https using lighttpd in am335x
Hello
     Im working on bringing https connection using lighttpd in am335x. But Im getting the following error, while producing the CSR (Certificate Signalling Request). I tried as I can , still im facing the same issue.
1073805024:error:0606B06E:digital envelope routines:EVP_SignFinal:wrong public key type:p_sign.c:125:
1073805024:error:0D0C3006:asn1 encoding routines:ASN1_item_sign:EVP lib:a_sign.c:279:
Thanks in advance
Arun
  • Hi Arun,
    The lighttpd package that comes with the AM335x SDK isn't compiled with SSL support. Perhaps this is the reason for your errors. To verify this, type:
    lighttpd -V
    The output is as follows:
    root@am335x-evm:~# lighttpd -V
    lighttpd/1.4.31 - a light and fast webserver
    Build-Date: Jun 25 2013 16:50:19
    Event Handlers:
        + select (generic)
        + poll (Unix)
        - rt-signals (Linux 2.4+)
        + epoll (Linux 2.6)
        - /dev/poll (Solaris)
        - eventports (Solaris)
        - kqueue (FreeBSD)
        - libev (generic)
    Network handler:
        - linux-sendfile
        - freebsd-sendfile
        - solaris-sendfilev
        + writev
        + write
        - mmap support
    Features:
        + IPv6 support
        + zlib support
        - bzip2 support
        + crypt support
        - SSL Support
        + PCRE support
        - mySQL support
        - LDAP support
        - memcached support
        - FAM support
        - LUA support
        - xml support
        - SQLite support
        - GDBM support
    Please refer to the lighttpd wiki page for information on how to compile and use lighttpd with secure http.
    Miroslav
  • Hi Miroslav,
    I cross compiled with lighttpd with ssl and while I execute "lighttpd -V" . I got the following saying ssl is enabled
    lighttpd/1.4.33 (ssl) - a light and fast webserver
    Build-Date: Apr 29 2014 12:40:33
    Event Handlers:
            + select (generic)
            + poll (Unix)
            + epoll (Linux 2.6)
            - kqueue (FreeBSD)
            - libev (generic)
    Network handler:
            - linux-sendfile
            - freebsd-sendfile
            - solaris-sendfilev
            + writev
            + write
            - mmap support
    Features:
            - IPv6 support
            - zlib support
            - bzip2 support
            + crypt support
            + SSL Support
            + PCRE support
            - mySQL support
            - LDAP support
            - memcached support
            - FAM support
            - LUA support
            - xml support
            - SQLite support
            - GDBM support
    Arun
  • Dear Sir,
    I have cross compiled lighttpd1.4.30 version for beaglebone white.  I am able to run the webserver form beaglebone.
    I have crosscompiling the lighttpd with SSL support, and copying the generated binaries in /usr/sbin and librariries in /usr/lib/lighttpd.
    Checking with command : lighttpd -V in beaglebone, give below output:
    root@am335x-evm:/usr/sbin# lighttpd -V
    lighttpd/1.4.30 (ssl) - a light and fast webserver
    Build-Date: Jun  9 2014 17:14:24
    Event Handlers:
            + select (generic)
            + poll (Unix)
            + epoll (Linux 2.6)
            - kqueue (FreeBSD)
            - libev (generic)
    Network handler:
            + writev
            + mmap support
    Features:
            + IPv6 support
            - zlib support
            - bzip2 support
            + crypt support
            + SSL Support
            + PCRE support
            - mySQL support
            - LDAP support
            - memcached support
            - FAM support
            - LUA support
            - xml support
            - SQLite support
            - GDBM support
    I generated the RSA key using following command:
    openssl genrsa -des3 -out maipl.com.key 1024
    Now, when i try to generate CSR key file using below command
    openssl req -new -key maipl.com.key -out maipl.com.csr, it shows following error:
    1074243296:error:0606B06E:digital envelope routines:EVP_SignFinal:wrong public key type:p_sign.c:125:
    1074243296:error:0D0C3006:asn1 encoding routines:ASN1_item_sign:EVP lib:a_sign.c:279:
    Please suggest me what can be cause of problem.
    Following are the data entered for csr key file.
    root@am335x-evm:/etc/lighttpd/ssl/gps.in# ls
    maipl.com.key
    ut maipl.com.csr/etc/lighttpd/ssl/gps.in# openssl req -new -key maipl.com.key -o
    Enter pass phrase for maipl.com.key:
    You are about to be asked to enter information that will be incorporated
    into your certificate request.
    What you are about to enter is what is called a Distinguished Name or a DN.
    There are quite a few fields but you can leave some blank
    For some fields there will be a default value,
    If you enter '.', the field will be left blank.
    Country Name (2 letter code) [AU]:in
    State or Province Name (full name) [Some-State]:guj
    Locality Name (eg, city) []:gnaga
    Organization Name (eg, company) [Internet Widgits Pty Ltd]:masibus
    Organizational Unit Name (eg, section) []:rnd
    Common Name (e.g. server FQDN or YOUR name) []:ajay
    Email Address []:ajayrajput@masibus.com
    Please enter the following 'extra' attributes
    to be sent with your certificate request
    A challenge password []:masibus1975
    An optional company name []:
    Thanks.
