Other Parts Discussed in Thread: AM3352
hi:
all,i have designed GPMC moduled connected with FPGA.but i have some problems about configuration wtih GPMC_CONFIG1---GPMC_CONFIG7,and i designed as follow:
1)FPGA used for 16bit write and read;
2) addr pins :GPMC_A11 --- GPMC_A1(highest 11 bit),GPMC_AD15 --- GPMC_AD0(lowest 16bit);
3) data pins:GPMC_AD15 --- GPMC_AD0;in other words GPMC is in Address and data multiplexed attached device.
4) FPGA is connected through GPMC_CS1;
5) my paltfrom is AM3352,used startware kit. not linux system.
I want to write/read with in sync mode.how should i config GPMC_CONFIG1---GPMC_CONFIG7?
I tryed as follow:
1) pins mux cpnfig:
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_A(1) ) =
(0 << CONTROL_CONF_GPMC_A1_CONF_GPMC_A1_MMODE_SHIFT) |
(0 << CONTROL_CONF_GPMC_A1_CONF_GPMC_A1_PUDEN_SHIFT) |
(1 << CONTROL_CONF_GPMC_A1_CONF_GPMC_A1_PUTYPESEL) |
(0 << CONTROL_CONF_GPMC_A1_CONF_GPMC_A1_RXACTIVE_SHIFT) |
(0 << CONTROL_CONF_GPMC_A1_CONF_GPMC_A1_SLEWCTRL_SHIFT);
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_A(2) ) =
(0 << CONTROL_CONF_GPMC_A2_CONF_GPMC_A2_MMODE_SHIFT) |
(0 << CONTROL_CONF_GPMC_A2_CONF_GPMC_A2_PUDEN_SHIFT) |
(1 << CONTROL_CONF_GPMC_A2_CONF_GPMC_A2_PUTYPESEL) |
(0 << CONTROL_CONF_GPMC_A2_CONF_GPMC_A2_RXACTIVE_SHIFT) |
(0 << CONTROL_CONF_GPMC_A2_CONF_GPMC_A2_SLEWCTRL_SHIFT);
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_A(3) ) =
(0 << CONTROL_CONF_GPMC_A3_CONF_GPMC_A3_MMODE_SHIFT) |
(0 << CONTROL_CONF_GPMC_A3_CONF_GPMC_A3_PUDEN_SHIFT) |
(1 << CONTROL_CONF_GPMC_A3_CONF_GPMC_A3_PUTYPESEL) |
(0 << CONTROL_CONF_GPMC_A3_CONF_GPMC_A3_RXACTIVE_SHIFT) |
(0 << CONTROL_CONF_GPMC_A3_CONF_GPMC_A3_SLEWCTRL_SHIFT);
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_A(4) ) =
(0 << CONTROL_CONF_GPMC_A4_CONF_GPMC_A4_MMODE_SHIFT) |
(0 << CONTROL_CONF_GPMC_A4_CONF_GPMC_A4_PUDEN_SHIFT) |
(1 << CONTROL_CONF_GPMC_A4_CONF_GPMC_A4_PUTYPESEL) |
(0 << CONTROL_CONF_GPMC_A4_CONF_GPMC_A4_RXACTIVE_SHIFT) |
(0 << CONTROL_CONF_GPMC_A4_CONF_GPMC_A4_SLEWCTRL_SHIFT);
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_A(5) ) =
(0 << CONTROL_CONF_GPMC_A5_CONF_GPMC_A5_MMODE_SHIFT) |
(0 << CONTROL_CONF_GPMC_A5_CONF_GPMC_A5_PUDEN_SHIFT) |
(1 << CONTROL_CONF_GPMC_A5_CONF_GPMC_A5_PUTYPESEL) |
(0 << CONTROL_CONF_GPMC_A5_CONF_GPMC_A5_RXACTIVE_SHIFT) |
(0 << CONTROL_CONF_GPMC_A5_CONF_GPMC_A5_SLEWCTRL_SHIFT);
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_A(6) ) =
(0 << CONTROL_CONF_GPMC_A6_CONF_GPMC_A6_MMODE_SHIFT) |
(0 << CONTROL_CONF_GPMC_A6_CONF_GPMC_A6_PUDEN_SHIFT) |
(1 << CONTROL_CONF_GPMC_A6_CONF_GPMC_A6_PUTYPESEL) |
(0 << CONTROL_CONF_GPMC_A6_CONF_GPMC_A6_RXACTIVE_SHIFT) |
(0 << CONTROL_CONF_GPMC_A6_CONF_GPMC_A6_SLEWCTRL_SHIFT);
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_A(7) ) =
(0 << CONTROL_CONF_GPMC_A7_CONF_GPMC_A7_MMODE_SHIFT) |
(0 << CONTROL_CONF_GPMC_A7_CONF_GPMC_A7_PUDEN_SHIFT) |
(1 << CONTROL_CONF_GPMC_A7_CONF_GPMC_A7_PUTYPESEL) |
(0 << CONTROL_CONF_GPMC_A7_CONF_GPMC_A7_RXACTIVE_SHIFT) |
(0 << CONTROL_CONF_GPMC_A7_CONF_GPMC_A7_SLEWCTRL_SHIFT);
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_A(8) ) =
(0 << CONTROL_CONF_GPMC_A8_CONF_GPMC_A8_MMODE_SHIFT) |
(0 << CONTROL_CONF_GPMC_A8_CONF_GPMC_A8_PUDEN_SHIFT) |
(1 << CONTROL_CONF_GPMC_A8_CONF_GPMC_A8_PUTYPESEL) |
(0 << CONTROL_CONF_GPMC_A8_CONF_GPMC_A8_RXACTIVE_SHIFT) |
(0 << CONTROL_CONF_GPMC_A8_CONF_GPMC_A8_SLEWCTRL_SHIFT);
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_A(9) ) =
(0 << CONTROL_CONF_GPMC_A9_CONF_GPMC_A9_MMODE_SHIFT) |
(0 << CONTROL_CONF_GPMC_A9_CONF_GPMC_A9_PUDEN_SHIFT) |
(1 << CONTROL_CONF_GPMC_A9_CONF_GPMC_A9_PUTYPESEL) |
(0 << CONTROL_CONF_GPMC_A9_CONF_GPMC_A9_RXACTIVE_SHIFT) |
(0 << CONTROL_CONF_GPMC_A9_CONF_GPMC_A9_SLEWCTRL_SHIFT);
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_A(10) ) =
(0 << CONTROL_CONF_GPMC_A10_CONF_GPMC_A10_MMODE_SHIFT) |
(0 << CONTROL_CONF_GPMC_A10_CONF_GPMC_A10_PUDEN_SHIFT) |
(1 << CONTROL_CONF_GPMC_A10_CONF_GPMC_A10_PUTYPESEL) |
(0 << CONTROL_CONF_GPMC_A10_CONF_GPMC_A10_RXACTIVE_SHIFT) |
(0 << CONTROL_CONF_GPMC_A10_CONF_GPMC_A10_SLEWCTRL_SHIFT);
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_A(11) ) =
(0 << CONTROL_CONF_GPMC_A11_CONF_GPMC_A11_MMODE_SHIFT) |
(0 << CONTROL_CONF_GPMC_A11_CONF_GPMC_A11_PUDEN_SHIFT) |
(1 << CONTROL_CONF_GPMC_A11_CONF_GPMC_A11_PUTYPESEL) |
(0 << CONTROL_CONF_GPMC_A11_CONF_GPMC_A11_RXACTIVE_SHIFT) |
(0 << CONTROL_CONF_GPMC_A11_CONF_GPMC_A11_SLEWCTRL_SHIFT);
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_AD(0) ) = 0x30;
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_AD(1) ) = 0x30;
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_AD(2) ) = 0x30;
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_AD(3) ) = 0x30;
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_AD(4) ) = 0x30;
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_AD(5) ) = 0x30;
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_AD(6) ) = 0x30;
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_AD(7) ) = 0x30;
//GPMC_AD8~GPMC_AD15
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_AD(8) ) = 0x30;
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_AD(9) ) = 0x30;
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_AD(10) ) = 0x30;
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_AD(11) ) = 0x30;
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_AD(12) ) = 0x30;
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_AD(13) ) = 0x30;
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_AD(14) ) = 0x30;
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_AD(15) ) = 0x30;
// CONF_GPMC_CS1N for FPGA Chip-Select
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_CSN(1) ) =
(0 << CONTROL_CONF_GPMC_CSN1_CONF_GPMC_CSN1_MMODE_SHIFT) |
(0 << CONTROL_CONF_GPMC_CSN1_CONF_GPMC_CSN1_PUDEN_SHIFT) |
(1 << CONTROL_CONF_GPMC_CSN1_CONF_GPMC_CSN1_PUTYPESEL_SHIFT) |
(0 << CONTROL_CONF_GPMC_CSN1_CONF_GPMC_CSN1_RXACTIVE_SHIFT) |
(0 << CONTROL_CONF_GPMC_CSN1_CONF_GPMC_CSN1_SLEWCTRL_SHIFT);
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_CSN(2) ) =
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_CSN(3) ) =
(7 << CONTROL_CONF_GPMC_CSN1_CONF_GPMC_CSN1_MMODE_SHIFT) |
// BE1n, BE0n, CS2n, OEn, WEn
// CONF_GPMC_WEN
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_WEN ) =
(0 << CONTROL_CONF_GPMC_WEN_CONF_GPMC_WEN_MMODE_SHIFT) |
(0 << CONTROL_CONF_GPMC_WEN_CONF_GPMC_WEN_PUDEN_SHIFT) |
(1 << CONTROL_CONF_GPMC_WEN_CONF_GPMC_WEN_PUTYPESEL_SHIFT) |
(0 << CONTROL_CONF_GPMC_WEN_CONF_GPMC_WEN_RXACTIVE_SHIFT) |
(0 << CONTROL_CONF_GPMC_WEN_CONF_GPMC_WEN_SLEWCTRL_SHIFT);
// CONF_GPMC_OEN_REN
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_OEN_REN ) =
(0 << CONTROL_CONF_GPMC_OEN_REN_CONF_GPMC_OEN_REN_MMODE_SHIFT) |
(0 << CONTROL_CONF_GPMC_OEN_REN_CONF_GPMC_OEN_REN_PUDEN_SHIFT) |
(1 << CONTROL_CONF_GPMC_OEN_REN_CONF_GPMC_OEN_REN_PUTYPESEL_SHIFT) |
(0 << CONTROL_CONF_GPMC_OEN_REN_CONF_GPMC_OEN_REN_RXACTIVE_SHIFT) |
(0 << CONTROL_CONF_GPMC_OEN_REN_CONF_GPMC_OEN_REN_SLEWCTRL_SHIFT);
// CONF_GPMC_BE0N_CLE
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_BE0N_CLE ) =
(0 << CONTROL_CONF_GPMC_BE0N_CLE_CONF_GPMC_BE0N_CLE_MMODE) |
(0 << CONTROL_CONF_GPMC_BE0N_CLE_CONF_GPMC_BE0N_CLE_PUDEN_SHIFT) |
(1 << CONTROL_CONF_GPMC_BE0N_CLE_CONF_GPMC_BE0N_CLE_PUTYPESEL_SHIFT)|
(0 << CONTROL_CONF_GPMC_BE0N_CLE_CONF_GPMC_BE0N_CLE_RXACTIVE_SHIFT) |
(0 << CONTROL_CONF_GPMC_BE0N_CLE_CONF_GPMC_BE0N_CLE_SLEWCTRL_SHIFT);
// CONF_GPMC_BE1N
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_BE1N ) =
(0 << CONTROL_CONF_GPMC_BE1N_CONF_GPMC_BE1N_MMODE_SHIFT) |
(0 << CONTROL_CONF_GPMC_BE1N_CONF_GPMC_BE1N_PUDEN_SHIFT) |
(1 << CONTROL_CONF_GPMC_BE1N_CONF_GPMC_BE1N_PUTYPESEL_SHIFT)|
(0 << CONTROL_CONF_GPMC_BE1N_CONF_GPMC_BE1N_RXACTIVE_SHIFT) |
(0 << CONTROL_CONF_GPMC_BE1N_CONF_GPMC_BE1N_SLEWCTRL_SHIFT);
// CONF_GPMC_CLK
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_CLK ) =
(0 << CONTROL_CONF_GPMC_CLK_CONF_GPMC_CLK_MMODE_SHIFT) |
(1 << CONTROL_CONF_GPMC_CLK_CONF_GPMC_CLK_PUDEN_SHIFT) |
(1 << CONTROL_CONF_GPMC_CLK_CONF_GPMC_CLK_PUTYPESEL_SHIFT)|
(1 << CONTROL_CONF_GPMC_CLK_CONF_GPMC_CLK_RXACTIVE_SHIFT) |
(0 << CONTROL_CONF_GPMC_CLK_CONF_GPMC_CLK_SLEWCTRL_SHIFT);
2) GPMC_CONFIG1---GPMC_CONFIG7:
HWREG(GPMC_CONFIG_REGS + GPMC_CONFIG7( FPGA_SRAM_CHIP_SELECT ) )= 0;
//GPMC_CONFIG1_i
HWREG(GPMC_CONFIG_REGS + GPMC_CONFIG1(FPGA_SRAM_CHIP_SELECT) ) = 0x28001200;
//GPMC_CONFIG2_i
HWREG(GPMC_CONFIG_REGS + GPMC_CONFIG2(FPGA_SRAM_CHIP_SELECT) ) = 0x00060700;
//GPMC_CONFIG3_i Chip-select signal timing parameter configuration
HWREG(GPMC_CONFIG_REGS + GPMC_CONFIG3(FPGA_SRAM_CHIP_SELECT) )= 0x11010100;
//GPMC_CONFIG4_i WE# and OE# signal timing parameter configuration
HWREG(GPMC_CONFIG_REGS + GPMC_CONFIG4(FPGA_SRAM_CHIP_SELECT) )= 0x0602e722;
//GPMC_CONFIG5_i RdAccess Time and Cycle Time parameter configuration
HWREG(GPMC_CONFIG_REGS + GPMC_CONFIG5(FPGA_SRAM_CHIP_SELECT) )= 0x01060607;
//GPMC_CONFIG6_i WrAccess, WrDataOnADmuxBus, Cycle2Cycle, and BusTurnAround parameter configuration
HWREG(GPMC_CONFIG_REGS + GPMC_CONFIG6(FPGA_SRAM_CHIP_SELECT) )= 0x030301c1;
//GPMC_CONFIG7_i Chip-Selectaddress mapping configuration
(0x0 << GPMC_CONFIG7_1_BASEADDRESS_SHIFT) |
(1 << GPMC_CONFIG7_1_CSVALID_SHIFT)|
(0x00 << GPMC_CONFIG7_1_MASKADDRESS_SHIFT);
But GPMC_CLK is not output!
Anyone could give some help? BASEADDR IS WRONG ? or have some pin mux wrong?
Thanks.
