Other Parts Discussed in Thread: TMS320C6657, SYSBIOS
I set up a project with “omp_hello.c” which offered by TI in TMS320C6657.It includes “ti/omp/omp.h”.
When I compile the project,errors occur,like couldn’t find header files and unresolved symbol.
I try to fix it. Until now,It reports the following error, and I feel hopeless.
Does openMP work in 6657? Are there any integrated example projects?
Error:
#10010 errors encountered during linking; "omp_hello.out" not built omp_hello C/C++ Problem
<a href="file:/C:/ti/ccsv5/tools/compiler/dmed/HTML/10234.html">#10234-D</a> unresolved symbols remain omp_hello C/C++ Problem
unresolved symbol ti_sysbios_knl_Task_self__E, first referenced in C:\ti\omp_1_01_03_02\packages\ti\omp\utils\lib\debug\ti.omp.utils.ae66<ThreadLocal.oe66> omp_hello C/C++ Problem
unresolved symbol ti_sysbios_knl_Task_getHookContext__E, first referenced in C:\ti\omp_1_01_03_02\packages\ti\omp\utils\lib\debug\ti.omp.utils.ae66<ThreadLocal.oe66> omp_hello C/C++ Problem
unresolved symbol xdc_runtime_Memory_calloc__E, first referenced in C:\ti\omp_1_01_03_02\packages\ti\omp\lib\debug\ti.omp.ae66<alloc.oe66> omp_hello C/C++ Problem
unresolved symbol xdc_runtime_Assert_raise__I, first referenced in C:\ti\omp_1_01_03_02\packages\ti\omp\utils\lib\debug\ti.omp.utils.ae66<ThreadLocal.oe66> omp_hello C/C++ Problem
unresolved symbol ti_omp_utils_ThreadLocal_Module__id__C, first referenced in C:\ti\omp_1_01_03_02\packages\ti\omp\utils\lib\debug\ti.omp.utils.ae66<ThreadLocal.oe66> omp_hello C/C++ Problem
unresolved symbol ti_omp_utils_ThreadLocal_Module__diagsMask__C, first referenced in C:\ti\omp_1_01_03_02\packages\ti\omp\utils\lib\debug\ti.omp.utils.ae66<ThreadLocal.oe66> omp_hello C/C++ Problem
unresolved symbol ti_sysbios_BIOS_getThreadType__E, first referenced in C:\ti\omp_1_01_03_02\packages\ti\omp\utils\lib\debug\ti.omp.utils.ae66<ThreadLocal.oe66> omp_hello C/C++ Problem
unresolved symbol ti_omp_utils_ThreadLocal_Module__state__V, first referenced in C:\ti\omp_1_01_03_02\packages\ti\omp\utils\lib\debug\ti.omp.utils.ae66<ThreadLocal.oe66> omp_hello C/C++ Problem
unresolved symbol ti_omp_utils_ThreadLocal_A_invalidKey__C, first referenced in C:\ti\omp_1_01_03_02\packages\ti\omp\utils\lib\debug\ti.omp.utils.ae66<ThreadLocal.oe66> omp_hello C/C++ Problem
unresolved symbol ti_omp_utils_ThreadLocal_A_invalidContext__C, first referenced in C:\ti\omp_1_01_03_02\packages\ti\omp\utils\lib\debug\ti.omp.utils.ae66<ThreadLocal.oe66> omp_hello C/C++ Problem
unresolved symbol ti_omp_utils_ThreadLocal_Module__diagsIncluded__C, first referenced in C:\ti\omp_1_01_03_02\packages\ti\omp\utils\lib\debug\ti.omp.utils.ae66<ThreadLocal.oe66> omp_hello C/C++ Problem
unresolved symbol ti_omp_utils_ThreadLocal_Module__diagsEnabled__C, first referenced in C:\ti\omp_1_01_03_02\packages\ti\omp\utils\lib\debug\ti.omp.utils.ae66<ThreadLocal.oe66> omp_hello C/C++ Problem
Warning:
Description Resource Path Location Type
#10210-D creating ".stack" section with default size of 0x400; use the -stack option to change the default size omp_hello C/C++ Problem
#10210-D creating ".sysmem" section with default size of 0x400; use the -heap option to change the default size omp_hello C/C++ Problem
unresolved symbol SharedRegion_getCacheLineSize, first referenced in C:\ti\omp_1_01_03_02\packages\ti\omp\lib\debug\ti.omp.ae66<alloc.oe66> omp_hello C/C++ Problem
unresolved symbol SharedRegion_getHeap, first referenced in C:\ti\omp_1_01_03_02\packages\ti\omp\lib\debug\ti.omp.ae66<alloc.oe66> omp_hello C/C++ Problem
#163-D unrecognized #pragma omp_hello.c /omp_hello line 32 C/C++ Problem
#10247-D creating output section "gomp_data" without a SECTIONS specification omp_hello C/C++ Problem
