How to set PAL in dvrrdk with linkapi
i have read the follow discussion,but it still can not work.
And if plug the video signal in before the application start, there is no video on the screen.
http://e2e.ti.com/support/dsp/davinci_digital_media_processors/f/717/p/222543/787692.aspx#787692
here is my usercase :
capture--->dei--->displayt ,
the signal is connected at vip1_portA. with BT.656 (PAL). 8bit mode.
My platform is DVRRDK_03.00.00.00, Would you please tell me how to modify to PAL mode, thanks!
here is my usercase code,please help me correct the follow code
 CaptureLink_CreateParams capturePrm;
 CaptureLink_VipInstParams *pCaptureInstPrm;
 CaptureLink_OutParams       *pCaptureOutPrm;
    DeiLink_CreateParams        deiPrm;
 DisplayLink_CreateParams displayPrm;
 UInt32 captureId,vipInstId;
 UInt32 displayId;
    UInt32 deiId;
 UInt32 i;
 CHAINS_INIT_STRUCT(CaptureLink_CreateParams,capturePrm);
 CHAINS_INIT_STRUCT(DisplayLink_CreateParams,displayPrm);
    CHAINS_INIT_STRUCT(DeiLink_CreateParams,deiPrm);
 captureId   = SYSTEM_LINK_ID_CAPTURE;
 displayId  = SYSTEM_LINK_ID_DISPLAY_1;
    deiId           = SYSTEM_LINK_ID_DEI_1;
    printf("%s\n",__func__);
 for(i = 0; i < gChains_ctrl.chRecNum; i++)
  gChains_ctrl.chCfg[i + gChains_ctrl.chCapNum].channel = i;
 /* Capture */
 if(chainsCfg->chCapNum > 0)
  capturePrm.numVipInst = chainsCfg->chCapNum;
  capturePrm.tilerEnable = FALSE;
  capturePrm.numBufsPerCh = 16;
  capturePrm.numExtraBufs = 0;
  capturePrm.maxBlindAreasPerCh = 0;
  capturePrm.isPalMode = TRUE;
  capturePrm.enableSdCrop = FALSE;
  capturePrm.doCropInCapture = FALSE;
  for(i = 0; i< capturePrm.numVipInst; i++)
   vipInstId = SYSTEM_CAPTURE_INST_VIP1_PORTA + 2*gChains_ctrl.chCfg[i].channel;
   pCaptureInstPrm      = &capturePrm.vipInst[i];
   pCaptureInstPrm->vipInstId   = vipInstId%SYSTEM_CAPTURE_INST_MAX;
   pCaptureInstPrm->videoDecoderId  = SYSTEM_DEVICE_VID_DEC_ADV7401_DRV;
   pCaptureInstPrm->inDataFormat  = SYSTEM_DF_YUV422P;
   pCaptureInstPrm->standard   = VSYS_STD_PAL;
   pCaptureInstPrm->numOutput   = 1;
   pCaptureInstPrm->numChPerOutput  = 0;
   pCaptureInstPrm->frameCaptureMode  = FALSE;
   pCaptureInstPrm->fieldsMerged  = FALSE;
   pCaptureOutPrm      = &pCaptureInstPrm->outParams[0];
   pCaptureOutPrm->dataFormat   = SYSTEM_DF_YUV422I_YUYV;
   pCaptureOutPrm->scEnable   = FALSE;
            pCaptureOutPrm->scOutWidth          = 0;
            pCaptureOutPrm->scOutHeight         = 0;
   pCaptureOutPrm->outQueId   = 0;
  capturePrm.outQueParams[0].nextLink  = deiId;
        deiPrm.inQueParams.prevLinkId  = captureId;
        deiPrm.inQueParams.prevLinkQueId = 0;
        deiPrm.outQueParams[DEI_LINK_OUT_QUE_DEI_SC].nextLink  = displayId;
        deiPrm.enableOut[DEI_LINK_OUT_QUE_DEI_SC]               = TRUE;
        deiPrm.tilerEnable[DEI_LINK_OUT_QUE_VIP_SC]          = FALSE;
        deiPrm.comprEnable                                   = FALSE;
        deiPrm.setVipScYuv422Format                          = FALSE;
        deiPrm.enableDeiForceBypass                          = FALSE;
        deiPrm.enableLineSkipSc                              = FALSE;
        deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_DEI_SC][0].scaleMode = DEI_SCALE_MODE_RATIO;
        deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_DEI_SC][0].ratio.widthRatio.numerator    = 1;
        deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_DEI_SC][0].ratio.widthRatio.denominator  = 1;
        deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_DEI_SC][0].ratio.heightRatio.numerator   = 1;
        deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_DEI_SC][0].ratio.heightRatio.denominator = 1;
 /* Dis */
 if(chainsCfg->chRecNum > 0)
  for(i = chainsCfg->chCapNum; i < chainsCfg->chNum; i++)
   chainsCfg->displayRes[i - chainsCfg->chCapNum] = chainsCfg->displayRes[i];
  Chains_displayCtrlInit(chainsCfg->displayRes);
  displayPrm.numInputQueues    = 1;
  displayPrm.activeQueue     = 0;
  displayPrm.inQueParams[0].prevLinkId = deiId;
  displayPrm.inQueParams[0].prevLinkQueId = 0;
  displayPrm.displayRes     = chainsCfg->displayRes[0];
        displayPrm.forceFieldSeparatedInputMode = FALSE;
  * Create Links
  System_linkCreate(captureId, &capturePrm,sizeof(capturePrm));
        System_linkCreate(deiId,&deiPrm,sizeof(deiPrm));
  System_linkCreate(displayId,&displayPrm,sizeof(displayPrm));
  * Start Links
  System_linkStart(displayId);
        System_linkStart(deiId);
  System_linkStart(captureId);
 int osdfd;
 int flag = 0;
 osdfd = exbutton_open("/dev/input/event0",O_RDONLY);
 if(osdfd < 0)
  printf("ERROR:open osd key device error !!!\n");
 while(1)
  int ch;
#if 0
  ch =  get_layout(osdfd,4);
  if(ch == 0)
   close(osdfd);
   break;
#endif
        ch = Chains_menuRunTime();
        if(ch=='0')
            break;
        if(ch=='v')
            System_linkControl(captureId, CAPTURE_LINK_CMD_FORCE_RESET, NULL, 0, TRUE);
        if(ch=='p') {
            System_linkControl(captureId, CAPTURE_LINK_CMD_PRINT_ADV_STATISTICS, NULL, 0, TRUE);
            System_linkControl(deiId, DEI_LINK_CMD_PRINT_STATISTICS, NULL, 0, TRUE);
            System_linkControl(displayId, DISPLAY_LINK_CMD_PRINT_STATISTICS, NULL, 0, TRUE);
  * Stop Links
  System_linkStop(captureId);
        System_linkStop(deiId);
  System_linkStop(displayId);
  * Delete Links
  System_linkDelete(captureId);
        System_linkDelete(deiId);
  System_linkDelete(displayId);
 Chains_displayCtrlDeInit();
#if defined(__cplusplus)
#endif
