Clkin to C5505
Other Parts Discussed in Thread: TMS320VC5505, SN74AVC1T45
Hello the datasheet for the TMS320VC5505 says that the external clock input can be given from a "LVCMOS clock", does that mean we cannot use a regular crystal to provide the clock input?
I was planning to use a 20Mhz crystal as an external clock input, will that be alright?
reg
Tanman
    That is correct.  An external crystal is not supported via the CLKIN input.  The C5505 does support a 32.768KHz crystal across RTC_XI and RTC_XO as illustrated in Figure 6-4 of the datasheet.  In addition, for USB support, a 12MHz crystal is supported on the USB_MXI and USB_MXO pins as illustrated in Figure 6-6 of the datasheet.
    But, CLKIN only supports a single-ended LVCMOS input.
    Not directly.  I have seen others in the past use an inverter logic device to generate single-ended output.  There is an application note on this subject of using a CMOS Unbuffered Inverter in Oscillator Circuits.
  • Hello
    in the EVM C5505, the 12Mhz crystal used for the USB has been used as an input to the device "SN74AVC1T45", whose output is given to the Clkin, Is that option also valid?
    reg
    Tanman
    Certainly.  It follows the same basic principle.
