C6678 EVM to EVM Hyperlink Problem
[C66xx_0] Version #: 0x01000105; string HYPLNK LLD Revision: 01.00.01.05:Nov 19 2012:16:04:15
[C66xx_0] About to do system setup (PLL, PSC, and DDR)
[C66xx_0] Power domain is already enabled.  You probably re-ran without device reset (which is OK)
[C66xx_0] Constructed SERDES configs: PLL=0x00000228; RX=0x0046c485; TX=0x000cc305
[C66xx_0] system setup worked
[C66xx_0] About to set up HyperLink Peripheral
[C66xx_0] ============== begin registers before initialization ===========
[C66xx_0] Revision register contents:
[C66xx_0]   Raw    = 0x4e901900
[C66xx_0] Status register contents:
[C66xx_0]   Raw        = 0x00002004
[C66xx_0] Link status register contents:
[C66xx_0]   Raw       = 0x00000000
[C66xx_0] Control register contents:
[C66xx_0]   Raw             = 0x00006203
[C66xx_0] ============== end registers before initialization ===========
[C66xx_0] SERDES_STS (32 bits) contents: 0x08101041; lock = 1
[C66xx_0] ============== begin registers after initialization ===========
[C66xx_0]   Raw        = 0x04400005
[C66xx_0]   Raw       = 0xccf00cf0
[C66xx_0]   Raw             = 0x00006200
[C66xx_0] ============== end registers after initialization ===========
[C66xx_0] Waiting 5 seconds to check link stability
[C66xx_0] Precursors 0 Analysis: 0,1,0,1,0,1,0,1
[C66xx_0] Postcursors: 19 Analysis: 0,1,0,1,0,1,0,1
[C66xx_0] Link seems stable
[C66xx_0] About to try to read remote registers
[C66xx_0] ============== begin REMOTE registers after initialization ===========
[C66xx_0]   Raw        = 0x0440000b
[C66xx_0]   Raw       = 0xfdf0bdf0
[C66xx_0] ============== end REMOTE registers after initialization ===========
[C66xx_0] Peripheral setup worked
[C66xx_0] About to read/write once
[C66xx_0] Single write test passed
[C66xx_0] About to pass 65536 tokens; iteration = 0
[C66xx_0] === this is not an optimized example ===
[C66xx_0] Link Speed is 4 * 6.25 Gbps
[C66xx_0] Passed 65536 tokens round trip (read+write through hyplnk) in 16247 Mcycles
[C66xx_0] Approximately 247918 cycles per round-trip
[C66xx_0] Checking statistics
[C66xx_0] Test Completed successfully
[C66xx_0]   Raw             = 0x00000001
[C66xx_0] Waiting for other side to come up (       0)
[C66xx_0] SERDES_STS (32 bits) contents: 0x03060c19; lock = 1
[C66xx_0] Waiting for other side to come up (       1)
[C66xx_0] Waiting for other side to come up (       2)
[C66xx_0] Waiting for other side to come up (       3)
[C66xx_0] Waiting for other side to come up (       4)
[C66xx_0] Waiting for other side to come up (       5)
[C66xx_0] Waiting for other side to come up (       6)
[C66xx_0] Waiting for other side to come up (       7)
[C66xx_0] Waiting for other side to come up (       8)
[C66xx_0] Waiting for other side to come up (       9)
[C66xx_0] Waiting for other side to come up (      10)
[C66xx_0] Waiting for other side to come up (      11)
[C66xx_0] Waiting for other side to come up (      12)
[C66xx_0] Waiting for other side to come up (      13)
[C66xx_0] Waiting for other side to come up (      14)
[C66xx_0] Waiting for other side to come up (      15)
[C66xx_0] Waiting for other side to come up (      16)
[C66xx_0] Waiting for other side to come up (      17)
[C66xx_0] Waiting for other side to come up (      18)
[C66xx_0] Waiting for other side to come up (      19)
[C66xx_0] Waiting for other side to come up (      20)
[C66xx_0] Waiting for other side to come up (      21)
[C66xx_0] Waiting for other side to come up (      22)
[C66xx_0] Waiting for other side to come up (      23)
[C66xx_0] Waiting for other side to come up (      24)
[C66xx_0] Waiting for other side to come up (      25)
[C66xx_0] Waiting for other side to come up (      26)
[C66xx_0] Waiting for other side to come up (      27)
[C66xx_0] Waiting for other side to come up (      28)
[C66xx_0] Waiting for other side to come up (      29)
[C66xx_0] Waiting for other side to come up (      30)
[C66xx_0] Waiting for other side to come up (      31)
[C66xx_0] Waiting for other side to come up (      32)
[C66xx_0] Waiting for other side to come up (      33)
[C66xx_0] Waiting for other side to come up (      34)
[C66xx_0] Waiting for other side to come up (      35)
[C66xx_0] Waiting for other side to come up (      36)
[C66xx_0] Waiting for other side to come up (      37)
[C66xx_0] Waiting for other side to come up (      38)
[C66xx_0] SERDES_STS (32 bits) contents: 0x00000001; lock = 1
[C66xx_0] Precursors 0 Analysis: 0,1,0,1,1,0,0,1
[C66xx_0] Postcursors: 19 Analysis: 0,1,0,1,1,0,1,0
[C66xx_0] Approximately 247917 cycles per round-trip
[C66xx_0] About to pass 65536 tokens; iteration = 1
[C66xx_0] fail 0 0
[C66xx_0] hyplnkExampleCPUTokenExchange failed: 1
[C66xx_0] Single write failed (when synchronizing bulk test)
Customer is using Hyperlink cable between two EVM and ran the example code (attached both side console output).  Apperars communication is occuring however there is an error on one side.
Also console printout thhat state this is not an optimized example. Any guidance on how to optimize this?
