DEI OMX component usage
Other Parts Discussed in Thread: TVP5147
I am running a modified version of the capture_dei_encode.oms script which comes packaged with the DM8168 EVM. I have successfully managed to capture and display video from a PAL source at 768x576i, using the upscale functionality of the DEI component to display the captured video in 1080p on an HDMI monitor.
However, there seems to only be one field of each frame which is passed to the display component (VFDC), as the frames are only half their intended height, and appear vertically squashed (see picture):
I would think that my configuration of the DEI component is therefore incorrect, so have included the script I am using below:
#omx omtb_dbg_lvl 0x00
#omx omtb_dbg_lvl 0x04
#omx omtb_dbg_lvl 0x08
#omx omtb_dbg_lvl 0x10
#omx omtb_dbg_lvl 0x80
omx api init
omx setp 0 vfcc compname OMX.TI.VPSSM3.VFCC
#omx setp 0 tvp compname OMX.TI.VPSSM3.CTRL.TVP
omx setp 0 dc insmod_hdmi disable
#I/P Port or O/P Port Params for VFCC
omx setp 0 vfcc numoutbuf 6
omx setp 0 vfcc frame_width 768
omx setp 0 vfcc frame_height 576
omx setp 0 vfcc op_chromat_format 422YUYV
omx setp 0 vfcc outbufalign 0
omx setp 0 vfcc outbuf_contig disable
omx setp 0 vfcc outbufsize 663552
omx setp 0 vfcc data_opmode driver
omx setp 0 vfcc outbuf allocate
omx setp 0 vfcc outbufsize_flag disable
omx setp 0 dei frame_width 768
omx setp 0 dei frame_height 576
omx setp 0 dei op_chromat_format 422YUYV
omx setp 0 dei ip_chromat_format 422YUYV
omx setp 0 dei numinbuf 6
omx setp 0 dei inbufalign 0
omx setp 0 dei inbuf_contig disable
omx setp 0 dei inbufsize_flag disable
omx setp 0 dei inbufsize 663552
omx setp 0 dei numoutbuf 8
omx setp 0 dei outbufalign 0
omx setp 0 dei outbuf_contig disable
omx setp 0 dei outbufsize_flag enable
omx setp 0 dei outbufsize 4147200
omx setp 0 dei data_opmode driver
omx setp 0 dei inbuf use
omx setp 0 dei outbuf allocate
omx setp 0 h264venc numinbuf 8
omx setp 0 h264venc frame_width 1920
omx setp 0 h264venc frame_height 1080
omx setp 0 h264venc inbufsize 4147200
omx setp 0 h264venc numoutbuf 4
omx setp 0 h264venc outbufsize_flag enable
omx setp 0 h264venc outbufsize 3110400
#omx setp 0 h264venc data_opmode driver
#To enable write to SD card change mode to file
omx setp 0 h264venc data_opmode file
omx setp 0 h264venc outfile /usr/share/ti/data/videos/dm816x_1080p60_encode.264
omx setp 0 vfdc frame_width 1920
omx setp 0 vfdc frame_height 1080
omx setp 0 vfdc ip_chromat_format 422YUYV
omx setp 0 vfdc numinbuf 8
omx setp 0 vfdc inbufalign 0
omx setp 0 vfdc inbuf_contig disable
omx setp 0 vfdc inbufsize 4147200
omx setp 0 vfdc inbuf use
omx setp 0 vfdc graphics_flag disable
#omx setp 0 vfdc vcdemo_flag enable
omx setp 0 vfdc mosaic_window_config vs
omx setp 0 dc insmod_hdmi enable
omx api gethandle vfcc 0 0
omx api gethandle dei 0 0
omx api gethandle h264venc 0 0
omx api gethandle vfdc 0 0
omx api gethandle dc 0 0
#SET ALL THE PARAMS FOR VFCC
omx setp 0 vfcc OMX_TI_IndexParamVFCCHwPortID eHwPortId vip1_porta
omx api setparam vfcc 0 0 0 OMX_TI_IndexParamVFCCHwPortID
omx setp 0 vfcc OMX_TI_IndexParamVFCCHwPortProperties eCaptMode sc_discrete_sync
omx setp 0 vfcc OMX_TI_IndexParamVFCCHwPortProperties eVifMode 16_bit
omx setp 0 vfcc OMX_TI_IndexParamVFCCHwPortProperties eInColorFormat 422YUYV
omx setp 0 vfcc OMX_TI_IndexParamVFCCHwPortProperties eScanType interlaced
omx setp 0 vfcc OMX_TI_IndexParamVFCCHwPortProperties nMaxWidth 768
omx setp 0 vfcc OMX_TI_IndexParamVFCCHwPortProperties nMaxHeight 576
omx setp 0 vfcc OMX_TI_IndexParamVFCCHwPortProperties nMaxChnlsPerHwPort 1
omx api setparam vfcc 0 0 0 OMX_TI_IndexParamVFCCHwPortProperties
omx setp 0 vfcc OMX_TI_IndexParamBuffMemType eBufMemoryType default
omx api setparam vfcc 0 0 0 OMX_TI_IndexParamBuffMemType
omx setp 0 vfcc OMX_IndexParamCompBufferSupplier eBufferSupplier unspecified
#omx api setparam vfcc 0 0 0 OMX_IndexParamCompBufferSupplier
omx setp 0 vfcc OMX_TI_IndexConfigVFCCFrameSkip frameSkipMask 0
#omx api setconfig vfcc 0 0 0 OMX_TI_IndexConfigVFCCFrameSkip
omx setp 0 vfcc OMX_IndexParamVideoInit nPorts 16
omx setp 0 vfcc OMX_IndexParamVideoInit nStartPortNumber 0
omx api setparam vfcc 0 0 0 OMX_IndexParamVideoInit
omx setp 0 dei OMX_TI_IndexParamVFPCNumChPerHandle nNumChannelsPerHandle 1
omx api setparam dei 0 0 0 OMX_TI_IndexParamVFPCNumChPerHandle
omx setp 0 dei OMX_TI_IndexConfigAlgEnable bAlgBypass enable
omx setp 0 dei OMX_TI_IndexConfigAlgEnable nChId 0
omx api setconfig dei 0 0 0 OMX_TI_IndexConfigAlgEnable
omx setp 0 dei OMX_TI_IndexConfigSubSamplingFactor nSubSamplingFactor 1
omx api setconfig dei 0 0 0 OMX_TI_IndexConfigSubSamplingFactor
omx setp 0 dei OMX_TI_IndexConfigVidChResolution Frm0Width 768
omx setp 0 dei OMX_TI_IndexConfigVidChResolution Frm0Height 576
omx setp 0 dei OMX_TI_IndexConfigVidChResolution Frm0Pitch 1536
omx setp 0 dei OMX_TI_IndexConfigVidChResolution Frm1Width 0
omx setp 0 dei OMX_TI_IndexConfigVidChResolution Frm1Height 0
omx setp 0 dei OMX_TI_IndexConfigVidChResolution Frm1Pitch 0
omx setp 0 dei OMX_TI_IndexConfigVidChResolution FrmStartX 0
omx setp 0 dei OMX_TI_IndexConfigVidChResolution FrmStartY 0
omx setp 0 dei OMX_TI_IndexConfigVidChResolution FrmCropWidth 768
omx setp 0 dei OMX_TI_IndexConfigVidChResolution FrmCropHeight 576
omx setp 0 dei OMX_TI_IndexConfigVidChResolution eDir input
omx setp 0 dei OMX_TI_IndexConfigVidChResolution nChId 0
omx api setconfig dei 0 0 0 OMX_TI_IndexConfigVidChResolution
omx setp 0 dei OMX_TI_IndexConfigVidChResolution Frm0Width 1920
omx setp 0 dei OMX_TI_IndexConfigVidChResolution Frm0Height 1080
omx setp 0 dei OMX_TI_IndexConfigVidChResolution Frm0Pitch 3840
omx setp 0 dei OMX_TI_IndexConfigVidChResolution Frm1Width 1920
omx setp 0 dei OMX_TI_IndexConfigVidChResolution Frm1Height 1080
omx setp 0 dei OMX_TI_IndexConfigVidChResolution Frm1Pitch 3840
omx setp 0 dei OMX_TI_IndexConfigVidChResolution FrmCropWidth 1920
omx setp 0 dei OMX_TI_IndexConfigVidChResolution FrmCropHeight 1080
omx setp 0 dei OMX_TI_IndexConfigVidChResolution eDir output
omx api setconfig dei 0 0 16 OMX_TI_IndexConfigVidChResolution
omx setp 0 dei OMX_TI_IndexParamBuffMemType eBufMemoryType default
omx api setparam dei 0 0 0 OMX_TI_IndexParamBuffMemType
omx api setparam dei 0 0 16 OMX_TI_IndexParamBuffMemType
omx api setparam dei 0 0 17 OMX_TI_IndexParamBuffMemType
omx setp 0 dei OMX_TI_IndexParamCompPortNotifyType eNotifyType always
#omx api setparam dei 0 0 0 OMX_TI_IndexParamCompPortNotifyType
#omx api setparam dei 0 0 16 OMX_TI_IndexParamCompPortNotifyType
#omx api setparam dei 0 0 17 OMX_TI_IndexParamCompPortNotifyType
omx setp 0 dei OMX_IndexParamCompBufferSupplier eBufferSupplier unspecified
omx setp 0 dei OMX_IndexParamVideoInit nPorts 3
omx setp 0 dei OMX_IndexParamVideoInit nStartPortNumber 0
omx api getparam dei 0 0 0 OMX_IndexParamPortDefinition
omx setp 0 dei OMX_IndexParamPortDefinition video.nStride 3840
omx api setparam dei 0 0 0 OMX_IndexParamPortDefinition
omx api getparam h264venc 0 0 0 OMX_IndexParamPortDefinition
omx setp 0 h264venc OMX_IndexParamPortDefinition video.nStride 1920
omx api setparam h264venc 0 0 0 OMX_IndexParamPortDefinition
omx setp 0 vfdc OMX_TI_IndexParamVFDCDriverInstId nDrvInstID 0
omx setp 0 vfdc OMX_TI_IndexParamVFDCDriverInstId eDispVencMode 1080p60
omx api setparam vfdc 0 0 0 OMX_TI_IndexParamVFDCDriverInstId
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout winStartX 0
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout winStartY 0
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout winWidth 1920
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout winHeight 1080
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout pitch.VFDC_YUV_INT_ADDR_IDX 3840
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout pitch.VFDC_YUV_SP_Y_ADDR_IDX 3840
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout pitch.VFDC_YUV_SP_CBCR_ADDR_IDX 3840
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout dataFormat 422I_YUYV
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout bpp bits16
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout priority 0
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout nLayoutId 0
omx setp 0 vfdc mosaicNumRows 1
omx setp 0 vfdc mosaicNumCols 1
omx setp 0 vfdc mosaicDispWindowWidth 1920
omx setp 0 vfdc mosaicDispWindowHeight 1080
omx api setparam vfdc 0 0 0 OMX_TI_IndexParamVFDCCreateMosaicLayout
omx setp 0 vfdc OMX_TI_IndexConfigVFDCMosaicPort2WinMap nLayoutId 0
omx api setconfig vfdc 0 0 0 OMX_TI_IndexConfigVFDCMosaicPort2WinMap 1 0
omx setp 0 vfdc OMX_TI_IndexParamBuffMemType eBufMemoryType default
omx setp 0 vfdc OMX_IndexParamCompBufferSupplier eBufferSupplier unspecified
omx setp 0 vfdc OMX_IndexParamVideoInit nPorts 1
omx setp 0 vfdc OMX_IndexParamVideoInit nStartPortNumber 0
omx api getparam vfdc 0 0 0 OMX_IndexParamPortDefinition
omx setp 0 vfdc OMX_IndexParamPortDefinition video.nStride 3840
omx api setparam vfdc 0 0 0 OMX_IndexParamPortDefinition
#SET ALL THE PARAMS FOR DC#0
omx setp 0 dc OMX_TI_IndexParamVFDCDriverInstId nDrvInstID 0
omx setp 0 dc OMX_TI_IndexParamVFDCDriverInstId eDispVencMode 1080p60
omx api setparam dc 0 0 0 OMX_TI_IndexParamVFDCDriverInstId
omx api sendcommand port vfcc 0 enable 0
omx api sendcommand port vfcc 0 waitforsem 0
omx api sendcommand port dei 0 enable 0
omx api sendcommand port dei 0 waitforsem 0
omx api sendcommand port dei 0 enable 16
omx api sendcommand port dei 0 waitforsem 16
omx api sendcommand port dei 0 enable 17
omx api sendcommand port dei 0 waitforsem 17
omx api sendcommand port vfdc 0 enable 0
omx api sendcommand port vfdc 0 waitforsem 0
omx api sendcommand port h264venc 0 enable 0
omx api sendcommand port h264venc 0 waitforsem 0
omx api sendcommand port h264venc 0 enable 1
omx api sendcommand port h264venc 0 waitforsem 1
omx api connect vfcc 0 0 dei 0 0
omx api connect dei 0 16 vfdc 0 0
omx api connect dei 0 17 h264venc 0 0
omx api sendcommand state vfcc 0 idle
omx api sendcommand state vfcc 0 waitforsem
omx api sendcommand state dei 0 idle
omx api sendcommand state dei 0 waitforsem
omx api sendcommand state dc 0 idle
omx api sendcommand state dc 0 waitforsem
omx api sendcommand state vfdc 0 idle
omx api sendcommand state vfdc 0 waitforsem
omx api sendcommand state h264venc 0 idle
omx api sendcommand state h264venc 0 waitforsem
omx api sendcommand state dc 0 exec
omx api sendcommand state vfdc 0 exec
omx api sendcommand state vfcc 0 exec
omx api sendcommand state dei 0 exec
omx api sendcommand state h264venc 0 exec
sleep 20000
omx api sendcommand state h264venc 0 loaded
omx api sendcommand state vfcc 0 loaded
omx api sendcommand state dei 0 loaded
omx api sendcommand state dc 0 loaded
omx api sendcommand state vfdc 0 loaded
omx api freehandle vfcc 0
omx api freehandle dei 0
omx api freehandle dc 0
omx api freehandle vfdc 0
omx api freehandle h264venc 0
omx api uninit
Any advice on this usecase is appreciated.
Marcus
