Is there the order of PLLs (MPU, Core, Display, DDR, Peripheral) Configuration?
For example: The Core PLL must be configured before other PLLs are configured.
Daisuke
Daisuke
Hi Biser,
Thank you for your reply.
I understand that a user can go without knowing the procedure to configure the PLLs in the initialization.
Daisuke
Hi Biser,
Our customer wants to reconfigure the PLLs in the user bootloader such as the attached source codes.
/************************************************************************* * Function Name: InitCorePLL * Parameters: None * * Return: None * * Description: Inits Core DPLL. CLKDCOLDO 2000MHZ * CORE_CLKOUTM6 500MHz * CORE_CLKOUTM4 200MHz * CORE_CLKOUTM5 250MHz * *************************************************************************/ void InitCorePLL(void) { /*CORE_DPLL in baypass*/ CM_CLKMODE_DPLL_CORE_bit.DPLL_EN = 4; /*Wait DPLL enter bypass mode*/ while((1 == CM_IDLEST_DPLL_CORE_bit.ST_DPLL_CLK) || (0 == CM_IDLEST_DPLL_CORE_bit.ST_MN_BYPASS)); /*disable Spread Spectrum Clocking*/ CM_CLKMODE_DPLL_CORE_bit.DPLL_SSC_EN = 0; /*Set DPLL multiplier factor *1000*/ CM_CLKSEL_DPLL_CORE_bit.DPLL_MULT = 1000; /*Set DPLL divider factor*/ CM_CLKSEL_DPLL_CORE_bit.DPLL_DIV = 24-1; /*Set DPLL post-divider factor M4*/ CM_DIV_M4_DPLL_CORE_bit.HSDIVIDER_CLKOUT1_DIV = 10; /*Set DPLL post-divider factor M5*/ CM_DIV_M5_DPLL_CORE_bit.HSDIVIDER_CLKOUT2_DIV = 8; /*Set DPLL post-divider factor M5*/ CM_DIV_M6_DPLL_CORE_bit.HSDIVIDER_CLKOUT3_DIV = 4; /*CORE_DPLL in baypass*/ CM_CLKMODE_DPLL_CORE_bit.DPLL_EN = 7; /*Wait DPLL locks*/ while((0 == CM_IDLEST_DPLL_CORE_bit.ST_DPLL_CLK) || (1 == CM_IDLEST_DPLL_CORE_bit.ST_MN_BYPASS)); } /************************************************************************* * Function Name: InitMPUPLL * Parameters: None * * Return: None * * Description: Inits MPU DPLL. MPU Clock 600 or 800MHz * * *************************************************************************/ void InitMPUPLL(void) { /*MPU_DPLL in baypass*/ CM_CLKMODE_DPLL_MPU_bit.DPLL_EN = 4; /*Wait DPLL enter bypass mode*/ while((1 == CM_IDLEST_DPLL_MPU_bit.ST_DPLL_CLK) || (0 == CM_IDLEST_DPLL_MPU_bit.ST_MN_BYPASS)); /*disable Spread Spectrum Clocking*/ CM_CLKMODE_DPLL_MPU_bit.DPLL_SSC_EN = 0; /*Set DPLL multiplier factor */ if (ismpuclk() == ON) { CM_CLKSEL_DPLL_MPU_bit.DPLL_MULT = 600; /* 600MHz */ } else { CM_CLKSEL_DPLL_MPU_bit.DPLL_MULT = 800; /* 800MHz */ } /*Set DPLL divider factor*/ CM_CLKSEL_DPLL_MPU_bit.DPLL_DIV = 24-1; /*Set DPLL post-divider factor M2*/ CM_DIV_M2_DPLL_MPU_bit.DPLL_CLKOUT_DIV = 1; /*MPU_DPLL in baypass*/ CM_CLKMODE_DPLL_MPU_bit.DPLL_EN = 7; /*Wait DPLL locks*/ while((0 == CM_IDLEST_DPLL_MPU_bit.ST_DPLL_CLK) || (1 == CM_IDLEST_DPLL_MPU_bit.ST_MN_BYPASS)); } /************************************************************************* * Function Name: InitPERPLL * Parameters: None * * Return: None * * Description: Inits PER DPLL. CLKDCOLDO 960MHZ * CLKOUT 192MHZ * *************************************************************************/ void InitPERPLL(void) { /*MPU_DPLL in baypass*/ CM_CLKMODE_DPLL_PER_bit.DPLL_EN = 4; /*Wait DPLL enter bypass mode*/ while((1 == CM_IDLEST_DPLL_PER_bit.ST_DPLL_CLK) || (0 == CM_IDLEST_DPLL_PER_bit.ST_MN_BYPASS)); /*disable Spread Spectrum Clocking*/ CM_CLKMODE_DPLL_PER_bit.DPLL_SSC_EN = 0; /*Set DPLL multiplier factor *960*/ CM_CLKSEL_DPLL_PERIPH_bit.DPLL_MULT = 960; /*Set DPLL divider factor*/ CM_CLKSEL_DPLL_PERIPH_bit.DPLL_DIV = 24-1; /*Set DPLL Sigma-Delta divider*/ CM_CLKSEL_DPLL_PERIPH_bit.DPLL_SD_DIV = 4; /*Set DPLL post-divider factor M2*/ CM_DIV_M2_DPLL_PER_bit.DPLL_CLKOUT_DIV = 5; /*MPU_DPLL in baypass*/ CM_CLKMODE_DPLL_PER_bit.DPLL_EN = 7; /*Wait DPLL locks*/ while((0 == CM_IDLEST_DPLL_PER_bit.ST_DPLL_CLK) || (1 == CM_IDLEST_DPLL_PER_bit.ST_MN_BYPASS)); } /************************************************************************* * Function Name: InitDDRPLL * Parameters: None * * Return: None * * Description: Inits DDR DPLL. DDR Clock 400MHZ * * *************************************************************************/ void InitDDRPLL(void) { /*DDR DPLL in baypass*/ CM_CLKMODE_DPLL_DDR_bit.DPLL_EN = 4; /*Wait DPLL enter bypass mode*/ while((1 == CM_IDLEST_DPLL_DDR_bit.ST_DPLL_CLK) || (0 == CM_IDLEST_DPLL_DDR_bit.ST_MN_BYPASS)); /*disable Spread Spectrum Clocking*/ CM_CLKMODE_DPLL_DDR_bit.DPLL_SSC_EN = 0; /*Set DPLL multiplier factor *400*/ CM_CLKSEL_DPLL_DDR_bit.DPLL_MULT = 400; /*Set DPLL divider factor*/ CM_CLKSEL_DPLL_DDR_bit.DPLL_DIV = 24-1; /*Set DPLL post-divider factor M2*/ CM_DIV_M2_DPLL_MPU_bit.DPLL_CLKOUT_DIV = 1; /*MPU_DPLL in baypass*/ CM_CLKMODE_DPLL_DDR_bit.DPLL_EN = 7; /*Wait DPLL locks*/ while((0 == CM_IDLEST_DPLL_DDR_bit.ST_DPLL_CLK) || (1 == CM_IDLEST_DPLL_DDR_bit.ST_MN_BYPASS)); } /************************************************************************* * Function Name: InitDDR * Parameters: None * * Return: None * * Description: * * *************************************************************************/ void InitDDR(void) { /*Enable Clocks*/ CM_PER_L3_CLKSTCTRL_bit.CLKTRCTRL = 2; CM_PER_L3_CLKCTRL_bit.MODULEMODE = 2; /*Enable Func Clock*/ CM_PER_EMIF_CLKCTRL_bit.MODULEMODE = 2; /*Wait clock to get active*/ while(CM_PER_EMIF_CLKCTRL_bit.IDLEST); /*VTP Init*/ /*Dynamic VTP compensation mode*/ VTP_CTRL_bit.ENABLE = 1; /*clears flops, start count again*/ VTP_CTRL_bit.CLRZ = 0; VTP_CTRL_bit.CLRZ = 1; /*wait ready*/ while(!VTP_CTRL_bit.READY); /*DDR Phy CMD0*/ CMD0_REG_PHY_CTRL_SLAVE_RATIO_0 = 0x80; CMD0_REG_PHY_DLL_LOCK_DIFF_0 = 0x1; CMD0_REG_PHY_INVERT_CLKOUT_0 = 0x0; /*DDR Phy CMD1*/ CMD1_REG_PHY_CTRL_SLAVE_RATIO_0 = 0x80; CMD1_REG_PHY_DLL_LOCK_DIFF_0 = 0x1; CMD1_REG_PHY_INVERT_CLKOUT_0 = 0x0; /*DDR Phy CMD2*/ CMD2_REG_PHY_CTRL_SLAVE_RATIO_0 = 0x80; CMD2_REG_PHY_DLL_LOCK_DIFF_0 = 0x1; CMD2_REG_PHY_INVERT_CLKOUT_0 = 0x0; /*Init Data Macro 0*/ DATA0_REG_PHY_RD_DQS_SLAVE_RATIO_0 = 0x40; DATA0_REG_PHY_WR_DQS_SLAVE_RATIO_0 = 0x00; DATA0_REG_PHY_WRLVL_INIT_RATIO_0 = 0x0; DATA0_REG_PHY_GATELVL_INIT_RATIO_0 = 0x0; DATA0_REG_PHY_FIFO_WE_SLAVE_RATIO_0 = 0x7B; DATA0_REG_PHY_WR_DATA_SLAVE_RATIO_0 = 0x80; DATA0_REG_PHY_DLL_LOCK_DIFF_0 = 1; /*Init Data Macro 1*/ DATA1_REG_PHY_RD_DQS_SLAVE_RATIO_0 = 0x40; DATA1_REG_PHY_WR_DQS_SLAVE_RATIO_0 = 0x0; DATA1_REG_PHY_WRLVL_INIT_RATIO_0 = 0x0; DATA1_REG_PHY_GATELVL_INIT_RATIO_0 = 0x0; DATA1_REG_PHY_FIFO_WE_SLAVE_RATIO_0 = 0x7B; DATA1_REG_PHY_WR_DATA_SLAVE_RATIO_0 = 0x80; DATA1_REG_PHY_DLL_LOCK_DIFF_0 = 1; /**/ DDR_CMD0_IOCTRL = 0x16B; DDR_CMD1_IOCTRL = 0x16B; DDR_CMD2_IOCTRL = 0x16B; DDR_DATA0_IOCTRL = 0x16B; DDR_DATA1_IOCTRL = 0x16B; /**/ DDR_IO_CTRL_bit.DDR3_RST_DEF_VAL = 0; DDR_IO_CTRL_bit.DDR_WUCLK_DISABLE = 0; DDR_IO_CTRL_bit.MDDR_SEL = 0; DDR_CKE_CTRL_bit.DDR_CKE_CTRL = 1; /**/ EMIF_DDR_PHY_CTRL_1 = 0x00000037; EMIF_DDR_PHY_CTRL_1_SHDW = 0x00000037; /**/ EMIF_SDRAM_TIM_1 = 0x199DFB1B; EMIF_SDRAM_TIM_1_SHDW = 0x199DFB1B; EMIF_SDRAM_TIM_2 = 0x269E7FDA; EMIF_SDRAM_TIM_2_SHDW = 0x269E7FDA; EMIF_SDRAM_TIM_3 = 0x501F895F; EMIF_SDRAM_TIM_3_SHDW = 0x501F895F; EMIF_SDRAM_REF_CTRL = 0x00000C30; EMIF_SDRAM_REF_CTRL_SHDW = 0x00000C30; EMIF_ZQ_CONFIG = 0x50074BE4; EMIF_SDRAM_CONFIG = 0x60A452B2; } /****************************************************************** Hardware dependent device initialization ******************************************************************/ void hw_init(void) /*Core PLL init*/ InitCorePLL(); /*MPU Clock init*/ InitMPUPLL(); /*Peripheral Clock init*/ InitPERPLL(); /*DDR PLL Init*/ InitDDRPLL(); /*DDR Init*/ InitDDR(); return; } /********************************< end of file >*******************************/ /* vi:set ts=4 sw=4: */
Is there the required procedure to configure the PLLs (MPU, Core, Display, DDR, Peripheral)?
They use the Master Osc (CLK_M_OSC) as the input clock source of all PLLs.
Daisuke
Hi Biser,
You do not necessarily have to watch the source codes. The customer wants to know the PLLs configuration requirements.
Can you answer the question same as my original question?
Daisuke Maeda said:
Is there the order of PLLs (MPU, Core, Display, DDR, Peripheral) Configuration?For example: The Core PLL must be configured before other PLLs are configured.
Daisuke
There is no specific order. It will depend on what peripherals are used and from which clock source they are clocked. I suggest your customer use the AM335X Clock Tree Tool: http://www.ti.com/tool/clocktreetool
