EINVAL error on OMAP5
I am getting following messages while running one application on OMAP5 based platform from DRM module of kernel. I am using SGX kernel driver based on 1.9.19@2166536 and linux kernel version is 3.4.25.
Is this known error message? Any pointer to fix this would be very helpful?
[   39.016601] ---> EINVAL because map-size incorrect for offset 85927
[   39.025909] ---> map->size:172032 vma->vm_end:2880532480 vma->vm_start:288027
[  127.564117] ---> EINVAL because map-size incorrect for offset 83610
[  127.570831] ---> map->size:73728 vma->vm_end:2878586880 vma->vm_start:2878455808 diff:131072 offset:3940892288
[  163.289154] ---> EINVAL because map-size incorrect for offset 88680
[  163.296112] ---> map->size:4096000 vma->vm_end:2842640384 vma->vm_start:2834251776 diff:8388608 offset:3940892288
[  163.331604] ---> EINVAL because map-size incorrect for offset 90729
[  163.338409] ---> map->size:3604480 vma->vm_end:2842640384 vma->vm_start:2834251776 diff:8388608 offset:3940892288
[  180.942718] ---> EINVAL because map-size incorrect for offset 94445
[  180.949462] ---> map->size:172032 vma->vm_end:2860457984 vma->vm_start:2860195840 diff:262144 offset:4011944728
[  189.475738] ---> EINVAL because map-size incorrect for offset 94510
[  189.482635] ---> map->size:6291456 vma->vm_end:2809630720 vma->vm_start:2801242112 diff:8388608 offset:3803176576
[  189.547241] ---> EINVAL because map-size incorrect for offset 96559
[  189.554046] ---> map->size:294912 vma->vm_end:2840309760 vma->vm_start:2839785472 diff:524288 offset:3803176576
[  189.569183] ---> EINVAL because map-size incorrect for offset 96688
[  189.575988] ---> map->size:6291456 vma->vm_end:2839154688 vma->vm_start:2830766080 diff:8388608 offset:3803176576
[  189.633941] ---> EINVAL because map-size incorrect for offset 98737
[  189.640960] ---> map->size:6291456 vma->vm_end:2839154688 vma->vm_start:2830766080 diff:8388608 offset:3803176576
[  189.691314] ---> EINVAL because map-size incorrect for offset 100786
[  189.698303] ---> map->size:602112 vma->vm_end:2837446656 vma->vm_start:2836398080 diff:1048576 offset:3803176576
[  189.713348] ---> EINVAL because map-size incorrect for offset 101052
[  189.720275] ---> map->size:28672 vma->vm_end:2841104384 vma->vm_start:2841071616 diff:32768 offset:3803176576
[  190.359252] ---> EINVAL because map-size incorrect for offset 96052
[  190.365936] ---> map->size:6291456 vma->vm_end:2812264448 vma->vm_start:2803875840 diff:8388608 offset:3803176576
[  190.409423] ---> EINVAL because map-size incorrect for offset 98101
[  190.416320] ---> map->size:294912 vma->vm_end:2840576000 vma->vm_start:2840051712 diff:524288 offset:3803176576
[  190.428985] ---> EINVAL because map-size incorrect for offset 98230
[  190.435821] ---> map->size:294912 vma->vm_end:2839420928 vma->vm_start:2838896640 diff:524288 offset:3803176576
[  190.448425] ---> EINVAL because map-size incorrect for offset 98359
[  190.455596] ---> map->size:294912 vma->vm_end:2837446656 vma->vm_start:2836922368 diff:524288 offset:3803176576
[  190.468383] ---> EINVAL because map-size incorrect for offset 98488
[  190.475341] ---> map->size:294912 vma->vm_end:2837446656 vma->vm_start:2836922368 diff:524288 offset:3803176576
[  190.488159] ---> EINVAL because map-size incorrect for offset 98617
[  190.494903] ---> map->size:294912 vma->vm_end:2836398080 vma->vm_start:2835873792 diff:524288 offset:3803176576
[  190.507415] ---> EINVAL because map-size incorrect for offset 98746
[  190.514312] ---> map->size:294912 vma->vm_end:2835345408 vma->vm_start:2834821120 diff:524288 offset:3803176576
[  190.527679] ---> EINVAL because map-size incorrect for offset 98875
[  190.534606] ---> map->size:6291456 vma->vm_end:2834292736 vma->vm_start:2825904128 diff:8388608 offset:3803176576
[  190.578247] ---> EINVAL because map-size incorrect for offset 100924
[  190.585021] ---> map->size:6291456 vma->vm_end:2812264448 vma->vm_start:2803875840 diff:8388608 offset:3803176576
[  190.640838] ---> EINVAL because map-size incorrect for offset 102973
[  190.647888] ---> map->size:602112 vma->vm_end:2825904128 vma->vm_start:2824855552 diff:1048576 offset:3803176576
[  190.663482] ---> EINVAL because map-size incorrect for offset 103239
[  190.670593] ---> map->size:28672 vma->vm_end:2841063424 vma->vm_start:2841030656 diff:32768 offset:3803176576
[  190.826293] ---> EINVAL because map-size incorrect for offset 95795
[  190.833221] ---> map->size:294912 vma->vm_end:2840576000 vma->vm_start:2840051712 diff:524288 offset:3803176576
[  190.845794] ---> EINVAL because map-size incorrect for offset 95924
[  190.852416] ---> map->size:294912 vma->vm_end:2840576000 vma->vm_start:2840051712 diff:524288 offset:4011944728
[  191.316223] ---> EINVAL because map-size incorrect for offset 96052
[  191.323028] ---> map->size:4325376 vma->vm_end:2810138624 vma->vm_start:2801750016 diff:8388608 offset:3803176576
[  191.362976] ---> EINVAL because map-size incorrect for offset 98101
[  191.369873] ---> map->size:294912 vma->vm_end:2840576000 vma->vm_start:2840051712 diff:524288 offset:3803176576
[  191.382446] ---> EINVAL because map-size incorrect for offset 98230
[  191.389099] ---> map->size:294912 vma->vm_end:2839420928 vma->vm_start:2838896640 diff:524288 offset:3803176576
Thanks & Regards,
Vikas
