Other Parts Discussed in Thread: DM3725, DM3730
I have two questions :
Is it possible to run dm3725 at and hybrid opp for instance with ARM @ OPP130 and DSP @ OPP100, or the opposite : ARM@OPP100 and DSP@OPP130. VMPU is set to the required OPP130 voltage.
Is it possible to lift the Tj < 90 °C constraint by running such an hybrid OPP ? In other word, can I for instance run the DSP at 520 MHz, the ARM at 800 MHz, and let the junction temperature go up to 105 ?
