dra7xx-evm board docs about dra752.pdf
Other Parts Discussed in Thread: DRA746, DRA752
Hi experts,
Based on logs on boot process, I noticed this board has been equipped with dra752 and ES 1.0. But I can find only dra746.pdf in the following website:
http://processors.wiki.ti.com/index.php/DRA7xx
http://www.ti.com/lsds/ti/apps/automotive/products.page
So here is the question:
Can I start the board from the website about its docs? Is that a right way to go?
If there is a docs dra752.pdf existed? like dra746.pdf in TI's website
Or dra746.pdf is exactly right for dra7xx-evm?
Cheers,
Zumeng
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 3.8.13-g89927f5 (tiiappadmin@swubn01) (gcc version 4.7.3 20130226 (prerelease) (crosstool-NG linaro-1.13.1-4.7-2013.03-20130313 - Linaro GCC 2013.03) ) #1 SMP PREEMPT Fri Dec 3
[    0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=10c53c7d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[    0.000000] Machine: Jacinto6 evm board, model: TI DRA7
[    0.000000] cma: CMA: reserved 64 MiB at 99000000
[    0.000000] cma: CMA: reserved 56 MiB at 95800000
[    0.000000] cma: CMA: reserved 8 MiB at 9f000000
[    0.000000] cma: CMA: reserved 32 MiB at 9d000000
[    0.000000] cma: CMA: reserved 16 MiB at ae800000
[    0.000000] Memory policy: ECC disabled, Data cache writealloc
[    0.000000] DRA752 ES1.0
    The cited web sites:
    Contain technical briefs, that describe the functionalities of DRA7xx SoCs. They are not guides for dra7xx evm startup or TRMs.
    The appropriate guides for board bring up are the GLSDK Software Developers Guide & DRA7xx Quick Start Guide:
    http://processors.wiki.ti.com/index.php/DRA7xx_GLSDK_Software_Developers_Guide
    http://downloads.ti.com/dsps/dsps_public_sw/glsdk/6_03_00_01/exports/DRA7xx_ES_1_0_Quick_Start_Guide.pdf
    Other useful information can be found on bellow links:
    http://processors.wiki.ti.com/index.php/DRA7xx_GLSDK_6.03.00.01_Release_Notes
    http://processors.wiki.ti.com/index.php/GLSDK_Datasheet_DRA7xx_6.03.00.01
    Yordan
  • Hi Yordan,
    Yes, I didn't want to find start guide, I just exactly want to get technical briefs, and more which describe the functionalities and detail about DRA7xx SoCs.
    So can you confirm DRA74x is exactly for DRA752 for me? Thanks in advance.
    And is there any docs to describe how the work coherency among 2xCortexA15, 2xQuadCortexM4, SGX544, C66x DSP, which I ever knew a little about them ;-)
    Cheers,
    Zumeng
  • Hello Zumeng,
    I confirm that DRA74x & DRA75x devices are identical.
    For information about C66x DSP you can check: http://processors.wiki.ti.com/index.php/Multicore
    For Cortex A15 & Cortex M4 you should refer to arm infocenter: http://infocenter.arm.com/help/index.jsp
    Also you can go through the respective chapters in OMAP5432 TRM.
    Yordan
  • Hi Yodan,
    Thanks for your comments. and here is the last question on this thread ;-)
    What is the relationship between omap543x and DRA7xx?
    Cheers,
    Zumeng
  • Hi Zumeng,
    DRA7xx SoC is based on enhanced OMAP5 architecutre. It is used for automotive infotainment applications.
    As you can see in Section 1.3 DRA74x Functional Block Diagram from http://www.ti.com/lit/ds/symlink/dra746.pdf, the DRA7xx SoC has CAN interface, Radio Coprocessor & PWM moudles added &  Video in Ports instead of ISS.
    Additional information about Jacinto 6 devices is available under NDA agreement.
    Yordan
  • OK, thanks Yordan for your tips to get these docs under NDA.
    Cheers,
    Zumeng
