DM8168 usb host and wifi
Hi!
 I'm using atheros ath9271 usb dongle (tp-link tl-wn722nc) at dm8168 board. I'm using backport 3.12 ath9k_htc driver. Also I use hostapd because I need AP mode. It works well without a high load. When I translate 2-3 rtsp streams to 1-2 devices, the kernel crashes with message "Unable to handle kernel NULL pointer dereference at virtual address 00000000". The kernel crashes in different places, sometimes in the ath driver, sometimes in some parts of IP stack. I have tried ralink rl3070 dongle and it also crashed when I start rtsp server and generate a high load to it. When I use rtsp server and wired ethernet it works good on the same loads.
Thanks.
  • here you may find relevant information. what are problems you are facing in case of ralink rl3070? any debug log may be helpful to find issue.
    Best luck
  • The link was not helpful. The issue the attached messages under a high load with rtsp server. The wifi connection freezes.
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project http://arago-project.org dm816x-evm ttyO2
    Arago 2011.09 dm816x-evm ttyO2
    dm816x-evm login:
    (gst-plugin-scanner:1494): GStreamer-WARNING **: Failed to load plugin '/usr/lib/gstreamer-0.10/libgstmad.so': /usr/lib/libid3tag.so.0: undefined symbol: id3_frametype_obsolete
    (gst-plugin-scanner:1494): GLib-GObject-WARNING **: cannot register existing type `GstVideoMixerPad'
    (gst-plugin-scanner:1494): GLib-CRITICAL **: g_once_init_leave: assertion `initialization_value != 0' failed
    VPSS_GRPX : please open fb0 node first.
    VPSS_GRPX : please open fb1 node first.
    VPSS_GRPX : please open fb2 node first.
    ieee80211 phy0: rt2x00usb_watchdog_tx_dma: Warning - TX queue 2 DMA timed out, invoke forced forced reset
    ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
    ieee80211 phy0: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x3064 with error -110
    ieee80211 phy0: rt2x00usb_vendor_request: Error - Vendor Request 0x06 failed for offset 0x3064 with error -110
