Flip mirror using the program given in facedetect demoLCDK 6748
Other Parts Discussed in Thread: OMAPL138
Hello !!
I will use the program given by TI to do facedetect. I would use the some code to do a flip mirror using the function flip in the cxcore.h . I need to call this function in the main.How I can do this? I need to create a task?
The second modification is to rad the state of the switches. I posted this question in another post but i didn't have the good answer. I think that this the IN_DATAn register.
I don't see how to do this. I think it is simple but i don't see. Could you help me please in the attached file.
Thanks&regards
 * facedetect_lcdk.c
 * This file contains face detection demo code for LCDK.
 * Copyright (C) 2009 Texas Instruments Incorporated - http://www.ti.com/
 *  Redistribution and use in source and binary forms, with or without
 *  modification, are permitted provided that the following conditions
 *  are met:
 *    Redistributions of source code must retain the above copyright
 *    Redistributions in binary form must reproduce the above copyright
 *    documentation and/or other materials provided with the
 *    distribution.
 *    Neither the name of Texas Instruments Incorporated nor the names of
 *  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
 *  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
 *  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
 *  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
 *  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
 *  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
 *  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
 *  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
 *  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
 *  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
 *  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
 *  \file   facedetect_lcdk.c
 *  \brief  This file contains the face detection demo code for LCDK.
 *          This application captures the live camera input which is then
 * 			passed to the DSP. The DSP runs the face detection algorithm
 * 			provided by OpenCV and draws a rectangular box around the
 * 			detected face. The output is displayed over LCDC.
/*                          INCLUDE FILES                                     */
#include <xdc/std.h>
#include <xdc/runtime/Error.h>
#include <xdc/runtime/System.h>
#include <ti/sysbios/BIOS.h>
#include <ti/sysbios/knl/Clock.h>
#include <ti/sysbios/knl/Task.h>
#include <ti/sysbios/knl/Semaphore.h>
#include <ti/sysbios/family/c64p/Hwi.h>
#include <stdio.h>
#include "psc.h"
#include "vpif.h"
#include "raster.h"
#include "interrupt.h"
#include "lcdkC6748.h"
#include "soc_C6748.h"
#include "hw_psc_C6748.h"
#include "adv7343.h"
#include "tvp5147.h"
#include "cdce913.h"
#include "codecif.h"
#include "i2cgpio.h"
#include "cv.h"
#include "cxtypes.h"
#include "string.h"
#include "facedetect.h"
**                      INTERNAL MACROS
#define MSTPRI1									(0x01C14114)
#define MSTPRI2									(0x01C14118)
#define CAPTURE_IMAGE_WIDTH					 	(720)
#define CAPTURE_IMAGE_HEIGHT				 	(488)
#define DISPLAY_IMAGE_WIDTH						(640)
#define DISPLAY_IMAGE_HEIGHT					(480)
#define CLASSIFIER_CASCADE_SIZE      			(52519)
#define REFERENCE_LOCATION_1         			(0xC30011B0)
#define REFERENCE_LOCATION_2		 			(0xC303464B)
#define CV_DEFAULT_IMAGE_ROW_ALIGN   			(8)
#define I2C_SLAVE_CODEC_ADV7343                 (0x2Au)
#define I2C_SLAVE_CODEC_TVP5147_1_SVIDEO    	(0x5Cu)
#define I2C_SLAVE_CODEC_TVP5147_2_COMPOSITE    	(0x5Du)
#define I2C_SLAVE_CDCE913      					(0x65u)
#define I2C_SLAVE_UI_EXPANDER	      			(0x20u)
#define INT_CHANNEL_I2C                       	(0x2u)
#define OFFSET1									((CAPTURE_IMAGE_HEIGHT - DISPLAY_IMAGE_HEIGHT)/2)
#define OFFSET2									((CAPTURE_IMAGE_WIDTH - DISPLAY_IMAGE_WIDTH)/2)
#define OFFSET 									(CAPTURE_IMAGE_WIDTH * OFFSET1 + OFFSET2)
**                      GLOBAL FUNCTION PROTOTYPES
extern void cbcr422sp_to_rgb565_c(const unsigned char * restrict, unsigned int,
		unsigned int, const short*, const unsigned char *restrict,
		unsigned int, unsigned short *restrict, unsigned int, unsigned);
**                      INTERNAL FUNCTION PROTOTYPES
static void SetUpVPIFRx(void);
static void SetUpLCD(void);
Void VPIFIsr(UArg arg);
Void LCDIsr(UArg arg);
Void colorconvertTask(UArg arg0, UArg arg1);
Void facedetectTask(UArg arg0, UArg arg1);
Void clockHandler(UArg arg);
**                      INTERNAL VARIABLE DEFINITIONS
unsigned int            pingpong=1, buffcount=0, buffcount2, display_buff_1=0;
int 					facedetect_complete=1, buffer_ready=0;
volatile unsigned int   changed=1, updated=3, processed=1;
unsigned char 			*buff_luma[2], *buff_chroma[2];
unsigned char			buff_luma1[CAPTURE_IMAGE_WIDTH * CAPTURE_IMAGE_HEIGHT];
unsigned char			buff_luma2[CAPTURE_IMAGE_WIDTH * CAPTURE_IMAGE_HEIGHT];
unsigned char			buff_chroma1[CAPTURE_IMAGE_WIDTH * CAPTURE_IMAGE_HEIGHT];
unsigned char			buff_chroma2[CAPTURE_IMAGE_WIDTH * CAPTURE_IMAGE_HEIGHT];
unsigned char			proc_buff_luma[DISPLAY_IMAGE_WIDTH * DISPLAY_IMAGE_HEIGHT];
unsigned char           *videoTopY, *videoTopC, *proc_buff_ptr;
unsigned short          *videoTopRgb1, *videoTopRgb2;
unsigned short          Rgb_buffer1[DISPLAY_IMAGE_WIDTH*DISPLAY_IMAGE_HEIGHT + 16];
unsigned short			Rgb_buffer2[DISPLAY_IMAGE_WIDTH*DISPLAY_IMAGE_HEIGHT + 16];
const short             ccCoeff[5] = {0x2000, 0x2BDD, -0x0AC5, -0x1658, 0x3770};
CvHaarClassifierCascade 	*cascade;
IplImage 					*image=NULL, *image1=NULL;
CvMemStorage 				*storage;
CvSeq 						*dsp_sequence = NULL, *dsp_sequence2 = NULL;
CvScalar 	  				blue = {255, 0, 0, 0};
CvPoint 					c1, c2;
CvRect 						*r;
Semaphore_Handle 			sem1;
Semaphore_Handle 			sem2;
**                       FUNCTION DEFINITIONS
Void main()
	Hwi_Params 		params;
	Hwi_Handle 		Hwi1, Hwi2;
	Task_Params 	taskParams;
	Task_Handle 	task1, task2;
	Clock_Params 	clockParams;
	Clock_Handle 	Clk;
	Error_Block 	eb;
    /* Create a Semaphore object to be use as a resource lock */
    sem1 = Semaphore_create(0, NULL, NULL);
    sem2 = Semaphore_create(0, NULL, NULL);
	/* Create the Color Convert Task */
    Error_init(&eb);
	Task_Params_init(&taskParams);
	taskParams.priority = 1;
	taskParams.stackSize = 10000;
	task1 = Task_create(colorconvertTask, &taskParams, &eb);
	if (task1 == NULL)
		System_printf("Task_create() failed for Color Conversion!\n");
		BIOS_exit(0);
	/* Create the FaceDetect Task*/
	task2 = Task_create(facedetectTask, &taskParams, &eb);
	if (task2 == NULL)
		System_printf("Task_create() failed for Face Detection!\n");
		BIOS_exit(0);
	/* Create the VPIF Interrupt*/
	Hwi_Params_init(&params);
	params.eventId = 95;
	params.enableInt = FALSE;
	Hwi1 = Hwi_create(8, &VPIFIsr, &params, &eb);
	if (Hwi1 == NULL)
		System_printf("Hwi_create() failed for VPIF!\n");
		BIOS_exit(0);
	/* Create the LCDC Interrupt*/
	params.eventId = 73;
	Hwi2 = Hwi_create(9, &LCDIsr, &params, &eb);
	if (Hwi2 == NULL)
		System_printf("Hwi_create() failed for LCDC!\n");
		BIOS_exit(0);
	/* Create a clock that would go off every 1 Clock tick*/
	Clock_Params_init(&clockParams);
	clockParams.period = 1;
	clockParams.startFlag = TRUE;
	Clk = Clock_create((Clock_FuncPtr)clockHandler, 4, &clockParams, &eb);
	if (Clk == NULL) {
	System_abort("Clock0 create failed");
	/* Setting the Master priority for LCD DMA controller to highest level */
	*((volatile uint32_t *) MSTPRI2) = *((volatile uint32_t *) MSTPRI2) & 0x0FFFFFFF;
	BIOS_start(); /* enable interrupts and start SYS/BIOS */
** ClockHandler
	/* Call Task_yield every 1 ms */
	Task_yield();
** ColorconvertTask - This would color convert the captured frames and make it available for the LCDC display.
** Also, if the facedetect algorithm has finished working on the frame provided, it would provide a new frame.
Void colorconvertTask(UArg a0, UArg a1)
	int   i, *buffer;
	/* Allocate and initialize 'image' which would then be passed to the face detection algorithm */
	image = (IplImage *) cvAlloc(sizeof(*image));
	cvInitImageHeader(image, cvSize(DISPLAY_IMAGE_WIDTH, DISPLAY_IMAGE_HEIGHT), IPL_DEPTH_8U, 1,
			IPL_ORIGIN_TL, CV_DEFAULT_IMAGE_ROW_ALIGN);
	/* Allocate and initialize 'image1' which would then be used to draw a box on the output buffer */
	image1 = (IplImage *) cvAlloc(sizeof(*image1));
	cvInitImageHeader(image1, cvSize(DISPLAY_IMAGE_WIDTH, DISPLAY_IMAGE_HEIGHT), IPL_DEPTH_16U,
			1, IPL_ORIGIN_TL, CV_DEFAULT_IMAGE_ROW_ALIGN);
	/* Initialize the cascade buffer */
	buffer = (int *) cvAlloc(sizeof(cascade_buffer));
	cascade = (CvHaarClassifierCascade *) buffer;
	for (i = 0; i < CLASSIFIER_CASCADE_SIZE; i++)
		if (cascade_buffer[i] > REFERENCE_LOCATION_1 && cascade_buffer[i] < REFERENCE_LOCATION_2)
			*(buffer + i) = (cascade_buffer[i] - REFERENCE_LOCATION_1) + (int) cascade;
		else
			*(buffer + i) = cascade_buffer[i];
	/* Initialize the dsp_sequnce which would contain the face coordinates */
	dsp_sequence2 = (CvSeq *) cvAlloc(sizeof(CvSeq) * 2);
	memset(dsp_sequence2, 0, sizeof(CvSeq) * 2);
	/* Allocate pointers to buffers */
	buff_luma[0] = buff_luma1;
	buff_luma[1] = buff_luma2;
	buff_chroma[0] = buff_chroma1;
	buff_chroma[1] = buff_chroma2;
	proc_buff_ptr = proc_buff_luma;
	/* Initializing palette for first buffer */
	*Rgb_buffer1 = 0x4000;
	for (i = 1; i < 16; i++)
		*(Rgb_buffer1 +i) = 0x0000;
	videoTopRgb1 = Rgb_buffer1 + i;
	/* Initializing palette for second buffer */
	*Rgb_buffer2 = 0x4000;
		*(Rgb_buffer2 + i) = 0x0000;
	videoTopRgb2 = Rgb_buffer2 + i;
	/* Power on VPIF */
	PSCModuleControl(SOC_PSC_1_REGS, HW_PSC_VPIF, PSC_POWERDOMAIN_ALWAYS_ON,
			PSC_MDCTL_NEXT_ENABLE);
	/* Initialize I2C and program UI GPIO expander, TVP5147, and ADV7343 via I2C */
	I2CPinMuxSetup(0);
	/*Initialize the TVP5147 to accept composite video */
	I2CCodecIfInit(SOC_I2C_0_REGS, INT_CHANNEL_I2C,
			I2C_SLAVE_CODEC_TVP5147_2_COMPOSITE);
	TVP5147CompositeInit(SOC_I2C_0_REGS);
	/* Setup VPIF pinmux */
	VPIFPinMuxSetup();
	/* Setup LCD */
	SetUpLCD();
	/* Initialize VPIF */
	SetUpVPIFRx();
	VPIFDMARequestSizeConfig(SOC_VPIF_0_REGS, VPIF_REQSIZE_ONE_TWENTY_EIGHT);
	VPIFEmulationControlSet(SOC_VPIF_0_REGS, VPIF_HALT);
	/* Initialize buffer addresses for 1st frame*/
	VPIFCaptureFBConfig(SOC_VPIF_0_REGS, VPIF_CHANNEL_0, VPIF_TOP_FIELD,
			VPIF_LUMA, (unsigned int) buff_luma[0], CAPTURE_IMAGE_WIDTH*2);
			VPIF_CHROMA, (unsigned int) buff_chroma[0], CAPTURE_IMAGE_WIDTH*2);
	VPIFCaptureFBConfig(SOC_VPIF_0_REGS, VPIF_CHANNEL_0, VPIF_BOTTOM_FIELD,
			VPIF_LUMA, (unsigned int) (buff_luma[0] + CAPTURE_IMAGE_WIDTH), CAPTURE_IMAGE_WIDTH*2);
			VPIF_CHROMA, (unsigned int) (buff_chroma[0] + CAPTURE_IMAGE_WIDTH), CAPTURE_IMAGE_WIDTH*2);
	/* Configuring the base ceiling */
	RasterDMAFBConfig(SOC_LCDC_0_REGS, (unsigned int) Rgb_buffer2,
			(unsigned int) (Rgb_buffer2 + DISPLAY_IMAGE_WIDTH * DISPLAY_IMAGE_HEIGHT + 15), 0);
			(unsigned int) (Rgb_buffer2 + DISPLAY_IMAGE_WIDTH * DISPLAY_IMAGE_HEIGHT + 15), 1);
	/* Enable interrupts */
	Hwi_enable();
	Hwi_enableInterrupt(8);
	Hwi_enableInterrupt(9);
	/* Enable capture */
	VPIFCaptureChanenEnable(SOC_VPIF_0_REGS, VPIF_CHANNEL_0);
	/* Enable VPIF interrupt */
	VPIFInterruptEnable(SOC_VPIF_0_REGS, VPIF_FRAMEINT_CH0);
	VPIFInterruptEnableSet(SOC_VPIF_0_REGS, VPIF_FRAMEINT_CH0);
	/* Enable End of frame interrupt */
	RasterEndOfFrameIntEnable(SOC_LCDC_0_REGS);
	/* Enable raster */
	RasterEnable(SOC_LCDC_0_REGS);
	buffcount++;
	buffcount2 = buffcount - 1;
	/* Run forever */
	while (1)
		/* Wait here till a new frame is not captured */
		Semaphore_pend(sem1, BIOS_WAIT_FOREVER);
		/* Process the next buffer only when both the raster buffers
		 * are pointing to the current buffer to avoid jitter effect
		Semaphore_pend(sem2, BIOS_WAIT_FOREVER);
		processed = 0;
		changed = 0;
		updated = 0;
		/* Copy the current frame into another buffer for running the facedetect algorithm */
		if(facedetect_complete)
			facedetect_complete=0;
			for(i=0;i<DISPLAY_IMAGE_HEIGHT;i++)
				memcpy((proc_buff_ptr + i*DISPLAY_IMAGE_WIDTH),(videoTopY + OFFSET +i*CAPTURE_IMAGE_WIDTH),
						DISPLAY_IMAGE_WIDTH);
			image->imageData = (char *)proc_buff_ptr;
			buffer_ready=1;
	    /* Convert the buffer from CBCR422 semi-planar to RGB565,
	     *  Set the flag for the buffer to be displayed on the LCD (which would be the processed buffer)
	     *  and notify the LCD of availability of a processed buffer.
	     *  The output buffers are ping-ponged each time.
		if (pingpong)
					(const unsigned char *) (videoTopC + OFFSET),
					DISPLAY_IMAGE_HEIGHT, CAPTURE_IMAGE_WIDTH, ccCoeff,
					(const unsigned char *) (videoTopY + OFFSET),
					CAPTURE_IMAGE_WIDTH, videoTopRgb1, DISPLAY_IMAGE_WIDTH,
			display_buff_1 = 1;
		else
					CAPTURE_IMAGE_WIDTH, videoTopRgb2, DISPLAY_IMAGE_WIDTH,
			display_buff_1 = 0;
		pingpong = !pingpong;
		processed = 1;
		changed = 1;
** FacedetectTask - Runs the Face Detection Algorithm on the frame provided to it
Void facedetectTask(UArg a0, UArg a1)
	int i;
	while(1)
		while(!buffer_ready)
			Task_sleep(10);
		buffer_ready=0;
		storage = cvCreateMemStorage(0);
		/* Apply OpenCV haardetect algorithm */
		dsp_sequence = cvHaarDetectObjects(image, cascade, storage, 2.5, 2, 0, cvSize(30, 30));
		/* Make a copy of the detected sequence to draw it on each frame */
		for (i = 0; i < 2; i++)
			*(dsp_sequence2 + i) = *(dsp_sequence + i);
		cvReleaseMemStorage(&storage);
		facedetect_complete=1;
 * Initialize capture
	/* Disable interrupts */
	VPIFInterruptDisable(SOC_VPIF_0_REGS, VPIF_FRAMEINT_CH1);
	VPIFInterruptDisable(SOC_VPIF_0_REGS, VPIF_FRAMEINT_CH0);
	/* Disable capture ports */
	VPIFCaptureChanenDisable(SOC_VPIF_0_REGS, VPIF_CHANNEL_1);
	VPIFCaptureChanenDisable(SOC_VPIF_0_REGS, VPIF_CHANNEL_0);
	/* Interrupt after capturing the bottom field of every frame */
	VPIFCaptureIntframeConfig(SOC_VPIF_0_REGS, VPIF_CHANNEL_0, VPIF_FRAME_INTERRUPT_BOTTOM);
	/* Y/C interleaved capture over 8-bit bus */
	VPIFCaptureYcmuxModeSelect(SOC_VPIF_0_REGS, VPIF_CHANNEL_0, VPIF_YC_MUXED);
	/* Capturing 480I (SD NTSC) */
	VPIFCaptureModeConfig(SOC_VPIF_0_REGS, VPIF_480I, VPIF_CHANNEL_0, 0, (struct vbufParam *) 0);
 * Configures raster to display image
    PSCModuleControl(SOC_PSC_1_REGS, HW_PSC_LCDC, PSC_POWERDOMAIN_ALWAYS_ON,
    LCDPinMuxSetup();
    /* disable raster */
    RasterDisable(SOC_LCDC_0_REGS);
    /* configure the pclk */
    RasterClkConfig(SOC_LCDC_0_REGS, 25000000, 150000000);
    /* configuring DMA of LCD controller */
    RasterDMAConfig(SOC_LCDC_0_REGS, RASTER_DOUBLE_FRAME_BUFFER,
                    RASTER_BURST_SIZE_16, RASTER_FIFO_THRESHOLD_8,
                    RASTER_BIG_ENDIAN_DISABLE);
    /* configuring modes(ex:tft or stn,color or monochrome etc) for raster controller */
    RasterModeConfig(SOC_LCDC_0_REGS, RASTER_DISPLAY_MODE_TFT,
                     RASTER_PALETTE_DATA, RASTER_COLOR, RASTER_RIGHT_ALIGNED);
    /* frame buffer data is ordered from least to Most significant bye */
    RasterLSBDataOrderSelect(SOC_LCDC_0_REGS);
    /* disable nibble mode */
    RasterNibbleModeDisable(SOC_LCDC_0_REGS);
     /* configuring the polarity of timing parameters of raster controller */
    RasterTiming2Configure(SOC_LCDC_0_REGS, RASTER_FRAME_CLOCK_LOW |
                                            RASTER_LINE_CLOCK_LOW  |
                                            RASTER_PIXEL_CLOCK_LOW |
                                            RASTER_SYNC_EDGE_RISING|
                                            RASTER_SYNC_CTRL_ACTIVE|
                                            RASTER_AC_BIAS_HIGH     , 0, 255);
    /* configuring horizontal timing parameter */
   RasterHparamConfig(SOC_LCDC_0_REGS, DISPLAY_IMAGE_WIDTH, 64, 48, 48);
    /* configuring vertical timing parameters */
   RasterVparamConfig(SOC_LCDC_0_REGS, DISPLAY_IMAGE_HEIGHT, 2, 11, 31);
   /* configuring fifo delay to */
   RasterFIFODMADelayConfig(SOC_LCDC_0_REGS, 2);
** VPIF Interrupt service routine.
#ifdef _TMS320C6X
	IntEventClear(SYS_INT_VPIF_INT);
#endif
	/* If previously captured frame is not processed, clear this interrupt and return */
	if (!processed)
		VPIFInterruptStatusClear(SOC_VPIF_0_REGS, VPIF_FRAMEINT_CH0);
		return;
	/* buffcount represents buffer to be given to capture driver and
	 * buffcount2 represents the newly captured buffer to be processed
	processed = 0;
	buffcount++;
	// Currently only two buffers are being used for capture
	if (buffcount == 2)
		buffcount = 0;
	/* Initialize buffer addresses for a new frame*/
			VPIF_LUMA, (unsigned int) buff_luma[buffcount], CAPTURE_IMAGE_WIDTH*2);
			VPIF_CHROMA, (unsigned int) buff_chroma[buffcount], CAPTURE_IMAGE_WIDTH*2);
			VPIF_LUMA, (unsigned int) (buff_luma[buffcount] + CAPTURE_IMAGE_WIDTH), CAPTURE_IMAGE_WIDTH*2);
			VPIF_CHROMA, (unsigned int) (buff_chroma[buffcount] + CAPTURE_IMAGE_WIDTH), CAPTURE_IMAGE_WIDTH*2);
	/* Initialize buffer addresses with the captured frame ready to be processed */
	videoTopC = buff_chroma[buffcount2];
	videoTopY = buff_luma[buffcount2];
	/* clear interrupt */
	Semaphore_post(sem1);
** For each end of frame interrupt base and ceiling is reconfigured
	unsigned int i, status;
#ifdef _TMS320C6X
	IntEventClear(SYS_INT_LCDC_INT);
#endif
	/* Find which interrupt occurred and clear it */
	status = RasterIntStatus(SOC_LCDC_0_REGS,
			RASTER_END_OF_FRAME0_INT_STAT | RASTER_END_OF_FRAME1_INT_STAT);
	status = RasterClearGetIntStatus(SOC_LCDC_0_REGS, status);
	if(!changed)
		return;
	/* Draw a rectangle from the detected sequence onto the current frame*/
	if (dsp_sequence2 == NULL);
	else
		if (display_buff_1)
			image1->imageData = (char *)videoTopRgb1;
		else
			image1->imageData = (char *)videoTopRgb2;
		//printf("DSP sequence contains %i elements:\n", dsp_sequence2->total);
		for (i = 0; i < dsp_sequence2->total; i++)
			r = (CvRect *) cvGetSeqElem(dsp_sequence2, i);
			//printf("%4i: %4i, %4i (%ix%i)\n", i, r->x, r->y, r->width, r->height);
			// mark with thick blue rectangle
			c1.x = r->x;
			c1.y = r->y;
			c2.x = r->x + r->width;
			c2.y = r->y + r->height;
			cvRectangle(image1, c1, c2, blue, 2, 8, 0);
	/* Display the appropriate output buffer on the appropriate raster buffer
	 * and if a new processed buffer is available, let the DSP know that
	 * it has configured the raster buffer to point to the new output buffer
	 * by updating the 'updated' flag
	if (display_buff_1)
		if (status & RASTER_END_OF_FRAME0_INT_STAT)
			RasterDMAFBConfig(SOC_LCDC_0_REGS, (unsigned int) Rgb_buffer1,
					(unsigned int) (Rgb_buffer1 + DISPLAY_IMAGE_WIDTH * DISPLAY_IMAGE_HEIGHT + 15), 0);
				updated = updated | 0x1;
		if (status & RASTER_END_OF_FRAME1_INT_STAT)
					(unsigned int) (Rgb_buffer1 + DISPLAY_IMAGE_WIDTH * DISPLAY_IMAGE_HEIGHT + 15), 1);
				updated = updated | 0x2;
	else
	if(updated==3)
		changed=0;
		Semaphore_post(sem2);
/***************************** End Of File ************************************/
7484.cxcore.h
data register
  • Hi Anounini,
    The same issue is already discussed twice and we have already suggested our inputs to introduce flip functionality into the project and configuring EVM switches through GPIO module. Actually, you have to walkthrough the existing facedetect code and understand all functions of facedetect functions to implement this new feature. I think, you need to develop this application to implement the flip function through EVM switches and we also referred the OMAPL138 starterware code to access those switches through GPIO module.
    Note: Please don't open multiple & many number of threads for the same issue and it would be very tedious for you as well for us to track the response.
    Thanks & regards,
    Sivaraj K
    Please click the Verify Answer button on this post if it answers your question.
  • I rediscuss the topic because i didn't have the responses of my questions.
    Ok thank you
