Other Parts Discussed in Thread: DM3730, ADS7846, TPS65951, MAX3232
HW: DM3730EVM - mistral
SW: dvsdk_04_03_00_06
I downloaded the fresh dvsdk4 from ti's website and trying to boot my dm3730 evm. referring to developers guide, prepared my SD card using mksdboot.sh available in dvsdk.
- Used all the prebuilt Images to prepare bootable SD card
- Used the Images which I have built on my ubuntu-10.04 32bit PC
- Checked all the switch settings and confirmed that all switches are configured as suggested in TI's omap3 beginners guide and mistrals hardware reference manual, which came along with dvsdk.
- I am using TI's arago tool chains (already available in dvsdk)and in Rules.make platform is specified as dm3730.
Both the cases, it couldn't boot. kernel either hangs or crashes at same point every time. Please find the logs below.
Texas Instruments X-Loader 1.51 (Dec 22 2011 - 23:00:39)
Starting X-loader on MMC
229036 Bytes Read from MMC
Starting OS Bootloader from MMC...
Starting OS Bootloader...
U-Boot 2010.06 (Dec 22 2011 - 23:11:38)
OMAP34xx/35xx-GP ES1.0, CPU-OPP2 L3-165MHz
OMAP3 EVM board + LPDDR/NAND
I2C: ready
DRAM: 256 MiB
NAND: HW ECC [Kernel/FS layout] selected
512 MiB
In: serial
Out: serial
Err: serial
Read back SMSC id 0x92200000
Die ID #1c2e0000000000000156087c0a022026
Net: smc911x-0
Hit any key to stop autoboot: 0
mmc1 is available
reading boot.scr
302 bytes read
Running bootscript from mmc ...
## Executing script at 82000000
reading uImage
3279160 bytes read
## Booting kernel from Legacy Image at 80200000 ...
Image Name: Linux-2.6.37
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 3279096 Bytes = 3.1 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[ 0.000000] Linux version 2.6.37 (root@ravikiranlapsony) (gcc version 4.3.3 (GCC) ) #1 Thu Feb 27 23:14:59 IST 2014
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: OMAP3 EVM
[ 0.000000] Reserving 4194304 bytes SDRAM for VRAM
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] OMAP3630 ES1.0 (l2cache iva sgx neon isp 192mhz_clk )
[ 0.000000] SRAM: Mapped pa 0x40200000 to va 0xfe400000 size: 0x10000
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 45312
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/mmcblk0p2 rw ip=off mem=55M@0x80000000 mpurate=1000 omap_vout.vid1_static_vrfb_alloc=y o
mapfb.vram=0:4M mem=128M@0x88000000 rootwait
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 55MB 124MB = 179MB total
[ 0.000000] Memory: 168884k/168884k available, 18508k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
[ 0.000000] vmalloc : 0xd0800000 - 0xf8000000 ( 632 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .init : 0xc0008000 - 0xc003f000 ( 220 kB)
[ 0.000000] .text : 0xc003f000 - 0xc061f35c (6017 kB)
[ 0.000000] .data : 0xc0620000 - 0xc07e2520 (1802 kB)
[ 0.000000] NR_IRQS:409
[ 0.000000] Clocking rate (Crystal/Core/MPU): 26.0/400/1000 MHz
[ 0.000000] omap_hwmod: i2c1: softreset failed (waited 10000 usec)
[ 0.000000] omap_hwmod: i2c2: softreset failed (waited 10000 usec)
[ 0.000000] omap_hwmod: i2c3: softreset failed (waited 10000 usec)
[ 0.000000] Reprogramming SDRC clock to 400000000 Hz
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96 interrupts
[ 0.000000] Total of 96 interrupts on 1 active controller
[ 0.000000] GPMC revision 5.0
[ 0.000000] Trying to install interrupt handler for IRQ402
[ 0.000000] Trying to install interrupt handler for IRQ403
[ 0.000000] Trying to install interrupt handler for IRQ404
[ 0.000000] Trying to install interrupt handler for IRQ405
[ 0.000000] Trying to install interrupt handler for IRQ406
[ 0.000000] Trying to install interrupt handler for IRQ407
[ 0.000000] Trying to install interrupt handler for IRQ408
[ 0.000000] Trying to install type control for IRQ409
[ 0.000000] Trying to set irq flags for IRQ409
[ 0.000000] OMAP clockevent source: GPTIMER1 at 32768 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] Lock dependency validator: Copyright (c) 2006 Red Hat, Inc., Ingo Molnar
[ 0.000000] ... MAX_LOCKDEP_SUBCLASSES: 8
[ 0.000000] ... MAX_LOCK_DEPTH: 48
[ 0.000000] ... MAX_LOCKDEP_KEYS: 8191
[ 0.000000] ... CLASSHASH_SIZE: 4096
[ 0.000000] ... MAX_LOCKDEP_ENTRIES: 16384
[ 0.000000] ... MAX_LOCKDEP_CHAINS: 32768
[ 0.000000] ... CHAINHASH_SIZE: 16384
[ 0.000000] memory used by lock dependency info: 3935 kB
[ 0.000000] per task-struct memory footprint: 2304 bytes
[ 0.000000] Calibrating delay loop... 998.84 BogoMIPS (lpj=3899392)
[ 0.000000] pid_max: default: 32768 minimum: 301
[ 0.000000] Security Framework initialized
[ 0.000000] Mount-cache hash table entries: 512
[ 0.000000] CPU: Testing write buffer coherency: ok
[ 0.000000] regulator: core version 0.5
[ 0.000000] regulator: dummy:
[ 0.000000] NET: Registered protocol family 16
[ 0.000000] OMAP GPIO hardware version 2.5
[ 0.000000] omap_mux_init: Add partition: #1: core, flags: 0
[ 0.000000] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.000000] ------------[ cut here ]------------
[ 0.000000] WARNING: at arch/arm/mach-omap2/clock.c:438 omap2_clk_switch_mpurate_at_boot+0x80/0xb4()
[ 0.000000] clock: dpll1_ck: unable to set MPU rate to 1000: -22
[ 0.000000] Modules linked in:
[ 0.000000] [<c004fa88>] (unwind_backtrace+0x0/0xec) from [<c0078f10>] (warn_slowpath_common+0x4c/0x64)
[ 0.000000] [<c0078f10>] (warn_slowpath_common+0x4c/0x64) from [<c0078fbc>] (warn_slowpath_fmt+0x30/0x40)
[ 0.000000] [<c0078fbc>] (warn_slowpath_fmt+0x30/0x40) from [<c001389c>] (omap2_clk_switch_mpurate_at_boot+0x80/0xb4)
[ 0.000000] [<c001389c>] (omap2_clk_switch_mpurate_at_boot+0x80/0xb4) from [<c00138dc>] (omap3xxx_clk_arch_init+0xc/0x3c)
[ 0.000000] [<c00138dc>] (omap3xxx_clk_arch_init+0xc/0x3c) from [<c003f3c8>] (do_one_initcall+0xc8/0x194)
[ 0.000000] [<c003f3c8>] (do_one_initcall+0xc8/0x194) from [<c000869c>] (kernel_init+0x98/0x150)
[ 0.000000] [<c000869c>] (kernel_init+0x98/0x150) from [<c004accc>] (kernel_thread_exit+0x0/0x8)
[ 0.000000] ---[ end trace 1b75b31a2719ed1c ]---
[ 0.000000] OMAP DMA hardware revision 5.0
[ 0.062744] bio: create slab <bio-0> at 0
[ 0.065277] regulator: vwl1271: 1800 mV
[ 0.068328] SCSI subsystem initialized
[ 0.074554] usbcore: registered new interface driver usbfs
[ 0.075317] usbcore: registered new interface driver hub
[ 0.075805] usbcore: registered new device driver usb
[ 0.078552] omap_i2c omap_i2c.1: bus 1 rev4.0 at 2600 kHz
[ 0.084136] twl4030: PIH (irq 7) chaining IRQs 368..375
[ 0.084228] twl4030: power (irq 373) chaining IRQs 376..383
[ 0.085449] twl4030: gpio (irq 368) chaining IRQs 384..401
[ 0.094390] regulator: VIO: 1800 mV normal standby
[ 0.095764] regulator: VMMC1: 1850 <--> 3150 mV at 3000 mV normal standby
[ 0.097137] regulator: VDAC: 1800 mV normal standby
[ 0.098480] regulator: VAUX2_4030: 2800 mV normal standby
[ 0.099792] regulator: VPLL2: 1800 mV normal standby
[ 0.101165] regulator: VSIM: 1800 <--> 3000 mV at 1800 mV normal standby
[ 0.102508] regulator: VAUX3: 2800 mV normal standby
[ 0.103210] omap_device: omap_i2c.1: new worst case deactivate latency 0: 30517
[ 0.112487] omap_i2c omap_i2c.2: bus 2 rev4.0 at 400 kHz
[ 0.128021] omap_i2c omap_i2c.3: bus 3 rev4.0 at 400 kHz
[ 0.131439] Advanced Linux Sound Architecture Driver Version 1.0.23.
[ 0.133056] Bluetooth: Core ver 2.15
[ 0.133514] NET: Registered protocol family 31
[ 0.133514] Bluetooth: HCI device and connection manager initialized
[ 0.133575] Bluetooth: HCI socket layer initialized
[ 0.134613] Switching to clocksource 32k_counter
[ 0.201843] musb-hdrc: version 6.0, otg (peripheral+host), debug=0
[ 0.202087] musb-hdrc musb-hdrc.0: dma type: dma-inventra
[ 0.202606] musb-hdrc musb-hdrc.0: USB OTG mode controller at fa0ab000 using DMA, IRQ 92
[ 0.203552] NET: Registered protocol family 2
[ 0.203857] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.204620] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.204833] TCP bind hash table entries: 8192 (order: 6, 360448 bytes)
[ 0.206207] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.206237] TCP reno registered
[ 0.206237] UDP hash table entries: 128 (order: 1, 12288 bytes)
[ 0.206359] UDP-Lite hash table entries: 128 (order: 1, 12288 bytes)
[ 0.206817] NET: Registered protocol family 1
[ 0.207580] RPC: Registered udp transport module.
[ 0.207580] RPC: Registered tcp transport module.
[ 0.207611] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.208068] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.210083] omap_device: omap_i2c.1: new worst case activate latency 0: 30517
[ 0.212036] omap3evm camera init done successfully...
[ 0.212493] omap-iommu omap-iommu.0: isp registered
[ 0.213043] AM37x/DM37x Linux PSP version 04.02.00.07 (OMAP3EVM)
[ 0.315460] VFS: Disk quotas dquot_6.5.2
[ 0.315521] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.316802] JFFS2 version 2.2. (NAND) (SUMMARY) �© 2001-2006 Red Hat, Inc.
[ 0.317321] msgmni has been set to 329
[ 0.320281] io scheduler noop registered
[ 0.320281] io scheduler deadline registered
[ 0.320404] io scheduler cfq registered (default)
[ 0.385009] OMAP DSS rev 2.0
[ 0.385192] OMAP DISPC rev 3.0
[ 0.385253] OMAP VENC rev 2
[ 0.385864] OMAP DSI rev 1.0
[ 0.715393] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.719482] omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 72) is a OMAP UART0
[ 1.552886] console [ttyO0] enabled
[ 1.557373] omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 73) is a OMAP UART1
[ 1.565521] omap_uart.2: ttyO2 at MMIO 0x49020000 (irq = 74) is a OMAP UART2
[ 1.573608] omap_uart.3: ttyO3 at MMIO 0x49042000 (irq = 80) is a OMAP UART3
[ 1.604858] brd: module loaded
[ 1.619537] loop: module loaded
[ 1.627746] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 1.634490] omap2-nand driver initializing
[ 1.639282] NAND device: Manufacturer ID: 0xad, Chip ID: 0xbc (Hynix )
[ 1.646179] Creating 5 MTD partitions on "omap2-nand.0":
[ 1.651763] 0x000000000000-0x000000080000 : "X-Loader-NAND"
[ 1.661712] 0x000000080000-0x0000001c0000 : "U-Boot-NAND"
[ 1.671173] 0x0000001c0000-0x000000280000 : "Boot Env-NAND"
[ 1.680480] 0x000000280000-0x000000780000 : "Kernel-NAND"
[ 1.691497] 0x000000780000-0x000020000000 : "File System - NAND"
[ 1.933410] OneNAND driver initializing
[ 1.937591] omap2-onenand omap2-onenand: Cannot request GPMC CS
[ 1.943939] omap2-onenand: probe of omap2-onenand failed with error -16
[ 1.953186] smsc911x: Driver version 2008-10-21.
[ 1.961486] smsc911x-mdio: probed
[ 1.965332] eth0: attached PHY driver [SMSC LAN8700] (mii_bus:phy_addr=ffffffff:01, irq=-1)
[ 1.974426] net eth0: MAC Address: 00:50:c2:7e:92:e9
[ 1.980560] usbcore: registered new interface driver asix
[ 1.986633] usbcore: registered new interface driver cdc_ether
[ 1.993103] usbcore: registered new interface driver net1080
[ 1.999420] usbcore: registered new interface driver cdc_subset
[ 2.006011] usbcore: registered new interface driver zaurus
[ 2.011901] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.025390] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 3.031768] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
[ 3.039855] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[ 3.056701] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 3.063049] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.070190] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.077758] usb usb1: Product: OMAP-EHCI Host Controller
[ 3.083343] usb usb1: Manufacturer: Linux 2.6.37 ehci_hcd
[ 3.089019] usb usb1: SerialNumber: ehci-omap.0
[ 3.095916] hub 1-0:1.0: USB hub found
[ 3.099884] hub 1-0:1.0: 3 ports detected
[ 3.135345] Initializing USB Mass Storage driver...
[ 3.140930] usbcore: registered new interface driver usb-storage
[ 3.147247] USB Mass Storage support registered.
[ 3.152557] usbcore: registered new interface driver usbtest
[ 3.158599] g_ether gadget: using random self ethernet address
[ 3.164733] g_ether gadget: using random host ethernet address
[ 3.171905] usb0: MAC 56:17:5c:59:e4:63
[ 3.175964] usb0: HOST MAC 1a:90:6a:42:d1:31
[ 3.180480] g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
[ 3.187438] g_ether gadget: g_ether ready
[ 3.191650] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
[ 3.197357] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 2
[ 3.205718] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.212829] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.220428] usb usb2: Product: MUSB HDRC host driver
[ 3.225616] usb usb2: Manufacturer: Linux 2.6.37 musb-hcd
[ 3.231292] usb usb2: SerialNumber: musb-hdrc.0
[ 3.237823] hub 2-0:1.0: USB hub found
[ 3.241790] hub 2-0:1.0: 1 port detected
[ 3.248535] mice: PS/2 mouse device common for all mice
[ 3.256072] input: TWL4030 Keypad as /devices/platform/omap/omap_i2c.1/i2c-1/1-004a/twl4030_keypad/input/input0
[ 3.267608] omap_device: omap_i2c.1: new worst case activate latency 0: 61035
[ 3.279602] ads7846 spi1.0: touchscreen, irq 335
[ 3.285858] input: ADS7846 Touchscreen as /devices/platform/omap2_mcspi.1/spi1.0/input/input1
[ 3.298583] input: twl4030_pwrbutton as /devices/platform/omap/omap_i2c.1/i2c-1/1-0049/twl4030_pwrbutton/input/input2
[ 3.312103] twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0
[ 3.319122] twl_rtc twl_rtc: Power up reset detected.
[ 3.325225] twl_rtc twl_rtc: Enabling TWL-RTC.
[ 3.331268] i2c /dev entries driver
[ 3.338165] Linux media interface: v0.10
[ 3.342651] Linux video capture interface: v2.00
[ 3.349121] omap3isp supply VDD_CSIPHY1 not found, using dummy regulator
[ 3.356231] omap3isp supply VDD_CSIPHY2 not found, using dummy regulator
[ 3.363525] omap3isp omap3isp: Revision 15.0 found
[ 3.368652] omap-iommu omap-iommu.0: isp: version 1.1
[ 3.437957] mt9t111 2-003c: Unable to detectmt9t111sensor
[ 3.446838] isp_register_subdev_group: Unable to register subdev mt9t111
[ 3.454986] tvp514x 3-005c: tvp514x 3-005c decoder driver registered !!
[ 3.462799] tvp514x 3-005c: Write: retry ... 0
[ 3.486694] tvp514x 3-005c: Write: retry ... 1
[ 3.510101] tvp514x 3-005c: Write: retry ... 2
[ 3.533538] tvp514x 3-005c: Write: retry ... 3
[ 3.556976] tvp514x 3-005c: Write: retry ... 4
[ 3.580413] tvp514x 3-005c: Write: retry ... 5
[ 3.603851] tvp514x 3-005c: Write failed. Err[-121]
[ 3.608917] tvp514x 3-005c: Unable to turn on decoder
[ 3.614410] tvp514x 3-005c: Read: retry ... 0
[ 3.635101] tvp514x 3-005c: Read: retry ... 1
[ 3.658538] tvp514x 3-005c: Read: retry ... 2
[ 3.681976] tvp514x 3-005c: Read: retry ... 3
[ 3.705413] tvp514x 3-005c: Read: retry ... 4
[ 3.728851] tvp514x 3-005c: Read: retry ... 5
[ 3.752288] tvp514x 3-005c: Unable to query std
[ 3.757934] usbcore: registered new interface driver uvcvideo
[ 3.763977] USB Video Class driver (v1.0.0)
[ 3.769561] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[ 3.776336] Bluetooth: HCI UART driver ver 2.2
[ 3.781005] Bluetooth: HCI H4 protocol initialized
[ 3.786041] Bluetooth: HCILL protocol initialized
[ 3.796783] mmci-omap-hs.1 supply vmmc_aux not found, using dummy regulator
[ 3.878479] usbcore: registered new interface driver usbhid
[ 3.884307] usbhid: USB HID core driver
[ 3.890045] usbcore: registered new interface driver snd-usb-audio
[ 3.899444] OMAP3 EVM SoC init
[ 3.938903] mmc1: card claims to support voltages below the defined range. These will be ignored.
[ 3.988098] asoc: twl4030-hifi <-> omap-mcbsp-dai.1 mapping ok
[ 3.997222] ALSA device list:
[ 4.000335] #0: omap3evm
[ 4.003204] oprofile: hardware counters not available
[ 4.008483] oprofile: using timer interrupt.
[ 4.013153] nf_conntrack version 0.5.0 (2638 buckets, 10552 max)
[ 4.020385] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 4.026306] TCP cubic registered
[ 4.029693] Initializing XFRM netlink socket
[ 4.034301] NET: Registered protocol family 17
[ 4.039001] NET: Registered protocol family 15
[ 4.044036] Bluetooth: L2CAP ver 2.15
[ 4.047912] Bluetooth: L2CAP socket layer initialized
[ 4.053253] Bluetooth: SCO (Voice Link) ver 0.6
[ 4.058013] Bluetooth: SCO socket layer initialized
[ 4.063446] Bluetooth: RFCOMM TTY layer initialized
[ 4.068634] Bluetooth: RFCOMM socket layer initialized
[ 4.074035] Bluetooth: RFCOMM ver 1.11
[ 4.077941] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 4.083526] Bluetooth: BNEP filters: protocol multicast
[ 4.089019] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.096405] Registering the dns_resolver key type
[ 4.101593] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 4.110443] ThumbEE CPU extension supported.
[ 4.121459] ------------[ cut here ]------------
[ 4.126312] Unable to handle kernel paging request at virtual address 9008d992
[ 4.133850] pgd = c0004000
[ 4.136657] [9008d992] *pgd=00000000
[ 4.140411] Internal error: Oops: 5 [#1]
[ 4.144500] last sysfs file:
[ 4.147583] Modules linked in:
[ 4.150787] CPU: 0 Tainted: G W (2.6.37 #1)
[ 4.156341] PC is at kallsyms_expand_symbol+0xc/0x84
[ 4.161529] LR is at kallsyms_lookup+0xa4/0xe4
[ 4.166198] pc : [<c00b13a8>] lr : [<c00b1b24>] psr: 20000093
[ 4.166198] sp : cf429ccc ip : 9008d992 fp : 00000400
[ 4.178192] r10: c07f3c9c r9 : c0571c11 r8 : cf429d10
[ 4.183654] r7 : cf429d0c r6 : cf429d14 r5 : cf429d31 r4 : c046e9ac
[ 4.190460] r3 : c04e1890 r2 : cf429d11 r1 : cf429d31 r0 : cfbac102
[ 4.197296] Flags: nzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel
[ 4.205017] Control: 10c5387d Table: 80004019 DAC: 00000017
[ 4.211029] Process swapper (pid: 1, stack limit = 0xcf4282f0)
[ 4.217102] Stack: (0xcf429ccc to 0xcf42a000)
[ 4.221649] 9cc0: c046e9ac cf429d31 cf429d14 cf429d0c cf429d10
[ 4.230224] 9ce0: c07f3c9c c00b1b24 cf429d31 c046e9ac c0571c12 c07f409c c07f409c c00b1b8c
[ 4.238769] 9d00: cf429d31 c0634fec 00000001 60000093 00000000 cf41a4f0 00000002 c07f3cbe
[ 4.247314] 9d20: c07f409c c021530c 00000000 60000093 00000000 c0067910 c0634fdc 0012400e
[ 4.255859] 9d40: 00000000 c00a4e14 00000000 0012400e 00000000 cf41a040 c0058e9c c0067910
[ 4.264404] 9d60: c0063e5c cf41a070 00000000 c00a5c68 c06359f0 cf41a0a0 00000000 00000001
[ 4.272949] 9d80: 00000000 0001da73 00000000 1b478423 00000000 c0213f98 c0635c40 cf429dd6
4.281524] 9da0: cf429ea5 cf429dde c07f3cba 0000ffff cf429dde c07f3cba 0000ffff 00000002
[ 4.290069] 9dc0: c07f409c c0214110 00000000 00000000 c0e69148 0000ffff 31323134 31320155
[ 4.298614] 9de0: 00000033 c0266c2c cf6a9410 cf6a9400 c0636400 00000033 c02668f8 c07e8434
[ 4.307159] 9e00: cf6a9400 cf6a9400 000026cb c0636478 c0636468 c07f3cbe c046e9ac c0215b20
[ 4.315704] 9e20: c0636400 ff0a0005 ffffffff 00000053 c0571c0d cf429f0c c07f3cbe 00000001
[ 4.324249] 9e40: c0571c10 c0215e44 ff0a0005 ffffffff c0636414 cf429e58 ff0a0005 ffffffff
[ 4.332794] 9e60: 00000000 00000400 c0573605 00000000 cf429f04 00000004 00000000 c0571bfb
[ 4.341369] 9e80: 00000000 c0216058 c07f3c9c c0079c24 00000034 60000013 00000001 205b0000
[ 4.349914] 9ea0: 34202020 3132312e 5d393534 00000020 00000000 c0067910 00000002 00000071
[ 4.358459] 9ec0: 00000000 c00a4e14 00000000 00000071 00000000 00000138 c0573605 c046e9ac
[ 4.367004] 9ee0: 00000000 00000009 00000000 00000000 00000000 c046d804 000041ed c0078ef8
[ 4.375549] 9f00: c0571bfb c0573605 00000138 c046e9ac c01d5dac cf0007fc 00000000 cf001660
[ 4.384094] 9f20: c0c50268 c0078f44 00000000 cf000758 cf109858 c046e9ac cf000758 cf109858
[ 4.392639] 9f40: 00000000 c01d5dac cf1098d8 00000000 00000001 c0032c68 c0032cc8 c004accc
[ 4.401214] 9f60: 00000013 c0010c4c 00000000 c01d5e60 00000000 00000000 00000092 c0012a64
[ 4.409759] 9f80: c005b478 c02134e8 80000013 c0032c68 c0032cc8 c004accc 00000013 c0010c4c
[ 4.418304] 9fa0: 00000000 00000000 00000000 c0010c60 00000000 c003f3c8 00000038 00000000
[ 4.426849] 9fc0: 00000013 00000199 c079961c c0032c68 c0032cc8 c004accc 00000013 00000000
[ 4.435394] 9fe0: 00000000 c000869c 00000000 00000000 c0008604 c004accc ffffffff ffffffff
[ 4.443969] [<c00b13a8>] (kallsyms_expand_symbol+0xc/0x84) from [<c00b1b24>] (kallsyms_lookup+0xa4/0xe4)
[ 4.453887] [<c00b1b24>] (kallsyms_lookup+0xa4/0xe4) from [<c00b1b8c>] (sprint_symbol+0x28/0xb4)
[ 4.463073] [<c00b1b8c>] (sprint_symbol+0x28/0xb4) from [<c021530c>] (symbol_string+0x40/0x84)
[ 4.472076] [<c021530c>] (symbol_string+0x40/0x84) from [<c0215b20>] (pointer+0xd0/0x210)
[ 4.480621] [<c0215b20>] (pointer+0xd0/0x210) from [<c0215e44>] (vsnprintf+0x1e4/0x358)
[ 4.488983] [<c0215e44>] (vsnprintf+0x1e4/0x358) from [<c0216058>] (vscnprintf+0xc/0x18)
[ 4.497467] [<c0216058>] (vscnprintf+0xc/0x18) from [<c0079c24>] (vprintk+0x180/0x3e0)
[ 4.505737] [<c0079c24>] (vprintk+0x180/0x3e0) from [<c046d804>] (printk+0x18/0x28)
[ 4.513763] [<c046d804>] (printk+0x18/0x28) from [<c0078ef8>] (warn_slowpath_common+0x34/0x64)
[ 4.522766] [<c0078ef8>] (warn_slowpath_common+0x34/0x64) from [<c0078f44>] (warn_slowpath_null+0x1c/0x24)
[ 4.532867] [<c0078f44>] (warn_slowpath_null+0x1c/0x24) from [<c046e9ac>] (__mutex_unlock_slowpath+0x60/0x114)
[ 4.543334] [<c046e9ac>] (__mutex_unlock_slowpath+0x60/0x114) from [<c01d5dac>] (debugfs_create_file+0x16c/0x1a0)
[ 4.554046] [<c01d5dac>] (debugfs_create_file+0x16c/0x1a0) from [<c01d5e60>] (debugfs_create_dir+0x20/0x28)
[ 4.564239] [<c01d5e60>] (debugfs_create_dir+0x20/0x28) from [<c0012a64>] (omap_voltage_late_init+0x38/0x314)
[ 4.574615] [<c0012a64>] (omap_voltage_late_init+0x38/0x314) from [<c0010c60>] (omap2_common_pm_late_init+0x14/0x64)
[ 4.585632] [<c0010c60>] (omap2_common_pm_late_init+0x14/0x64) from [<c003f3c8>] (do_one_initcall+0xc8/0x194)
[ 4.596008] [<c003f3c8>] (do_one_initcall+0xc8/0x194) from [<c000869c>] (kernel_init+0x98/0x150)
[ 4.605194] [<c000869c>] (kernel_init+0x98/0x150) from [<c004accc>] (kernel_thread_exit+0x0/0x8)
[ 4.614379] Code: 28020288AA8 e59f3070 e92d45f0 e083c000 (e7d36000)
Reading boot sector Online 00:09
