AM335x USB
    I am working in Beagle Bone Black
   I downloaded pre built images from the following website
app.box.com/s/4u7fgvnsfwhutyf0ngte
 I booted the board with the same files but I am getting some I2C write failed and active sync is not getting connect, Please guide me and need some guidelines for connecting the device through active sync in Windows 7(I am using Windows Mobile Device Center) I am pasting the logs below please check it out
ÑåUéÉÕÕ%%5)MåÍѵÉå5)A?E?¹½É½Ý¹±½¹¹¹5)%9=éA?½Ý¹±½¹¹¹¹5)%¹¥Ñ!]?½¹Ñ?±±?IMQ5)ÿSDCARD: requested speed 1000000, actual speed 1000000
SDCARD: requested speed 25000000, actual speed 19200000
BLSDCardReadCfg:  cannot open eboot.cfg
BLReadBootCfg returns error
WARN: Boot config wasn't found, using defaults
INFO: SW3 boot setting: 0x18
BLSDCardReadLogo:  cannot open logo.bmp
>>> Forcing cold boot (non-persistent registry and other data will be wiped) <<<
ab30a0c8 8616 -> c8 a0 30 ab 16 86
ab30a0c8 8816 -> c8 a0 30 ab 16 88
Hit space to enter configuration menu 3...
Hit space to enter configuration menu 2...
 Main Menu
 [1] Show Current Settings
 [2] Select Boot Device
 [3] Select KITL (Debug) Device
 [4] Network Settings
 [5] SDCard Settings
 [6] Set Device ID
 [7] Save Settings
 [9] Enable/Disable OAL Retail Messages
 [a] Select Display Resolution
 [b] Select OPP Mode
 [0] Exit and Continue
 Selection: 3
 Select Debug Device
 [1] Internal EMAC
 Selection (actual Internal EMAC): 0
 Main Menu
 [5] SDCard Settings
 [6] Set Device ID
 [7] Save Settings
 [b] Select OPP Mode
 Selection: 4
 Network Settings
 [2] Enable/disable KITL
 [3] KITL interrupt/poll mode
 [4] KITL Active/Passive mode
 [5] Enable/disable DHCP
 [6] Set IP address
 [7] Set IP mask
 [8] Set default router
 [9] Enable/disable VMINI
 [a] Set MAC address
 [b] Set MAC address 1
 Selection: 2
 Disable KITL (actually enabled) [y/-]: y
 KITL disabled
 Network Settings
 [6] Set IP address
 [7] Set IP mask
 [a] Set MAC address
 Selection: 9
 Disable VMINI (actually enabled) [y/-]: y
 VMINI disabled
 Network Settings
 [6] Set IP address
 [7] Set IP mask
 [a] Set MAC address
 Selection: 5
 Disable DHCP (actually enabled) [y/-]: y
 DHCP disabled
 Network Settings
 [6] Set IP address
 [7] Set IP mask
 [a] Set MAC address
 Selection: 0
 Main Menu
 [5] SDCard Settings
 [6] Set Device ID
 [7] Save Settings
 [b] Select OPP Mode
 Selection: 2
 Select Boot Device
 [1] Internal EMAC
 [2] NK from SDCard FILE
 Selection (actual NK from SDCard FILE ): 2
 Boot device set to NK from SDCard FILE
 Main Menu
 [5] SDCard Settings
 [6] Set Device ID
 [7] Save Settings
 [b] Select OPP Mode
 Selection: 0
OEMPreDownload: Filename nk.bin
BL_IMAGE_TYPE_BIN
+OEMMultiBinNotify(0x8feb24b8 -> 1)
Download file information:
[0]: Address=0x80002000  Length=0x0425f3c4  Save=0x80002000
Download file type: 1
+OEMIsFlashAddr(0x80002000) g_eboot.type 1
...............................................................................................................................................................................................................................................................................................................................rom_offset=0x0.
..ImageStart = 0x80002000, ImageLength = 0x425f3c4, LaunchAddr = 0x8000ac60
Completed file(s):
[0]: Address=0x80002000  Length=0x425f3c4  Name="" Target=RAM
ROMHDR at Address 80002044h
Launch Windows CE image by jumping to 0x8000ac60...
Windows CE Kernel for ARM (Thumb Enabled)
+OALTimerInit(1, 24000, 200)
--- High Performance Frequecy is 24 MHz---
PID:00400002 TID:00410002 SetOpp to 3
PID:00400002 TID:019C001A BEEPDev: BEEP_Init
PID:00400002 TID:019C001A Cpsw3g_InitializeAdapter: mode=1, port=1, txCh=0, rxChMask=0x01, ActiveCpgmac=1
PID:00400002 TID:019C001A +EnableHPOut_PLL fs_ref=48kHz, sample_rate_div=1 (0x00), lVol=0x00, rVol=0x00
PID:00400002 TID:019C001A Write: Attempts = 2
PID:00400002 TID:019C001A Write: Attempts = 3
PID:00400002 TID:019C001A Write: Attempts = 4
PID:00400002 TID:019C001A Write: Attempts = 5
PID:00400002 TID:019C001A WARN: I2C: Write failed (SA=0x1B, register=0x00000000)
PID:00400002 TID:02730002 _cpsw3g_phy_update_link, Port:0  LINK:UP  SPEED:100  DUPLEX:FD
PID:00400002 TID:019C001A WARN: I2C: Write failed (SA=0x1B, register=0x00000001)
PID:00400002 TID:019C001A WARN: I2C: Write failed (SA=0x1B, register=0x00000002)
PID:00400002 TID:019C001A WARN: I2C: Write failed (SA=0x1B, register=0x00000003)
PID:00400002 TID:019C001A WARN: I2C: Write failed (SA=0x1B, register=0x00000004)
PID:00400002 TID:019C001A WARN: I2C: Write failed (SA=0x1B, register=0x00000005)
PID:00400002 TID:019C001A WARN: I2C: Write failed (SA=0x1B, register=0x00000006)
PID:00400002 TID:019C001A WARN: I2C: Write failed (SA=0x1B, register=0x00000007)
PID:00400002 TID:019C001A WARN: I2C: Write failed (SA=0x1B, register=0x00000008)
PID:00400002 TID:019C001A WARN: I2C: Write failed (SA=0x1B, register=0x00000009)
PID:00400002 TID:019C001A WARN: I2C: Write failed (SA=0x1B, register=0x0000000A)
PID:00400002 TID:019C001A WARN: I2C: Write failed (SA=0x1B, register=0x0000000B)
PID:00400002 TID:019C001A WARN: I2C: Write failed (SA=0x1B, register=0x0000000F)
PID:00400002 TID:019C001A WARN: I2C: Write failed (SA=0x1B, register=0x00000010)
PID:00400002 TID:019C001A WARN: I2C: Write failed (SA=0x1B, register=0x00000013)
PID:00400002 TID:019C001A WARN: I2C: Write failed (SA=0x1B, register=0x00000016)
PID:00400002 TID:019C001A WARN: I2C: Write failed (SA=0x1B, register=0x0000001B)
PID:00400002 TID:019C001A WARN: I2C: Write failed (SA=0x1B, register=0x0000001E)
PID:00400002 TID:019C001A WARN: I2C: Write failed (SA=0x1B, register=0x00000025)
PID:00400002 TID:019C001A WARN: I2C: Write failed (SA=0x1B, register=0x00000026)
PID:00400002 TID:019C001A WARN: I2C: Write failed (SA=0x1B, register=0x0000002B)
PID:00400002 TID:019C001A WARN: I2C: Write failed (SA=0x1B, register=0x0000002C)
PID:00400002 TID:019C001A WARN: I2C: Write failed (SA=0x1B, register=0x0000002F)
PID:00400002 TID:019C001A WARN: I2C: Write failed (SA=0x1B, register=0x00000033)
PID:00400002 TID:019C001A WARN: I2C: Write failed (SA=0x1B, register=0x00000040)
PID:00400002 TID:019C001A WARN: I2C: Write failed (SA=0x1B, register=0x00000041)
PID:00400002 TID:019C001A WARN: I2C: Write failed (SA=0x1B, register=0x00000052)
PID:00400002 TID:019C001A WARN: I2C: Write failed (SA=0x1B, register=0x00000056)
PID:00400002 TID:019C001A WARN: I2C: Write failed (SA=0x1B, register=0x0000005C)
PID:00400002 TID:019C001A WARN: I2C: Write failed (SA=0x1B, register=0x0000005D)
PID:00400002 TID:019C001A WARN: I2C: Write failed (SA=0x1B, register=0x0000003A)
PID:00400002 TID:019C001A WARN: I2C: Write failed (SA=0x1B, register=0x00000048)
PID:00400002 TID:019C001A WARN: I2C: Write failed (SA=0x1B, register=0x00000065)
PID:00400002 TID:019C001A WARN: I2C: Write failed (SA=0x1B, register=0x00000066)
PID:00400002 TID:019C001A WARN: I2C: Write failed (SA=0x1B, register=0x00000011)
PID:00400002 TID:019C001A WARN: I2C: Write failed (SA=0x1B, register=0x00000012)
PID:00400002 TID:019C001A WARN: I2C: Write failed (SA=0x1B, register=0x00000019)
PID:00400002 TID:019C001A SDHC: CPU revision 0xffffffff
PID:00400002 TID:019C001A SDHC host controller initialize: m_fastPathSDIO:1 m_fastPathSDMEM:0
PID:00400002 TID:019C001A SDHC host controller initialize: m_fastPathSDIO:1 m_fastPathSDMEM:1
PID:00400002 TID:019C001A CAM3xxOTG::Init DEVCTL 80
PID:00400002 TID:019C001A CAM3xxOTG::Init DEVCTL 98
PID:00400002 TID:0106001E Write: Attempts = 2
PID:00400002 TID:019C001A CAM3xxOTG[1]::FunctionMode(): entering function mode
PID:00400002 TID:0106001E Write: Attempts = 3
PID:00400002 TID:04660002 PVR:getCpuFamily: 5
PID:00400002 TID:04660002 PVR:omapsgxddgpe getCpuFamily: 5
PID:00400002 TID:0106001E Write: Attempts = 4
PID:00400002 TID:020B0002 Exception 'Data Abort' (0x4): Thread-Id=020b0002(pth=9e81f9c0), Proc-Id=00400002(pprc=8427e5e0) 'NK.EXE', VM-active=05910002(pprc=9e861270) 'GweUser.exe'
PID:00400002 TID:020B0002 PC=efd90ad8(gwes.dll+0x00030ad8) RA=efdb25b0(gwes.dll+0x000525b0) SP=aadefdb0, BVA=00000000
PID:00400002 TID:0106001E Write: Attempts = 5
PID:00400002 TID:0106001E WARN: I2C: Write failed (SA=0x1B, register=0x0000002B)
PID:00400002 TID:04660002 Write: Attempts = 2
PID:00400002 TID:04660002 Write: Attempts = 3
PID:00400002 TID:04660002 Write: Attempts = 4
PID:00400002 TID:04660002 Write: Attempts = 5
PID:00400002 TID:04660002 WARN: I2C: Write failed (SA=0x38, register=0x00000000)
PID:00400002 TID:04660002 PddInitializeHardware-
PID:00400002 TID:0106001E WARN: I2C: Write failed (SA=0x1B, register=0x0000002C)
Thanks in advance
Sinthu Raja
