HI :
I used NVRSOURCE_04.01,
I want to use dec_dis usecase, Once i use this setting run demo with usecase dev_dis,It runs well, when i set it to NVR and run dvrmain,it caused a err: system_dctrl.c: dctrlTriDisplayConfig != NULL : failed !!!The setting of the vdisParams as follows.
May be something set to wrong,but i did not find it.
int DVR_StartSystem(int isNTSC, int main_vout, int sub_vout, int venc_mode)
int i,j, layoutId, fps;
VSYS_PARAMS_S vsysParams;
//VCAP_PARAMS_S vcapParams;
//VENC_PARAMS_S vencParams;
VDEC_PARAMS_S vdecParams;
VDIS_PARAMS_S vdisParams;
VDIS_MOSAIC_S sVdMosaicParam;
Bool forceLowCostScale = FALSE;
UInt64 wallTimeBase;
AUDIO_STATE *pAudstate = &gAudio_state ;
pAudstate->pbchannel = 0;
VdecVdis_bitsRdInit();
#ifdef VDEC_VDIS_ENABLE_IPCFRAMESOUT
VdecVdis_ipcFramesCreate();
#endif
TRACE_APP("\n");
#if 0
gDemo_info.maxVcapChannels = 0;
gDemo_info.maxVdisChannels = gVdecVdis_config.fileNum;
gDemo_info.maxVencChannels = 0;
gDemo_info.maxVdecChannels = gVdecVdis_config.fileNum;
vdecParams.numChn = gVdecVdis_config.fileNum;
vdisParams.numChannels = gVdecVdis_config.fileNum;
#endif
TRACE_APP("\n");
Vsys_params_init(&vsysParams);
vsysParams.systemUseCase = VSYS_USECASE_MULTICHN_VDEC_VDIS;
vsysParams.enableCapture = FALSE;
vsysParams.enableNsf = FALSE;
vsysParams.enableEncode = FALSE;
vsysParams.enableDecode = TRUE;
vsysParams.enableNullSrc = FALSE;
vsysParams.enableAVsync = TRUE;
vsysParams.numDeis = 0;
vsysParams.numSwMs = 2;
vsysParams.numDisplays = 2;
#ifdef DEBUG_TRS_LCD_DISPLAY
TRACE_APP("\n");
// vcapParams.numChn = 3;
// vencParams.numPrimaryChn = 3;
vdecParams.numChn = 1;
vdisParams.numChannels = 1;
//vsysParams.numChs = 1;
#else
vsysParams.systemUseCase = VSYS_USECASE_MULTICHN_PROGRESSIVE_VCAP_VDIS_VENC_VDEC;
// vcapParams.numChn = 16;
// vencParams.numPrimaryChn = 16;
vdecParams.numChn = 16;
vdisParams.numChannels = 32;
vsysParams.numChs = 16;
#endif
#if 0
//CIF output setting///
#ifdef RTSP_STREAM_ENABLE
vsysParams.enableSecondaryOut = TRUE;
vsysParams.enableNsf = TRUE;
vencParams.numSecondaryChn = 16;
#else
vsysParams.enableSecondaryOut = FALSE;
vencParams.numSecondaryChn = 0;
#endif
vsysParams.enableMjpegEnc = FALSE;
vsysParams.enableCapture = TRUE;
vsysParams.enableOsd = TRUE;
vsysParams.enableScd = FALSE;
vsysParams.numDeis = 2;
vsysParams.numDisplays = 3;
#endif
printf ("--------------- CHANNEL DETAILS-------------\n");
// printf ("Capture Channels => %d\n", vcapParams.numChn);
// printf ("Enc Channels => Primary %d, Secondary %d\n", vencParams.numPrimaryChn, vencParams.numSecondaryChn);
printf ("Dec Channels => %d\n", vdecParams.numChn);
printf ("Disp Channels => %d\n", vdisParams.numChannels);
printf ("-------------------------------------------\n");
DVR_Override960HParamsInitSettings();
TRACE_APP("\n");
/* Override the context here as needed */
DVR_Override960HParamsVsys(&vsysParams);
TRACE_APP("\n");
Vsys_init(&vsysParams);
TRACE_APP("\n");
#if 0
for(i=0;i<MAX_DVR_CHANNELS;i++)
vcapParams.channelParams[i].dynamicParams.contrast = gInitSettings.camera[i].coloradjust.iContrast;
vcapParams.channelParams[i].dynamicParams.satauration = gInitSettings.camera[i].coloradjust.iSaturation;
vcapParams.channelParams[i].dynamicParams.brightness = gInitSettings.camera[i].coloradjust.iBrightness;
DVR_Override960HParamsVcap(&vcapParams);
Vcap_init(&vcapParams);
switch(gInitSettings.camera[i].camrec.iFps)
case FRAMERATE_30_25:
if(isNTSC == CAM_NTSC)
fps = 30*1000;
else
fps = 25*1000;
break;
case FRAMERATE_15_13:
fps = 15*1000;
else
fps = 13*1000;
break;
case FRAMERATE_08_06:
fps = 8*1000;
else
fps = 6*1000;
break;
case FRAMERATE_04_03:
fps = 4*1000;
else
fps = 3*1000;
break;
default:
fps = 30*1000;
else
fps = 25*1000;
break;
vencParams.encChannelParams[i].dynamicParam.frameRate = fps;
vencParams.encChannelParams[i].enableAnalyticinfo = 1 ;
int bps = gInitSettings.camera[i].camrec.ikbps*1000;
if(bps >= 64000 && bps <= 4000000)
vencParams.encChannelParams[i].dynamicParam.targetBitRate = bps;
switch(gInitSettings.camera[i].camrec.iIFrameInterval)
case IFRAME_INTERVAL_30_25:
vencParams.encChannelParams[i].dynamicParam.intraFrameInterval = 30;
else
vencParams.encChannelParams[i].dynamicParam.intraFrameInterval = 25;
break;
case IFRAME_INTERVAL_15_13:
vencParams.encChannelParams[i].dynamicParam.intraFrameInterval = 15;
else
vencParams.encChannelParams[i].dynamicParam.intraFrameInterval = 13;
break;
case IFRAME_INTERVAL_10_6:
vencParams.encChannelParams[i].dynamicParam.intraFrameInterval = 10;
else
vencParams.encChannelParams[i].dynamicParam.intraFrameInterval = 6;
break;
case IFRAME_INTERVAL_5_3:
vencParams.encChannelParams[i].dynamicParam.intraFrameInterval = 5;
else
vencParams.encChannelParams[i].dynamicParam.intraFrameInterval = 3;
break;
case IFRAME_INTERVAL_1:
vencParams.encChannelParams[i].dynamicParam.intraFrameInterval = 1;
break;
default:
else
break;
if(gInitSettings.camera[i].camrec.iBitrateType == BITRATE_TYPE_CBR)
vencParams.encChannelParams[i].rcType = VENC_RATE_CTRL_CBR;
else
vencParams.encChannelParams[i].rcType = VENC_RATE_CTRL_VBR;
DVR_Override960HParamsVenc(&vencParams);
Venc_init(&vencParams);
#endif
//Vcap_params_init(&vcapParams);
//Venc_params_init(&vencParams);
TRACE_APP("\n");
Vdec_params_init(&vdecParams);
vdecParams.forceUseDecChannelParams = TRUE ; // Pal
for (i=0; i < vdecParams.numChn; i++)
vdecParams.decChannelParams[i].dynamicParam.frameRate = 30; // NOT USED
vdecParams.decChannelParams[i].dynamicParam.targetBitRate = 2 * 1000 * 1000; // NOT USED
vdecParams.decChannelParams[i].maxVideoWidth = 1920; //gVdecVdis_config.fileInfo[i].width;//720;//gInitSettings.dvrMode.width;
vdecParams.decChannelParams[i].maxVideoHeight = 1080;// gVdecVdis_config.fileInfo[i].height;//576;//gInitSettings.dvrMode.height;
TRACE_APP("i=%d vdecParams.decChannelParams[i].maxVideoWidth=%d",i,vdecParams.decChannelParams[i].maxVideoWidth);
TRACE_APP("i=%d vdecParams.decChannelParams[i].maxVideoHeight=%d",i,vdecParams.decChannelParams[i].maxVideoHeight);
/*If the codec type is missing, by default choose h264*/
vdecParams.decChannelParams[i].isCodec = VDEC_CHN_H264;
vdecParams.decChannelParams[i].displayDelay = 0;
vdecParams.decChannelParams[i].numBufPerCh = 0;
vdecParams.decChannelParams[i].tilerEnable = TRUE;
vdecParams.decChannelParams[i].enableWaterMarking = 0;
DVR_Override960HParamsVdec(&vdecParams);
Vdec_init(&vdecParams);
TRACE_APP("\n");
//V_dis
Vdis_params_init(&vdisParams);
gLiveDspId = gInitSettings.layout.iMainOutput;
gPlayDspId = gInitSettings.layout.iSubOutput;
TRACE_APP("gLiveDspId=%d gPlayDspId=%d \n",gLiveDspId,gPlayDspId);
vdisParams.deviceParams[gLiveDspId].resolution = DEMO_HD_DISPLAY_DEFAULT_STD;//VSYS_STD_1080P_60;
vdisParams.deviceParams[gPlayDspId].resolution = DEMO_HD_DISPLAY_DEFAULT_STD;//VSYS_STD_1080P_60;
/* Since HDCOMP and HDMI are tied together they must have same resolution */
vdisParams.deviceParams[VDIS_DEV_HDMI].resolution = vdisParams.deviceParams[gLiveDspId].resolution;
vdisParams.deviceParams[VDIS_DEV_DVO2].resolution = vdisParams.deviceParams[gPlayDspId].resolution;
vdisParams.deviceParams[VDIS_DEV_SD].resolution = VSYS_STD_NTSC;// VSYS_STD_PAL;
TRACE_APP("--------------\n");
TRACE_APP("vdisParams.deviceParams[VDIS_DEV_DVO2].resolution=%d \n",
vdisParams.deviceParams[VDIS_DEV_DVO2].resolution );
printf("vdisParams.\n",vdisParams.deviceParams[VDIS_DEV_HDMI].resolution);
Vdis_tiedVencInit(VDIS_DEV_HDMI, VDIS_DEV_DVO2, &vdisParams);
switch(gInitSettings.layout.iLayoutMode)
case LIB_LAYOUTMODE_1:
layoutId = MULTICH_LAYOUT_MODE_1CH;
break;
case LIB_LAYOUTMODE_4:
layoutId = MULTICH_LAYOUT_MODE_2x2_4CH;
break;
case LIB_LAYOUTMODE_9:
layoutId = MULTICH_LAYOUT_MODE_3x3_9CH;
break;
case LIB_LAYOUTMODE_8:
layoutId = MULTICH_LAYOUT_MODE_1x1_8CH;
break;
case LIB_LAYOUTMODE_8_1:
layoutId = MULTICH_LAYOUT_MODE_2x2_8CH;
break;
case LIB_LAYOUTMODE_12:
layoutId = MULTICH_LAYOUT_MODE_4x3_12CH;
break;
case LIB_LAYOUTMODE_12_1:
layoutId = MULTICH_LAYOUT_MODE_12CH;
break;
case LIB_LAYOUTMODE_14:
layoutId = MULTICH_LAYOUT_MODE_14CH;
break;
case LIB_LAYOUTMODE_16:
layoutId = MULTICH_LAYOUT_MODE_4x4_16CH;
break;
case LIB_LAYOUTMODE_20:
break;
case LIB_LAYOUTMODE_CAMFLOW:
break;
default:
break;
DVR_swMsGenerateLayouts(gLiveDspId, 0, MAX_CH*2, layoutId, &(vdisParams.mosaicParams[gLiveDspId]),
forceLowCostScale, vdisParams.deviceParams[gLiveDspId].resolution, 0);
vdisParams.mosaicParams[gLiveDspId].userSetDefaultSWMLayout = TRUE;
for (i=0; i<vdisParams.mosaicParams[gLiveDspId].numberOfWindows; i++)
gMosaicInfo_Live.chMap[i] = vdisParams.mosaicParams[gLiveDspId].chnMap[i];
gMosaicInfo_Live.layoutId = layoutId;
gMosaicInfo_Live.numWin = vdisParams.mosaicParams[gLiveDspId].numberOfWindows;
gMosaicInfo_Live.isCamPropMode = 0;
switch(gInitSettings.layout.iSecondLayoutMode)
break;
break;
break;
break;
break;
break;
break;
break;
break;
break;
break;
default:
break;
if(gInitSettings.layout.iMainOutput != gInitSettings.layout.iSubOutput)
DVR_swMsGenerateLayouts(gPlayDspId, MAX_CH, MAX_CH*2, layoutId, &(vdisParams.mosaicParams[gPlayDspId]),
forceLowCostScale,vdisParams.deviceParams[gPlayDspId].resolution, 0);
vdisParams.mosaicParams[gPlayDspId].userSetDefaultSWMLayout = TRUE;
for (i=0; i<vdisParams.mosaicParams[gPlayDspId].numberOfWindows; i++)
gMosaicInfo_Play.chMap[i] = vdisParams.mosaicParams[gPlayDspId].chnMap[i];
vdisParams.mosaicParams[gPlayDspId].chnMap[i] = VDIS_CHN_INVALID;
gMosaicInfo_Play.layoutId = layoutId;
gMosaicInfo_Play.numWin = vdisParams.mosaicParams[gPlayDspId].numberOfWindows;
gMosaicInfo_Play.isCamPropMode = 0;
else
DVR_swMsGenerateLayouts(VDIS_DEV_HDCOMP, MAX_CH, MAX_CH*2, layoutId, &(vdisParams.mosaicParams[VDIS_DEV_HDCOMP]),
forceLowCostScale,vdisParams.deviceParams[VDIS_DEV_HDCOMP].resolution, 0);
vdisParams.mosaicParams[VDIS_DEV_HDCOMP].userSetDefaultSWMLayout = TRUE;
for (i=0; i<vdisParams.mosaicParams[VDIS_DEV_HDCOMP].numberOfWindows; i++)
gMosaicInfo_Play.chMap[i] = vdisParams.mosaicParams[VDIS_DEV_HDCOMP].chnMap[i];
vdisParams.mosaicParams[VDIS_DEV_HDCOMP].chnMap[i] = VDIS_CHN_INVALID;
gMosaicInfo_Play.layoutId = gMosaicInfo_Live.layoutId;
gMosaicInfo_Play.numWin = gMosaicInfo_Live.numWin;
vdisParams.enableLayoutGridDraw = FALSE;
vdisParams.tiedDevicesMask = VDIS_DEV_DVO2;
DVR_Override960HParamsVdis(&vdisParams);
Vdis_init(&vdisParams);
/* Init the application specific module which will handle bitstream exchange */
WRITER_create();
wallTimeBase = get_current_time_to_msec();
Vdis_setWallTimeBase(wallTimeBase);
/* Configure display */
Vsys_configureDisplay();
printf("=====Going to Vsys_create=========\n");
/* Create Link instances and connects compoent blocks */
Vsys_create();
#if 0
if(vsysParams.enableSecondaryOut)
Int32 chId;
VENC_CHN_DYNAMIC_PARAM_S params = { 0 };
for (chId=0; chId < vencParams.numPrimaryChn; chId++)
/* now use VIP-SC secondary output, so input to VIP-SC and VIP-SC secondary channel are both
half of the real input framerate */
/* At capture level,YUV420 D1 stream id is 1. Set for D1 channels 0 ~ MAX_CH */
Vcap_setFrameRate(chId, 1, 30, 30);
/* At capture level,YUV422 D1 stream id is 0. Set for D1 channels 0 ~ MAX_CH */
Vcap_setFrameRate(chId, 0, 60, 0);
Int32 i;
if((vdisParams.mosaicParams[gLiveDspId].chnMap[i] == chId) && (vdisParams.mosaicParams[gLiveDspId].useLowCostScaling[i] == FALSE))
Vcap_setFrameRate(chId,0,30,30); // Arun -Vcap_setFrameRate(chId,0,60,30);
if((vdisParams.mosaicParams[gPlayDspId].chnMap[i] == chId) && (vdisParams.mosaicParams[gPlayDspId].useLowCostScaling[i] == FALSE))
Vcap_setFrameRate(chId,0,30,30); // Arun - Vcap_setFrameRate(chId,0,60,30);
/* At capture level, CIF stream id is 2. Set for CIF channels 0 ~ MAX_CH */
Vcap_setFrameRate(chId, 2, 30, 30);
for(chId=0;chId<vencParams.numPrimaryChn;chId++)
memset(¶ms, 0, sizeof(params));
Venc_setInputFrameRate(chId, CIF_FPS_DEI_NTSC);
params.frameRate = CIF_FPS_DEI_NTSC;
Venc_setDynamicParam(chId, 0, ¶ms, VENC_FRAMERATE);
Venc_setInputFrameRate(chId+vencParams.numPrimaryChn, CIF_FPS_DEI_NTSC);
params.frameRate = CIF_FPS_ENC_NTSC;
params.targetBitRate = CIF_BITRATE * 1000;
/* At encode level, CIF channel id is 16 ~ 31. Stream id is immaterial */
Venc_setDynamicParam(chId+vencParams.numPrimaryChn, 0, ¶ms, VENC_FRAMERATE);
if (vencParams.numTertiaryChn)
Venc_setInputFrameRate(chId+(vencParams.numPrimaryChn*3), CIF_FPS_DEI_NTSC);
params.targetBitRate = 125 * 1000;
Venc_setDynamicParam(chId+(vencParams.numPrimaryChn*3), 0, ¶ms, VENC_FRAMERATE);
#endif
/* Start components in reverse order */
Vdis_start();
Vdec_start();
// Venc_start();
//Vcap_start();
//Vdis_stopDrv(VDIS_DEV_HDMI);
// Vdis_stopDrv(VDIS_DEV_DVO2);
Vdis_startDrv(VDIS_DEV_HDMI);
Vdis_startDrv(VDIS_DEV_DVO2);
#if 0
isNTSC = Vcap_detectVideoInfo();
if(isNTSC == VSYS_STD_PAL)
printf("\nFirst Camera connected is of PAL type\n");
else if(isNTSC == VSYS_STD_NTSC)
printf("\nFirst Camera connected is of NTSC type\n");
DVR_GetSourceStatus();
UInt32 chId;
VCAP_VIDEO_SOURCE_STATUS_S videoSourceStatus;
VCAP_VIDEO_SOURCE_CH_STATUS_S *pChStatus;
Vcap_getVideoSourceStatus( &videoSourceStatus );
for(chId=0; chId<videoSourceStatus.numChannels; chId++)
pChStatus = &videoSourceStatus.chStatus[chId];
if(pChStatus->isVideoDetect)
if(pChStatus->frameHeight == 288)
Venc_setInputFrameRate(chId, CIF_FPS_DEI_PAL);
switch(gInitSettings.camera[chId].camrec.iFps)
params.frameRate = 25;
break;
params.frameRate = 13;
break;
params.frameRate = 6;
break;
params.frameRate = 3;
break;
default:
break;
Venc_setInputFrameRate(chId+vencParams.numPrimaryChn, CIF_FPS_DEI_PAL);
params.frameRate = CIF_FPS_ENC_PAL;
else if(pChStatus->frameHeight == 240)
params.frameRate = 30;
break;
params.frameRate = 15;
break;
params.frameRate = 8;
break;
params.frameRate = 4;
break;
default:
break;
else
printf (" DEMO: %2d: No video detected at CH [%d,%d] !!!\n",
chId, pChStatus->vipInstId, pChStatus->chId);
VCAP_CHN_DYNAMIC_PARAM_S params;
for(i = 0; i<MAX_DVR_CHANNELS; i++)
for(j = 0; j < ALG_LINK_OSD_MAX_WINDOWS; j++)
g_osdChParam[i].winPrm[j].enableWin = 0;
/* max value check below need to be fixed below based upon capture max width and height*/
params.osdChWinPrm = &g_osdChParam[i];
Vcap_setDynamicParamChn(i, ¶ms, VCAP_OSDWINPRM);
DVR_setCaptureResolution(i, gInitSettings.camera[i].camrec.iResolution);
#endif
if(gInitSettings.camera[i].iEnable == 0)
DVR_SetCameraEnable(i, gInitSettings.camera[i].iEnable);
if(gInitSettings.playbackcamera[i].iEnable == 0)
DVR_SetCameraEnable(MAX_CH+i, gInitSettings.playbackcamera[i].iEnable);
grpx_fb_start();
DVR_SetSpotChannel(gInitSettings.iSpotOutputCh);
DVR_setOff_GRPX() ;
if(gInitSettings.layout.iMainOutput != VDIS_DEV_HDMI)
DVR_SwitchDisplay(gInitSettings.layout.iMainOutput, gInitSettings.layout.iSubOutput, 1);
printf("\n ===============Switch Display Done========================= \n");
if(gInitSettings.maindisplayoutput.iResolution != DC_MODE_1080P_60)
DVR_SetDisplayRes(gInitSettings.layout.iMainOutput, gInitSettings.maindisplayoutput.iResolution, 0);
printf("\n ===============Main Output Resolution Switch Done========== \n");
if(gInitSettings.subdisplayoutput.iResolution != DC_MODE_1080P_60)
DVR_SetDisplayRes(gInitSettings.layout.iSubOutput, gInitSettings.subdisplayoutput.iResolution, 0);
printf("\n ===============Sub Output Resolution Switch Done=========== \n");
DVR_setOff_GRPX() ;
DVR_SetMosaicLayout(LIB_LAYOUTMODE_16); //Arun
#ifdef DVRAPP_960H_ENABLE
DVR_SetPlaybackMosaicLayout(LIB_LAYOUTMODE_4);
#endif /* DVRAPP_960H_ENABLE */
#ifdef AUDIO_STREAM_ENABLE
DVR_setAudioInputParams(AUDIO_SAMPLE_RATE_DEFAULT, gInitSettings.audioin.iVolume);
Audio_playStart(gInitSettings.audioout.iDevId);
Audio_playSetVolume(gInitSettings.audioout.iVolume*10);
Audio_captureStart();
sleep(1);
#endif
printf("\n ================DVR_StartSystem Done===================== \n");
return 0;
