When does the IPC library use the IPC peripheral?
We have some code which (for efficiency reasons, every cycle counts for this application) uses the IPC peripheral by directly accessing the peripheral's registers. However, we now have to integrate a library which uses ti.sdo.ipc.SharedRegion, therefore IPC_start() has to be called - which in our cases uses ti.sdo.ipc.family.c647x.NotifyCircSetup.
1. What I wonder : Is it save to remove that interrupt handler later on, when SharedRegion is the only thing provided by IPC we use?
2. The handler is registered at an interrupt specified in a variable called "NotifyCircSetup_dspIntVectId". Looking at the header, the only thing I see is:
/* dspIntVectId */
#ifdef ti_sdo_ipc_family_c647x_NotifyCircSetup_dspIntVectId__D
#define ti_sdo_ipc_family_c647x_NotifyCircSetup_dspIntVectId (ti_sdo_ipc_family_c647x_NotifyCircSetup_dspIntVectId__D)
#else
#define ti_sdo_ipc_family_c647x_NotifyCircSetup_dspIntVectId (ti_sdo_ipc_family_c647x_NotifyCircSetup_dspIntVectId__C)
typedef xdc_UInt CT__ti_sdo_ipc_family_c647x_NotifyCircSetup_dspIntVectId;
__extern __FAR__ const CT__ti_sdo_ipc_family_c647x_NotifyCircSetup_dspIntVectId ti_sdo_ipc_family_c647x_NotifyCircSetup_dspIntVectId__C;
#endif
Any idea where this value is defined?
Thank you in advance, Clemens
