Hallo,
I am neu in SYS/BIOS. I use SYS/BIOS 6.35 in AM335x StarterKit.
Is there any possiblity to resume (change the task mode to READY) the task which is blocked by Task_sleep() function?
Thanks in advance,
Best gerads
Hallo,
Thanks in advance,
Best gerads
Hi Baska,
A task cannot be explicitly changed into READY mode. You may want to consider having the task pend on a Semaphore. You can specify a Timeout (in clock ticks) and you can post the Semaphore from another task if you would like to trigger execution before the Timeout is over.
--Emmanuel
Hi Emmanuel,
That is a good idea,
Thank you very much.
Baska
Emmanuel Trinidad - Alicea said:Hi Baska,
--Emmanuel
