how to change frame rate on dm357 platform codecs?
hi;
I am using dm357 platform.Now ,I want to change the encode frame rate .when I try to change the parames of the reframerate and targetframerate,but it is invalid.The output frame is also 30fps.
Does anybody know how to change the encode frame rate?
Thanks;
    Can you please specify the Input frame rate and desired encode frame rate?
    Usually the Encoder does not drop frames by itself to change frame rates from the input frames. The only thing it uses from the target frame rate is to calculate the time increament between the frames.
    Pankaj
