C:\ti\pdk_C6678_1_1_2_6\packages\ti\transport\ipc\examples\shmIpcBenchmark
it include many libs in the cmd generated after build the project. but i do not know how these libs included in the project. in the property of the project,it do not set the path of the lib and do not include the lib。
for example,the project use the function platform_init of the lib in the
C:\ti\pdk_C6678_1_1_2_6\packages\ti\platform\evmc6678l\platform_lib\lib\debug
i think if it is included by the cfg.but i do not know where it is or how it is included by other methods.
the cfg file of the project is:
/* --COPYRIGHT--,BSD
* Copyright (c) 2011, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* --/COPYRIGHT--*/
/* Benchmark Task */
var Task = xdc.useModule('ti.sysbios.knl.Task');
var tskParams = new Task.Params;
tskParams.instance.name = "tsk0";
Program.global.task0 = Task.create('&tsk0', tskParams);
var Semaphore = xdc.useModule('ti.sysbios.knl.Semaphore');
Semaphore.supportsEvents = false;
//var Agent = xdc.useModule('ti.sysbios.rta.Agent');
//Agent.transport = Agent.Transport_STOP_MODE_ONLY;
//var Load = xdc.useModule('ti.sysbios.utils.Load');
//Load.hwiEnabled = false;
//Load.swiEnabled = false;
//Load.taskEnabled = false;
var System = xdc.useModule('xdc.runtime.System');
var Startup = xdc.useModule('xdc.runtime.Startup');
var SysStd = xdc.useModule('xdc.runtime.SysStd');
System.SupportProxy = SysStd;
System.extendedFormats = "%f";
var BIOS = xdc.useModule('ti.sysbios.BIOS');
BIOS.clockEnabled = false;
BIOS.heapSize = 0x8000;
var Timestamp = xdc.useModule("xdc.runtime.Timestamp");
Program.sectMap[".msgQ_ptrs"] = new Program.SectionSpec();
Program.sectMap[".msgQ_ptrs"] = "L2SRAM";
Program.sectMap["platform_lib"] = new Program.SectionSpec();
Program.sectMap["platform_lib"] = "L2SRAM";
var PlatformLib = xdc.loadPackage('ti.platform.evmc6678l');
** Register an EVM Init handler with BIOS. This will initialize the hardware. BIOS calls before it starts.
** If debugging with CCS, then this function will execute as CCS loads it if the option in your
** Target Configuration file (.ccxml) has the option set to execute all code before Main. That is the
** default.
Startup.firstFxns.$add('&initPlatform');
var cslSettings = xdc.useModule ('ti.csl.Settings');
var cacheEnabled = true;
var cacheLineSize = 128;
var procName = null;
var procNameList = [];
var Settings = xdc.module('ti.sdo.ipc.family.Settings');
var Cache = xdc.useModule('ti.sysbios.family.c66.Cache');
var MessageQ = xdc.module('ti.sdo.ipc.MessageQ');
var Notify = xdc.module('ti.sdo.ipc.Notify');
var Ipc = xdc.useModule('ti.sdo.ipc.Ipc');
Notify.SetupProxy = xdc.module(Settings.getNotifySetupDelegate());
MessageQ.SetupTransportProxy= xdc.module(Settings.getMessageQSetupDelegate());
/* Use shared memory IPC */
Notify.SetupProxy = xdc.module('ti.sdo.ipc.family.c647x.NotifyCircSetup');
MessageQ.SetupTransportProxy = xdc.module('ti.sdo.ipc.transports.TransportShmNotifySetup');
/* Set to disable error printouts */
/* var Error = xdc.useModule('xdc.runtime.Error'); */
/* Error.raiseHook = null; */
Program.global.NOTIFYSETUP = Notify.SetupProxy.delegate$.$name;
Program.global.TRANSPORTSETUP = MessageQ.SetupTransportProxy.delegate$.$name;
switch (Program.platformName) {
case "ti.sdo.ipc.examples.platforms.evm6678.core0":
case "ti.platforms.evm6678":
Program.global.USING_C6678 = 1;
procNameList = ["CORE0", "CORE1"];
Program.global.shmBase = 0x0C000000;
Program.global.shmSize = 0x00100000; /* Sized for greater than 8000 128 byte messageQ messages */
break;
case "ti.sdo.ipc.examples.platforms.evm6670.core0":
case "ti.platforms.evm6670":
Program.global.USING_C6670 = 1;
break;
default:
throw("Unsupported platform: " + Program.platformName);
var MultiProc = xdc.useModule('ti.sdo.utils.MultiProc');
MultiProc.setConfig(procName, procNameList);
Program.global.DEVICENAME = Program.cpu.deviceName;
Program.global.PROCNAMES = procNameList.join(",");
Program.global.BUILDPROFILE = Program.build.profile;
var SharedRegion = xdc.useModule('ti.sdo.ipc.SharedRegion');
SharedRegion.translate = false;
SharedRegion.setEntryMeta(0,
{ base: Program.global.shmBase,
len: Program.global.shmSize,
ownerProcId: 0,
isValid: true,
cacheEnable: cacheEnabled,
cacheLineSize: cacheLineSize, /* Aligns allocated messages to a cache line */
/* Optimization stuff */
Diags = xdc.useModule("xdc.runtime.Diags");
var Defaults = xdc.useModule('xdc.runtime.Defaults');
//Defaults.common$.diags_ASSERT = Diags.ALWAYS_OFF;
Defaults.common$.logger = null;
