questions for acronyms in data sheet SPRUGZ8E on TMS320DM814x
Other Parts Discussed in Thread: TMS320DM8148
preface: i am posting this questions here on special request from the ASKTEXAS support staff after first asking them those product related question directly.
I have the publically available data sheet SPRUGZ8E on TMS320DM814x to my hands and now I have stumbled across a few shortcuts for some hardware units for which I currently cannot find a sufficient set of informations.
The units and shortcuts in question are:
* SW3PG
* ISS
* ISP
* FACEDETECT
* DSS
* HDD_SS
As of now I can only find power and clock domain controls for that units.
For some keywords there is an entry at "3.2.17 DEV_FEATURE Register (offset = 604h) [reset = 0h]"
Further there is a document of name "efuse xls " referenced in "Table 3-20. DEV_FEATURE Register Field Descriptions"
that I have not seen so far and further don’t know how to obtain that document.
Where can I find data sheet and description of this units for checking their features and probably programming them?
Where can I find that mentioned xls document?
  • Alexander,
    SPRUGZ8E is DM814x TRM, not datasheet. See the DM8148 official site:
    http://www.ti.com/product/tms320dm8148
    We have 3 public documents:
    1. DM814x datasheet (SPRS647E) : http://www.ti.com/lit/ds/symlink/tms320dm8148.pdf
    2. DM814x TRM (SPRUGZ8E) : http://www.ti.com/lit/ug/sprugz8e/sprugz8e.pdf
    3. DM814x Silicon Errata (SPRZ343C) : http://www.ti.com/lit/er/sprz343c/sprz343c.pdf
    * SW3PG
    I think this is the three port switch (3PSW) Ethernet subsystem, documented in chapter 9 of the TRM.
    * ISS
    This stands for Imaging SubSystem, this is documented in separate addendum which is available only under NDA and through local FAE / TI representative.
    * ISP
    This stands for Image Signal Processor. This is submodule of the ISS, hence documented in the ISS addendum.
    * FACEDETECT
    I am not sure if facedetect hardware module is available in the DM814x device. I will further check and come back to you.
    * DSS
    * HDD_SS
    I think these two are the same, the Display Subsystem, which is part of the HDVPSS. HDVPSS document is   separate addendum which is available only under NDA and through local FAE / TI representative.
    This is TI internal document, which I do not think will be helpful to you. If you have any specific questions regarding the DM814x efuses let me know.
    Pavel
  • (sprugz8e pops up in section user guides. the term data sheet might be understood as a top level term for nearly any sort technical description - for the TI web page the section headline "Datasheet" covers what you told me. - stop with side track.)
    all terms i asked for are mentioned in that document as some attribute of the device described by it.
