there is a process of eMMC flashing described here
A debrick script is mentioned. Is there a download link for it?
--Gunter
--Gunter
Hi Gunter,
As stated here, the instructions on thе page are still work in progress. Please take a look at the following pages for reference eMMC flasher scripts:
http://www.crashcourse.ca/wiki/index.php/BBB_software_update_process
https://github.com/RobertCNelson/tools/blob/master/scripts/beaglebone-black-copy-microSD-to-eMMC.sh
The script from the second link is pretty much what you need. You just need to modify it to load the files via TFTP and not from the SD card.
Miroslav
Hi Miroslav,
I am following the link (http://processors.wiki.ti.com/index.php/Sitara_Linux_Program_the_eMMC_on_Beaglebone_Black) for flashing beaglebone black using uniflash in production environment onto eMMC And am using windows as host,
1) Could you please confirm is the above script ie., https://github.com/RobertCNelson/tools/blob/master/scripts/beaglebone-black-copy-microSD-to-eMMC.sh can be used without any modification as debrick.sh??..
And I have copied all the below files into (c:\AM335x_images by default as per the link http://processors.wiki.ti.com/index.php/Sitara_Linux_Program_the_eMMC_on_Beaglebone_Black ).
Could you please let me know if there are any other files to be put into c:\AM335x_images, because I was confused when I was going through the other link ie., (http://processors.wiki.ti.com/index.php/Sitara_Linux_AM335x_Flash_Programming_Linux_Development#eMMC_Programming_Process)
Or only the above files is sufficient
2) Can I use uboot.img & image.fit (verified boot , signed images) format files for flashing into eMMC by following the link (http://processors.wiki.ti.com/index.php/Sitara_Linux_Program_the_eMMC_on_Beaglebone_Black) using uniflash,If so how can I flash this uboot.img & image.fit ( ie., signed kernel image) onto eMMC using Uniflash
Could you please do the needful as early as possible, as am stuck with this from many days
Awaiting for your replies,
Many Thanks in advance
Hi Srini,
Miroslav is not in his role so you can followup the following threads.
http://e2e.ti.com/support/embedded/linux/f/354/t/382761.aspx
http://e2e.ti.com/support/embedded/linux/f/354/t/380960.aspx
http://e2e.ti.com/support/embedded/linux/f/354/t/382809.aspx
