Other Parts Discussed in Thread: TPS65910
DM8127 SD boot problem:
I want boot from sd card,but the program running is not always correct,
I want to know how to solve this problem!
My bootargs is:
bootcmd=ipnc_ff_init 1;mmc rescan 0;fatload mmc 0 0x81000000 uImage;bootm 0x81000000 bootargs=console=ttyO0,115200n8 noinitrd mem=80M rootwait vram=4M notify.vpssm3_sva=0xBFD00 000 root=/dev/mmcblk0p2 rw eth=84:7e:40:6f:d1:4e ip=192.168.1.168 cmemk.phys_start=0x850000 00 cmemk.phys_end=0x89000000 cmemk.allowOverlap=1 earlyprintk
I use the release binarys file is:
GA_Release_3.5.0
when running error the complete boot log is:
U-Boot 2010.06 (Dec 19 2013 - 16:05:22) DM8127_IPNC_3.50.00
TI8148-GP rev 2.1
ARM clk: 600MHz
DDR clk: 400MHz
L3 clk: 200MHz
IVA clk: 450MHz
ISS clk: 400MHz
DSP Default OFF
DSS Default OFF
DRAM: 512 MiB
MMC: OMAP SD/MMC: 0, ON-BOARD SDIO: 1
Using default environment
The 2nd stage U-Boot will now be auto-loaded
Please do not interrupt the countdown till TI8148_EVM prompt if 2nd stage is already flashe
d
Hit any key to stop autoboot: 0
reading u-boot.bin
199528 bytes read
## Starting application at 0x80800000 ...
U-Boot 2010.06 (Dec 19 2013 - 16:06:43) DM8127_IPNC_3.50.00
TI8148-GP rev 2.1
ARM clk: 600MHz
DDR clk: 400MHz
L3 clk: 200MHz
IVA clk: 450MHz
ISS clk: 400MHz
DSP Default OFF
DSS Default OFF
I2C: ready
DRAM: 512 MiB
NAND: HW ECC BCH8 Selected
256 MiB
.:;rrr;;.
,5#@@@@#####@@@@@@#2,
,A@@@hi;;;r5;;;;r;rrSG@@@A,
r@@#i;:;s222hG;rrsrrrrrr;ri#@@r
:@@hr:r;SG3ssrr2r;rrsrsrsrsrr;rh@@:
B@H;;rr;3Hs;rrr;sr;;rrsrsrsrsrsr;;H@B
@@s:rrs;5#;;rrrr;r#@H:;;rrsrsrsrsrr:s@@
@@;;srs&X#9;r;r;;,2@@@rrr:;;rrsrsrsrr;;@@
@@;;rrsrrs@MB#@@@@@###@@@@@@#rsrsrsrsrr;;@@
G@r;rrsrsr;#X;SX25Ss#@@#M@#9H9rrsrsrsrsrs;r@G
@9:srsrsrs;2@;:;;:.X@@@@@H::;rrsrsrsrsrsrr:3@
X@;rrsrsrsrr;XAi;;:&@@#@Bs:rrsrsrsrsrsrsrsrr;@X
@#;rsrsrsrsrr;r2ir@@@###::rrsrsrsrsrsrsrsrsr:@@
@A:rrsrsrsrr;:2@29@@M@@@;:;rrrrsrsrsrsrsrsrs;H@
@&;rsrsrsrr;A@@@@@@###@@@s::;:;;rrsrsrsrsrsr;G@
@#:rrsrsrsr;G@5Hr25@@@#@@@#9XG9s:rrrrsrsrsrs:#@
M@;rsrsrsrs;r@&#;::S@@@@@@@M@@@@Grr:;rsrsrsr;@#
:@s;rsrsrsrr:M#Msrr;;&#@@@@@@@@@@H@@5;rsrsr;s@,
@@:rrsrsrsr;S@rrrsr;:;r3MH@@#@M5,S@@irrsrr:@@
@A:rrsrsrsrrrrrsrsrrr;::;@##@r:;rH@h;srr:H@
;@9:rrsrsrsrrrsrsrsrsr;,S@Hi@i:;s;MX;rr:h@;
r@B:rrrrsrsrsrsrsrr;;sA@#i,i@h;r;S5;r:H@r
,@@r;rrrsrsrsrsrr;2BM3r:;r:G@:rrr;;r@@,
B@Mr;rrrrsrsrsr@@S;;;rrr:5M;rr;rM@H
.@@@i;;rrrrsrs2i;rrrrr;r@M:;i@@@.
.A@@#5r;;;r;;;rrr;r:r#AsM@@H.
;&@@@@MhXS5i5SX9B@@@@G;
:ihM#@@@@@##hs,
Date: 2012-11-09 (Friday) Time: 14:18:49
Net: Detected MACID:84:7e:40:6f:d1:4e
cpsw
Hit any key to stop autoboot: 3 2 1 0
reading uImage
2493132 bytes read
## Booting kernel from Legacy Image at 81000000 ...
Image Name: Linux-2.6.37_DM8127_IPNC_3.50.00
Created: 2013-12-19 8:27:47 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2493068 Bytes = 2.4 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 2.6.37_DM8127_IPNC_3.50.00 (root@ws-virtual-machine) (gcc version 4.5.3 20110
311 (prerelease) (GCC) ) #1 Thu Dec 19 16:27:38 CST 2013
CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: ti8148ipnc
vram size = 4194304 at 0x0
bootconsole [earlycon0] enabled
ti81xx_reserve: ### Reserved DDR region @84f00000
reserved size = 4194304 at 0x0
FB: Reserving 4194304 bytes SDRAM for VRAM
Memory policy: ECC disabled, Data cache writeback
OMAP chip is TI8148 2.1
SRAM: Mapped pa 0x402f1000 to va 0xfe400000 size: 0xf000
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 19040
Kernel command line: console=ttyO0,115200n8 noinitrd mem=80M rootwait vram=4M notifyk.vpssm
3_sva=0xBFD00000 root=/dev/mmcblk0p2 rw eth=84:7e:40:6f:d1:4e ip=192.168.253.168 cmemk.phys
_start=0x85000000 cmemk.phys_end=0x89000000 cmemk.allowOverlap=1 earlyprintk
cpsw: kernel boot params Ethernet address: 84:7e:40:6f:d1:4e
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 74MB 1MB = 75MB total
Memory: 70652k/70652k available, 11268k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0xc5800000 - 0xf8000000 ( 808 MB)
lowmem : 0xc0000000 - 0xc5000000 ( 80 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.init : 0xc0008000 - 0xc003e000 ( 216 kB)
.text : 0xc003e000 - 0xc04bf000 (4612 kB)
.data : 0xc04c0000 - 0xc05004c0 ( 258 kB)
SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:375
IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
Total of 128 interrupts on 1 active controller
GPMC revision 6.0
Trying to install interrupt handler for IRQ368
Trying to install interrupt handler for IRQ369
Trying to install interrupt handler for IRQ370
Trying to install interrupt handler for IRQ371
Trying to install interrupt handler for IRQ372
Trying to install interrupt handler for IRQ373
Trying to install interrupt handler for IRQ374
Trying to install type control for IRQ375
Trying to set irq flags for IRQ375
OMAP clockevent source: GPTIMER1 at 20000000 Hz
Console: colour dummy device 80x30
Calibrating delay loop... 599.65 BogoMIPS (lpj=2998272)
pid_max: default: 32768 minimum: 301
Security Framework initialized
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
devtmpfs: initialized
TI81XX: Map 0x84f00000 to 0xfe500000 for dram barrier
TI81XX: Map 0x40300000 to 0xfe600000 for sram barrier
omap_voltage_early_init: voltage driver support not added
regulator: core version 0.5
regulator: dummy:
NET: Registered protocol family 16
omap_voltage_domain_lookup: Voltage driver init not yet happened.Faulting!
omap_voltage_add_dev: VDD specified does not exist!
OMAP GPIO hardware version 0.1
omap_mux_init: Add partition: #1: core, flags: 4
_omap_mux_init_gpio: Could not set gpio79
_omap_mux_init_gpio: Could not set gpio80
Cannot clk_get ck_32
Debugfs: Only enabling/disabling deep sleep and wakeup timer is supported now
registered ti81xx_vpss device
registered ti81xx_vidout device
registered ti81xx on-chip HDMI device
registered ti81xx_fb device
PWM0 init success.
PWM1 init success.
bio: create slab <bio-0> at 0
SCSI subsystem initialized
USBSS revision 4ea2080b
registerd cppi-dma Intr @ IRQ 17
Cppi41 Init Done
omap_i2c omap_i2c.1: bus 1 rev4.0 at 100 kHz
regulator: VRTC: 1800 mV
regulator: VIO: 1500 mV
regulator: VDD1: 600 <--> 1500 mV at 1100 mV
regulator: VDD2: 600 <--> 1500 mV at 1350 mV
regulator: VDDCTRL: 600 <--> 1400 mV at 1200 mV
regulator: LDO1: 1100 <--> 3300 mV at 1800 mV
regulator: LDO2: 1100 <--> 3300 mV at 1800 mV
regulator: LDO3: 1100 <--> 3300 mV at 3300 mV
regulator: LDO4: 1100 <--> 3300 mV at 1800 mV
regulator: LDO5: 1100 <--> 3300 mV at 3300 mV
regulator: LDO6: 1100 <--> 3300 mV at 3300 mV
regulator: LDO7: 1100 <--> 3300 mV at 3300 mV
regulator: LDO8: 1100 <--> 3300 mV at 1800 mV
tps65911-rtc tps65911-rtc: rtc core: registered tps65911-rtc as rtc0
tps65910 1-002d: No interrupt support, no core IRQ
Advanced Linux Sound Architecture Driver Version 1.0.23.
Switching to clocksource gp timer
musb-hdrc: version 6.0, peripheral, debug=0
musb-hdrc musb-hdrc.0: dma type: dma-cppi41
MUSB controller-0 revision 4ea20800
usb2phy: computed values rxcalib(15)DACs(29 12 14)
usb2phy: override computed values rxcalib(15)DACs(29 12 14)
usb2phy_config: musb(0) rxcalib done, rxcalib read value 6f6ed976
musb-hdrc musb-hdrc.0: USB Peripheral mode controller at c581e000 using DMA, IRQ 18
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
NetWinder Floating Point Emulator V0.97 (double precision)
PMU: registered new PMU device of type 0
omap-iommu omap-iommu.0: ducati registered
omap-iommu omap-iommu.1: sys registered
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 137
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
CMEMK module: built on Dec 10 2013 at 11:03:49
Reference Linux version 2.6.37
File /opt/ipnc/Source/ti_tools/linuxutils_3_23_00_01/packages/ti/sdo/linuxutils/cmem/src/
module/cmemk.c
allocated heap buffer 0xc7000000 of size 0x4000000
cmemk initialized
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0
console [ttyO0] enabled, bootconsole disabled
omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
brd: module loaded
loop: module loaded
omap2-nand driver initializing
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xca (Micron )
Creating 8 MTD partitions on "omap2-nand.0":
0x000000000000-0x000000020000 : "U-Boot-min"
0x000000020000-0x000000260000 : "U-Boot"
0x000000260000-0x000000280000 : "U-Boot Env"
0x000000280000-0x0000006c0000 : "Kernel"
0x0000006c0000-0x000006fc0000 : "File System"
0x000006fc0000-0x000007bc0000 : "Data"
0x000007bc0000-0x00000b0c0000 : "File System2"
0x00000b0c0000-0x000010000000 : "Reserved"
davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
davinci_mdio davinci_mdio.0: detected phy mask fffffffc
davinci_mdio.0: probed
davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver unknown
davinci_mdio davinci_mdio.0: phy[1]: device 0:01, driver unknown
mice: PS/2 mouse device common for all mice
i2c /dev entries driver
Linux video capture interface: v2.00
OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
notify_init : notify drivercreated for remote proc id 2 at physical Address 0xbfd00000
cm: Module associated with clock hdmi_i2s_fck didn't enable in 100000 tries
asoc: tlv320aic3x-hifi <-> davinci-mcasp.2 mapping ok
asoc: HDMI-DAI-CODEC <-> hdmi-dai mapping ok
ALSA device list:
#0: TI8148 IPNC
nf_conntrack version 0.5.0 (1103 buckets, 4412 max)
ip_tables: (C) 2000-2006 Netfilter Core Team
TCP cubic registered
NET: Registered protocol family 17
Bridge firewalling registered
lib80211: common routines for IEEE802.11 drivers
Registering the dns_resolver key type
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
omap_voltage_late_init: Voltage driver support not added
Power Management for TI81XX.
Detected MACID=84:7e:40:6f:d1:4e
tps65911-rtc tps65911-rtc: setting system clock to 2012-11-09 14:18:58 UTC (1352470738)
mmc1: new high speed SDHC card at address 1234
mmcblk0: mmc1:1234 SA04G 3.63 GiB
mmcblk0: p1 p2
CPSW phy found : id is : 0x4dd074
IP-Config: Guessing netmask 255.255.255.0
IP-Config: Complete:
device=eth0, addr=192.168.253.168, mask=255.255.255.0, gw=255.255.255.255,
host=192.168.253.168, domain=, nis-domain=(none),
bootserver=255.255.255.255, rootserver=255.255.255.255, rootpath=
EXT3-fs: barriers not enabled
PHY: 0:01 - Link is Up - 0/Half
PHY: 0:01 - Link is Down
PHY: 0:00 - Link is Up - 100/Full
kjournald starting. Commit interval 5 seconds
EXT3-fs (mmcblk0p2): warning: maximal mount count reached, running e2fsck is recommended
EXT3-fs (mmcblk0p2): using internal journal
EXT3-fs (mmcblk0p2): recovery complete
EXT3-fs (mmcblk0p2): mounted filesystem with writeback data mode
VFS: Mounted root (ext3 filesystem) on device 179:2.
devtmpfs: mounted
Freeing init memory: 216K
INIT: version 2.86 booting
Please wait: booting...
Starting udev
Remounting root file system...
Caching udev devnodes
root: mount: mounting /dev/root on / failed: No such file or directory
Configuring network interfaces... done.
Setting up IP spoofing protection: rp_filter.
rm: cannot remove '/tmp': Device or resource busy
inside finish.sh
UBI: attaching mtd5 to ubi0
UBI: physical eraseblock size: 131072 bytes (128 KiB)
UBI: logical eraseblock size: 126976 bytes
UBI: smallest flash I/O unit: 2048
UBI: sub-page size: 512
UBI: VID header offset: 2048 (aligned 2048)
UBI: data offset: 4096
UBI: max. sequence number: 130
UBI: attached mtd5 to ubi0
UBI: MTD device name: "Data"
UBI: MTD device size: 12 MiB
UBI: number of good PEBs: 96
UBI: number of bad PEBs: 0
UBI: number of corrupted PEBs: 0
UBI: max. allowed volumes: 128
UBI: wear-leveling threshold: 4096
UBI: number of internal volumes: 1
UBI: number of user volumes: 1
UBI: available PEBs: 0
UBI: total number of reserved PEBs: 96
UBI: number of PEBs reserved for bad PEB handling: 2
UBI: max/mean erase counter: 3/2
UBI: image sequence number: 720586556
UBI: background thread "ubi_bgt0d" started, PID 280
UBI device number 0, total 96 LEBs (12189696 bytes, 11.6 MiB), available 0 LEBs (0 bytes),
LEB size 126976 bytes (124.0 KiB)
UBIFS: recovery needed
UBIFS: recovery completed
UBIFS: mounted UBI device 0, volume 0, name "ubifs_volume"
UBIFS: file system size: 10285056 bytes (10044 KiB, 9 MiB, 81 LEBs)
UBIFS: journal size: 1015809 bytes (992 KiB, 0 MiB, 6 LEBs)
UBIFS: media format: w4/r0 (latest is w4/r0)
UBIFS: default compressor: lzo
UBIFS: reserved for root: 485787 bytes (474 KiB)
UBI: attaching mtd7 to ubi1
UBI: max. sequence number: 25
UBI: attached mtd7 to ubi1
UBI: MTD device name: "Reserved"
UBI: MTD device size: 79 MiB
UBI: number of good PEBs: 634
UBI: total number of reserved PEBs: 634
UBI: number of PEBs reserved for bad PEB handling: 6
UBI: max/mean erase counter: 8/7
UBI: image sequence number: 1523120032
UBI: background thread "ubi_bgt1d" started, PID 292
UBI device number 1, total 634 LEBs (80502784 bytes, 76.8 MiB), available 0 LEBs (0 bytes),
UBIFS: mounted UBI device 1, volume 0, name "ubifs_volume"
UBIFS: file system size: 78090240 bytes (76260 KiB, 74 MiB, 615 LEBs)
UBIFS: journal size: 3936256 bytes (3844 KiB, 3 MiB, 31 LEBs)
UBIFS: reserved for root: 3688395 bytes (3601 KiB)
./init.sh: line 5: -f: not found
numid=1,iface=MIXER,name='PCM Playback Volume'
; type=INTEGER,access=rw---R--,values=2,min=0,max=127,step=0
: values=127,127
| dBscale-min=-63.50dB,step=0.50dB,mute=0
[c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[m3video] Remote Debug Shared Memory @ 0xbff05020
[m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
SysLink version : 2.20.02.20
SysLink module created on Date:Dec 9 2013 Time:18:58:07
Trace enabled
Trace SetFailureReason enabled
/dev/mem opened.
Phy Addr : 0x48181560 Data : 0x00000002
secss put in low power state
Phy Addr : 0x48180f10 Data : 0x00000000
Phy Addr : 0x48180508 Data : 0x00000302
Phy Addr : 0x48180520 Data : 0x00000002
Phy Addr : 0x48180524 Data : 0x00000002
Phy Addr : 0x48180528 Data : 0x00000002
Phy Addr : 0x4c0000e4 Data : 0x00170208
Phy Addr : 0x4d0000e4 Data : 0x00170208
DDR IOs RX is shutdown
[host] Setting DMM priority for [ISS ] to [0] ( 0x4e000634 = 0x00800000 )
[host] Setting L3 bandwidth regulator for [HDVICP0 ] to [press=[0,0] BW=900, WM Cycles=25
00]
[host] Setting DMM priority for [HDVICP0 ] to [1] ( 0x4e000634 = 0x00000009 )
Creat queue id:0
queue id:0
FileMngThread created
Creat queue id:32769
queue id:32769
AlramThread created
Share memory init success
IPNC_3.50.00 (root@ws-virtual-machine) (gcc version 4.5.3 20110311 (pre
queue id:32769
Creat queue id:65538
queue id:65538
Creat queue id:98307
queue id:98307
[host] Attached to slave procId 2.
[host] Loaded file ./firmware/ipnc_rdk_fw_m3vpss.xem3 on slave procId 2.
[host] Started slave procId 2.
[host] Attached to slave procId 1.
inside autorun
sbulla: unknown partition table
[m3vpss ] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[m3vpss ] notify_attach rtnVal 0
[m3vpss ] initProxyServer rtnVal 0
[host] After Ipc_loadcallback status [0x00000000]
[host] Attached to slave procId 0.
[m3vpss ]
[m3vpss ] *** UTILS: CPU KHz = 400000 Khz ***
[m3vpss ]
[m3vpss ] 285: SYSTEM : System Common Init in progress !!!
[m3vpss ] 286: SYSTEM: IPC init in progress !!!
[m3vpss ] 286: SYSTEM: Attaching to [HOST] ...
[host] Loaded file ./firmware/ipnc_rdk_fw_m3video.xem3 on slave procId 1.
[m3vpss ] 1285: SYSTEM: Attaching to [HOST] ...
[host] After Ipc_startcallback status [0x00000000]
[m3vpss ] 1289: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[m3vpss ] 1289: SYSTEM: Attaching to [DSP] ...
[m3vpss ] 2288: SYSTEM: Attaching to [DSP] ...
INIT: Entering runlevel: 5
mkdosfs 3.0.12 (29 Oct 2011)
unable to get drive geometry, using default 255/63
/dev/sbulla has 255 heads and 63 sectors per track,
logical sector size is 512,
using 0xf8 media descriptor, with 1024 sectors;
file system has 2 12-bit FATs and 4 sectors per cluster.
FAT size is 1 sector, and provides 247 clusters.
There is 1 reserved sector.
Root directory contains 512 slots and uses 32 sectors.
Volume ID is 07980935, no volume label.
[m3vpss ] 3288: SYSTEM: Attaching to [DSP] ...
Starting telnet daemon
[host] Started slave procId 1.
[m3video] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[m3video]
[m3video] *** UTILS: CPU KHz = 400000 Khz ***
[m3video]
[m3video] 3394: SYSTEM : System Common Init in progress !!!
[m3video] 3395: SYSTEM: IPC init in progress !!!
[m3video] 3395: SYSTEM: Attaching to [HOST] ...
[host] Loaded file ./firmware/ipnc_rdk_fw_c6xdsp.xe674 on slave procId 0.
[host] Started slave procId 0.
[c6xdsp ] ***** SYSTEM : Frequency <ORG> - 500000000, <NEW> - 500000000
[c6xdsp ]
[c6xdsp ] *** UTILS: CPU KHz = 500000 Khz ***
[c6xdsp ]
[c6xdsp ] 1: SYSTEM : System Common Init in progress !!!
[c6xdsp ] 1: SYSTEM: IPC init in progress !!!
[c6xdsp ] 1: SYSTEM: Attaching to [HOST] ...
g_file_storage gadget: No serial-number string provided!
g_file_storage gadget: File-backed Storage Gadget, version: 1 September 2010
g_file_storage gadget: Number of LUNs=1
g_file_storage gadget-lun0: ro=0, nofua=0, file: /dev/sbulla
Simple mixer control 'PGA',0
Capabilities: cvolume cswitch penum
Capture channels: Front Left - Front Right
Limits: Capture 0 - 119
Front Left: Capture 80 [67%] [40.00dB] [on]
Front Right: Capture 80 [67%] [40.00dB] [on]
[m3video] 4394: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 4288: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 1001: SYSTEM: Attaching to [HOST] ...
[m3video] 4427: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[c6xdsp ] 1004: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[m3video] 4427: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 1004: SYSTEM: Attaching to [VIDEO-M3] ...
[m3vpss ] 5288: SYSTEM: Attaching to [DSP] ...
[m3video] 5426: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 2003: SYSTEM: Attaching to [VIDEO-M3] ...
[m3vpss ] 6288: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 2977: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[m3video] 6426: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 2977: SYSTEM: Attaching to [VPSS-M3] ...
[m3video] 6427: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
[m3video] 6427: SYSTEM: Attaching to [VPSS-M3] ...
[m3vpss ] 7288: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 3976: SYSTEM: Attaching to [VPSS-M3] ...
[m3video] 7426: SYSTEM: Attaching to [VPSS-M3] ...
[c6xdsp ] 4839: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[m3vpss ] 8288: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 4839: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3vpss ] 8289: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
[m3vpss ] 8289: SYSTEM: Attaching to [VIDEO-M3] ...
[m3video] 8426: SYSTEM: Attaching to [VPSS-M3] ...
queue id:0
[c6xdsp ] 5839: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3video] 9289: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[m3vpss ] 9288: SYSTEM: Attaching to [VIDEO-M3] ...
[m3video] 9289: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3vpss ] 9289: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[m3video] 9290: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
[m3vpss ] 9289: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3vpss ] 9290: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
[m3vpss ] 9290: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
[m3video] 9290: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
[m3vpss ] 9292: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[m3video] 9292: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[m3vpss ] 9292: SYSTEM: Notify register to [DSP] line 0, event 12 ...
[m3video] 9293: SYSTEM: Notify register to [DSP] line 0, event 12 ...
[m3vpss ] 9293: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[m3video] 9293: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[m3vpss ] 9293: SYSTEM: IPC init DONE !!!
[m3video] 9293: SYSTEM: IPC init DONE !!!
[m3vpss ] Received character 's'
[m3video] 9303: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[m3vpss ] 9303: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[m3video] 9303: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03c00000 (60 MB)
[m3vpss ] 9303: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03c00000 (60 MB)
[m3video] 9305: SYSTEM : System Common Init Done !!!
[m3vpss ] 9305: SYSTEM : System Common Init Done !!!
[m3video] Received character 's'
[c6xdsp ] 6839: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[c6xdsp ] 6839: SYSTEM: Creating MsgQ [DSP_MSGQ] ...
[c6xdsp ] 6840: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ...
[c6xdsp ] 6840: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[c6xdsp ] 6840: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[c6xdsp ] 6840: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[c6xdsp ] 6841: SYSTEM: IPC init DONE !!!
[c6xdsp ] 6844: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[c6xdsp ] 6844: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03c00000 (60 MB)
[c6xdsp ] 6845: SYSTEM : System Common Init Done !!!
[c6xdsp ] Received character 's'
queue id:65538
CPU is TI812x
Error: SemWait: Invalid Semaphore handler
Error: SemRelease: Invalid Semaphore handler
IPNC BUILD VERSION: DM8127 IPNC RDK VERSION 03.50.00.08
./bin/ipnc_rdk_mcfw.out VNF_QUALITY TRISTREAM TRIPLE_H264 TI2A AEWB 1080P_D1 H264 HIGH_SP
EED1 H264 HIGH_SPEED2 MJPEG 80 &
queue id:0
Starting syslogd/klogd: done
ApproDrvInit: 3
Creat queue id:131076
queue id:131076
[c6xdsp ] 13043: SYSTEM : System DSP Init in progress !!!
[c6xdsp ] 13048: SYSTEM: Creating ListMP [DSP_IPC_OUT_23] in region 0 ...
[c6xdsp ] 13049: SYSTEM: Creating ListMP [DSP_IPC_IN_23] in region 0 ...
[c6xdsp ] 13049: SYSTEM: ListElem Shared Addr = 0xbe98b680
[c6xdsp ] 13050: SYSTEM: Creating ListMP [DSP_IPC_OUT_24] in region 0 ...
[c6xdsp ] 13050: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ...
[c6xdsp ] 13050: SYSTEM: ListElem Shared Addr = 0xbe9ab080
[c6xdsp ] 13051: SYSTEM: Creating ListMP [DSP_IPC_OUT_25] in region 0 ...
[c6xdsp ] 13052: SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ...
[c6xdsp ] 13052: SYSTEM: ListElem Shared Addr = 0xbe9caa80
[c6xdsp ] 13053: SYSTEM: Creating ListMP [DSP_IPC_OUT_28] in region 0 ...
[c6xdsp ] 13053: SYSTEM: Creating ListMP [DSP_IPC_IN_28] in region 0 ...
[c6xdsp ] 13053: SYSTEM: ListElem Shared Addr = 0xbe9ea480
[c6xdsp ] 13054: SYSTEM: Creating ListMP [DSP_IPC_OUT_29] in region 0 ...
[c6xdsp ] 13054: SYSTEM: Creating ListMP [DSP_IPC_IN_29] in region 0 ...
[c6xdsp ] 13054: SYSTEM: ListElem Shared Addr = 0xbea04100
[c6xdsp ] !!WARNING.Resource already registered:2
[c6xdsp ] 13054: SYSTEM : Initializing Links !!!
[m3video] 16505: SYSTEM : System Video Init in progress !!!
[m3vpss ] 16505: SYSTEM : System VPSS Init in progress !!!
[m3video] 16505: SYSTEM : System Video Init Done !!!
[c6xdsp ] 13055: SYSTEM : FREE SPACE : System Heap = 6282544 B, Mbx = 10240 msgs)
[m3video] 16506: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
[m3video] 16506: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
[m3video] 16506: SYSTEM: ListElem Shared Addr = 0xbea1dd80
[m3video] 16509: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
[m3video] 16509: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
[m3video] 16510: SYSTEM: ListElem Shared Addr = 0xbea21280
[c6xdsp ] 13069: SYSTEM : Initializing Links ... DONE !!!
[m3video] 16521: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_28] in region 0 ...
[m3vpss ] === I2C0/2 Clk is active ===
[m3video] 16521: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_28] in region 0 ...
[m3vpss ] 16524: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
[c6xdsp ] 13069: SYSTEM : System DSP Init Done !!!
[m3video] 16521: SYSTEM: ListElem Shared Addr = 0xbea24780
[m3vpss ] 16525: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
[m3video] 16524: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_29] in region 0 ...
[m3vpss ] 16525: SYSTEM: ListElem Shared Addr = 0xbea58080
[m3video] 16525: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_29] in region 0 ...
[m3video] 16525: SYSTEM: ListElem Shared Addr = 0xbea3ea00
[m3video] 16527: HDVICP: Doing PRCM for IVAHD[0] ...
[m3vpss ] 16528: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
[m3video] 16527: HDVICP: PRCM for IVAHD[0] ... DONE.
[m3vpss ] 16528: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
[m3video] 16528: SYSTEM : Initializing Links !!!
[m3vpss ] 16528: SYSTEM: ListElem Shared Addr = 0xbea5b580
[m3video] 16528: SYSTEM : FREE SPACE : System Heap = 6282128 B, Mbx = 10240 msgs)
[m3vpss ] 16544: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_23] in region 0 ...
[m3vpss ] 16544: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_23] in region 0 ...
[m3video] 16529: SYSTEM : FREE SPACE : SR0 Heap = 15342464 B (14 MB)
[m3vpss ] 16544: SYSTEM: ListElem Shared Addr = 0xbea5ea80
[m3video] 16529: SYSTEM : FREE SPACE : Frame Buffer = 110100352 B (104 MB)
[m3vpss ] 16547: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_24] in region 0 ...
[m3vpss ] 16547: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_24] in region 0 ...
[m3video] 16529: SYSTEM : FREE SPACE : Bitstream Buffer = 62914432 B (59 MB)
[m3vpss ] 16548: SYSTEM: ListElem Shared Addr = 0xbea7e480
[m3vpss ] 16551: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_25] in region 0 ...
[m3video] 16529: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[m3vpss ] 16551: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_25] in region 0 ...
[m3video] 16530: SYSTEM : FREE SPACE : Tiler Buffer = 127 B (0 MB) - TILER OFF
[m3vpss ] 16551: SYSTEM: ListElem Shared Addr = 0xbea9de80
[m3vpss ] 16559: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_28] in region 0 ...
[m3vpss ] 16559: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_28] in region 0 ...
[m3vpss ] 16559: SYSTEM: ListElem Shared Addr = 0xbeabd880
[m3vpss ] 16562: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_29] in region 0 ...
[m3video] 16587: SYSTEM : Initializing Links ... DONE !!!
[m3vpss ] 16562: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_29] in region 0 ...
[m3vpss ] 16562: SYSTEM: ListElem Shared Addr = 0xbead7500
[m3vpss ] 16565: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
[m3vpss ] 16565: SYSTEM : FVID2 Init in progress !!!
[m3vpss ] 16631: SYSTEM : FVID2 Init in progress DONE !!!
[m3vpss ] 16631: SYSTEM : Device Init in progress !!!
[m3vpss ] Iss_init called !!!!!!
[m3vpss ] CPIS_init DONE !!!!!!
[m3vpss ] initPrms.isI2cInitReq = 1
[m3vpss ] Vps_deviceInit Daughter card not detected/connected!
[m3vpss ]
[m3vpss ] I2C2: Passed for address 0x5d !!!
[m3vpss ] 19366: SYSTEM : Device Init in progress DONE !!!
[m3vpss ] 19395: SYSTEM : System VPSS Init Done !!!
[m3vpss ] 19395: UTILS: DMA: HWI Create for INT62 !!!
[m3vpss ] 19395: SYSTEM : Initializing Links !!!
[m3vpss ] 19395: SYSTEM : FREE SPACE : System Heap = 1718872 B, Mbx = 10240 msgs)
[m3vpss ] 19395: SYSTEM : FREE SPACE : SR0 Heap = 14742656 B (14 MB)
[m3vpss ] 19395: SYSTEM : FREE SPACE : Frame Buffer = 105790336 B (100 MB)
[m3vpss ] 19396: SYSTEM : FREE SPACE : Bitstream Buffer = 62914432 B (59 MB)
[m3vpss ] 19396: SYSTEM : FREE SPACE : Tiler Buffer = 127 B (0 MB) - TILER OFF
[m3vpss ] Received character 't'
[m3vpss ] 19527: SYSTEM : Initializing Links ... DONE !!!
[m3video] Received character 't'
[c6xdsp ] Received character 't'
ApproDrvInit: 7
queue id:131076
DMA: Module install successful, device major num = 248
DRV: Module install successful
DRV: Module built on Dec 9 2013 19:10:37
_____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org DM8127_IPNC ttyO0
Arago 2011.09 DM8127_IPNC ttyO0
DM8127_IPNC login: root (automatic login)
root@DM8127_IPNC:~# HDMI W1 rev 4.0
HDMI CEC Spec version 1.2
I2C No Ack
[host]
[host] ORG 0x46c00524: 0
[host] NEW 0x46c00524: 2
[host]
[host] Application Start Completed
[host] 0: SYSTEM: System Common Init in progress !!!
[host] 0: SYSTEM: IPC init in progress !!!
[host] 21: SYSTEM: CPU [DSP] syslink proc ID is [0] !!!
[host] 21: SYSTEM: CPU [VIDEO-M3] syslink proc ID is [1] !!!
[host] 21: SYSTEM: CPU [VPSS-M3] syslink proc ID is [2] !!!
[host] 21: SYSTEM: CPU [HOST] syslink proc ID is [3] !!!
[host] 21: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[host] 22: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
[host] 24: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] DMA: ChannelID allocated:4
[host] DMA: ChannelID allocated:10
26: SYSTEM: Opening MsgQ [DSP_MSGQ] ...
[host] 26: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[host] 27: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[host] 28: SYSTEM: Notify register to [DSP] line 0, event 12 ...
[host] 29: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[host] 29: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[host] 30: SYSTEM: IPC init DONE !!!
[host] 31: SYSTEM: Creating ListMP [HOST_IPC_OUT_28] in region 0 ...
[host] 33: SYSTEM: Creating ListMP [HOST_IPC_IN_28] in region 0 ...
[host] 35: SYSTEM: ListElem Shared Addr = 0x40676180
[host] 35: SYSTEM: Creating ListMP [HOST_IPC_OUT_29] in region 0 ...
[host] 38: SYSTEM: Creating ListMP [HOST_IPC_IN_29] in region 0 ...
[host] 39: SYSTEM: ListElem Shared Addr = 0x4068fe00
[host] 41: SYSTEM: Creating ListMP [HOST_IPC_OUT_23] in region 0 ...
[host] 43: SYSTEM: Creating ListMP [HOST_IPC_IN_23] in region 0 ...
[host] 44: SYSTEM: ListElem Shared Addr = 0x406a9a80
[host] 45: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
[host] 47: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
[host] 49: SYSTEM: ListElem Shared Addr = 0x406c9480
[host] 50: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
[host] 52: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
[host] 53: SYSTEM: ListElem Shared Addr = 0x406e8e80
[host] 54: SYSTEM: System Common Init Done !!!
[host] Vsys_allocBuf - addr = 0x4d04e000,size = 65011712
[host] MCFW_IPCBITS:App_streamSysInit:virt addr of 85000000 cir buffer is 4d04e000
##########pInfo->totalsize 63897600
[host] MemMng_memcpy_open:OSA_dmaOpen passed with ch id = 4
[host] CacheMng_MemCpy_open:OSA_dmaOpen passed with ch id = 10
queue id:131076
queue id:65538
[host] MCFW_IPCBITS:App_ipcBitsRecvStreamFxn:Entered...
[host] MCFW_IPCFRAMES:App_ipcFramesSendRecvFxn:Entered...
[host] Before System_linkControl SYSTEM_M3VPSS_CMD_GET_DISPLAYCTRL_INIT
queue id:0
queue id:32769
[host]
********** FULL FEATURE USECASE ********
[host] ********* Entered Tri Streaming usecase - H264 1080p @60fps + H264 D1 @30fps + MJPE
G 1080p @5fps ********
[m3vpss ] VPS_DCTRL_INST_0
[m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_DVO2
[m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_HDMI
[m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_SD
[m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_CLK_SRC VPS_DC_VENC_HDMI | VPS_DC_VENC_DVO2
[host] 139: MCFW : CPU Revision [ES2.1] !!!
[host] 139: MCFW : Detected [UNKNOWN] Board !!!
[host] 139: MCFW : Base Board Revision [REV A] !!!
[m3vpss ] 27118: CAMERA: Create in progress !!!
[m3vpss ] 27118: CAMERA: VIP0 PortA camera mode is [ 8-bit, Non-mux Embedded Sync] !!!
[m3vpss ] 27122: CAMERA: VIP 0: VID DEC 268436744 (0x48): bebebebe:bebebebe:8ebd60d8, AUD
_STATUS -1094795586
[m3vpss ] Stream ID 0: chId = 0 VpsUtils_queCreate.
[m3vpss ] Stream ID 1: chId = 0 VpsUtils_queCreate.
[m3vpss ] 27334: CAMERA: Create Done !!!
[m3vpss ] 27423: CAMERA: Detect video in progress !!!
[m3vpss ] 27423: CAMERA: Detect video Done !!!
[m3vpss ] 27424: VNF:
[m3vpss ] Create in progress ... !!!
[m3vpss ] Input Channel CH0 of 1952 x 1112, pitch = (1984, 1984) [0,0][PROGRESSIVE] [7] ..
[m3vpss ] 27680: VNF:
[m3vpss ] Create ... DONE !!!
[m3vpss ] 27969: DUP : Create Done !!!
[m3vpss ] 27975: DUP : Create Done !!!
[m3vpss ] 27977: MERGE : Create Done !!!
[m3vpss ] DCC server task running
[m3vpss ] {SWOSD} edma3Handle->tccVal = 36
[m3vpss ] {SWOSD} edma3Handle->chId = 36
[m3vpss ] {SWOSD} edma3Handle->tccVal = 37
[m3vpss ] {SWOSD} edma3Handle->chId = 37
[m3vpss ] {SWOSD} edma3Handle->tccVal = 38
[m3vpss ] {SWOSD} edma3Handle->chId = 38
[m3vpss ] 27759: SWOSD : Create Done !!!
[m3vpss ] 28049: DUP : Create Done !!!
[m3vpss ] 28049: SCLR: Create in progress !!!
[m3vpss ] 28054: SCLR : Loading Up-scaling Co-effs ...
[m3vpss ] 28055: SCLR : Co-effs Loading ... DONE !!!
[m3video] 28062: IPC_IN_M3 : Create in progress !!!
[m3video] 28062: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ...
[m3vpss ] SCLR:HEAPID:0 USED:64
[m3video] 28062: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ...
[m3vpss ] SCLR:HEAPID:1 USED:5952
[m3video] 28066: IPC_IN_M3 : Create Done !!!
[m3vpss ] 28055: SCLR: Create Done !!!
[m3video] 28066: ENCODE: Create in progress ... !!!
[m3vpss ] 27776: FD : Alg Create Done !!!
[m3vpss ] 27776: FD : Create Done !!!
[m3vpss ] 28060: IPC_OUT_M3 : Create in progress !!!
[m3vpss ] 28061: IPC_OUT_M3 : Create Done !!!
[m3video] 28130: ENCODE: Creating CH0 of 1920 x 1080, pitch = (1952, 1952) [PROGRESSIVE]
[NON-TILED ], bitrate = 8000 Kbps ...
[m3video] ENCLINK_H264:HEAPID:0 USED:13808
[m3video] 28236: ENCODE: Creating CH1 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [NON
[host] IpcBitsInLink_tskMain:Entered
[host] 1092: IPC_BITS_IN : Create in progress !!!
[host] 1092: IPC_BITS_IN : ListMPOpen start !!!
[host] 1092: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_28] ...
[host] 1094: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_28] ...
[host] 1095: IPC_BITS_IN : ListMPOpen done !!!
[host] 1097: IPC_BITS_IN : System_linkGetInfo done !!!
[host] 1097: IPC_BITS_IN : Create Done !!!
[host] USECASE SETUP DONE
[m3video] ENCLINK_H264:HEAPID:0 USED:11912
[m3vpss ] 28360: DISPLAY: Create in progress !!!
[m3video] 28346: ENCODE: Creating CH2 of 1920 x 1080, pitch = (1952, 1952) [PROGRESSIVE]
[NON-TILED ], bitrate = 100 Kbps ...
[m3vpss ] DisplayId = 1,DataFormat = 7
[m3vpss ] SC2 displayInstId = 6
[m3vpss ] 28361: DISPLAY: Create Done !!!
[m3video] ENCLINK_JPEG:HEAPID:0 USED:4432
[m3vpss ] 28361: DISPLAY: Create in progress !!!
[m3video] 28347: ENCODE: All CH Create ... DONE !!!
[m3vpss ] DisplayId = 4,DataFormat = 7
[m3vpss ] SD displayInstId = 2
[m3vpss ] 28363: DISPLAY: Create Done !!!
[m3video] ENCLINK:HEAPID:0 USED:30472
[m3vpss ] 28364: DISPLAY: Start in progress !!!
[m3video] 28350: ENCODE: Create ... DONE !!!
[m3video] 24957: VSTAB : Alg Create Done !!!
[m3video] 24957: VSTAB : Create Done !!!
[m3video] 28351: IPC_BITS_OUT : Create in progress !!!
[m3video] 28354: IPC_BITS_OUT : Create Done !!!
[m3vpss ] 28400: DISPLAY: Start Done !!!
[m3vpss ] 28401: DISPLAY: AUX PATH: 54 fps, Latency (Min / Max) = ( 255 / 0 ), Callback I
nterval (Min / Max) = ( 255 / 0 ) !!!
[m3vpss ] 28401: DISPLAY: Start in progress !!!
[m3vpss ] 28464: DISPLAY: Start Done !!!
[m3vpss ] 28464: DISPLAY: SDDAC(SEC1): 15 fps, Latency (Min / Max) = ( 255 / 0 ), Callbac
k Interval (Min / Max) = ( 255 / 0 ) !!!
[m3vpss ] 28183: CAMERA: Start in progress !!!
[m3vpss ] 28183: CAMERA: Start Done !!!
[host]
Application Run Completed
[m3vpss ] 28356: CAMERA: Fields = 2 (fps = 0), Total Resets = 0 (Avg 0 ms per reset)
TimeOut occure in boot_proc.
Program exit.
[host] ITT server task running !!!
[host]
ITT ittServer_run
[host] ITT Server Message initialization successful
[host]
ITT capture task created
[host] DCC server Message ques is open succefully
[host] Setting cmd <1> in message <40490100>
[host] Posting message <40490100> in QId <20002>
[m3vpss ] Command 1 recived from HOST A8
[host] Response from M3 is : 1
[host] Default parameters were sent sucessfully
[host] Server Socket created with ID <22>
[host] MCFW_IPCBITS: Callback function:App_ipcBitsInCbFxn
[host] MCFW_IPCBITS:App_ipcBitsRecvStreamFxn:INFO: periodic print.. [m3vpss ] Command 2 re
cived from HOST A8
[m3video] Channel:1 inputframerate:30 targetfps:60
[m3vpss ] New DCC data of size <33603>
[m3vpss ] Call to VNF_LINK_CMD_UPDATE_DCC 536870977
[m3video] Channel:0 inputframerate:60 targetfps:60
[m3video] Channel:2 inputframerate:60 targetfps:5
Program exit.
[m3vpss ] 32976: DISPLAY: Stop in progress !!!
Venc not supported!!
[m3vpss ] 33036: DISPLAY: Stop Done !!!
[m3vpss ] 33039: DISPLAY: Start in progress !!!
[m3vpss ] 33089: DISPLAY: Start Done !!!
[m3vpss ] 33089: DISPLAY: SDDAC(SEC1): 2740 fps, Latency (Min / Max) = ( 1 / 109 ), Callb
ack Interval (Min / Max) = ( 33 / 34 ) !!!
[host] VNF MESSAGE RECIEVED: (Enable:0) (Mode:5) (Strength:0) (EnableTNF:0) (EnableSNF:0)
[host]
Channel Selected: 0
[host]
Channel Selected: 0,rate control = 0
[host]
Channel Selected: 0 [m3vpss ] 32828: VNF:
[m3vpss ] EnableSNF current SNF 0 => new 0!!!
[host]
Channel Selected: 0
[host]
Channel Selected: 0
[host]
Channel Selected: 0,packet size = 100
[host]
Channel Selected: 0,encPreset = 0
[host]
Channel Selected: 0,enable = 0
[host]
Channel Selected: 1
[host]
Channel Selected: 1,rate control = 0
[host]
Channel Selected: 1
[host]
Channel Selected: 1
[host]
Channel Selected: 1
[host]
Channel Selected: 1,packet size = 100
[host]
Channel Selected: 1,encPreset = 0
[host]
Channel Selected: 1,enable = 0
[host]
Channel Selected: 2
[host]
Channel Selected: 2,rate control = 2 [m3vpss ] 32828: VNF:
[m3vpss ] EnableTNF current TNF 0 => new 0!!!
[m3vpss ] ws_framerateParams->FrameRate = 30
[host] MJPEG in Rate Control OFF Mode
Check_device_version : DEVICE VER = 1 !!
[m3video] Channel:1 inputframerate:30 targetfps:30
[m3video] ENCLINK: new targetbitrate to set:2000000
[m3video] ENCLINK: new targetframerate to set:30000
[m3video] ENCLINK: new intraFrameInterval to set:30
[m3video] ENCLINK: new QP I Param to set:10 36 -1
[m3video] ENCLINK: new QP P Param to set:10 40 28
[m3video] ENCLINK: new PacketSize Param to set:100
[m3video] ENCLINK: new Encode Preset Param to set:0
[m3video] ENCLINK: new rate control algorithm to set:0
[m3video] Channel:0 inputframerate:30 targetfps:30
[m3video] Channel:2 inputframerate:30 targetfps:5
[m3video] ENCLINK: new targetbitrate to set:10000000
[m3video] ENCLINK: new intraFrameInterval to set:60
[m3video] JPGLINK: new targetframerate to set:5000 for bitrate 100000
[m3video] JPGLINK: new QP Param to set:1 51 80
[m3video] JPGLINK: new qualityFactor Param to set:80
[m3video] JPGLINK: new rate control algorithm to set:2 for bitrate: 100000
[m3video] JPGLINK: Run time parameters changed 0
Front Left: Capture 95 [80%] [47.50dB] [on]
Front Right: Capture 95 [80%] [47.50dB] [on]
Simple mixer control 'PCM',0
Capabilities: pvolume penum
Playback channels: Front Left - Front Right
Limits: Playback 0 - 127
Mono:
Front Left: Playback 101 [80%] [-13.00dB]
Front Right: Playback 101 [80%] [-13.00dB]
[host]
Force IDR on Channel: 0
[host]
Force IDR on Channel: 1SystemInit success
Schedule manager init success
Dmva Schedule manager init success
Error System server receive msg fail
ERROR:: Argument list too long
Recieved Quit event
Kill queue id:65538
Kill queue id:98307
Kill queue id:32769
ApproDrvExit: 7
Kill queue id:0
[09/Nov/2012:06:19:49 +0000] boa: server version Boa/0.94.13
[09/Nov/2012:06:19:49 +0000] boa: server built Dec 9 2013 at 19:05:19.
[09/Nov/2012:06:19:49 +0000] boa: starting server pid=441, port 80
[09/Nov/2012:06:20:21 +0000] caught SIGSEGV, dumping core in /tmp/nand
when running right the complete boot log is:
TI8148-GP rev 2.1
ARM clk: 600MHz
DDR clk: 400MHz
L3 clk: 200MHz
IVA clk: 450MHz
ISS clk: 400MHz
DSP Default OFF
DSS Default OFF
DRAM: 512 MiB
d
reading u-boot.bin
199528 bytes read
TI8148-GP rev 2.1
ARM clk: 600MHz
DDR clk: 400MHz
L3 clk: 200MHz
IVA clk: 450MHz
ISS clk: 400MHz
DSP Default OFF
DSS Default OFF
I2C: ready
DRAM: 512 MiB
256 MiB
.:;rrr;;.
:ihM#@@@@@##hs,
Date: 2012-11-09 (Friday) Time: 14:16:38
cpsw
reading uImage
2493132 bytes read
OK
Starting kernel ...
Machine: ti8148ipnc
NR_IRQS:375
GPMC revision 6.0
regulator: dummy:
PWM0 init success.
PWM1 init success.
Cppi41 Init Done
usb2phy: computed values rxcalib(15)DACs(30 12 14)
usb2phy: override computed values rxcalib(15)DACs(30 12 14)
usb2phy_config: musb(0) rxcalib done, rxcalib read value 6f6f5976
TCP reno registered
module/cmemk.c
cmemk initialized
brd: module loaded
loop: module loaded
ALSA device list:
#0: TI8148 IPNC
tps65911-rtc tps65911-rtc: setting system clock to 2012-11-09 14:16:46 UTC (1352470606)
mmcblk0: p1 p2
devtmpfs: mounted
Starting udev
inside finish.sh
UBI: max. sequence number: 115
UBI: background thread "ubi_bgt0d" started, PID 287
UBI: max. sequence number: 24
UBI: background thread "ubi_bgt1d" started, PID 299
: values=127,127
Trace enabled
/dev/mem opened.
00]
Creat queue id:0
queue id:0
queue id:32769
AlramThread created
queue id:65538
queue id:98307
queue id:32769
Starting telnet daemon inside autorun
[m3video]
[m3video]
[m3video] 89: SYSTEM : System Common Init in progress !!!
[m3video] 89: SYSTEM: IPC init in progress !!!
[m3video] 89: SYSTEM: Attaching to [HOST] ...
[m3vpss ]
[m3vpss ]
[m3vpss ] 133: SYSTEM : System Common Init in progress !!!
[m3vpss ] 134: SYSTEM: IPC init in progress !!!
[m3vpss ] 134: SYSTEM: Attaching to [HOST] ...
done
Volume ID is ff311e55, no volume label.
[m3video] 1088: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 1134: SYSTEM: Attaching to [HOST] ...
[m3video] 1092: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[m3vpss ] 1136: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[m3video] 1092: SYSTEM: Attaching to [DSP] ...
[m3vpss ] 1136: SYSTEM: Attaching to [DSP] ...
_____ _ _
|___| |___|
Arago Project http://arago-project.org dm814x-evm ttyO0
Arago 2011.09 dm814x-evm ttyO0
dm814x-evm login: root (automatic login)
[m3video] 2091: SYSTEM: Attaching to [DSP] ...
[m3vpss ] 2136: SYSTEM: Attaching to [DSP] ...
[m3video] 3091: SYSTEM: Attaching to [DSP] ...
[m3vpss ] 3136: SYSTEM: Attaching to [DSP] ...
[c6xdsp ]
[c6xdsp ]
[m3video] 4091: SYSTEM: Attaching to [DSP] ...
[m3vpss ] 4136: SYSTEM: Attaching to [DSP] ...
[m3video] 5091: SYSTEM: Attaching to [DSP] ...
[m3vpss ] 5136: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 2741: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[m3video] 6091: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 2741: SYSTEM: Attaching to [VPSS-M3] ...
[m3video] 6092: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
[m3video] 6092: SYSTEM: Attaching to [VPSS-M3] ...
[m3vpss ] 6136: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 3741: SYSTEM: Attaching to [VPSS-M3] ...
[m3video] 7091: SYSTEM: Attaching to [VPSS-M3] ...
[c6xdsp ] 3785: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[m3vpss ] 7136: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 3785: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3vpss ] 7136: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
[m3vpss ] 7136: SYSTEM: Attaching to [VIDEO-M3] ...
[m3video] 8091: SYSTEM: Attaching to [VPSS-M3] ...
[c6xdsp ] 4785: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3video] 8136: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[m3vpss ] 8136: SYSTEM: Attaching to [VIDEO-M3] ...
[m3video] 8137: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3vpss ] 8136: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[m3video] 8137: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
[m3vpss ] 8136: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3video] 8137: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
[m3vpss ] 8137: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
[m3vpss ] 8137: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
[m3video] 8139: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[m3vpss ] 8139: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[m3video] 8140: SYSTEM: Notify register to [DSP] line 0, event 12 ...
[m3vpss ] 8140: SYSTEM: Notify register to [DSP] line 0, event 12 ...
[m3video] 814g_file_storage gadget: No serial-number string provided!
0: SYSTEM: Notify register to [Vg_file_storage gadget: File-backed Storage Gadget, version:
1 September 2010
PSS-M3] line 0, g_file_storage gadget: Number of LUNs=1
event 12 ...
[m3vpss ] 8140: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[m3video] 8140: SYSTEM: IPC init DONE !!!
[m3vpss ] 8140: SYSTEM: IPC init DONE !!!
[m3video] 8150: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[m3vpss ] 8150: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[m3video] 8150: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03c00000 (60 MB)
[m3vpss ] 8150: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03c00000 (60 MB)
[m3video] 8153: SYSTEM : System Common Init Done !!!
[m3vpss ] 8152: SYSTEM : System Common Init Done !!!
root@dm814x-evm:~# [c6xdsp ] 5785: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[c6xdsp ] 5785: SYSTEM: Creating MsgQ [DSP_MSGQ] ...
[c6xdsp ] 5786: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ...
[c6xdsp ] 5786: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[c6xdsp ] 5786: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[c6xdsp ] 5786: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[c6xdsp ] 5787: SYSTEM: IPC init DONE !!!
[c6xdsp ] 5790: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[c6xdsp ] 5790: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03c00000 (60 MB)
queue id:65538
CPU is TI812x
[c6xdsp ] 5791: SYSTEM : System Common Init Done !!!
queue id:0
[c6xdsp ] 12989: SYSTEM : System DSP Init in progress !!!
[c6xdsp ] 12994: SYSTEM: Creating ListMP [DSP_IPC_OUT_23] in region 0 ...
[m3video] 16352: SYSTEM : System Video Init in progress !!!
[m3vpss ] 16353: SYSTEM : System VPSS Init in progress !!!
[c6xdsp ] 12995: SYSTEM: Creating ListMP [DSP_IPC_IN_23] in region 0 ...
[m3video] 16352: SYSTEM : System Video Init Done !!!
[c6xdsp ] 12995: SYSTEM: ListElem Shared Addr = 0xbe98b680
[m3video] 16353: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
[c6xdsp ] 12996: SYSTEM: Creating ListMP [DSP_IPC_OUT_24] in region 0 ...
[m3video] 16353: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
[c6xdsp ] 12996: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ...
[m3video] 16354: SYSTEM: ListElem Shared Addr = 0xbea1dd80
[c6xdsp ] 12996: SYSTEM: ListElem Shared Addr = 0xbe9ab080
[c6xdsp ] 12997: SYSTEM: Creating ListMP [DSP_IPC_OUT_25] in region 0 ...
[c6xdsp ] 12998: SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ...
[c6xdsp ] 12998: SYSTEM: ListElem Shared Addr = 0xbe9caa80
[c6xdsp ] 12999: SYSTEM: Creating ListMP [DSP_IPC_OUT_28] in region 0 ...
[c6xdsp ] 12999: SYSTEM: Creating ListMP [DSP_IPC_IN_28] in region 0 ...
[c6xdsp ] 12999: SYSTEM: ListElem Shared Addr = 0xbe9ea480
[c6xdsp ] 13000: SYSTEM: Creating ListMP [DSP_IPC_OUT_29] in region 0 ...
[c6xdsp ] 13000: SYSTEM: Creating ListMP [DSP_IPC_IN_29] in region 0 ...
[c6xdsp ] 13000: SYSTEM: ListElem Shared Addr = 0xbea04100
[c6xdsp ] 12999: SYSTEM : Initializing Links !!!
[c6xdsp ] 13001: SYSTEM : FREE SPACE : System Heap = 6282544 B, Mbx = 10240 msgs)
[m3video] 16356: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
[m3video] 16356: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
[m3video] 16357: SYSTEM: ListElem Shared Addr = 0xbea21280
[c6xdsp ] 13015: SYSTEM : Initializing Links ... DONE !!!
[m3video] 16368: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_28] in region 0 ...
[m3video] 16368: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_28] in region 0 ...
[m3vpss ] 16371: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
[c6xdsp ] 13015: SYSTEM : System DSP Init Done !!!
[m3video] 16368: SYSTEM: ListElem Shared Addr = 0xbea24780
[m3vpss ] 16372: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
[m3video] 16371: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_29] in region 0 ...
[m3vpss ] 16372: SYSTEM: ListElem Shared Addr = 0xbea3ea00
[m3video] 16372: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_29] in region 0 ...
[m3vpss ] 16375: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
[m3video] 16372: SYSTEM: ListElem Shared Addr = 0xbea41900
[m3vpss ] 16375: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
[m3video] 16374: HDVICP: Doing PRCM for IVAHD[0] ...
[m3vpss ] 16375: SYSTEM: ListElem Shared Addr = 0xbea5b580
[m3video] 16374: HDVICP: PRCM for IVAHD[0] ... DONE.
[m3video] 16375: SYSTEM : Initializing Links !!!
[m3video] 16375: SYSTEM : FREE SPACE : System Heap = 6282128 B, Mbx = 10240 msgs)
[m3video] 16376: SYSTEM : FREE SPACE : SR0 Heap = 15342464 B (14 MB)
[m3vpss ] 16391: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_23] in region 0 ...
[m3vpss ] 16391: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_23] in region 0 ...
[m3video] 16376: SYSTEM : FREE SPACE : Frame Buffer = 110100352 B (104 MB)
[m3vpss ] 16391: SYSTEM: ListElem Shared Addr = 0xbea5ea80
[m3vpss ] 16394: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_24] in region 0 ...
[m3video] 16376: SYSTEM : FREE SPACE : Bitstream Buffer = 62914432 B (59 MB)
[m3vpss ] 16394: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_24] in region 0 ...
[m3vpss ] 16395: SYSTEM: ListElem Shared Addr = 0xbea7e480
[m3video] 16376: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[m3video] 16377: SYSTEM : FREE SPACE : Tiler Buffer = 127 B (0 MB) - TILER OFF
[m3vpss ] 16398: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_25] in region 0 ...
[m3vpss ] 16398: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_25] in region 0 ...
[m3vpss ] 16398: SYSTEM: ListElem Shared Addr = 0xbea9de80
[m3vpss ] 16406: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_28] in region 0 ...
[m3vpss ] 16406: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_28] in region 0 ...
[m3vpss ] 16406: SYSTEM: ListElem Shared Addr = 0xbeabd880
[m3vpss ] 16409: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_29] in region 0 ...
[m3vpss ] 16409: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_29] in region 0 ...
[m3vpss ] 16409: SYSTEM: ListElem Shared Addr = 0xbead7500
[m3vpss ] 16412: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
[m3vpss ] 16412: SYSTEM : FVID2 Init in progress !!!
[m3video] 16434: SYSTEM : Initializing Links ... DONE !!!
[m3vpss ] 16478: SYSTEM : FVID2 Init in progress DONE !!!
[m3vpss ] 16478: SYSTEM : Device Init in progress !!!
[m3vpss ]
queue id:0
ApproDrvInit: 3
queue id:131076
[m3vpss ] 19214: SYSTEM : Device Init in progress DONE !!!
[m3vpss ] 19242: SYSTEM : System VPSS Init Done !!!
[m3vpss ] 19242: UTILS: DMA: HWI Create for INT62 !!!
[m3vpss ] 19242: SYSTEM : Initializing Links !!!
[m3vpss ] 19242: SYSTEM : FREE SPACE : System Heap = 1718872 B, Mbx = 10240 msgs)
[m3vpss ] 19242: SYSTEM : FREE SPACE : SR0 Heap = 14742656 B (14 MB)
[m3vpss ] 19242: SYSTEM : FREE SPACE : Frame Buffer = 105790336 B (100 MB)
[m3vpss ] 19243: SYSTEM : FREE SPACE : Bitstream Buffer = 62914432 B (59 MB)
[m3vpss ] 19243: SYSTEM : FREE SPACE : Tiler Buffer = 127 B (0 MB) - TILER OFF
[m3vpss ] 19374: SYSTEM : Initializing Links ... DONE !!!
ApproDrvInit: 7
queue id:131076
Program exit.
HDMI W1 rev 4.0
I2C No Ack
[host]
[host]
Program exit.
[host] 600: SYSTEM: CPU [DSP] syslink proc ID is [0] !!!
[host] 601: SYSTEM: CPU [VIDEO-M3] syslink proc ID is [1] !!!
[host] 601: SYSTEM: CPU [VPSS-M3] syslink proc ID is [2] !!!
[host] 601: SYSTEM: CPU [HOST] syslink proc ID is [3] !!!
[host] 601: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[host] 602: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
[host] 604: SYSTEM: Creating MsgQ [HOST_ACKDMA: ChannelID allocated:4
_MSGQ] ...
[host] 606: SYSTEM: Opening MsgQ [DSP_MSGQ] ...
[host] 606: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[host] 607: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[host] 608: SYSTEM: Notify register to [DSP] line 0, event 12 ...
[host] 608: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[host] 609: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[host] 609: SYSTEM: IPC init DONE !!!
[host] 611: SYSTEM: Creating ListMP [HOST_IPC_OUT_28] in region 0 ...
[host] 613: SYSTEM: Creating ListMP [HOST_IPC_IN_28] in region 0 ...
[host] 614: SYSTEM: ListElem Shared Addr = 0x405d8180
[host] 615: SYSTEM: Creating ListMP [HOST_IPC_OUT_29] in region 0 ...
[host] 617: SYSTEM: Creating ListMP [HOST_IPC_IN_29] in region 0 ...
[host] 618: SYSTEM: ListElem Shared Addr = 0x405f1e00
[host] 620: SYSTEM: Creating ListMP [HOST_IPC_OUT_23] in region 0 ...
[host] 622: SYSTEM: Creating ListMP [HOST_IPC_IN_23] in region 0 ...
[host] 624: SYSTEM: ListElem Shared Addr = 0x4060ba80
[host] 624: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
[host] 626: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
[host] 628: SYSTEM: ListElem Shared Addr = 0x4062b480
[host] 629: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
[host] 631: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
[host] 632: SYSTEM: ListElem Shared Addr = 0x4064ae80
[host] 633: SYSTEM: System Common Init Done !!!
[host] Vsys_allocBuf - addr = 0x4d072000,size = 65011712
[host] MCFW_IPCBITS:App_streamSysInit:virt addr of 85000000 cir buffer is 4d072000
queue id:131076
queue id:65538
[host]
[host] 723: MCFW : CPU Revision [ES2.1] !!!
[host] 723: MCFW : Detected [UNKNOWN] Board !!!
[host] 723: MCFW : Base Board Revision [REV A] !!!
[m3vpss ] 37256: CAMERA: Create in progress !!!
[m3vpss ] 37256: CAMERA: VIP0 PortA camera mode is [ 8-bit, Non-mux Embedded Sync] !!!
[m3vpss ] 37259: CAMERA: VIP 0: VID DEC 268436744 (0x48): bebebebe:bebebebe:8ebd60d8, AUD
_STATUS -1094795586
[m3vpss ] 37472: CAMERA: Create Done !!!
[m3vpss ] 37561: CAMERA: Detect video in progress !!!
[m3vpss ] 37561: CAMERA: Detect video Done !!!
[m3vpss ] 37561: VNF:
[m3vpss ] 37562: VNF:
queue id:0
queue id:32769
[m3vpss ] 37817: VNF:
[m3vpss ] 37955: DUP : Create Done !!!
[m3vpss ] 37962: DUP : Create Done !!!
[m3vpss ] 37964: MERGE : Create Done !!!
[m3vpss ] 37896: SWOSD : Create Done !!!
[m3vpss ] 38034: DUP : Create Done !!!
[m3vpss ] 38034: SCLR: Create in progress !!!
[m3video] 38047: IPC_IN_M3 : Create in progress !!!
[m3vpss ] 38040: SCLR : Loading Up-scaling Co-effs ...
[m3video] 38047: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ...
[m3vpss ] 38040: SCLR : Co-effs Loading ... DONE !!!
[m3video] 38048: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ...
[m3video] 38051: IPC_IN_M3 : Create Done !!!
[m3video] 38051: ENCODE: Create in progress ... !!!
[m3vpss ] 38040: SCLR: Create Done !!!
[m3vpss ] 37913: FD : Alg Create Done !!!
[m3vpss ] 37913: FD : Create Done !!!
[m3vpss ] 38045: IPC_OUT_M3 : Create in progress !!!
[m3vpss ] 38046: IPC_OUT_M3 : Create Done !!!
[m3video] 38115: ENCODE: Creating CH0 of 1920 x 1080, pitch = (1952, 1952) [PROGRESSIVE]
[m3video] 38221: ENCODE: Creating CH1 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [NON
[host] 1674: IPC_BITS_IN : Create in progress !!!
[host] 1674: IPC_BITS_IN : ListMPOpen start !!!
[host] 1674: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_28] ...
[host] 1676: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_28] ...
[host] 1677: IPC_BITS_IN : ListMPOpen done !!!
[host] 1679: IPC_BITS_IN : System_linkGetInfo done !!!
[host] 1679: IPC_BITS_IN : Create Done !!!
[m3vpss ] 38344: DISPLAY: Create in progress !!!
[m3video] 38330: ENCODE: Creating CH2 of 1920 x 1080, pitch = (1952, 1952) [PROGRESSIVE]
[m3vpss ] 38345: DISPLAY: Create Done !!!
[m3vpss ] 38345: DISPLAY: Create in progress !!!
[m3video] 38331: ENCODE: All CH Create ... DONE !!!
[m3vpss ] 38346: DISPLAY: Create Done !!!
[m3vpss ] 38348: DISPLAY: Start in progress !!!
[m3video] 38334: ENCODE: Create ... DONE !!!
[m3video] 38247: VSTAB : Alg Create Done !!!
[m3video] 38247: VSTAB : Create Done !!!
[m3video] 38335: IPC_BITS_OUT : Create in progress !!!
[m3video] 38337: IPC_BITS_OUT : Create Done !!!
[m3vpss ] 38386: DISPLAY: Start Done !!!
[m3vpss ] 38387: DISPLAY: AUX PATH: 51 fps, Latency (Min / Max) = ( 255 / 0 ), Callback I
[m3vpss ] 38387: DISPLAY: Start in progress !!!
[m3vpss ] 38451: DISPLAY: Start Done !!!
[m3vpss ] 38451: DISPLAY: SDDAC(SEC1): 15 fps, Latency (Min / Max) = ( 255 / 0 ), Callbac
[m3vpss ] 38321: CAMERA: Start in progress !!!
[m3vpss ] 38321: CAMERA: Start Done !!!
[host]
[m3vpss ] 38489: CAMERA: Fields = 2 (fps = 0), Total Resets = 0 (Avg 0 ms per reset)
[host]
ITT ittServer_run
[host]
[host] Setting cmd <1> in message <403f2100>
[host] Posting message <403f2100> in QId <20002>
[host] MCFW_IPCBITS:App_ipcBitsRecvStreamFxn:INFO: periodic print.. [m3video] Channel:1 i
[m3vpss ] Command 2 recived from HOST A8
[m3vpss ] 42973: DISPLAY: Stop in progress !!!
[m3vpss ] 43022: DISPLAY: Stop Done !!!
[m3vpss ] 43025: DISPLAY: Start in progress !!!
[m3vpss ] 43075: DISPLAY: Start Done !!!
[m3vpss ] 43075: DISPLAY: SDDAC(SEC1): 2760 fps, Latency (Min / Max) = ( 1 / 109 ), Callb
[host]
Channel Selected: 0
[host]
[host]
Channel Selected: 0
[host]
Channel Selected: 0
[host]
Channel Selected: 0
[host]
[host]
Channel Selected: 0,encPreset = 0 [m3vpss ] 42960: VNF:
[host]
[host]
Channel Selected: 1
[host]
[host]
Channel Selected: 1
[host]
Channel Selected: 1
[host]
Channel Selected: 1
[host]
[host]
[host]
[host]
Channel Selected: 2
[host]
[m3vpss ] 42961: VNF:
Mono:
[host]
[host]
umount: can't umount /mnt/mmc: Invalid argument
mount: mounting /dev/mmcblk0 on /mnt/mmc failed: Device or resource busy
killall: dhcpcd: no process killed
rm: cannot remove '/var/run/dhcpcd-eth0.pid': No such file or directory
net_search_gateway:eth0, FDA8C0, 0, 1
dns=192.168.253.1
net_search_gateway:eth0, 0, FEFDA8C0, 3
dns=192.168.253.1
[09/Nov/2012:06:17:38 +0000] boa: server version Boa/0.94.13
[09/Nov/2012:06:17:38 +0000] boa: server built Dec 9 2013 at 19:05:19.
[09/Nov/2012:06:17:38 +0000] boa: starting server pid=501, port 80
queue id:0
<UDN>uuid:Upnp-TVEmulator-1_0-00_0015610453</UDN>
Upnp port is 0
UPnP Initialized OK ip=192.168.253.168, port=0
desc_doc_url = http://192.168.253.168/tvdevicedesc.xml
error code = 0
ApproDrvInit: 10
queue id:131076
Initializing...
ApproDrvInit: 2
queue id:131076
Initializing...
ApproDrvInit: 6
ApproDrvInit: 8
queue id:131076
Initializing...
ApproDrvInit: 9
queue id:131076
...done initializing
Play this stream using the URL:
rtsp://192.168.253.168:8557/PSIA/Streaming/channels/2?videoCodecType=H.264
(We use port 8304 for optional RTSP-over-HTTP tunneling.)
rtsp://192.168.253.168:8553/PSIA/Streaming/channels/1?videoCodecType=MPEG4
(We use port 8300 for optional RTSP-over-HTTP tunneling.)
Initializing...
rtsp://192.168.253.168:8556/PSIA/Streaming/channels/2?videoCodecType=H.264
(We use port 8303 for optional RTSP-over-HTTP tunneling.)
queue id:131076
Initializing...
rtsp://192.168.253.168:8554/PSIA/Streaming/channels/1?videoCodecType=MPEG4
(We use port 8301 for optional RTSP-over-HTTP tunneling.)
rtsp://192.168.253.168:8555/PSIA/Streaming/channels/0?videoCodecType=MJPEG
(We use port 8302 for optional RTSP-over-HTTP tunneling.)
device advertisement succeed.
[09/Nov/2012:06:18:27 +0000] request from 192.168.253.103 "GET /tvcontrolSCPD.xml HTTP/1.1"
("/var/www/tvcontrolSCPD.xml"): document open: No such file or directory
[09/Nov/2012:06:18:27 +0000] request from 192.168.253.103 "GET /tvpictureSCPD.xml HTTP/1.1"
("/var/www/tvpictureSCPD.xml"): document open: No such file or directory
[09/Nov/2012:06:18:27 +0000] request from 192.168.253.146 "GET /tvcontrolSCPD.xml HTTP/1.1"
[09/Nov/2012:06:18:27 +0000] request from 192.168.253.146 "GET /tvpictureSCPD.xml HTTP/1.1"
