How to disable RTDX from linking in memory
We are running into a memory limitation with our project running on C5505 DSP, so I'm trying to optimize everything I can think of...
From the memory map output file that is created after the build, I noticed that a lot of memory was taken by RTDX which we do not use at all. So my first guess was to disable RTDX in DSP/BIOS control panel. But when I rebuilt the solution and analysed the MAP file, I concluded that a lot of RTDX segments were still linked and mapped to different memory locations. For instance I still see: .rtdx_text ; .rtdx_data linked into the memory...
Is there any way I can completely forbid RTDX to link into the memory? This happens both in release and debug mode.
Thank you,
