DDR controller on XTCIEVMK2X(evmtci6638k2k) Rev11
Other Parts Discussed in Thread: TCI6638K2K, TMS320C6678
We have a XTCIEVMK2X(evmtci6638k2k) Rev11 evm board.
And one of the DDR controller is crippled. The data width is 32@1333MHz which should be 64@1600MHz according to spec.
This is a known issue because the gel file of that board implies that.
My question is that is there any new revision of that board or other evm board with keystone II DSP have fixed that issue.
Because our project need 2nd fully functional DDR controller to provide more memory bandwidth.
Thanks.
  • Hi Yang,
    The Rev2 and Rev3 versions of the EVM uses the 1.1 revision of the KeyStone II processor. That revision allows the use of all 64bits of DDR for both DDR interfaces.
    Regards, Bill
  • Hi Bill,
    I got the Rev3 boards.
    But how do I find the corresponding initialization gel file? The one in the CCS is still for 32Bits DDRA.
    -Yang
  • Hi Yang,
    The Gel files should be available with the MCSDK software download.
    Regards, Bill
  • Hi Bill,
    I installed the latest MCSDK 03_00_03.
    I searched all the newly installed directories with no luck to find the new gel file for that board.
    I do find one in C:\ti\mcsdk_bios_3_00_03_15\tools\program_evm\gel\xtcievmk2x.gel
    But I check the file and  it has no function to set DDRA as 64 bit.
    Do I missed something? Please help to show me the file I need.
    -Yang
  • Hi Yang,
    I'm sorry this is so painful. I'll try and get a gel for you and post it directly. Then I will attempt to get the latest gels into the software release. It would be helpful if you could post the gel you're currently using.
    Regards, Bill
  • Sure.
    This gel file exists in C:\ti\ccsv5\ccs_base\emulation\boards\evmtci6638k2k\gel\evmtci6638k2k.gel
    Notice its version is 1.4 and without 64 bit DDRA support. It's latest one as I can find.
    Please get me a new one.
    -Yang
    * Copyright (c) 2012 Texas Instruments Incorporated - http://www.ti.com
    * Redistribution and use in source and binary forms, with or without
    * modification, are permitted provided that the following conditions
    * are met:
    * Redistributions of source code must retain the above copyright
    * notice, this list of conditions and the following disclaimer.
    * Redistributions in binary form must reproduce the above copyright
    * notice, this list of conditions and the following disclaimer in the
    * documentation and/or other materials provided with the
    * distribution.
    * Neither the name of Texas Instruments Incorporated nor the names of
    * its contributors may be used to endorse or promote products derived
    * from this software without specific prior written permission.
    * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
    * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
    * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
    * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
    * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
    * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
    * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
    * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
    * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
    * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
    * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    * Filename: evmtci6638k2k.gel
    * Description: Utility GEL for use with the TCI6638K2K EVM. This GEL has
    * functions that initialize the chip PLL's and the DDR3A and DDR3B interfaces.
    * It also includes general utilities that are useful for EVM development
    * More functions will be added as needed.
    * Author: Randy Rosales
    * Revision History:
    * Revision 0.1
    * - Initial revision based on the Kepler VDB GEL 32bit_DDR-800_Kepler_PLL_and_DDR3_Init_Silicon_Rev15.gel put together for Kepler bringup by Pragna Paranji
    * - Added in GEL system clock frequency estimation functions written by WenZhong Liu to help debug core PLL instability
    * + dspPollDSPClockFreq will estimate the clock based on a comparison with windows system clock time
    * Revision 0.2 - pparanji
    * - Added DDR3A and DDR3B memory test capabilities.
    * Revision 0.3 - pparanji
    * - Added the following configurations
    * DDR3A 32bit - DDR800, DDR1066, DDR1333
    * DDR3B 64bit - DDR800, DDR1066, DDR1333, DDR1600
    * DSP core PLL @ 122.88 MHz to 614.4 MHz operation
    * 122.88 MHz to 737.28 MHz operation
    * 122.88 MHz to 983.04 MHz operation
    * 122.88 MHz to 1.2 GHz operation
    * ARM PLL @ 100 MHz to 1.0 GHz operation
    * 100 MHz to 1.4 GHz operation
    * 175 MHz to 1.4 GHz operation
    * Rev 1.2 - - pparanji
    * ------ Updates DDR3A and DDR3B to single rank configurations
    * Rev 1.3 - pparanji
    * ------ Updated timing on DDR3A-1066 and DDR3A-1333
    * Rev 1.4 - csmith
    * ------ Updated PA PLL config and Tetris PLL config
    #define GEL_VERSION 1.3
    // Timeout definitions
    int _GEL_Global_Timeout1 = 0;
    #define TIMEOUT_ID 10
    // Global timeout value
    #define GTIMEOUT 2000
    // Power definitions
    #define PSC_BASE 0x02350000
    #define PSC_PTCMD *( unsigned int* )( PSC_BASE+0x120 )
    #define PSC_PTSTAT *( unsigned int* )( PSC_BASE+0x128 )
    #define PSC_PDCTL_BASE ( PSC_BASE+0x300 )
    #define PSC_MDSTAT_BASE ( PSC_BASE+0x800 )
    #define PSC_MDCTL_BASE ( PSC_BASE+0xA00 )
    // Modules on power domain 0
    // Always on
    // Modules on power domain 1
    #define LPSC_DEBUG (5)
    #define LPSC_TETB (6)
    // Modules on power domain 2
    #define LPSC_PA (7)
    #define LPSC_SGMII (8)
    #define LPSC_SA (9)
    // Modules on power domain 3
    #define LPSC_PCIE (10)
    // Modules on power domain 4
    #define LPSC_SRIO (11)
    // Modules on power domain 5
    #define LPSC_HYPERLINK_0 (12)
    // Modules on power domain 6
    #define LPSC_SR (13)
    // Modules on power domain 7
    #define LPSC_MSMCRAM (14)
    // Modules on power domain 8
    #define LPSC_GEM_0 (15)
    // Modules on power domain 9
    #define LPSC_GEM_1 (16)
    // Modules on power domain 10
    #define LPSC_GEM_2 (17)
    // Modules on power domain 11
    #define LPSC_GEM_3 (18)
    // Modules on power domain 12
    #define LPSC_GEM_4 (19)
    // Modules on power domain 13
    #define LPSC_GEM_5 (20)
    // Modules on power domain 14
    #define LPSC_GEM_6 (21)
    // Modules on power domain 15
    #define LPSC_GEM_7 (22)
    // Modules on power domain 16
    #define LPSC_DDR3_0 (23)
    #define LPSC_DDR3_1 (24)
    // Modules on power domain 17
    #define LPSC_TAC (25)
    #define LPSC_RAC_01 (26)
    // Modules on power domain 18
    #define LPSC_RAC_23 (27)
    // Modules on power domain 19
    #define LPSC_FFTCA_FFTC_0 (28)
    #define LPSC_FFTCA_FFTC_1 (29)
    // Modules on power domain 20
    #define LPSC_FFTCA_FFTC_2 (30)
    #define LPSC_FFTCA_FFTC_3 (31)
    #define LPSC_FFTCA_FFTC_4 (32)
    #define LPSC_FFTCA_FFTC_5 (33)
    // Modules on power domain 21
    #define LPSC_AIF (34)
    // Modules on power domain 22
    #define LPSC_TCP3D_0 (35)
    #define LPSC_TCP3D_1 (36)
    // Modules on power domain 23
    #define LPSC_TCP3D_2 (37)
    #define LPSC_TCP3D_3 (38)
    // Modules on power domain 24
    #define LPSC_VCP_0 (39)
    #define LPSC_VCP_1 (40)
    #define LPSC_VCP_2 (41)
    #define LPSC_VCP_3 (42)
    // Modules on power domain 25
    #define LPSC_VCP_4 (43)
    #define LPSC_VCP_5 (44)
    #define LPSC_VCP_6 (45)
    #define LPSC_VCP_7 (46)
    // Modules on power domain 26
    #define LPSC_BCP (47)
    // Modules on power domain 27
    #define LPSC_DXB (48)
    // Modules on power domain 28
    #define LPSC_HYPERLINK_1 (49)
    // Modules on power domain 29
    #define LPSC_XGE (50)
    // Modules on power domain 31
    #define LPSC_ARM (52)
    // Power domains definitions
    #define PD0 (0) // Power Domain-0
    #define PD1 (1) // Power Domain-1
    #define PD2 (2) // Power Domain-2
    #define PD3 (3) // Power Domain-3
    #define PD4 (4) // Power Domain-4
    #define PD5 (5) // Power Domain-5
    #define PD6 (6) // Power Domain-6
    #define PD7 (7) // Power Domain-7
    #define PD8 (8) // Power Domain-8
    #define PD9 (9) // Power Domain-9
    #define PD10 (10) // Power Domain-10
    #define PD11 (11) // Power Domain-11
    #define PD12 (12) // Power Domain-12
    #define PD13 (13) // Power Domain-13
    #define PD14 (14) // Power Domain-14
    #define PD15 (15) // Power Domain-15
    #define PD16 (16) // Power Domain-16
    #define PD17 (17) // Power Domain-17
    #define PD18 (18) // Power Domain-18
    #define PD19 (19) // Power Domain-19
    #define PD20 (20) // Power Domain-20
    #define PD21 (21) // Power Domain-21
    #define PD22 (22) // Power Domain-22
    #define PD23 (23) // Power Domain-23
    #define PD24 (24) // Power Domain-24
    #define PD25 (25) // Power Domain-25
    #define PD26 (26) // Power Domain-26
    #define PD27 (27) // Power Domain-27
    #define PD28 (28) // Power Domain-28
    #define PD29 (29) // Power Domain-29
    #define PD30 (30) // Power Domain-30
    #define PD31 (31) // Power Domain-31
    #define PSC_SYNCRESET (0x1)
    #define PSC_DISABLE (0x2)
    #define PSC_ENABLE (0x3)
    #define CHIP_LEVEL_REG 0x02620000
    /******************* PLL registers **********************************/
    /*Boot cfg registers*/
    #define KICK0 *(unsigned int*)(CHIP_LEVEL_REG + 0x0038)
    #define KICK1 *(unsigned int*)(CHIP_LEVEL_REG + 0x003C)
    #define KICK0_UNLOCK (0x83E70B13)
    #define KICK1_UNLOCK (0x95A4F1E0)
    #define KICK_LOCK 0
    #define TINPSEL *(unsigned int*)(CHIP_LEVEL_REG + 0x0300)
    #define TOUTPSEL *(unsigned int*)(CHIP_LEVEL_REG + 0x0304)
    #define MAINPLLCTL0 *(unsigned int*)(CHIP_LEVEL_REG + 0x0350) //0x0328)
    #define MAINPLLCTL1 *(unsigned int*)(CHIP_LEVEL_REG + 0x0354) //0x032C)
    #define MAIN_PLLD_OFFSET 0
    #define MAIN_PLLD_MASK 0xFFFFFFC0
    #define MAIN_PLLM_OFFSET 12
    #define MAIN_PLLM_MASK 0xFFF80FFF
    #define MAIN_BWADJ0_OFFSET 24
    #define MAIN_BWADJ0_MASK 0x00FFFFFF
    #define MAIN_ENSAT_OFFSET 6
    #define MAIN_ENSAT_MASK 0xFFFFFFBF
    #define MAIN_BWADJ1_OFFSET 0
    #define MAIN_BWADJ1_MASK 0xFFFFFFF0
    #define OBSCLKCTL *(unsigned int*)(CHIP_LEVEL_REG + 0x0C80)
    /* PA PLL Registers */
    #define BYPASS_BIT_SHIFT 23
    #define CLKF_BIT_SHIFT 6
    #define CLKD_BIT_SHIFT 0
    #define DEVSTAT (*((unsigned int *) 0x02620020))
    #define PAPLLCTL0 *(unsigned int*)(CHIP_LEVEL_REG + 0x0358)
    #define PAPLLCTL1 *(unsigned int*)(CHIP_LEVEL_REG + 0x035C)
    #define PASSCLKSEL_MASK (1 << 17) /* Tells the configuration of the PASSCLKSEL pin */
    #define PA_PLL_BYPASS_MASK (1 << BYPASS_BIT_SHIFT) /* Tells whether the PA PLL is in BYPASS mode or not */
    #define PA_PLL_CLKOD_MASK (0x00780000) /* Tells the output divider value for the PA PLL */
    #define PA_PLL_CLKF_MASK (0x0007FFC0) /* Tells the multiplier value for the PA PLL */
    #define PA_PLL_CLKR_MASK (0x0000003F) /* Tells the divider value for the PA PLL */
    #define PA_PLL_RESET_MASK (0x00004000)
    #define CHIP_MISC1 *(unsigned int*)(CHIP_LEVEL_REG + 0x0C7C)
    #define ARMPLL_ENABLE_OFFSET 13
    #define DDR3APLLCTL0 *(unsigned int*)(CHIP_LEVEL_REG + 0x0360)
    #define DDR3APLLCTL1 *(unsigned int*)(CHIP_LEVEL_REG + 0x0364)
    #define DDR3BPLLCTL0 *(unsigned int*)(CHIP_LEVEL_REG + 0x0368)
    #define DDR3BPLLCTL1 *(unsigned int*)(CHIP_LEVEL_REG + 0x036C)
    // PLL 1 definitions (DSP and ARM clock and subsystems)
    #define PLL1_BASE 0x02310000
    #define PLL1_PLLCTL (*(unsigned int*)(PLL1_BASE + 0x100)) // PLL1 Control
    #define PLL1_SECCTL (*(unsigned int*)(PLL1_BASE + 0x108)) // PLL1 Secondary Control
    #define PLL1_PLLM (*(unsigned int*)(PLL1_BASE + 0x110)) // PLL1 Multiplier
    #define PLL1_DIV1 (*(unsigned int*)(PLL1_BASE + 0x118)) // DIV1 divider
    #define PLL1_DIV2 (*(unsigned int*)(PLL1_BASE + 0x11C)) // DIV2 divider
    #define PLL1_DIV3 (*(unsigned int*)(PLL1_BASE + 0x120)) // DIV3 divider
    #define PLL1_CMD (*(unsigned int*)(PLL1_BASE + 0x138)) // CMD control
    #define PLL1_STAT (*(unsigned int*)(PLL1_BASE + 0x13C)) // STAT control
    #define PLL1_ALNCTL (*(unsigned int*)(PLL1_BASE + 0x140)) // ALNCTL control
    #define PLL1_DCHANGE (*(unsigned int*)(PLL1_BASE + 0x144)) // DCHANGE status
    #define PLL1_CKEN (*(unsigned int*)(PLL1_BASE + 0x148)) // CKEN control
    #define PLL1_CKSTAT (*(unsigned int*)(PLL1_BASE + 0x14C)) // CKSTAT status
    #define PLL1_SYSTAT (*(unsigned int*)(PLL1_BASE + 0x150)) // SYSTAT status
    #define PLL1_DIV4 (*(unsigned int*)(PLL1_BASE + 0x160)) // DIV4 divider
    #define PLL1_DIV5 (*(unsigned int*)(PLL1_BASE + 0x164)) // DIV5 divider
    #define PLL1_DIV6 (*(unsigned int*)(PLL1_BASE + 0x168)) // DIV6 divider
    #define PLL1_DIV7 (*(unsigned int*)(PLL1_BASE + 0x16C)) // DIV7 divider
    #define PLL1_DIV8 (*(unsigned int*)(PLL1_BASE + 0x170)) // DIV8 divider
    #define PLL1_DIV9 (*(unsigned int*)(PLL1_BASE + 0x174)) // DIV9 divider
    #define PLL1_DIV10 (*(unsigned int*)(PLL1_BASE + 0x178)) // DIV10 divider
    #define PLL1_DIV11 (*(unsigned int*)(PLL1_BASE + 0x17C)) // DIV11 divider
    #define PLL1_DIV12 (*(unsigned int*)(PLL1_BASE + 0x180)) // DIV12 divider
    #define PLL1_DIV13 (*(unsigned int*)(PLL1_BASE + 0x184)) // DIV13 divider
    #define PLL1_DIV14 (*(unsigned int*)(PLL1_BASE + 0x188)) // DIV14 divider
    #define PLL1_DIV15 (*(unsigned int*)(PLL1_BASE + 0x18C)) // DIV15 divider
    #define PLL1_DIV16 (*(unsigned int*)(PLL1_BASE + 0x190)) // DIV16 divider
    #define PLLPWRDN_OFFSET 1
    #define PLLPWRDN_MASK 0xFFFFFFFD
    #define PLLRST_OFFSET 3
    #define PLLRST_MASK 0xFFFFFFF7
    #define PLLENSRC_OFFSET 5
    #define PLLENSRC_MASK 0xFFFFFFDF
    #define PLLEN_OFFSET 0
    #define PLLEN_MASK 0xFFFFFFFE
    #define OUTPUT_DIVIDE_OFFSET 19
    #define OUTPUT_DIVIDE_MASK 0xFF87FFFF
    #define BYPASS_OFFSET 23
    #define BYPASS_MASK 0xFF7FFFFF
    #define PLLM_OFFSET 0
    #define PLLM_MASK 0xFFFFFFC0
    #define GOSET_OFFSET 0
    #define GOSET_MASK 0xFFFFFFFE
    #define GOSTAT_OFFSET 0
    #define GOSTAT_MASK 0xFFFFFFFE
    // ARMPLL definitions
    #define SEC_PLLCTL0_PLLM_OFFSET 6
    #define SEC_PLLCTL0_PLLM_MASK 0xFFFF003F
    #define SEC_PLLCTL0_BWADJ_OFFSET 24
    #define SEC_PLLCTL0_BWADJ_MASK 0x00FFFFFF
    #define SEC_PLLCTL0_OD_OFFSET 19
    #define SEC_PLLCTL0_OD_MASK 0xFF87FFFF
    #define SEC_PLLCTL0_BYPASS_OFFSET 23
    #define SEC_PLLCTL0_BYPASS_MASK 0xFF7FFFFF
    #define SEC_PLLCTL1_RESET_OFFSET 14
    #define SEC_PLLCTL1_RESET_MASK 0xFFFFBFFF
    #define SEC_PLLCTL1_PWRDWN_OFFSET 15
    #define SEC_PLLCTL1_PWRDWN_MASK 0xFFFF7FFF
    #define SEC_PLLCTL1_ENSTAT_OFFSET 6
    #define SEC_PLLCTL1_ENSTAT_MASK 0xFFFFFFBF
    /*----------------DDR3A Register definition---------------------*/
    #define DDR3A_BASE_ADDR (0x21010000)
    #define DDR3A_STATUS (*(int*)(DDR3A_BASE_ADDR + 0x00000004))
    #define DDR3A_SDCFG (*(int*)(DDR3A_BASE_ADDR + 0x00000008))
    #define DDR3A_SDRFC (*(int*)(DDR3A_BASE_ADDR + 0x00000010))
    #define DDR3A_SDTIM1 (*(int*)(DDR3A_BASE_ADDR + 0x00000018))
    #define DDR3A_SDTIM2 (*(int*)(DDR3A_BASE_ADDR + 0x0000001C))
    #define DDR3A_SDTIM3 (*(int*)(DDR3A_BASE_ADDR + 0x00000020))
    #define DDR3A_SDTIM4 (*(int*)(DDR3A_BASE_ADDR + 0x00000028))
    #define DDR3A_ZQCFG (*(int*)(DDR3A_BASE_ADDR + 0x000000C8))
    #define DDR3A_TMPALRT (*(int*)(DDR3A_BASE_ADDR + 0x000000CC))
    #define DDR3A_DDRPHYC (*(int*)(DDR3A_BASE_ADDR + 0x000000E4))
    #define DDR3A_PHY_CFG_BASE (0x02329000)
    #define DDR3A_PIR (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000004))
    #define DDR3A_PGCR0 (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000008))
    #define DDR3A_PGCR1 (*(int*)(DDR3A_PHY_CFG_BASE + 0x0000000C))
    #define DDR3A_PGCR2 (*(int*)(DDR3A_PHY_CFG_BASE + 0x0000008C))
    #define DDR3A_PGSR0 (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000010))
    #define DDR3A_PGSR1 (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000014))
    #define DDR3A_PLLCR (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000018))
    #define DDR3A_PTR0 (*(int*)(DDR3A_PHY_CFG_BASE + 0x0000001C))
    #define DDR3A_PTR1 (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000020))
    #define DDR3A_PTR2 (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000024))
    #define DDR3A_PTR3 (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000028))
    #define DDR3A_PTR4 (*(int*)(DDR3A_PHY_CFG_BASE + 0x0000002C))
    #define DDR3A_DSGCR (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000040))
    #define DDR3A_DCR (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000044))
    #define DDR3A_MR0 (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000054))
    #define DDR3A_MR1 (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000058))
    #define DDR3A_MR2 (*(int*)(DDR3A_PHY_CFG_BASE + 0x0000005C))
    #define DDR3A_DTCR (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000068))
    #define DDR3A_DTPR0 (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000048))
    #define DDR3A_DTPR1 (*(int*)(DDR3A_PHY_CFG_BASE + 0x0000004C))
    #define DDR3A_DTPR2 (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000050))
    #define DDR3A_ZQ0CR1 (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000184))
    #define DDR3A_ZQ1CR1 (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000194))
    #define DDR3A_ZQ2CR1 (*(int*)(DDR3A_PHY_CFG_BASE + 0x000001A4))
    #define DDR3A_ZQ3CR1 (*(int*)(DDR3A_PHY_CFG_BASE + 0x000001B4))
    #define DDR3A_DATX8_8 (*(int*)(DDR3A_PHY_CFG_BASE + 0x000003C0))
    #define DDR3_TEST_START_ADDRESS (*(int*)(0x80000000))
    #define IODDRM_MASK 0x00000180
    #define ZCKSEL_MASK 0x01800000
    #define CL_MASK 0x00000072
    #define WR_MASK 0x00000E00
    #define BL_MASK 0x00000003
    #define RRMODE_MASK 0x00040000
    #define UDIMM_MASK 0x20000000
    #define BYTEMASK_MASK 0x0000FC00
    #define MPRDQ_MASK 0x00000080
    #define PDQ_MASK 0x00000070
    #define NOSRA_MASK 0x08000000
    #define ECC_MASK 0x00000001
    #define DDR3A_DX0GSR0 (*(int*)(DDR3A_PHY_CFG_BASE + 0x000001C4)) //0x71
    #define DDR3A_DX1GSR0 (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000204)) //0x81
    #define DDR3A_DX2GSR0 (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000244)) //0x91
    #define DDR3A_DX3GSR0 (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000284)) //0xA1
    #define DDR3A_DX4GSR0 (*(int*)(DDR3A_PHY_CFG_BASE + 0x000002C4)) //0xB1
    #define DDR3A_DX5GSR0 (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000304)) //0xC1
    #define DDR3A_DX6GSR0 (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000344)) //0xD1
    #define DDR3A_DX7GSR0 (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000384)) //0xE1
    #define DDR3A_DX8GSR0 (*(int*)(DDR3A_PHY_CFG_BASE + 0x000003C4)) //0xF1
    #define DDR3A_TEST_START_ADDRESS (0x80000000)
    #define DDR3A_TEST_END_ADDRESS (DDR3A_TEST_START_ADDRESS + (4 * 100))
    #define DDR3A_BASE_ADDRESS 0x80000000
    #define DDR3B_BASE_ADDR (0x21020000)
    #define DDR3B_STATUS (*(int*)(DDR3B_BASE_ADDR + 0x00000004))
    #define DDR3B_SDCFG (*(int*)(DDR3B_BASE_ADDR + 0x00000008))
    #define DDR3B_SDRFC (*(int*)(DDR3B_BASE_ADDR + 0x00000010))
    #define DDR3B_SDTIM1 (*(int*)(DDR3B_BASE_ADDR + 0x00000018))
    #define DDR3B_SDTIM2 (*(int*)(DDR3B_BASE_ADDR + 0x0000001C))
    #define DDR3B_SDTIM3 (*(int*)(DDR3B_BASE_ADDR + 0x00000020))
    #define DDR3B_SDTIM4 (*(int*)(DDR3B_BASE_ADDR + 0x00000028))
    #define DDR3B_ZQCFG (*(int*)(DDR3B_BASE_ADDR + 0x000000C8))
    #define DDR3B_TMPALRT (*(int*)(DDR3B_BASE_ADDR + 0x000000CC))
    #define DDR3B_DDRPHYC (*(int*)(DDR3B_BASE_ADDR + 0x000000E4))
    #define DDR3B_PHY_CFG_BASE (0x02328000)
    #define DDR3B_PIR (*(int*)(DDR3B_PHY_CFG_BASE + 0x00000004))
    #define DDR3B_PGCR0 (*(int*)(DDR3B_PHY_CFG_BASE + 0x00000008))
    #define DDR3B_PGCR1 (*(int*)(DDR3B_PHY_CFG_BASE + 0x0000000C))
    #define DDR3B_PGCR2 (*(int*)(DDR3B_PHY_CFG_BASE + 0x0000008C))
    #define DDR3B_PGSR0 (*(int*)(DDR3B_PHY_CFG_BASE + 0x00000010))
    #define DDR3B_PGSR1 (*(int*)(DDR3B_PHY_CFG_BASE + 0x00000014))
    #define DDR3B_PTR0 (*(int*)(DDR3B_PHY_CFG_BASE + 0x0000001C))
    #define DDR3B_PTR1 (*(int*)(DDR3B_PHY_CFG_BASE + 0x00000020))
    #define DDR3B_PTR2 (*(int*)(DDR3B_PHY_CFG_BASE + 0x00000024))
    #define DDR3B_PTR3 (*(int*)(DDR3B_PHY_CFG_BASE + 0x00000028))
    #define DDR3B_PTR4 (*(int*)(DDR3B_PHY_CFG_BASE + 0x0000002C))
    #define DDR3B_DSGCR (*(int*)(DDR3B_PHY_CFG_BASE + 0x00000040))
    #define DDR3B_DCR (*(int*)(DDR3B_PHY_CFG_BASE + 0x00000044))
    #define DDR3B_MR0 (*(int*)(DDR3B_PHY_CFG_BASE + 0x00000054))
    #define DDR3B_MR1 (*(int*)(DDR3B_PHY_CFG_BASE + 0x00000058))
    #define DDR3B_MR2 (*(int*)(DDR3B_PHY_CFG_BASE + 0x0000005C))
    #define DDR3B_DTCR (*(int*)(DDR3B_PHY_CFG_BASE + 0x00000068))
    #define DDR3B_DTPR0 (*(int*)(DDR3B_PHY_CFG_BASE + 0x00000048))
    #define DDR3B_DTPR1 (*(int*)(DDR3B_PHY_CFG_BASE + 0x0000004C))
    #define DDR3B_DTPR2 (*(int*)(DDR3B_PHY_CFG_BASE + 0x00000050))
    #define DDR3B_PLLCR (*(int*)(DDR3B_PHY_CFG_BASE + 0x00000018))
    #define DDR3B_ZQ0CR1 (*(int*)(DDR3B_PHY_CFG_BASE + 0x00000184))
    #define DDR3B_ZQ1CR1 (*(int*)(DDR3B_PHY_CFG_BASE + 0x00000194))
    #define DDR3B_ZQ2CR1 (*(int*)(DDR3B_PHY_CFG_BASE + 0x000001A4))
    #define DDR3B_ZQ3CR1 (*(int*)(DDR3B_PHY_CFG_BASE + 0x000001B4))
    #define DDR3B_TEST_START_ADDRESS (0x60000000)
    #define DDR3B_TEST_END_ADDRESS (DDR3B_TEST_START_ADDRESS + (4 * 100))
    #define DDR3B_BASE_ADDRESS 0x60000000
    #define TETRIS_BASE 0x01E80000
    #define TETRIS_CPU0_PTCMD *(unsigned int*)(TETRIS_BASE + 0x0400)
    #define TETRIS_CPU0_PDSTAT *(unsigned int*)(TETRIS_BASE + 0x0404)
    #define TETRIS_CPU0_PDCTL *(unsigned int*)(TETRIS_BASE + 0x0408)
    #define TETRIS_CPU1_PTCMD *(unsigned int*)(TETRIS_BASE + 0x040C)
    #define TETRIS_CPU1_PDSTAT *(unsigned int*)(TETRIS_BASE + 0x0410)
    #define TETRIS_CPU1_PDCTL *(unsigned int*)(TETRIS_BASE + 0x0414)
    #define TETRIS_CPU2_PTCMD *(unsigned int*)(TETRIS_BASE + 0x0418)
    #define TETRIS_CPU2_PDSTAT *(unsigned int*)(TETRIS_BASE + 0x041C)
    #define TETRIS_CPU2_PDCTL *(unsigned int*)(TETRIS_BASE + 0x0420)
    #define TETRIS_CPU3_PTCMD *(unsigned int*)(TETRIS_BASE + 0x0424)
    #define TETRIS_CPU3_PDSTAT *(unsigned int*)(TETRIS_BASE + 0x0428)
    #define TETRIS_CPU3_PDCTL *(unsigned int*)(TETRIS_BASE + 0x042C)
    #define SECPLLCTL0 *(unsigned int*)(CHIP_LEVEL_REG + 0x0370)
    #define SECPLLCTL1 *(unsigned int*)(CHIP_LEVEL_REG + 0x0374)
    unsigned int read_val;
    * NAME
    * OnTargetConnect
    * PURPOSE:
    * Setup almost everything ready for a new debug session:
    * DSP modules and EVM board modules, at target connection.
    * Do nothing if target is in realtime mode.
    * This routine is called when you connect to the target board.
    * IMPORTANT: this routine won't attempt to connect to the target
    * if the target is not in real-time mode and that the dsp boot
    * mode switches are not set in emulation boot mode.
    * USAGE
    * This routine is a callback routine and called by CCS only.
    * RETURN VALUE
    * NONE
    * REFERENCE
    OnTargetConnect()
    /* GEL_Reset() is used to deal with the worst case */
    /* senario of unknown target state. If for some reason */
    /* a reset is not desired upon target connection, */
    /* GEL_Reset() may be removed and replaced with */
    /* something "less brutal" like a cache initialization */
    /* function. */
    //GEL_Reset();
    //xmc_setup();
    //ddr3_setup();
    GEL_TextOut("\nConnecting Target...\n");
    // Check if target is not in real-time mode. If it is in stop mode,
    // initialize everything. In real-time mode, do nothing to connect
    // unobtrusively...
    if (!GEL_IsInRealtimeMode())
    // Validates if emulation boot mode
    if (DEVSTAT & 0x0000000E)
    GEL_TextOut("No initialization performed since bootmode = %x \n",,,,,(DEVSTAT >> 1 ) & 0xF);
    GEL_TextOut("You can manually initialize with GlobalDefaultSetup\n");
    else
    // Comment the following line at production application test
    // when the application need to initialize everything, but not the
    // GEL file.
    Global_Default_Setup_Silent();
    } else {
    GEL_TextOut("No initialization performed in real time mode\n");
    /* OnReset() */
    /* This function is called by CCS when you do Debug->Resest. */
    /* The goal is to put the C6x into a known good state with */
    /* respect to cache, edma and interrupts. */
    OnReset( int nErrorCode )
    /* xmc_setup() */
    /* XMC MPAX register setting to access DDR3 config space */
    #define XMC_BASE_ADDR (0x08000000)
    #define XMPAX2_L (*(int*)(XMC_BASE_ADDR + 0x00000010))
    #define XMPAX2_H (*(int*)(XMC_BASE_ADDR + 0x00000014))
    xmc_setup()
    /* mapping for ddr emif registers XMPAX*2 */
    XMPAX2_L = 0x121010FF; /* replacement addr + perm */
    XMPAX2_H = 0x2101000B; /* base addr + seg size (64KB)*/ //"1B"-->"B" by xj
    GEL_TextOut("XMC setup complete.\n");
    * NAME
    * Global_Default_Setup_Silent
    * PURPOSE:
    * DSP modules and EVM board modules.
    * USAGE
    * This routine can be called as:
    * Global_Default_Setup_Silent()
    * RETURN VALUE
    * NONE
    * REFERENCE
    float gel_ver = GEL_VERSION;
    // Set DSP cache to pre defined values...
    GEL_TextOut( "TCI6638K2K GEL file Ver is %f \n",,,,, (float) (gel_ver/1.0));
    //Set_DSP_Cache();
    // Only core 0 can set these
    if (DNUM == 0)
    // Setup main PLL DSP @ 983 MHz
    Set_Pll1(3); // call Set_Pll1 with index = 3 -> 122.88 MHz to 983.04 MHz operation
    // Setup all Power Domains on
    Set_Psc_All_On();
    // Setup PA PLL
    PaPllConfig();
    GEL_TextOut("DDR begin\n");
    xmc_setup();
    ddr3A_32bit_DDR1333_setup();
    ddr3B_64bit_DDR1600_setup();
    GEL_TextOut("DDR done\n");
    * NAME
    * Set_PSC_State
    * PURPOSE:
    * Set a new power state for the specified domain id in a power controler
    * domain. Wait for the power transition to complete.
    * USAGE
    * Set_PSC_State(unsigned int pd,unsigned int id,unsigned int state)
    * pd - (i) power domain.
    * id - (i) module id to use for module in the specified power domain
    * state - (i) new state value to set
    * 0 = RESET
    * 1 = SYNC RESET
    * 2 = DISABLE
    * 3 = ENABLE
    * RETURN VALUE
    * 0 if ok, !=0 for error
    * REFERENCE
    unsigned int* mdctl;
    unsigned int* mdstat;
    unsigned int* pdctl;
    int ret=0;
    // Only core0 can set PSC
    if (DNUM == 0)
    mdctl = ( unsigned int* )(PSC_MDCTL_BASE + ( 4 * id ));
    mdstat = ( unsigned int* )( PSC_MDSTAT_BASE + ( 4 * id ));
    pdctl = ( unsigned int* )(PSC_PDCTL_BASE + ( 4 * pd ));
    // If state is already set, do nothing
    if ( ( *mdstat & 0x1f ) == state )
    return(0);
    // Wait for GOSTAT to clear
    Set_Timeout(GTIMEOUT);
    while( Get_Timeout() && (PSC_PTSTAT & (0x1 << pd)) != 0 );
    // Check if we got timeout error while waiting
    if (!Get_Timeout())
    GEL_TextOut( "Set_PSC_State... Timeout Error #01 pd=%d, md=%d!\n",,2,,,pd,id);
    ret=1;
    else
    // Set power domain control
    *pdctl = (*pdctl) | 0x00000001;
    // Set MDCTL NEXT to new state
    *mdctl = ((*mdctl) & ~(0x1f)) | state;
    // Start power transition by setting PTCMD GO to 1
    PSC_PTCMD = (PSC_PTCMD) | (0x1<<pd);
    // Wait for PTSTAT GOSTAT to clear
    if (!Get_Timeout())
    GEL_TextOut( "Set_PSC_State... Timeout Error #02 pd=%d, md=%d!\n",,2,,,pd,id);
    ret=2;
    else
    // Verify state changed
    while(Get_Timeout() && ( *mdstat & 0x1f ) != state );
    if (!Get_Timeout())
    GEL_TextOut( "Set_PSC_State... Timeout Error #03 pd=%d, md=%d!\n",,2,,,pd,id);
    ret=3;
    // Kill the currently running timeout
    Kill_Timeout();
    else
    GEL_TextOut("DSP core #%d cannot set PSC.\n",,2,,,DNUM);
    return(ret);
    * NAME
    * Set_Timeout
    * PURPOSE:
    * Starts a timeout period of msec. The running timeout period can be
    * query with Get_Timeout. To kill a running timeout before the end,
    * call Kill_Timeout. Only one timeout period can be used at any time.
    * A timeout period can be used to measure a period of time while doing
    * anything else. Not accurate, sets timer at least as big as desired.
    * USAGE
    * Set_Timeout(msec)
    * msec - (i) timeout period in msec (not very precise < sec range)
    * RETURN VALUE
    * NONE
    * REFERENCE
    Set_Timeout(msec)
    // Cancel the current timer if not already expired
    GEL_CancelTimer(TIMEOUT_ID);
    // Starts the timeout period
    _GEL_Global_Timeout1=1;
    // Setup a callback routine with specified timeout
    GEL_SetTimer(msec, TIMEOUT_ID, "_Timeout_Callback()");
    * NAME
    * Get_Timeout
    * PURPOSE:
    * Query the running state of a timeout period started by Set_Timeout.
    * (see Set_Timeout for more info).
    * USAGE
    * Get_Timeout()
    * RETURN VALUE
    * 0:expired, 1:running
    * REFERENCE
    Get_Timeout()
    if (!_GEL_Global_Timeout1)
    // Return the global timeout status 1=running, 0=expired
    return _GEL_Global_Timeout1;
    * NAME
    * Kill_Timeout
    * PURPOSE:
    * Cancel a running timeout period before it expires
    * USAGE
    * Kill_Timeout()
    * RETURN VALUE
    * NONE
    * REFERENCE
    Kill_Timeout()
    // The timeout period is expired
    _GEL_Global_Timeout1=0;
    * NAME
    * _Timeout_Callback
    * PURPOSE:
    * Internal Callback function used by Set_timeout
    * USAGE
    * This routine must not be called by itself.
    * RETURN VALUE
    * NONE
    * REFERENCE
    _Timeout_Callback()
    * NAME
    * Set_Psc_All_On
    * PURPOSE:
    * Enable all PSC modules and DSP power domains on ALWAYSON, and wait
    * for these power transitions to complete.
    * USAGE
    * Set_Psc_All_On()
    * RETURN VALUE
    * NONE
    * REFERENCE
    hotmenu Set_Psc_All_On( )
    unsigned int i=0;
    if (DNUM == 0)
    GEL_TextOut( "Power on all PSC modules and DSP domains... \n");
    Set_PSC_State(PD1, LPSC_DEBUG, PSC_ENABLE);
    Set_PSC_State(PD1, LPSC_TETB, PSC_ENABLE);
    Set_PSC_State(PD2, LPSC_PA, PSC_ENABLE);
    Set_PSC_State(PD2, LPSC_SGMII, PSC_ENABLE);
    Set_PSC_State(PD2, LPSC_SA, PSC_ENABLE);
    Set_PSC_State(PD3, LPSC_PCIE, PSC_ENABLE);
    Set_PSC_State(PD4, LPSC_SRIO, PSC_ENABLE);
    Set_PSC_State(PD5, LPSC_HYPERLINK_0, PSC_ENABLE);
    Set_PSC_State(PD6, LPSC_SR, PSC_ENABLE);
    Set_PSC_State(PD7, LPSC_MSMCRAM, PSC_ENABLE);
    Set_PSC_State(PD8, LPSC_GEM_0, PSC_ENABLE);
    Set_PSC_State(PD9, LPSC_GEM_1, PSC_ENABLE);
    Set_PSC_State(PD10, LPSC_GEM_2, PSC_ENABLE);
    Set_PSC_State(PD11, LPSC_GEM_3, PSC_ENABLE);
    Set_PSC_State(PD12, LPSC_GEM_4, PSC_ENABLE);
    Set_PSC_State(PD13, LPSC_GEM_5, PSC_ENABLE);
    Set_PSC_State(PD14, LPSC_GEM_6, PSC_ENABLE);
    Set_PSC_State(PD15, LPSC_GEM_7, PSC_ENABLE);
    Set_PSC_State(PD16, LPSC_DDR3_0, PSC_ENABLE);
    Set_PSC_State(PD16, LPSC_DDR3_1, PSC_ENABLE);
    Set_PSC_State(PD17, LPSC_TAC, PSC_ENABLE);
    Set_PSC_State(PD17, LPSC_RAC_01, PSC_ENABLE);
    Set_PSC_State(PD18, LPSC_RAC_23, PSC_ENABLE);
    Set_PSC_State(PD19, LPSC_FFTCA_FFTC_0, PSC_ENABLE);
    Set_PSC_State(PD19, LPSC_FFTCA_FFTC_1, PSC_ENABLE);
    Set_PSC_State(PD20, LPSC_FFTCA_FFTC_2, PSC_ENABLE);
    Set_PSC_State(PD20, LPSC_FFTCA_FFTC_3, PSC_ENABLE);
    Set_PSC_State(PD20, LPSC_FFTCA_FFTC_4, PSC_ENABLE);
    Set_PSC_State(PD20, LPSC_FFTCA_FFTC_5, PSC_ENABLE);
    Set_PSC_State(PD21, LPSC_AIF, PSC_ENABLE);
    Set_PSC_State(PD22, LPSC_TCP3D_0, PSC_ENABLE);
    Set_PSC_State(PD22, LPSC_TCP3D_1, PSC_ENABLE);
    Set_PSC_State(PD23, LPSC_TCP3D_2, PSC_ENABLE);
    Set_PSC_State(PD23, LPSC_TCP3D_3, PSC_ENABLE);
    Set_PSC_State(PD24, LPSC_VCP_0, PSC_ENABLE);
    Set_PSC_State(PD24, LPSC_VCP_1, PSC_ENABLE);
    Set_PSC_State(PD24, LPSC_VCP_2, PSC_ENABLE);
    Set_PSC_State(PD24, LPSC_VCP_3, PSC_ENABLE);
    Set_PSC_State(PD25, LPSC_VCP_4, PSC_ENABLE);
    Set_PSC_State(PD25, LPSC_VCP_5, PSC_ENABLE);
    Set_PSC_State(PD25, LPSC_VCP_6, PSC_ENABLE);
    Set_PSC_State(PD25, LPSC_VCP_7, PSC_ENABLE);
    Set_PSC_State(PD26, LPSC_BCP, PSC_ENABLE);
    Set_PSC_State(PD27, LPSC_DXB, PSC_ENABLE);
    Set_PSC_State(PD28, LPSC_HYPERLINK_1, PSC_ENABLE);
    Set_PSC_State(PD29, LPSC_XGE, PSC_ENABLE);
    Set_PSC_State(PD31, LPSC_ARM, PSC_ENABLE);
    GEL_TextOut( "Power on all PSC modules and DSP domains... Done.\n" );
    else
    Set_Pll1() - This function executes the main PLL initialization
    sequence needed to get the main PLL up after coming out of an initial power up
    before it is locked or after it is already locked.
    Index value determines multiplier, divier used and clock reference assumed for
    output display.
    Set_Pll1(int index)
    int i, TEMP;
    unsigned int BYPASS_val;
    unsigned int BWADJ_val;
    unsigned int OD_val;
    float CLKIN_val;
    unsigned int PLLM_val;
    unsigned int PLLD_val;
    unsigned int PLLDIV3_val; //example value for SYSCLK2 (from 6614 spec) Default /2 - Fast Peripherals, (L2, MSMC, DDR3 EMIF, EDMA0...)
    unsigned int PLLDIV4_val; //example value for SYSCLK3 (from 6614 spec) Default /3 - Switch Fabric
    unsigned int PLLDIV7_val; //example value for SYSCLK6 (from 6614 spec) Defualt /6 - Slow Peripherals (UART, SPI, I2C, GPIO...)
    unsigned int debug_info_on;
    unsigned int delay;
    if(index == 1){ // 122.88 MHz -> 614.4 MHz
    CLKIN_val = 122.88; // setup CLKIN to 122.88 MHz
    PLLM_val = 10; // setup PLLM (PLL multiplier) to x10
    PLLD_val = 1; // setup PLLD (reference divider) to /1
    OD_val = 2; // setup OD to a fixed /2
    else if(index == 2){ // 122.88MHz -> 737.28 MHz
    PLLM_val = 12; // setup PLLM (PLL multiplier) to x12
    else if(index == 3){ // 122.88MHz -> 983.04 MHz
    PLLM_val = 16; // setup PLLM (PLL multiplier) to x12
    else if(index == 4){ // 122.88 MHz -> 1.2 GHz
    PLLM_val = 20; // setup PLLM (PLL multiplier) to x20
    else if(index == 5){ // 122.88 MHz -> 1.35 GHz
    PLLM_val = 22; // setup PLLM (PLL multiplier) to x22
    PLLDIV3_val = 3; // setup PLL output divider 3 to /3
    PLLDIV4_val = 5; // setup PLL output divider 4 to /3
    PLLDIV7_val = 6; // setup PLL output divider 7 to /6
    BYPASS_val = PLL1_SECCTL & ~BYPASS_MASK; // get value of the BYPASS field
    BWADJ_val = (PLLM_val) >> 1; // setup BWADJ to be 1/2 the value of PLLM
    debug_info_on = 1;
    delay = 1000; // fix this!
    /* Step 1: Unlock Boot Config Registers */
    KICK0 = KICK0_UNLOCK;
    KICK1 = KICK1_UNLOCK;
    /* Step 2: Check if SECCTL bypass is low or high indicating what state the Main PLL is currently in. if
    the Main PLL is in bypass still (not yet setup) execute the following steps. */
    if(BYPASS_val != 0x00000000){ // PLL bypass enabled - Execute PLL setup for PLL fresh out of power on reset
    if(debug_info_on){
    GEL_TextOut("Detected PLL bypass enabled: SECCTL[BYPASS] = %x\n",,,,, BYPASS_val);
    /* Step 2a: Set MAINPLLCTL1[ENSAT] = 1 - This enables proper biasing of PLL analog circuitry */
    MAINPLLCTL1 |= (1 << MAIN_ENSAT_OFFSET);
    if(debug_info_on){
    GEL_TextOut("(2a) MAINPLLCTL1 = %x\n",,,,, MAINPLLCTL1);
    /* Step 2b: Set PLLCTL[PLLEN] = 0 This enables bypass in PLL controller MUX */
    PLL1_PLLCTL &= ~(1 << PLLEN_OFFSET);
    if(debug_info_on){
    GEL_TextOut("(2b) PLLCTL = %x\n",,,,, PLL1_PLLCTL);
    /* Step 2c: Set PLLCTL[PLLENSRC] = 0 - This enables PLLEN to control PLL controller MUX */
    PLL1_PLLCTL &= ~(1 << PLLENSRC_OFFSET);
    if(debug_info_on){
    GEL_TextOut("(2c) PLLCTL = %x\n",,,,, PLL1_PLLCTL);
    /* Step 2d: Wait 4 reference clock cycles (slowest of ALTCORE or SYSCLK) to make sure
    that the PLL controller MUX switches properly to bypass. */
    if(debug_info_on){
    GEL_TextOut("(2d) Delay...\n",,,,,);
    for(i = 0; i < delay; i++); // this delay is much more than required
    /* Step 2e: Set SECCTL[BYPASS] = 1 - enables bypass in PLL MUX */
    PLL1_SECCTL |= (1 << BYPASS_OFFSET);
    if(debug_info_on){
    GEL_TextOut("(2e) SECCTL = %x\n",,,,, PLL1_SECCTL);
    /* Step 2f: Set PLLCTL[PLLPWRDN] = 1 - power down the PLL */
    PLL1_PLLCTL |= (1 << PLLPWRDN_OFFSET);
    if(debug_info_on){
    GEL_TextOut("(2f) PLLCTL = %x\n",,,,, PLL1_PLLCTL);
    /* Step 2g: Wait for at least 5us for the PLL to power down */
    if(debug_info_on){
    GEL_TextOut("(2g) Delay...\n",,,,,);
    /* Step 2h: Set PLLCTL[PLLPWRDN] = 0 - Power the PLL back up */
    PLL1_PLLCTL &= ~(1 << PLLPWRDN_OFFSET);
    if(debug_info_on){
    GEL_TextOut("(2h) PLLCTL = %x\n",,,,, PLL1_PLLCTL);
    else{ // PLL bypass disabled - Execute PLL setup for PLL that has previously been locked (skip to Step 3)
    if(debug_info_on){
    GEL_TextOut("Detected PLL bypass disabled: SECCTL[BYPASS] = %x\n",,,,, BYPASS_val);
    /* Step 3a: Set PLLCTL[PLLEN] = 0 This enables bypass in PLL controller MUX */
    if(debug_info_on){
    GEL_TextOut("(3a) PLLCTL = %x\n",,,,, PLL1_PLLCTL);
    /* Step 3b: Set PLLCTL[PLLENSRC] = 0 - This enables PLLEN to control PLL controller MUX */
    if(debug_info_on){
    GEL_TextOut("(3b) PLLCTL = %x\n",,,,, PLL1_PLLCTL);
    /* Step 3c: Wait 4 reference clock cycles (slowest of ALTCORE or SYSCLK) to make sure
    if(debug_info_on){
    GEL_TextOut("(3c) Delay...\n",,,,,);
    /* Step 4: Programming PLLM[5:0] in the PLLM register of the PLL controller and
    programming PLLM[12:6] in the MAINPLLCTL0 register */
    PLL1_PLLM &= PLLM_MASK; // clear the PLLM[5:0] bit field
    PLL1_PLLM |= ~PLLM_MASK & (PLLM_val - 1); // set the PLLM[5:0] bit field to the 6 LSB of PLLM_val
    if(debug_info_on){
    GEL_TextOut("(4)PLLM[PLLM] = %x\n",,,,, PLL1_PLLM);
    MAINPLLCTL0 &= MAIN_PLLM_MASK; // clear the PLLM[12:6] bit field
    MAINPLLCTL0 |= ~MAIN_PLLM_MASK & (( (PLLM_val - 1) >> 6) << MAIN_PLLM_OFFSET); // set the PLLM[12:6] bit field to the 7 MSB of PLL_val
    if(debug_info_on){
    GEL_TextOut("MAINPLLCTL0 = %x\n",,,,, MAINPLLCTL0);
    /* Step 5: Programming BWADJ[7:0] in the MAINPLLCTL0 register and BWADJ[11:8] in MAINPLLCTL1 register */
    MAINPLLCTL0 &= MAIN_BWADJ0_MASK; // clear the MAIN_BWADJ0 bit field
    MAINPLLCTL0 |= ~MAIN_BWADJ0_MASK & ((BWADJ_val - 1) << MAIN_BWADJ0_OFFSET); // set the MAIN_BWADJ[7:0] bit field to the 8 LSB of BWADJ_val
    if(debug_info_on){
    GEL_TextOut("(5) MAINPLLCTL0 = %x\n",,,,, MAINPLLCTL0);
    MAINPLLCTL1 &= MAIN_BWADJ1_MASK; // clear the MAIN_BWADJ1 bit field
    MAINPLLCTL1 |= ~MAIN_BWADJ1_MASK & (( (BWADJ_val - 1) >> 8) << MAIN_BWADJ1_OFFSET); // set the MAIN_BWADJ[11:8] bit field to the 4 MSB of BWADJ_val
    if(debug_info_on){
    GEL_TextOut("(5) MAINPLLCTL1 = %x\n",,,,, MAINPLLCTL1);
    /* Step 6: Programming PLLD[5:0] in the MAINPLLCTL0 register */
    MAINPLLCTL0 &= MAIN_PLLD_MASK; // clear the PLLD bit field
    MAINPLLCTL0 |= ~MAIN_PLLD_MASK & (PLLD_val - 1); // set the PLLD[5:0] bit field of PLLD to PLLD_val
    if(debug_info_on){
    GEL_TextOut("(6) MAINPLLCTL0 = %x\n",,,,, MAINPLLCTL0);
    /* Step 7: Programming OD[3:0] in the SECCTL register */
    PLL1_SECCTL &= OUTPUT_DIVIDE_MASK; // clear the OD bit field
    PLL1_SECCTL |= ~OUTPUT_DIVIDE_MASK & (OD_val - 1) << OUTPUT_DIVIDE_OFFSET; // set the OD[3:0] bit field of PLLD to OD_val
    if(debug_info_on){
    GEL_TextOut("(7) SECCTL = %x\n",,,,, PLL1_SECCTL);
    /* Step 8: Following steps are needed to change the default output dividers */
    /* Step 8a: Check that the GOSTAT bit in PLLSTAT is cleared to show that no GO
    operation is currently in progress*/
    if(debug_info_on){
    GEL_TextOut("(8a) Delay...\n",,,,,);
    while((PLL1_STAT) & 0x00000001);
    /* Step 8b: Program the RATIO field in PLLDIVn to the desired new divide-down rate.
    If RATIO field is changed, the PLL controller will flag the change in the
    corresponding bit of DCHANGE*/
    PLL1_DIV3 = (PLLDIV3_val-1) | 0x8000; //Set PLLDIV3
    PLL1_DIV4 = (PLLDIV4_val-1) | 0x8000; //Set PLLDIV4
    PLL1_DIV7 = (PLLDIV7_val-1) | 0x8000; //Set PLLDIV7
    if(debug_info_on){
    GEL_TextOut("PLL1_DIV3 = %x\n",,,,, PLL1_DIV3);
    GEL_TextOut("PLL1_DIV4 = %x\n",,,,, PLL1_DIV4);
    GEL_TextOut("PLL1_DIV7 = %x\n",,,,, PLL1_DIV7);
    /* Step 8c: Set GOSET bit in PLLCMD to initiate the GO operation to change the divide
    values and align the SYSCLKs as programmed */
    PLL1_CMD |= 0x00000001;
    /*Step 8d/e: Read the GOSTAT bit in PLLSTAT to make sure the bit returns to 0 to
    indicate that the GO operation has completed */
    if(debug_info_on){
    GEL_TextOut("(8d/e) Delay...\n",,,,,);
    /* Step 9: Set PLLCTL[PLLRST] = 1 - Assert PLL reset (Previously Step 3)*/
    PLL1_PLLCTL |= (1 << PLLRST_OFFSET);
    /* Step 10: Wait for the at least 7us for the PLL reset properly (128 CLKIN1 cycles) */
    if(debug_info_on){
    GEL_TextOut("(10) Delay...\n",,,,,);
    for(i=0;i<delay;i++);
    /* Step 11: Set PLLCTL[PLLRST] = 0 - De-Assert PLL reset */
    PLL1_PLLCTL &= ~(1 << PLLRST_OFFSET);
    /* Step 12: Wait for PLL to lock (2000 CLKIN1 cycles) */
    if(debug_info_on){
    GEL_TextOut("(12) Delay...\n",,,,,);
    /* Step 13: In SECCTL, write BYPASS = 0 (enable PLL mux to switch to PLL mode) */
    PLL1_SECCTL &= ~(1 << BYPASS_OFFSET);
    if(debug_info_on){
    GEL_TextOut("(13) SECCTL = %x\n",,,,, PLL1_SECCTL);
    if(debug_info_on){
    GEL_TextOut("(Delay...\n",,,,,);
    if(debug_info_on){
    /* Step 14: In PLLCTL, write PLLEN = 1 to enable PLL mode */
    PLL1_PLLCTL |= (1 << PLLEN_OFFSET);
    if(debug_info_on){
    GEL_TextOut("(14) PLLCTL = %x\n",,,,, PLL1_PLLCTL);
    /* Step 15: Lock Boot Config Registers */
    KICK0 = 0x00000000;
    KICK1 = 0x00000000;
    GEL_TextOut("PLL has been configured (CLKIN * PLLM / PLLD / PLLOD = PLLOUT):\n",,,,,);
    GEL_TextOut("PLL has been configured (%f MHz * %d / %d / 2 = %f MHz)\n",,,,, CLKIN_val, PLLM_val, PLLD_val, (CLKIN_val * PLLM_val / PLLD_val / 2) );
    Set_Tetris_Pll(int index)
    float CLKIN_val;
    int i;
    GEL_TextOut("Switching on ARM Core 0\n",,,,,);
    TETRIS_CPU0_PDCTL = 0x00000000;
    TETRIS_CPU0_PTCMD = 0x00000001;
    GEL_TextOut("Switching on ARM Core 1\n",,,,,);
    TETRIS_CPU1_PDCTL = 0x00000000;
    TETRIS_CPU1_PTCMD = 0x00000001;
    GEL_TextOut("Switching on ARM Core 2\n",,,,,);
    TETRIS_CPU2_PDCTL = 0x00000000;
    TETRIS_CPU2_PTCMD = 0x00000001;
    GEL_TextOut("Switching on ARM Core 3\n",,,,,);
    TETRIS_CPU3_PDCTL = 0x00000000;
    TETRIS_CPU3_PTCMD = 0x00000001;
    if(index == 1){ // 100 MHz -> 1.0 GHz
    CLKIN_val = 125; // setup CLKIN to 125 MHz
    PLLM_val = 16; // setup PLLM (PLL multiplier) to x20
    else if(index == 2){ // 100 MHz -> 1.4 GHz
    PLLM_val = 22; // setup PLLM (PLL multiplier) to x28
    else if(index == 3){ // 174.825MHz -> 1.4 GHz
    CLKIN_val = 174.825; // setup CLKIN to 174.825 MHz
    PLLM_val = 16; // setup PLLM (PLL multiplier) to x16
    BWADJ_val = (PLLM_val-1) >> 1; // setup BWADJ to be 1/2 the value of PLLM
    //Step 1 : Assert SEC PLL Reset
    SECPLLCTL1 = ((1 << SEC_PLLCTL1_RESET_OFFSET) | (1 << SEC_PLLCTL1_ENSTAT_OFFSET));
    //Step 2 : Change CLKF/OD/BWADJ etc. for SEC PLL
    SECPLLCTL0 = ((BWADJ_val << SEC_PLLCTL0_BWADJ_OFFSET) |
    ((OD_val-1) << SEC_PLLCTL0_OD_OFFSET)|
    ((PLLM_val-1) << SEC_PLLCTL0_PLLM_OFFSET));
    //Step 3 : Make sure the resets are held for 5us
    for(i = 0; i < 200000; i++);
    //Step 4 : Remove SEC PLL reset
    SECPLLCTL1 = (1 << SEC_PLLCTL1_ENSTAT_OFFSET);
    //Step 5 : Wait for PLL to lock (4000 CLKIN1 cycles)
    for(i = 0; i < 4000; i++);
    //Step 6 : Get the PLL out of Bypass
    //SECPLLCTL0 &= ~(1 << SEC_PLLCTL0_BYPASS_OFFSET);
    CHIP_MISC1 |= (1 << ARMPLL_ENABLE_OFFSET);
    //Step 6 : Lock Boot Config Registers
    KICK0 = 0x00000000;
    KICK1 = 0x00000000;
    GEL_TextOut("ARM PLL has been configured (%f MHz * %d / %d = %f MHz)\n",,,,, CLKIN_val, PLLM_val, OD_val, (CLKIN_val * PLLM_val)/OD_val);
    /* Set the desired PA PLL configuration */
    PaPllConfig()
    unsigned int passclksel = (DEVSTAT & PASSCLKSEL_MASK);
    unsigned int papllctl0val_orig = PAPLLCTL0;
    unsigned int papllctl1val_orig = PAPLLCTL1;
    unsigned int papllctl0val_final;
    unsigned int papllctl1val_final;
    unsigned int papllclkf = 16; //204; // 204; 20 (if PASSREFCLK == 100mhz) Multiply by clkf + 1
    unsigned int papllclkd = 0; //11; // 11; 1 (if PASSREFCLK == 100mhz) Divide by clkd + 1
    unsigned int i = 0;
    if (passclksel != PASSCLKSEL_MASK) GEL_TextOut("WARNING: SYSCLK is the input to the PA PLL.\n");
    /* Unlock Chip Level Registers */
    // PAPLLCTL1 = PAPLLCTL1 | 0x00000040; //Set ENSAT = 1; Set PLL Select to 0 (for SYCLK0 as input of PASS)
    PAPLLCTL1 = PAPLLCTL1 | 0x00002040; //Set ENSAT = 1; Set PLL Select to 1 (for PA PLL as input of PASS)
    /*in PAPLLCTL0, clear bypass bit to set the PA PLL in Bypass Mode*/
    //PAPLLCTL0 &= ~(1<<BYPASS_BIT_SHIFT); // Not setting Bypass bit
    PAPLLCTL0 |= (1<<BYPASS_BIT_SHIFT); // Actually setting bypass bit
    /*Wait 4 cycles for the slowest of PLLOUT or reference clock source (CLKIN)*/
    for(i=0;i<100;i++);
    /*In PAPLLCTL1, write PLL reset bit to put the PLL in reset*/
    PAPLLCTL1 |= PA_PLL_RESET_MASK;
    /* Program the multiplier value */
    PAPLLCTL0 &= (~PA_PLL_CLKF_MASK); //clear multiplier value
    PAPLLCTL0 &= (~PA_PLL_CLKR_MASK); //clear divider value
    PAPLLCTL0 |= (papllclkf<<CLKF_BIT_SHIFT); // set PLLM
    PAPLLCTL0 |= (papllclkd<<CLKD_BIT_SHIFT); // set PLLD
    PAPLLCTL0 &= 0x00FFFFFF;
    PAPLLCTL0 |= ((((papllclkf + 1)>>1)-1)<<24);
    //PAPLLCTL1 = PAPLLCTL1 | 0x00002000;
    /*Wait for PLL to properly reset (128 CLKIN1 cycles) */
    for(i=0;i<1000;i++);
    /* take the PA PLL out of reset */
    PAPLLCTL1 &= (~PA_PLL_RESET_MASK);
    /*Wait for PLL to lock (2000 CLKIN1 cycles) */
    for(i=0;i<5000;i++);
    /* enable PLL mode */
    PAPLLCTL0 &= ~(1<<BYPASS_BIT_SHIFT); // actually setting PLL MODE
    for(i=0;i<4000;i++);
    /* Lock Chip Level Registers */
    KICK0 = KICK_LOCK;
    KICK1 = KICK_LOCK;
    papllctl0val_final = PAPLLCTL0;
    papllctl1val_final = PAPLLCTL1;
    GEL_TextOut("Completed PA PLL Setup\n");
    GEL_TextOut("PAPLLCTL0 - before: 0x%x\t after: 0x%x\n",,,,, papllctl0val_orig, papllctl0val_final);
    GEL_TextOut("PAPLLCTL1 - before: 0x%x\t after: 0x%x\n",,,,, papllctl1val_orig, papllctl1val_final);
    if ((papllctl0val_final != 0x09080500) || (papllctl1val_final != 0x00002040))
    return 1;
    return 0;
    //--------DDR3A Memory test----------------------
    ddr3A_memory_test ()
    unsigned int index, value;
    GEL_TextOut( "DDR3A memory test... Started\n" );
    /* Write a pattern */
    for (index = DDR3A_TEST_START_ADDRESS; index < DDR3A_TEST_END_ADDRESS; index += 4) {
    *index = index;
    /* Read and check the pattern */
    value = *index;
    if (value != index) {
    GEL_TextOut( "DDR3A memory test... Failed\n" );
    return -1;
    /* Write a pattern for complementary values */
    *index = ~index;
    value = *index;
    if (value != ~index) {
    return -1;
    GEL_TextOut( "DDR3A memory test... Passed\n" );
    return 0;
    //--------DDR3B Memory test----------------------
    ddr3B_memory_test ()
    GEL_TextOut( "DDR3B memory test... Started\n" );
    for (index = DDR3B_TEST_START_ADDRESS; index < DDR3B_TEST_END_ADDRESS; index += 4) {
    *index = index;
    value = *index;
    GEL_TextOut( "DDR3B memory test... Failed\n" );
    return -1;
    *index = ~index;
    value = *index;
    return -1;
    GEL_TextOut( "DDR3B memory test... Passed\n" );
    return 0;
    * NAME
    * Setup_Memory_Map
    * PURPOSE:
    * Setup the Memory Map for EVMC6678L.
    * Defined memory location avoid debugger access outside these locations.
    * USAGE
    * Setup_Memory_Map()
    * RETURN VALUE
    * NONE
    * REFERENCE
    * Based on TMS320C6678 datasheet.
    hotmenu Setup_Memory_Map( )
    GEL_TextOut("Setup_Memory_Map...\n",,);
    GEL_MapOn( );
    GEL_MapReset( );
    GEL_MapAddStr( 0x00000000, 0, 0x21400000, "R|W|AS4", 0 ); //
    GEL_MapAddStr( 0x21400000,0, 0x00000080, "R|W|AS4", 0 ); // Hyperlink Config (remote)
    //GEL_MapAddStr( 0x21400080,0, 0x00000080, "R|W|AS4", 0 ); // Hyperlink Config (remote)
    GEL_MapAddStr( 0x21400200, 0, 0xdebffe00, "R|W|AS4", 0 ); //
    GEL_TextOut( "Setup_Memory_Map... Done.\n" );
    /*----------------------------------------------------- DDR3A : DDR800, 32bit--------------------------------------------------------------------------*/
    ddr3A_32bit_DDR800_setup()
    unsigned int multiplier = 15;
    unsigned int divider = 0;
    int temp;
    unsigned int OD_val = 8;
    KICK0 = 0x83E70B13;
    KICK1 = 0x95A4F1E0;
    //1. Poll for IDONE=1 in the PHY General Status Register 0 (address offset 0x010).
    do {
    read_val = DDR3A_PGSR0;
    } while ((read_val&0x00000001) != 0x00000001);
    //4. Clocks are enabled and frequency is stable---------------------------------------
    //DDR3A PLL setup
    GEL_TextOut ( "DDR3 PLL (PLL2) Setup ... \n");
    //DDR3APLLCTL0 = DDR3APLLCTL0 & 0xFF7FFFFF;
    // Set ENSAT = 1
    DDR3APLLCTL1 |= 0x00000040;
    // Put the PLL in PLL Mode
    DDR3APLLCTL0 |= 0x00800000;
    // In PLL Controller, reset the PLL (bit 13 in DDR3APLLCTL1 register)
    DDR3APLLCTL1 |= 0x00002000;
    // Program the necessary multipliers/dividers and BW adjustments
    // Set the divider values
    DDR3APLLCTL0 &= ~(0x0000003F);
    DDR3APLLCTL0 |= (divider & 0x0000003F);
    DDR3APLLCTL0 &= OUTPUT_DIVIDE_MASK; // clear the OD bit field
    DDR3APLLCTL0 |= ~OUTPUT_DIVIDE_MASK & (OD_val - 1) << OUTPUT_DIVIDE_OFFSET; // set the OD[3:0] bit field of PLLD to OD_val
    /* Set the Multipler values */
    DDR3APLLCTL0 &= ~(0x0007FFC0);
    DDR3APLLCTL0 |= ((multiplier << 6) & 0x0007FFC0 );
    temp = ((multiplier + 1) >> 1) - 1;
    DDR3APLLCTL0 &= ~(0xFF000000);
    DDR3APLLCTL0 |= ((temp << 24) & 0xFF000000);
    DDR3APLLCTL1 &= ~(0x0000000F);
    DDR3APLLCTL1 |= ((temp >> 8) & 0x0000000F);
    //In DDR3PLLCTL1, write PLLRST = 0 to bring PLL out of reset
    DDR3APLLCTL1 &= ~(0x00002000);
    DDR3APLLCTL0 &= ~(0x00800000); // ReSet the Bit 23
    GEL_TextOut( "DDR3 PLL Setup complete, DDR3A clock now running at 400MHz.\n" );
    //DDR3A PLL setup complete ---------------------------------------
    /*------------------------- Start PHY Configuration -------------------------------*/
    //DDR3A_PGCR1 = 0x0280C487;
    //5.a Program FRQSEL in the PLL Control Register (address offset 0x018).
    DDR3A_PLLCR = 0xDC000; //Set FRQSEL=11, for ctl_clk between 166-275MHz
    //5.b. Program WLSTEP=1, IODDRM=1, and ZCKSEL in the PHY General Configuration Register 1 (address offset 0x00C).
    DDR3A_PGCR1 |= (1 << 2); //WLSTEP = 1
    DDR3A_PGCR1 &= ~(IODDRM_MASK);
    DDR3A_PGCR1 |= (( 1 << 7) & IODDRM_MASK);
    DDR3A_PGCR1 &= ~(ZCKSEL_MASK);
    DDR3A_PGCR1 |= (( 1 << 23) & ZCKSEL_MASK);
    //5.c. Program PHY Timing Parameters Register 0-4 (address offset 0x01C - 0x02C).
    DDR3A_PTR0 = 0x42C21590;
    DDR3A_PTR1 = 0xD05612C0;
    // Maintaining default values of Phy Timing Parameters Register 2 in PUB
    DDR3A_PTR3 = 0x06C30D40;//0x18061A80;
    DDR3A_PTR4 = 0x06413880;//0x0AAE7100;
    //5.d. Program PDQ, MPRDQ, and BYTEMASK in the DRAM Configuration Register (address offset 0x044).
    // All other fields must be left at their default values.
    DDR3A_DCR &= ~(PDQ_MASK); //PDQ = 0
    DDR3A_DCR &= ~(MPRDQ_MASK); //MPRDQ = 0
    DDR3A_DCR &= ~(BYTEMASK_MASK);
    DDR3A_DCR |= (( 1 << 10) & BYTEMASK_MASK);
    DDR3A_DCR &= ~(NOSRA_MASK);
    DDR3A_DCR |= (( 1 << 27) & NOSRA_MASK);
    DDR3A_DCR &= ~(UDIMM_MASK);
    DDR3A_DCR |= (( 1 << 29) & UDIMM_MASK);
    //5.e. Program DRAM Timing Parameters Register 0-2 (address offset 0x048 - 0x050).
    DDR3A_DTPR0 = 0x50CF6644; //0x50CE6644;
    DDR3A_DTPR1 = 0x12834180;
    DDR3A_DTPR2 = 0x50022A00;
    //5.f. Program BL=0, CL, WR, and PD=1 in the Mode Register 0 (address offset 0x054).
    //All other fields must be left at their default values.
    DDR3A_MR0 = 0x00001420;
    //5.g. Program DIC, RTT, and TDQS in the Mode Register 1 (address offset 0x058).
    DDR3A_MR1 = 0x00000006;
    //5.h. Program Mode Register 2 (address offset 0x05C).
    // Maintaining default values of Program Mode Register 2
    // DDR3A_MR2 = 0x00000018;
    //5.i. Program DTMPR=1, DTEXD, DTEXG, RANKEN=1 or 3, and RFSHDT=7 in the Data Training Configuration Register (address offset 0x068).
    DDR3A_DTCR = 0x710035C7; //0x710035C7;
    //5.j. Program tREFPRD=(5*tREFI/ddr_clk_period) in the PHY General Configuration Register 2 (address offset 0x08C).
    DDR3A_PGCR2 = 0x00F03D09; //NOBUB = 0, FXDLAT = 0
    //DDR3A_PGCR2 = 0x00F83D09; //NOBUB = 0, FXDLAT = 1
    //Set Impedence Register
    DDR3A_ZQ0CR1 = 0x0000005D;
    DDR3A_ZQ1CR1 = 0x0000005B;
    DDR3A_ZQ2CR1 = 0x0000005B;
    //6. Re-trigger PHY initialization in DDR PHY through the VBUSP interface.
    //6.a. Program 0x00000033 to the PHY Initialization Register (address offset 0x004) to re-trigger PLL, ZCAL, and DCAL initialization.
    DDR3A_PIR = 0x00000033;
    //6.b. Poll for IDONE=1 in the PHY General Status Register 0 (address offset 0x010).
    do {
    // 7. Trigger DDR3 initialization and leveling/training in DDR PHY through the VBUSP interface.
    // a. If using a 16-bit wide DDR interface, program DXEN=0 in the DATX8 2-7 General Configuration Registers (address offsets 0x240, 0x280, 0x2C0, 0x300, 0x340, and 0x380) to disable the leveling/training for the upper byte lanes.
    // b. If using a 32-bit wide DDR interface, program DXEN=0 in the DATX8 4-7 General Configuration Registers (address offsets 0x2C0, 0x300, 0x340, and 0x380) to disable the leveling/training for the upper byte lanes.
    // c. If ECC is not required, program DXEN=0 in the DATX8 8 General Configuration Register (address offset 0x3C0) to disable the leveling/training for the ECC byte lane.
    // NOTE: Setup supports 64-bit by default, ECC enable by default.
    //7.d. Program 0x0000XF81 to the PHY Initialization Register (address offset 0x004) to trigger DDR3 initialization and leveling/training sequences
    DDR3A_PIR = 0x00000F81; //WLADJ - ON
    //DDR3A_PIR = 0x00000781; //WLADJ - OFF
    //7.e. Poll for IDONE=1 in the PHY General Status Register 0 (address offset 0x010).
    do {
    /* End PHY Configuration */
    /* START EMIF INITIALIZATION
    ++++++++++++++++++SDCFG Register Calculation+++++++++++++++++++
    | 31 - 29 | 28 |27 - 25 | 24 | 23 - 22| 21 - 17 |
    |SDRAM_TYPE|Rsvd|DDR_TERM| DDQS | DYN_ODT| Rsvd |
    | 0x011 | 0 | 0x011 | 0x1 | 0x00 | 0x0 |
    | 16-14 |13 - 12 | 11 - 8 | 7 |6 - 5 | 4 | 3 | 2 | 1 - 0 |
    | CWL | NM | CL | Rsvd |IBANK | Rsvd|EBANK| Rsvd|PAGE_SIZE|
    | 0x11 | 0x00 | 0x1110 | 0x0 | 0x11 | 0x0 | 0 | 0 | 0x10 |
    SDCFG = 0x0110 0011 0010 0010 0011 0011 1011 0010
    SDCFG = 0x6700486A;//0x63223332
    SDRAM_TYPE = 3
    DDR_TERM = 3 (RZQ/4 = 1; RZQ/6=3)
    DDQS = 1
    DYN_ODT = 0
    CWL = 3 (CWL5=0; CWL6=1; CWL7=2; CWL8=3)
    NM = 0 (64-bit=0, 32-bit=1, 16-bit=2)
    CL = 14 (CL5=2; CL6=4; CL7=6; CL8=8; CL9=10; CL10=12; CL11=14)
    IBANK = 3 (8bank)
    EBANK = 0 (0 - pad_cs_o_n[0] , 1 - pad_cs_o_n[1:0])
    PAGE_SIZE = 2 (1024page-size=2; 2048page-size=3)
    /* Start DDR3A EMIF Configuration */
    //8. Configure the EMIF through the VBUSM interface.
    //8.a. Program all EMIF MMR’s.
    DDR3A_SDCFG = 0x62001462 ; //0x6200046A
    DDR3A_SDTIM1 = 0x0A384C23;
    DDR3A_SDTIM2 = 0x00001CA5;
    DDR3A_SDTIM3 = 0x21ADFF32;
    DDR3A_SDTIM4 = 0x533F067F;
    DDR3A_ZQCFG = 0xF0073200;
    //8.b. Program reg_initref_dis=0 in the SDRAM Refresh Control Register (address offset 0x10).
    DDR3A_SDRFC = 0x00000C34;
    GEL_TextOut("DDR3A initialization complete \n");
    /* End DDR3A EMIF Configuration */
    /*----------------------------------------------------- DDR3A : DDR1066, 32bit--------------------------------------------------------------------------*/
    ddr3A_32bit_DDR1066_setup()
    int temp;
    unsigned int OD_val = 6;
    KICK0 = 0x83E70B13;
    KICK1 = 0x95A4F1E0;
    do {
    //DDR3A PLL setup
    // Set ENSAT = 1
    GEL_TextOut( "DDR3 PLL Setup complete, DDR3A clock now running at 533MHz.\n" );
    DDR3A_PTR3 = 0x05B41104;//0x09041104;//0x18061A80;
    DDR3A_PTR4 = 0x0855A068;//0x0AAE7100;
    //DDR3A_DCR &= ~(UDIMM_MASK);
    //DDR3A_DCR |= (( 1 << 29) & UDIMM_MASK);
    //RRMODE
    //DDR3A_DSGCR &= ~(RRMODE_MASK); //RR_MODE = 0
    //DDR3A_DSGCR &= ~(RRMODE_MASK); //RR_MODE = 1
    //DDR3A_DSGCR |= (( 1 << 18) & RRMODE_MASK);
    DDR3A_DTPR0 = 0x6D147764;//0x6D148844; //0x6D148844; 0x69137764 ---changed in rev 1.3
    DDR3A_DTPR1 = 0x1282B200;//0x12845A00;
    DDR3A_DTPR2 = 0x50023600;
    DDR3A_MR0 = 0x00001830; //0x00001870;
    DDR3A_MR1 = 0x00000006; //0x00000044; ---changed in rev 1.3
    DDR3A_MR2 = 0x00000008; //18 ---changed in rev 1.3
    DDR3A_DTCR = 0x710035C7; //0x730035C7;
    DDR3A_PGCR2 = 0x00F05159; //NOBUB = 0, FXDLAT = 0
    do {
    do {
    SDRAM_TYPE = 3
    DDQS = 1
    DYN_ODT = 0
    IBANK = 3 (8bank)
    DDR3A_SDCFG = 0x62005662; //0x62005662;
    DDR3A_SDTIM1 = 0x0E4C6835; //0x0E4C6833;//0x0E4C6833;
    DDR3A_SDTIM2 = 0x00001CC6; //0x00001CE7;
    DDR3A_SDTIM3 = 0x3169FF32; //0x323DFF32;
    DDR3A_SDTIM4 = 0x533F055F; //0x533F08AF;
    DDR3A_ZQCFG = 0x70073200;//0xF0073200;
    DDR3A_SDRFC = 0x00001044;
    /*----------------------------------------------------- DDR3A : DDR1333, 32bit--------------------------------------------------------------------------*/
    unsigned int multiplier = 19;
    int temp;
    KICK0 = 0x83E70B13;
    KICK1 = 0x95A4F1E0;
    do {
    //DDR3A PLL setup
    // Set ENSAT = 1
    GEL_TextOut( "DDR3 PLL Setup complete, DDR3A clock now running at 666 MHz.\n" );
    DDR3A_PLLCR = 0x5C000; //Set FRQSEL=11, for ctl_clk between 166-275MHz
    DDR3A_PTR3 = 0x0B4515C2;//0x072515C2; //0x0B4515C2;//0x18061A80;
    DDR3A_PTR4 = 0x0A6E08B4;//0x0AAE7100;
    DDR3A_DTPR0 = 0x8558AA75;//0x85589975;//0x8558AA55;
    DDR3A_DTPR1 = 0x12857280;//0x12835A80;//0x12857280;
    DDR3A_DTPR2 = 0x5002C200;
    DDR3A_MR0 = 0x00001A60; //50
    DDR3A_MR2 = 0x00000010;
    DDR3A_PGCR2 = 0x00F065B8; //NOBUB = 0, FXDLAT = 0
    //DDR3A_ZQ3CR1 = 0x0000005D;
    do {
    DDR3A_PIR = 0x0000FF81; //WLADJ - ON
    do {
    SDRAM_TYPE = 3
    DDQS = 1
    DYN_ODT = 0
    IBANK = 3 (8bank)
    DDR3A_SDCFG = 0x62009C62; // 9A62//0x62008C62 ;//0x6600CE62=single rank,0x6600CE6A=dual rank
    DDR3A_SDTIM1 = 0x125C8044;
    DDR3A_SDTIM2 = 0x00001D29;
    DDR3A_SDTIM3 = 0x32CDFF43;
    DDR3A_SDTIM4 = 0x543F0ADF;
    DDR3A_SDRFC = 0x00001457;
    /*----------------------------------------------------- DDR3B : DDR800, 64bit--------------------------------------------------------------------------*/
    ddr3B_64bit_DDR800_setup()
    int temp;
    KICK0 = 0x83E70B13;
    KICK1 = 0x95A4F1E0;
    do {
    read_val = DDR3B_PGSR0;
    //DDR3B PLL setup
    //DDR3BPLLCTL0 = DDR3BPLLCTL0 & 0xFF7FFFFF;
    // Set ENSAT = 1
    DDR3BPLLCTL1 |= 0x00000040;
    DDR3BPLLCTL0 |= 0x00800000;
    // In PLL Controller, reset the PLL (bit 13 in DDR3BPLLCTL1 register)
    DDR3BPLLCTL1 |= 0x00002000;
    DDR3BPLLCTL0 &= ~(0x0000003F);
    DDR3BPLLCTL0 |= (divider & 0x0000003F);
    DDR3BPLLCTL0 &= OUTPUT_DIVIDE_MASK; // clear the OD bit field
    DDR3BPLLCTL0 |= ~OUTPUT_DIVIDE_MASK & (OD_val - 1) << OUTPUT_DIVIDE_OFFSET; // set the OD[3:0] bit field of PLLD to OD_val
    DDR3BPLLCTL0 &= ~(0x0007FFC0);
    DDR3BPLLCTL0 |= ((multiplier << 6) & 0x0007FFC0 );
    DDR3BPLLCTL0 &= ~(0xFF000000);
    DDR3BPLLCTL0 |= ((temp << 24) & 0xFF000000);
    DDR3BPLLCTL1 &= ~(0x0000000F);
    DDR3BPLLCTL1 |= ((temp >> 8) & 0x0000000F);
    DDR3BPLLCTL1 &= ~(0x00002000);
    DDR3BPLLCTL0 &= ~(0x00800000); // ReSet the Bit 23
    GEL_TextOut( "DDR3 PLL Setup complete, DDR3B clock now running at 400MHz.\n" );
    //DDR3B PLL setup complete ---------------------------------------
    //DDR3B_PGCR1 = 0x0280C487;
    DDR3B_PLLCR = 0xDC000; //Set FRQSEL=11, for ctl_clk between 166-275MHz
    DDR3B_PGCR1 |= (1 << 2); //WLSTEP = 1
    DDR3B_PGCR1 &= ~(IODDRM_MASK);
    DDR3B_PGCR1 |= (( 1 << 7) & IODDRM_MASK);
    DDR3B_PGCR1 &= ~(ZCKSEL_MASK);
    DDR3B_PGCR1 |= (( 1 << 23) & ZCKSEL_MASK);
    //RRMODE
    //DDR3B_DSGCR &= ~(RRMODE_MASK); //RR_MODE = 0
    //DDR3B_DSGCR &= ~(RRMODE_MASK); //RR_MODE = 1
    //DDR3B_DSGCR |= (( 1 << 18) & RRMODE_MASK);
    DDR3B_PTR0 = 0x42C21590;
    DDR3B_PTR1 = 0xD05612C0;
    DDR3B_PTR3 = 0x06C30D40;//0x18061A80;
    DDR3B_PTR4 = 0x6413880;//0x0AAE7100;
    DDR3B_DCR &= ~(PDQ_MASK); //PDQ = 0
    DDR3B_DCR &= ~(MPRDQ_MASK); //MPRDQ = 0
    DDR3B_DCR &= ~(BYTEMASK_MASK);
    DDR3B_DCR |= (( 1 << 10) & BYTEMASK_MASK);
    DDR3B_DCR &= ~(NOSRA_MASK);
    DDR3B_DCR |= (( 1 << 27) & NOSRA_MASK);
    //DDR3B_DCR &= ~(UDIMM_MASK);
    //DDR3B_DCR |= (( 1 << 29) & UDIMM_MASK);
    DDR3B_DTPR0 = 0x50CE6644;
    DDR3B_DTPR1 = 0x12834180;
    DDR3B_DTPR2 = 0x50022A00;
    DDR3B_MR0 = 0x00001420;
    DDR3B_MR1 = 0x00000006;
    // DDR3B_MR2 = 0x00000018;
    DDR3B_DTCR = 0x710035C7; //0x710035C7;
    DDR3B_PGCR2 = 0x00F03D09; //NOBUB = 0, FXDLAT = 0
    //DDR3B_PGCR2 = 0x00F83D09; //NOBUB = 0, FXDLAT = 1
    DDR3B_ZQ0CR1 = 0x0000005D;
    DDR3B_ZQ1CR1 = 0x0000005B;
    DDR3B_ZQ2CR1 = 0x0000005B;
    DDR3B_PIR = 0x00000033;
    do {
    DDR3B_PIR = 0x00000F81; //WLADJ - ON
    //DDR3B_PIR = 0x00000781; //WLADJ - OFF
    do {
    SDRAM_TYPE = 3
    DDQS = 1
    DYN_ODT = 0
    IBANK = 3 (8bank)
    /* Start DDR3B EMIF Configuration */
    DDR3B_SDCFG = 0x62000462 ;
    DDR3B_SDTIM1 = 0x0A384C23;
    DDR3B_SDTIM2 = 0x00001CA5;
    DDR3B_SDTIM3 = 0x21ADFF32;
    DDR3B_SDTIM4 = 0x533F067F;
    DDR3B_ZQCFG = 0xF0073200;
    DDR3B_SDRFC = 0x00000C34;
    GEL_TextOut("DDR3B initialization complete \n");
    /* End DDR3B EMIF Configuration */
    /*----------------------------------------------------- DDR3B : DDR1066, 64bit--------------------------------------------------------------------------*/
    ddr3B_64bit_DDR1066_setup()
    int temp;
    KICK0 = 0x83E70B13;
    KICK1 = 0x95A4F1E0;
    do {
    //DDR3B PLL setup
    // Set ENSAT = 1
    GEL_TextOut( "DDR3 PLL Setup complete, DDR3B clock now running at 533MHz.\n" );
    DDR3B_PTR3 = 0x09041104;//0x18061A80;
    DDR3B_PTR4 = 0x0855A068;//0x0AAE7100;
    DDR3B_DTPR0 = 0x6D148844;
    DDR3B_DTPR1 = 0x12845A00;
    DDR3B_DTPR2 = 0x50023600;
    DDR3B_MR0 = 0x00001830; //0x00001870
    DDR3B_MR2 = 0x00000008;
    DDR3B_DTCR = 0x710035C7; //0x730035C7;
    DDR3B_PGCR2 = 0x00F05159; //NOBUB = 0, FXDLAT = 0
    do {
    do {
    SDRAM_TYPE = 3
    DDQS = 1
    DYN_ODT = 0
    IBANK = 3 (8bank)
    DDR3B_SDCFG = 0x62004662; //0x6600CE62=single rank, 0x6600CE6A=dual rank
    DDR3B_SDTIM1 = 0x0E4C6833;
    DDR3B_SDTIM2 = 0x00001CE7;
    DDR3B_SDTIM3 = 0x323DFF32;
    DDR3B_SDTIM4 = 0x533F08AF;
    DDR3B_SDRFC = 0x00001044;
    /*----------------------------------------------------- DDR3B : DDR1333, 64bit--------------------------------------------------------------------------*/
    ddr3B_64bit_DDR1333_setup()
    int temp;
    KICK0 = 0x83E70B13;
    KICK1 = 0x95A4F1E0;
    do {
    //DDR3B PLL setup
    // Set ENSAT = 1
    GEL_TextOut( "DDR3 PLL Setup complete, DDR3B clock now running at 666 MHz.\n" );
    DDR3B_PLLCR = 0x5C000; //Set FRQSEL=11, for ctl_clk between 166-275MHz
    DDR3B_PTR3 = 0x0B4515C2;//0x18061A80;
    DDR3B_PTR4 = 0x0A6E08B4;//0x0AAE7100;
    // DDR3B_DCR &= ~(UDIMM_MASK);
    // DDR3B_DCR |= (( 1 << 29) & UDIMM_MASK);
    DDR3B_DTPR0 = 0x8558AA55;
    DDR3B_DTPR1 = 0x12857280;
    DDR3B_DTPR2 = 0x5002C200;
    DDR3B_MR0 = 0x00001A60;
    DDR3B_MR2 = 0x00000010;
    DDR3B_PGCR2 = 0x00F065B8; //NOBUB = 0, FXDLAT = 0
    //DDR3B_ZQ3CR1 = 0x0000005D;
    do {
    DDR3B_PIR = 0x0000FF81; //WLADJ - ON
    do {
    SDRAM_TYPE = 3
    DDQS = 1
    DYN_ODT = 0
    IBANK = 3 (8bank)
    DDR3B_SDCFG = 0x62008C62 ;//0x6600CE62=single rank,0x6600CE6A=dual rank
    DDR3B_SDTIM1 = 0x125C8044;
    DDR3B_SDTIM2 = 0x00001D29;
    DDR3B_SDTIM3 = 0x32CDFF43;
    DDR3B_SDTIM4 = 0x543F0ADF;
    DDR3B_SDRFC = 0x00001457;
    /*----------------------------------------------------- DDR3B : DDR1600, 64bit--------------------------------------------------------------------------*/
    int temp;
    unsigned int OD_val = 4;
    KICK0 = 0x83E70B13;
    KICK1 = 0x95A4F1E0;
    do {
    //DDR3B PLL setup
    GEL_TextOut ( "DDR3 PLL Setup ... \n");
    // Set ENSAT = 1
    //DDR3BPLLCTL0 &= ~(0x00780000);
    //DDR3BPLLCTL0 |= ((OD_val << 19)& 0x00780000);
    GEL_TextOut( "DDR3 PLL Setup complete, DDR3B clock now running at 800MHz.\n" );
    DDR3B_PLLCR = 0x1C000; //Set FRQSEL=11, for ctl_clk between 166-275MHz
    DDR3B_PTR3 = 0x0D861A80;//
    DDR3B_PTR4 = 0x0C827100;
    DDR3B_DTPR0 = 0xA19DBB66;
    DDR3B_DTPR1 = 0x12868300;
    DDR3B_DTPR2 = 0x50035200;
    DDR3B_MR0 = 0x00001C70; //-CL - 11, CWL -8
    DDR3B_PGCR2 = 0x00F07A12; //NOBUB = 0, FXDLAT = 0
    //DDR3B_DATX8_8 &= ~(ECC_MASK);
    do {
    do {
    SDRAM_TYPE = 3
    DDQS = 1
    DYN_ODT = 0
    IBANK = 3 (8bank)
    DDR3B_SDCFG = 0x6200CE62 ;//0x66004862=single rank, 0x6600486A=dual rank CL- 11
    DDR3B_SDTIM1 = 0x16709C55;
    DDR3B_SDTIM2 = 0x00001D4A;
    DDR3B_SDTIM3 = 0x435DFF54;
    DDR3B_SDTIM4 = 0x553F0CFF;
    DDR3B_SDRFC = 0x00001869;
    /* TCI66x MENU */
    menuitem "TCI66x Functions";
    * NAME
    * PURPOSE:
    * USAGE
    * Global_Default_Setup()
    * RETURN VALUE
    * NONE
    * REFERENCE
    hotmenu Global_Default_Setup()
    GEL_TextOut( "Global Default Setup...\n" );
    GEL_TextOut( "Global Default Setup... Done.\n" );
    hotmenu Reset()
    GEL_Reset();
    hotmenu InitXMC()
    xmc_setup();
    hotmenu CORE_PLL_INIT_122_88MHZ_to_614_4MHz()
    Set_Pll1(1); // call Set_Pll1 with index = 1 -> 122.88 MHz to 614.4 MHz operation
    hotmenu CORE_PLL_INIT_122_88MHZ_to_737_28MHz()
    Set_Pll1(2); // call Set_Pll1 with index = 2 -> 122.88 MHz to 737.28 MHz operation
    hotmenu CORE_PLL_INIT_122_88MHZ_to_983_04MHz()
    hotmenu CORE_PLL_INIT_122_88MHZ_to_1_2GHz()
    Set_Pll1(4); // call Set_Pll1 with index = 4 -> 122.88 MHz to 1.2 GHz operation
    hotmenu CORE_PLL_INIT_122_88MHZ_to_1_3Gz()
    Set_Pll1(5); // call Set_Pll1 with index = 4 -> 122.88 MHz to 1.2 GHz operation
    hotmenu TETRIS_POWERUP_AND_PLL_INIT_100MHZ_to_1000MHz()
    Set_Tetris_Pll(1); // 100 MHz to 1.0 GHz operation
    hotmenu TETRIS_POWERUP_AND_PLL_INIT_100MHZ_to_1400MHz()
    Set_Tetris_Pll(2); // 100 MHz to 1.4 GHz operation
    hotmenu TETRIS_POWERUP_AND_PLL_INIT_175MHZ_to_1400MHz()
    Set_Tetris_Pll(3); // 175 MHz to 1.4 GHz operation
    hotmenu PA_PLL_COnfig()
    PaPllConfig();
    hotmenu InitDDR3A_32bit_DDR800()
    ddr3A_32bit_DDR800_setup();
    hotmenu InitDDR3A_32bit_DDR1066()
    ddr3A_32bit_DDR1066_setup();
    hotmenu InitDDR3A_32bit_DDR1333()
    hotmenu InitDDR3B_64bit_DDR800()
    ddr3B_64bit_DDR800_setup();
    hotmenu InitDDR3B_64bit_DDR1066()
    ddr3B_64bit_DDR1066_setup();
    hotmenu InitDDR3B_64bit_DDR1333()
    ddr3B_64bit_DDR1333_setup();
    hotmenu InitDDR3B_64bit_DDR1600()
    ///* Function to enable CORE PLL observation clock for PLL output *///
    hotmenu ENABLE_CORE_PLL_OBSCLK()
    /* set bit 1 to enable power to the CORE PLL observation clock, clear bit 0 to view the CORE PLL observation (output) clock */
    OBSCLKCTL |= (1 << 1); /* set bit 1 to enable power to the observation clock */
    OBSCLKCTL &= ~(1 << 0); /* clear bit 0 to view the CORE PLL clock */
    KICK0 = 0x00000000;
    KICK1 = 0x00000000;
    GEL_TextOut("CORE PLL observation clock enabled and configured to show CORE PLL output\n");
    /* Function to enable DDR PLL observation clock for PLL output */
    hotmenu ENABLE_DDR_PLL_OBSCLK ()
    OBSCLKCTL |= (1 << 3); /* set bit 3 to enable power to the observation clock */
    OBSCLKCTL |= (1 << 2); /* set bit 2 to view the DDR PLL clock */
    //KICK0 = 0x00000000;
    // KICK1 = 0x00000000;
    GEL_TextOut("DDR PLL observation clock enabled and configured to show DDR PLL output\n");
    hotmenu ENABLE_ARM_PLL_OBSCLK ()
    //OBSCLKCTL |= (1 << 3); /* set bit 3 to enable power to the observation clock */
    OBSCLKCTL |= (1 << 6); /* set bit 2 to view the DDR PLL clock */
    KICK0 = 0x00000000;
    KICK1 = 0x00000000;
    hotmenu ENABLE_PA_PLL_OBSCLK ()
    OBSCLKCTL |= (1 << 4); /* set bit 3 to enable power to the observation clock */
    OBSCLKCTL |= (1 << 5); /* set bit 2 to view the DDR PLL clock */
    KICK0 = 0x00000000;
    KICK1 = 0x00000000;
    hotmenu ddr3A_write_read_test()
    //int data_set[4];
    //= {0xAAAAAAAA, 0x55555555, 0xFFFFFFFF, 0x00000000};
    unsigned int write_data = 0xAAAAAAAA;
    unsigned int read_data = 0x0;
    unsigned int errors = 0;
    int dw;
    unsigned int i, mem_start, mem_size, mem_location;
    mem_start = DDR3A_BASE_ADDRESS + (DNUM * 0x01000000);
    mem_size = 0x100;
    for(dw=0;dw<4;dw++)
    if (dw == 0) write_data = 0xAAAAAAAA;
    if (dw == 1) write_data = 0x55555555;
    if (dw == 2) write_data = 0xFFFFFFFF;
    if (dw == 3) write_data = 0x00000000;
    mem_location = mem_start;
    GEL_TextOut( "Memory Test Write Core: %d, Mem Start: 0x%x, Mem Size: 0x%x, value: 0x%x ...\n",,2,,,DNUM,mem_start,mem_size,write_data);
    for(i=0;i<mem_size;i++)
    *( unsigned int* )(mem_location) = write_data;
    mem_location += 4;
    GEL_TextOut( "Memory Test Read Core: %d, Mem Start: 0x%x, Mem Size: 0x%x ...\n",,2,,,DNUM,mem_start,mem_size);
    for (i=0;i<mem_size;i++)
    read_data = *( unsigned int* )(mem_location);
    if (read_data != write_data)
    GEL_TextOut("DDR3 Data Error: DSP Core: %d, Mem Addr: 0x%x, read: 0x%x, expected: 0x%x \n",,2,,,DNUM,(DDR3_BASE_ADDRESS + (i * 4)),read_data,write_data);
    errors++;
    mem_location += 4;
    if (errors == 0)
    GEL_TextOut( "Memory Test Done, no errors found.\n" );
    else
    GEL_TextOut("Memory Test Done, %d errors were encounterd. \n",,2,,,errors);
    GEL_TextOut( "All Memory Test Completed on core: %d with %d errors.\n",,2,,,DNUM,errors);
    hotmenu ddr3B_write_read_test()
    //int data_set[4];
    int dw;
    mem_start = DDR3B_BASE_ADDRESS + (DNUM * 0x01000000);
    mem_size = 0x100;
    for(dw=0;dw<4;dw++)
    mem_location += 4;
    errors++;
    mem_location += 4;
    if (errors == 0)
    else
    menuitem "DSP CLOCK Estimation";
    #define TIMER_TSC (1) // The timer used for polling TSCH/TSCL
    #define TIMER_TSC_POLL_PERIOD (10) // Every 10 seconds
    unsigned int gPollPeriod = TIMER_TISC_POLL_PERIOD;
    unsigned int gTSCL = 0;
    unsigned int gTSCH = 0; // Global var for holding previous read of TSCL/H
    unsigned int gNumberPoll=0; // Number of pulling */
    unsigned int gLoopCount=0;
    hotmenu dspEnableTsc()
    //GEL_TextOut( "dspEnableTsc - write a value to TSCL to enable it\n" );
    if( GEL_IsHalted() ) {
    TSCL = 0; // A write to TSCL will enable TSC (timestamp counter)
    GEL_Run();
    } else {
    GEL_Halt();
    TSCL = 0;
    GEL_Run();
    hotmenu dspDumpTsc()
    unsigned int tscl, tsch;
    tscl = TSCL; /* note: need to read TSCL first */
    tsch = TSCH;
    GEL_TextOut( "dspEnableTsc - TSCH=%x, TSCL=%x\n",,,,, tscl, tsch );
    dspPollTsc()
    unsigned long long tsc1, tsc2;
    if( gLoopCount <= gNumberPoll) {
    //GEL_EnableRealtime();
    GEL_Halt();
    tscl = TSCL; /* The read time can be considered as variations */
    tsch = TSCH; /* The read won't cause variation */
    //GEL_DisableRealtime();
    GEL_Run();
    tsc2 = (((unsigned long long) tsch)<<32) + tscl;
    tsc1 = (((unsigned long long)gTSCH)<<32) + gTSCL;
    gTSCL = tscl;
    gTSCH = tsch;
    //tsc1 = (tsc2-tsc1)/TIMER_TSC_POLL_PERIOD;
    tsc1 = (tsc2-tsc1)/gPollPeriod;
    GEL_TextOut( "dspPollTsc - [TSCH,TSCL] = [%x, %x], freq=%dhz, i=%d\n",,,,,
    gTSCH, gTSCL, (tsc1), gLoopCount);
    if( gLoopCount>=gNumberPoll ) {
    dspCancelTscTimer();
    } else {
    gLoopCount++;
    // To cancel the Timer - TIMER_TSC, after using it. Otherwise, it will continue running.
    hotmenu dspCancelTscTimer()
    GEL_TextOut( "dspCancelTscTimer\n");
    GEL_CancelTimer( TIMER_TSC );
    // To poll the DSP clock.
    dialog dspPollDSPClockFreq(
    pollPeriod "Polling period (sec) - the longer, the more accurate!",
    numberOfPoll "Number of Polls" )
    gPollPeriod = pollPeriod;
    GEL_TextOut( "dspPollDSPClockFreq with - pollPeriod=%dsec, numberOfPoll=%d\n"
    ,,,,, gPollPeriod, numberOfPoll);
    gNumberPoll = numberOfPoll-1;
    gLoopCount = 0;
    dspEnableTsc();
    // Get the initial value of TSC
    GEL_Halt();
    gTSCL = TSCL; /* The read time can be considered as variations */
    gTSCH = TSCH; /* The read won't cause variation */
    GEL_Run();
    GEL_SetTimer( gPollPeriod*1000, TIMER_TSC, "dspPollTsc()");
    * Copyright (c) 2012 Texas Instruments Incorporated - http://www.ti.com
    * Redistribution and use in source and binary forms, with or without
    * modification, are permitted provided that the following conditions
    * are met:
    * Redistributions of source code must retain the above copyright
    * notice, this list of conditions and the following disclaimer.
    * Redistributions in binary form must reproduce the above copyright
    * notice, this list of conditions and the following disclaimer in the
    * documentation and/or other materials provided with the
    * distribution.
    * Neither the name of Texas Instruments Incorporated nor the names of
    * its contributors may be used to endorse or promote products derived
    * from this software without specific prior written permission.
    * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
    * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
    * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
    * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
    * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
    * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
    * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
    * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
    * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
    * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
    * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    * Filename: evmtci6638k2k.gel
    * Description: Utility GEL for use with the TCI6638K2K EVM. This GEL has
    * functions that initialize the chip PLL's and the DDR3A and DDR3B interfaces.
    * It also includes general utilities that are useful for EVM development
    * More functions will be added as needed.
    * Author: Randy Rosales
    * Revision History:
    * Revision 0.1
    * - Initial revision based on the Kepler VDB GEL 32bit_DDR-800_Kepler_PLL_and_DDR3_Init_Silicon_Rev15.gel put together for Kepler bringup by Pragna Paranji
    * - Added in GEL system clock frequency estimation functions written by WenZhong Liu to help debug core PLL instability
    * + dspPollDSPClockFreq will estimate the clock based on a comparison with windows system clock time
    * Revision 0.2 - pparanji
    * - Added DDR3A and DDR3B memory test capabilities.
    * Revision 0.3 - pparanji
    * - Added the following configurations
    * DDR3A 32bit - DDR800, DDR1066, DDR1333
    * DDR3B 64bit - DDR800, DDR1066, DDR1333, DDR1600
    * DSP core PLL @ 122.88 MHz to 614.4 MHz operation
    * 122.88 MHz to 737.28 MHz operation
    * 122.88 MHz to 983.04 MHz operation
    * 122.88 MHz to 1.2 GHz operation
    * ARM PLL @ 100 MHz to 1.0 GHz operation
    * 100 MHz to 1.4 GHz operation
    * 175 MHz to 1.4 GHz operation
    * Rev 1.2 - - pparanji
    * ------ Updates DDR3A and DDR3B to single rank configurations
    * Rev 1.3 - pparanji
    * ------ Updated timing on DDR3A-1066 and DDR3A-1333
    * Rev 1.4 - csmith
    * ------ Updated PA PLL config and Tetris PLL config
    #define GEL_VERSION 1.3
    // Timeout definitions
    int _GEL_Global_Timeout1 = 0;
    #define TIMEOUT_ID 10
    // Global timeout value
    #define GTIMEOUT 2000
    // Power definitions
    #define PSC_BASE 0x02350000
    #define PSC_PTCMD *( unsigned int* )( PSC_BASE+0x120 )
    #define PSC_PTSTAT *( unsigned int* )( PSC_BASE+0x128 )
    #define PSC_PDCTL_BASE ( PSC_BASE+0x300 )
    #define PSC_MDSTAT_BASE ( PSC_BASE+0x800 )
    #define PSC_MDCTL_BASE ( PSC_BASE+0xA00 )
    // Modules on power domain 0
    // Always on
    // Modules on power domain 1
    #define LPSC_DEBUG (5)
    #define LPSC_TETB (6)
    // Modules on power domain 2
    #define LPSC_PA (7)
    #define LPSC_SGMII (8)
    #define LPSC_SA (9)
    // Modules on power domain 3
    #define LPSC_PCIE (10)
    // Modules on power domain 4
    #define LPSC_SRIO (11)
    // Modules on power domain 5
    #define LPSC_HYPERLINK_0 (12)
    // Modules on power domain 6
    #define LPSC_SR (13)
    // Modules on power domain 7
    #define LPSC_MSMCRAM (14)
    // Modules on power domain 8
    #define LPSC_GEM_0 (15)
    // Modules on power domain 9
    #define LPSC_GEM_1 (16)
    // Modules on power domain 10
    #define LPSC_GEM_2 (17)
    // Modules on power domain 11
    #define LPSC_GEM_3 (18)
    // Modules on power domain 12
    #define LPSC_GEM_4 (19)
    // Modules on power domain 13
    #define LPSC_GEM_5 (20)
    // Modules on power domain 14
    #define LPSC_GEM_6 (21)
    // Modules on power domain 15
    #define LPSC_GEM_7 (22)
    // Modules on power domain 16
    #define LPSC_DDR3_0 (23)
    #define LPSC_DDR3_1 (24)
    // Modules on power domain 17
    #define LPSC_TAC (25)
    #define LPSC_RAC_01 (26)
    // Modules on power domain 18
    #define LPSC_RAC_23 (27)
    // Modules on power domain 19
    #define LPSC_FFTCA_FFTC_0 (28)
    #define LPSC_FFTCA_FFTC_1 (29)
    // Modules on power domain 20
    #define LPSC_FFTCA_FFTC_2 (30)
    #define LPSC_FFTCA_FFTC_3 (31)
    #define LPSC_FFTCA_FFTC_4 (32)
    #define LPSC_FFTCA_FFTC_5 (33)
    // Modules on power domain 21
    #define LPSC_AIF (34)
    // Modules on power domain 22
    #define LPSC_TCP3D_0 (35)
    #define LPSC_TCP3D_1 (36)
    // Modules on power domain 23
    #define LPSC_TCP3D_2 (37)
    #define LPSC_TCP3D_3 (38)
    // Modules on power domain 24
    #define LPSC_VCP_0 (39)
    #define LPSC_VCP_1 (40)
    #define LPSC_VCP_2 (41)
    #define LPSC_VCP_3 (42)
    // Modules on power domain 25
    #define LPSC_VCP_4 (43)
    #define LPSC_VCP_5 (44)
    #define LPSC_VCP_6 (45)
    #define LPSC_VCP_7 (46)
    // Modules on power domain 26
    #define LPSC_BCP (47)
    // Modules on power domain 27
    #define LPSC_DXB (48)
    // Modules on power domain 28
    #define LPSC_HYPERLINK_1 (49)
    // Modules on power domain 29
    #define LPSC_XGE (50)
    // Modules on power domain 31
    #define LPSC_ARM (52)
    // Power domains definitions
    #define PD0 (0) // Power Domain-0
    #define PD1 (1) // Power Domain-1
    #define PD2 (2) // Power Domain-2
    #define PD3 (3) // Power Domain-3
    #define PD4 (4) // Power Domain-4
    #define PD5 (5) // Power Domain-5
    #define PD6 (6) // Power Domain-6
    #define PD7 (7) // Power Domain-7
    #define PD8 (8) // Power Domain-8
    #define PD9 (9) // Power Domain-9
    #define PD10 (10) // Power Domain-10
    #define PD11 (11) // Power Domain-11
    #define PD12 (12) // Power Domain-12
    #define PD13 (13) // Power Domain-13
    #define PD14 (14) // Power Domain-14
    #define PD15 (15) // Power Domain-15
    #define PD16 (16) // Power Domain-16
    #define PD17 (17) // Power Domain-17
    #define PD18 (18) // Power Domain-18
    #define PD19 (19) // Power Domain-19
    #define PD20 (20) // Power Domain-20
    #define PD21 (21) // Power Domain-21
    #define PD22 (22) // Power Domain-22
    #define PD23 (23) // Power Domain-23
    #define PD24 (24) // Power Domain-24
    #define PD25 (25) // Power Domain-25
    #define PD26 (26) // Power Domain-26
    #define PD27 (27) // Power Domain-27
    #define PD28 (28) // Power Domain-28
    #define PD29 (29) // Power Domain-29
    #define PD30 (30) // Power Domain-30
    #define PD31 (31) // Power Domain-31
    #define PSC_SYNCRESET (0x1)
    #define PSC_DISABLE (0x2)
    #define PSC_ENABLE (0x3)
    #define CHIP_LEVEL_REG 0x02620000
    /******************* PLL registers **********************************/
    /*Boot cfg registers*/
    #define KICK0 *(unsigned int*)(CHIP_LEVEL_REG + 0x0038)
    #define KICK1 *(unsigned int*)(CHIP_LEVEL_REG + 0x003C)
    #define KICK0_UNLOCK (0x83E70B13)
    #define KICK1_UNLOCK (0x95A4F1E0)
    #define KICK_LOCK 0
    #define TINPSEL *(unsigned int*)(CHIP_LEVEL_REG + 0x0300)
    #define TOUTPSEL *(unsigned int*)(CHIP_LEVEL_REG + 0x0304)
    #define MAINPLLCTL0 *(unsigned int*)(CHIP_LEVEL_REG + 0x0350) //0x0328)
    #define MAINPLLCTL1 *(unsigned int*)(CHIP_LEVEL_REG + 0x0354) //0x032C)
    #define MAIN_PLLD_OFFSET 0
    #define MAIN_PLLD_MASK 0xFFFFFFC0
    #define MAIN_PLLM_OFFSET 12
    #define MAIN_PLLM_MASK 0xFFF80FFF
    #define MAIN_BWADJ0_OFFSET 24
    #define MAIN_BWADJ0_MASK 0x00FFFFFF
    #define MAIN_ENSAT_OFFSET 6
    #define MAIN_ENSAT_MASK 0xFFFFFFBF
    #define MAIN_BWADJ1_OFFSET 0
    #define MAIN_BWADJ1_MASK 0xFFFFFFF0
    #define OBSCLKCTL *(unsigned int*)(CHIP_LEVEL_REG + 0x0C80)
    /* PA PLL Registers */
    #define BYPASS_BIT_SHIFT 23
    #define CLKF_BIT_SHIFT 6
    #define CLKD_BIT_SHIFT 0
    #define DEVSTAT (*((unsigned int *) 0x02620020))
    #define PAPLLCTL0 *(unsigned int*)(CHIP_LEVEL_REG + 0x0358)
    #define PAPLLCTL1 *(unsigned int*)(CHIP_LEVEL_REG + 0x035C)
    #define PASSCLKSEL_MASK (1 << 17) /* Tells the configuration of the PASSCLKSEL pin */
    #define PA_PLL_BYPASS_MASK (1 << BYPASS_BIT_SHIFT) /* Tells whether the PA PLL is in BYPASS mode or not */
    #define PA_PLL_CLKOD_MASK (0x00780000) /* Tells the output divider value for the PA PLL */
    #define PA_PLL_CLKF_MASK (0x0007FFC0) /* Tells the multiplier value for the PA PLL */
    #define PA_PLL_CLKR_MASK (0x0000003F) /* Tells the divider value for the PA PLL */
    #define PA_PLL_RESET_MASK (0x00004000)
    #define CHIP_MISC1 *(unsigned int*)(CHIP_LEVEL_REG + 0x0C7C)
    #define ARMPLL_ENABLE_OFFSET 13
    #define DDR3APLLCTL0 *(unsigned int*)(CHIP_LEVEL_REG + 0x0360)
    #define DDR3APLLCTL1 *(unsigned int*)(CHIP_LEVEL_REG + 0x0364)
    #define DDR3BPLLCTL0 *(unsigned int*)(CHIP_LEVEL_REG + 0x0368)
    #define DDR3BPLLCTL1 *(unsigned int*)(CHIP_LEVEL_REG + 0x036C)
    // PLL 1 definitions (DSP and ARM clock and subsystems)
    #define PLL1_BASE 0x02310000
    #define PLL1_PLLCTL (*(unsigned int*)(PLL1_BASE + 0x100)) // PLL1 Control
    #define PLL1_SECCTL (*(unsigned int*)(PLL1_BASE + 0x108)) // PLL1 Secondary Control
    #define PLL1_PLLM (*(unsigned int*)(PLL1_BASE + 0x110)) // PLL1 Multiplier
    #define PLL1_DIV1 (*(unsigned int*)(PLL1_BASE + 0x118)) // DIV1 divider
    #define PLL1_DIV2 (*(unsigned int*)(PLL1_BASE + 0x11C)) // DIV2 divider
    #define PLL1_DIV3 (*(unsigned int*)(PLL1_BASE + 0x120)) // DIV3 divider
    #define PLL1_CMD (*(unsigned int*)(PLL1_BASE + 0x138)) // CMD control
    #define PLL1_STAT (*(unsigned int*)(PLL1_BASE + 0x13C)) // STAT control
    #define PLL1_ALNCTL (*(unsigned int*)(PLL1_BASE + 0x140)) // ALNCTL control
    #define PLL1_DCHANGE (*(unsigned int*)(PLL1_BASE + 0x144)) // DCHANGE status
    #define PLL1_CKEN (*(unsigned int*)(PLL1_BASE + 0x148)) // CKEN control
    #define PLL1_CKSTAT (*(unsigned int*)(PLL1_BASE + 0x14C)) // CKSTAT status
    #define PLL1_SYSTAT (*(unsigned int*)(PLL1_BASE + 0x150)) // SYSTAT status
    #define PLL1_DIV4 (*(unsigned int*)(PLL1_BASE + 0x160)) // DIV4 divider
    #define PLL1_DIV5 (*(unsigned int*)(PLL1_BASE + 0x164)) // DIV5 divider
    #define PLL1_DIV6 (*(unsigned int*)(PLL1_BASE + 0x168)) // DIV6 divider
    #define PLL1_DIV7 (*(unsigned int*)(PLL1_BASE + 0x16C)) // DIV7 divider
    #define PLL1_DIV8 (*(unsigned int*)(PLL1_BASE + 0x170)) // DIV8 divider
    #define PLL1_DIV9 (*(unsigned int*)(PLL1_BASE + 0x174)) // DIV9 divider
    #define PLL1_DIV10 (*(unsigned int*)(PLL1_BASE + 0x178)) // DIV10 divider
    #define PLL1_DIV11 (*(unsigned int*)(PLL1_BASE + 0x17C)) // DIV11 divider
    #define PLL1_DIV12 (*(unsigned int*)(PLL1_BASE + 0x180)) // DIV12 divider
    #define PLL1_DIV13 (*(unsigned int*)(PLL1_BASE + 0x184)) // DIV13 divider
    #define PLL1_DIV14 (*(unsigned int*)(PLL1_BASE + 0x188)) // DIV14 divider
    #define PLL1_DIV15 (*(unsigned int*)(PLL1_BASE + 0x18C)) // DIV15 divider
    #define PLL1_DIV16 (*(unsigned int*)(PLL1_BASE + 0x190)) // DIV16 divider
    #define PLLPWRDN_OFFSET 1
    #define PLLPWRDN_MASK 0xFFFFFFFD
    #define PLLRST_OFFSET 3
    #define PLLRST_MASK 0xFFFFFFF7
    #define PLLENSRC_OFFSET 5
    #define PLLENSRC_MASK 0xFFFFFFDF
    #define PLLEN_OFFSET 0
    #define PLLEN_MASK 0xFFFFFFFE
    #define OUTPUT_DIVIDE_OFFSET 19
    #define OUTPUT_DIVIDE_MASK 0xFF87FFFF
    #define BYPASS_OFFSET 23
    #define BYPASS_MASK 0xFF7FFFFF
    #define PLLM_OFFSET 0
    #define PLLM_MASK 0xFFFFFFC0
    #define GOSET_OFFSET 0
    #define GOSET_MASK 0xFFFFFFFE
    #define GOSTAT_OFFSET 0
    #define GOSTAT_MASK 0xFFFFFFFE
    // ARMPLL definitions
    #define SEC_PLLCTL0_PLLM_OFFSET 6
    #define SEC_PLLCTL0_PLLM_MASK 0xFFFF003F
    #define SEC_PLLCTL0_BWADJ_OFFSET 24
    #define SEC_PLLCTL0_BWADJ_MASK 0x00FFFFFF
    #define SEC_PLLCTL0_OD_OFFSET 19
    #define SEC_PLLCTL0_OD_MASK 0xFF87FFFF
    #define SEC_PLLCTL0_BYPASS_OFFSET 23
    #define SEC_PLLCTL0_BYPASS_MASK 0xFF7FFFFF
    #define SEC_PLLCTL1_RESET_OFFSET 14
    #define SEC_PLLCTL1_RESET_MASK 0xFFFFBFFF
    #define SEC_PLLCTL1_PWRDWN_OFFSET 15
    #define SEC_PLLCTL1_PWRDWN_MASK 0xFFFF7FFF
    #define SEC_PLLCTL1_ENSTAT_OFFSET 6
    #define SEC_PLLCTL1_ENSTAT_MASK 0xFFFFFFBF
    /*----------------DDR3A Register definition---------------------*/
    #define DDR3A_BASE_ADDR (0x21010000)
    #define DDR3A_STATUS (*(int*)(DDR3A_BASE_ADDR + 0x00000004))
    #define DDR3A_SDCFG (*(int*)(DDR3A_BASE_ADDR + 0x00000008))
    #define DDR3A_SDRFC (*(int*)(DDR3A_BASE_ADDR + 0x00000010))
    #define DDR3A_SDTIM1 (*(int*)(DDR3A_BASE_ADDR + 0x00000018))
    #define DDR3A_SDTIM2 (*(int*)(DDR3A_BASE_ADDR + 0x0000001C))
    #define DDR3A_SDTIM3 (*(int*)(DDR3A_BASE_ADDR + 0x00000020))
    #define DDR3A_SDTIM4 (*(int*)(DDR3A_BASE_ADDR + 0x00000028))
    #define DDR3A_ZQCFG (*(int*)(DDR3A_BASE_ADDR + 0x000000C8))
    #define DDR3A_TMPALRT (*(int*)(DDR3A_BASE_ADDR + 0x000000CC))
    #define DDR3A_DDRPHYC (*(int*)(DDR3A_BASE_ADDR + 0x000000E4))
    #define DDR3A_PHY_CFG_BASE (0x02329000)
    #define DDR3A_PIR (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000004))
    #define DDR3A_PGCR0 (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000008))
    #define DDR3A_PGCR1 (*(int*)(DDR3A_PHY_CFG_BASE + 0x0000000C))
    #define DDR3A_PGCR2 (*(int*)(DDR3A_PHY_CFG_BASE + 0x0000008C))
    #define DDR3A_PGSR0 (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000010))
    #define DDR3A_PGSR1 (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000014))
    #define DDR3A_PLLCR (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000018))
    #define DDR3A_PTR0 (*(int*)(DDR3A_PHY_CFG_BASE + 0x0000001C))
    #define DDR3A_PTR1 (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000020))
    #define DDR3A_PTR2 (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000024))
    #define DDR3A_PTR3 (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000028))
    #define DDR3A_PTR4 (*(int*)(DDR3A_PHY_CFG_BASE + 0x0000002C))
    #define DDR3A_DSGCR (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000040))
    #define DDR3A_DCR (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000044))
    #define DDR3A_MR0 (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000054))
    #define DDR3A_MR1 (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000058))
    #define DDR3A_MR2 (*(int*)(DDR3A_PHY_CFG_BASE + 0x0000005C))
    #define DDR3A_DTCR (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000068))
    #define DDR3A_DTPR0 (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000048))
    #define DDR3A_DTPR1 (*(int*)(DDR3A_PHY_CFG_BASE + 0x0000004C))
    #define DDR3A_DTPR2 (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000050))
    #define DDR3A_ZQ0CR1 (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000184))
    #define DDR3A_ZQ1CR1 (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000194))
    #define DDR3A_ZQ2CR1 (*(int*)(DDR3A_PHY_CFG_BASE + 0x000001A4))
    #define DDR3A_ZQ3CR1 (*(int*)(DDR3A_PHY_CFG_BASE + 0x000001B4))
    #define DDR3A_DATX8_8 (*(int*)(DDR3A_PHY_CFG_BASE + 0x000003C0))
    #define DDR3_TEST_START_ADDRESS (*(int*)(0x80000000))
    #define IODDRM_MASK 0x00000180
    #define ZCKSEL_MASK 0x01800000
    #define CL_MASK 0x00000072
    #define WR_MASK 0x00000E00
    #define BL_MASK 0x00000003
    #define RRMODE_MASK 0x00040000
    #define UDIMM_MASK 0x20000000
    #define BYTEMASK_MASK 0x0000FC00
    #define MPRDQ_MASK 0x00000080
    #define PDQ_MASK 0x00000070
    #define NOSRA_MASK 0x08000000
    #define ECC_MASK 0x00000001
    #define DDR3A_DX0GSR0 (*(int*)(DDR3A_PHY_CFG_BASE + 0x000001C4)) //0x71
    #define DDR3A_DX1GSR0 (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000204)) //0x81
    #define DDR3A_DX2GSR0 (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000244)) //0x91
    #define DDR3A_DX3GSR0 (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000284)) //0xA1
    #define DDR3A_DX4GSR0 (*(int*)(DDR3A_PHY_CFG_BASE + 0x000002C4)) //0xB1
    #define DDR3A_DX5GSR0 (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000304)) //0xC1
    #define DDR3A_DX6GSR0 (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000344)) //0xD1
    #define DDR3A_DX7GSR0 (*(int*)(DDR3A_PHY_CFG_BASE + 0x00000384)) //0xE1
    #define DDR3A_DX8GSR0 (*(int*)(DDR3A_PHY_CFG_BASE + 0x000003C4)) //0xF1
    #define DDR3A_TEST_START_ADDRESS (0x80000000)
    #define DDR3A_TEST_END_ADDRESS (DDR3A_TEST_START_ADDRESS + (4 * 100))
    #define DDR3A_BASE_ADDRESS 0x80000000
    #define DDR3B_BASE_ADDR (0x21020000)
    #define DDR3B_STATUS (*(int*)(DDR3B_BASE_ADDR + 0x00000004))
    #define DDR3B_SDCFG (*(int*)(DDR3B_BASE_ADDR + 0x00000008))
    #define DDR3B_SDRFC (*(int*)(DDR3B_BASE_ADDR + 0x00000010))
    #define DDR3B_SDTIM1 (*(int*)(DDR3B_BASE_ADDR + 0x00000018))
    #define DDR3B_SDTIM2 (*(int*)(DDR3B_BASE_ADDR + 0x0000001C))
    #define DDR3B_SDTIM3 (*(int*)(DDR3B_BASE_ADDR + 0x00000020))
    #define DDR3B_SDTIM4 (*(int*)(DDR3B_BASE_ADDR + 0x00000028))
    #define DDR3B_ZQCFG (*(int*)(DDR3B_BASE_ADDR + 0x000000C8))
    #define DDR3B_TMPALRT (*(int*)(DDR3B_BASE_ADDR + 0x000000CC))
    #define DDR3B_DDRPHYC (*(int*)(DDR3B_BASE_ADDR + 0x000000E4))
    #define DDR3B_PHY_CFG_BASE (0x02328000)
    #define DDR3B_PIR (*(int*)(DDR3B_PHY_CFG_BASE + 0x00000004))
    #define DDR3B_PGCR0 (*(int*)(DDR3B_PHY_CFG_BASE + 0x00000008))
    #define DDR3B_PGCR1 (*(int*)(DDR3B_PHY_CFG_BASE + 0x0000000C))
    #define DDR3B_PGCR2 (*(int*)(DDR3B_PHY_CFG_BASE + 0x0000008C))
    #define DDR3B_PGSR0 (*(int*)(DDR3B_PHY_CFG_BASE + 0x00000010))
    #define DDR3B_PGSR1 (*(int*)(DDR3B_PHY_CFG_BASE + 0x00000014))
    #define DDR3B_PTR0 (*(int*)(DDR3B_PHY_CFG_BASE + 0x0000001C))
    #define DDR3B_PTR1 (*(int*)(DDR3B_PHY_CFG_BASE + 0x00000020))
    #define DDR3B_PTR2 (*(int*)(DDR3B_PHY_CFG_BASE + 0x00000024))
    #define DDR3B_PTR3 (*(int*)(DDR3B_PHY_CFG_BASE + 0x00000028))
    #define DDR3B_PTR4 (*(int*)(DDR3B_PHY_CFG_BASE + 0x0000002C))
    #define DDR3B_DSGCR (*(int*)(DDR3B_PHY_CFG_BASE + 0x00000040))
    #define DDR3B_DCR (*(int*)(DDR3B_PHY_CFG_BASE + 0x00000044))
    #define DDR3B_MR0 (*(int*)(DDR3B_PHY_CFG_BASE + 0x00000054))
    #define DDR3B_MR1 (*(int*)(DDR3B_PHY_CFG_BASE + 0x00000058))
    #define DDR3B_MR2 (*(int*)(DDR3B_PHY_CFG_BASE + 0x0000005C))
    #define DDR3B_DTCR (*(int*)(DDR3B_PHY_CFG_BASE + 0x00000068))
    #define DDR3B_DTPR0 (*(int*)(DDR3B_PHY_CFG_BASE + 0x00000048))
    #define DDR3B_DTPR1 (*(int*)(DDR3B_PHY_CFG_BASE + 0x0000004C))
    #define DDR3B_DTPR2 (*(int*)(DDR3B_PHY_CFG_BASE + 0x00000050))
    #define DDR3B_PLLCR (*(int*)(DDR3B_PHY_CFG_BASE + 0x00000018))
    #define DDR3B_ZQ0CR1 (*(int*)(DDR3B_PHY_CFG_BASE + 0x00000184))
    #define DDR3B_ZQ1CR1 (*(int*)(DDR3B_PHY_CFG_BASE + 0x00000194))
    #define DDR3B_ZQ2CR1 (*(int*)(DDR3B_PHY_CFG_BASE + 0x000001A4))
    #define DDR3B_ZQ3CR1 (*(int*)(DDR3B_PHY_CFG_BASE + 0x000001B4))
    #define DDR3B_TEST_START_ADDRESS (0x60000000)
    #define DDR3B_TEST_END_ADDRESS (DDR3B_TEST_START_ADDRESS + (4 * 100))
    #define DDR3B_BASE_ADDRESS 0x60000000
    #define TETRIS_BASE 0x01E80000
    #define TETRIS_CPU0_PTCMD *(unsigned int*)(TETRIS_BASE + 0x0400)
    #define TETRIS_CPU0_PDSTAT *(unsigned int*)(TETRIS_BASE + 0x0404)
    #define TETRIS_CPU0_PDCTL *(unsigned int*)(TETRIS_BASE + 0x0408)
    #define TETRIS_CPU1_PTCMD *(unsigned int*)(TETRIS_BASE + 0x040C)
    #define TETRIS_CPU1_PDSTAT *(unsigned int*)(TETRIS_BASE + 0x0410)
    #define TETRIS_CPU1_PDCTL *(unsigned int*)(TETRIS_BASE + 0x0414)
    #define TETRIS_CPU2_PTCMD *(unsigned int*)(TETRIS_BASE + 0x0418)
    #define TETRIS_CPU2_PDSTAT *(unsigned int*)(TETRIS_BASE + 0x041C)
    #define TETRIS_CPU2_PDCTL *(unsigned int*)(TETRIS_BASE + 0x0420)
    #define TETRIS_CPU3_PTCMD *(unsigned int*)(TETRIS_BASE + 0x0424)
    #define TETRIS_CPU3_PDSTAT *(unsigned int*)(TETRIS_BASE + 0x0428)
    #define TETRIS_CPU3_PDCTL *(unsigned int*)(TETRIS_BASE + 0x042C)
    #define SECPLLCTL0 *(unsigned int*)(CHIP_LEVEL_REG + 0x0370)
    #define SECPLLCTL1 *(unsigned int*)(CHIP_LEVEL_REG + 0x0374)
    unsigned int read_val;
    * NAME
    * OnTargetConnect
    * PURPOSE:
    * Setup almost everything ready for a new debug session:
    * DSP modules and EVM board modules, at target connection.
    * Do nothing if target is in realtime mode.
    * This routine is called when you connect to the target board.
    * IMPORTANT: this routine won't attempt to connect to the target
    * if the target is not in real-time mode and that the dsp boot
    * mode switches are not set in emulation boot mode.
    * USAGE
    * This routine is a callback routine and called by CCS only.
    * RETURN VALUE
    * NONE
    * REFERENCE
    OnTargetConnect()
    /* GEL_Reset() is used to deal with the worst case */
    /* senario of unknown target state. If for some reason */
    /* a reset is not desired upon target connection, */
    /* GEL_Reset() may be removed and replaced with */
    /* something "less brutal" like a cache initialization */
    /* function. */
    //GEL_Reset();
    //xmc_setup();
    //ddr3_setup();
    GEL_TextOut("\nConnecting Target...\n");
    // Check if target is not in real-time mode. If it is in stop mode,
    // initialize everything. In real-time mode, do nothing to connect
    // unobtrusively...
    if (!GEL_IsInRealtimeMode())
    // Validates if emulation boot mode
    if (DEVSTAT & 0x0000000E)
    GEL_TextOut("No initialization performed since bootmode = %x \n",,,,,(DEVSTAT >> 1 ) & 0xF);
    GEL_TextOut("You can manually initialize with GlobalDefaultSetup\n");
    else
    // Comment the following line at production application test
    // when the application need to initialize everything, but not the
    // GEL file.
    Global_Default_Setup_Silent();
    } else {
    GEL_TextOut("No initialization performed in real time mode\n");
    /* OnReset() */
    /* This function is called by CCS when you do Debug->Resest. */
    /* The goal is to put the C6x into a known good state with */
    /* respect to cache, edma and interrupts. */
    OnReset( int nErrorCode )
    /* xmc_setup() */
    /* XMC MPAX register setting to access DDR3 config space */
    #define XMC_BASE_ADDR (0x08000000)
    #define XMPAX2_L (*(int*)(XMC_BASE_ADDR + 0x00000010))
    #define XMPAX2_H (*(int*)(XMC_BASE_ADDR + 0x00000014))
    xmc_setup()
    /* mapping for ddr emif registers XMPAX*2 */
    XMPAX2_L = 0x121010FF; /* replacement addr + perm */
    XMPAX2_H = 0x2101000B; /* base addr + seg size (64KB)*/ //"1B"-->"B" by xj
    GEL_TextOut("XMC setup complete.\n");
    * NAME
    * Global_Default_Setup_Silent
    * PURPOSE:
    * DSP modules and EVM board modules.
    * USAGE
    * This routine can be called as:
    * Global_Default_Setup_Silent()
    * RETURN VALUE
    * NONE
    * REFERENCE
    float gel_ver = GEL_VERSION;
    // Set DSP cache to pre defined values...
    GEL_TextOut( "TCI6638K2K GEL file Ver is %f \n",,,,, (float) (gel_ver/1.0));
    //Set_DSP_Cache();
    // Only core 0 can set these
    if (DNUM == 0)
    // Setup main PLL DSP @ 983 MHz
    Set_Pll1(3); // call Set_Pll1 with index = 3 -> 122.88 MHz to 983.04 MHz operation
    // Setup all Power Domains on
    Set_Psc_All_On();
    // Setup PA PLL
    PaPllConfig();
    GEL_TextOut("DDR begin\n");
    xmc_setup();
    ddr3A_32bit_DDR1333_setup();
    ddr3B_64bit_DDR1600_setup();
    GEL_TextOut("DDR done\n");
    * NAME
    * Set_PSC_State
    * PURPOSE:
    * Set a new power state for the specified domain id in a power controler
    * domain. Wait for the power transition to complete.
    * USAGE
    * Set_PSC_State(unsigned int pd,unsigned int id,unsigned int state)
    * pd - (i) power domain.
    * id - (i) module id to use for module in the specified power domain
    * state - (i) new state value to set
    * 0 = RESET
    * 1 = SYNC RESET
    * 2 = DISABLE
    * 3 = ENABLE
    * RETURN VALUE
    * 0 if ok, !=0 for error
    * REFERENCE
    unsigned int* mdctl;
    unsigned int* mdstat;
    unsigned int* pdctl;
    int ret=0;
    // Only core0 can set PSC
    if (DNUM == 0)
    mdctl = ( unsigned int* )(PSC_MDCTL_BASE + ( 4 * id ));
    mdstat = ( unsigned int* )( PSC_MDSTAT_BASE + ( 4 * id ));
    pdctl = ( unsigned int* )(PSC_PDCTL_BASE + ( 4 * pd ));
    // If state is already set, do nothing
    if ( ( *mdstat & 0x1f ) == state )
    return(0);
    // Wait for GOSTAT to clear
    Set_Timeout(GTIMEOUT);
    while( Get_Timeout() && (PSC_PTSTAT & (0x1 << pd)) != 0 );
    // Check if we got timeout error while waiting
    if (!Get_Timeout())
    GEL_TextOut( "Set_PSC_State... Timeout Error #01 pd=%d, md=%d!\n",,2,,,pd,id);
    ret=1;
    else
    // Set power domain control
    *pdctl = (*pdctl) | 0x00000001;
    // Set MDCTL NEXT to new state
    *mdctl = ((*mdctl) & ~(0x1f)) | state;
    // Start power transition by setting PTCMD GO to 1
    PSC_PTCMD = (PSC_PTCMD) | (0x1<<pd);
    // Wait for PTSTAT GOSTAT to clear
    if (!Get_Timeout())
    GEL_TextOut( "Set_PSC_State... Timeout Error #02 pd=%d, md=%d!\n",,2,,,pd,id);
    ret=2;
    else
    // Verify state changed
    while(Get_Timeout() && ( *mdstat & 0x1f ) != state );
    if (!Get_Timeout())
    GEL_TextOut( "Set_PSC_State... Timeout Error #03 pd=%d, md=%d!\n",,2,,,pd,id);
    ret=3;
    // Kill the currently running timeout
    Kill_Timeout();
    else
    GEL_TextOut("DSP core #%d cannot set PSC.\n",,2,,,DNUM);
    return(ret);
    * NAME
    * Set_Timeout
    * PURPOSE:
    * Starts a timeout period of msec. The running timeout period can be
    * query with Get_Timeout. To kill a running timeout before the end,
    * call Kill_Timeout. Only one timeout period can be used at any time.
    * A timeout period can be used to measure a period of time while doing
    * anything else. Not accurate, sets timer at least as big as desired.
    * USAGE
    * Set_Timeout(msec)
    * msec - (i) timeout period in msec (not very precise < sec range)
    * RETURN VALUE
    * NONE
    * REFERENCE
    Set_Timeout(msec)
    // Cancel the current timer if not already expired
    GEL_CancelTimer(TIMEOUT_ID);
    // Starts the timeout period
    _GEL_Global_Timeout1=1;
    // Setup a callback routine with specified timeout
    GEL_SetTimer(msec, TIMEOUT_ID, "_Timeout_Callback()");
    * NAME
    * Get_Timeout
    * PURPOSE:
    * Query the running state of a timeout period started by Set_Timeout.
    * (see Set_Timeout for more info).
    * USAGE
    * Get_Timeout()
    * RETURN VALUE
    * 0:expired, 1:running
    * REFERENCE
    Get_Timeout()
    if (!_GEL_Global_Timeout1)
    // Return the global timeout status 1=running, 0=expired
    return _GEL_Global_Timeout1;
    * NAME
    * Kill_Timeout
    * PURPOSE:
    * Cancel a running timeout period before it expires
    * USAGE
    * Kill_Timeout()
    * RETURN VALUE
    * NONE
    * REFERENCE
    Kill_Timeout()
    // The timeout period is expired
    _GEL_Global_Timeout1=0;
    * NAME
    * _Timeout_Callback
    * PURPOSE:
    * Internal Callback function used by Set_timeout
    * USAGE
    * This routine must not be called by itself.
    * RETURN VALUE
    * NONE
    * REFERENCE
    _Timeout_Callback()
    * NAME
    * Set_Psc_All_On
    * PURPOSE:
    * Enable all PSC modules and DSP power domains on ALWAYSON, and wait
    * for these power transitions to complete.
    * USAGE
    * Set_Psc_All_On()
    * RETURN VALUE
    * NONE
    * REFERENCE
    hotmenu Set_Psc_All_On( )
    unsigned int i=0;
    if (DNUM == 0)
    GEL_TextOut( "Power on all PSC modules and DSP domains... \n");
    Set_PSC_State(PD1, LPSC_DEBUG, PSC_ENABLE);
    Set_PSC_State(PD1, LPSC_TETB, PSC_ENABLE);
    Set_PSC_State(PD2, LPSC_PA, PSC_ENABLE);
    Set_PSC_State(PD2, LPSC_SGMII, PSC_ENABLE);
    Set_PSC_State(PD2, LPSC_SA, PSC_ENABLE);
    Set_PSC_State(PD3, LPSC_PCIE, PSC_ENABLE);
    Set_PSC_State(PD4, LPSC_SRIO, PSC_ENABLE);
    Set_PSC_State(PD5, LPSC_HYPERLINK_0, PSC_ENABLE);
    Set_PSC_State(PD6, LPSC_SR, PSC_ENABLE);
    Set_PSC_State(PD7, LPSC_MSMCRAM, PSC_ENABLE);
    Set_PSC_State(PD8, LPSC_GEM_0, PSC_ENABLE);
    Set_PSC_State(PD9, LPSC_GEM_1, PSC_ENABLE);
    Set_PSC_State(PD10, LPSC_GEM_2, PSC_ENABLE);
    Set_PSC_State(PD11, LPSC_GEM_3, PSC_ENABLE);
    Set_PSC_State(PD12, LPSC_GEM_4, PSC_ENABLE);
    Set_PSC_State(PD13, LPSC_GEM_5, PSC_ENABLE);
    Set_PSC_State(PD14, LPSC_GEM_6, PSC_ENABLE);
    Set_PSC_State(PD15, LPSC_GEM_7, PSC_ENABLE);
    Set_PSC_State(PD16, LPSC_DDR3_0, PSC_ENABLE);
    Set_PSC_State(PD16, LPSC_DDR3_1, PSC_ENABLE);
    Set_PSC_State(PD17, LPSC_TAC, PSC_ENABLE);
    Set_PSC_State(PD17, LPSC_RAC_01, PSC_ENABLE);
    Set_PSC_State(PD18, LPSC_RAC_23, PSC_ENABLE);
    Set_PSC_State(PD19, LPSC_FFTCA_FFTC_0, PSC_ENABLE);
    Set_PSC_State(PD19, LPSC_FFTCA_FFTC_1, PSC_ENABLE);
    Set_PSC_State(PD20, LPSC_FFTCA_FFTC_2, PSC_ENABLE);
    Set_PSC_State(PD20, LPSC_FFTCA_FFTC_3, PSC_ENABLE);
    Set_PSC_State(PD20, LPSC_FFTCA_FFTC_4, PSC_ENABLE);
    Set_PSC_State(PD20, LPSC_FFTCA_FFTC_5, PSC_ENABLE);
    Set_PSC_State(PD21, LPSC_AIF, PSC_ENABLE);
    Set_PSC_State(PD22, LPSC_TCP3D_0, PSC_ENABLE);
    Set_PSC_State(PD22, LPSC_TCP3D_1, PSC_ENABLE);
    Set_PSC_State(PD23, LPSC_TCP3D_2, PSC_ENABLE);
    Set_PSC_State(PD23, LPSC_TCP3D_3, PSC_ENABLE);
    Set_PSC_State(PD24, LPSC_VCP_0, PSC_ENABLE);
    Set_PSC_State(PD24, LPSC_VCP_1, PSC_ENABLE);
    Set_PSC_State(PD24, LPSC_VCP_2, PSC_ENABLE);
    Set_PSC_State(PD24, LPSC_VCP_3, PSC_ENABLE);
    Set_PSC_State(PD25, LPSC_VCP_4, PSC_ENABLE);
    Set_PSC_State(PD25, LPSC_VCP_5, PSC_ENABLE);
    Set_PSC_State(PD25, LPSC_VCP_6, PSC_ENABLE);
    Set_PSC_State(PD25, LPSC_VCP_7, PSC_ENABLE);
    Set_PSC_State(PD26, LPSC_BCP, PSC_ENABLE);
    Set_PSC_State(PD27, LPSC_DXB, PSC_ENABLE);
    Set_PSC_State(PD28, LPSC_HYPERLINK_1, PSC_ENABLE);
    Set_PSC_State(PD29, LPSC_XGE, PSC_ENABLE);
    Set_PSC_State(PD31, LPSC_ARM, PSC_ENABLE);
    GEL_TextOut( "Power on all PSC modules and DSP domains... Done.\n" );
    else
    Set_Pll1() - This function executes the main PLL initialization
    sequence needed to get the main PLL up after coming out of an initial power up
    before it is locked or after it is already locked.
    Index value determines multiplier, divier used and clock reference assumed for
    output display.
    Set_Pll1(int index)
    int i, TEMP;
    unsigned int BYPASS_val;
    unsigned int BWADJ_val;
    unsigned int OD_val;
    float CLKIN_val;
    unsigned int PLLM_val;
    unsigned int PLLD_val;
    unsigned int PLLDIV3_val; //example value for SYSCLK2 (from 6614 spec) Default /2 - Fast Peripherals, (L2, MSMC, DDR3 EMIF, EDMA0...)
    unsigned int PLLDIV4_val; //example value for SYSCLK3 (from 6614 spec) Default /3 - Switch Fabric
    unsigned int PLLDIV7_val; //example value for SYSCLK6 (from 6614 spec) Defualt /6 - Slow Peripherals (UART, SPI, I2C, GPIO...)
    unsigned int debug_info_on;
    unsigned int delay;
    if(index == 1){ // 122.88 MHz -> 614.4 MHz
    CLKIN_val = 122.88; // setup CLKIN to 122.88 MHz
    PLLM_val = 10; // setup PLLM (PLL multiplier) to x10
    PLLD_val = 1; // setup PLLD (reference divider) to /1
    OD_val = 2; // setup OD to a fixed /2
    else if(index == 2){ // 122.88MHz -> 737.28 MHz
    PLLM_val = 12; // setup PLLM (PLL multiplier) to x12
    else if(index == 3){ // 122.88MHz -> 983.04 MHz
    PLLM_val = 16; // setup PLLM (PLL multiplier) to x12
    else if(index == 4){ // 122.88 MHz -> 1.2 GHz
    PLLM_val = 20; // setup PLLM (PLL multiplier) to x20
    else if(index == 5){ // 122.88 MHz -> 1.35 GHz
    PLLM_val = 22; // setup PLLM (PLL multiplier) to x22
    PLLDIV3_val = 3; // setup PLL output divider 3 to /3
    PLLDIV4_val = 5; // setup PLL output divider 4 to /3
    PLLDIV7_val = 6; // setup PLL output divider 7 to /6
    BYPASS_val = PLL1_SECCTL & ~BYPASS_MASK; // get value of the BYPASS field
    BWADJ_val = (PLLM_val) >> 1; // setup BWADJ to be 1/2 the value of PLLM
    debug_info_on = 1;
    delay = 1000; // fix this!
    /* Step 1: Unlock Boot Config Registers */
    KICK0 = KICK0_UNLOCK;
    KICK1 = KICK1_UNLOCK;
    /* Step 2: Check if SECCTL bypass is low or high indicating what state the Main PLL is currently in. if
    the Main PLL is in bypass still (not yet setup) execute the following steps. */
    if(BYPASS_val != 0x00000000){ // PLL bypass enabled - Execute PLL setup for PLL fresh out of power on reset
    if(debug_info_on){
    GEL_TextOut("Detected PLL bypass enabled: SECCTL[BYPASS] = %x\n",,,,, BYPASS_val);
    /* Step 2a: Set MAINPLLCTL1[ENSAT] = 1 - This enables proper biasing of PLL analog circuitry */
    MAINPLLCTL1 |= (1 << MAIN_ENSAT_OFFSET);
    if(debug_info_on){
    GEL_TextOut("(2a) MAINPLLCTL1 = %x\n",,,,, MAINPLLCTL1);
    /* Step 2b: Set PLLCTL[PLLEN] = 0 This enables bypass in PLL controller MUX */
    PLL1_PLLCTL &= ~(1 << PLLEN_OFFSET);
    if(debug_info_on){
    GEL_TextOut("(2b) PLLCTL = %x\n",,,,, PLL1_PLLCTL);
    /* Step 2c: Set PLLCTL[PLLENSRC] = 0 - This enables PLLEN to control PLL controller MUX */
    PLL1_PLLCTL &= ~(1 << PLLENSRC_OFFSET);
    if(debug_info_on){
    GEL_TextOut("(2c) PLLCTL = %x\n",,,,, PLL1_PLLCTL);
    /* Step 2d: Wait 4 reference clock cycles (slowest of ALTCORE or SYSCLK) to make sure
    that the PLL controller MUX switches properly to bypass. */
    if(debug_info_on){
    GEL_TextOut("(2d) Delay...\n",,,,,);
    for(i = 0; i < delay; i++); // this delay is much more than required
    /* Step 2e: Set SECCTL[BYPASS] = 1 - enables bypass in PLL MUX */
    PLL1_SECCTL |= (1 << BYPASS_OFFSET);
    if(debug_info_on){
    GEL_TextOut("(2e) SECCTL = %x\n",,,,, PLL1_SECCTL);
    /* Step 2f: Set PLLCTL[PLLPWRDN] = 1 - power down the PLL */
    PLL1_PLLCTL |= (1 << PLLPWRDN_OFFSET);
    if(debug_info_on){
    GEL_TextOut("(2f) PLLCTL = %x\n",,,,, PLL1_PLLCTL);
    /* Step 2g: Wait for at least 5us for the PLL to power down */
    if(debug_info_on){
    GEL_TextOut("(2g) Delay...\n",,,,,);
    /* Step 2h: Set PLLCTL[PLLPWRDN] = 0 - Power the PLL back up */
    PLL1_PLLCTL &= ~(1 << PLLPWRDN_OFFSET);
    if(debug_info_on){
    GEL_TextOut("(2h) PLLCTL = %x\n",,,,, PLL1_PLLCTL);
    else{ // PLL bypass disabled - Execute PLL setup for PLL that has previously been locked (skip to Step 3)
    if(debug_info_on){
    GEL_TextOut("Detected PLL bypass disabled: SECCTL[BYPASS] = %x\n",,,,, BYPASS_val);
    /* Step 3a: Set PLLCTL[PLLEN] = 0 This enables bypass in PLL controller MUX */
    if(debug_info_on){
    GEL_TextOut("(3a) PLLCTL = %x\n",,,,, PLL1_PLLCTL);
    /* Step 3b: Set PLLCTL[PLLENSRC] = 0 - This enables PLLEN to control PLL controller MUX */
    if(debug_info_on){
    GEL_TextOut("(3b) PLLCTL = %x\n",,,,, PLL1_PLLCTL);
    /* Step 3c: Wait 4 reference clock cycles (slowest of ALTCORE or SYSCLK) to make sure
    if(debug_info_on){
    GEL_TextOut("(3c) Delay...\n",,,,,);
    /* Step 4: Programming PLLM[5:0] in the PLLM register of the PLL controller and
    programming PLLM[12:6] in the MAINPLLCTL0 register */
    PLL1_PLLM &= PLLM_MASK; // clear the PLLM[5:0] bit field
    PLL1_PLLM |= ~PLLM_MASK & (PLLM_val - 1); // set the PLLM[5:0] bit field to the 6 LSB of PLLM_val
    if(debug_info_on){
    GEL_TextOut("(4)PLLM[PLLM] = %x\n",,,,, PLL1_PLLM);
    MAINPLLCTL0 &= MAIN_PLLM_MASK; // clear the PLLM[12:6] bit field
    MAINPLLCTL0 |= ~MAIN_PLLM_MASK & (( (PLLM_val - 1) >> 6) << MAIN_PLLM_OFFSET); // set the PLLM[12:6] bit field to the 7 MSB of PLL_val
    if(debug_info_on){
    GEL_TextOut("MAINPLLCTL0 = %x\n",,,,, MAINPLLCTL0);
    /* Step 5: Programming BWADJ[7:0] in the MAINPLLCTL0 register and BWADJ[11:8] in MAINPLLCTL1 register */
    MAINPLLCTL0 &= MAIN_BWADJ0_MASK; // clear the MAIN_BWADJ0 bit field
    MAINPLLCTL0 |= ~MAIN_BWADJ0_MASK & ((BWADJ_val - 1) << MAIN_BWADJ0_OFFSET); // set the MAIN_BWADJ[7:0] bit field to the 8 LSB of BWADJ_val
    if(debug_info_on){
    GEL_TextOut("(5) MAINPLLCTL0 = %x\n",,,,, MAINPLLCTL0);
    MAINPLLCTL1 &= MAIN_BWADJ1_MASK; // clear the MAIN_BWADJ1 bit field
    MAINPLLCTL1 |= ~MAIN_BWADJ1_MASK & (( (BWADJ_val - 1) >> 8) << MAIN_BWADJ1_OFFSET); // set the MAIN_BWADJ[11:8] bit field to the 4 MSB of BWADJ_val
    if(debug_info_on){
    GEL_TextOut("(5) MAINPLLCTL1 = %x\n",,,,, MAINPLLCTL1);
    /* Step 6: Programming PLLD[5:0] in the MAINPLLCTL0 register */
    MAINPLLCTL0 &= MAIN_PLLD_MASK; // clear the PLLD bit field
    MAINPLLCTL0 |= ~MAIN_PLLD_MASK & (PLLD_val - 1); // set the PLLD[5:0] bit field of PLLD to PLLD_val
    if(debug_info_on){
    GEL_TextOut("(6) MAINPLLCTL0 = %x\n",,,,, MAINPLLCTL0);
    /* Step 7: Programming OD[3:0] in the SECCTL register */
    PLL1_SECCTL &= OUTPUT_DIVIDE_MASK; // clear the OD bit field
    PLL1_SECCTL |= ~OUTPUT_DIVIDE_MASK & (OD_val - 1) << OUTPUT_DIVIDE_OFFSET; // set the OD[3:0] bit field of PLLD to OD_val
    if(debug_info_on){
    GEL_TextOut("(7) SECCTL = %x\n",,,,, PLL1_SECCTL);
    /* Step 8: Following steps are needed to change the default output dividers */
    /* Step 8a: Check that the GOSTAT bit in PLLSTAT is cleared to show that no GO
    operation is currently in progress*/
    if(debug_info_on){
    GEL_TextOut("(8a) Delay...\n",,,,,);
    while((PLL1_STAT) & 0x00000001);
    /* Step 8b: Program the RATIO field in PLLDIVn to the desired new divide-down rate.
    If RATIO field is changed, the PLL controller will flag the change in the
    corresponding bit of DCHANGE*/
    PLL1_DIV3 = (PLLDIV3_val-1) | 0x8000; //Set PLLDIV3
    PLL1_DIV4 = (PLLDIV4_val-1) | 0x8000; //Set PLLDIV4
    PLL1_DIV7 = (PLLDIV7_val-1) | 0x8000; //Set PLLDIV7
    if(debug_info_on){
    GEL_TextOut("PLL1_DIV3 = %x\n",,,,, PLL1_DIV3);
    GEL_TextOut("PLL1_DIV4 = %x\n",,,,, PLL1_DIV4);
    GEL_TextOut("PLL1_DIV7 = %x\n",,,,, PLL1_DIV7);
    /* Step 8c: Set GOSET bit in PLLCMD to initiate the GO operation to change the divide
    values and align the SYSCLKs as programmed */
    PLL1_CMD |= 0x00000001;
    /*Step 8d/e: Read the GOSTAT bit in PLLSTAT to make sure the bit returns to 0 to
    indicate that the GO operation has completed */
    if(debug_info_on){
    GEL_TextOut("(8d/e) Delay...\n",,,,,);
    /* Step 9: Set PLLCTL[PLLRST] = 1 - Assert PLL reset (Previously Step 3)*/
    PLL1_PLLCTL |= (1 << PLLRST_OFFSET);
    /* Step 10: Wait for the at least 7us for the PLL reset properly (128 CLKIN1 cycles) */
    if(debug_info_on){
    GEL_TextOut("(10) Delay...\n",,,,,);
    for(i=0;i<delay;i++);
    /* Step 11: Set PLLCTL[PLLRST] = 0 - De-Assert PLL reset */
    PLL1_PLLCTL &= ~(1 << PLLRST_OFFSET);
    /* Step 12: Wait for PLL to lock (2000 CLKIN1 cycles) */
    if(debug_info_on){
    GEL_TextOut("(12) Delay...\n",,,,,);
    /* Step 13: In SECCTL, write BYPASS = 0 (enable PLL mux to switch to PLL mode) */
    PLL1_SECCTL &= ~(1 << BYPASS_OFFSET);
    if(debug_info_on){
    GEL_TextOut("(13) SECCTL = %x\n",,,,, PLL1_SECCTL);
    if(debug_info_on){
    GEL_TextOut("(Delay...\n",,,,,);
    if(debug_info_on){
    /* Step 14: In PLLCTL, write PLLEN = 1 to enable PLL mode */
    PLL1_PLLCTL |= (1 << PLLEN_OFFSET);
    if(debug_info_on){
    GEL_TextOut("(14) PLLCTL = %x\n",,,,, PLL1_PLLCTL);
    /* Step 15: Lock Boot Config Registers */
    KICK0 = 0x00000000;
    KICK1 = 0x00000000;
    GEL_TextOut("PLL has been configured (CLKIN * PLLM / PLLD / PLLOD = PLLOUT):\n",,,,,);
    GEL_TextOut("PLL has been configured (%f MHz * %d / %d / 2 = %f MHz)\n",,,,, CLKIN_val, PLLM_val, PLLD_val, (CLKIN_val * PLLM_val / PLLD_val / 2) );
    Set_Tetris_Pll(int index)
    float CLKIN_val;
    int i;
    GEL_TextOut("Switching on ARM Core 0\n",,,,,);
    TETRIS_CPU0_PDCTL = 0x00000000;
    TETRIS_CPU0_PTCMD = 0x00000001;
    GEL_TextOut("Switching on ARM Core 1\n",,,,,);
    TETRIS_CPU1_PDCTL = 0x00000000;
    TETRIS_CPU1_PTCMD = 0x00000001;
    GEL_TextOut("Switching on ARM Core 2\n",,,,,);
    TETRIS_CPU2_PDCTL = 0x00000000;
    TETRIS_CPU2_PTCMD = 0x00000001;
    GEL_TextOut("Switching on ARM Core 3\n",,,,,);
    TETRIS_CPU3_PDCTL = 0x00000000;
    TETRIS_CPU3_PTCMD = 0x00000001;
    if(index == 1){ // 100 MHz -> 1.0 GHz
    CLKIN_val = 125; // setup CLKIN to 125 MHz
    PLLM_val = 16; // setup PLLM (PLL multiplier) to x20
    else if(index == 2){ // 100 MHz -> 1.4 GHz
    PLLM_val = 22; // setup PLLM (PLL multiplier) to x28
    else if(index == 3){ // 174.825MHz -> 1.4 GHz
    CLKIN_val = 174.825; // setup CLKIN to 174.825 MHz
    PLLM_val = 16; // setup PLLM (PLL multiplier) to x16
    BWADJ_val = (PLLM_val-1) >> 1; // setup BWADJ to be 1/2 the value of PLLM
    //Step 1 : Assert SEC PLL Reset
    SECPLLCTL1 = ((1 << SEC_PLLCTL1_RESET_OFFSET) | (1 << SEC_PLLCTL1_ENSTAT_OFFSET));
    //Step 2 : Change CLKF/OD/BWADJ etc. for SEC PLL
    SECPLLCTL0 = ((BWADJ_val << SEC_PLLCTL0_BWADJ_OFFSET) |
    ((OD_val-1) << SEC_PLLCTL0_OD_OFFSET)|
    ((PLLM_val-1) << SEC_PLLCTL0_PLLM_OFFSET));
    //Step 3 : Make sure the resets are held for 5us
    for(i = 0; i < 200000; i++);
    //Step 4 : Remove SEC PLL reset
    SECPLLCTL1 = (1 << SEC_PLLCTL1_ENSTAT_OFFSET);
    //Step 5 : Wait for PLL to lock (4000 CLKIN1 cycles)
    for(i = 0; i < 4000; i++);
    //Step 6 : Get the PLL out of Bypass
    //SECPLLCTL0 &= ~(1 << SEC_PLLCTL0_BYPASS_OFFSET);
    CHIP_MISC1 |= (1 << ARMPLL_ENABLE_OFFSET);
    //Step 6 : Lock Boot Config Registers
    KICK0 = 0x00000000;
    KICK1 = 0x00000000;
    GEL_TextOut("ARM PLL has been configured (%f MHz * %d / %d = %f MHz)\n",,,,, CLKIN_val, PLLM_val, OD_val, (CLKIN_val * PLLM_val)/OD_val);
    /* Set the desired PA PLL configuration */
    PaPllConfig()
    unsigned int passclksel = (DEVSTAT & PASSCLKSEL_MASK);
    unsigned int papllctl0val_orig = PAPLLCTL0;
    unsigned int papllctl1val_orig = PAPLLCTL1;
    unsigned int papllctl0val_final;
    unsigned int papllctl1val_final;
    unsigned int papllclkf = 16; //204; // 204; 20 (if PASSREFCLK == 100mhz) Multiply by clkf + 1
    unsigned int papllclkd = 0; //11; // 11; 1 (if PASSREFCLK == 100mhz) Divide by clkd + 1
    unsigned int i = 0;
    if (passclksel != PASSCLKSEL_MASK) GEL_TextOut("WARNING: SYSCLK is the input to the PA PLL.\n");
    /* Unlock Chip Level Registers */
    // PAPLLCTL1 = PAPLLCTL1 | 0x00000040; //Set ENSAT = 1; Set PLL Select to 0 (for SYCLK0 as input of PASS)
    PAPLLCTL1 = PAPLLCTL1 | 0x00002040; //Set ENSAT = 1; Set PLL Select to 1 (for PA PLL as input of PASS)
    /*in PAPLLCTL0, clear bypass bit to set the PA PLL in Bypass Mode*/
    //PAPLLCTL0 &= ~(1<<BYPASS_BIT_SHIFT); // Not setting Bypass bit
    PAPLLCTL0 |= (1<<BYPASS_BIT_SHIFT); // Actually setting bypass bit
    /*Wait 4 cycles for the slowest of PLLOUT or reference clock source (CLKIN)*/
    for(i=0;i<100;i++);
    /*In PAPLLCTL1, write PLL reset bit to put the PLL in reset*/
    PAPLLCTL1 |= PA_PLL_RESET_MASK;
    /* Program the multiplier value */
    PAPLLCTL0 &= (~PA_PLL_CLKF_MASK); //clear multiplier value
    PAPLLCTL0 &= (~PA_PLL_CLKR_MASK); //clear divider value
    PAPLLCTL0 |= (papllclkf<<CLKF_BIT_SHIFT); // set PLLM
    PAPLLCTL0 |= (papllclkd<<CLKD_BIT_SHIFT); // set PLLD
    PAPLLCTL0 &= 0x00FFFFFF;
    PAPLLCTL0 |= ((((papllclkf + 1)>>1)-1)<<24);
    //PAPLLCTL1 = PAPLLCTL1 | 0x00002000;
    /*Wait for PLL to properly reset (128 CLKIN1 cycles) */
    for(i=0;i<1000;i++);
    /* take the PA PLL out of reset */
    PAPLLCTL1 &= (~PA_PLL_RESET_MASK);
    /*Wait for PLL to lock (2000 CLKIN1 cycles) */
    for(i=0;i<5000;i++);
    /* enable PLL mode */
    PAPLLCTL0 &= ~(1<<BYPASS_BIT_SHIFT); // actually setting PLL MODE
    for(i=0;i<4000;i++);
    /* Lock Chip Level Registers */
    KICK0 = KICK_LOCK;
    KICK1 = KICK_LOCK;
    papllctl0val_final = PAPLLCTL0;
    papllctl1val_final = PAPLLCTL1;
    GEL_TextOut("Completed PA PLL Setup\n");
    GEL_TextOut("PAPLLCTL0 - before: 0x%x\t after: 0x%x\n",,,,, papllctl0val_orig, papllctl0val_final);
    GEL_TextOut("PAPLLCTL1 - before: 0x%x\t after: 0x%x\n",,,,, papllctl1val_orig, papllctl1val_final);
    if ((papllctl0val_final != 0x09080500) || (papllctl1val_final != 0x00002040))
    return 1;
    return 0;
    //--------DDR3A Memory test----------------------
    ddr3A_memory_test ()
    unsigned int index, value;
    GEL_TextOut( "DDR3A memory test... Started\n" );
    /* Write a pattern */
    for (index = DDR3A_TEST_START_ADDRESS; index < DDR3A_TEST_END_ADDRESS; index += 4) {
    *index = index;
    /* Read and check the pattern */
    value = *index;
    if (value != index) {
    GEL_TextOut( "DDR3A memory test... Failed\n" );
    return -1;
    /* Write a pattern for complementary values */
    *index = ~index;
    value = *index;
    if (value != ~index) {
    return -1;
    GEL_TextOut( "DDR3A memory test... Passed\n" );
    return 0;
    //--------DDR3B Memory test----------------------
    ddr3B_memory_test ()
    GEL_TextOut( "DDR3B memory test... Started\n" );
    for (index = DDR3B_TEST_START_ADDRESS; index < DDR3B_TEST_END_ADDRESS; index += 4) {
    *index = index;
    value = *index;
    GEL_TextOut( "DDR3B memory test... Failed\n" );
    return -1;
    *index = ~index;
    value = *index;
    return -1;
    GEL_TextOut( "DDR3B memory test... Passed\n" );
    return 0;
    * NAME
    * Setup_Memory_Map
    * PURPOSE:
    * Setup the Memory Map for EVMC6678L.
    * Defined memory location avoid debugger access outside these locations.
    * USAGE
    * Setup_Memory_Map()
    * RETURN VALUE
    * NONE
    * REFERENCE
    * Based on TMS320C6678 datasheet.
    hotmenu Setup_Memory_Map( )
    GEL_TextOut("Setup_Memory_Map...\n",,);
    GEL_MapOn( );
    GEL_MapReset( );
    GEL_MapAddStr( 0x00000000, 0, 0x21400000, "R|W|AS4", 0 ); //
    GEL_MapAddStr( 0x21400000,0, 0x00000080, "R|W|AS4", 0 ); // Hyperlink Config (remote)
    //GEL_MapAddStr( 0x21400080,0, 0x00000080, "R|W|AS4", 0 ); // Hyperlink Config (remote)
    GEL_MapAddStr( 0x21400200, 0, 0xdebffe00, "R|W|AS4", 0 ); //
    GEL_TextOut( "Setup_Memory_Map... Done.\n" );
    /*----------------------------------------------------- DDR3A : DDR800, 32bit--------------------------------------------------------------------------*/
    unsigned int multiplier = 15;
    unsigned int divider = 0;
    int temp;
    unsigned int OD_val = 8;
    KICK0 = 0x83E70B13;
    KICK1 = 0x95A4F1E0;
    //1. Poll for IDONE=1 in the PHY General Status Register 0 (address offset 0x010).
    do {
    read_val = DDR3A_PGSR0;
    } while ((read_val&0x00000001) != 0x00000001);
    //4. Clocks are enabled and frequency is stable---------------------------------------
    //DDR3A PLL setup
    GEL_TextOut ( "DDR3 PLL (PLL2) Setup ... \n");
    //DDR3APLLCTL0 = DDR3APLLCTL0 & 0xFF7FFFFF;
    // Set ENSAT = 1
    DDR3APLLCTL1 |= 0x00000040;
    // Put the PLL in PLL Mode
    DDR3APLLCTL0 |= 0x00800000;
    // In PLL Controller, reset the PLL (bit 13 in DDR3APLLCTL1 register)
    DDR3APLLCTL1 |= 0x00002000;
    // Program the necessary multipliers/dividers and BW adjustments
    // Set the divider values
    DDR3APLLCTL0 &= ~(0x0000003F);
    DDR3APLLCTL0 |= (divider & 0x0000003F);
    DDR3APLLCTL0 &= OUTPUT_DIVIDE_MASK; // clear the OD bit field
    DDR3APLLCTL0 |= ~OUTPUT_DIVIDE_MASK & (OD_val - 1) << OUTPUT_DIVIDE_OFFSET; // set the OD[3:0] bit field of PLLD to OD_val
    /* Set the Multipler values */
    DDR3APLLCTL0 &= ~(0x0007FFC0);
    DDR3APLLCTL0 |= ((multiplier << 6) & 0x0007FFC0 );
    temp = ((multiplier + 1) >> 1) - 1;
    DDR3APLLCTL0 &= ~(0xFF000000);
    DDR3APLLCTL0 |= ((temp << 24) & 0xFF000000);
    DDR3APLLCTL1 &= ~(0x0000000F);
    DDR3APLLCTL1 |= ((temp >> 8) & 0x0000000F);
    //In DDR3PLLCTL1, write PLLRST = 0 to bring PLL out of reset
    DDR3APLLCTL1 &= ~(0x00002000);
    DDR3APLLCTL0 &= ~(0x00800000); // ReSet the Bit 23
    GEL_TextOut( "DDR3 PLL Setup complete, DDR3A clock now running at 400MHz.\n" );
    //DDR3A PLL setup complete ---------------------------------------
    /*------------------------- Start PHY Configuration -------------------------------*/
    //DDR3A_PGCR1 = 0x0280C487;
    //5.a Program FRQSEL in the PLL Control Register (address offset 0x018).
    DDR3A_PLLCR = 0xDC000; //Set FRQSEL=11, for ctl_clk between 166-275MHz
    //5.b. Program WLSTEP=1, IODDRM=1, and ZCKSEL in the PHY General Configuration Register 1 (address offset 0x00C).
    DDR3A_PGCR1 |= (1 << 2); //WLSTEP = 1
    DDR3A_PGCR1 &= ~(IODDRM_MASK);
    DDR3A_PGCR1 |= (( 1 << 7) & IODDRM_MASK);
    DDR3A_PGCR1 &= ~(ZCKSEL_MASK);
    DDR3A_PGCR1 |= (( 1 << 23) & ZCKSEL_MASK);
    //5.c. Program PHY Timing Parameters Register 0-4 (address offset 0x01C - 0x02C).
    DDR3A_PTR0 = 0x42C21590;
    DDR3A_PTR1 = 0xD05612C0;
    // Maintaining default values of Phy Timing Parameters Register 2 in PUB
    DDR3A_PTR3 = 0x06C30D40;//0x18061A80;
    DDR3A_PTR4 = 0x06413880;//0x0AAE7100;
    //5.d. Program PDQ, MPRDQ, and BYTEMASK in the DRAM Configuration Register (address offset 0x044).
    // All other fields must be left at their default values.
    DDR3A_DCR &= ~(PDQ_MASK); //PDQ = 0
    DDR3A_DCR &= ~(MPRDQ_MASK); //MPRDQ = 0
    DDR3A_DCR &= ~(BYTEMASK_MASK);
    DDR3A_DCR |= (( 1 << 10) & BYTEMASK_MASK);
    DDR3A_DCR &= ~(NOSRA_MASK);
    DDR3A_DCR |= (( 1 << 27) & NOSRA_MASK);
    DDR3A_DCR &= ~(UDIMM_MASK);
    DDR3A_DCR |= (( 1 << 29) & UDIMM_MASK);
    //5.e. Program DRAM Timing Parameters Register 0-2 (address offset 0x048 - 0x050).
    DDR3A_DTPR0 = 0x50CF6644; //0x50CE6644;
    DDR3A_DTPR1 = 0x12834180;
    DDR3A_DTPR2 = 0x50022A00;
    //5.f. Program BL=0, CL, WR, and PD=1 in the Mode Register 0 (address offset 0x054).
    //All other fields must be left at their default values.
    DDR3A_MR0 = 0x00001420;
    //5.g. Program DIC, RTT, and TDQS in the Mode Register 1 (address offset 0x058).
    DDR3A_MR1 = 0x00000006;
    //5.h. Program Mode Register 2 (address offset 0x05C).
    // Maintaining default values of Program Mode Register 2
    // DDR3A_MR2 = 0x00000018;
    //5.i. Program DTMPR=1, DTEXD, DTEXG, RANKEN=1 or 3, and RFSHDT=7 in the Data Training Configuration Register (address offset 0x068).
    DDR3A_DTCR = 0x710035C7; //0x710035C7;
    //5.j. Program tREFPRD=(5*tREFI/ddr_clk_period) in the PHY General Configuration Register 2 (address offset 0x08C).
    DDR3A_PGCR2 = 0x00F03D09; //NOBUB = 0, FXDLAT = 0
    //DDR3A_PGCR2 = 0x00F83D09; //NOBUB = 0, FXDLAT = 1
    //Set Impedence Register
    DDR3A_ZQ0CR1 = 0x0000005D;
    DDR3A_ZQ1CR1 = 0x0000005B;
    DDR3A_ZQ2CR1 = 0x0000005B;
    //6. Re-trigger PHY initialization in DDR PHY through the VBUSP interface.
    //6.a. Program 0x00000033 to the PHY Initialization Register (address offset 0x004) to re-trigger PLL, ZCAL, and DCAL initialization.
    DDR3A_PIR = 0x00000033;
    //6.b. Poll for IDONE=1 in the PHY General Status Register 0 (address offset 0x010).
    do {
    // 7. Trigger DDR3 initialization and leveling/training in DDR PHY through the VBUSP interface.
    // a. If using a 16-bit wide DDR interface, program DXEN=0 in the DATX8 2-7 General Configuration Registers (address offsets 0x240, 0x280, 0x2C0, 0x300, 0x340, and 0x380) to disable the leveling/training for the upper byte lanes.
    // b. If using a 32-bit wide DDR interface, program DXEN=0 in the DATX8 4-7 General Configuration Registers (address offsets 0x2C0, 0x300, 0x340, and 0x380) to disable the leveling/training for the upper byte lanes.
    // c. If ECC is not required, program DXEN=0 in the DATX8 8 General Configuration Register (address offset 0x3C0) to disable the leveling/training for the ECC byte lane.
    // NOTE: Setup supports 64-bit by default, ECC enable by default.
    //7.d. Program 0x0000XF81 to the PHY Initialization Register (address offset 0x004) to trigger DDR3 initialization and leveling/training sequences
    DDR3A_PIR = 0x00000F81; //WLADJ - ON
    //DDR3A_PIR = 0x00000781; //WLADJ - OFF
    //7.e. Poll for IDONE=1 in the PHY General Status Register 0 (address offset 0x010).
    do {
    /* End PHY Configuration */
    /* START EMIF INITIALIZATION
    ++++++++++++++++++SDCFG Register Calculation+++++++++++++++++++
    | 31 - 29 | 28 |27 - 25 | 24 | 23 - 22| 21 - 17 |
    |SDRAM_TYPE|Rsvd|DDR_TERM| DDQS | DYN_ODT| Rsvd |
    | 0x011 | 0 | 0x011 | 0x1 | 0x00 | 0x0 |
    | 16-14 |13 - 12 | 11 - 8 | 7 |6 - 5 | 4 | 3 | 2 | 1 - 0 |
    | CWL | NM | CL | Rsvd |IBANK | Rsvd|EBANK| Rsvd|PAGE_SIZE|
    | 0x11 | 0x00 | 0x1110 | 0x0 | 0x11 | 0x0 | 0 | 0 | 0x10 |
    SDCFG = 0x0110 0011 0010 0010 0011 0011 1011 0010
    SDCFG = 0x6700486A;//0x63223332
    SDRAM_TYPE = 3
    DDR_TERM = 3 (RZQ/4 = 1; RZQ/6=3)
    DDQS = 1
    DYN_ODT = 0
    CWL = 3 (CWL5=0; CWL6=1; CWL7=2; CWL8=3)
    NM = 0 (64-bit=0, 32-bit=1, 16-bit=2)
    CL = 14 (CL5=2; CL6=4; CL7=6; CL8=8; CL9=10; CL10=12; CL11=14)
    IBANK = 3 (8bank)
    EBANK = 0 (0 - pad_cs_o_n[0] , 1 - pad_cs_o_n[1:0])
    PAGE_SIZE = 2 (1024page-size=2; 2048page-size=3)
    /* Start DDR3A EMIF Configuration */
    //8. Configure the EMIF through the VBUSM interface.
    //8.a. Program all EMIF MMR’s.
    DDR3A_SDCFG = 0x62001462 ; //0x6200046A
    DDR3A_SDTIM1 = 0x0A384C23;
    DDR3A_SDTIM2 = 0x00001CA5;
    DDR3A_SDTIM3 = 0x21ADFF32;
    DDR3A_SDTIM4 = 0x533F067F;
    DDR3A_ZQCFG = 0xF0073200;
    //8.b. Program reg_initref_dis=0 in the SDRAM Refresh Control Register (address offset 0x10).
    DDR3A_SDRFC = 0x00000C34;
    GEL_TextOut("DDR3A initialization complete \n");
    /* End DDR3A EMIF Configuration */
    /*----------------------------------------------------- DDR3A : DDR1066, 32bit--------------------------------------------------------------------------*/
    int temp;
    unsigned int OD_val = 6;
    KICK0 = 0x83E70B13;
    KICK1 = 0x95A4F1E0;
    do {
    //DDR3A PLL setup
    // Set ENSAT = 1
    GEL_TextOut( "DDR3 PLL Setup complete, DDR3A clock now running at 533MHz.\n" );
    DDR3A_PTR3 = 0x05B41104;//0x09041104;//0x18061A80;
    DDR3A_PTR4 = 0x0855A068;//0x0AAE7100;
    //DDR3A_DCR &= ~(UDIMM_MASK);
    //DDR3A_DCR |= (( 1 << 29) & UDIMM_MASK);
    //RRMODE
    //DDR3A_DSGCR &= ~(RRMODE_MASK); //RR_MODE = 0
    //DDR3A_DSGCR &= ~(RRMODE_MASK); //RR_MODE = 1
    //DDR3A_DSGCR |= (( 1 << 18) & RRMODE_MASK);
    DDR3A_DTPR0 = 0x6D147764;//0x6D148844; //0x6D148844; 0x69137764 ---changed in rev 1.3
    DDR3A_DTPR1 = 0x1282B200;//0x12845A00;
    DDR3A_DTPR2 = 0x50023600;
    DDR3A_MR0 = 0x00001830; //0x00001870;
    DDR3A_MR1 = 0x00000006; //0x00000044; ---changed in rev 1.3
    DDR3A_MR2 = 0x00000008; //18 ---changed in rev 1.3
    DDR3A_DTCR = 0x710035C7; //0x730035C7;
    DDR3A_PGCR2 = 0x00F05159; //NOBUB = 0, FXDLAT = 0
    do {
    do {
    SDRAM_TYPE = 3
    DDQS = 1
    DYN_ODT = 0
    IBANK = 3 (8bank)
    DDR3A_SDCFG = 0x62005662; //0x62005662;
    DDR3A_SDTIM1 = 0x0E4C6835; //0x0E4C6833;//0x0E4C6833;
    DDR3A_SDTIM2 = 0x00001CC6; //0x00001CE7;
    DDR3A_SDTIM3 = 0x3169FF32; //0x323DFF32;
    DDR3A_SDTIM4 = 0x533F055F; //0x533F08AF;
    DDR3A_ZQCFG = 0x70073200;//0xF0073200;
    DDR3A_SDRFC = 0x00001044;
    /*----------------------------------------------------- DDR3A : DDR1333, 32bit--------------------------------------------------------------------------*/
    unsigned int multiplier = 19;
    int temp;
    KICK0 = 0x83E70B13;
    KICK1 = 0x95A4F1E0;
    do {
    //DDR3A PLL setup
    // Set ENSAT = 1
    GEL_TextOut( "DDR3 PLL Setup complete, DDR3A clock now running at 666 MHz.\n" );
    DDR3A_PLLCR = 0x5C000; //Set FRQSEL=11, for ctl_clk between 166-275MHz
    DDR3A_PTR3 = 0x0B4515C2;//0x072515C2; //0x0B4515C2;//0x18061A80;
    DDR3A_PTR4 = 0x0A6E08B4;//0x0AAE7100;
    DDR3A_DTPR0 = 0x8558AA75;//0x85589975;//0x8558AA55;
    DDR3A_DTPR1 = 0x12857280;//0x12835A80;//0x12857280;
    DDR3A_DTPR2 = 0x5002C200;
    DDR3A_MR0 = 0x00001A60; //50
    DDR3A_MR2 = 0x00000010;
    DDR3A_PGCR2 = 0x00F065B8; //NOBUB = 0, FXDLAT = 0
    //DDR3A_ZQ3CR1 = 0x0000005D;
    do {
    DDR3A_PIR = 0x0000FF81; //WLADJ - ON
    do {
    SDRAM_TYPE = 3
    DDQS = 1
    DYN_ODT = 0
    IBANK = 3 (8bank)
    DDR3A_SDCFG = 0x62009C62; // 9A62//0x62008C62 ;//0x6600CE62=single rank,0x6600CE6A=dual rank
    DDR3A_SDTIM1 = 0x125C8044;
    DDR3A_SDTIM2 = 0x00001D29;
    DDR3A_SDTIM3 = 0x32CDFF43;
    DDR3A_SDTIM4 = 0x543F0ADF;
    DDR3A_SDRFC = 0x00001457;
    /*----------------------------------------------------- DDR3B : DDR800, 64bit--------------------------------------------------------------------------*/
    int temp;
    KICK0 = 0x83E70B13;
    KICK1 = 0x95A4F1E0;
    do {
    read_val = DDR3B_PGSR0;
    //DDR3B PLL setup
    //DDR3BPLLCTL0 = DDR3BPLLCTL0 & 0xFF7FFFFF;
    // Set ENSAT = 1
    DDR3BPLLCTL1 |= 0x00000040;
    DDR3BPLLCTL0 |= 0x00800000;
    // In PLL Controller, reset the PLL (bit 13 in DDR3BPLLCTL1 register)
    DDR3BPLLCTL1 |= 0x00002000;
    DDR3BPLLCTL0 &= ~(0x0000003F);
    DDR3BPLLCTL0 |= (divider & 0x0000003F);
    DDR3BPLLCTL0 &= OUTPUT_DIVIDE_MASK; // clear the OD bit field
    DDR3BPLLCTL0 |= ~OUTPUT_DIVIDE_MASK & (OD_val - 1) << OUTPUT_DIVIDE_OFFSET; // set the OD[3:0] bit field of PLLD to OD_val
    DDR3BPLLCTL0 &= ~(0x0007FFC0);
    DDR3BPLLCTL0 |= ((multiplier << 6) & 0x0007FFC0 );
    DDR3BPLLCTL0 &= ~(0xFF000000);
    DDR3BPLLCTL0 |= ((temp << 24) & 0xFF000000);
    DDR3BPLLCTL1 &= ~(0x0000000F);
    DDR3BPLLCTL1 |= ((temp >> 8) & 0x0000000F);
    DDR3BPLLCTL1 &= ~(0x00002000);
    DDR3BPLLCTL0 &= ~(0x00800000); // ReSet the Bit 23
    GEL_TextOut( "DDR3 PLL Setup complete, DDR3B clock now running at 400MHz.\n" );
    //DDR3B PLL setup complete ---------------------------------------
    //DDR3B_PGCR1 = 0x0280C487;
    DDR3B_PLLCR = 0xDC000; //Set FRQSEL=11, for ctl_clk between 166-275MHz
    DDR3B_PGCR1 |= (1 << 2); //WLSTEP = 1
    DDR3B_PGCR1 &= ~(IODDRM_MASK);
    DDR3B_PGCR1 |= (( 1 << 7) & IODDRM_MASK);
    DDR3B_PGCR1 &= ~(ZCKSEL_MASK);
    DDR3B_PGCR1 |= (( 1 << 23) & ZCKSEL_MASK);
    //RRMODE
    //DDR3B_DSGCR &= ~(RRMODE_MASK); //RR_MODE = 0
    //DDR3B_DSGCR &= ~(RRMODE_MASK); //RR_MODE = 1
    //DDR3B_DSGCR |= (( 1 << 18) & RRMODE_MASK);
    DDR3B_PTR0 = 0x42C21590;
    DDR3B_PTR1 = 0xD05612C0;
    DDR3B_PTR3 = 0x06C30D40;//0x18061A80;
    DDR3B_PTR4 = 0x6413880;//0x0AAE7100;
    DDR3B_DCR &= ~(PDQ_MASK); //PDQ = 0
    DDR3B_DCR &= ~(MPRDQ_MASK); //MPRDQ = 0
    DDR3B_DCR &= ~(BYTEMASK_MASK);
    DDR3B_DCR |= (( 1 << 10) & BYTEMASK_MASK);
    DDR3B_DCR &= ~(NOSRA_MASK);
    DDR3B_DCR |= (( 1 << 27) & NOSRA_MASK);
    //DDR3B_DCR &= ~(UDIMM_MASK);
    //DDR3B_DCR |= (( 1 << 29) & UDIMM_MASK);
    DDR3B_DTPR0 = 0x50CE6644;
    DDR3B_DTPR1 = 0x12834180;
    DDR3B_DTPR2 = 0x50022A00;
    DDR3B_MR0 = 0x00001420;
    DDR3B_MR1 = 0x00000006;
    // DDR3B_MR2 = 0x00000018;
    DDR3B_DTCR = 0x710035C7; //0x710035C7;
    DDR3B_PGCR2 = 0x00F03D09; //NOBUB = 0, FXDLAT = 0
    //DDR3B_PGCR2 = 0x00F83D09; //NOBUB = 0, FXDLAT = 1
    DDR3B_ZQ0CR1 = 0x0000005D;
    DDR3B_ZQ1CR1 = 0x0000005B;
    DDR3B_ZQ2CR1 = 0x0000005B;
    DDR3B_PIR = 0x00000033;
    do {
    DDR3B_PIR = 0x00000F81; //WLADJ - ON
    //DDR3B_PIR = 0x00000781; //WLADJ - OFF
    do {
    SDRAM_TYPE = 3
    DDQS = 1
    DYN_ODT = 0
    IBANK = 3 (8bank)
    /* Start DDR3B EMIF Configuration */
    DDR3B_SDCFG = 0x62000462 ;
    DDR3B_SDTIM1 = 0x0A384C23;
    DDR3B_SDTIM2 = 0x00001CA5;
    DDR3B_SDTIM3 = 0x21ADFF32;
    DDR3B_SDTIM4 = 0x533F067F;
    DDR3B_ZQCFG = 0xF0073200;
    DDR3B_SDRFC = 0x00000C34;
    GEL_TextOut("DDR3B initialization complete \n");
    /* End DDR3B EMIF Configuration */
    /*----------------------------------------------------- DDR3B : DDR1066, 64bit--------------------------------------------------------------------------*/
    ddr3B_64bit_DDR1066_setup()
    int temp;
    KICK0 = 0x83E70B13;
    KICK1 = 0x95A4F1E0;
    do {
    //DDR3B PLL setup
    // Set ENSAT = 1
    GEL_TextOut( "DDR3 PLL Setup complete, DDR3B clock now running at 533MHz.\n" );
    DDR3B_PTR3 = 0x09041104;//0x18061A80;
    DDR3B_PTR4 = 0x0855A068;//0x0AAE7100;
    DDR3B_DTPR0 = 0x6D148844;
    DDR3B_DTPR1 = 0x12845A00;
    DDR3B_DTPR2 = 0x50023600;
    DDR3B_MR0 = 0x00001830; //0x00001870
    DDR3B_MR2 = 0x00000008;
    DDR3B_DTCR = 0x710035C7; //0x730035C7;
    DDR3B_PGCR2 = 0x00F05159; //NOBUB = 0, FXDLAT = 0
    do {
    do {
    SDRAM_TYPE = 3
    DDQS = 1
    DYN_ODT = 0
    IBANK = 3 (8bank)
    DDR3B_SDCFG = 0x62004662; //0x6600CE62=single rank, 0x6600CE6A=dual rank
    DDR3B_SDTIM1 = 0x0E4C6833;
    DDR3B_SDTIM2 = 0x00001CE7;
    DDR3B_SDTIM3 = 0x323DFF32;
    DDR3B_SDTIM4 = 0x533F08AF;
    DDR3B_SDRFC = 0x00001044;
    /*----------------------------------------------------- DDR3B : DDR1333, 64bit--------------------------------------------------------------------------*/
    ddr3B_64bit_DDR1333_setup()
    int temp;
    KICK0 = 0x83E70B13;
    KICK1 = 0x95A4F1E0;
    do {
    //DDR3B PLL setup
    // Set ENSAT = 1
    GEL_TextOut( "DDR3 PLL Setup complete, DDR3B clock now running at 666 MHz.\n" );
    DDR3B_PLLCR = 0x5C000; //Set FRQSEL=11, for ctl_clk between 166-275MHz
    DDR3B_PTR3 = 0x0B4515C2;//0x18061A80;
    DDR3B_PTR4 = 0x0A6E08B4;//0x0AAE7100;
    // DDR3B_DCR &= ~(UDIMM_MASK);
    // DDR3B_DCR |= (( 1 << 29) & UDIMM_MASK);
    DDR3B_DTPR0 = 0x8558AA55;
    DDR3B_DTPR1 = 0x12857280;
    DDR3B_DTPR2 = 0x5002C200;
    DDR3B_MR0 = 0x00001A60;
    DDR3B_MR2 = 0x00000010;
    DDR3B_PGCR2 = 0x00F065B8; //NOBUB = 0, FXDLAT = 0
    //DDR3B_ZQ3CR1 = 0x0000005D;
    do {
    DDR3B_PIR = 0x0000FF81; //WLADJ - ON
    do {
    SDRAM_TYPE = 3
    DDQS = 1
    DYN_ODT = 0
    IBANK = 3 (8bank)
    DDR3B_SDCFG = 0x62008C62 ;//0x6600CE62=single rank,0x6600CE6A=dual rank
    DDR3B_SDTIM1 = 0x125C8044;
    DDR3B_SDTIM2 = 0x00001D29;
    DDR3B_SDTIM3 = 0x32CDFF43;
    DDR3B_SDTIM4 = 0x543F0ADF;
    DDR3B_SDRFC = 0x00001457;
    /*----------------------------------------------------- DDR3B : DDR1600, 64bit--------------------------------------------------------------------------*/
    int temp;
    unsigned int OD_val = 4;
    KICK0 = 0x83E70B13;
    KICK1 = 0x95A4F1E0;
    do {
    //DDR3B PLL setup
    GEL_TextOut ( "DDR3 PLL Setup ... \n");
    // Set ENSAT = 1
    //DDR3BPLLCTL0 &= ~(0x00780000);
    //DDR3BPLLCTL0 |= ((OD_val << 19)& 0x00780000);
    GEL_TextOut( "DDR3 PLL Setup complete, DDR3B clock now running at 800MHz.\n" );
    DDR3B_PLLCR = 0x1C000; //Set FRQSEL=11, for ctl_clk between 166-275MHz
    DDR3B_PTR3 = 0x0D861A80;//
    DDR3B_PTR4 = 0x0C827100;
    DDR3B_DTPR0 = 0xA19DBB66;
    DDR3B_DTPR1 = 0x12868300;
    DDR3B_DTPR2 = 0x50035200;
    DDR3B_MR0 = 0x00001C70; //-CL - 11, CWL -8
    DDR3B_PGCR2 = 0x00F07A12; //NOBUB = 0, FXDLAT = 0
    //DDR3B_DATX8_8 &= ~(ECC_MASK);
    do {
    do {
    SDRAM_TYPE = 3
    DDQS = 1
    DYN_ODT = 0
    IBANK = 3 (8bank)
    DDR3B_SDCFG = 0x6200CE62 ;//0x66004862=single rank, 0x6600486A=dual rank CL- 11
    DDR3B_SDTIM1 = 0x16709C55;
    DDR3B_SDTIM2 = 0x00001D4A;
    DDR3B_SDTIM3 = 0x435DFF54;
    DDR3B_SDTIM4 = 0x553F0CFF;
    DDR3B_SDRFC = 0x00001869;
    /* TCI66x MENU */
    menuitem "TCI66x Functions";
    * NAME
    * PURPOSE:
    * USAGE
    * Global_Default_Setup()
    * RETURN VALUE
    * NONE
    * REFERENCE
    hotmenu Global_Default_Setup()
    GEL_TextOut( "Global Default Setup...\n" );
    GEL_TextOut( "Global Default Setup... Done.\n" );
    hotmenu Reset()
    GEL_Reset();
    hotmenu InitXMC()
    xmc_setup();
    hotmenu CORE_PLL_INIT_122_88MHZ_to_614_4MHz()
    Set_Pll1(1); // call Set_Pll1 with index = 1 -> 122.88 MHz to 614.4 MHz operation
    hotmenu CORE_PLL_INIT_122_88MHZ_to_737_28MHz()
    Set_Pll1(2); // call Set_Pll1 with index = 2 -> 122.88 MHz to 737.28 MHz operation
    hotmenu CORE_PLL_INIT_122_88MHZ_to_983_04MHz()
    hotmenu CORE_PLL_INIT_122_88MHZ_to_1_2GHz()
    Set_Pll1(4); // call Set_Pll1 with index = 4 -> 122.88 MHz to 1.2 GHz operation
    hotmenu CORE_PLL_INIT_122_88MHZ_to_1_3Gz()
    Set_Pll1(5); // call Set_Pll1 with index = 4 -> 122.88 MHz to 1.2 GHz operation
    hotmenu TETRIS_POWERUP_AND_PLL_INIT_100MHZ_to_1000MHz()
    Set_Tetris_Pll(1); // 100 MHz to 1.0 GHz operation
    hotmenu TETRIS_POWERUP_AND_PLL_INIT_100MHZ_to_1400MHz()
    Set_Tetris_Pll(2); // 100 MHz to 1.4 GHz operation
    hotmenu TETRIS_POWERUP_AND_PLL_INIT_175MHZ_to_1400MHz()
    Set_Tetris_Pll(3); // 175 MHz to 1.4 GHz operation
    hotmenu PA_PLL_COnfig()
    PaPllConfig();
    hotmenu InitDDR3A_32bit_DDR800()
    ddr3A_32bit_DDR800_setup();
    hotmenu InitDDR3A_32bit_DDR1066()
    ddr3A_32bit_DDR1066_setup();
    hotmenu InitDDR3A_32bit_DDR1333()
    hotmenu InitDDR3B_64bit_DDR800()
    ddr3B_64bit_DDR800_setup();
    hotmenu InitDDR3B_64bit_DDR1066()
    ddr3B_64bit_DDR1066_setup();
    hotmenu InitDDR3B_64bit_DDR1333()
    ddr3B_64bit_DDR1333_setup();
    hotmenu InitDDR3B_64bit_DDR1600()
    ///* Function to enable CORE PLL observation clock for PLL output *///
    hotmenu ENABLE_CORE_PLL_OBSCLK()
    /* set bit 1 to enable power to the CORE PLL observation clock, clear bit 0 to view the CORE PLL observation (output) clock */
    OBSCLKCTL |= (1 << 1); /* set bit 1 to enable power to the observation clock */
    OBSCLKCTL &= ~(1 << 0); /* clear bit 0 to view the CORE PLL clock */
    KICK0 = 0x00000000;
    KICK1 = 0x00000000;
    GEL_TextOut("CORE PLL observation clock enabled and configured to show CORE PLL output\n");
    /* Function to enable DDR PLL observation clock for PLL output */
    hotmenu ENABLE_DDR_PLL_OBSCLK ()
    OBSCLKCTL |= (1 << 3); /* set bit 3 to enable power to the observation clock */
    OBSCLKCTL |= (1 << 2); /* set bit 2 to view the DDR PLL clock */
    //KICK0 = 0x00000000;
    // KICK1 = 0x00000000;
    GEL_TextOut("DDR PLL observation clock enabled and configured to show DDR PLL output\n");
    hotmenu ENABLE_ARM_PLL_OBSCLK ()
    //OBSCLKCTL |= (1 << 3); /* set bit 3 to enable power to the observation clock */
    OBSCLKCTL |= (1 << 6); /* set bit 2 to view the DDR PLL clock */
    KICK0 = 0x00000000;
    KICK1 = 0x00000000;
    hotmenu ENABLE_PA_PLL_OBSCLK ()
    OBSCLKCTL |= (1 << 4); /* set bit 3 to enable power to the observation clock */
    OBSCLKCTL |= (1 << 5); /* set bit 2 to view the DDR PLL clock */
    KICK0 = 0x00000000;
    KICK1 = 0x00000000;
    hotmenu ddr3A_write_read_test()
    //int data_set[4];
    //= {0xAAAAAAAA, 0x55555555, 0xFFFFFFFF, 0x00000000};
    unsigned int write_data = 0xAAAAAAAA;
    unsigned int read_data = 0x0;
    unsigned int errors = 0;
    int dw;
    unsigned int i, mem_start, mem_size, mem_location;
    mem_start = DDR3A_BASE_ADDRESS + (DNUM * 0x01000000);
    mem_size = 0x100;
    for(dw=0;dw<4;dw++)
    if (dw == 0) write_data = 0xAAAAAAAA;
    if (dw == 1) write_data = 0x55555555;
    if (dw == 2) write_data = 0xFFFFFFFF;
    if (dw == 3) write_data = 0x00000000;
    mem_location = mem_start;
    GEL_TextOut( "Memory Test Write Core: %d, Mem Start: 0x%x, Mem Size: 0x%x, value: 0x%x ...\n",,2,,,DNUM,mem_start,mem_size,write_data);
    for(i=0;i<mem_size;i++)
    *( unsigned int* )(mem_location) = write_data;
    mem_location += 4;
    GEL_TextOut( "Memory Test Read Core: %d, Mem Start: 0x%x, Mem Size: 0x%x ...\n",,2,,,DNUM,mem_start,mem_size);
    for (i=0;i<mem_size;i++)
    read_data = *( unsigned int* )(mem_location);
    if (read_data != write_data)
    GEL_TextOut("DDR3 Data Error: DSP Core: %d, Mem Addr: 0x%x, read: 0x%x, expected: 0x%x \n",,2,,,DNUM,(DDR3_BASE_ADDRESS + (i * 4)),read_data,write_data);
    errors++;
    mem_location += 4;
    if (errors == 0)
    GEL_TextOut( "Memory Test Done, no errors found.\n" );
    else
    GEL_TextOut("Memory Test Done, %d errors were encounterd. \n",,2,,,errors);
    GEL_TextOut( "All Memory Test Completed on core: %d with %d errors.\n",,2,,,DNUM,errors);
    hotmenu ddr3B_write_read_test()
    //int data_set[4];
    int dw;
    mem_start = DDR3B_BASE_ADDRESS + (DNUM * 0x01000000);
    mem_size = 0x100;
    for(dw=0;dw<4;dw++)
    mem_location += 4;
    errors++;
    mem_location += 4;
    if (errors == 0)
    else
    menuitem "DSP CLOCK Estimation";
    #define TIMER_TSC (1) // The timer used for polling TSCH/TSCL
    #define TIMER_TSC_POLL_PERIOD (10) // Every 10 seconds
    unsigned int gPollPeriod = TIMER_TISC_POLL_PERIOD;
    unsigned int gTSCL = 0;
    unsigned int gTSCH = 0; // Global var for holding previous read of TSCL/H
    unsigned int gNumberPoll=0; // Number of pulling */
    unsigned int gLoopCount=0;
    hotmenu dspEnableTsc()
    //GEL_TextOut( "dspEnableTsc - write a value to TSCL to enable it\n" );
    if( GEL_IsHalted() ) {
    TSCL = 0; // A write to TSCL will enable TSC (timestamp counter)
    GEL_Run();
    } else {
    GEL_Halt();
    TSCL = 0;
    GEL_Run();
    hotmenu dspDumpTsc()
    unsigned int tscl, tsch;
    tscl = TSCL; /* note: need to read TSCL first */
    tsch = TSCH;
    GEL_TextOut( "dspEnableTsc - TSCH=%x, TSCL=%x\n",,,,, tscl, tsch );
    dspPollTsc()
    unsigned long long tsc1, tsc2;
    if( gLoopCount <= gNumberPoll) {
    //GEL_EnableRealtime();
    GEL_Halt();
    tscl = TSCL; /* The read time can be considered as variations */
    tsch = TSCH; /* The read won't cause variation */
    //GEL_DisableRealtime();
    GEL_Run();
    tsc2 = (((unsigned long long) tsch)<<32) + tscl;
    tsc1 = (((unsigned long long)gTSCH)<<32) + gTSCL;
    gTSCL = tscl;
    gTSCH = tsch;
    //tsc1 = (tsc2-tsc1)/TIMER_TSC_POLL_PERIOD;
    tsc1 = (tsc2-tsc1)/gPollPeriod;
    GEL_TextOut( "dspPollTsc - [TSCH,TSCL] = [%x, %x], freq=%dhz, i=%d\n",,,,,
    gTSCH, gTSCL, (tsc1), gLoopCount);
    if( gLoopCount>=gNumberPoll ) {
    dspCancelTscTimer();
    } else {
    gLoopCount++;
    // To cancel the Timer - TIMER_TSC, after using it. Otherwise, it will continue running.
    hotmenu dspCancelTscTimer()
    GEL_TextOut( "dspCancelTscTimer\n");
    GEL_CancelTimer( TIMER_TSC );
    // To poll the DSP clock.
    dialog dspPollDSPClockFreq(
    pollPeriod "Polling period (sec) - the longer, the more accurate!",
    numberOfPoll "Number of Polls" )
    gPollPeriod = pollPeriod;
    GEL_TextOut( "dspPollDSPClockFreq with - pollPeriod=%dsec, numberOfPoll=%d\n"
    ,,,,, gPollPeriod, numberOfPoll);
    gNumberPoll = numberOfPoll-1;
    gLoopCount = 0;
    dspEnableTsc();
    // Get the initial value of TSC
    GEL_Halt();
    gTSCL = TSCL; /* The read time can be considered as variations */
    gTSCH = TSCH; /* The read won't cause variation */
    GEL_Run();
    GEL_SetTimer( gPollPeriod*1000, TIMER_TSC, "dspPollTsc()");
  • Sure. See attachment.
    This file exist in C:\ti\ccsv5\ccs_base\emulation\boards\evmtci6638k2k\gel\evmtci6638k2k.gel
    It's the latest as I can find.
    Please get me a new one.
    1300.evmtci6638k2k.gel
    -Yang
  • Hi Yang,
    Here is the pre-release version of the file that will be in the next CCS release. Let me know if you have any problems.
    Regards, Bill
    1727.evmtci6638k2k_alpha_board_v1.5.gel
  • It works.
    Thank you so much!
