Hi, all
How should I program right when I need each section code run parallel?
I tried like following:
-----the .cfg file-----
// allocate out of this shared region heap after IPC has been started.
var SharedRegion = xdc.useModule('ti.sdo.ipc.SharedRegion');
// Configure HeapOMP for the shared memory heap
// HeapOMP created in ti/omp/common.cfg.xs
var HeapOMP = xdc.useModule('ti.omp.utils.HeapOMP');
HeapOMP.sharedRegionId = 2;
HeapOMP.localHeapSize = 0x20000;
HeapOMP.sharedHeapSize = 0x1000000;
// Specify the Shared Region
SharedRegion.setEntryMeta( HeapOMP.sharedRegionId,
{ base: 0x90000000,
len: HeapOMP.sharedHeapSize,
ownerProcId: 0,
cacheEnable: true,
createHeap: true,
isValid: true,
/* load the common configuration file */
xdc.loadCapsule('ti/omp/common.cfg.xs');
var System = xdc.useModule('xdc.runtime.System');
System.extendedFormats = "%$S";
var OpenMP = xdc.useModule('ti.omp.utils.OpenMP');
OpenMP.setNumProcessors(4);
OpenMP.autoDnldCore = false; //add this line
Program.sectMap["ddr"] = new Program.SectionSpec();
Program.sectMap["ddr"].loadSegment = "DDR3";
Program.sectMap[".threadprivate"] = new Program.SectionSpec();
Program.sectMap[".threadprivate"].loadSegment = "L2SRAM";
// Enable Cache Write-back for HEAPOMP
var Cache = xdc.useModule('ti.sysbios.family.c66.Cache');
Cache.setMarMeta(0x80000000, 0x20000000, Cache.PC | Cache.WTE);
-----the C file-----
void main()
#pragma omp parallel sections //------>this is the line where error occur
#pragma omp section
// other code
printf("ThreadId is %d\n", omp_get_thread_num());
#pragma omp section
// other code
#pragma omp section
// other code
#pragma omp section
// other code
But when I build this, It occurred " error #1510: syntax error in OpenMP pragma "
Can anyone tell me why?
Mike,
Regards.
