I am new to RTOS concepts , Now I am allocated to TI sys/bios project , I need to know how message queue works in sys/bios , i.e how the data shared between process or tasks or threads ?
Mohamed,
Message queue(MessageQ) is not directly part of SYS/BIOS but part of the IPC (Interprocess Communication) package that can be used with SYS/BIOS.
A good way to start with TI-RTOS Kernel (SYS/BIOS) is to go over the following training material to help with the RTOS concepts: http://processors.wiki.ti.com/index.php/TI-RTOS_Workshop
Then to use Message queue (IPC MessageQ module), you'll have to install IPC which can be found here. Here's the IPC user guide to get you started: http://processors.wiki.ti.com/index.php/IPC_Users_Guide
The MessageQ module specifically can be learned about here: http://processors.wiki.ti.com/index.php/IPC_Users_Guide/MessageQ_Module
I'd be pleased to answer any further questions
Moses
Thanks for your reply .
I have one more question:
for Each message queue created , One reader and Multiple writers , how reader knows that what data written by which writer since multiple writer possible?
Many thanks in advance.
mohamed ashik said:One reader and Multiple writers , how reader knows that what data written by which writer since multiple writer possible?
That's up to you to manage. A common way though is to use the msgId in the header. Writer X can set the msgId to one value and writer Y can set it to something else.
Todd
