RDK 4.1 encoder callback issue
We have a customize board based on DM814x and we are using RDK 4.0 on it.
We are giving
    1] 8ch capture + encode + dump (mp4 + JPEG)&
    2] 8ch capture + display support.
Now we are migrating on RDK 4.1 because of B Frame support.
After migrating, I found a major issue, that sometimes only encoder is not giving a callback for encoded frame.
Same case is working perfectly with RDK 4.0.
For reference, please find attached log file.
etc/passwd found in /etc/passwd.
/etc/shadow found in /etc/shadow.
mkdir: can't create directory '/thirdeye_temp/': File exists
chmod: /dev/mag: No such file or directory
chmod: /dev/mma: No such file or directory
*** Bootargs Validated for mem param ***
*** Bootargs Validated for notifyk.vpssm3 params ***
Kernel bootargs validated
amixer: Cannot find the given element from control default
 [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
 [m3video] Remote Debug Shared Memory @ 0xbff10820
 [m3vpss ] Remote Debug Shared Memory @ 0xbff21040
 Setting DMM priority for [DUCATI  ] to [0] ( 0x4e000624 = 0x08000000 )
 Setting DMM priority for [HDVICP0 ] to [2] ( 0x4e000634 = 0x0000000a )
 *** TVP5158 probe : START ***
 TI VS EVM : TVP5158 device address : 0x58, 0x5a, 0x5c, 0x5e
 TI DVR    : TVP5158 device address : 0x58, 0x59, 0x5a, 0x5b
 Device found     : I2C (0xXX): 0x08 = 0x51
                    I2C (0xXX): 0x09 = 0x58
 Device NOT found : I2C (0xXX): Read ERROR !!! (reg[0x08], count = 2)
 I2C (0x5c): 0x08 = 0x51
 I2C (0x5c): 0x09 = 0x58
 I2C (0x5d): 0x08 = 0x51
 I2C (0x5d): 0x09 = 0x58
 *** TVP5158 probe : END ***
/opt/dvr_rdk/ti814x
Attached to slave procId 2.
Loaded file ../firmware/dvr_rdk_fw_m3vpss_1024M_384M.xem3 on slave procId 2.
Started slave procId 2.
After Ipc_loadcallback status [0x00000000]
 [m3vpss ]      ISS Freq  : 480 MHz
 [m3vpss ] ***** VPSS Firmware build time 18:33:49 Mar  8 2014  EDG gcc 3.0 mode
 [m3vpss ] ***** SYSTEM  : Frequency <ORG> - 200000000, <NEW> - 240000000
 [m3vpss ] notify_attach  rtnVal  0
 [m3vpss ] initProxyServer  rtnVal  0
 [m3vpss ]
 [m3vpss ]  *** UTILS: CPU KHz = 480000 Khz ***
 [m3vpss ]
 [m3vpss ]  44: SYSTEM: IPC init in progress !!!
 [m3vpss ]  44: SYSTEM: Attaching to [HOST] ...
 [m3vpss ]  46: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
After Ipc_startcallback status [0x00000000]
Attached to slave procId 1.
Loaded file ../firmware/dvr_rdk_fw_m3video_1024M_384M.xem3 on slave procId 1.
Started slave procId 1.
 [m3video]      ISS Freq  : 480 MHz
 [m3video] ***** VIDEO Firmware build time 18:34:45 Mar  8 2014  EDG gcc 3.0 mode
 [m3video] ***** SYSTEM  : Frequency <ORG> - 200000000, <NEW> - 240000000
 [m3video]
 [m3video]  *** UTILS: CPU KHz = 480000 Khz ***
 [m3video]
 [m3video]  969: SYSTEM: IPC init in progress !!!
 [m3video]  969: SYSTEM: Attaching to [HOST] ...
 [m3video]  972: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
Attached to slave procId 0.
 [m3vpss ]  1045: SYSTEM: Attaching to [DSP] ...
Loaded file ../firmware/dvr_rdk_fw_c6xdsp_1024M_384M.xe674 on slave procId 0.
Started slave procId 0.
 [c6xdsp ]      DSP Freq  : 750 MHz
 [m3video]  1311: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
 [m3vpss ]  1313: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
 [c6xdsp ] ***** VIDEO Firmware build time 18:32:39 Mar  8 2014  EDG gcc 3.0 mode
 [m3video]  1315: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
 [m3vpss ]  1315: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
 [c6xdsp ] ***** SYSTEM  : Frequency <ORG> - 500000000, <NEW> - 750000000
 [m3video]  1315: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_1] ...
 [m3vpss ]  1315: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_2] ...
 [c6xdsp ]
 [m3video]  1315: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
 [m3vpss ]  1315: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
 [c6xdsp ]  *** UTILS: CPU KHz = 750000 Khz ***
 [m3video]  1316: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
 [m3vpss ]  1316: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
 [c6xdsp ]
 [m3video]  1318: SYSTEM: Notify register to [HOST] line 0, event 15 ...
 [m3vpss ]  1317: SYSTEM: Notify register to [HOST] line 0, event 15 ...
 [c6xdsp ]  1: SYSTEM: IPC init in progress !!!
 [m3video]  1318: SYSTEM: Notify register to [DSP] line 0, event 15 ...
 [m3vpss ]  1318: SYSTEM: Notify register to [DSP] line 0, event 15 ...
 [c6xdsp ]  1: SYSTEM: Attaching to [HOST] ...
 [m3video]  1318: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
 [m3vpss ]  1318: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
 [c6xdsp ]  4: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
 [m3vpss ]  1318: SYSTEM: IPC init DONE !!!
 [c6xdsp ]  7: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
 [c6xdsp ]  9: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
 [c6xdsp ]  9: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_0] ...
 [m3video]  1318: SYSTEM: IPC init DONE !!!
 [c6xdsp ]  9: SYSTEM: Creating MsgQ [DSP_MSGQ] ...
 [c6xdsp ]  10: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ...
 [c6xdsp ]  10: SYSTEM: Notify register to [HOST] line 0, event 15 ...
 [c6xdsp ]  10: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
 [c6xdsp ]  10: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
 [c6xdsp ]  10: SYSTEM: IPC init DONE !!!
 [c6xdsp ]  12: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x07000000 (112 MB)
 [c6xdsp ]  12: MEM: Shared Region 1: Base = 0x98000000, Length = 0x04f00000 (79 MB)
 [c6xdsp ]  12: SYSTEM  : RpeServer_init() done... Ret Val 0!!!
 [c6xdsp ]  17: SYSTEM: Creating ListMP [DSP_IPC_OUT_19] in region 0 ...
 [m3video]  1325: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x07000000 (112 MB)
 [m3vpss ]  1325: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x07000000 (112 MB)
 [c6xdsp ]  17: SYSTEM: Creating ListMP [DSP_IPC_IN_19] in region 0 ...
 [m3video]  1326: MEM: Shared Region 1: Base = 0x98000000, Length = 0x04f00000 (79 MB)
 [m3vpss ]  1326: MEM: Shared Region 1: Base = 0x98000000, Length = 0x04f00000 (79 MB)
 [c6xdsp ]  17: SYSTEM: ListElem Shared Addr = 0xbf173e00
 [m3video]  1329: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
 [c6xdsp ]  18: SYSTEM: Creating ListMP [DSP_IPC_OUT_20] in region 0 ...
 [c6xdsp ]  18: SYSTEM: Creating ListMP [DSP_IPC_IN_20] in region 0 ...
 [c6xdsp ]  18: SYSTEM: ListElem Shared Addr = 0xbf199600
 [c6xdsp ]  19: SYSTEM: Creating ListMP [DSP_IPC_OUT_21] in region 0 ...
 [c6xdsp ]  19: SYSTEM: Creating ListMP [DSP_IPC_IN_21] in region 0 ...
 [m3video]  1329: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
 [c6xdsp ]  19: SYSTEM: ListElem Shared Addr = 0xbf1bee00
 [c6xdsp ]  20: SYSTEM: Creating ListMP [DSP_IPC_OUT_24] in region 0 ...
 [c6xdsp ]  20: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ...
 [c6xdsp ]  20: SYSTEM: ListElem Shared Addr = 0xbf1e4600
 [c6xdsp ]  21: SYSTEM: Creating ListMP [DSP_IPC_OUT_25] in region 0 ...
 [c6xdsp ]  21: SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ...
 [c6xdsp ]  21: SYSTEM: ListElem Shared Addr = 0xbf203080
 [m3video]  1329: SYSTEM: ListElem Shared Addr = 0xbf221b00
 [c6xdsp ] !!WARNING.Resource already registered:2
 [c6xdsp ]  20: SYSTEM  : Initializing Links !!!
 [c6xdsp ]  35: SYSTEM  : Initializing Links ... DONE !!!
 [m3video]  1332: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
 [m3vpss ] !!!!!!!!!!! Initiating pinmux for i2c1: Vps_platformTI814xSetPinMux 879
 [m3video]  1332: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
 [m3vpss ] === I2C1/3 Interface Clk is active ===
 [m3video]  1332: SYSTEM: ListElem Shared Addr = 0xbf225000
 [m3vpss ]  1350: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
 [m3video]  1340: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_19] in region 0 ...
 [m3vpss ]  1351: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
 [m3video]  1340: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_19] in region 0 ...
 [m3vpss ]  1351: SYSTEM: ListElem Shared Addr = 0xbf298d00
 [m3video]  1340: SYSTEM: ListElem Shared Addr = 0xbf228500
 [m3vpss ]  1354: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
 [m3video]  1343: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_20] in region 0 ...
 [m3vpss ]  1354: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
 [m3video]  1344: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_20] in region 0 ...
 [m3vpss ]  1354: SYSTEM: ListElem Shared Addr = 0xbf29c200
 [m3video]  1344: SYSTEM: ListElem Shared Addr = 0xbf24dd00
 [m3vpss ]  1372: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_19] in region 0 ...
 [m3video]  1347: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_21] in region 0 ...
 [m3vpss ]  1372: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_19] in region 0 ...
 [m3video]  1347: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_21] in region 0 ...
 [m3vpss ]  1373: SYSTEM: ListElem Shared Addr = 0xbf2dcc00
 [m3video]  1347: SYSTEM: ListElem Shared Addr = 0xbf273500
 [m3vpss ]  1376: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_20] in region 0 ...
 [m3video]  1364: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_24] in region 0 ...
 [m3vpss ]  1376: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_20] in region 0 ...
 [m3video]  1365: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_24] in region 0 ...
 [m3vpss ]  1376: SYSTEM: ListElem Shared Addr = 0xbf302400
 [m3video]  1365: SYSTEM: ListElem Shared Addr = 0xbf29f700
 [m3vpss ]  1379: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_21] in region 0 ...
 [m3video]  1368: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_25] in region 0 ...
 [m3vpss ]  1379: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_21] in region 0 ...
 [m3video]  1368: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_25] in region 0 ...
 [m3vpss ]  1380: SYSTEM: ListElem Shared Addr = 0xbf327c00
 [m3video]  1368: SYSTEM: ListElem Shared Addr = 0xbf2be180
 [m3vpss ]      HDVPSS Freq  : 220 MHz
 [m3video]  1370: HDVICP: Doing PRCM for IVAHD[0] ...
 [m3video]  1371: HDVICP: PRCM for IVAHD[0] ... DONE.
 [m3video]  1372: UTILS: DMA: HWI Create for INT62 !!!
 [m3vpss ]  1599: UTILS: DMA: HWI Create for INT63 !!!
 [m3video]  1382: VCOP BOOST BIT is Set
 [m3vpss ]  1600: SYSTEM  : Initializing Links !!!
 [m3video]  1384: SYSTEM  : Initializing Links !!!
 [m3video]  1444: SYSTEM  : Initializing Links ... DONE !!!
 [m3vpss ] Received character 's'
 [m3vpss ]  1751: SYSTEM  : Initializing Links ... DONE !!!
 [m3vpss ]  1751: SYSTEM  : Set Static L3 pressure for HDVPSS as High
 [m3video] Received character 's'
 [c6xdsp ] Received character 's'
/opt/dvr_rdk/ti814x
 ORG 0x46c00524: 0
 NEW 0x46c00524: 2
httpd: apr_sockaddr_info_get() failed for dm814x
httpd: Could not reliably determine the server's fully qualified domain name, using 127.0.0.1 for ServerName
========== COMPLETION OF SERVICE START ==========
sh: /sys/devices/virtual/sensor/mma/transient_detection0/enable: No such file or directory
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project http://arago-project.org dm814x ttyO0
Arago 2012.10 dm814x ttyO0
dm814x login: mv: can't rename '/media/mmcblk0/3rdeye/storage/event_data.json': No such file or directory
        r 0: SYSTEM: IPC init in progress !!!
        48: SYSTEM: CPU [DSP] syslink proc ID is [0] !!!
                        48: SYSTEM: CPU [VIDEO-M3] syslink proc ID is [1] !!!
        48: SYSTEM: CPU [VPSS-M3] syslink proc ID is [2] !!!
        48: SYSTEM: CPU [HOST] syslink proc ID is [3] !!!
             49: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_3] ...
        55: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
        57: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
        58: SYSTEM: Opening MsgQ [DSP_MSGQ] ...
                              59: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
        70: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
        73: SYSTEM: Notify register to [DSP] line 0, event 15 ...
          75: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
        75: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
        76: SYSTEM: IPC init DONE !!!
        83: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
                                                             85: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
        86: SYSTEM: ListElem Shared Addr = 0x40b52680
        87: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
                                                              89: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
        90: SYSTEM: ListElem Shared Addr = 0x40b89480
        95: SYSTEM: Creating ListMP [HOST_IPC_OUT_19] in region 0 ...
                                                               97: SYSTEM: Creating ListMP [HOST_IPC_IN_19] in region 0 ...
        98: SYSTEM: ListElem Shared Addr = 0x40bc0280
  99: SYSTEM: Creating ListMP [HOST_IPC_OUT_20] in region 0 ...
        101: SYSTEM: Creating ListMP [HOST_IPC_IN_20] in region 0 ...
        102: SYSTEM: ListElem Shared Addr = 0x40c03580
     103: SYSTEM: Creating ListMP [HOST_IPC_OUT_21] in region 0 ...
        105: SYSTEM: Creating ListMP [HOST_IPC_IN_21] in region 0 ...
        106: SYSTEM: ListElem Shared Addr = 0x40c46880
        oot
Password:  [host] HDMI Ctrl :Initializing
[HOST]
ThreadName:Vdis_hdmiControlThread_0,ThreadID:697
 [host] HDMI Ctrl :Initialized
 [host] HDMI Ctrl :Sink Connected
 976: MCFW  : CPU Revision [ES2.1] !!!
 VCAP: DEVICE-0 (0x5c): Chip ID 0x5158, Rev 0x0002, Firmware 0x0000 !!!
 VCAP: DEVICE-0 (0x5c):  NO Video Detected !!!
 VCAP: DEVICE-1 (0x5d): Chip ID 0x5158, Rev 0x0002, Firmware 0x0000 !!!
 VCAP: DEVICE-1 (0x5d): Detected video (720x240@59Hz, 1) !!!
 TVP5158: 0x5c: Downloading patch ...
[HOST]
ThreadName:SystemLink_tskMain_3000003f,ThreadID:696
 TVP5158: 0x5c: Downloading patch ... DONE !!!
 TVP5158: 0x5c: 5158:0002:0302
 TVP5158: 0x5d: Downloading patch ...
root@dm814x:~#
root@dm814x:~#
root@dm814x:~#  TVP5158: 0x5d: Downloading patch ... DONE !!!
 TVP5158: 0x5d: 5158:0002:0302
 [m3vpss ]  63883: CAPTURE: Create in progress !!!
 [m3vpss ]  63916: CAPTURE: VIP0 PortA capture mode is [ 8-bit, Pixel-mux Embedded Sync] !!!
root@dm814x:~#  [m3vpss ]  63990: CAPTURE: VIP1 PortA capture mode is [ 8-bit, Pixel-mux Embedded Sync] !!!
 [m3vpss ]  UTILS: DMA: Allocated CH (TCC) = 58 (58)
 [m3vpss ]  UTILS: DMA: 0 of 4: Allocated PaRAM = 58 (0x49004740)
 [m3vpss ]  UTILS: DMA: 1 of 4: Allocated PaRAM = 64 (0x49004800)
 [m3vpss ]  UTILS: DMA: 2 of 4: Allocated PaRAM = 65 (0x49004820)
 [m3vpss ]  UTILS: DMA: 3 of 4: Allocated PaRAM = 66 (0x49004840)
 [m3vpss ] CAPTURE::HEAPID:0    USED:520
 [m3vpss ] CAPTURE::HEAPID:4    USED:31279104
 [m3vpss ]  64064: CAPTURE: Create Done !!!
 [m3vpss ]  64064: NSF: Create in progress !!!
 [m3vpss ] NSF::HEAPID:0        USED:128
 [m3vpss ] NSF::HEAPID:1        USED:14784
 [m3vpss ] NSF::HEAPID:4        USED:12976128
 [m3vpss ]  64136: NSF: Create Done !!!
 [m3vpss ]  64140: DUP:  0: Format: INTERLACED , 704 x 240
 [m3vpss ]  64140: DUP:  1: Format: INTERLACED , 704 x 240
 [m3vpss ]  64140: DUP:  2: Format: INTERLACED , 704 x 240
 [m3vpss ]  64140: DUP:  3: Format: INTERLACED , 704 x 240
 [m3vpss ]  64141: DUP:  4: Format: INTERLACED , 704 x 240
 [m3vpss ]  64141: DUP:  5: Format: INTERLACED , 704 x 240
 [m3vpss ]  64141: DUP:  6: Format: INTERLACED , 704 x 240
 [m3vpss ]  64141: DUP:  7: Format: INTERLACED , 704 x 240
 [m3vpss ]  64142: DUP   : Create Done !!!
 [m3vpss ]  64143: SELECT_0: OUT QUE0: OUT CH0: IN CH0: 704 x 240, pitch = (704, 704) [INTERLACED ] [NON-TILED  ]
 [m3vpss ]  64144: SELECT   : Create Done !!!
 [m3vpss ]  64157: DEI    : Create in progress !!!
 [m3vpss ] DEI: Ch 0, Outformat is PROGRESSIVE
 [m3vpss ]  64173: DEI: OUT0:  0: Format: PROGRESSIVE, 0xbae50c80, 704 x 480, 4 frames
 [m3vpss ]  64175: DEI     : Loading Up-scaling Co-effs
 [m3vpss ]  64175: DEI     : Co-effs Loading ... DONE !!!
 [m3vpss ] DEI:HEAPID:0 USED:64
 [m3vpss ] DEI:HEAPID:1 USED:5040
 [m3vpss ] DEI:HEAPID:4 USED:2872320
 [m3vpss ]  64176: DEI    : Create Done !!!
 [m3vpss ]  64176: DEI    : Create in progress !!!
 [m3vpss ]  64192: DEI: OUT0:  0: Format: PROGRESSIVE, 0xbb10e080, 704 x 480, 4 frames
 [m3vpss ] DEI: Ch 1, Outformat is PROGRESSIVE
 [m3vpss ]  64206: DEI: OUT0:  1: Format: PROGRESSIVE, 0xbb3a2080, 704 x 480, 4 frames
 [m3vpss ] DEI: Ch 2, Outformat is PROGRESSIVE
 [m3vpss ]  64221: DEI: OUT0:  2: Format: PROGRESSIVE, 0xbb636080, 704 x 480, 4 frames
 [m3vpss ] DEI: Ch 3, Outformat is PROGRESSIVE
 [m3vpss ]  64236: DEI: OUT0:  3: Format: PROGRESSIVE, 0xbb8ca080, 704 x 480, 4 frames
 [m3vpss ] DEI: Ch 4, Outformat is PROGRESSIVE
 [m3vpss ]  64250: DEI: OUT0:  4: Format: PROGRESSIVE, 0xbbb5e080, 704 x 480, 4 frames
 [m3vpss ] DEI: Ch 5, Outformat is PROGRESSIVE
 [m3vpss ]  64265: DEI: OUT0:  5: Format: PROGRESSIVE, 0xbbdf2080, 704 x 480, 4 frames
 [m3vpss ] DEI: Ch 6, Outformat is PROGRESSIVE
 [m3vpss ]  64280: DEI: OUT0:  6: Format: PROGRESSIVE, 0xbc086080, 704 x 480, 4 frames
 [m3vpss ] DEI: Ch 7, Outformat is PROGRESSIVE
 [m3vpss ]  64294: DEI: OUT0:  7: Format: PROGRESSIVE, 0xbc31a080, 704 x 480, 4 frames
 [m3vpss ]  64306: DEI: OUT1:  0: Format: PROGRESSIVE, 0xbc5ae080, 704 x 480, 4 frames
 [m3vpss ]  64317: DEI: OUT1:  1: Format: PROGRESSIVE, 0xbc79d080, 704 x 480, 4 frames
 [m3vpss ]  64328: DEI: OUT1:  2: Format: PROGRESSIVE, 0xbc98c080, 704 x 480, 4 frames
 [m3vpss ]  64339: DEI: OUT1:  3: Format: PROGRESSIVE, 0xbcb7b080, 704 x 480, 4 frames
 [m3vpss ]  64350: DEI: OUT1:  4: Format: PROGRESSIVE, 0xbcd6a080, 704 x 480, 4 frames
 [m3vpss ]  64361: DEI: OUT1:  5: Format: PROGRESSIVE, 0xbcf59080, 704 x 480, 4 frames
 [m3vpss ]  64372: DEI: OUT1:  6: Format: PROGRESSIVE, 0xbd148080, 704 x 480, 4 frames
 [m3vpss ]  64383: DEI: OUT1:  7: Format: PROGRESSIVE, 0xbd337080, 704 x 480, 4 frames
 [m3vpss ]  64395: DEI     : Loading Up-scaling Co-effs
 [m3vpss ]  64395: DEI     : Co-effs Loading ... DONE !!!
 [m3vpss ] DEI:HEAPID:1 USED:12160
 [m3vpss ] DEI:HEAPID:4 USED:39198720
 [m3vpss ]  64396: DEI    : Create Done !!!
 [m3vpss ]  64398: DEI    : Create in progress !!!
 [m3vpss ]  64400: DEI: OUT1:  0: Format: PROGRESSIVE, 0xbd670080, 176 x 120, 4 frames
 [m3vpss ]  64401: DEI: OUT1:  1: Format: PROGRESSIVE, 0xbd68ef80, 176 x 120, 4 frames
 [m3vpss ]  64402: DEI: OUT1:  2: Format: PROGRESSIVE, 0xbd6ade80, 176 x 120, 4 frames
 [m3vpss ]  64403: DEI: OUT1:  3: Format: PROGRESSIVE, 0xbd6ccd80, 176 x 120, 4 frames
 [m3vpss ]  64404: DEI: OUT1:  4: Format: PROGRESSIVE, 0xbd6ebc80, 176 x 120, 4 frames
 [m3vpss ]  64405: DEI: OUT1:  5: Format: PROGRESSIVE, 0xbd70ab80, 176 x 120, 4 frames
 [m3vpss ]  64405: DEI: OUT1:  6: Format: PROGRESSIVE, 0xbd729a80, 176 x 120, 4 frames
 [m3vpss ]  64406: DEI: OUT1:  7: Format: PROGRESSIVE, 0xbd748980, 176 x 120, 4 frames
 [m3vpss ]  64410: DEI     : Loading Down-scaling Co-effs
 [m3vpss ]  64410: DEI     : Co-effs Loading ... DONE !!!
 [m3vpss ] DEI:HEAPID:1 USED:11584
 [m3vpss ] DEI:HEAPID:4 USED:1013760
 [m3vpss ]  64411: DEI    : Create Done !!!
 [m3vpss ]  64411: SCLR: Create in progress !!!
 [m3vpss ]  64443: SCLR    : Loading Up-scaling Co-effs ...
 [m3vpss ]  64443: SCLR    : Co-effs Loading ... DONE !!!
 [m3vpss ] SCLR:HEAPID:0        USED:64
 [m3vpss ] SCLR:HEAPID:1        USED:22976
 [m3vpss ] SCLR:HEAPID:4        USED:5406720
 [m3vpss ]  64443: SCLR: Create Done !!!
 [m3vpss ]  64454: NSF: Create in progress !!!
 [m3video]  64484: IPC_IN_M3   : Create in progress !!!
 [m3video]  64484: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ...
 [m3video]  64484: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ...
 [m3vpss ] NSF::HEAPID:1        USED:11264
 [m3vpss ] NSF::HEAPID:4        USED:4055040
 [m3vpss ]  64477: NSF: Create Done !!!
 [m3vpss ]  64478: MERGE:  0: Format: PROGRESSIVE, 704 x 480
 [m3vpss ]  64478: MERGE:  1: Format: PROGRESSIVE, 704 x 480
 [m3vpss ]  64478: MERGE:  2: Format: PROGRESSIVE, 704 x 480
 [m3vpss ]  64479: MERGE:  3: Format: PROGRESSIVE, 704 x 480
 [m3vpss ]  64479: MERGE:  4: Format: PROGRESSIVE, 704 x 480
 [m3vpss ]  64479: MERGE:  5: Format: PROGRESSIVE, 704 x 480
 [m3vpss ]  64479: MERGE:  6: Format: PROGRESSIVE, 704 x 480
 [m3vpss ]  64479: MERGE:  7: Format: PROGRESSIVE, 704 x 480
 [m3vpss ]  64480: MERGE:  8: Format: PROGRESSIVE, 176 x 120
 [m3vpss ]  64480: MERGE:  9: Format: PROGRESSIVE, 176 x 120
 [m3vpss ]  64480: MERGE: 10: Format: PROGRESSIVE, 176 x 120
 [m3vpss ]  64480: MERGE: 11: Format: PROGRESSIVE, 176 x 120
 [m3vpss ]  64480: MERGE: 12: Format: PROGRESSIVE, 176 x 120
 [m3vpss ]  64480: MERGE: 13: Format: PROGRESSIVE, 176 x 120
 [m3vpss ]  64480: MERGE: 14: Format: PROGRESSIVE, 176 x 120
 [m3vpss ]  64480: MERGE: 15: Format: PROGRESSIVE, 176 x 120
 [m3vpss ]  64481: MERGE: 16: Format: INTERLACED , 704 x 480
 [m3vpss ]  64481: MERGE: 17: Format: INTERLACED , 704 x 480
 [m3vpss ]  64481: MERGE: 18: Format: INTERLACED , 704 x 480
 [m3video]  64485: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
 [m3vpss ]  64481: MERGE: 19: Format: INTERLACED , 704 x 480
 [m3vpss ]  64481: MERGE: 20: Format: INTERLACED , 704 x 480
 [m3vpss ]  64481: MERGE: 21: Format: INTERLACED , 704 x 480
 [m3vpss ]  64482: MERGE: 22: Format: INTERLACED , 704 x 480
 [m3vpss ]  64482: MERGE: 23: Format: INTERLACED , 704 x 480
 [m3vpss ]  64482: MERGE   : Create Done !!!
 [m3vpss ]  64482: IPC_OUT_M3   : Create in progress !!!
 [m3vpss ]  64483: IPC_OUT_M3   : Create Done !!!
 [m3video]  64488: IPC_IN_M3   : Create Done !!!
 [m3video]  64488: ENCODE: Create in progress ... !!!
 [m3video] ENCLINK:INFO: !!!Number of output buffers for ch[16] set to [1]
 [m3video]  ENCLINK: B Frame is enabled for a channel 0
 [m3video]  ENCLINK: WARNING: B Frame is enabled for a channel, cannot enable HIGH_SPEED
 [m3video]  ENCLINK: B Frame is enabled for a channel 1
 [m3video]  ENCLINK: B Frame is enabled for a channel 2
 [host] IpcBitsInLink_tskMain:Entered[HOST]
ThreadName:IpcBitsInLink_tskMain_3000001a,ThreadID:687
 [host]  5292: IPC_BITS_IN   : Create in progress !!!
 [host]  5292: IPC_BITS_IN   : ListMPOpen start !!!
 [host]  5292: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_24] ...
 5294: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_24] ...
 [host]  5296: IPC_BITS_IN   : ListMPOpen done !!!
 [m3video]  ENCLINK: B Frame is enabled for a channel 3
 [host]  5298: IPC_BITS_IN   : System_linkGetInfo done !!!
 [host]  5298: IPC_BITS_IN   : Create Done !!!
[HOST]
ThreadName:IpcBitsInLink_periodicTaskFxn_3000001a,ThreadID:707
 [m3vpss ]  64661: MERGE:  0: Format: PROGRESSIVE, 704 x 480
 [m3vpss ]  64662: MERGE:  1: Format: PROGRESSIVE, 704 x 480
 [m3video]  ENCLINK: B Frame is enabled for a channel 4
 [m3vpss ]  64662: MERGE:  2: Format: PROGRESSIVE, 704 x 480
 [m3vpss ]  64662: MERGE:  3: Format: PROGRESSIVE, 704 x 480
 [m3vpss ]  64663: MERGE:  4: Format: PROGRESSIVE, 704 x 480
 [m3vpss ]  64663: MERGE:  5: Format: PROGRESSIVE, 704 x 480
 [m3video]  ENCLINK: B Frame is enabled for a channel 5
 [m3vpss ]  64663: MERGE:  6: Format: PROGRESSIVE, 704 x 480
 [m3vpss ]  64663: MERGE:  7: Format: PROGRESSIVE, 704 x 480
 [m3vpss ]  64663: MERGE:  8: Format: PROGRESSIVE, 704 x 480
 [m3vpss ]  64664: MERGE:  9: Format: INTERLACED , 704 x 240
 [m3video]  ENCLINK: B Frame is enabled for a channel 6
 [m3vpss ]  64664: MERGE: 10: Format: INTERLACED , 704 x 240
 [m3vpss ]  64664: MERGE: 11: Format: INTERLACED , 704 x 240
 [m3vpss ]  64664: MERGE: 12: Format: INTERLACED , 704 x 240
 [m3vpss ]  64664: MERGE: 13: Format: INTERLACED , 704 x 240
 [m3video]  ENCLINK: B Frame is enabled for a channel 7
 [m3vpss ]  64664: MERGE: 14: Format: INTERLACED , 704 x 240
 [m3vpss ]  64664: MERGE: 15: Format: INTERLACED , 704 x 240
 [m3vpss ]  64664: MERGE: 16: Format: INTERLACED , 704 x 240
 [m3vpss ]  64664: MERGE   : Create Done !!!
 [m3video]  ENCLINK: WARNING: B Frame is enabled for a channel, cannot do batch processing (processMulti) for H.264 channels
 [m3vpss ]  64669: DUP:  0: Format: PROGRESSIVE, 704 x 480
 [m3vpss ]  64669: DUP:  1: Format: PROGRESSIVE, 704 x 480
 [m3vpss ]  64669: DUP:  2: Format: PROGRESSIVE, 704 x 480
 [m3vpss ]  64669: DUP:  3: Format: PROGRESSIVE, 704 x 480
 [m3vpss ]  64669: DUP:  4: Format: PROGRESSIVE, 704 x 480
 [m3vpss ]  64669: DUP:  5: Format: PROGRESSIVE, 704 x 480
 [m3vpss ]  64669: DUP:  6: Format: PROGRESSIVE, 704 x 480
 [m3vpss ]  64670: DUP:  7: Format: PROGRESSIVE, 704 x 480
 [m3vpss ]  64670: DUP:  8: Format: PROGRESSIVE, 704 x 480
 [m3vpss ]  64670: DUP:  9: Format: INTERLACED , 704 x 240
 [m3vpss ]  64670: DUP: 10: Format: INTERLACED , 704 x 240
 [m3vpss ]  64670: DUP: 11: Format: INTERLACED , 704 x 240
 [m3vpss ]  64670: DUP: 12: Format: INTERLACED , 704 x 240
 [m3vpss ]  64670: DUP: 13: Format: INTERLACED , 704 x 240
 [m3vpss ]  64670: DUP: 14: Format: INTERLACED , 704 x 240
 [m3video]  64559: ENCODE: Creating CH0 of 704 x 480, pitch = (704, 704) [PROGRESSIVE] [NON-TILED  ], bitrate = 450 Kbps, I-P Interval 3...
 [m3vpss ]  64670: DUP: 15: Format: INTERLACED , 704 x 240
 [m3vpss ]  64670: DUP: 16: Format: INTERLACED , 704 x 240
 [m3vpss ]  64672: DUP   : Create Done !!!
 [m3video] ENCLINK_H264:HEAPID:0        USED:13808
 [m3vpss ]  64672: SWMS: Create in progress !!!
 [m3video] ENCLINK_H264:HEAPID:3        USED:1511424
 [m3vpss ]  UTILS: DMA: Allocated CH (TCC) = 59 (59)
 [m3video]  64569: ENCODE: Creating CH1 of 704 x 480, pitch = (704, 704) [PROGRESSIVE] [NON-TILED  ], bitrate = 450 Kbps, I-P Interval 3...
 [m3vpss ]  UTILS: DMA: 0 of 1: Allocated PaRAM = 59 (0x49004760)
 [m3vpss ]  UTILS: DMA: Allocated CH (TCC) = 60 (60)
 [m3vpss ]  UTILS: DMA: 0 of 4: Allocated PaRAM = 60 (0x49004780)
 [m3video] ENCLINK_H264:HEAPID:0        USED:11912
 [m3vpss ]  UTILS: DMA: 1 of 4: Allocated PaRAM = 67 (0x49004860)
 [m3vpss ]  UTILS: DMA: 2 of 4: Allocated PaRAM = 160 (0x49005400)
 [m3video]  64579: ENCODE: Creating CH2 of 704 x 480, pitch = (704, 704) [PROGRESSIVE] [NON-TILED  ], bitrate = 450 Kbps, I-P Interval 3...
 [m3vpss ]  UTILS: DMA: 3 of 4: Allocated PaRAM = 161 (0x49005420)
 [m3vpss ] SWMS: instance 0, sc id 5, start win 0 end win 17
 [m3vpss ]  64817: SWMS0    : Loading Vertical Co-effs (UPSCALE)x ...
 [m3vpss ]  64817: SWMS0    : Loading Horizontal Co-effs (UPSCALE)x ...
 [m3vpss ]  64817: SWMS    : Co-effs Loading ... DONE !!!
 [m3video]  64589: ENCODE: Creating CH3 of 704 x 480, pitch = (704, 704) [PROGRESSIVE] [NON-TILED  ], bitrate = 450 Kbps, I-P Interval 3...
 [m3vpss ] AVSYNC:WARNING!! Application wrongly configureddisplayID[-1]. Reseting to correct displayID[0]
 [m3vpss ]  64818: SWMS:  0: Format: PROGRESSIVE, 704 x 480
 [m3vpss ]  64818: SWMS:  1: Format: PROGRESSIVE, 704 x 480
 [m3vpss ]  64818: SWMS:  2: Format: PROGRESSIVE, 704 x 480
 [m3video]  64598: ENCODE: Creating CH4 of 704 x 480, pitch = (704, 704) [PROGRESSIVE] [NON-TILED  ], bitrate = 450 Kbps, I-P Interval 3...
 [m3vpss ]  64819: SWMS:  3: Format: PROGRESSIVE, 704 x 480
 [m3vpss ]  64819: SWMS:  4: Format: PROGRESSIVE, 704 x 480
 [m3vpss ]  64819: SWMS:  5: Format: PROGRESSIVE, 704 x 480
 [m3vpss ]  64819: SWMS:  6: Format: PROGRESSIVE, 704 x 480
 [m3vpss ]  64819: SWMS:  7: Format: PROGRESSIVE, 704 x 480
 [m3video]  64608: ENCODE: Creating CH5 of 704 x 480, pitch = (704, 704) [PROGRESSIVE] [NON-TILED  ], bitrate = 450 Kbps, I-P Interval 3...
 [m3vpss ]  64819: SWMS:  8: Format: PROGRESSIVE, 704 x 480
 [m3vpss ]  64819: SWMS:  9: Format: INTERLACED , 704 x 240
 [m3vpss ]  64819: SWMS: 10: Format: INTERLACED , 704 x 240
 [m3vpss ]  64819: SWMS: 11: Format: INTERLACED , 704 x 240
 [m3vpss ]  64819: SWMS: 12: Format: INTERLACED , 704 x 240
 [m3video]  64618: ENCODE: Creating CH6 of 704 x 480, pitch = (704, 704) [PROGRESSIVE] [NON-TILED  ], bitrate = 450 Kbps, I-P Interval 3...
 [m3vpss ]  64820: SWMS: 13: Format: INTERLACED , 704 x 240
 [m3vpss ]  64820: SWMS: 14: Format: INTERLACED , 704 x 240
 [m3vpss ]  64820: SWMS: 15: Format: INTERLACED , 704 x 240
 [m3vpss ]  64820: SWMS: 16: Format: INTERLACED , 704 x 240
 [m3vpss ]  64820: SWMS    : ******* Configuring clock 7 secs...
 [m3video]  64628: ENCODE: Creating CH7 of 704 x 480, pitch = (704, 704) [PROGRESSIVE] [NON-TILED  ], bitrate = 450 Kbps, I-P Interval 3...
 [m3vpss ]  64820: SWMS0    : Loading Vertical Co-effs (UPSCALE)x ...
 [m3vpss ]  64820: SWMS0    : Loading Horizontal Co-effs (UPSCALE)x ...
 [m3vpss ]  64820: SWMS    : Co-effs Loading ... DONE !!!
 [m3vpss ]
 [m3vpss ]  *** [SWMS0] Mosaic Parameters ***
 [m3vpss ]
 [m3vpss ]  Output FPS: 120
 [m3vpss ]
 [m3vpss ]  Win | Ch  | Input      | Input          | Input         | Input       | Output     |  Output         | Output        | Output      | Scan        | Low Cost | SWMS | Data  | Blank |
 [m3vpss ]  Num | Num | Start X, Y | Width x Height | Pitch Y / C   | Memory Type | Start X, Y |  Width x Height | Pitch Y / C   | Memory Type | Fmt         | ON / OFF | Inst | Format| Frame |
 [m3vpss ]  ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
 [m3vpss ]    0 |   0 |    0,    0 |   704 x    240 |  2816 /  2816 | NON-TILED   |    0,    0 |  1440 x    810 |  3840 /      0 | NON-TILED   | PROGRESSIVE |       ON |    0 |  422I  |   OFF |
 [m3video]  64637: ENCODE: Creating CH8 of 176 x 120, pitch = (176, 176) [PROGRESSIVE] [NON-TILED  ], bitrate = 100 Kbps, I-P Interval 0...
 [m3vpss ]    1 |   1 |    0,    0 |   704 x    240 |  2816 /  2816 | NON-TILED   | 1440,    0 |   480 x    270 |  3840 /      0 | NON-TILED   | PROGRESSIVE |       ON |    0 |  422I  |   OFF |
 [m3vpss ]    2 |   2 |    0,    0 |   704 x    240 |  2816 /  2816 | NON-TILED   | 1440,  270 |   480 x    270 |  3840 /      0 | NON-TILED   | PROGRESSIVE |       ON |    0 |  422I  |   OFF |
 [m3vpss ]    3 |   3 |    0,    0 |   704 x    240 |  2816 /  2816 | NON-TILED   | 1440,  540 |   480 x    270 |  3840 /      0 | NON-TILED   | PROGRESSIVE |       ON |    0 |  422I  |   OFF |
 [m3video] ENCLINK_JPEG:HEAPID:0        USED:2064
 [m3vpss ]    4 |   4 |    0,    0 |   704 x    240 |  2816 /  2816 | NON-TILED   |    0,  810 |   480 x    270 |  3840 /      0 | NON-TILED   | PROGRESSIVE |       ON |    0 |  422I  |   OFF |
 [m3video]  64638: ENCODE: Creating CH9 of 176 x 120, pitch = (176, 176) [PROGRESSIVE] [NON-TILED  ], bitrate = 100 Kbps, I-P Interval 0...
 [m3vpss ]    5 |   5 |    0,    0 |   704 x    240 |  2816 /  2816 | NON-TILED   |  480,  810 |   480 x    270 |  3840 /      0 | NON-TILED   | PROGRESSIVE |       ON |    0 |  422I  |   OFF |
 [m3vpss ]    6 |   6 |    0,    0 |   704 x    240 |  2816 /  2816 | NON-TILED   |  960,  810 |   480 x    270 |  3840 /      0 | NON-TILED   | PROGRESSIVE |       ON |    0 |  422I  |   OFF |
 [m3vpss ]    7 |   7 |    0,    0 |   704 x    240 |  2816 /  2816 | NON-TILED   | 1440,  810 |   480 x    270 |  3840 /      0 | NON-TILED   | PROGRESSIVE |       ON |    0 |  422I  |   OFF |
 [m3vpss ]
 [m3video]  64639: ENCODE: Creating CH10 of 176 x 120, pitch = (176, 176) [PROGRESSIVE] [NON-TILED  ], bitrate = 100 Kbps, I-P Interval 0...
 [m3vpss ] SWMS:HEAPID:0        USED:360
 [m3vpss ] SWMS:HEAPID:1        USED:43776
 [m3video]  64640: ENCODE: Creating CH11 of 176 x 120, pitch = (176, 176) [PROGRESSIVE] [NON-TILED  ], bitrate = 100 Kbps, I-P Interval 0...
 [m3vpss ] SWMS:HEAPID:4        USED:4147200
 [m3vpss ]  64825: SWMS: Create Done !!!
 [m3vpss ]  64834: SWMS: Create in progress !!!
 [m3vpss ]  UTILS: DMA: Allocated CH (TCC) = 61 (61)
 [m3video]  64641: ENCODE: Creating CH12 of 176 x 120, pitch = (176, 176) [PROGRESSIVE] [NON-TILED  ], bitrate = 100 Kbps, I-P Interval 0...
 [m3vpss ]  UTILS: DMA: 0 of 1: Allocated PaRAM = 61 (0x490047A0)
 [m3vpss ]  UTILS: DMA: Allocated CH (TCC) = 62 (62)
 [m3vpss ]  UTILS: DMA: 0 of 4: Allocated PaRAM = 62 (0x490047C0)
 [m3vpss ]  UTILS: DMA: 1 of 4: Allocated PaRAM = 162 (0x49005440)
 [m3video]  64641: ENCODE: Creating CH13 of 176 x 120, pitch = (176, 176) [PROGRESSIVE] [NON-TILED  ], bitrate = 100 Kbps, I-P Interval 0...
 [m3vpss ]  UTILS: DMA: 2 of 4: Allocated PaRAM = 163 (0x49005460)
 [m3vpss ]  UTILS: DMA: 3 of 4: Allocated PaRAM = 164 (0x49005480)
 [m3vpss ] SWMS: instance 0, sc id 6, start win 0 end win 17
 [m3vpss ]  64872: SWMS    : VipScReq is TRUE!!!
 [m3video]  64642: ENCODE: Creating CH14 of 176 x 120, pitch = (176, 176) [PROGRESSIVE] [NON-TILED  ], bitrate = 100 Kbps, I-P Interval 0...
 [m3vpss ]  64878: SWMS1    : Loading Vertical Co-effs (UPSCALE)x ...
 [m3vpss ]  64878: SWMS1    : Loading Horizontal Co-effs (UPSCALE)x ...
 [m3vpss ]  64878: SWMS    : Co-effs Loading ... DONE !!!
 [m3vpss ]  64878: SWMS    : OutFrames List -> 2 !!!!!!!
 [m3video]  64643: ENCODE: Creating CH15 of 176 x 120, pitch = (176, 176) [PROGRESSIVE] [NON-TILED  ], bitrate = 100 Kbps, I-P Interval 0...
 [m3vpss ] AVSYNC:WARNING!! Application wrongly configureddisplayID[-1]. Reseting to correct displayID[2]
 [m3vpss ]  64879: SWMS:  0: Format: PROGRESSIVE, 704 x 480
 [m3vpss ]  64879: SWMS:  1: Format: PROGRESSIVE, 704 x 480
 [m3video]  64644: ENCODE: Creating CH16 of 704 x 480, pitch = (704, 704) [INTERLACED ] [NON-TILED  ], bitrate = 100 Kbps, I-P Interval 0...
 [m3vpss ]  64880: SWMS:  2: Format: PROGRESSIVE, 704 x 480
 [m3vpss ]  64880: SWMS:  3: Format: PROGRESSIVE, 704 x 480
 [m3vpss ]  64880: SWMS:  4: Format: PROGRESSIVE, 704 x 480
 [m3vpss ]  64880: SWMS:  5: Format: PROGRESSIVE, 704 x 480
 [m3video]  64645: ENCODE: Creating CH17 of 704 x 480, pitch = (704, 704) [INTERLACED ] [NON-TILED  ], bitrate = 100 Kbps, I-P Interval 0...
 [m3vpss ]  64880: SWMS:  6: Format: PROGRESSIVE, 704 x 480
 [m3vpss ]  64880: SWMS:  7: Format: PROGRESSIVE, 704 x 480
 [m3vpss ]  64880: SWMS:  8: Format: PROGRESSIVE, 704 x 480
 [m3vpss ]  64880: SWMS:  9: Format: INTERLACED , 704 x 240
 [m3video]  64645: ENCODE: Creating CH18 of 704 x 480, pitch = (704, 704) [INTERLACED ] [NON-TILED  ], bitrate = 100 Kbps, I-P Interval 0...
 [m3vpss ]  64880: SWMS: 10: Format: INTERLACED , 704 x 240
 [m3vpss ]  64881: SWMS: 11: Format: INTERLACED , 704 x 240
 [m3vpss ]  64881: SWMS: 12: Format: INTERLACED , 704 x 240
 [m3vpss ]  64881: SWMS: 13: Format: INTERLACED , 704 x 240
 [m3video]  64646: ENCODE: Creating CH19 of 704 x 480, pitch = (704, 704) [INTERLACED ] [NON-TILED  ], bitrate = 100 Kbps, I-P Interval 0...
 [m3vpss ]  64881: SWMS: 14: Format: INTERLACED , 704 x 240
 [m3vpss ]  64881: SWMS: 15: Format: INTERLACED , 704 x 240
 [m3vpss ]  64881: SWMS: 16: Format: INTERLACED , 704 x 240
 [m3vpss ]  64881: SWMS    : ******* Configuring clock 15 secs...
 [m3video]  64647: ENCODE: Creating CH20 of 704 x 480, pitch = (704, 704) [INTERLACED ] [NON-TILED  ], bitrate = 100 Kbps, I-P Interval 0...
 [m3vpss ]  64881: SWMS1    : Loading Vertical Co-effs (UPSCALE)x ...
 [m3vpss ]  64881: SWMS1    : Loading Horizontal Co-effs (11/16)x ...
 [m3vpss ]  64882: SWMS    : Co-effs Loading ... DONE !!!
 [m3vpss ]
 [m3vpss ]  *** [SWMS1] Mosaic Parameters ***
 [m3vpss ]
 [m3vpss ]  Output FPS: 60
 [m3vpss ]
 [m3video]  64648: ENCODE: Creating CH21 of 704 x 480, pitch = (704, 704) [INTERLACED ] [NON-TILED  ], bitrate = 100 Kbps, I-P Interval 0...
 [m3vpss ]    0 |   0 |    0,    0 |   704 x    240 |  2816 /  2816 | NON-TILED   |    0,    0 |   528 x    360 |  1472 /      0 | NON-TILED   | PROGRESSIVE |       ON |    0 |  422I  |   OFF |
 [m3vpss ]    1 |   1 |    0,    0 |   704 x    240 |  2816 /  2816 | NON-TILED   |  528,    0 |   192 x    120 |  1472 /      0 | NON-TILED   | PROGRESSIVE |       ON |    0 |  422I  |   OFF |
 [m3vpss ]    2 |   2 |    0,    0 |   704 x    240 |  2816 /  2816 | NON-TILED   |  528,  120 |   192 x    120 |  1472 /      0 | NON-TILED   | PROGRESSIVE |       ON |    0 |  422I  |   OFF |
 [m3vpss ]    3 |   3 |    0,    0 |   704 x    240 |  2816 /  2816 | NON-TILED   |  528,  240 |   192 x    120 |  1472 /      0 | NON-TILED   | PROGRESSIVE |       ON |    0 |  422I  |   OFF |
 [m3video]  64649: ENCODE: Creating CH22 of 704 x 480, pitch = (704, 704) [INTERLACED ] [NON-TILED  ], bitrate = 100 Kbps, I-P Interval 0...
 [m3vpss ]    4 |   4 |    0,    0 |   704 x    240 |  2816 /  2816 | NON-TILED   |    0,  360 |   176 x    120 |  1472 /      0 | NON-TILED   | PROGRESSIVE |       ON |    0 |  422I  |   OFF |
 [m3vpss ]    5 |   5 |    0,    0 |   704 x    240 |  2816 /  2816 | NON-TILED   |  176,  360 |   176 x    120 |  1472 /      0 | NON-TILED   | PROGRESSIVE |       ON |    0 |  422I  |   OFF |
 [m3vpss ]    6 |   6 |    0,    0 |   704 x    240 |  2816 /  2816 | NON-TILED   |  352,  360 |   176 x    120 |  1472 /      0 | NON-TILED   | PROGRESSIVE |       ON |    0 |  422I  |   OFF |
 [m3vpss ]    7 |   7 |    0,    0 |   704 x    240 |  2816 /  2816 | NON-TILED   |  528,  360 |   176 x    120 |  1472 /      0 | NON-TILED   | PROGRESSIVE |       ON |    0 |  422I  |   OFF |
 [m3video]  64650: ENCODE: Creating CH23 of 704 x 480, pitch = (704, 704) [INTERLACED ] [NON-TILED  ], bitrate = 100 Kbps, I-P Interval 0...
 [m3vpss ]
 Channel Selected: 0
 Channel Selected: 0
 Channel Selected: 1
 Channel Selected: 1
 Channel Selected: 2
 Channel Selected: 2
 Channel Selected: 3
 Channel Selected: 3
 Channel Selected: 4
 Channel Selected: 4
 Channel Selected: 5
 Channel Selected: 5
 Channel Selected: 6
 Channel Selected: 6
 Channel Selected: 7
 [m3video]  64650: ENCODE: All CH Create ... DONE !!!
 [m3vpss ] SWMS:HEAPID:1        USED:20736
 [m3vpss ]  64886: SWMS: Create Done !!!
 [m3vpss ]  64893: DISPLAY: Create in progress !!!
 [m3video] ENCLINK:HEAPID:0     USED:130256
 [m3vpss ]  64894: DISPLAY: Create Done !!!
 [m3video] ENCLINK:HEAPID:2     USED:12036096
 [m3vpss ]  64894: DISPLAY: Create in progress !!!
 [m3video] ENCLINK:HEAPID:3     USED:12091392
 [m3vpss ]  64895: DISPLAY: 44: Field Separate Mode ENABLED for Que 0 !!!
 [m3video]  64651: ENCODE: Create ... DONE !!!
 [m3vpss ]  64896: DISPLAY: Create Done !!!
 [m3video]  64652: IPC_BITS_OUT   : Create in progress !!!
 [m3vpss ]  64899: SWMS    : ******* Configuring clock 15 secs...
 [m3vpss ]  64899: SWMS0    : Loading Vertical Co-effs (UPSCALE)x ...
 [m3vpss ]  64899: SWMS0    : Loading Horizontal Co-effs (UPSCALE)x ...
 [m3video]  64654: IPC_BITS_OUT   : Create Done !!!
 [m3vpss ]  64899: SWMS    : Co-effs Loading ... DONE !!!
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]    0 |   9 |    0,    0 |   704 x    240 |   704 /   704 | NON-TILED   |    0,    0 |  1440 x    810 |  3840 /      0 | NON-TILED   | INTERLACE   |       ON |    0 |  420SP |   OFF |
 [m3vpss ]    1 |  10 |    0,    0 |   704 x    240 |   704 /   704 | NON-TILED   | 1440,    0 |   480 x    270 |  3840 /      0 | NON-TILED   | INTERLACE   |       ON |    0 |  420SP |   OFF |
 [m3vpss ]    2 |  11 |    0,    0 |   704 x    240 |   704 /   704 | NON-TILED   | 1440,  270 |   480 x    270 |  3840 /      0 | NON-TILED   | INTERLACE   |       ON |    0 |  420SP |   OFF |
 [m3vpss ]    3 |  12 |    0,    0 |   704 x    240 |   704 /   704 | NON-TILED   | 1440,  540 |   480 x    270 |  3840 /      0 | NON-TILED   | INTERLACE   |       ON |    0 |  420SP |   OFF |
 [m3vpss ]    4 |  13 |    0,    0 |   704 x    240 |   704 /   704 | NON-TILED   |    0,  810 |   480 x    270 |  3840 /      0 | NON-TILED   | INTERLACE   |       ON |    0 |  420SP |   OFF |
 [m3vpss ]    5 |  14 |    0,    0 |   704 x    240 |   704 /   704 | NON-TILED   |  480,  810 |   480 x    270 |  3840 /      0 | NON-TILED   | INTERLACE   |       ON |    0 |  420SP |   OFF |
 [m3vpss ]    6 |  15 |    0,    0 |   704 x    240 |   704 /   704 | NON-TILED   |  960,  810 |   480 x    270 |  3840 /      0 | NON-TILED   | INTERLACE   |       ON |    0 |  420SP |   OFF |
 [m3vpss ]    7 |  16 |    0,    0 |   704 x    240 |   704 /   704 | NON-TILED   | 1440,  810 |   480 x    270 |  3840 /      0 | NON-TILED   | INTERLACE   |       ON |    0 |  420SP |   OFF |
 [m3vpss ]
 [m3vpss ]  64907: SWMS    : ******* Configuring clock 30 secs...
 [m3vpss ]  64907: SWMS1    : Loading Vertical Co-effs (UPSCALE)x ...
 [m3vpss ]  64907: SWMS1    : Loading Horizontal Co-effs (11/16)x ...
 [m3vpss ]  64907: SWMS    : Co-effs Loading ... DONE !!!
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]  Output FPS: 30
 [m3vpss ]
 [m3vpss ]    0 |   9 |    0,    0 |   704 x    240 |   704 /   704 | NON-TILED   |    0,    0 |   528 x    360 |  1472 /      0 | NON-TILED   | INTERLACE   |       ON |    0 |  420SP |   OFF |
 [m3vpss ]    1 |  10 |    0,    0 |   704 x    240 |   704 /   704 | NON-TILED   |  528,    0 |   192 x    120 |  1472 /      0 | NON-TILED   | INTERLACE   |       ON |    0 |  420SP |   OFF |
 Channel Selected: 7
 [m3vpss ]    2 |  11 |    0,    0 |   704 x    240 |   704 /   704 | NON-TILED   |  528,  120 |   192 x    120 |  1472 /      0 | NON-TILED   | INTERLACE   |       ON |    0 |  420SP |   OFF |
 [m3vpss ]    3 |  12 |    0,    0 |   704 x    240 |   704 /   704 | NON-TILED   |  528,  240 |   192 x    120 |  1472 /      0 | NON-TILED   | INTERLACE   |       ON |    0 |  420SP |   OFF |
 [m3vpss ]    4 |  13 |    0,    0 |   704 x    240 |   704 /   704 | NON-TILED   |    0,  360 |   176 x    120 |  1472 /      0 | NON-TILED   | INTERLACE   |       ON |    0 |  420SP |   OFF |
 [m3vpss ]    5 |  14 |    0,    0 |   704 x    240 |   704 /   704 | NON-TILED   |  176,  360 |   176 x    120 |  1472 /      0 | NON-TILED   | INTERLACE   |       ON |    0 |  420SP |   OFF |
 [m3vpss ]    6 |  15 |    0,    0 |   704 x    240 |   704 /   704 | NON-TILED   |  352,  360 |   176 x    120 |  1472 /      0 | NON-TILED   | INTERLACE   |       ON |    0 |  420SP |   OFF |
 [m3vpss ]    7 |  16 |    0,    0 |   704 x    240 |   704 /   704 | NON-TILED   |  528,  360 |   176 x    120 |  1472 /      0 | NON-TILED   | INTERLACE   |       ON |    0 |  420SP |   OFF |
 [m3vpss ]
 [m3vpss ] 64912:MERGELINK[2000000e]:Input link ID passed to MERGE_LINK_CMD_GET_INPUT_LINK_CHINFO is invalid[20000002]
 [m3vpss ]  64913: DISPLAY: Start in progress !!!
 [m3vpss ]  64960: DISPLAY: Start Done !!!
 Channel Selected: 16
 [m3vpss ]  64960: DISPLAY: HDDAC(BP0) : 42 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) DropCount:0 DispLatency (Min / Max) = ( 8947 / 0 ) !!!
 Channel Selected: 17
 Channel Selected: 18
 Channel Selected: 19
 Channel Selected: 20
 Channel Selected: 21[HOST]
 [m3vpss ]  64961: DISPLAY DRV: HDDAC(BP0) : Q:[2] Display:[2], Repeat:[1], DQ:[0]
 [m3vpss ]  64961: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 1, HDDAC(BP0) 0, DVO2(BP1) 1, SDDAC(SEC1) 1
 [m3vpss ]  64961: DISPLAY: Start in progress !!!
 [m3vpss ]  65022: DISPLAY: Start Done !!!
 [m3vpss ]  65022: DISPLAY: SDDAC(SEC1): 16 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) DropCount:0 DispLatency (Min / Max) = ( 8947 / 0 ) !!!
 Channel Selected: 22
 Channel Selected: 23
Disable Channel: 8
Disable Channel: 9
Disable Channel: 10
Disable Channel: 11
Disable Channel: 12
Disable Channel: 13
Disable Channel: 14
Disable Channel: 15
Disable Channel: 16
Disable Channel: 17
Disable Channel: 18
Disable Channel: 19
Disable Channel: 20
Disable Channel: 21
Disable Channel: 22
Disable Channel: 23
Disable Channel: 24
Disable Channel: 25
Disable Channel: 26
Disable Channel: 27
Disable Channel: 28
Disable Channel: 29
 [m3vpss ]  65022: DISPLAY DRV: SDDAC(SEC1): Q:[2] Display:[1], Repeat:[0], DQ:[0]
 [m3vpss ]  65022: SWMS: Start in Progress !!!
 [m3vpss ]  65022: SWMS: Start Done !!!
 [m3vpss ]  65023: SWMS: Start in Progress !!!
 [m3vpss ]  65023: SWMS: Start Done !!!
 [m3vpss ]  66047: CAPTURE: Start in progress !!!
 [m3vpss ]  66146: CAPTURE: Enabled Time Stamping !!!
 [m3vpss ]  66155: CAPTURE: Enabled Time Stamping !!!
 [m3vpss ]  66163: CAPTURE: Start Done !!!
Disable Channel: 30
Disable Channel: 31
Disable Channel: 32
Disable Channel: 33
Disable Channel: 34
Disable Channel: 35
Disable Channel: 36
Disable Channel: 37
Disable Channel: 38
Disable Channel: 39
Disable Channel: 40
Disable Channel: 41
Disable Channel: 42
Disable Channel: 43
Disable Channel: 44
Disable Channel: 45
Disable Channel: 46
Disable Channel: 47
Disable Channel: 48
Disable Channel: 49
Disable Channel: 50
Disable Channel: 51
Disable Channel: 52
Disable Channel: 53
Disable Channel: 54
Disable Channel: 55
Disable Channel: 56
Disable Channel: 57
Disable Channel: 58
Disable Channel: 59
Disable Channel: 60
Disable Channel: 61
Disable Channel: 62
Disable Channel: 63
 [host] AUDIO: ENC Handle 27A588, Int Handle 27A594
 [host] AUDIO: ENC -> bitrate - 24000 inputBitsPerSample - 16, sampleRate - 16000, numberOfChannels - 1...
 [host] AUDIO: ENC -> Rpe_create(AAC_ENC) done....
 [host] AUDIO: CAPTURE -> Encoder creation SUCCESS for CH - 0
 [host] AUDIO: ENC Handle 27A6B0, Int Handle 27A6BC
 [host] AUDIO: CAPTURE -> Encoder creation SUCCESS for CH - 1
 [host] AUDIO: ENC Handle 27A778, Int Handle 27A784
 [host] AUDIO: CAPTURE -> Encoder creation SUCCESS for CH - 2
 [host] AUDIO: ENC Handle 27A858, Int Handle 27A864
 [host] AUDIO: CAPTURE -> Encoder creation SUCCESS for CH - 3
 [host] AUDIO: ENC Handle 27A920, Int Handle 27A92C
 [host] AUDIO: CAPTURE -> Encoder creation SUCCESS for CH - 4
 [host] AUDIO: ENC Handle 27A9E8, Int Handle 27A9F4
 [host] AUDIO: CAPTURE -> Encoder creation SUCCESS for CH - 5
 [host] AUDIO: ENC Handle 27AAB0, Int Handle 27AABC
 [host] AUDIO: CAPTURE -> Encoder creation SUCCESS for CH - 6
 [host] AUDIO: ENC Handle 27AB78, Int Handle 27AB84
 [host] AUDIO: CAPTURE -> Encoder creation SUCCESS for CH - 7
[HOST]
ThreadName:Audio_captureTaskFxn_0,ThreadID:764
 [host] AUDIO: Audio_startCapture() success....
 [host] AUDIO: capPtr: 41C4D880 <8192> encBuf: 41C51880 <1024> encOutBuf: 41C7AE80 <768> encHdl: 27A588
 [host] AUDIO: capPtr: 41C51C80 <8192> encBuf: 41C55C80 <1024> encOutBuf: 41C86780 <768> encHdl: 27A6B0
 [host] AUDIO: capPtr: 41C56080 <8192> encBuf: 41C5A080 <1024> encOutBuf: 41C92080 <768> encHdl: 27A778
 [host] AUDIO: capPtr: 41C5A480 <8192> encBuf: 41C5E480 <1024> encOutBuf: 41C9D980 <768> encHdl: 27A858
 [host] AUDIO: capPtr: 41C5E880 <8192> encBuf: 41C62880 <1024> encOutBuf: 41CA9280 <768> encHdl: 27A920
 [host] AUDIO: capPtr: 41C62C80 <8192> encBuf: 41C66C80 <1024> encOutBuf: 41CB4B80 <768> encHdl: 27A9E8
 [host] AUDIO: capPtr: 41C67080 <8192> encBuf: 41C6B080 <1024> encOutBuf: 41CC0480 <768> encHdl: 27AAB0
 [host] AUDIO: capPtr: 41C6B480 <8192> encBuf: 41C6F480 <1024> encOutBuf: 41CCBD80 <768> encHdl: 27AB78
Enable Interrupt
 [host]
AUDIO: STARTING AUDIO CAPTURE!!!!!
 [host]
AUDIO: AUDIO CAPTURE DEVICE Init Done!!!!!
Enable Interrupt
**** No video detected at CH [0,0] ****
Disable Channel: 0**** No video detected at CH [0,1] ****
Disable Channel: 1**** Detected video at CH [0,2] (720x240@59Hz, 1) ****
Enable Channel: 2**** Detected video at CH [0,3] (720x240@59Hz, 1) ****
Enable Channel: 3**** Detected video at CH [1,0] (720x240@59Hz, 1) ****
Enable Channel: 4**** Detected video at CH [1,1] (720x240@59Hz, 1) ****
Enable Channel: 5**** Detected video at CH [1,2] (720x240@59Hz, 1) ****
Enable Channel: 6**** Detected video at CH [1,3] (720x240@59Hz, 1) ****
Enable Channel: 7Clear Interrupt
Clear Interrupt
First Channel is: 2
Please update on this quickly.
