Other Parts Discussed in Thread: TVP5158, TPS40400, PMP
Dear all,
I am trying to execute RDK applications on DM8168 DVR from udworks. I did not change the kernel and try to follow the instructions for execution of applications in install guide.
My environment in UBOOT is:
I2C: ready
DRAM: 2 GiB
NAND: HW ECC BCH8 Selected
256 MiB
MMC: OMAP SD/MMC: 0
Net: Ethernet PHY: GENERIC @ 0x01
DaVinci EMAC
Hit any key to stop autoboot: 3 0
UBOOT # printenv
baudrate=115200
autoload=no
ntpserverip=192.168.1.231
timeoffset=32400
ethact=DaVinci EMAC
filesize=2880000
logoreadaddr=0x81000000
ethaddr1=44:aa:27:00:04:d7
eth1addr=44:aa:27:00:04:d7
gatewayip=10.0.0.138
netmask=255.255.255.0
ipaddr=10.0.0.56
dnsip=10.0.0.138
bootdelay=3
serverip=10.0.0.46
bootcmd=nand read ${logoreadaddr} 0x280000 0x300000; logo on $(logoreadaddr} 0xA0000000 0x81600000 40 60; nand read 0x81000000 0x00580000 0x300000; bootm 0x81000000
bootargs=mem=256M console=ttyO2,115200n8 noinitrd rw ubi.mtd=4,2048 rootfstype=ubifs root=ubi0:rootfs ip=dhcp vram=20M notifyk.vpssm3_sva=0xBEE00000 ddr_mem=1024M
stdin=serial
stdout=serial
stderr=serial
ethaddr=44:aa:27:00:04:d6
hwver=00:80
ver=U-Boot 2010.06 (Jun 25 2013 - 17:00:09)
Once the linux is booted I follow the instructions in install guide:
root@dvr:~# cd /oroot@dvr:~# cd /opt/root@dvr:~# cd /opt/dvr_rdk/root@dvr:~# cd /opt/dvr_rdk/ti816x/root@dvr:~# cd /opt/dvr_rdk/ti816x/
root@dvr:/opt/dvr_rdk/ti816x# ./iniroot@dvr:/opt/dvr_rdk/ti816x# ./init.sh
*** Bootargs Validated for mem param ***
*** Bootargs Validated for notifyk.vpssm3 params ***
Kernel bootargs validated
numid=101,iface=MIXER,name='Left DAC Mux'
; type=ENUMERATED,access=rw------,values=1,items=3
; Item #0 'DAC_L1'
; Item #1 'DAC_L3'
; Item #2 'DAC_L2'
: values=2
numid=99,iface=MIXER,name='Right DAC Mux'
; Item #0 'DAC_R1'
; Item #1 'DAC_R3'
; Item #2 'DAC_R2'
: values=2
[c6xdsp ] Remote Debug Shared Memory @ 0xbf000000
[m3video] Remote Debug Shared Memory @ 0xbf005020
[m3vpss ] Remote Debug Shared Memory @ 0xbf00a040
plughw:0,1: underrun !!!
insmod: error inserting './kermod/syslink.ko': -1 File exists
Setting DMM priority for [DUCATI ] to [0] ( 0x4e000624 = 0x08000000 )
Setting DMM priority for [HDVICP0 ] to [2] ( 0x4e000634 = 0x0000000a )
Setting DMM priority for [HDVICP1 ] to [2] ( 0x4e000634 = 0x000a0000 )
Setting DMM priority for [HDVICP2 ] to [2] ( 0x4e000634 = 0x00a00000 )
*** TVP5158 probe : START ***
TI VS EVM : TVP5158 device address : 0x58, 0x5a, 0x5c, 0x5e
TI DVR : TVP5158 device address : 0x5c, 0x5d, 0x5e, 0x5f
Device found : I2C (0xXX): 0x08 = 0x51
I2C (0xXX): 0x09 = 0x58
Device NOT found : I2C (0xXX): Read ERROR !!! (reg[0x08], count = 2)
I2C (0x58): Read ERROR !!! (reg[0x08], count = 2)
I2C (0x5a): Read ERROR !!! (reg[0x08], count = 2)
I2C (0x5c): 0x08 = 0x51
I2C (0x5c): 0x09 = 0x58
I2C (0x5d): 0x08 = 0x51
I2C (0x5d): 0x09 = 0x58
I2C (0x5e): 0x08 = 0x51
I2C (0x5e): 0x09 = 0x58
I2C (0x5f): 0x08 = 0x51
I2C (0x5f): 0x09 = 0x58
*** TVP5158 probe : END ***
/opt/dvr_rdk/ti816x
root@dvr:/opt/dvr_rdk/ti816x# ./loroot@dvr:/opt/dvr_rdk/ti816x# ./load.sh
Attached to slave procId 2.
*** _ProcMgr_map: All memEntries slots are in use!
Error [0x6a85000] at Line no: 2590 in file /home/hwjun/proj/workdir/ti_tools/syslink/syslink_2_20_02_20/packages/ti/syslink/utils/hlos/knl/Linux/../../../../../../ti/syslink/procMgr/common/ProcMgr.c
plughw:0,1: unde*** _ProcMgr_map: All memEntries slots are in use!
rrun !!!
Loaded file ../firmware/dvr_rdk_fw_m3vpss_1024M_256M.xem3 on sla*** _ProcMgr_map: All memEntries slots are in use!
ve procId 2.
St*** _ProcMgr_map: All memEntries slots are in use!
arted slave procId 2.
[m3vpss ] ***** SYSTEM : Frequency <ORG> - 250000000, <NEW> - 274909088
[m3vpss ] notify_attach rtnVal 0
[m3vpss ] initProxyServer rtnVal 0
[m3vpss ]
[m3vpss ] *** UTILS: CPU KHz = 549818 Khz ***
[m3vpss ]
[m3vpss ] 161377: SYSTEM : System Common Init in progress !!!
[m3vpss ] 161377: SYSTEM: IPC init in progress !!!
[m3vpss ] 161377: SYSTEM: Attaching to [HOST] ...
After Ipc_loadcallback status [0x00000000]
*** Platform_startCallback: Ipc_readConfig timeout
Error [0xffffffff] at Line no: 2882 in file /home/hwjun/proj/workdir/ti_tools/syslink/syslink_2_20_02_20/packages/ti/syslink/utils/hlos/knl/Linux/../../../../../../ti/syslink/family/hlos/knl/ti81xx/Platform.c
*** Ipc_control: Platform_startCallback failed!
Error [0xffffffff] at Line no: 853 in file /home/hwjun/proj/workdir/ti_tools/syslink/syslink_2_20_02_20/packages/ti/syslink/utils/hlos/knl/Linux/../../../../../../ti/syslink/ipc/hlos/knl/Ipc.c
Error in Ipc_control Ipc_CONTROLCMD_STARTCALLBACK [0xffffffff]
Attached to slave procId 1.
Loaded file ../firmware/dvr_rdk_fw_m3video_1024M_256M.xem3 on slave procId 1.
Started slave procId 1.
After Ipc_startcallback status [0x00000000]
[m3video] ***** SYSTEM : Frequency <ORG> - 250000000, <NEW> - 274909088
[m3video]
[m3video] *** UTILS: CPU KHz = 549818 Khz ***
[m3video]
[m3video] 162362: SYSTEM : System Common Init in progress !!!
[m3video] 162362: SYSTEM: IPC init in progress !!!
[m3video] 162362: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 162376: SYSTEM: Attaching to [HOST] ...
Attached to slave procId 0.
Loaded file ../firmware/dvr_rdk_fw_c6xdsp_1024M_256M.xe674 on slave procId 0.
Started slave procId 0.
[c6xdsp ] ***** SYSTEM : Frequency <ORG> - 800000000, <NEW> - 1000000000
[c6xdsp ]
[c6xdsp ] *** UTILS: CPU KHz = 1000000 Khz ***
[c6xdsp ]
[c6xdsp ] 5: SYSTEM : System Common Init in progress !!!
[c6xdsp ] 5: SYSTEM: IPC init in progreDMA: Module install successful, device major num = 250
ss !!!
[c6xdspDRV: Module install successful
] 5: SYSTEM: ADRV: Module built on Jun 25 2013 17:09:17
[m3video] 163362: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 163376: SYSTEM: Attaching to [HOST] ...
[c6xdsp ] 1012: SYSTEM: Attaching to [HOST] ...
[m3video] 164362: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 164376: SYSTEM: Attaching to [HOST] ...
[c6xdsp ] 2019: SYSTEM: Attaching to [HOST] ...
[m3video] 165362: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 165376: SYSTEM: Attaching to [HOST] ...
[c6xdsp ] 3026: SYSTEM: Attaching to [HOST] ...
[m3video] 166362: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 166376: SYSTEM: Attaching to [HOST] ...
[c6xdsp ] 4033: SYSTEM: Attaching to [HOST] ...
[m3video] 167362: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 167376: SYSTEM: Attaching to [HOST] ...
[c6xdsp ] 5040: SYSTEM: Attaching to [HOST] ...
[m3video] 168362: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 168376: SYSTEM: Attaching to [HOST] ...
[c6xdsp ] 6048: SYSTEM: Attaching to [HOST] ...
[m3video] 169362: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 169376: SYSTEM: Attaching to [HOST] ...
[c6xdsp ] 7055: SYSTEM: Attaching to [HOST] ...
[m3video] 170362: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 170376: SYSTEM: Attaching to [HOST] ...
[c6xdsp ] 8062: SYSTEM: Attaching to [HOST] ...
[m3video] 171362: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 171376: SYSTEM: Attaching to [HOST] ...
... and so on, so the load.sh does not terminate. Please help me understand what I am doing wrong.
Gleb
