3video]  301368: DECODE: All CH Create ... DONE !!!
 [m3vpss ]  301375: IPC_IN_M3   : Create Done !!!
 [m3video] DECLINK:HEAPID:0     USED:120
 [m3vpss ]  301376: MERGE   : Create Done !!!
 [m3video]  301371: DECODE: Create ... DONE !!!
 [m3vpss ]  301377: SELECT: OUT QUE0: OUT CH0: IN CH17: 1440 x 810, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ]
 [m3video]  301371: IPC_OUT_M3   : Create in progress !!!
 [m3vpss ]  301377: SELECT: OUT QUE0: OUT CH1: IN CH18: 0 x 0, pitch = (0, 0) [INTERLACED ] [NON-TILED  ]
 [m3video]  301372: IPC_OUT_M3   : Create Done !!!
 [m3vpss ]  301377: SELECT: OUT QUE0: OUT CH2: IN CH0: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  301378: SELECT: OUT QUE0: OUT CH3: IN CH1: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  301378: SELECT: OUT QUE0: OUT CH4: IN CH2: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  301378: SELECT: OUT QUE0: OUT CH5: IN CH3: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  301378: SELECT: OUT QUE0: OUT CH6: IN CH4: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  301378: SELECT: OUT QUE0: OUT CH7: IN CH5: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  301379: SELECT: OUT QUE0: OUT CH8: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  301379: SELECT: OUT QUE0: OUT CH9: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  301379: SELECT: OUT QUE0: OUT CH10: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  301379: SELECT: OUT QUE0: OUT CH11: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  301379: SELECT: OUT QUE0: OUT CH12: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  301380: SELECT: OUT QUE0: OUT CH13: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  301380: SELECT: OUT QUE0: OUT CH14: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  301380: SELECT: OUT QUE0: OUT CH15: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  301380: SELECT: OUT QUE0: OUT CH16: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  301380: SELECT: OUT QUE0: OUT CH17: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  301381: SELECT: OUT QUE0: OUT CH18: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  301381: SELECT: OUT QUE1: OUT CH0: IN CH8: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  301381: SELECT: OUT QUE1: OUT CH1: IN CH9: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  301381: SELECT: OUT QUE1: OUT CH2: IN CH10: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  301381: SELECT: OUT QUE1: OUT CH3: IN CH11: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  301381: SELECT: OUT QUE1: OUT CH4: IN CH12: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  301382: SELECT: OUT QUE1: OUT CH5: IN CH13: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  301382: SELECT: OUT QUE1: OUT CH6: IN CH14: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  301382: SELECT: OUT QUE1: OUT CH7: IN CH15: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  301382: SELECT: OUT QUE1: OUT CH8: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  301382: SELECT: OUT QUE1: OUT CH9: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  301383: SELECT: OUT QUE1: OUT CH10: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  301383: SELECT: OUT QUE1: OUT CH11: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  301383: SELECT: OUT QUE1: OUT CH12: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  301383: SELECT: OUT QUE1: OUT CH13: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  301383: SELECT: OUT QUE1: OUT CH14: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  301384: SELECT: OUT QUE1: OUT CH15: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  301384: SELECT: OUT QUE1: OUT CH16: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  301384: SELECT: OUT QUE1: OUT CH17: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  301384: SELECT: OUT QUE1: OUT CH18: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  301384: SELECT   : Create Done !!!
 [m3vpss ]  301385: SWMS: Create in progress !!!
 [m3vpss ]  UTILS: DMA: Allocated CH (TCC) = 59 (59)
 [m3vpss ]  UTILS: DMA: 0 of 1: Allocated PaRAM = 59 (0x49004760)
 [m3vpss ]  UTILS: DMA: Allocated CH (TCC) = 60 (60)
 [m3vpss ]  UTILS: DMA: 0 of 4: Allocated PaRAM = 60 (0x49004780)
 [m3vpss ]  UTILS: DMA: 1 of 4: Allocated PaRAM = 67 (0x49004860)
 [m3vpss ]  UTILS: DMA: 2 of 4: Allocated PaRAM = 160 (0x49005400)
 [m3vpss ]  UTILS: DMA: 3 of 4: Allocated PaRAM = 161 (0x49005420)
 [m3vpss ] SWMS: instance 0, sc id 5, start win 0 end win 2
 [m3vpss ] SWMS: instance 1, sc id 6, start win 3 end win 20
 [m3vpss ]  301578: SWMS0    : Loading Vertical Co-effs (UPSCALE)x ...
 [m3vpss ]  301578: SWMS0    : Loading Horizontal Co-effs (UPSCALE)x ...
 [m3vpss ]  301578: SWMS    : Co-effs Loading ... DONE !!!
 [m3vpss ]  301578: SWMS    : VipScReq is FALSE!!!
 [m3vpss ]  301582: SWMS0    : Loading Vertical Co-effs (UPSCALE)x ...
 [m3vpss ]  301582: SWMS0    : Loading Horizontal Co-effs (UPSCALE)x ...
 [m3vpss ]  301582: SWMS    : Co-effs Loading ... DONE !!!
 [m3vpss ]  301583: SWMS    : ******* Configuring clock 16 secs...
 [m3vpss ]  301583: SWMS0    : Loading Vertical Co-effs (UPSCALE)x ...
 [m3vpss ]  301583: SWMS0    : Loading Horizontal Co-effs (UPSCALE)x ...
 [m3vpss ]  301583: SWMS    : Co-effs Loading ... DONE !!!
 [m3vpss ]
 [m3vpss ]  *** [SWMS0] Mosaic Parameters ***
 [m3vpss ]
 [m3vpss ]  Output FPS: 60
 [m3vpss ]
 [m3vpss ]  Win | Ch  | Input      | Input          | Input         | Input       | Output     |  Output         | Output        | Output      | Low Cost | SWMS | Data  | Blank |
 [m3vpss ]  Num | Num | Start X, Y | Width x Height | Pitch Y / C   | Memory Type | Start X, Y |  Width x Height | Pitch Y / C   | Memory Type | ON / OFF | Inst | Format| Frame |
 [m3vpss ]  ----------------------------------------------------------------------------------------------------------------------------------------------------------------------
 [m3vpss ]    0 |   0 |    0,    0 |  1440 x    810 | 16384 / 32768 | TILED       |    0,    0 |  1440 x    810 |  3840 /      0 | NON-TILED   |       ON |    0 |  420SP |   OFF |
 [m3vpss ]    1 |   1 |    0,    0 |     0 x      0 |     0 /     0 | NON-TILED   | 1440,    0 |   480 x    270 |  3840 /      0 | NON-TILED   |       ON |    0 | UNKNWN |   OFF |
 [m3vpss ]    2 |   2 |    0,    0 |  1920 x    540 |  4096 /  4096 | NON-TILED   | 1440,  270 |   480 x    270 |  3840 /      0 | NON-TILED   |       ON |    0 |  420SP |   OFF |
 [m3vpss ]    3 |   3 |    0,    0 |  1920 x    540 |  4096 /  4096 | NON-TILED   | 1440,  540 |   480 x    270 |  3840 /      0 | NON-TILED   |       ON |    1 |  420SP |   OFF |
 [m3vpss ]    4 |   4 |    0,    0 |  1920 x    540 |  4096 /  4096 | NON-TILED   |    0,  810 |   480 x    270 |  3840 /      0 | NON-TILED   |       ON |    1 |  420SP |   OFF |
 [m3vpss ]    5 |   5 |    0,    0 |  1920 x    540 |  4096 /  4096 | NON-TILED   |  480,  810 |   480 x    270 |  3840 /      0 | NON-TILED   |       ON |    1 |  420SP |   OFF |
 [m3vpss ]    6 |   6 |    0,    0 |  1920 x    540 |  4096 /  4096 | NON-TILED   |  960,  810 |   480 x    270 |  3840 /      0 | NON-TILED   |       ON |    1 |  420SP |   OFF |
 [m3vpss ]    7 |   7 |    0,    0 |  1920 x    540 |  4096 /  4096 | NON-TILED   | 1440,  810 |   480 x    270 |  3840 /      0 | NON-TILED   |       ON |    1 |  420SP |   OFF |
 [m3vpss ]
 [m3vpss ] SWMS:HEAPID:0        USED:424
 [m3vpss ] SWMS:HEAPID:1        USED:66656
 [m3vpss ] SWMS:HEAPID:4        USED:37324800
 [m3vpss ]  301587: SWMS: Create Done !!!
 [m3vpss ]  301587: SWMS: Create in progress !!!
 [m3vpss ]  UTILS: DMA: Allocated CH (TCC) = 61 (61)
 [m3vpss ]  UTILS: DMA: 0 of 1: Allocated PaRAM = 61 (0x490047A0)
 [m3vpss ]  UTILS: DMA: Allocated CH (TCC) = 62 (62)
 [m3vpss ]  UTILS: DMA: 0 of 4: Allocated PaRAM = 62 (0x490047C0)
 [m3vpss ]  UTILS: DMA: 1 of 4: Allocated PaRAM = 162 (0x49005440)
 [m3vpss ]  UTILS: DMA: 2 of 4: Allocated PaRAM = 163 (0x49005460)
 [m3vpss ]  UTILS: DMA: 3 of 4: Allocated PaRAM = 164 (0x49005480)
 [m3vpss ] SWMS: instance 0, sc id 7, start win 0 end win 17
 [m3vpss ]  301776: SWMS    : VipScReq is FALSE!!!
 [c6xdsp ]  301024: IPC_FRAMES_IN   : Create in progress !!!
 [m3vpss ]  301779: SWMS1    : Loading Vertical Co-effs (UPSCALE)x ...
 [c6xdsp ]  301024: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_19] ...
 [m3vpss ]  301779: SWMS1    : Loading Horizontal Co-effs (UPSCALE)x ...
 [c6xdsp ]  301024: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_19] ...
 [m3vpss ]  301780: SWMS    : Co-effs Loading ... DONE !!!
 [c6xdsp ]  301024: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
 [m3vpss ]  301780: SWMS    : ******* Configuring clock 16 secs...
 [m3vpss ]  301780: SWMS1    : Loading Vertical Co-effs (7/16)x ...
 [m3vpss ]  301780: SWMS1    : Loading Horizontal Co-effs (7/16)x ...
 [c6xdsp ] IPC_FRAMES_IN:HEAPID:0       USED:304
 [m3vpss ]  301781: SWMS    : Co-effs Loading ... DONE !!!
 [c6xdsp ]  301025: IPC_FRAMES_IN   : Create Done !!!
 [m3vpss ]
 [m3vpss ]  *** [SWMS1] Mosaic Parameters ***
 [m3vpss ]
 [m3vpss ]
 [c6xdsp ]  301026: ALG : Create in progress !!!
 [m3vpss ]    0 |   0 |    0,    0 |  1920 x   1080 |  2048 /  2048 | NON-TILED   |    0,    0 |   960 x    540 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
 [m3vpss ]    1 |   1 |    0,    0 |  1920 x   1080 |  2048 /  2048 | NON-TILED   |  960,    0 |   960 x    540 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
 [m3vpss ]    2 |   2 |    0,    0 |  1920 x   1080 |  2048 /  2048 | NON-TILED   |    0,  540 |   960 x    540 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
 [m3vpss ]    3 |   3 |    0,    0 |  1920 x   1080 |  2048 /  2048 | NON-TILED   |  960,  540 |   960 x    540 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
 [m3vpss ]
 [m3vpss ] SWMS:HEAPID:0        USED:360
 [c6xdsp ] ALGLINK:HEAPID:0     USED:2616
 [m3vpss ] SWMS:HEAPID:1        USED:17056
 [c6xdsp ] ALGLINK:HEAPID:1     USED:5912
 [c6xdsp ]  301036: ALG : Create Done !!!
 [m3vpss ]  301783: SWMS: Create Done !!!
 [c6xdsp ]  301040: IPC_FRAMES_IN   : Create in progress !!!
 [m3vpss ]  301783: IPC_FRAMES_OUT   : Create in progress !!!
 [c6xdsp ]  301040: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_20] ...
 [c6xdsp ]  301041: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_20] ...
 [m3vpss ]  301785: IPC_FRAMES_OUT   : Create Done !!!
 [m3vpss ]  301800: IPC_FRAMES_OUT   : Create in progress !!!
 [c6xdsp ]  301042: IPC_FRAMES_IN   : Create Done !!!
 [c6xdsp ]  301042: ALG : Create in progress !!!
 [m3vpss ]  301802: IPC_FRAMES_OUT   : Create Done !!!
 [m3vpss ]  301817: MERGE   : Create Done !!!
 [m3vpss ]  301817: SELECT: OUT QUE0: OUT CH0: IN CH0: 1920 x 1080, pitch = (3840, 0) [PROGRESSIVE] [NON-TILED  ]
 [c6xdsp ] ALGLINK:HEAPID:0     USED:504
 [m3vpss ]  301818: SELECT: OUT QUE1: OUT CH0: IN CH1: 1920 x 1080, pitch = (3840, 0) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  301818: SELECT   : Create Done !!!
 [c6xdsp ]  301052: ALG : Create Done !!!
 [m3video]  301830: IPC_IN_M3   : Create in progress !!!
 [m3vpss ]  301823: DUP   : Create Done !!!
 [m3video]  301830: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ...
 [m3vpss ]  301824: DISPLAY: Create in progress !!!
 [m3video]  301830: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ...
 [m3vpss ]  301825: DISPLAY: Create Done !!!
 [m3vpss ]  301825: DISPLAY: Create in progress !!!
 [m3vpss ]  301826: DISPLAY: Create Done !!!
 [m3vpss ]  301826: NSF: Create in progress !!!
 [m3video]  301832: IPC_IN_M3   : Create Done !!!
 [m3video]  301833: ENCODE: Create in progress ... !!!
 [m3vpss ] NSF::HEAPID:0        USED:128
 [m3vpss ] NSF::HEAPID:1        USED:4928
 [m3vpss ]  301828: NSF: Create Done !!!
 [m3vpss ]  301828: IPC_OUT_M3   : Create in progress !!!
 [m3vpss ]  301829: IPC_OUT_M3   : Create Done !!!
 [m3video]  301856: ENCODE: Creating CH0 of 1920 x 1080, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 8000 Kbps ...
 [host] IpcBitsInLink_tskMain:Entered
 [host]  2079: IPC_BITS_IN   : Create in progress !!!
 [host]  2079: IPC_BITS_IN   : ListMPOpen start !!!
 [host]  2079: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_24] ...
 2081: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_24] ...
 [host]  2083: IPC_BITS_IN   : ListMPOpen done !!!
 [host]  2084: IPC_BITS_IN   : System_linkGetInfo done !!!
 [host]  2084: IPC_BITS_IN   : Create Done !!!
[src/codecs_links.c 1242 @ Jul 09, 12:55:55] __codecs_decoder_links_create: Leave.
[src/codecs_decoder.c 2155 @ Jul 09, 12:55:55] __codecs_decode_task_external_main: Leave(status=0)
[src/codecs_decoder.c 3815 @ Jul 09, 12:55:55] __codecs_encoder_task_external_main: Enter
[src/codecs_decoder.c 3546 @ Jul 09, 12:55:55] __codecs_encoder_init: Enter (pencode=0x13f158, orig=0x13f158)
[src/codecs_decoder.c 2971 @ Jul 09, 12:55:55] __codecs_encode_chn_init: Enter
[src/codecs_capability.c 520 @ Jul 09, 12:55:55] __codecs_capability_allocate: Prev cap:48, Curr cap:32.
[src/codecs_transport.c 897 @ Jul 09, 12:55:55] __transport_rtsp_init: Enter
 [m3video] ENCLINK_H264:HEAPID:0        USED:13808
 [m3video] ENCLINK_H264:HEAPID:3        USED:98304
 [m3video]  301860: ENCODE: All CH Create ... DONE !!!
[src/codecs_transport.c 971 @ Jul 09, 12:55:55] __transport_rtsp_init: Leave
[src/codecs_decoder.c 3017 @ Jul 09, 12:55:55] __codecs_encode_chn_init: Leave (status=0)
[src/codecs_decoder.c 3576 @ Jul 09, 12:55:55] __codecs_encoder_init: Leave (pencode=0x13f158)
[src/codecs_decoder.c 3854 @ Jul 09, 12:55:55] __codecs_encoder_task_external_main: Leave (status=0)
 [m3video] ENCLINK:HEAPID:0     USED:13928
 [m3video] ENCLINK:HEAPID:2     USED:4147200
 [m3video] ENCLINK:HEAPID:3     USED:98304
 [m3video]  301862: ENCODE: Create ... DONE !!!
 [m3video]  301862: IPC_BITS_OUT   : Create in progress !!!
[src/codecs_main.c 347 @ Jul 09, 12:55:55] task_daemon_start: Enter
[src/codecs_decoder.c 1434 @ Jul 09, 12:55:55] __codecs_decode_start: Enter
 [m3video]  301864: IPC_BITS_OUT   : Create Done !!!
 [m3video]  301871: DECODE: CH1:
 [m3video] Queueing last frame in prev IVA[1]
 [m3video] Iva Map Change Serialization: Last Frame of Prev IVA [1] received
 [m3video]  301871: DECODE: CH2:
 [m3video] Queueing last frame in prev IVA[2]
 [m3video]  301872: DECODE: CH2:
 [m3video] Iva Map Change Serialization: Last Frame of Prev IVA [2] received
 [m3video]  301872: DECODE: CH4:
 [m3video]  301872: DECODE: CH5:
 [m3video]  301872: DECODE: CH7:
 [m3video]  301873: DECODE: CH8:
 [m3video]  301873: DECODE: CH10:
 [m3video]  301873: DECODE: CH11:
 [m3video]  301873: DECODE: CH13:
 [m3video]  301874: DECODE: CH14:
 [m3video]  301874: DECODE: CH16:
 [m3video]  301874: DECODE: CH1:
 [m3video] Queueing first frame in next IVA[0]
 [m3video] Iva Map Change Serialization: First Frame of Next IVA [0] received
 [m3video] Iva Map Change Serialization: First Frame of Next IVA [0] received. Serialization complete!!
 [m3video]  301875: DECODE: CH2:
 [m3video]  301875: DECODE: CH4:
 [m3video]  301875: DECODE: CH5:
 [m3video]  301876: DECODE: CH5:
 [m3video]  301876: DECODE: CH7:
 [m3video]  301876: DECODE: CH8:
 [m3video]  301877: DECODE: CH8:
 [m3video]  301877: DECODE: CH10:
 [m3video]  301877: DECODE: CH11:
 [m3video]  301878: DECODE: CH13:
 [m3video]  301878: DECODE: CH14:
 [m3video]  301878: DECODE: CH16:
 [m3video]  301879: DECODE: CH16:
 [m3vpss ]  301973: CAPTURE: Start in progress !!!
 [m3vpss ]  302073: CAPTURE: Enabled Time Stamping !!!
 [m3vpss ]  302082: CAPTURE: Start Done !!!
 [m3vpss ]  302105: DISPLAY: Start in progress !!!
"testStream" stream, from the file "/tmp/encChannel0.264"
Play this stream using the URL "rtsp://192.168.1.180:8554/testStream"
(We use port 80 for optional RTSP-over-HTTP tunneling.)
 [m3vpss ]  302144: DISPLAY: Start Done !!!
 [m3vpss ]  302144: DISPLAY: HDDAC(BP0) : 51 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) DropCount:0 DispLatency (Min / Max) = ( 8259 / 0 ) !!!
 [m3vpss ]  302144: DISPLAY DRV: HDDAC(BP0) : Q:[2] Display:[2], Repeat:[1], DQ:[0]
 [m3vpss ]  302144: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 3, HDDAC(BP0) 4, DVO2(BP1) 4, SDDAC(SEC1) 4
 [m3vpss ]  302144: SYSTEM  : FREE SPACE : System Heap      = 66672 B, Mbx = 10238 msgs)
 [m3vpss ]  302144: SYSTEM  : FREE SPACE : SR0 Heap         = 15529472 B (14 MB)
 [m3vpss ]  302145: SYSTEM  : FREE SPACE : Frame Buffer     = 587422592 B (560 MB)
 [m3vpss ]  302145: SYSTEM  : FREE SPACE : Bitstream Buffer = 111100800 B (105 MB)
 [m3vpss ]  302145: DISPLAY: Start in progress !!!
 [m3vpss ] TILER_STATS: CNT :8BIT
 [m3vpss ] TILER_STATS: CNT RESOLUTION:    16384 x 8192
 [m3vpss ] TILER_STATS: BUCKET RESOLUTION: 16384 x 8188
 [m3vpss ] TILER_STATS: NUM FREE BUCKETS:  0
 [m3vpss ] TILER_STATS: NUM USED BUCKETS:  1
 [m3vpss ] TILER_STATS: TOTAL FREE AREA:   100357120 (74 %)
 [m3vpss ] TILER_STATS: TOTAL USED AREA:   33795072 (25 %)
 [m3vpss ] TILER_STATS: TOTAL WASTE AREA:  0 (0 %)
[src/codecs_decoder.c 1446 @ Jul 09, 12:55:56] __codecs_decode_start: Leave
[src/codecs_decoder.c 2155 @ Jul 09, 12:55:56] __codecs_decode_task_external_main: Leave(status=0)
[src/codecs_decoder.c 3815 @ Jul 09, 12:55:56] __codecs_encoder_task_external_main: Enter
[src/codecs_main.c 351 @ Jul 09, 12:55:56] task_daemon_start: Leave
Choice | Description
   1     Print Task Manamger TASK instruments.
   2     Print Task Manamger THDPOOL instruments.
   3     Print codecs system detailed statistics.
   4     Print codecs system buffer statistics.
   5     Print codecs system ivahd statistics.
   a     Switch Swms display layout
   b     Switch Swms display windows
   c     Disable Swms window
   d     Enable Swms window
   e     Disable decode channel
   f     Enable decode channel
   g     Create decode channel
   h     Change decode channel transport dynamically
   i     Delete decode channel
   j     Disable encode channel
   k     Enable  encode channel
   l     Disable splicing encode channel
   m     Enable  splicing encode channel
   n     Set encode channel bitrate
   o     Select encode channel
   x     Modify codecs system configure file.
   q     Quit from this codecs system daemon.
Please enter the choice:  [m3vpss ] TILER_STATS: MAX WIDTH RECT:    16384 x 3788
 [m3vpss ] TILER_STATS: MAX HEIGHT RECT:    16384 x 3788
 [m3vpss ] TILER_STATS: RES ALLOC COUNT [720P] :  16
 [m3vpss ] TILER_STATS: CNT :16BIT
 [m3vpss ] TILER_STATS: CNT RESOLUTION:    32768 x 8192
 [m3vpss ] TILER_STATS: BUCKET RESOLUTION: 32768 x 8192
 [m3vpss ] TILER_STATS: TOTAL FREE AREA:   251537920 (93 %)
 [m3vpss ] TILER_STATS: TOTAL USED AREA:   16897536 (6 %)
 [m3vpss ] TILER_STATS: MAX WIDTH RECT:    32768 x 6532
 [m3vpss ] TILER_STATS: MAX HEIGHT RECT:    32768 x 6532
 [m3vpss ]  302148: SYSTEM  : FREE SPACE : Tiler 8-bit      = 100357120 B (95 MB)  - TILER ON
 [m3vpss ]  302148: SYSTEM  : FREE SPACE : Tiler 16-bit     = 251537920 B (239 MB)  - TILER ON
 [m3vpss ]  302211: DISPLAY: Start Done !!!
 [m3vpss ]  302211: DISPLAY: DVO2(BP1)  : 30 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) DropCount:0 DispLatency (Min / Max) = ( 8259 / 0 ) !!!
 [m3vpss ]  302211: SWMS: Start in Progress !!!
 [m3vpss ]  302211: SWMS: Start Done !!!
 [m3vpss ]  302212: SWMS: Start in Progress !!!
 [m3vpss ]  302212: SWMS: Start Done !!!
 [m3vpss ]  302212: DISPLAY DRV: DVO2(BP1)  : Q:[2] Display:[2], Repeat:[1], DQ:[0]
 [m3vpss ] AVSYNC:Media Time Base:2261,FirstVidPTS:2262,FirstAudPTS:-1
Please enter the choice: q
[src/codecs_main.c 641 @ Jul 09, 12:56:06] task_daemon_run: Quit from this task daemon.
[src/codecs_main.c 701 @ Jul 09, 12:56:06] task_daemon_stop: Enter
[src/codecs_main.c 705 @ Jul 09, 12:56:06] task_daemon_stop: Leave
[src/codecs_manager.c 281 @ Jul 09, 12:56:06] codecs_manager_deinit: Enter
[src/codecs_manager.c 325 @ Jul 09, 12:56:06] __codecs_mgr_deinit: Enter
[src/codecs_manager.c 445 @ Jul 09, 12:56:06] __codecs_mgr_synchronize: do synchronized.
[src/threadpool.c 685 @ Jul 09, 12:56:06] __threadpool_task_dispatch: thread[0x35f878] wait for task.
[src/codecs_manager.c 332 @ Jul 09, 12:56:06] __codecs_mgr_deinit: Leave
[src/codecs_manager.c 291 @ Jul 09, 12:56:06] codecs_manager_deinit: Leave
[src/codecs_decoder.c 1482 @ Jul 09, 12:56:06] __codecs_decode_stop: Enter
[src/codecs_links.c 1287 @ Jul 09, 12:56:06] __codecs_decoder_links_stop: Enter
 [m3video]  312931: DECODE: Stop in progress !!!
 [m3vpss ]  312937: SWMS: Stop in Progress !!!
 [m3video]  312931: DECODE: Stop Done !!!
 [m3vpss ]  312937: SWMS: Stop Done !!!
 [m3vpss ]  312937: DISPLAY: Stop in progress !!!
 [m3vpss ]  312977: DISPLAY: Stop Done !!!
 [m3vpss ]  312978: DISPLAY: Stop in progress !!!
 [m3vpss ]  313044: DISPLAY: Stop Done !!!
 [m3vpss ]  313846: CAPTURE: Stop in progress !!!
 [host]  14105: IPC_BITS_IN   : Stop Done !!!
[src/codecs_links.c 1306 @ Jul 09, 12:56:07] __codecs_decoder_links_stop: Leave
[src/codecs_decoder.c 1494 @ Jul 09, 12:56:07] __codecs_decode_stop: Leave
[src/codecs_links.c 1358 @ Jul 09, 12:56:07] __codecs_decoder_links_delete: Enter
 [m3vpss ]  313889: CAPTURE: Stop Done !!!
 [m3video]  313890: ENCODE: CH-1:
 [m3video] Stop in progress !!!
 [m3vpss ]  313891: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 704, HDDAC(BP0) 709, DVO2(BP1) 709, SDDAC(SEC1) 1381
 [m3video] Stop done !!!
 [m3vpss ]
 [host] 14115: IPCBITSIN:Link[3000001a]:
 [host] RECV:646        FREE:646,DROPPED:0,AVGLATENCY:7,AVG_APP_CB_TIME:7
 [host]  14115: IPC_BITS_IN   : Delete in progress !!!
 [host]  14116: IPC_BITS_IN   : Delete Done !!!
 [host]  14119: IPC_BITS_OUT   : Delete in progress !!!
 [host]
14122: IPCBITSOUT:Link[30000018]:
 [host] RECV:0  FREE:0,DROPPED:0,AVGLATENCY:0
 [host] IPC_BITSOUT:BitBuffer Free.chID:0,Size:0x9E3400
 [host] ******* RingBuf 0 deleted ********
 [host] IPC_BITSOUT:BitBuffer Free.chID:1,Size:0x9E3400
 [host] ******* RingBuf 1 deleted ********
 [host] IPC_BITSOUT:BitBuffer Free.chID:2,Size:0x9E3400
 [host] ******* RingBuf 2 deleted ********
 [host] IPC_BITSOUT:BitBuffer Free.chID:3,Size:0x9E3400
 [host] ******* RingBuf 3 deleted ********
 [host] IPC_BITSOUT:BitBuffer Free.chID:4,Size:0x9E3400
 [host] ******* RingBuf 4 deleted ********
 [host] IPC_BITSOUT:BitBuffer Free.chID:5,Size:0x9E3400
 [host] ******* RingBuf 5 deleted ********
 [host] IPC_BITSOUT:BitBuffer Free.chID:6,Size:0x9E3400
 [host] ******* RingBuf 6 deleted ********
 [host] IPC_BITSOUT:BitBuffer Free.chID:7,Size:0x9E3400
 [host] ******* RingBuf 7 deleted ********
 [host] IPC_BITSOUT:BitBuffer Free.chID:8,Size:0x9E3400
 [host] ******* RingBuf 8 deleted ********
 [host] IPC_BITSOUT:BitBuffer Free.chID:9,Size:0x9E3400
 [host] ******* RingBuf 9 deleted ********
 [host] IPC_BITSOUT:BitBuffer Free.chID:10,Size:0x9E3400
 [host] ******* RingBuf 10 deleted ********
 [host] IPC_BITSOUT:BitBuffer Free.chID:11,Size:0x9E3400
 [host] ******* RingBuf 11 deleted ********
 [host] IPC_BITSOUT:BitBuffer Free.chID:12,Size:0x9E3400
 [host] ******* RingBuf 12 deleted ********
 [host] IPC_BITSOUT:BitBuffer Free.chID:13,Size:0x9E3400
 [host] ******* RingBuf 13 deleted ********
 [host] IPC_BITSOUT:BitBuffer Free.chID:14,Size:0x9E3400
 [host] ******* RingBuf 14 deleted ********
 [host] IPC_BITSOUT:BitBuffer Free.chID:15,Size:0x9E3400
 [host] ******* RingBuf 15 deleted ********
 [host] IPC_BITSOUT:BitBuffer Free.chID:16,Size:0x9E3400
 [host] ******* RingBuf 16 deleted ********
 [host]  14295: IPC_BITS_OUT   : Delete Done !!!
 [m3video]  313897: IPC_IN_M3   : Delete in progress !!!
 [m3vpss ]  *** Capture Driver Advanced Statistics ***
 [m3video]  313897: IPC_IN_M3   : Delete Done !!!
 [m3vpss ]
 [m3video]  313897: ENCODE: CH-1:
 [m3vpss ]  VIP Parser Reset Count : 0
 [m3vpss ]
 [m3video]  ENC    : Delete in progress !!!
 [m3video] MemoryLeak:STAGE:0   HEAPNUM:0       ALLOC=13808     FREED=11912
 [m3vpss ]      |   Total    Even     Odd  Total  Even   Odd  Min /  Max  Min /  Max Dropped Fid Repeat Frame Error Y/C
 [m3video]  313900: ENCODE: CH-1:
 [m3video]  ENC    : Delete done !!!
 [m3vpss ]  CH  |  Fields  Fields  Fields    FPS   FPS   FPS       Width      Height  Fields      Count (Desc Error Y/C)
 [c6xdsp ] 313328: IPCFRAMESIN:Link[16]:
 [c6xdsp ] RECV:646     FREE:646,DROPPED:0,AVGLATENCY:0
 [c6xdsp ]  313328: IPC_FRAMES_IN   : Delete in progress !!!
 [m3video]  313900: IPC_BITS_OUT   : Delete in progress !!!
 [c6xdsp ]  313328: IPC_FRAMES_IN   : Delete Done !!!
 [c6xdsp ]  313329: ALG : Delete in progress !!!
 [m3video] 313900: IPCBITSOUT:Link[10000018]:
 [m3video] RECV:646     FREE:646,DROPPED:0,AVGLATENCY:7
 [m3video]  313900: PRF : IPC_BITS_OUT0 : t: 13 ms, c: 646, f: 646, fps: 49692, fpc: 1
 [c6xdsp ]  313329: ALG : Delete Done !!!
 [m3vpss ]  000 |     704     704       0     64    64     0 65535 /    0 65535 /    0      49          0 0/0 (703/0)
 [m3video]  313900: IPC_BITS_OUT   : Delete Done !!!
 [m3video]  313901: DECODE: Stop in progress !!!
 [m3vpss ]
 [m3video]  313901: DECODE: Stop Done !!!
 [m3video]  313901: DECODE: Delete in progress !!!
 [m3vpss ]  VIP Capture Port 0 | DescMissMatch1 = 0, DescMissMatch2 = 0 , DescMissMatch3 = 0
 [m3video] 313902: DECODE: CodecInst and OutFrm bufs were NOT created for CH0
 [m3vpss ]
 [m3video] 313902: DECODE: CodecInst and OutFrm bufs were NOT created for CH1
 [m3video] 313902: DECODE: CodecInst and OutFrm bufs were NOT created for CH2
 [m3vpss ]  *** Capture List Manager Advanced Statistics ***
 [m3video] 313902: DECODE: CodecInst and OutFrm bufs were NOT created for CH3
 [m3video] 313902: DECODE: CodecInst and OutFrm bufs were NOT created for CH4
 [m3vpss ]
 [m3video] 313902: DECODE: CodecInst and OutFrm bufs were NOT created for CH5
 [m3video] 313902: DECODE: CodecInst and OutFrm bufs were NOT created for CH6
 [m3vpss ]  List Post Count        : 1471
 [m3video] 313902: DECODE: CodecInst and OutFrm bufs were NOT created for CH7
 [m3video] 313903: DECODE: CodecInst and OutFrm bufs were NOT created for CH8
 [m3vpss ]  List Stall Count       : 0
 [m3video] 313903: DECODE: CodecInst and OutFrm bufs were NOT created for CH9
 [m3video] 313903: DECODE: CodecInst and OutFrm bufs were NOT created for CH10
 [m3vpss ]  List Post Time (ms)    : Max = 0, Min = 0, Avg = 0, Total = 0
 [m3video] 313903: DECODE: CodecInst and OutFrm bufs were NOT created for CH11
 [m3video] 313903: DECODE: CodecInst and OutFrm bufs were NOT created for CH12
 [m3vpss ]  INTC Timeout Count     : (0, 0) (Min timeout value = 990, 1000)
 [m3video] 313903: DECODE: CodecInst and OutFrm bufs were NOT created for CH13
 [m3video] 313903: DECODE: CodecInst and OutFrm bufs were NOT created for CH14
 [m3vpss ]  Descriptor miss found count : 0
 [m3video] 313903: DECODE: CodecInst and OutFrm bufs were NOT created for CH15
 [m3video] 313903: DECODE: CodecInst and OutFrm bufs were NOT created for CH16
 [m3vpss ]
 [m3video]  313904: DECODE: Delete Done !!!
 [m3vpss ]
 [m3video] 313904: IPCBITSIN:Link[1000001a]:
 [m3video] RECV:0       FREE:0,DROPPED:0,AVGLATENCY:0
 [m3video]  313904: IPC_BITS_IN   : Delete in progress !!!
 [m3video]  313904: IPC_BITS_IN   : Delete Done !!!
 [m3vpss ]  VIP and VPDMA registers,
 14308: SYSTEM: System Common De-Init in progress !!!
 [host] OSA_tskDelete:In progress...
 [host] OSA_tskDelete:In progress... 14314: SYSTEM: IPC de-init in progress !!!
 [m3video]  314093: IPC_OUT_M3   : Delete in progress !!!
 [c6xdsp ] 313330: IPCFRAMESIN:Link[17]:
 [c6xdsp ]  313330: IPC_FRAMES_IN   : Delete in progress !!!
 [m3video]  314093: IPC_OUT_M3   : Delete Done !!!
 [c6xdsp ]  313330: IPC_FRAMES_IN   : Delete Done !!!
 [c6xdsp ]  313331: ALG : Delete in progress !!!
 [c6xdsp ]  313331: ALG : Delete Done !!!
 [m3vpss ]
 14334: SYSTEM: IPC de-init DONE !!!
 14334: SYSTEM: System Common De-Init Done !!!
[src/codecs_links.c 1398 @ Jul 09, 12:56:08] __codecs_decoder_links_delete: Leave
[src/codecs_decoder.c 2155 @ Jul 09, 12:56:08] __codecs_decode_task_external_main: Leave(status=0)
[src/codecs_decoder.c 3646 @ Jul 09, 12:56:08] __codecs_encoder_synchronize: do synchronized.
[src/codecs_decoder.c 3611 @ Jul 09, 12:56:08] __codecs_encoder_deinit :Enter
[src/codecs_decoder.c 3039 @ Jul 09, 12:56:08] __codecs_encode_chn_deinit :Enter
[src/codecs_transport.c 1049 @ Jul 09, 12:56:08] __transport_rtsp_deinit: Enter
 [m3vpss ]
 [m3vpss ]  313893: CAPTURE: Fields = 655 (fps = 55, CPU Load = 0)
[src/threadpool.c 685 @ Jul 09, 12:56:08] __threadpool_task_dispatch: thread[0x33dff0] wait for task.
 [m3vpss ]  313893: CAPTURE: Num Resets = 0 (Avg 0 ms per reset)
 [m3vpss ]  313893: SYSTEM  : FREE SPACE : System Heap      = 66672 B, Mbx = 10238 msgs)
[src/codecs_transport.c 1083 @ Jul 09, 12:56:08] __transport_rtsp_deinit: Leave
[src/codecs_capability.c 533 @ Jul 09, 12:56:08] __codecs_capability_release: Prev cap:32, Curr cap:48.
[src/codecs_decoder.c 3058 @ Jul 09, 12:56:08] __codecs_encode_chn_deinit :Leave(status = 0)
[src/codecs_decoder.c 3627 @ Jul 09, 12:56:08] __codecs_encoder_deinit :Leave(status = 0)
[src/codecs_decoder.c 3854 @ Jul 09, 12:56:08] __codecs_encoder_task_external_main: Leave (status=0)
[src/threadpool.c 685 @ Jul 09, 12:56:08] __threadpool_task_dispatch: thread[0x33def0] wait for task.
[src/threadpool.c 685 @ Jul 09, 12:56:08] __threadpool_task_dispatch: thread[0x33cfe0] wait for task.
 [m3vpss ]  313893: SYSTEM  : FREE SPACE : SR0 Heap         = 16840192 B (16 MB)
[src/threadpool.c 536 @ Jul 09, 12:56:08] __threadpool_exit: Cancel all working thread.
[src/threadpool.c 562 @ Jul 09, 12:56:08] __threadpool_exit: Wait for all thread to terminate.
[src/threadpool.c 570 @ Jul 09, 12:56:08] __threadpool_exit: Delete all thread.
codecs_system_env_deinit: De-initialize task manager.
codecs_system_env_deinit: De-initialize debug module.
root@ti81xx:~#  [m3vpss ]  313893: SYSTEM  : FREE SPACE : Frame Buffer     = 587422592 B (560 MB)
 [m3vpss ]  313894: SYSTEM  : FREE SPACE : Bitstream Buffer = 111100800 B (105 MB)
 [m3vpss ]  313895: SYSTEM  : FREE SPACE : Tiler 8-bit      = 100357120 B (95 MB)  - TILER ON
 [m3vpss ]  313896: SYSTEM  : FREE SPACE : Tiler 16-bit     = 251537920 B (239 MB)  - TILER ON
 [m3vpss ]  313896: CAPTURE: Delete in progress !!!
 [m3vpss ]  UTILS: DMA: Free'ed CH (TCC) = 58 (58)
 [m3vpss ]  313896: CAPTURE: Delete Done !!!
 [m3vpss ]  313897: IPC_OUT_M3   : Delete in progress !!!
 [m3vpss ]  313897: IPC_OUT_M3   : Delete Done !!!
 [m3vpss ]  314081: SWMS: Frames = 652 (fps = 202) !!!
 [m3vpss ]  314081: SWMS: Delete in progress !!!
 [m3vpss ]  UTILS: DMA: Free'ed CH (TCC) = 59 (59)
 [m3vpss ]  UTILS: DMA: Free'ed CH (TCC) = 60 (60)
 [m3vpss ]  314083: SWMS: Delete Done !!!
 [m3vpss ]  314084: DISPLAY: Frames = 639 (fps = 59) !!!
 [m3vpss ]  314084: DISPLAY: Delete in progress !!!
 [m3vpss ]  314084: DISPLAY: Delete Done !!!
 [m3vpss ]  314084: SWMS: Frames = 4 (fps = 0) !!!
 [m3vpss ]  314084: SWMS: Delete in progress !!!
 [m3vpss ]  UTILS: DMA: Free'ed CH (TCC) = 61 (61)
 [m3vpss ]  UTILS: DMA: Free'ed CH (TCC) = 62 (62)
 [m3vpss ]  314086: SWMS: Delete Done !!!
 [m3vpss ]  314087: DISPLAY: Frames = 642 (fps = 59) !!!
 [m3vpss ]  314087: DISPLAY: Delete in progress !!!
 [m3vpss ]  314087: DISPLAY: Delete Done !!!
 [m3vpss ]  314087: DUP   : Delete Done !!!
 [m3vpss ]  314088: MERGE   : Delete Done !!!
 [m3vpss ]  314088: SELECT   : Delete Done !!!
 [m3vpss ]  314089: NSF    : Fields = 646 (fps = 105) !!!
 [m3vpss ]  314089: NSF: Delete in progress !!!
 [m3vpss ]  314089: NSF: Delete Done !!!
 [m3vpss ]  314089: IPC_FRAMES_OUT   : Delete in progress !!!
 [m3vpss ] 314089: IPCFRAMESOUT:Link[20000013]:
 [m3vpss ] RECV:646     FORWARD:646,DROPPED:0,AVGLATENCY:0
 [m3vpss ]  314090: PRF : IPC_FRAMES_OUT0 : t: 20 ms, c: 646, f: 646, fps: 32300, fpc: 1
 [m3vpss ]  314090: IPC_FRAMES_OUT   : Delete Done !!!
 [m3vpss ]  314090: IPC_FRAMES_OUT   : Delete in progress !!!
 [m3vpss ] 314091: IPCFRAMESOUT:Link[20000014]:
 [m3vpss ]  314091: PRF : IPC_FRAMES_OUT1 : t: 23 ms, c: 646, f: 646, fps: 28086, fpc: 1
 [m3vpss ]  314091: IPC_FRAMES_OUT   : Delete Done !!!
 [m3vpss ]  314092: IPC_IN_M3   : Delete in progress !!!
 [m3vpss ]  314093: IPC_IN_M3   : Delete Done !!!
vcap_chn_num = 1
vcap_vid0_std = 18
venc_chn_num = 1
vdec_chn_num = 0
vdis_dev_num = 2
vdis_dev0_std = 18
vdis_dev0_mode = 7
vdis_dev1_std = 18
vdis_dev1_mode = 3
img size = 14784.
Dec Channels => 0
Disp Channels => 0
 23: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
 25: SYSTEM: Opening MsgQ [DSP_MSGQ] ...
 26: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
 26: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
 27: SYSTEM: Notify register to [DSP] line 0, event 15 ...
 28: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
 29: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
 30: SYSTEM: IPC init DONE !!!
 31: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
 34: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
 36: SYSTEM: ListElem Shared Addr = 0x40e93b00
 37: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
 40: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
 42: SYSTEM: ListElem Shared Addr = 0x40ec8d00
 44: SYSTEM: Creating ListMP [HOST_IPC_OUT_19] in region 0 ...
 47: SYSTEM: Creating ListMP [HOST_IPC_IN_19] in region 0 ...
 49: SYSTEM: ListElem Shared Addr = 0x40f40f80
 50: SYSTEM: Creating ListMP [HOST_IPC_OUT_20] in region 0 ...
 53: SYSTEM: Creating ListMP [HOST_IPC_IN_20] in region 0 ...
 55: SYSTEM: ListElem Shared Addr = 0x40f84280
 57: SYSTEM: Creating ListMP [HOST_IPC_OUT_21] in region 0 ...
 59: SYSTEM: Creating ListMP [HOST_IPC_IN_21] in region 0 ...
 62: SYSTEM: ListElem Shared Addr = 0x40fc7000
 79: SYSTEM: System Common Init Done !!!
[src/codecs_links.c 372 @ Jul 09, 12:57:17] __codecs_decoder_links_create: Enter.
 [m3vpss ]  383975: CAPTURE: Create in progress !!!
 [host]  1572: IPC_BITS_OUT   : Create in progress !!!
 [host]
 [host] IPCBITSOUTLINK:Translated Addr Virt:0x42211080 To Phy:0x80000080
 [host]
 [host] ###Bit buff BasePtr: 42211080 / PhyAddr 80000080
 [host]
 [host] IPCBITSOUTLINK:Translated Addr Virt:0x42bf4480 To Phy:0x809e3480
 [host]
 [host] ###Bit buff BasePtr: 42BF4480 / PhyAddr 809E3480
 [host]
 [host] IPCBITSOUTLINK:Translated Addr Virt:0x435d7880 To Phy:0x813c6880
 [host]
 [host] ###Bit buff BasePtr: 435D7880 / PhyAddr 813C6880
 [host]
 [host] IPCBITSOUTLINK:Translated Addr Virt:0x43fbac80 To Phy:0x81da9c80
 [host]
 [host] ###Bit buff BasePtr: 43FBAC80 / PhyAddr 81DA9C80
 [host]
 [host] IPCBITSOUTLINK:Translated Addr Virt:0x4499e080 To Phy:0x8278d080
 [host]
 [host] ###Bit buff BasePtr: 4499E080 / PhyAddr 8278D080
 [host]
 [host] IPCBITSOUTLINK:Translated Addr Virt:0x45381480 To Phy:0x83170480
 [host]
 [host] ###Bit buff BasePtr: 45381480 / PhyAddr 83170480
 [host]
 [host] IPCBITSOUTLINK:Translated Addr Virt:0x45d64880 To Phy:0x83b53880
 [host]
 [host] ###Bit buff BasePtr: 45D64880 / PhyAddr 83B53880
 [host]
 [host] IPCBITSOUTLINK:Translated Addr Virt:0x46747c80 To Phy:0x84536c80
 [host]
 [host] ###Bit buff BasePtr: 46747C80 / PhyAddr 84536C80
 [host]
 [host] IPCBITSOUTLINK:Translated Addr Virt:0x4712b080 To Phy:0x84f1a080
 [host]
 [host] ###Bit buff BasePtr: 4712B080 / PhyAddr 84F1A080
 [host]
 [host] IPCBITSOUTLINK:Translated Addr Virt:0x47b0e480 To Phy:0x858fd480
 [host]
 [host] ###Bit buff BasePtr: 47B0E480 / PhyAddr 858FD480
 [host]
 [host] IPCBITSOUTLINK:Translated Addr Virt:0x484f1880 To Phy:0x862e0880
 [host]
 [host] ###Bit buff BasePtr: 484F1880 / PhyAddr 862E0880
 [host]
 [host] IPCBITSOUTLINK:Translated Addr Virt:0x48ed4c80 To Phy:0x86cc3c80
 [host]
 [host] ###Bit buff BasePtr: 48ED4C80 / PhyAddr 86CC3C80
 [host]
 [host] IPCBITSOUTLINK:Translated Addr Virt:0x498b8080 To Phy:0x876a7080
 [host]
 [host] ###Bit buff BasePtr: 498B8080 / PhyAddr 876A7080
 [host]
 [host] IPCBITSOUTLINK:Translated Addr Virt:0x4a29b480 To Phy:0x8808a480
 [host]
 [host] ###Bit buff BasePtr: 4A29B480 / PhyAddr 8808A480
 [host]
 [host] IPCBITSOUTLINK:Translated Addr Virt:0x4ac7e880 To Phy:0x88a6d880
 [host]
 [host] ###Bit buff BasePtr: 4AC7E880 / PhyAddr 88A6D880
 [host]
 [host] IPCBITSOUTLINK:Translated Addr Virt:0x4b661c80 To Phy:0x89450c80
 [host]
 [host] ###Bit buff BasePtr: 4B661C80 / PhyAddr 89450C80
 [host]
 [host] IPCBITSOUTLINK:Translated Addr Virt:0x4c045080 To Phy:0x89e34080
 [host]
 [host] ###Bit buff BasePtr: 4C045080 / PhyAddr 89E34080
 [host]  1575: IPC_BITS_OUT   : Create Done !!!
 [m3video]  384014: IPC_BITS_IN   : Create in progress !!!
 [m3vpss ]  384008: CAPTURE: VIP0 PortA capture mode is [16-bit, Non-mux Embedded Sync] !!!
 [m3video]  384015: SYSTEM: Opening ListMP [HOST_IPC_OUT_24] ...
 [m3video]  384015: SYSTEM: Opening ListMP [HOST_IPC_IN_24] ...
 [m3video]  384017: IPC_BITS_IN   : Create Done !!!
 [m3video]  384017: DECODE: Create in progress ... !!!
 [m3video] 384019: DECODE: CodecInst and OutFrm bufs are NOT created for CH0
 [m3vpss ]  384011: CAPTURE: Create Done !!!
 [m3video]  384019: DECODE: Creating CH0 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 8000 Kbps ...
 [m3video] 384019: DECODE: CodecInst and OutFrm bufs are NOT created for CH1
 [m3video]  384019: DECODE: Creating CH1 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 8000 Kbps ...
 [m3video] 384019: DECODE: CodecInst and OutFrm bufs are NOT created for CH2
 [m3video]  384019: DECODE: Creating CH2 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 8000 Kbps ...
 [m3video] 384020: DECODE: CodecInst and OutFrm bufs are NOT created for CH3
 [m3video]  384020: DECODE: Creating CH3 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 8000 Kbps ...
 [m3video] 384020: DECODE: CodecInst and OutFrm bufs are NOT created for CH4
 [m3video]  384020: DECODE: Creating CH4 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 8000 Kbps ...
 [m3video] 384020: DECODE: CodecInst and OutFrm bufs are NOT created for CH5
 [m3video]  384020: DECODE: Creating CH5 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 8000 Kbps ...
 [m3video] 384020: DECODE: CodecInst and OutFrm bufs are NOT created for CH6
 [m3video]  384021: DECODE: Creating CH6 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 8000 Kbps ...
 [m3video] 384021: DECODE: CodecInst and OutFrm bufs are NOT created for CH7
 [m3video]  384021: DECODE: Creating CH7 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 8000 Kbps ...
 [m3video] 384021: DECODE: CodecInst and OutFrm bufs are NOT created for CH8
 [m3video]  384021: DECODE: Creating CH8 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 8000 Kbps ...
 [m3video] 384021: DECODE: CodecInst and OutFrm bufs are NOT created for CH9
 [m3video]  384021: DECODE: Creating CH9 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 8000 Kbps ...
 [m3video] 384022: DECODE: CodecInst and OutFrm bufs are NOT created for CH10
 [m3video]  384022: DECODE: Creating CH10 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 8000 Kbps ...
 [m3video] 384022: DECODE: CodecInst and OutFrm bufs are NOT created for CH11
 [m3video]  384022: DECODE: Creating CH11 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 8000 Kbps ...
 [m3video] 384022: DECODE: CodecInst and OutFrm bufs are NOT created for CH12
 [m3video]  384022: DECODE: Creating CH12 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 8000 Kbps ...
 [m3video] 384023: DECODE: CodecInst and OutFrm bufs are NOT created for CH13
 [m3video]  384023: DECODE: Creating CH13 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 8000 Kbps ...
 [m3video] 384023: DECODE: CodecInst and OutFrm bufs are NOT created for CH14
 [m3video]  384023: DECODE: Creating CH14 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 8000 Kbps ...
 [m3video] 384023: DECODE: CodecInst and OutFrm bufs are NOT created for CH15
 [m3video]  384023: DECODE: Creating CH15 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 8000 Kbps ...
 [m3video] 384023: DECODE: CodecInst and OutFrm bufs are NOT created for CH16
 [m3video]  384024: DECODE: Creating CH16 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 8000 Kbps ...
 [m3video]  384025: DECODE: All CH Create ... DONE !!!
 [m3vpss ]  384030: IPC_IN_M3   : Create in progress !!!
 [m3vpss ]  384030: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_0] ...
 [m3vpss ]  384030: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_0] ...
 [m3video]  384028: DECODE: Create ... DONE !!!
 [m3vpss ]  384032: IPC_IN_M3   : Create Done !!!
 [m3video]  384029: IPC_OUT_M3   : Create in progress !!!
 [m3vpss ]  384033: MERGE   : Create Done !!!
 [m3video]  384029: IPC_OUT_M3   : Create Done !!!
 [m3vpss ]  384034: SELECT: OUT QUE0: OUT CH0: IN CH17: 1440 x 810, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ]
 [m3vpss ]  384034: SELECT: OUT QUE0: OUT CH1: IN CH18: 0 x 0, pitch = (0, 0) [INTERLACED ] [NON-TILED  ]
 [m3vpss ]  384035: SELECT: OUT QUE0: OUT CH2: IN CH0: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  384035: SELECT: OUT QUE0: OUT CH3: IN CH1: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  384035: SELECT: OUT QUE0: OUT CH4: IN CH2: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  384035: SELECT: OUT QUE0: OUT CH5: IN CH3: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  384035: SELECT: OUT QUE0: OUT CH6: IN CH4: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  384036: SELECT: OUT QUE0: OUT CH7: IN CH5: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  384036: SELECT: OUT QUE0: OUT CH8: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  384036: SELECT: OUT QUE0: OUT CH9: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  384036: SELECT: OUT QUE0: OUT CH10: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  384036: SELECT: OUT QUE0: OUT CH11: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  384037: SELECT: OUT QUE0: OUT CH12: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  384037: SELECT: OUT QUE0: OUT CH13: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  384037: SELECT: OUT QUE0: OUT CH14: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  384037: SELECT: OUT QUE0: OUT CH15: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  384037: SELECT: OUT QUE0: OUT CH16: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  384038: SELECT: OUT QUE0: OUT CH17: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  384038: SELECT: OUT QUE0: OUT CH18: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  384038: SELECT: OUT QUE1: OUT CH0: IN CH8: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  384038: SELECT: OUT QUE1: OUT CH1: IN CH9: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  384038: SELECT: OUT QUE1: OUT CH2: IN CH10: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  384039: SELECT: OUT QUE1: OUT CH3: IN CH11: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  384039: SELECT: OUT QUE1: OUT CH4: IN CH12: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  384039: SELECT: OUT QUE1: OUT CH5: IN CH13: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  384039: SELECT: OUT QUE1: OUT CH6: IN CH14: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  384039: SELECT: OUT QUE1: OUT CH7: IN CH15: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  384040: SELECT: OUT QUE1: OUT CH8: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  384040: SELECT: OUT QUE1: OUT CH9: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  384040: SELECT: OUT QUE1: OUT CH10: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  384040: SELECT: OUT QUE1: OUT CH11: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  384040: SELECT: OUT QUE1: OUT CH12: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  384041: SELECT: OUT QUE1: OUT CH13: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  384041: SELECT: OUT QUE1: OUT CH14: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  384041: SELECT: OUT QUE1: OUT CH15: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  384041: SELECT: OUT QUE1: OUT CH16: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  384041: SELECT: OUT QUE1: OUT CH17: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  384041: SELECT: OUT QUE1: OUT CH18: IN CH16: 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ]
 [m3vpss ]  384042: SELECT   : Create Done !!!
 [m3vpss ]  384042: SWMS: Create in progress !!!
 [m3vpss ]  384235: SWMS0    : Loading Vertical Co-effs (UPSCALE)x ...
 [m3vpss ]  384235: SWMS0    : Loading Horizontal Co-effs (UPSCALE)x ...
 [m3vpss ]  384235: SWMS    : Co-effs Loading ... DONE !!!
 [m3vpss ]  384235: SWMS    : VipScReq is FALSE!!!
 [m3vpss ]  384239: SWMS0    : Loading Vertical Co-effs (UPSCALE)x ...
 [m3vpss ]  384239: SWMS0    : Loading Horizontal Co-effs (UPSCALE)x ...
 [m3vpss ]  384239: SWMS    : Co-effs Loading ... DONE !!!
 [m3vpss ]  384240: SWMS    : ******* Configuring clock 16 secs...
 [m3vpss ]  384240: SWMS0    : Loading Vertical Co-effs (UPSCALE)x ...
 [m3vpss ]  384240: SWMS0    : Loading Horizontal Co-effs (UPSCALE)x ...
 [m3vpss ]  384240: SWMS    : Co-effs Loading ... DONE !!!
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]  384244: SWMS: Create Done !!!
 [m3vpss ]  384244: SWMS: Create in progress !!!
 [m3vpss ]  384433: SWMS    : VipScReq is FALSE!!!
 [m3vpss ]  384437: SWMS1    : Loading Vertical Co-effs (UPSCALE)x ...
 [m3vpss ]  384437: SWMS1    : Loading Horizontal Co-effs (UPSCALE)x ...
 [m3vpss ]  384437: SWMS    : Co-effs Loading ... DONE !!!
 [m3vpss ]  384438: SWMS    : ******* Configuring clock 16 secs...
 [m3vpss ]  384438: SWMS1    : Loading Vertical Co-effs (7/16)x ...
 [m3vpss ]  384438: SWMS1    : Loading Horizontal Co-effs (7/16)x ...
 [m3vpss ]  384438: SWMS    : Co-effs Loading ... DONE !!!
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [c6xdsp ]  383681: IPC_FRAMES_IN   : Create in progress !!!
 [c6xdsp ]  383681: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_19] ...
 [c6xdsp ]  383682: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_19] ...
 [m3vpss ]  384440: SWMS: Create Done !!!
 [m3vpss ]  384441: IPC_FRAMES_OUT   : Create in progress !!!
 [c6xdsp ]  383683: IPC_FRAMES_IN   : Create Done !!!
 [c6xdsp ]  383683: ALG : Create in progress !!!
 [m3vpss ]  384443: IPC_FRAMES_OUT   : Create Done !!!
 [m3vpss ]  384457: IPC_FRAMES_OUT   : Create in progress !!!
 [c6xdsp ] ALGLINK:HEAPID:0     USED:2560
 [m3vpss ]  384459: IPC_FRAMES_OUT   : Create Done !!!
 [c6xdsp ]  383693: ALG : Create Done !!!
 [c6xdsp ]  383698: IPC_FRAMES_IN   : Create in progress !!!
 [c6xdsp ]  383698: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_20] ...
 [c6xdsp ]  383698: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_20] ...
 [m3vpss ]  384474: MERGE   : Create Done !!!
 [m3vpss ]  384475: SELECT: OUT QUE0: OUT CH0: IN CH0: 1920 x 1080, pitch = (3840, 0) [PROGRESSIVE] [NON-TILED  ]
 [c6xdsp ]  383699: IPC_FRAMES_IN   : Create Done !!!
 [m3vpss ]  384475: SELECT: OUT QUE1: OUT CH0: IN CH1: 1920 x 1080, pitch = (3840, 0) [PROGRESSIVE] [NON-TILED  ]
 [c6xdsp ]  383700: ALG : Create in progress !!!
 [m3vpss ]  384476: SELECT   : Create Done !!!
 [m3vpss ]  384481: DUP   : Create Done !!!
 [m3vpss ]  384481: DISPLAY: Create in progress !!!
 [m3vpss ]  384482: DISPLAY: Create Done !!!
 [m3vpss ]  384483: DISPLAY: Create in progress !!!
 [c6xdsp ]  383710: ALG : Create Done !!!
 [m3video]  384487: IPC_IN_M3   : Create in progress !!!
 [m3vpss ]  384484: DISPLAY: Create Done !!!
 [m3video]  384488: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ...
 [m3vpss ]  384484: NSF: Create in progress !!!
 [m3video]  384488: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ...
 [m3video]  384490: IPC_IN_M3   : Create Done !!!
 [m3video]  384490: ENCODE: Create in progress ... !!!
 [m3vpss ]  384486: NSF: Create Done !!!
 [m3vpss ]  384486: IPC_OUT_M3   : Create in progress !!!
 [m3vpss ]  384487: IPC_OUT_M3   : Create Done !!!
 [host]  2082: IPC_BITS_IN   : Create in progress !!!
 [host]  2082: IPC_BITS_IN   : ListMPOpen start !!!
 [host]  2082: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_24] ...
 2085: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_24] ...
 [m3video]  384514: ENCODE: Creating CH0 of 1920 x 1080, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 8000 Kbps ...
 [host]  2087: IPC_BITS_IN   : ListMPOpen done !!!
 [host]  2088: IPC_BITS_IN   : System_linkGetInfo done !!!
 [host]  2088: IPC_BITS_IN   : Create Done !!!
[src/codecs_links.c 1242 @ Jul 09, 12:57:18] __codecs_decoder_links_create: Leave.
[src/codecs_decoder.c 2155 @ Jul 09, 12:57:18] __codecs_decode_task_external_main: Leave(status=0)
[src/codecs_decoder.c 3815 @ Jul 09, 12:57:18] __codecs_encoder_task_external_main: Enter
[src/codecs_decoder.c 3546 @ Jul 09, 12:57:18] __codecs_encoder_init: Enter (pencode=0x13f158, orig=0x13f158)
[src/codecs_decoder.c 2971 @ Jul 09, 12:57:18] __codecs_encode_chn_init: Enter
[src/codecs_capability.c 520 @ Jul 09, 12:57:18] __codecs_capability_allocate: Prev cap:48, Curr cap:32.
[src/codecs_transport.c 897 @ Jul 09, 12:57:18] __transport_rtsp_init: Enter
 [m3video] ENCLINK_H264:HEAPID:0        USED:11912
 [m3video]  384517: ENCODE: All CH Create ... DONE !!!
[src/codecs_transport.c 971 @ Jul 09, 12:57:18] __transport_rtsp_init: Leave
[src/codecs_decoder.c 3017 @ Jul 09, 12:57:18] __codecs_encode_chn_init: Leave (status=0)
[src/codecs_decoder.c 3576 @ Jul 09, 12:57:18] __codecs_encoder_init: Leave (pencode=0x13f158)
[src/codecs_decoder.c 3854 @ Jul 09, 12:57:18] __codecs_encoder_task_external_main: Leave (status=0)
 [m3video] ENCLINK:HEAPID:0     USED:12032
 [m3video]  384519: ENCODE: Create ... DONE !!!
 [m3video]  384519: IPC_BITS_OUT   : Create in progress !!!
[src/codecs_main.c 347 @ Jul 09, 12:57:18] task_daemon_start: Enter
[src/codecs_decoder.c 1434 @ Jul 09, 12:57:18] __codecs_decode_start: Enter
 [m3video]  384521: IPC_BITS_OUT   : Create Done !!!
 [m3vpss ]  384581: CAPTURE: Start in progress !!!
 [m3video]  384528: DECODE: CH1:
 [m3video]  384529: DECODE: CH1:
 [m3video]  384529: DECODE: CH2:
 [m3video]  384529: DECODE: CH4:
 [m3video]  384529: DECODE: CH5:
 [m3video]  384530: DECODE: CH7:
 [m3video]  384530: DECODE: CH8:
 [m3video]  384530: DECODE: CH10:
 [m3video]  384530: DECODE: CH11:
 [m3video]  384531: DECODE: CH11:
 [m3video]  384531: DECODE: CH13:
 [m3video]  384531: DECODE: CH14:
 [m3video]  384531: DECODE: CH16:
 [m3video]  384532: DECODE: CH1:
 [m3video]  384532: DECODE: CH2:
 [m3video]  384532: DECODE: CH4:
 [m3video]  384533: DECODE: CH4:
 [m3video]  384533: DECODE: CH5:
 [m3video]  384533: DECODE: CH7:
 [m3video]  384534: DECODE: CH8:
 [m3video]  384534: DECODE: CH10:
 [m3video]  384535: DECODE: CH11:
 [m3video]  384535: DECODE: CH13:
 [m3video]  384535: DECODE: CH14:
 [m3video]  384536: DECODE: CH14:
 [m3video]  384536: DECODE: CH16:
 [m3vpss ]  384681: CAPTURE: Enabled Time Stamping !!!
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]  000 |     704     704       0      1     1     0 65535 /    0 65535 /    0      49          0 0/0 (703/0)
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]  VIP0 : FIQ_STATUS  : 0x4810551c = 0x00000010
 [m3vpss ]  VIP1 : FIQ_STATUS  : 0x48105a1c = 0x00000000
 [m3vpss ]  VPDMA: LIST_BUSY   : 0x4810d00c = 0x00010000
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]  387683: CAPTURE: Start Done !!!
 [m3vpss ]  387685: DISPLAY: Start in progress !!!
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]  VIP Capture Port 0 | DescMissMatch1 = 1, DescMissMatch2 = 1 , DescMissMatch3 = 0
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]  List Post Count        : 1474
 [m3vpss ]  List Stall Count       : 1
 [m3vpss ]  List Post Time (ms)    : Max = 3090, Min = 0, Avg = 2, Total = 3090
 [m3vpss ]  INTC Timeout Count     : (3, 0) (Min timeout value = 0, 1000)
 [m3vpss ]
 [m3vpss ]  List Stall Info,
 [m3vpss ]    0:   387647 ms
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]  VPDMA: LIST_BUSY   : 0x4810d00c = 0x00030000
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]  VIP Capture Port 0 | DescMissMatch1 = 2, DescMissMatch2 = 2 , DescMissMatch3 = 1
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]  List Post Count        : 1477
 [m3vpss ]  List Stall Count       : 2
 [m3vpss ]  List Post Time (ms)    : Max = 3090, Min = 0, Avg = 4, Total = 6180
 [m3vpss ]  INTC Timeout Count     : (6, 0) (Min timeout value = 0, 1000)
 [m3vpss ]
 [m3vpss ]    1:   393742 ms
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]  402963: CAPTURE: Overflow detected on VIP0, Total Resets = 1
 [host] HDMI Ctrl :Sink Disconnected
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]  000 |       1       1       0      0     0     0 65535 /    0 65535 /    0       1          0 0/0 (0/2)
 [m3vpss ]
 [m3vpss ]  VIP Capture Port 0 | DescMissMatch1 = 3, DescMissMatch2 = 3 , DescMissMatch3 = 2
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]  List Post Count        : 1480
 [m3vpss ]  List Stall Count       : 3
 [m3vpss ]  List Post Time (ms)    : Max = 3090, Min = 0, Avg = 6, Total = 9270
 [m3vpss ]  INTC Timeout Count     : (9, 0) (Min timeout value = 0, 1000)
 [m3vpss ]
 [m3vpss ]    2:   399837 ms
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [host] HDMI Ctrl :Sink Connected
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]  VIP Capture Port 0 | DescMissMatch1 = 3, DescMissMatch2 = 3 , DescMissMatch3 = 3
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]  List Post Count        : 1481
 [m3vpss ]  List Stall Count       : 4
 [m3vpss ]  List Post Time (ms)    : Max = 3090, Min = 0, Avg = 8, Total = 12360
 [m3vpss ]  INTC Timeout Count     : (10, 0) (Min timeout value = 0, 1000)
 [m3vpss ]
 [m3vpss ]    3:   405933 ms
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
Many thanks!
  • This could be an issue with delete sequence. Does unload / load resolves this issue?
    Share your use case file for recreating this issue - still we will not be able to provide a solution immediately.
    Until we debug this issue, I would recommend to proceed with your product development with the working sequence (first).
  • Hi team:
    Customer follow our HDVPSS user guide. Add a IOCTL_VPS_CAPT_RESET_VIP0/1 at capture link. Reset VP interface resolve this problem.
    Beleve it is scaler parameter set need disable/enable VP at user guide gived suggest.
    Best Regards!
    Han Tao
  • Register values show that there is vip overflow which gets fixed on calling IOCTL_VPS_CAPT_RESET_VIP0.
    What is the PG revision used? With 1.1, there are such possible overflow issues.
    IOCTL_VPS_CAPT_RESET_VIP0/1 can be used on a fresh start. So, customer can follow this working sequence.
