we are experiencing crashes in the TI MUSB driver (USB host) when we subject it to many small transfers.
This pattern occurs when running the rt28xx WiFi drivers, which issue a sequence of small USB vendor requests in occasional bursts.
I have attached the full kernel crash dump.
The function that blows up is musb_start_urb, which I understand is supposed to kick the hardware queue if necessary to start processing of previously added URBs (USB packets).
However, there appears to be a race condition and the URB is gone by the time the function is called. the next_urb(qh) function returns NULL and then blows up when it's dereferenced:
* Start the URB at the front of an endpoint's queue
* end must be claimed from the caller.
* Context: controller locked, irqs blocked */ static void musb_start_urb(struct musb *musb, int is_in, struct musb_qh *qh) {
u16 frame;
u32 len;
void __iomem *mbase = musb->mregs;
struct urb *urb = next_urb(qh);
void *buf = urb->transfer_buffer; <<<<Crash happens here, urb is NULL.
u32 offset = 0;
struct musb_hw_ep *hw_ep = qh->hw_ep;
unsigned pipe = urb->pipe;
u8 address = usb_pipedevice(pipe);
int epnum = hw_ep->epnum;
/* initialize software qh state */
qh->offset = 0;
qh->segsize = 0;
hw_ep->xfer_type = qh->type;
