Hi team,
One of customer use nand boot mode of C6748, they use aisgen tool to make the .ais file and set the entry point to 0x11800000, it will boot failed. But if set entry point to 0x11810000, everytings fine.
I have check spraat2f.pdf, nor lagceny boot will use the first 16KB of L2 ram, but haven't find any limted about nand boot mode.
Also I have check the pervious version spraat2a.pdf, it says:"Memory Usage: The bootloader uses 16 KB of DSP L2 RAM starting from 0x11800000 for multiple
purposes. This memory should not be used by any initialized section of the user application." It seems the new version of this documents delete this.
So could you please help to confirm the nand boot requirement of L2ram?
Thanks!
BR,
Denny
