Other Parts Discussed in Thread: TLC59108, TVP7002
I am using the DM8148 EVM , while running the syslink examples , I am facing the the following difficulty.
1) Every time I load the DSP server using slaveloader I am getting the following crash report:
root@dm814x-evm:~/syslink_test# set -x
root@dm814x-evm:~/syslink_test# ./slaveloader startup DSP server_dsp.xe674
+ ./slaveloader startup DSP server_dsp.xe674
Attached to slave procId 0.
Loading procId 0.
BUG: Your driver calls ioremap() on system memory. This leads
to architecturally unpredictable behaviour on ARMv6+, and ioremap()
will fail in the next kernel release. Please fix your driver.
------------[ cut here ]------------
WARNING: at arch/arm/mm/ioremap.c:211 __arm_ioremap_pfn_caller+0x58/0x190()
Modules linked in: bufferclass_ti omaplfb pvrsrvkm tlc59108 ti81xxhdmi ti81xxvin tvp7002 ti81xxvo ti81xxfb vpss syslink ipv6
Backtrace:
[<c004bbd0>] (dump_backtrace+0x0/0x110) from [<c03ef4d8>] (dump_stack+0x18/0x1c)
r7:00000000 r6:c004f78c r5:c04c484b r4:000000d3
[<c03ef4c0>] (dump_stack+0x0/0x1c) from [<c0070738>] (warn_slowpath_common+0x54/0x6c)
[<c00706e4>] (warn_slowpath_common+0x0/0x6c) from [<c0070774>] (warn_slowpath_null+0x24/0x2c)
r9:00000002 r8:00000000 r7:bf081188 r6:0008f000 r5:0001b3c0
r4:00000000
[<c0070750>] (warn_slowpath_null+0x0/0x2c) from [<c004f78c>] (__arm_ioremap_pfn_caller+0x58/0x190)
[<c004f734>] (__arm_ioremap_pfn_caller+0x0/0x190) from [<c004f948>] (__arm_ioremap_caller+0x64/0x6c)
[<c004f8e4>] (__arm_ioremap_caller+0x0/0x6c) from [<c00620e0>] (omap_ioremap+0x60/0x64)
r6:00000000 r5:0001b3c0 r4:8f000000
[<c0062080>] (omap_ioremap+0x0/0x64) from [<bf081188>] (MemoryOS_map+0x1f0/0x3a8 [syslink])
r7:d670dcc4 r6:00000000 r5:d670dc58 r4:d7109000
[<bf080f98>] (MemoryOS_map+0x0/0x3a8 [syslink]) from [<bf04ec10>] (_ProcMgr_map+0x1cc/0x4ac [syslink])
r8:dbfe2000 r7:d670dcc4 r6:00000000 r5:bf148ba8 r4:d670dd48
[<bf04ea44>] (_ProcMgr_map+0x0/0x4ac [syslink]) from [<bf05d0ec>] (ElfLoaderTrgWrite_copy+0x10c/0x388 [syslink])
[<bf05cfe0>] (ElfLoaderTrgWrite_copy+0x0/0x388 [syslink]) from [<bf060730>] (DLIF_copy+0x10/0x1c [syslink])
[<bf060720>] (DLIF_copy+0x0/0x1c [syslink]) from [<bf05f46c>] (DLOAD_load+0x734/0xa58 [syslink])
[<bf05ed38>] (DLOAD_load+0x0/0xa58 [syslink]) from [<bf05c150>] (ElfLoader_load+0x274/0x37c [syslink])
[<bf05bedc>] (ElfLoader_load+0x0/0x37c [syslink]) from [<bf04cc10>] (Loader_load+0xec/0x164 [syslink])
[<bf04cb24>] (Loader_load+0x0/0x164 [syslink]) from [<bf051104>] (ProcMgr_load+0x220/0x2fc [syslink])
[<bf050ee4>] (ProcMgr_load+0x0/0x2fc [syslink]) from [<bf0530a8>] (ProcMgrDrv_ioctl+0xb7c/0x1b74 [syslink])
[<bf05252c>] (ProcMgrDrv_ioctl+0x0/0x1b74 [syslink]) from [<c00d76ec>] (vfs_ioctl+0x28/0x44)
r8:bedd9bb0 r7:00000008 r6:00000008 r5:d594a300 r4:00000000
[<c00d76c4>] (vfs_ioctl+0x0/0x44) from [<c00d7dfc>] (do_vfs_ioctl+0x500/0x540)
[<c00d78fc>] (do_vfs_ioctl+0x0/0x540) from [<c00d7e94>] (sys_ioctl+0x58/0x7c)
[<c00d7e3c>] (sys_ioctl+0x0/0x7c) from [<c0047e00>] (ret_fast_syscall+0x0/0x30)
r8:c0047fa8 r7:00000036 r6:00000000 r5:00000000 r4:bedd9bb0
---[ end trace eab8d36c9ed0f969 ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf081188 r6:0008f01b r5:000068f4
r4:00000000
r6:00000000 r5:000068f4 r4:8f01b3c0
---[ end trace eab8d36c9ed0f96a ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf081188 r6:0008f021 r5:00003e9e
r4:00000000
r6:00000000 r5:00003e9e r4:8f021cb8
---[ end trace eab8d36c9ed0f96b ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf081188 r6:0008f025 r5:0000143c
r4:00000000
r6:00000000 r5:0000143c r4:8f025b58
---[ end trace eab8d36c9ed0f96c ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf081188 r6:0008f026 r5:00001000
r4:00000000
r6:00000000 r5:00001000 r4:8f026f98
---[ end trace eab8d36c9ed0f96d ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf081188 r6:0008f027 r5:00000064
r4:00000000
r6:00000000 r5:00000064 r4:8f027f98
---[ end trace eab8d36c9ed0f96e ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf081188 r6:0008f028 r5:00000200
r4:00000000
r6:00000000 r5:00000200 r4:8f028000
---[ end trace eab8d36c9ed0f96f ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf081188 r6:0008f028 r5:00000120
r4:00000000
r6:00000000 r5:00000120 r4:8f028200
---[ end trace eab8d36c9ed0f970 ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf081188 r6:0008f028 r5:00000010
r4:00000000
r6:00000000 r5:00000010 r4:8f028320
---[ end trace eab8d36c9ed0f971 ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf081188 r6:0008f028 r5:0000000c
r4:00000000
r6:00000000 r5:0000000c r4:8f028330
---[ end trace eab8d36c9ed0f972 ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf081188 r6:0008f028 r5:00000034
r4:00000000
r6:00000000 r5:00000034 r4:8f028400
---[ end trace eab8d36c9ed0f973 ]---
Loaded file server_dsp.xe674 on slave procId 0.
Started slave procId 0.
2) While running the app_host application it is failing in the "Ipc_control" function call and the return is getting as -1?
The log is as:
root@dm814x-evm:~/syslink_test# ./app_host DSP
+ ./app_host DSP
--> main:
Going to Main_main
--> Main_main:
The remoteProcId value is 0
The status value is -1
Main_main: load callback failed
<-- Main_main:
Successfully executed Main_main
<-- main:
