how to use Heap*MP Modules
Hi
how can Heap*MP Modules be useful? in the examples code i have seen create and allocate memory from Heap*MP but how i can use this allocated memory?
I have seen APIs that create/open and allocate memory from  this module but how can use this allocated memory? Is there any API to read this memory ?
in my application I need a share region to be see with all cores (core0 runs linux and core1-7 run sys/bios) Can i use Heap*MP Modules to do that?
  • Well, typically memory allocated from Heap*MP is used for passing messages between different processors.
    Heap*MP is supported between BIOS to BIOS not Linux to BIOS so I do not think you can use this in your case.
    For Linux you can use a module called CMEM.
