This is an example name task_audio in dsp 6713. What I want to give is two different output to left and right speaker. What change should I make ? Example code is written below as well as attached.Any help is appreciated.
/* * Copyright 2003 by Texas Instruments Incorporated. * All rights reserved. Property of Texas Instruments Incorporated. * Restricted rights to use, duplicate or disclose this code are * granted through contract. * */ /* "@(#) DSP/BIOS 4.90.270 01-08-04 (bios,dsk6713-c04)" */ /* * ======== tsk_audio.c ======== * * This example demonstrates the use of IOM drivers with SIOs and tasks by * using the DIO class driver with a user defined device mini-driver * called "codec" and a class driver DIO instance called "dio_codec". This is * the loopback application where audio is read from an input SIO, then sent * back via an output SIO. * The following objects need to be created in the DSP/BIOS * configuration for this application: * * * A UDEV object, which links in a user device driver. In this * case the UDEV is a codec based IOM device driver. * * A DIO object, which links the UDEV object. * * A TSK object, with the function to run set to the function echo * defined in this file. * * A LOG named trace for debug and status output. */ #include <std.h> #include <log.h> #include <sys.h> #include <mem.h> #include <sio.h> #ifdef _6x_ extern far LOG_Obj trace; /* * Buffers placed in external memory are aligned on a 128 bytes boundary. * In addition, the buffer should be of a size multiple of 128 bytes for * the cache work optimally on the C6x. */ #define BUFLEN 128 /* number of samples in the frame */ #define BUFALIGN 128 /* alignment of buffer to allow use of L2 cache */ #else extern LOG_Obj trace; #define BUFLEN 128 /* number of samples in the frame */ #define BUFALIGN 1 #endif #define BUFSIZE (BUFLEN * sizeof(MdUns)) /* inStream and outStream are SIO handles created in main */ SIO_Handle inStream, outStream; /* Function prototype */ static Void createStreams(); static Void prime(); /* * ======== main ======== */ Void main() { LOG_printf(&trace, "tsk_audio started"); } /* * ======== createStreams ======== */ static Void createStreams() { SIO_Attrs attrs; /* align the buffer to allow it to be used with L2 cache */ attrs = SIO_ATTRS; attrs.align = BUFALIGN; attrs.model = SIO_ISSUERECLAIM; /* open the I/O streams */ inStream = SIO_create("/dioCodec", SIO_INPUT, BUFSIZE, &attrs); if (inStream == NULL) { SYS_abort("Create input stream FAILED."); } outStream = SIO_create("/dioCodec", SIO_OUTPUT, BUFSIZE, &attrs); if (outStream == NULL) { SYS_abort("Create output stream FAILED."); } } /* * ======== prime ======== */ static Void prime() { Ptr buf0, buf1, buf2, buf3; LOG_printf(&trace, "Allocate buffers started"); /* Allocate buffers for the SIO buffer exchanges */ buf0 = (Ptr)MEM_calloc(0, BUFSIZE, BUFALIGN); buf1 = (Ptr)MEM_calloc(0, BUFSIZE, BUFALIGN); buf2 = (Ptr)MEM_calloc(0, BUFSIZE, BUFALIGN); buf3 = (Ptr)MEM_calloc(0, BUFSIZE, BUFALIGN); if (buf0 == NULL || buf1 == NULL || buf2 == NULL || buf3 == NULL) { SYS_abort("MEM_calloc failed."); } /* Issue the first & second empty buffers to the input stream */ if (SIO_issue(inStream, buf0, SIO_bufsize(inStream), NULL) != SYS_OK) { SYS_abort("Error issuing buffer to the input stream"); } if (SIO_issue(inStream, buf1, SIO_bufsize(inStream), NULL) != SYS_OK) { SYS_abort("Error issuing buffer to the input stream"); } /* Issue the first & second empty buffers to the output stream */ if (SIO_issue(outStream, buf2, SIO_bufsize(outStream), NULL) != SYS_OK) { SYS_abort("Error issuing buffer to the output stream"); } if (SIO_issue(outStream, buf3, SIO_bufsize(outStream), NULL) != SYS_OK) { SYS_abort("Error issuing buffer to the output stream"); } } /* * ======== echo ======== * This function copies from the input SIO to the output SIO. You could * easily replace the copy function with a signal processing algorithm. */ Void echo() { Int i; Int nmadus; /* number of minimal addressable units */ MdUns *inbuf, *outbuf; /* Call createStream function to create I/O streams */ createStreams(); /* Call prime function to do priming */ prime(); /* Loop forever looping back buffers */ for (;;) { /* Reclaim full buffer from the input stream */ if ((nmadus = SIO_reclaim(inStream, (Ptr *)&inbuf, NULL)) < 0) { SYS_abort("Error reclaiming full buffer from the input stream"); } /* Reclaim empty buffer from the output stream to be reused */ if (SIO_reclaim(outStream, (Ptr *)&outbuf, NULL) < 0) { SYS_abort("Error reclaiming empty buffer from the output stream"); } /* Do the data move. */ for (i = 0; i < (nmadus / sizeof(short)); i++) { outbuf[i] = 100*inbuf[i]; } /* Issue full buffer to the output stream */ if (SIO_issue(outStream, outbuf, nmadus, NULL) != SYS_OK) { SYS_abort("Error issuing full buffer to the output stream"); } /* Issue an empty buffer to the input stream */ if (SIO_issue(inStream, inbuf, SIO_bufsize(inStream), NULL) != SYS_OK) { SYS_abort("Error issuing empty buffer to the input stream"); } } } /* * ======== prd10secs ======== * prd10secs is configured to be called every 10 seconds */ Void prd10secs() { static Int seconds = 0; static Int minutes = 0; static Int hours = 0; seconds += 10; if (seconds == 60) { seconds = 0; minutes++; if (minutes == 60) { minutes = 0; hours++; } LOG_printf(&trace, "%d hours and %d minutes", hours, minutes); } else { LOG_printf(&trace, "%d seconds", seconds); } }
#include <std.h>
#include <log.h>
#include <sys.h>
#include <mem.h>
#include <sio.h>
#ifdef _6x_
#else
#define BUFALIGN 1
#endif
Void main()
SIO_Attrs attrs;
attrs = SIO_ATTRS;
static Void prime()
Void echo()
Int i;
createStreams();
prime();
for (;;) {
Void prd10secs()
seconds += 10;
seconds = 0;
minutes++;
minutes = 0;
hours++;
else {
