I'm developing a WinCE Display driver for DM365 EVM board. I'm using the TFT LCD monitor shipped with Davinci(DM6446) EVM for testing the display driver. My display driver when loaded is displaying a green screen on Display. As per the DM365 EVM technical reference, I verified the switch settings for NTSC and they are proper. I could not locate the problem for this behaviour. I'm suspecting the VPBE hardware configuration.
I intend to configure the VPBE controller in Composite-Analog-NTSC mode and in the Standard definition mode. I'm using Video Window 0 and all other windows are deactivated. Just below I pasted the register set dump. Please tell me if I have done anything wrong in configuring the VPBE controller.
========VPSS VPSSCLK Register Dump @ 0x01C70000 ==========
10392 PID:400002 TID:2c60002 CLKCTRL 0x1
========VPSS VENC Register Dump @ 0x01C70400 ==========
10394 PID:400002 TID:2c60002 VMOD 0x3
10395 PID:400002 TID:2c60002 VIDCTRL 0x101
10397 PID:400002 TID:2c60002 Video Data Processing Register 0x0
10398 PID:400002 TID:2c60002 Sync Control Register 0x4000
10399 PID:400002 TID:2c60002 Horizontal Sync Pulse Width Register 0x0
10400 PID:400002 TID:2c60002 Vertical Sync Pulse Width Register 0x0
10401 PID:400002 TID:2c60002 Horizontal Interval Register 0x0
10402 PID:400002 TID:2c60002 Horizontal Valid Data Start Position Register 0x0
10404 PID:400002 TID:2c60002 Horizontal Data Valid Range Register 0x0
10405 PID:400002 TID:2c60002 Vertical Interval Register 0x0
10406 PID:400002 TID:2c60002 Vertical Valid Data Start Position Register 0x0
10407 PID:400002 TID:2c60002 Vertical Data Valid Range Register 0x0
10408 PID:400002 TID:2c60002 Horizontal Sync Delay Register 0x0
10409 PID:400002 TID:2c60002 Veritcal Sync Delay Register 0x0
10410 PID:400002 TID:2c60002 YCbCr Control Register 0x1
10412 PID:400002 TID:2c60002 RGB Control Register 0x0
10413 PID:400002 TID:2c60002 RGB Level Clipping Register 0xFF00
10414 PID:400002 TID:2c60002 Line Id Control Register 0x0
10415 PID:400002 TID:2c60002 Culling line control Register 0x0
10416 PID:400002 TID:2c60002 LCD Output Signal Control Register 0x0
10417 PID:400002 TID:2c60002 LCD_AC Signal Control 0x0
10418 PID:400002 TID:2c60002 DCLK Control Register 0x0
10420 PID:400002 TID:2c60002 DCLK Pattern 0 Register 0x0
10421 PID:400002 TID:2c60002 DCLK Pattern 1 Register 0x0
10422 PID:400002 TID:2c60002 DCLK Pattern 2 Register 0x0
10423 PID:400002 TID:2c60002 DCLK Pattern 3 Register 0x0
10424 PID:400002 TID:2c60002 DCLK Auxiliary Pattern 0 Register 0x0
10425 PID:400002 TID:2c60002 DCLK Auxiliary Pattern 1 Register 0x0
10426 PID:400002 TID:2c60002 DCLK Auxiliary Pattern 2 Register 0x0
10428 PID:400002 TID:2c60002 DCLK Auxiliary Pattern 3 Register 0x0
10429 PID:400002 TID:2c60002 Horizontal DCLK Mask start Register 0x0
10430 PID:400002 TID:2c60002 Horizontal Auxiliart DCLK Mask Atart Register 0x0
10431 PID:400002 TID:2c60002 Horizontal DCLK Mask Range Register 0x0
10432 PID:400002 TID:2c60002 Vertical DCLK Mask Start Register 0x0
10433 PID:400002 TID:2c60002 Vertical DCLK Mask Range Register 0x0
10434 PID:400002 TID:2c60002 Caption Control Register 0x0
10435 PID:400002 TID:2c60002 Caption Data Odd Field Register 0x0
10437 PID:400002 TID:2c60002 Caption Data Even Field Register 0x0
10438 PID:400002 TID:2c60002 Video Attribute Data 0 Register 0x0
10439 PID:400002 TID:2c60002 Video Attribute Data 1 Register 0x0
10440 PID:400002 TID:2c60002 Video Attribute Data 2 Register 0x0
10441 PID:400002 TID:2c60002 Video Status Register 0x10
10442 PID:400002 TID:2c60002 GCP-FRC Table RAM Address Register 0x0
10443 PID:400002 TID:2c60002 GCP-FRC Table RAM Data Port Register 0x0
10445 PID:400002 TID:2c60002 DAC Test Register 0x0
10446 PID:400002 TID:2c60002 YOUT and COUT Levels Register 0x0
10447 PID:400002 TID:2c60002 Sub-Carrier Programming Register 0x17A
10448 PID:400002 TID:2c60002 Composite Mode Register 0x0
10449 PID:400002 TID:2c60002 CVBS Timing Control 0 Register 0x0
10450 PID:400002 TID:2c60002 CVBS Timing Control 1 Register 0x0
10451 PID:400002 TID:2c60002 Digital RGB Matrix 0 Register 0x400
10453 PID:400002 TID:2c60002 Digital RGB Matrix 1 Register 0x57C
10454 PID:400002 TID:2c60002 Digital RGB Matrix 2 Register 0x159
10455 PID:400002 TID:2c60002 Digital RGB Matrix 3 Register 0x2CB
10456 PID:400002 TID:2c60002 Digital RGB Matrix 4 Register 0x6EE
10457 PID:400002 TID:2c60002 Vertical Data Valid Start Position for Even Field Register 0x0
10458 PID:400002 TID:2c60002 OSD Clock Control 0 Register 0x1
10459 PID:400002 TID:2c60002 OSD Clock Control 1 Register 0x2
10460 PID:400002 TID:2c60002 Horizontal Valid Culling Control 0 Register 0x0
10462 PID:400002 TID:2c60002 Horizontal Valid Culling Control 1 Register 0x0
10463 PID:400002 TID:2c60002 OSD Horizontal Sync Adavnced Register 0x0
10464 PID:400002 TID:2c60002 Clock control Register 0x1
10465 PID:400002 TID:2c60002 Enable gama correction Register 0x0
10466 PID:400002 TID:2c60002
========VPBE OSD Register Dump @ 0x01C70200 ==========
10467 PID:400002 TID:2c60002 OSD MODE 0x1200
10468 PID:400002 TID:2c60002 VIDWIN Mode 0x3
10470 PID:400002 TID:2c60002 OSD0WIN Mode 0x0
10471 PID:400002 TID:2c60002 OSD1WIN Mode 0x0
10472 PID:400002 TID:2c60002 Rectangular Cursor Setup Register 0xF913
10473 PID:400002 TID:2c60002 Video Window 0 Offset Register 0x45
10474 PID:400002 TID:2c60002 Video Window 1 Offset Register 0x0
10475 PID:400002 TID:2c60002 OSD Window 0 Offset Register 0x0
10476 PID:400002 TID:2c60002 OSD Window 1 Offset Register 0x0
10478 PID:400002 TID:2c60002 Video Window 01 Address-High register Register 0x30
10479 PID:400002 TID:2c60002 Video Window 0 Address-Low register Register 0x0
10480 PID:400002 TID:2c60002 Video Window 1 Address-Low register Register 0x0
10481 PID:400002 TID:2c60002 OSD Window 01 Address-High register Register 0x0
10482 PID:400002 TID:2c60002 OSD Window 0 Address-Low register 0x0
10484 PID:400002 TID:2c60002 OSD Window 1 Address-Low register Register 0x0
10485 PID:400002 TID:2c60002 Base Pixel X register Register 0x8A
10486 PID:400002 TID:2c60002 Base Pixel Y register Register 0x12
10487 PID:400002 TID:2c60002 Video Window 0 X-Position Register 0x0
10488 PID:400002 TID:2c60002 Video Window 0 Y-Position Register 0x0
10489 PID:400002 TID:2c60002 Video Window 0 X-Size Register 0x2E0
10490 PID:400002 TID:2c60002 Video Window 0 Y-Size Register 0xF0
10492 PID:400002 TID:2c60002 Video Window 1 X-Position Register 0x0
10493 PID:400002 TID:2c60002 Video Window 1 Y-Position Register 0x0
10494 PID:400002 TID:2c60002 Video Window 1 X-Size Register 0x0
10495 PID:400002 TID:2c60002 Video Window 1 Y-Size Register 0x0
10496 PID:400002 TID:2c60002 OSD Bitmap Window 0 X-Position Register 0x0
10497 PID:400002 TID:2c60002 OSD Bitmap Window 0 Y-Position Register 0x0
10498 PID:400002 TID:2c60002 OSD Bitmap Window 0 X-Size Register 0x0
10499 PID:400002 TID:2c60002 OSD Bitmap Window 0 Y-Size Register 0x0
10501 PID:400002 TID:2c60002 OSD Bitmap Window 1 X-Position Register 0x0
10502 PID:400002 TID:2c60002 OSD Bitmap Window 1 Y-Position Register 0x0
10503 PID:400002 TID:2c60002 OSD Bitmap Window 1 X-Size 0x0
10504 PID:400002 TID:2c60002 OSD Bitmap Window 1 Y-Size Register 0x0
10505 PID:400002 TID:2c60002 Rectangular Cursor Window X-Position Register 0x0
10506 PID:400002 TID:2c60002 Rectangular Cursor Window Y-Position Register 0x0
10507 PID:400002 TID:2c60002 Rectangular Cursor Window X-Size Register 0x2
10509 PID:400002 TID:2c60002 Rectangular Cursor Window Y-Size Register 0x1
10510 PID:400002 TID:2c60002 Window 0 Bitmap Value to Palette Map 0/1 Register 0x0
10511 PID:400002 TID:2c60002 Window 0 Bitmap Value to Palette Map 2/3 Register 0x0
10512 PID:400002 TID:2c60002 Window 0 Bitmap Value to Palette Map 4/5 Register 0x0
10513 PID:400002 TID:2c60002 Window 0 Bitmap Value to Palette Map 6/7 Register 0x0
10514 PID:400002 TID:2c60002 Window 0 Bitmap Value to Palette Map 8/9 Register 0x0
10516 PID:400002 TID:2c60002 Window 0 Bitmap Value to Palette Map A/B Register 0x0
10517 PID:400002 TID:2c60002 Window 0 Bitmap Value to Palette Map C/D Register 0x0
10518 PID:400002 TID:2c60002 Window 0 Bitmap Value to Palette Map E/F Register 0x0
10519 PID:400002 TID:2c60002 Window 1 Bitmap Value to Palette Map 0/1 Register 0x0
10520 PID:400002 TID:2c60002 Window 1 Bitmap Value to Palette Map 2/3 Register 0x0
10521 PID:400002 TID:2c60002 Window 1 Bitmap Value to Palette Map 4/5 Register 0x0
10522 PID:400002 TID:2c60002 Window 1 Bitmap Value to Palette Map 6/7 Register 0x0
10524 PID:400002 TID:2c60002 Window 1 Bitmap Value to Palette Map 8/9 Register 0x0
10525 PID:400002 TID:2c60002 Window 1 Bitmap Value to Palette Map A/B Register 0x0
10526 PID:400002 TID:2c60002 Window 1 Bitmap Value to Palette Map C/D Register 0x0
10527 PID:400002 TID:2c60002 Window 1 Bitmap Value to Palette Map E/F Register 0x0
10528 PID:400002 TID:2c60002 Test mode Register 0x0
10529 PID:400002 TID:2c60002 Extended mode Register 0x0
10530 PID:400002 TID:2c60002 Miscellaneous Control Register 0x1000
10531 PID:400002 TID:2c60002 CLUT RAMYCB Setup Register 0x0
10533 PID:400002 TID:2c60002 CLUT RAM Setup Register 0x0
10534 PID:400002 TID:2c60002 Transparency color code-Lower Register 0x0
10535 PID:400002 TID:2c60002 Transparency color code-Upper Register 0x0
regards,
T.Dilip Chakravarthy
