enc image flicker
hi all, i do the cap->enc->dec->dis for cap the pc desk .i found the image is flicker and some place has the masics around the desk image flag?so what is wrong?
  • Attach the encoded bistream, Vsys_printDetailedStatistics log and link connection details
  • the following is the log and 264 enc stream
    //[20140306 15:23:49 192.168.1.198 192.168.1.198]
    XXX -  --- version info ---
    BIOS Version: U-Boot 2010.06-dirty-d9534e4 (Mar 03 2014 - 19:08:23)
    HLOS Version: Linux version 2.6.37+ (root@ubuntu) (gcc version 4.5.3 20110311 (prerelease) (GCC) ) #27 Tue Jan 14 17:13:54 CST 2014 hdmeeting20-9be5728
    FS   Version: GITVERSION_UBIFS-dirty-master-ccc7769 Thu Mar  6 11:35:02 CST 2014
    XXX -  --- filesystem info ---
    Current mount: console=ttyO2,115200n8 ubi.mtd=4,2048 rootwait root=ubi0:rootfs rootfstype=ubifs rootflags=sync rw mem=256M vram=20M notifyk.vpssm3_sva=0xBEE00000 ddr_mem=1024M ip=dhcp dhcpdelay=1
    Next    mount: console=ttyO2,115200n8 ubi.mtd=4,2048 rootwait root=ubi0:rootfs rootfstype=ubifs rootflags=sync rw mem=256M vram=20M notifyk.vpssm3_sva=0xBEE00000 ddr_mem=1024M ip=dhcp dhcpdelay=1
    XXX -  --- kermod info ---
    Module                  Size  Used by
    ad9388a                 6177  0
    gpio                    3365  0
    XXX -  --- para info ---
    IP=192.168.1.198
    ## Error: "reloadfactory" not defined
    autorunrdk=0
    autorunapp=0
    XXX -  ----------------
    root@HDMTerm:~# autorunrdk.sh 1
    autorunrdk=1
    root@HDMTerm:~# ./autorun.sh
                   autorun init script
    gpio                    3365  0
    ad9388a                 6177  0
    XXX - ------------------- rdk -------------------
    *** Bootargs Validated for mem param ***
    *** Bootargs Validated for notifyk.vpssm3 params ***
    *** Kernel Base address validated ***
    Kernel bootargs validated
    numid=101,iface=MIXER,name='Left DAC Mux'
      ; type=ENUMERATED,access=rw------,values=1,items=3
      ; Item #0 'DAC_L1'
      ; Item #1 'DAC_L3'
      ; Item #2 'DAC_L2'
      : values=0
    numid=99,iface=MIXER,name='Right DAC Mux'
      ; Item #0 'DAC_R1'
      ; Item #1 'DAC_R3'
      ; Item #2 'DAC_R2'
      : values=0
     [c6xdsp ] Remote Debug Shared Memory @ 0xbf000000
     [m3video] Remote Debug Shared Memory @ 0xbf010820
     [m3vpss ] Remote Debug Shared Memory @ 0xbf021040
     Setting DMM priority for [DUCATI  ] to [0] ( 0x4e000624 = 0x08000000 )
     Setting DMM priority for [HDVICP0 ] to [2] ( 0x4e000634 = 0x0000000a )
     Setting DMM priority for [HDVICP1 ] to [2] ( 0x4e000634 = 0x000a0000 )
     Setting DMM priority for [HDVICP2 ] to [2] ( 0x4e000634 = 0x00a00000 )
    /opt/dvr_rdk/ti816x
    Attached to slave procId 2.
    Loaded file ../firmware/dvr_rdk_fw_m3vpss_1024M_256M.xem3 on slave procId 2.
    Started slave procId 2.
    After Ipc_loadcallback status [0x00000000]
     [m3vpss ] ***** VPSS Firmware build time 16:30:25 Jan  8 2014  EDG gcc 3.0 mode
     [m3vpss ] ***** SYSTEM  : Frequency <ORG> - 250000000, <NEW> - 274909088
     [m3vpss ] notify_attach  rtnVal  0
     [m3vpss ] initProxyServer  rtnVal  0
     [m3vpss ]
     [m3vpss ]  *** UTILS: CPU KHz = 549818 Khz ***
     [m3vpss ]
     [m3vpss ]  34: SYSTEM  : System Common Init in progress !!!
     [m3vpss ]  35: SYSTEM: IPC init in progress !!!
     [m3vpss ]  35: SYSTEM: Attaching to [HOST] ...
     [m3vpss ]  37: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
    After Ipc_startcallback status [0x00000000]
    Attached to slave procId 1.
     [m3vpss ]  1035: SYSTEM: Attaching to [DSP] ...
    Loaded file ../firmware/dvr_rdk_fw_m3video_1024M_256M.xem3 on slave procId 1.
    Started slave procId 1.
     [m3video] ***** VIDEO Firmware build time 16:31:24 Jan  8 2014  EDG gcc 3.0 mode
     [m3video] ***** SYSTEM  : Frequency <ORG> - 250000000, <NEW> - 274909088
     [m3video]
     [m3video]  *** UTILS: CPU KHz = 549818 Khz ***
     [m3video]
     [m3video]  1114: SYSTEM  : System Common Init in progress !!!
     [m3video]  1114: SYSTEM: IPC init in progress !!!
     [m3video]  1115: SYSTEM: Attaching to [HOST] ...
     [m3video]  1117: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
    Attached to slave procId 0.
    Loaded file ../firmware/dvr_rdk_fw_c6xdsp_1024M_256M.xe674 on slave procId 0.
    Started slave procId 0.
     [c6xdsp ] ***** VIDEO Firmware build time 16:29:20 Jan  8 2014  EDG gcc 3.0 mode
     [c6xdsp ] ***** SYSTEM  : Frequency <ORG> - 800000000, <NEW> - 1000000000
     [c6xdsp ]
     [c6xdsp ]  *** UTILS: CPU KHz = 1000000 Khz ***
     [c6xdsp ]
     [c6xdsp ]  5: SYSTEM  : System Common Init in progress !!!
     [c6xdsp ]  5: SYSTEM: IPC init in progress !!!
     [c6xdsp ]  5: SYSTEM: Attaching to [HOST] ...
     [c6xdsp ]  8: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
     [c6xdsp ]  10: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
     [m3video]  1560: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
     [m3vpss ]  1562: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
     [c6xdsp ]  12: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
     [m3video]  1564: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
     [m3vpss ]  1564: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
     [c6xdsp ]  12: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_0] ...
     [m3video]  1564: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_1] ...
     [m3vpss ]  1564: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_2] ...
     [c6xdsp ]  12: SYSTEM: Creating MsgQ [DSP_MSGQ] ...
     [m3video]  1565: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
     [m3vpss ]  1565: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
     [c6xdsp ]  12: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ...
     [m3video]  1565: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
     [m3vpss ]  1565: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
     [c6xdsp ]  13: SYSTEM: Notify register to [HOST] line 0, event 15 ...
     [m3video]  1566: SYSTEM: Notify register to [HOST] line 0, event 15 ...
     [m3vpss ]  1566: SYSTEM: Notify register to [HOST] line 0, event 15 ...
     [c6xdsp ]  13: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
     [m3video]  1567: SYSTEM: Notify register to [DSP] line 0, event 15 ...
     [m3vpss ]  1567: SYSTEM: Notify register to [DSP] line 0, event 15 ...
     [c6xdsp ]  13: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
     [m3video]  1567: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
     [m3vpss ]  1567: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
     [c6xdsp ]  13: SYSTEM: IPC init DONE !!!
     [m3video]  1567: SYSTEM: IPC init DONE !!!
     [m3vpss ]  1567: SYSTEM: IPC init DONE !!!
     [c6xdsp ]  14: MEM: Shared Region 2: Base = 0xae000000, Length = 0x109c0000 (265 MB)
     [c6xdsp ]  14: MEM: Shared Region 1: Base = 0x90000000, Length = 0x0c700000 (199 MB)
     [c6xdsp ]  15: SYSTEM  : System Common Init Done !!!
     [c6xdsp ]  9: SYSTEM  : System DSP Init in progress !!!
     [c6xdsp ]  9: SYSTEM  : RpeServer_init() done... Ret Val 0!!!
     [c6xdsp ]  17: SYSTEM: Creating ListMP [DSP_IPC_OUT_19] in region 0 ...
     [c6xdsp ]  17: SYSTEM: Creating ListMP [DSP_IPC_IN_19] in region 0 ...
     [c6xdsp ]  17: SYSTEM: ListElem Shared Addr = 0xbf273e00
     [c6xdsp ]  18: SYSTEM: Creating ListMP [DSP_IPC_OUT_20] in region 0 ...
     [c6xdsp ]  18: SYSTEM: Creating ListMP [DSP_IPC_IN_20] in region 0 ...
     [c6xdsp ]  18: SYSTEM: ListElem Shared Addr = 0xbf299600
     [c6xdsp ]  19: SYSTEM: Creating ListMP [DSP_IPC_OUT_21] in region 0 ...
     [c6xdsp ]  19: SYSTEM: Creating ListMP [DSP_IPC_IN_21] in region 0 ...
     [c6xdsp ]  19: SYSTEM: ListElem Shared Addr = 0xbf2bee00
     [c6xdsp ]  19: SYSTEM: Creating ListMP [DSP_IPC_OUT_24] in region 0 ...
     [c6xdsp ]  19: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ...
     [c6xdsp ]  19: SYSTEM: ListElem Shared Addr = 0xbf2e4600
     [c6xdsp ]  20: SYSTEM: Creating ListMP [DSP_IPC_OUT_25] in region 0 ...
     [m3video]  1572: MEM: Shared Region 2: Base = 0xae000000, Length = 0x109c0000 (265 MB)
     [m3vpss ]  1572: MEM: Shared Region 2: Base = 0xae000000, Length = 0x109c0000 (265 MB)
     [c6xdsp ]  20: SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ...
     [m3video]  1573: MEM: Shared Region 1: Base = 0x90000000, Length = 0x0c700000 (199 MB)
     [m3vpss ]  1573: MEM: Shared Region 1: Base = 0x90000000, Length = 0x0c700000 (199 MB)
     [c6xdsp ]  20: SYSTEM: ListElem Shared Addr = 0xbf302100
     [m3video]  1574: SYSTEM  : System Common Init Done !!!
     [m3vpss ]  1574: SYSTEM  : System Common Init Done !!!
     [c6xdsp ] !!WARNING.Resource already registered:2
     [c6xdsp ]  15: SYSTEM  : Initializing Links !!!
     [m3video]  1575: SYSTEM  : System Video Init in progress !!!
     [m3vpss ]  1575: SYSTEM  : System VPSS Init in progress !!!
     [m3video]  1575: SYSTEM  : System Video Init Done !!!
     [c6xdsp ]  20: SYSTEM  : FREE SPACE : System Heap      = 10391168 B, Mbx = 10240 msgs)
     [m3video]  1575: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
     [m3video]  1575: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
     [m3video]  1576: SYSTEM: ListElem Shared Addr = 0xbf31fc00
     [m3video]  1578: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
     [m3video]  1578: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
     [m3video]  1578: SYSTEM: ListElem Shared Addr = 0xbf323100
     [c6xdsp ]  24: SYSTEM  : Initializing Links ... DONE !!!
     [m3video]  1584: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_19] in region 0 ...
     [m3vpss ] === HDVPSS Clocks are enabled ===
     [m3video]  1584: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_19] in region 0 ...
     [m3vpss ] === HDVPSS is fully functional ===
     [c6xdsp ]  ETH_OFFLOAD: Init !!!
     [m3video]  1584: SYSTEM: ListElem Shared Addr = 0xbf329b00
     [m3vpss ] === HDVPSS module is not in standby ===
     [c6xdsp ]  25: SYSTEM  : System DSP Init Done !!!
     [m3video]  1587: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_20] in region 0 ...
     [m3vpss ] === I2C1 Clk is active ===
     [m3video]  1587: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_20] in region 0 ...
     [m3vpss ]  1583: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
     [m3video]  1587: SYSTEM: ListElem Shared Addr = 0xbf352800
     [m3vpss ]  1584: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
     [m3video]  1589: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_21] in region 0 ...
     [m3vpss ]  1584: SYSTEM: ListElem Shared Addr = 0xbf326880
     [m3video]  1590: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_21] in region 0 ...
     [m3vpss ]  1586: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
     [m3video]  1590: SYSTEM: ListElem Shared Addr = 0xbf378000
     [m3vpss ]  1586: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
     [m3vpss ]  1587: SYSTEM: ListElem Shared Addr = 0xbf34f300
     [m3video]  1603: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_24] in region 0 ...
     [m3vpss ]  1600: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_19] in region 0 ...
     [m3video]  1603: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_24] in region 0 ...
     [m3vpss ]  1601: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_19] in region 0 ...
     [m3video]  1604: SYSTEM: ListElem Shared Addr = 0xbf3c3580
     [m3vpss ]  1601: SYSTEM: ListElem Shared Addr = 0xbf39d800
     [m3video]  1606: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_25] in region 0 ...
     [m3vpss ]  1603: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_20] in region 0 ...
     [m3video]  1606: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_25] in region 0 ...
     [m3vpss ]  1604: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_20] in region 0 ...
     [m3video]  1606: SYSTEM: ListElem Shared Addr = 0xbf406580
     [m3vpss ]  1604: SYSTEM: ListElem Shared Addr = 0xbf3e0b00
     [m3video]  1608: HDVICP: Doing PRCM for IVAHD[0] ...
     [m3vpss ]  1606: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_21] in region 0 ...
     [m3video]  1608: HDVICP: PRCM for IVAHD[0] ... DONE.
     [m3vpss ]  1606: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_21] in region 0 ...
     [m3video]  1608: HDVICP: Doing PRCM for IVAHD[1] ...
     [m3vpss ]  1607: SYSTEM: ListElem Shared Addr = 0xbf423e00
     [m3video]  1608: HDVICP: PRCM for IVAHD[1] ... DONE.
     [m3vpss ]  1608: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
     [m3video]  1608: HDVICP: Doing PRCM for IVAHD[2] ...
     [m3vpss ]  1608: SYSTEM  : FVID2 Init in progress !!!
     [m3video]  1608: HDVICP: PRCM for IVAHD[2] ... DONE.
     [m3video]  1609: SYSTEM  : Initializing Links !!!
     [m3video]  1609: SYSTEM  : FREE SPACE : System Heap      = 6279304 B, Mbx = 10240 msgs)
     [m3vpss ] TILER_STATS: CNT :8BIT
     [m3video]  1609: SYSTEM  : FREE SPACE : SR0 Heap         = 12283904 B (11 MB)
     [m3vpss ] TILER_STATS: CNT RESOLUTION:    16384 x 8192
     [m3video]  1609: SYSTEM  : FREE SPACE : Frame Buffer     = 278658944 B (265 MB)
     [m3vpss ] TILER_STATS: BUCKET RESOLUTION: 16384 x 8188
     [m3video]  1609: SYSTEM  : FREE SPACE : Bitstream Buffer = 208666496 B (198 MB)
     [m3vpss ] TILER_STATS: NUM FREE BUCKETS:  1
     [m3video]  1609: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
     [m3video]  1611: SYSTEM  : FREE SPACE : Tiler 8-bit      = 134152192 B (127 MB)  - TILER ON
     [m3vpss ] TILER_STATS: NUM USED BUCKETS:  0
     [m3video]  1611: SYSTEM  : FREE SPACE : Tiler 16-bit     = 100663296 B (96 MB)  - TILER ON
     [m3vpss ] TILER_STATS: TOTAL FREE AREA:   134152192 (99 %)
     [m3video]  1646: SYSTEM  : Initializing Links ... DONE !!!
     [m3vpss ] TILER_STATS: TOTAL USED AREA:   0 (0 %)
     [m3vpss ] TILER_STATS: CNT :16BIT
     [m3vpss ] TILER_STATS: CNT RESOLUTION:    32768 x 3072
     [m3vpss ] TILER_STATS: BUCKET RESOLUTION: 32768 x 3072
     [m3vpss ] TILER_STATS: TOTAL FREE AREA:   100663296 (100 %)
     [m3vpss ]  1678: SYSTEM  : FVID2 Init in progress DONE !!!
     [m3vpss ]  1678: SYSTEM  : Device Init in progress !!!
     [m3vpss ]  1681: SYSTEM  : Device Init in progress DONE !!!
     [m3vpss ]  1721: SYSTEM  : System VPSS Init Done !!!
     [m3vpss ]  1721: UTILS: DMA: HWI Create for INT63 !!!
     [m3vpss ]  1722: SYSTEM  : Initializing Links !!!
     [m3vpss ]  1722: SYSTEM  : FREE SPACE : System Heap      = 74056 B, Mbx = 10240 msgs)
     [m3vpss ]  1722: SYSTEM  : FREE SPACE : SR0 Heap         = 12283904 B (11 MB)
     [m3vpss ]  1722: SYSTEM  : FREE SPACE : Frame Buffer     = 274348928 B (261 MB)
     [m3vpss ]  1722: SYSTEM  : FREE SPACE : Bitstream Buffer = 208666496 B (198 MB)
     [m3vpss ] Received character 's'
     [m3video] Received character 's'
     [c6xdsp ] Received character 's'
    /opt/dvr_rdk/ti816x
     [m3vpss ]  1723: SYSTEM  : FREE SPACE : Tiler 8-bit      = 134152192 B (127 MB)  - TILER ON
     [m3vpss ]  1723: SYSTEM  : FREE SPACE : Tiler 16-bit     = 100663296 B (96 MB)  - TILER ON
     [m3vpss ]  1838: SYSTEM  : Initializing Links ... DONE !!!
     [m3vpss ]  1838: SYSTEM  : Set Static L3 pressure for HDVPSS as High
     ORG 0x46c00524: 0
     NEW 0x46c00524: 2
    XXX - ------------------- 3101 -------------------
    Module                  Size  Used by
    sii9022a                5318  0
    ti81xxhdmi             24612  0
    ti81xxfb               22502  0
    vpss                   78287  3 sii9022a,ti81xxhdmi,ti81xxfb
    osa_kermod              8881  0
    syslink               803610  0
    ad9388a                 6177  0
    gpio                    3365  0
    IP=192.168.1.198
    autorunrdk=1
    autorunapp=0
    WARNING - Run "autorunapp.sh 1/yes" to enable APP auto run !!!
    root@HDMTerm:~# cd /opt/hdmeeting20/bin/
    root@HDMTerm:/opt/hdmeeting20/bin# ./gt_hdcard20_app.out
     0: SYSTEM: System Common Init in progress !!!
     1: SYSTEM: IPC init in progress !!!
     13: SYSTEM: CPU [DSP] syslink proc ID is [0] !!!
     13: SYSTEM: CPU [VIDEO-M3] syslink proc ID is [1] !!!
     13: SYSTEM: CPU [VPSS-M3] syslink proc ID is [2] !!!
     13: SYSTEM: CPU [HOST] syslink proc ID is [3] !!!
     13: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_3] ...
     17: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
     19: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
     21: SYSTEM: Opening MsgQ [DSP_MSGQ] ...
     21: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
     21: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
     22: SYSTEM: Notify register to [DSP] line 0, event 15 ...
     23: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
     24: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
     24: SYSTEM: IPC init DONE !!!
     25: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
     28: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
     29: SYSTEM: ListElem Shared Addr = 0x407ef880
     30: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
     32: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
     33: SYSTEM: ListElem Shared Addr = 0x40824a80
     35: SYSTEM: Creating ListMP [HOST_IPC_OUT_19] in region 0 ...
     37: SYSTEM: Creating ListMP [HOST_IPC_IN_19] in region 0 ...
     39: SYSTEM: ListElem Shared Addr = 0x40859c80
     40: SYSTEM: Creating ListMP [HOST_IPC_OUT_20] in region 0 ...
     42: SYSTEM: Creating ListMP [HOST_IPC_IN_20] in region 0 ...
     43: SYSTEM: ListElem Shared Addr = 0x4089cf80
     44: SYSTEM: Creating ListMP [HOST_IPC_OUT_21] in region 0 ...
     47: SYSTEM: Creating ListMP [HOST_IPC_IN_21] in region 0 ...
     48: SYSTEM: ListElem Shared Addr = 0x408e0280
     64: SYSTEM: System Common Init Done !!!
     [m3vpss ]  12139: CAPTURE: Create in progress !!!
     [m3vpss ]  12168: CAPTURE: VIP0 PortA capture mode is [16-bit, Non-mux Discrete Sync - ACTVID_VSYNC] !!!
     [m3vpss ]  12378: CAPTURE: VIP1 PortA capture mode is [16-bit, Non-mux Discrete Sync - ACTVID_VSYNC] !!!
     [m3vpss ]  UTILS: DMA: Allocated CH (TCC) = 58 (58)
     [m3vpss ]  UTILS: DMA: 0 of 4: Allocated PaRAM = 58 (0x49004740)
     [m3vpss ]  UTILS: DMA: 1 of 4: Allocated PaRAM = 64 (0x49004800)
     [m3vpss ]  UTILS: DMA: 2 of 4: Allocated PaRAM = 65 (0x49004820)
     [m3vpss ]  UTILS: DMA: 3 of 4: Allocated PaRAM = 66 (0x49004840)
     [m3vpss ] CAPTURE::HEAPID:0    USED:520
     [m3vpss ] CAPTURE::HEAPID:4    USED:95385600
     [m3vpss ]  12590: CAPTURE: Create Done !!!
     [m3vpss ]  12595: DUP   : Create Done !!!
     [m3vpss ]  12595: NSF: Create in progress !!!
     [m3vpss ] NSF::HEAPID:0        USED:128
     [m3vpss ] NSF::HEAPID:1        USED:6336
     [m3vpss ]  12597: NSF: Create Done !!!
     [m3vpss ]  12597: IPC_OUT_M3   : Create in progress !!!
     [m3vpss ]  12598: IPC_OUT_M3   : Create Done !!!
     [m3vpss ]  12599: CAPTURE: Start in progress !!!
     [m3vpss ]  12699: CAPTURE: Enabled Time Stamping !!!
     [m3vpss ]  12707: CAPTURE: Enabled Time Stamping !!!
     Selected file write path [/opt]
     Opened file [/opt/VID_CH00.h264] for writing CH0
     Opened file [/opt/VID_CH01.h264] for writing CH1
     [m3vpss ]  12715: CAPTURE: Start Done !!!
     [m3video]  12720: IPC_IN_M3   : Create in progress !!!
     [m3video]  12720: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ...
     [m3video]  12720: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ...
     [m3video]  12722: IPC_IN_M3   : Create Done !!!
     [m3video]  12722: ENCODE: Create in progress ... !!!
     [m3video]  12783: ENCODE: Creating CH0 of 1920 x 1080, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
     [host] IpcBitsInLink_tskMain:Entered
     [host]  721: IPC_BITS_IN   : Create in progress !!!
     [host]  721: IPC_BITS_IN   : ListMPOpen start !!!
     [host]  721: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_24] ...
     723: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_24] ...
     [host]  725: IPC_BITS_IN   : ListMPOpen done !!!
     [host]  726: IPC_BITS_IN   : System_linkGetInfo done !!!
     [host]  726: IPC_BITS_IN   : Create Done !!!
    ---------dec numChn = 16---------
     Vdec_init : Initialize the decoder successfully !
     [host]  727: IPC_BITS_OUT   : Create in progress !!!
     [host] IPC_BITSOUT:BitBuffer Alloc.ChID:0,Size:0x9E3400
     [host]
    ******* RingBuf 0 created ********
     [host] IPCBITSOUTLINK:Translated Addr Virt:0x4923e880 To Phy:0x90bdd880
     [host]
    ###Bit buff of size from the SR # 1 : 10368000 / bufsize 2073600, maxQueueDepth 50
     [host] ###Bit buff BasePtr: 4923E880 / PhyAddr 90BDD880
     [host] IPC_BITSOUT:BitBuffer Alloc.ChID:1,Size:0x9E3400
     [host]
    ******* RingBuf 1 created ********
     [host] IPCBITSOUTLINK:Translated Addr Virt:0x49c21c80 To Phy:0x915c0c80
     [host]
     [host] ###Bit buff BasePtr: 49C21C80 / PhyAddr 915C0C80
     [host] IPC_BITSOUT:BitBuffer Alloc.ChID:2,Size:0x9E3400
     [host]
    ******* RingBuf 2 created ********
     [host] IPCBITSOUTLINK:Translated Addr Virt:0x4a605080 To Phy:0x91fa4080
     [host]
     [host] ###Bit buff BasePtr: 4A605080 / PhyAddr 91FA4080
     [host] IPC_BITSOUT:BitBuffer Alloc.ChID:3,Size:0x9E3400
     [host]
    ******* RingBuf 3 created ********
     [host] IPCBITSOUTLINK:Translated Addr Virt:0x4afe8480 To Phy:0x92987480
     [host]
     [host] ###Bit buff BasePtr: 4AFE8480 / PhyAddr 92987480
     [host] IPC_BITSOUT:BitBuffer Alloc.ChID:4,Size:0x9E3400
     [host]
    ******* RingBuf 4 created ********
     [host] IPCBITSOUTLINK:Translated Addr Virt:0x4b9cb880 To Phy:0x9336a880
     [host]
     [host] ###Bit buff BasePtr: 4B9CB880 / PhyAddr 9336A880
     [host] IPC_BITSOUT:BitBuffer Alloc.ChID:5,Size:0x9E3400
     [host]
    ******* RingBuf 5 created ********
     [host] IPCBITSOUTLINK:Translated Addr Virt:0x4c3aec80 To Phy:0x93d4dc80
     [host]
     [host] ###Bit buff BasePtr: 4C3AEC80 / PhyAddr 93D4DC80
     [host] IPC_BITSOUT:BitBuffer Alloc.ChID:6,Size:0x9E3400
     [host]
    ******* RingBuf 6 created ********
     [host] IPCBITSOUTLINK:Translated Addr Virt:0x4cd92080 To Phy:0x94731080
     [host]
     [host] ###Bit buff BasePtr: 4CD92080 / PhyAddr 94731080
     [host] IPC_BITSOUT:BitBuffer Alloc.ChID:7,Size:0x9E3400
     [host]
    ******* RingBuf 7 created ********
     [host] IPCBITSOUTLINK:Translated Addr Virt:0x4d775480 To Phy:0x95114480
     [host]
     [host] ###Bit buff BasePtr: 4D775480 / PhyAddr 95114480
     [host] IPC_BITSOUT:BitBuffer Alloc.ChID:8,Size:0x9E3400
     [host]
    ******* RingBuf 8 created ********
     [host] IPCBITSOUTLINK:Translated Addr Virt:0x4e158880 To Phy:0x95af7880
     [host]
     [host] ###Bit buff BasePtr: 4E158880 / PhyAddr 95AF7880
     [host] IPC_BITSOUT:BitBuffer Alloc.ChID:9,Size:0x9E3400
     [host]
    ******* RingBuf 9 created ********
     [host] IPCBITSOUTLINK:Translated Addr Virt:0x4eb3bc80 To Phy:0x964dac80
     [host]
     [host] ###Bit buff BasePtr: 4EB3BC80 / PhyAddr 964DAC80
     [host] IPC_BITSOUT:BitBuffer Alloc.ChID:10,Size:0x9E3400
     [host]
    ******* RingBuf 10 created ********
     [host] IPCBITSOUTLINK:Translated Addr Virt:0x4f51f080 To Phy:0x96ebe080
     [host]
     [host] ###Bit buff BasePtr: 4F51F080 / PhyAddr 96EBE080
     [host] IPC_BITSOUT:BitBuffer Alloc.ChID:11,Size:0x9E3400
     [host]
    ******* RingBuf 11 created ********
     [host] IPCBITSOUTLINK:Translated Addr Virt:0x4ff02480 To Phy:0x978a1480
     [host]
     [host] ###Bit buff BasePtr: 4FF02480 / PhyAddr 978A1480
     [host] IPC_BITSOUT:BitBuffer Alloc.ChID:12,Size:0x9E3400
     [host]
    ******* RingBuf 12 created ********
     [host] IPCBITSOUTLINK:Translated Addr Virt:0x508e5880 To Phy:0x98284880
     [host]
     [host] ###Bit buff BasePtr: 508E5880 / PhyAddr 98284880
     [host] IPC_BITSOUT:BitBuffer Alloc.ChID:13,Size:0x9E3400
     [host]
    ******* RingBuf 13 created ********
     [host] IPCBITSOUTLINK:Translated Addr Virt:0x512c8c80 To Phy:0x98c67c80
     [host]
     [host] ###Bit buff BasePtr: 512C8C80 / PhyAddr 98C67C80
     [host] IPC_BITSOUT:BitBuffer Alloc.ChID:14,Size:0x9E3400
     [host]
    ******* RingBuf 14 created ********
     [host] IPCBITSOUTLINK:Translated Addr Virt:0x51cac080 To Phy:0x9964b080
     [host]
     [host] ###Bit buff BasePtr: 51CAC080 / PhyAddr 9964B080
     [host] IPC_BITSOUT:BitBuffer Alloc.ChID:15,Size:0x9E3400
     [host]
    ******* RingBuf 15 created ********
     [host] IPCBITSOUTLINK:Translated Addr Virt:0x5268f480 To Phy:0x9a02e480
     [host]
     [host] ###Bit buff BasePtr: 5268F480 / PhyAddr 9A02E480
     [host]  730: IPC_BITS_OUT   : Create Done !!!
     [m3video] ENCLINK_H264:HEAPID:0        USED:13808
     [m3video] ENCLINK_H264:HEAPID:3        USED:98304
     [m3video]  12786: ENCODE: Creating CH1 of 1920 x 1080, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
     Vtmcl_createVdecLink : Create the decode links successfully !
     Vdec_start : Start the decoder successfully !
     [host] HDMI Ctrl :Initializing
     [host] HDMI Ctrl :Initialized
     [host] HDMI Ctrl :Sink Connected
     [m3vpss ]  12820: IPC_IN_M3   : Create in progress !!!
     [m3video] ENCLINK_H264:HEAPID:0        USED:11912
     [m3vpss ]  12820: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_0] ...
     [m3vpss ]  12820: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_0] ...
     [m3video]  12789: ENCODE: All CH Create ... DONE !!!
     [m3vpss ]  12821: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
     [m3vpss ]  12822: IPC_IN_M3   : Create Done !!!
     [m3video] ENCLINK:HEAPID:0     USED:25840
     [m3vpss ]  12823: MERGE   : Create Done !!!
     [m3video] ENCLINK:HEAPID:2     USED:12441600
     [m3vpss ]  12829: DUP   : Create Done !!!
     [m3video] ENCLINK:HEAPID:3     USED:196608
     [m3vpss ]  12830: SWMS: Create in progress !!!
     [m3video]  12791: ENCODE: Create ... DONE !!!
     [m3vpss ]  UTILS: DMA: Allocated CH (TCC) = 59 (59)
     [m3video]  12791: IPC_BITS_OUT   : Create in progress !!!
     [m3vpss ]  UTILS: DMA: 0 of 1: Allocated PaRAM = 59 (0x49004760)
     [m3vpss ]  UTILS: DMA: Allocated CH (TCC) = 60 (60)
     [m3vpss ]  UTILS: DMA: 0 of 4: Allocated PaRAM = 60 (0x49004780)
     [m3video]  12793: IPC_BITS_OUT   : Create Done !!!
     [m3vpss ]  UTILS: DMA: 1 of 4: Allocated PaRAM = 67 (0x49004860)
     [m3video]  12802: IPC_BITS_IN   : Create in progress !!!
     [m3vpss ]  UTILS: DMA: 2 of 4: Allocated PaRAM = 160 (0x49005400)
     [m3video]  12803: SYSTEM: Opening ListMP [HOST_IPC_OUT_24] ...
     [m3vpss ]  UTILS: DMA: 3 of 4: Allocated PaRAM = 161 (0x49005420)
     [m3video]  12803: SYSTEM: Opening ListMP [HOST_IPC_IN_24] ...
     [m3vpss ] SWMS: instance 0, sc id 7, start win 0 end win 15
     [m3video]  12804: SYSTEM: Opening MsgQ [HOST_MSGQ] ...
     [m3vpss ] SWMS: instance 1, sc id 4, start win 16 end win 33
     [m3video]  12805: IPC_BITS_IN   : Create Done !!!
     [m3vpss ]  12936: SWMS    : VipScReq is FALSE!!!
     [m3video]  12805: DECODE: Create in progress ... !!!
     [m3vpss ]  12940: SWMS0    : Loading Vertical Co-effs (UPSCALE)x ...
     [m3video] 12807: DECODE: CodecInst and OutFrm bufs are NOT created for CH0
     [m3vpss ]  12940: SWMS0    : Loading Horizontal Co-effs (UPSCALE)x ...
     [m3video]  12807: DECODE: Creating CH0 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 2000 Kbps ...
     [m3vpss ]  12940: SWMS    : Co-effs Loading ... DONE !!!
     [m3video] 12807: DECODE: CodecInst and OutFrm bufs are NOT created for CH1
     [m3vpss ]  12944: SWMS0    : Loading Vertical Co-effs (UPSCALE)x ...
     [m3video]  12807: DECODE: Creating CH1 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 2000 Kbps ...
     [m3vpss ]  12944: SWMS0    : Loading Horizontal Co-effs (UPSCALE)x ...
     [m3video] 12807: DECODE: CodecInst and OutFrm bufs are NOT created for CH2
     [m3vpss ]  12944: SWMS    : Co-effs Loading ... DONE !!!
     [m3video]  12808: DECODE: Creating CH2 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 2000 Kbps ...
     [m3vpss ]  12945: SWMS    : ******* Configuring clock 15 secs...
     [m3video] 12808: DECODE: CodecInst and OutFrm bufs are NOT created for CH3
     [m3vpss ]  12945: SWMS0    : Loading Vertical Co-effs (UPSCALE)x ...
     [m3video]  12808: DECODE: Creating CH3 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 2000 Kbps ...
     [m3vpss ]  12945: SWMS0    : Loading Horizontal Co-effs (UPSCALE)x ...
     [m3video] 12808: DECODE: CodecInst and OutFrm bufs are NOT created for CH4
     [m3vpss ]  12945: SWMS    : Co-effs Loading ... DONE !!!
     [m3video]  12808: DECODE: Creating CH4 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 2000 Kbps ...
     [m3video] 12808: DECODE: CodecInst and OutFrm bufs are NOT created for CH5
     [m3video]  12808: DECODE: Creating CH5 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 2000 Kbps ...
     [m3video] 12809: DECODE: CodecInst and OutFrm bufs are NOT created for CH6
     [m3vpss ]
     [m3vpss ]  *** [SWMS0] Mosaic Parameters ***
     [m3vpss ]
     [m3vpss ]  Output FPS: 60
     [m3vpss ]
     [m3vpss ]  Win | Ch  | Input      | Input          | Input         | Input       | Output     |  Output         | Output        | Output      | Low Cost | SWMS | Data  | Blank |
     [m3vpss ]  Num | Num | Start X, Y | Width x Height | Pitch Y / C   | Memory Type | Start X, Y |  Width x Height | Pitch Y / C   | Memory Type | ON / OFF | Inst | Format| Frame |
     [m3vpss ]  ----------------------------------------------------------------------------------------------------------------------------------------------------------------------
     [m3video]  12809: DECODE: Creating CH6 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 2000 Kbps ...
     [m3vpss ]    0 |   0 |    0,    0 |  1920 x   1080 |  2048 /  2048 | NON-TILED   |    0,    0 |  1920 x   1080 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3video] 12809: DECODE: CodecInst and OutFrm bufs are NOT created for CH7
     [m3vpss ]
     [m3video]  12809: DECODE: Creating CH7 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 2000 Kbps ...
     [m3video] 12809: DECODE: CodecInst and OutFrm bufs are NOT created for CH8
     [m3video]  12809: DECODE: Creating CH8 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 2000 Kbps ...
     [m3vpss ] SWMS:HEAPID:0        USED:424
     [m3video] 12809: DECODE: CodecInst and OutFrm bufs are NOT created for CH9
     [m3vpss ] SWMS:HEAPID:1        USED:64352
     [m3video]  12810: DECODE: Creating CH9 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 2000 Kbps ...
     [m3vpss ] SWMS:HEAPID:4        USED:20736000
     [m3video] 12810: DECODE: CodecInst and OutFrm bufs are NOT created for CH10
     [m3vpss ]  12947: SWMS: Create Done !!!
     [m3video]  12810: DECODE: Creating CH10 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 2000 Kbps ...
     [m3video] 12810: DECODE: CodecInst and OutFrm bufs are NOT created for CH11
     [m3video]  12810: DECODE: Creating CH11 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 2000 Kbps ...
     [m3video] 12810: DECODE: CodecInst and OutFrm bufs are NOT created for CH12
     [m3video]  12810: DECODE: Creating CH12 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 2000 Kbps ...
     [m3video] 12811: DECODE: CodecInst and OutFrm bufs are NOT created for CH13
     [m3video]  12811: DECODE: Creating CH13 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 2000 Kbps ...
     [m3video] 12811: DECODE: CodecInst and OutFrm bufs are NOT created for CH14
     [m3video]  12811: DECODE: Creating CH14 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 2000 Kbps ...
     [m3video] 12811: DECODE: CodecInst and OutFrm bufs are NOT created for CH15
     [m3video]  12811: DECODE: Creating CH15 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 2000 Kbps ...
     [m3video]  12813: DECODE: All CH Create ... DONE !!!
     [m3vpss ]  13187: SWMS: Create in progress !!!
     [m3video] DECLINK:HEAPID:0     USED:120
     [m3video]  12816: DECODE: Create ... DONE !!!
     [m3video]  12816: IPC_OUT_M3   : Create in progress !!!
     [m3video]  12817: IPC_OUT_M3   : Create Done !!!
     [m3vpss ]  UTILS: DMA: Allocated CH (TCC) = 61 (61)
     [m3vpss ]  UTILS: DMA: 0 of 1: Allocated PaRAM = 61 (0x490047A0)
     [m3vpss ]  UTILS: DMA: Allocated CH (TCC) = 62 (62)
     [m3vpss ]  UTILS: DMA: 0 of 4: Allocated PaRAM = 62 (0x490047C0)
     [m3vpss ]  UTILS: DMA: 1 of 4: Allocated PaRAM = 162 (0x49005440)
     [m3vpss ]  UTILS: DMA: 2 of 4: Allocated PaRAM = 163 (0x49005460)
     [m3vpss ]  UTILS: DMA: 3 of 4: Allocated PaRAM = 164 (0x49005480)
     [m3vpss ] SWMS: instance 0, sc id 6, start win 0 end win 15
     [m3vpss ] SWMS: instance 1, sc id 3, start win 16 end win 33
     [m3vpss ]  13290: SWMS    : VipScReq is FALSE!!!
     [m3vpss ]  13294: SWMS1    : Loading Vertical Co-effs (UPSCALE)x ...
     [m3vpss ]  13294: SWMS1    : Loading Horizontal Co-effs (UPSCALE)x ...
     [m3vpss ]  13294: SWMS    : Co-effs Loading ... DONE !!!
     [c6xdsp ]  11754: IPC_FRAMES_IN   : Create in progress !!!
     [m3vpss ]  13298: SWMS1    : Loading Vertical Co-effs (UPSCALE)x ...
     [c6xdsp ]  11754: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_19] ...
     [m3vpss ]  13298: SWMS1    : Loading Horizontal Co-effs (UPSCALE)x ...
     [c6xdsp ]  11754: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_19] ...
     [m3vpss ]  13298: SWMS    : Co-effs Loading ... DONE !!!
     [c6xdsp ]  11754: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
     [m3vpss ]  13299: SWMS    : ******* Configuring clock 15 secs...
     [m3vpss ]  13299: SWMS1    : Loading Vertical Co-effs (UPSCALE)x ...
     [m3vpss ]  13299: SWMS1    : Loading Horizontal Co-effs (UPSCALE)x ...
     [c6xdsp ] IPC_FRAMES_IN:HEAPID:0       USED:304
     [m3vpss ]  13299: SWMS    : Co-effs Loading ... DONE !!!
     [c6xdsp ]  11755: IPC_FRAMES_IN   : Create Done !!!
     [c6xdsp ]  11756: ALG : Create in progress !!!
     [m3vpss ]
     [m3vpss ]  *** [SWMS1] Mosaic Parameters ***
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [c6xdsp ] ALGLINK:HEAPID:0     USED:2616
     [m3vpss ] SWMS:HEAPID:1        USED:66656
     [c6xdsp ] ALGLINK:HEAPID:1     USED:31512
     [c6xdsp ]  11767: ALG : Create Done !!!
     [m3vpss ]  13300: SWMS: Create Done !!!
     [m3vpss ]  13301: MERGE   : Create Done !!!
     [m3vpss ]  13302: IPC_FRAMES_OUT   : Create in progress !!!
     [m3vpss ]  13304: IPC_FRAMES_OUT   : Create Done !!!
     [m3vpss ]  13319: SELECT: OUT QUE0: OUT CH0: IN CH0: 1920 x 1080, pitch = (3840, 0) [PROGRESSIVE] [NON-TILED  ]
     [m3vpss ]  13320: SELECT: OUT QUE1: OUT CH0: IN CH1: 1920 x 1080, pitch = (3840, 0) [PROGRESSIVE] [NON-TILED  ]
     [m3vpss ]  13320: SELECT   : Create Done !!!
     [m3vpss ]  13320: DISPLAY: Create in progress !!!
     [m3vpss ]  13321: DISPLAY: Create Done !!!
     [m3vpss ]  13321: DISPLAY: Create in progress !!!
     [m3vpss ]  13322: DISPLAY: Create Done !!!
     [m3vpss ]  13323: DISPLAY: Start in progress !!!
     [m3vpss ]  13378: DISPLAY: Start Done !!!
     [m3vpss ]  13379: DISPLAY: HDDAC(BP0) : 35 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) DropCount:0 DispLatency (Min / Max) = ( 7811 / 0 ) !!!
     [m3vpss ]  13379: DISPLAY DRV: HDDAC(BP0) : Q:[2] Display:[2], Repeat:[1], DQ:[0]
     [m3vpss ]  13379: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 36, HDDAC(BP0) 36, DVO2(BP1) 36, SDDAC(SEC1) 36
     [m3vpss ]  13379: SYSTEM  : FREE SPACE : System Heap      = 66384 B, Mbx = 10238 msgs)
     [m3vpss ]  13379: SYSTEM  : FREE SPACE : SR0 Heap         = 8713728 B (8 MB)
     [m3vpss ]  13379: SYSTEM  : FREE SPACE : Frame Buffer     = 137294720 B (130 MB)
     [m3vpss ]  13379: SYSTEM  : FREE SPACE : Bitstream Buffer = 30336896 B (28 MB)
     [m3vpss ]  13380: DISPLAY: Start in progress !!!
     [m3vpss ] TILER_STATS: NUM FREE BUCKETS:  0
     [m3vpss ] TILER_STATS: NUM USED BUCKETS:  1
     [m3vpss ] TILER_STATS: TOTAL FREE AREA:   108003328 (80 %)
     [m3vpss ] TILER_STATS: TOTAL USED AREA:   26148864 (19 %)
     [m3vpss ] TILER_STATS: TOTAL WASTE AREA:  0 (0 %)
     [m3vpss ] TILER_STATS: MAX WIDTH RECT:    16384 x 5948
     [m3vpss ] TILER_STATS: MAX HEIGHT RECT:    16384 x 5948
    New resolution for CH 0 is 1920 x 1080
    Open Channel: 0
     [m3vpss ] TILER_STATS: RES ALLOC COUNT [1080P] :  12
    ---------vdecCrePrm->chMaxReqBufSize;-------2073600-- status=0-
    ---------ipcBufCreateParams.chMaxReqBufSize-------2073600---
     [m3video] DECLINK_H264:HEAPID:0        USED:2368
     [m3video] DECLINK_H264:HEAPID:3        USED:9363456
     [m3video]  15369: DECODE: Creating CH0 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 4000 Kbps ...
     [m3video]  15369: DECODE: CH0: Decoder Create CH done!!!
     [m3vpss ] TILER_STATS: TOTAL FREE AREA:   87588864 (87 %)
     [m3vpss ] TILER_STATS: TOTAL USED AREA:   13074432 (12 %)
     [m3vpss ] TILER_STATS: MAX WIDTH RECT:    32768 x 1952
     [m3vpss ] TILER_STATS: MAX HEIGHT RECT:    32768 x 1952
     [m3vpss ]  13382: SYSTEM  : FREE SPACE : Tiler 8-bit      = 108003328 B (103 MB)  - TILER ON
     [m3vpss ]  13382: SYSTEM  : FREE SPACE : Tiler 16-bit     = 87588864 B (83 MB)  - TILER ON
     [m3vpss ]  13420: DISPLAY: Start Done !!!
     [m3vpss ]  13420: DISPLAY: DVO2(BP1)  : 50 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) DropCount:0 DispLatency (Min / Max) = ( 7811 / 0 ) !!!
     [m3vpss ]  13420: SWMS: Start in Progress !!!
     [m3vpss ]  13420: SWMS: Start Done !!!
     [m3vpss ]  13420: DISPLAY DRV: DVO2(BP1)  : Q:[2] Display:[2], Repeat:[1], DQ:[0]
     [m3vpss ]
     [m3vpss ]  *** Capture Driver Advanced Statistics ***
     [m3vpss ]
     [m3vpss ]  VIP Parser Reset Count : 0
     [m3vpss ]
     [m3vpss ]      |   Total    Even     Odd  Total  Even   Odd  Min /  Max  Min /  Max Dropped Fid Repeat Frame Error Y/C
     [m3vpss ]  CH  |  Fields  Fields  Fields    FPS   FPS   FPS       Width      Height  Fields      Count (Desc Error Y/C)
     [m3vpss ]  000 |     270     270       0     67    67     0 1920 / 1920 1080 / 1080      37          0 0/0 (0/0)
     [m3vpss ]  200 |       1       1       0      0     0     0 65535 /    0 65535 /    0       1          0 0/0 (0/0)
     [m3vpss ]
     [m3vpss ]  VIP Capture Port 0 | DescMissMatch1 = 0, DescMissMatch2 = 0 , DescMissMatch3 = 0
     [m3vpss ]  VIP Capture Port 2 | DescMissMatch1 = 0, DescMissMatch2 = 0 , DescMissMatch3 = 0
     [m3vpss ]
     [m3vpss ]  *** Capture List Manager Advanced Statistics ***
     [m3vpss ]
     [m3vpss ]  List Post Count        : 1129
     [m3vpss ]  List Stall Count       : 0
     [c6xdsp ]
     [c6xdsp ]  *** SCD Statistics ***
     [c6xdsp ]
     [c6xdsp ]  Elasped Time           : 19 secs
     [c6xdsp ]  Total Fields Processed : 0
     [c6xdsp ]  Total Fields FPS       : 0 FPS
     [c6xdsp ]
     [c6xdsp ]
     [c6xdsp ]  CH  | In Recv In Process User Skip Process Skip In Process Time
     [c6xdsp ]  Num | FPS     FPS        FPS       FPS          per frame (msec)
     [c6xdsp ]  ----------------------------------------------------------------
     [m3vpss ]  List Post Time (ms)    : Max = 0, Min = 0, Avg = 0, Total = 0
     [c6xdsp ]
     [m3vpss ]  INTC Timeout Count     : (0, 0) (Min timeout value = 992, 1000)
     [m3vpss ]  Descriptor miss found count : 0
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  VIP and VPDMA registers,
     [m3vpss ]  VIP0 : FIQ_STATUS  : 0x4810551c = 0x00000000
     [m3vpss ]  VIP1 : FIQ_STATUS  : 0x48105a1c = 0x00000000
     [m3vpss ]  VPDMA: LIST_BUSY   : 0x4810d00c = 0x00ac0000
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  17221: CAPTURE: Fields = 232 (fps = 51, CPU Load = 0)
     [m3video]      23249: HDVICP-ID:0
     [m3video] All percentage figures are based off totalElapsedTime
     [m3vpss ]  17221: CAPTURE: Num Resets = 0 (Avg 0 ms per reset)
     [m3video]               totalAcquire2wait :0 %
     [m3video]               totalWait2Isr :145 %
     [m3video]               totalIsr2Done :0 %
     [m3video]               totalWait2Done :145 %
     [m3video]               totalDone2Release :0 %
     [m3video]               totalAcquire2Release :145 %
     [m3video]               totalAcq2acqDelay :78 %
     [m3video]               totalElapsedTime in msec :   10356
     [m3video]               numAccessCnt:     205
     [m3vpss ]  17221: SYSTEM  : FREE SPACE : System Heap      = 66384 B, Mbx = 10237 msgs)
     [m3video]              IVA-FPS :      20
     [m3vpss ]  17222: SYSTEM  : FREE SPACE : SR0 Heap         = 8713728 B (8 MB)
     [m3video]              Average time spent per frame in microsec:   73249
     [m3vpss ]  17222: SYSTEM  : FREE SPACE : Frame Buffer     = 106255232 B (101 MB)
     [m3video]      23250: HDVICP-ID:1
     [m3vpss ]  17222: SYSTEM  : FREE SPACE : Bitstream Buffer = 30336896 B (28 MB)
     [m3video]               totalWait2Isr :0 %
     [m3video]               totalWait2Done :0 %
     [m3video]               totalAcquire2Release :0 %
     [m3video]               totalAcq2acqDelay :0 %
     [m3video]               totalElapsedTime in msec :       0
     [m3video]               numAccessCnt:       0
     [m3video]              IVA-FPS :       0
     [m3video]              Average time spent per frame in microsec:       0
     [m3video]      23250: HDVICP-ID:2
     [m3video]               totalWait2Isr :18 %
     [m3video]               totalWait2Done :18 %
     [m3video]               totalAcquire2Release :18 %
     [m3video]               totalAcq2acqDelay :81 %
     [m3video]               totalElapsedTime in msec :    5913
     [m3video]               numAccessCnt:     121
     [m3video]              IVA-FPS :      24
     [m3video]              Average time spent per frame in microsec:    8796
     [m3video]
     [m3video]  *** ENCODE Statistics ***
     [m3video]
     [m3video]  Elasped Time           : 10 secs
     [m3video]
     [m3video]
     [m3video]  CH  | In Recv In Skip In User  Out Latency
     [m3video]  Num | FPS     FPS     Skip FPS FPS Min / Max
     [m3video]  --------------------------------------------
     [m3video]    0 |      58      38        0  20 255 / 12193
     [m3video]    1 |       0       0        0   0 255 /   0
     [m3video]
     [m3video] Multi Channel Encode Average Submit Batch Size
     [m3video] Max Submit Batch Size : 24
     [m3video] IVAHD_0 Average Batch Size : 1
     [m3video] IVAHD_0 Max achieved Batch Size : 1
     [m3video] IVAHD_1 Average Batch Size : 0
     [m3video] IVAHD_1 Max achieved Batch Size : 0
     [m3video] IVAHD_2 Average Batch Size : 0
     [m3video] IVAHD_2 Max achieved Batch Size : 0
     [m3video]
     [m3video] Multi Channel Encode Batch break Stats
     [m3video] Total Number of Batches created: 203
     [m3video] All numbers are based off total number of Batches created
     [m3video]       Batch breaks due to batch sizeexceeding limit: 100 %
     [m3video]       Batch breaks due to ReqObj Que being empty: 0 %
     [m3video]       Batch breaks due to changed resolution class: 0 %
     [m3video]       Batch breaks due to interlace and progressivecontent mix: 0 %
     [m3video]       Batch breaks due to channel repeat: 0 %
     [m3video]       Batch breaks due to different codec: 0 %
     [m3video] Total Number of Batches created: 0
     [m3video]       Batch breaks due to batch sizeexceeding limit: 0 %
     [m3vpss ]  17224: SYSTEM  : FREE SPACE : Tiler 8-bit      = 108003328 B (103 MB)  - TILER ON
     [m3video]
     [m3video]  *** DECODE Statistics ***
     [m3video]
     [m3video]  Elasped Time           : 5 secs
     [m3video]
     [m3video]
     [m3video]  CH  | In Recv In User  Out
     [m3video]  Num | FPS     Skip FPS FPS
     [m3video]    0 |      23        0  23
     [m3vpss ]  17225: SYSTEM  : FREE SPACE : Tiler 16-bit     = 87588864 B (83 MB)  - TILER ON
     [m3video]    1 |       0        0   0
     [m3video]    2 |       0        0   0
     [m3vpss ]
     [m3vpss ]  *** [NSF0] NSF Statistics ***
     [m3vpss ]
     [m3vpss ]  Elasped Time           : 4 secs
     [m3vpss ]  Total Fields Processed : 226
     [m3vpss ]  Total Fields FPS       : 111 FPS
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  CH  | In Recv In Reject In Process Out User Out Out
     [m3vpss ]  Num | FPS     FPS       FPS        FPS Skip FPS Skip FPS
     [m3video]    3 |       0        0   0
     [m3vpss ]    0 |      58         1         56  56        0        1
     [m3video]    4 |       0        0   0
     [m3vpss ]    1 |       0         0          0   0        0        0
     [m3video]    5 |       0        0   0
     [m3vpss ]
     [m3video]    6 |       0        0   0
     [m3vpss ]
     [m3vpss ]  *** [SWMS0] Mosaic Statistics ***
     [m3vpss ]
     [m3vpss ]  Elasped Time: 3 secs
     [m3vpss ]
     [m3vpss ]  Output Request FPS   : 84 fps (252 frames)
     [m3vpss ]  Output Actual  FPS   : 76 fps (228 frames)
     [m3vpss ]  Output Drop    FPS   : 8 fps (24 frames)
     [m3vpss ]  Output Reject  FPS   : 0 fps (0 frames)
     [m3vpss ]  Scaling Internal     : 14 ms
     [m3vpss ]  Scaling Internal min : 15 ms
     [m3vpss ]  Scaling Internal max : 15 ms
     [m3vpss ]
     [m3vpss ]  Win | Window Repeat Drop Recv Que  FID Invlid Acc Event          Invalid   Que Reject Reject Latency   OutBufCopy InBufCopy
     [m3vpss ]  Num | FPS    FPS    FPS  FPS  FPS  FPS        Count (Max/Min)    CH Frames Frames     Frames Min / Max FPS        FPS
     [m3video]    7 |       0        0   0
     [m3vpss ]    0 |      0     76    0    0    0          0        0 (  0/255)         0          0      0 65535 /   0          0         0
     [m3video]    8 |       0        0   0
     [m3vpss ]
     [m3video]    9 |       0        0   0
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3video]   10 |       0        0   0
     [m3vpss ]    0 |   0 |    0,    0 |  1920 x   1080 |  2048 /  2048 | NON-TILED   |    0,    0 |  1920 x   1080 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |    ON |
     [m3video]   11 |       0        0   0
     [m3vpss ]
     [m3video]   12 |       0        0   0
     [m3vpss ]
     [m3video]   13 |       0        0   0
     [m3vpss ]
     [m3vpss ]  *** [SWMS1] Mosaic Statistics ***
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  Output Actual  FPS   : 75 fps (227 frames)
     [m3vpss ]  Output Drop    FPS   : 8 fps (25 frames)
     [m3vpss ]
     [m3video]   14 |       0        0   0
     [m3vpss ]    0 |      0     75    0    0    0          0        0 (  0/255)         0          0      0 65535 /   0          0         0
     [m3video]   15 |       0        0   0
     [m3vpss ]
     [m3video]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3video] Multi Channel Decode Average Submit Batch Size
     [m3vpss ]
     [m3video] IVAHD_0 Average Batch Size : 0
     [m3vpss ]
     [m3video] IVAHD_0 Max achieved Batch Size : 0
     [m3vpss ]  17243: DISPLAY: HDDAC(BP0) : 59 fps, Latency (Min / Max) = ( 63 / 81 ), Callback Interval (Min / Max) = ( 16 / 17 ) DropCount:0 DispLatency (Min / Max) = ( 49 / 66 ) !!!
     [m3vpss ]  17244: DISPLAY DRV: HDDAC(BP0) : Q:[229] Display:[233], Repeat:[7], DQ:[225]
     [m3video] IVAHD_2 Average Batch Size : 1
     [m3vpss ]  17244: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 238, HDDAC(BP0) 235, DVO2(BP1) 235, SDDAC(SEC1) 476
     [m3video] IVAHD_2 Max achieved Batch Size : 1
     [m3vpss ]  17244: SYSTEM  : FREE SPACE : System Heap      = 66384 B, Mbx = 10238 msgs)
     [m3video]
     [m3video] Multi Channel Decode Batch break Stats
     [m3vpss ]  17244: SYSTEM  : FREE SPACE : SR0 Heap         = 8713728 B (8 MB)
     [m3vpss ]  17244: SYSTEM  : FREE SPACE : Frame Buffer     = 106255232 B (101 MB)
     [m3vpss ]  17244: SYSTEM  : FREE SPACE : Bitstream Buffer = 30336896 B (28 MB)
     [m3video] Total Number of Batches created: 117
     [m3video]
     [m3video]
     [m3video]  27219: LOAD: CPU: 6.3% HWI: 0.5%, SWI:1.1%
     [m3video]
     [m3video]  27219: LOAD: TSK: IPC_OUT_M30         : 0.1%
     [m3video]  27219: LOAD: TSK: IPC_IN_M30          : 0.1%
     [m3video]  27219: LOAD: TSK: IPC_BITS_IN0        : 0.1%
     [m3video]  27219: LOAD: TSK: IPC_BITS_OUT0       : 0.3%
     [m3video]  27219: LOAD: TSK: ENC0                : 1.1%
     [m3video]  27219: LOAD: TSK: DEC0                : 1.7%
     [m3video]  27219: LOAD: TSK: ENC_PROCESS_TSK_0   : 0.4%
     [m3video]  27220: LOAD: TSK: DEC_PROCESS_TSK_2   : 0.2%
     [m3vpss ]  17247: SYSTEM  : FREE SPACE : Tiler 8-bit      = 108003328 B (103 MB)  - TILER ON
     [m3video]  27220: LOAD: TSK: MISC                : 0.7%
     [m3vpss ]  17247: SYSTEM  : FREE SPACE : Tiler 16-bit     = 87588864 B (83 MB)  - TILER ON
     [m3video]
     [m3vpss ]  17247: DISPLAY: DVO2(BP1)  : 59 fps, Latency (Min / Max) = ( 69 / 83 ), Callback Interval (Min / Max) = ( 16 / 17 ) DropCount:0 DispLatency (Min / Max) = ( 49 / 66 ) !!!
     [m3vpss ]  17247: DISPLAY DRV: DVO2(BP1)  : Q:[228] Display:[231], Repeat:[5], DQ:[225]
     [m3vpss ]
     [m3vpss ]  *** IpcFramesOutRTOS Statistics ***
     [m3vpss ]
     [m3vpss ]  Elasped Time           : 3 secs
     [m3vpss ]  Total Fields Processed : 455
     [m3vpss ]  Total Fields FPS       : 151 FPS
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  CH  | In Recv In Process In Skip
     [m3vpss ]    0 |      76         76       0
     [m3vpss ]    1 |      75         75       0
     [m3vpss ]
     [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[0],ChID[0],FirstPTS[0]
     [m3vpss ]
     [m3vpss ]  26258: LOAD: CPU: 15.7% HWI: 2.9%, SWI:1.4%
     [m3vpss ]
     [m3vpss ]  26258: LOAD: TSK: IPC_OUT_M30         : 0.4%
     [m3vpss ]  26258: LOAD: TSK: IPC_FRAMES_OUT0     : 1.2%
     [m3vpss ]  26258: LOAD: TSK: CAPTURE             : 0.4%
     [m3vpss ]  26258: LOAD: TSK: NSF0                : 0.6%
     [c6xdsp ]
     [m3vpss ]  26258: LOAD: TSK: DISPLAY0            : 0.4%
     [c6xdsp ]  26672: LOAD: CPU: 0.6% HWI: 0.1%, SWI:0.0%
     [c6xdsp ]
     [m3vpss ]  26259: LOAD: TSK: DISPLAY1            : 0.4%
     [c6xdsp ]  26672: LOAD: TSK: IPC_FRAMES_IN0      : 0.1%
     [m3vpss ]  26259: LOAD: TSK: DUP0                : 0.2%
     [c6xdsp ]  26672: LOAD: TSK: ALG0                : 0.1%
     [m3vpss ]  26259: LOAD: TSK: DUP1                : 0.2%
     [c6xdsp ]  26672: LOAD: TSK: MISC                : 0.3%
     [m3vpss ]  26259: LOAD: TSK: SWMS0               : 2.4%
     [c6xdsp ]
     [m3vpss ]  26259: LOAD: TSK: SWMS1               : 2.2%
     [m3vpss ]  26259: LOAD: TSK: MERGE0              : 0.1%
     [m3vpss ]  26259: LOAD: TSK: MERGE1              : 0.3%
     [m3vpss ]  26259: LOAD: TSK: SELECT0             : 0.2%
     [m3vpss ]  26259: LOAD: TSK: MISC                : 2.4%
    ***********osdTotalBufSize=13824******************
     [m3vpss ]
    ***********osdTotalBufSize=262656******************
     Main Menu
     1: TEST VCAP API
     2: TEST VENC API
     3: TEST VDEC API
     4: TEST VDIS API
     5: TEST OSD API
     e: Exit
     Enter Choice: ^C
    root@HDMTerm:/opt/hdmeeting20/bin# reboot
    Broadcast message from root@HDMTerm (pts/0) (Thu Mar  6 07:25:17 2014):
    The system is going down for reboot NOW!
    http://e2e.ti.com/cfs-file.ashx/__key/communityserver-discussions-components-files/717/0753.VID_5F00_CH00.7z
  • Can you indicate what you are referring to as flickering. The encoded stream doesn't show any flicker. Only all frames are encoded as I-frames mostly due to wrong configuration from your application.The encoder link is dropping some frames because output buffers are not available
  • now i change the QP value that will not flicker,but around of the image or the words have some mosaics when i use the big screen to display,so what is wrong with that ?
    the following is my enc parameter configure
    pLinkChPrm = &encPrm.chCreateParams[i];
    pLinkDynPrm = &pLinkChPrm->defaultDynamicParams;
    pChPrm = &gVencModuleContext.vencConfig.encChannelParams[i];
    pDynPrm = &pChPrm->dynamicParam;
    pLinkChPrm->format = IVIDEO_H264HP;
    pLinkChPrm->profile = VENC_CHN_HIGH_PROFILE;
    pLinkChPrm->dataLayout = IVIDEO_FIELD_SEPARATED;
    pLinkChPrm->fieldMergeEncodeEnable = FALSE;
    pLinkChPrm->enableAnalyticinfo = pChPrm->enableAnalyticinfo;
    pLinkChPrm->enableWaterMarking = pChPrm->enableWaterMarking;
    pLinkChPrm->maxBitRate = pChPrm->maxBitRate;
    pLinkChPrm->encodingPreset = pChPrm->encodingPreset;
    pLinkChPrm->rateControlPreset = IVIDEO_LOW_DELAY;
    pLinkChPrm->enableSVCExtensionFlag = pChPrm->enableSVCExtensionFlag;
    pLinkChPrm->numTemporalLayer = pChPrm->numTemporalLayer;
    pLinkDynPrm->targetFrameRate = pDynPrm->frameRate;
    pLinkDynPrm->intraFrameInterval = pDynPrm->intraFrameInterval;
    pLinkDynPrm->targetBitRate = pDynPrm->targetBitRate;
    pLinkDynPrm->interFrameInterval = 1;
    pLinkDynPrm->mvAccuracy = IVIDENC2_MOTIONVECTOR_QUARTERPEL;
    pLinkDynPrm->inputFrameRate = pDynPrm->inputFrameRate;
    pLinkDynPrm->rcAlg = pDynPrm->rcAlg;
    pLinkDynPrm->qpMin = pDynPrm->qpMin;
    pLinkDynPrm->qpMax = pDynPrm->qpMax;
    pLinkDynPrm->qpInit = pDynPrm->qpInit;
    pLinkDynPrm->vbrDuration = pDynPrm->vbrDuration;
    pLinkDynPrm->vbrSensitivity = pDynPrm->vbrSensitivity;
    tomorrow the enc stream is error ,i am not set the GOP ,the following is right
    http://e2e.ti.com/cfs-file.ashx/__key/communityserver-discussions-components-files/717/2117.VID_5F00_CH00.7z
  • You are setting targetBitrate to 2 mbps for a 1080P60 stream.Reasonable bitrate is around 10 mbps.
  • but if in my environment the network can not be to 10mbps,so whether the image quality can not be improved?
    or some other ways can improved the image quality?
    i also do some test with 10Mbps, around of the image or the words also have some mosaics flicker,just the effect is a little better.
  • You can check this post http://e2e.ti.com/support/dsp/davinci_digital_media_processors/f/717/p/307578/1071547.aspx#1071547
    You can also limit qpMax value to small number like 10 and check.
    Print the static and dynamic params and attach the encoded stream at 10 mbps to confirm you are not making any mistake in encoder configuration.
  • hi Badri,i see the post you say,but the following about the enable 'Region of Interest Encoding',
    i can not understand ,so how can i do to enable that?
    4.If your application is video-conferencing or any other in which you are interested only in particular part of video content, then enable 'Region of Interest Encoding' . The over-head in a system would be to detect objects(face) and pass them to encoder to encode with better quality.
    tks
