capture fps
Hi, we use DM8168, RDK4.0. From the log as fllowing, the capture  Link can not capture the frame, is it right?
The total FPS can be thinked of the capture frameRate?
[m3vpss ]
 [m3vpss ]  *** Capture Driver Advanced Statistics ***
 [m3vpss ]
 [m3vpss ]  VIP Parser Reset Count : 0
 [m3vpss ]
 [m3vpss ]      |   Total    Even     Odd  Total  Even   Odd  Min /  Max  Min /  Max Dropped Fid Repeat Frame Error Y/C
 [m3vpss ]  CH  |  Fields  Fields  Fields    FPS   FPS   FPS       Width      Height  Fields      Count (Desc Error Y/C)
 [m3vpss ]  ------------------------------------------------------------------------------------------------------------
 [m3vpss ]  000 |     168     168       0      0     0     0  197 / 1920   86 / 1080       1          0 0/0 (0/0)
 [m3vpss ]  200 |     168     168       0      0     0     0  197 / 1920   86 / 1080       1          0 0/0 (0/0)
 [m3vpss ]
 [m3vpss ]  VIP Capture Port 0 | DescMissMatch1 = 0, DescMissMatch2 = 0 , DescMissMatch3 = 0
 [m3vpss ]  VIP Capture Port 2 | DescMissMatch1 = 0, DescMissMatch2 = 0 , DescMissMatch3 = 0
 [m3vpss ]
 [m3vpss ]  *** Capture List Manager Advanced Statistics ***
 [m3vpss ]
 [m3vpss ]  List Post Count        : 748720
 [m3vpss ]  List Stall Count       : 0
 [m3vpss ]  List Post Time (ms)    : Max = 0, Min = 0, Avg = 0, Total = 0
 [m3vpss ]  INTC Timeout Count     : (0, 0) (Min timeout value = 979, 988)
 [m3vpss ]  Descriptor miss found count : 0
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]  VIP and VPDMA registers,
 [m3vpss ]  VIP0 : FIQ_STATUS  : 0x4810551c = 0x00000000
 [m3vpss ]  VIP1 : FIQ_STATUS  : 0x48105a1c = 0x00000000
 [m3vpss ]  VPDMA: LIST_BUSY   : 0x4810d00c = 0x00060000
 [m3vpss ]
 [m3vpss ]
 [m3vpss ] [links_m3vpss/capture/captureLink_drv.c:2458] 3045722: CAPTURE: Fields = 334 (fps = 0, CPU Load = 0)
 [m3vpss ] [links_m3vpss/capture/captureLink_drv.c:2463] 3045722: CAPTURE: Num Resets = 0 (Avg 0 ms per reset)
 [m3vpss ]  3045722: SYSTEM  : FREE SPACE : System Heap      = 67056 B, Mbx = 10238 msgs)
 [m3vpss ]  3045722: SYSTEM  : FREE SPACE : SR0 Heap         = 16839552 B (16 MB)
 [m3vpss ]  3045722: SYSTEM  : FREE SPACE : Frame Buffer     = 446935424 B (426 MB)
 [m3vpss ]  3045722: SYSTEM  : FREE SPACE : Bitstream Buffer = 254179200 B (242 MB)
 [m3vpss ]
 [m3vpss ]
 [m3vpss ] TILER_STATS: CNT :8BIT
 [m3vpss ]
 [m3vpss ] TILER_STATS: CNT RESOLUTION:    16384 x 8192
 [m3vpss ]
 [m3vpss ] TILER_STATS: BUCKET RESOLUTION: 16384 x 8188
 [m3vpss ]
 [m3vpss ] TILER_STATS: NUM FREE BUCKETS:  1
 [m3vpss ]
 [m3vpss ] TILER_STATS: NUM USED BUCKETS:  0
 [m3vpss ]
 [m3vpss ] TILER_STATS: TOTAL FREE AREA:   134152192 (99 %)
 [m3vpss ]
 [m3vpss ] TILER_STATS: TOTAL USED AREA:   0 (0 %)
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ] TILER_STATS: CNT :16BIT
 [m3vpss ]
 [m3vpss ] TILER_STATS: CNT RESOLUTION:    32768 x 4096
 [m3vpss ]
 [m3vpss ] TILER_STATS: BUCKET RESOLUTION: 32768 x 4096
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ] TILER_STATS: TOTAL FREE AREA:   134217728 (100 %)
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]  3045724: SYSTEM  : FREE SPACE : Tiler 8-bit      = 134152192 B (127 MB)  - TILER ON
 [m3vpss ]  3045724: SYSTEM  : FREE SPACE : Tiler 16-bit     = 134217728 B (128 MB)  - TILER ON
 [m3vpss ]
 [m3vpss ]  *** [NSF0] NSF Statistics ***
 [m3vpss ]
 [m3vpss ]  Elasped Time           : 96 secs
 [m3vpss ]  Total Fields Processed : 99831
 [m3vpss ]  Total Fields FPS       : 111 FPS
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]  CH  | In Recv In Reject In Process Out User Out Out
 [m3vpss ]  Num | FPS     FPS       FPS        FPS Skip FPS Skip FPS
 [m3vpss ]    0 |      33         0         33  33        0        0
 [m3vpss ]
 [m3vpss ] [links_m3vpss/dei/deiLink_drv.c:2730]
 [m3vpss ] [links_m3vpss/dei/deiLink_drv.c:2731] *** [
 [m3vpss ] [links_m3vpss/dei/deiLink_drv.c:2732]
 [m3vpss ] [links_m3vpss/dei/deiLink_drv.c:2733] Elasped Time           : 0 secs
 [m3vpss ] [links_m3vpss/dei/deiLink_drv.c:2734] Total Fields Processed : 0
 [m3vpss ] [links_m3vpss/dei/deiLink_drv.c:2735] Total Fields FPS       : 0 FPS
 [m3vpss ] [links_m3vpss/dei/deiLink_drv.c:2736]
 [m3vpss ] [links_m3vpss/dei/deiLink_drv.c:2737]
 [m3vpss ] [links_m3vpss/dei/deiLink_drv.c:2738] CH  | In Recv In Reject In Process Out[0] Out[1] Out[2] Out[3] Out[4] Skip Out[0] Skip Out[1] Skip Out[2] Skip Out[3] Skip Out[4] User Out[0] User Out[1] User Out[2] User Out[3] User Out[4] Latency
 [m3vpss ] [links_m3vpss/dei/deiLink_drv.c:2739] Num | FPS     FPS       FPS        FPS    FPS    FPS    FPS    FPS       FPS         FPS         FPS         FPS         FPS       Skip FPS    Skip FPS    Skip FPS    Skip FPS    Skip FPS   Min / Max
 [m3vpss ] [links_m3vpss/dei/deiLink_drv.c:2740] -------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
 [m3vpss ] [links_m3vpss/dei/deiLink_drv.c:2751]   0 |      33         0         33      0     33      0      0      0          33           0           0           0           0           0           0           0           0           0   9 /  23
 [m3vpss ]
 [m3vpss ] [links_m3vpss/sclr/sclrLink_drv.c:47]
 [m3vpss ] [links_m3vpss/sclr/sclrLink_drv.c:48] *** [] SCLR Statistics ***
 [m3vpss ] [links_m3vpss/sclr/sclrLink_drv.c:49]
 [m3vpss ] [links_m3vpss/sclr/sclrLink_drv.c:50] Elasped Time           : 1 secs
 [m3vpss ] [links_m3vpss/sclr/sclrLink_drv.c:51] Total Fields Processed : 1
 [m3vpss ] [links_m3vpss/sclr/sclrLink_drv.c:52] Total Fields FPS       : 1 FPS
 [m3vpss ] [links_m3vpss/sclr/sclrLink_drv.c:53]
 [m3vpss ] [links_m3vpss/sclr/sclrLink_drv.c:54]
 [m3vpss ] [links_m3vpss/sclr/sclrLink_drv.c:55] CH  | In Recv In Reject In Process Out Skip Out User Out Latency
 [m3vpss ] [links_m3vpss/sclr/sclrLink_drv.c:56] Num | FPS     FPS       FPS        FPS    FPS   Skip FPS Min / Max
 [m3vpss ] [links_m3vpss/sclr/sclrLink_drv.c:57] ---------------------------------------------------------------------
 [m3vpss ] [links_m3vpss/sclr/sclrLink_drv.c:68]   0 |      33         0         33  33        0        0   9  23
 [m3vpss ]
 [m3vpss ] [links_m3vpss/sclr/sclrLink_drv.c:68]   0 |      33         0         33  33        0        0  16  31
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]  *** [SWMS0] Mosaic Statistics ***
 [m3vpss ]
 [m3vpss ]  Elasped Time: 96 secs
 [m3vpss ]
 [m3vpss ]  Output Request FPS   : 33 fps (3218 frames)
 [m3vpss ]  Output Actual  FPS   : 33 fps (3218 frames)
 [m3vpss ]  Output Drop    FPS   : 0 fps (0 frames)
 [m3vpss ]  Output Reject  FPS   : 0 fps (0 frames)
 [m3vpss ]  Scaling Internal     : 29 ms
 [m3vpss ]  Scaling Internal min : 30 ms
 [m3vpss ]  Scaling Internal max : 31 ms
 [m3vpss ]
 [m3vpss ]  Win | Window Repeat Drop Recv Que  FID Invlid Acc Event          Invalid   Que Reject Reject Latency   OutBufCopy InBufCopy
 [m3vpss ]  Num | FPS    FPS    FPS  FPS  FPS  FPS        Count (Max/Min)    CH Frames Frames     Frames Min / Max FPS        FPS
 [m3vpss ]  ---------------------------------------------------------------------------------------------------------------------------
 [m3vpss ]    0 |     33     33    0    0    0          0        0 (  0/255)         0          0      0  29 / 535519         33         0
 [m3vpss ]    1 |     33     33    0    0    0          0        0 (  0/255)         0          0      0  26 / 241143         33         0
 [m3vpss ]    2 |     33     33    0    0    0          0        0 (  0/255)         0          0      0  26 / 241143         33         0
 [m3vpss ]    3 |     33     33    0    0    0          0        0 (  0/255)         0          0      0  29 / 535519         33         0
 [m3vpss ]
 [m3vpss ] [links_m3vpss/swMs/swMsLink_drv.c:987] *** [SWMS0] Mosaic Parameters ***,output FPS:30
 [m3vpss ] [links_m3vpss/swMs/swMsLink_drv.c:988] Win | Ch  | Input      | Input          | Input         | Input       | Output     |  Output         | Output        | Output      | Low Cost | SWMS | Data  | Blank |
 [m3vpss ] [links_m3vpss/swMs/swMsLink_drv.c:989] Num | Num | Start X, Y | Width x Height | Pitch Y / C   | Memory Type | Start X, Y |  Width x Height | Pitch Y / C   | Memory Type | ON / OFF | Inst | Format| Frame |
 [m3vpss ] [links_m3vpss/swMs/swMsLink_drv.c:990] ----------------------------------------------------------------------------------------------------------------------------------------------------------------------
 [m3vpss ] [links_m3vpss/swMs/swMsLink_drv.c:1005]   0 |   0 |    0,    0 |  1920 x   1080 |  1920 /  1920 | NON-TILED   |    0,    0 |   960 x    540 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
 [m3vpss ] [links_m3vpss/swMs/swMsLink_drv.c:1005]   1 |   1 |    0,    0 |  1920 x   1080 |  1920 /  1920 | NON-TILED   |  960,    0 |   960 x    540 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
 [m3vpss ] [links_m3vpss/swMs/swMsLink_drv.c:1005]   2 |   2 |    0,    0 |  1920 x   1080 |  1920 /  1920 | NON-TILED   |    0,  540 |   960 x    540 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
 [m3vpss ] [links_m3vpss/swMs/swMsLink_drv.c:1005]   3 |   3 |    0,    0 |  1920 x   1080 |  1920 /  1920 | NON-TILED   |  960,  540 |   960 x    540 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
 [m3vpss ]
 [m3vpss ]  3045744: DISPLAY: HDDAC(BP0) : 59 fps, Latency (Min / Max) = ( 73 / 97 ), Callback Interval (Min / Max) = ( 16 / 17 ) DropCount:0 DispLatency (Min / Max) = ( 49 / 83 ) !!!
 [m3vpss ]  3045744: DISPLAY DRV: HDDAC(BP0) : Q:[99833] Display:[179706], Repeat:[79875], DQ:[99830]
 [m3vpss ]
 [m3vpss ]  3045744: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 5792, HDDAC(BP0) 5797, DVO2(BP1) 5797, SDDAC(SEC1) 11790
 [m3vpss ]  3045744: SYSTEM  : FREE SPACE : System Heap      = 67056 B, Mbx = 10239 msgs)
 [m3vpss ]  3045744: SYSTEM  : FREE SPACE : SR0 Heap         = 16839552 B (16 MB)
 [m3vpss ]  3045744: SYSTEM  : FREE SPACE : Frame Buffer     = 446935424 B (426 MB)
 [m3vpss ]  3045744: SYSTEM  : FREE SPACE : Bitstream Buffer = 254179200 B (242 MB)
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]  3045746: SYSTEM  : FREE SPACE : Tiler 8-bit      = 134152192 B (127 MB)  - TILER ON
 [m3vpss ]  3045746: SYSTEM  : FREE SPACE : Tiler 16-bit     = 134217728 B (128 MB)  - TILER ON
 [m3vpss ]  3045746: DISPLAY: DVO2(BP1)  : 59 fps, Latency (Min / Max) = ( 80 / 110 ), Callback Interval (Min / Max) = ( 16 / 17 ) DropCount:0 DispLatency (Min / Max) = ( 49 / 83 ) !!!
 [m3vpss ]  3045746: DISPLAY DRV: DVO2(BP1)  : Q:[99832] Display:[179702], Repeat:[79871], DQ:[99830]
 [m3vpss ]
 [m3vpss ]  *** IpcFramesOutRTOS Statistics ***
 [m3vpss ]
 [m3vpss ]  Total Fields Processed : 8
 [m3vpss ]  Total Fields FPS       : 0 FPS
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]  CH  | In Recv In Process In Skip
 [m3vpss ]    0 |       0          0       0
 [m3vpss ]    1 |       0          0       0
 [m3vpss ]    2 |       0          0       0
 [m3vpss ]    3 |       0          0       0
 [m3vpss ]
 [c6xdsp ]
 [c6xdsp ]  *** SCD Statistics ***
 [c6xdsp ]
 [c6xdsp ]  Elasped Time           : 96 secs
 [c6xdsp ]  Total Fields Processed : 0
 [c6xdsp ]  Total Fields FPS       : 0 FPS
 [c6xdsp ]
 [c6xdsp ]
 [c6xdsp ]  CH  | In Recv In Process User Skip Process Skip In Process Time
 [c6xdsp ]  Num | FPS     FPS        FPS       FPS          per frame (msec)
 [c6xdsp ]  ----------------------------------------------------------------
 [c6xdsp ]
 [m3video]
 [m3video]      3051748: HDVICP-ID:0
 [m3video] All percentage figures are based off totalElapsedTime
 [m3video]
 [m3video]               totalAcquire2wait :0 %
 [m3video]               totalWait2Isr :3 %
 [m3video]               totalIsr2Done :0 %
 [m3video]               totalWait2Done :3 %
 [m3video]               totalDone2Release :0 %
 [m3video]               totalAcquire2Release :3 %
 [m3video]               totalAcq2acqDelay :96 %
 [m3video]               totalElapsedTime in msec : 3000893
 [m3video]               numAccessCnt:  100122
 [m3video]
 [m3video]              IVA-FPS :      33
 [m3video]
 [m3video]              Average time spent per frame in microsec:     899
 [m3video]
 [m3video]      3051749: HDVICP-ID:1
 [m3video]
 [m3video]               totalWait2Isr :38 %
 [m3video]               totalWait2Done :38 %
 [m3video]               totalAcquire2Release :39 %
 [m3video]               totalAcq2acqDelay :60 %
 [m3video]               totalElapsedTime in msec : 3000903
 [m3video]               numAccessCnt:  100121
 [m3video]
 [m3video]
 [m3video]              Average time spent per frame in microsec:   11389
 [m3video]
 [m3video]      3051749: HDVICP-ID:2
 [m3video]
 [m3video]               totalWait2Isr :0 %
 [m3video]               totalWait2Done :0 %
 [m3video]               totalAcquire2Release :0 %
 [m3video]               totalAcq2acqDelay :99 %
 [m3video]               totalElapsedTime in msec : 2876343
 [m3video]               numAccessCnt:     160
 [m3video]
 [m3video]              IVA-FPS :       0
 [m3video]
 [m3video]              Average time spent per frame in microsec:       0
 [m3video] [links_m3video/iva_enc/encLink_common.c:2015]
 [m3video] [links_m3video/iva_enc/encLink_common.c:2016] *** ENCODE Statistics ***
 [m3video] [links_m3video/iva_enc/encLink_common.c:2017]
 [m3video] [links_m3video/iva_enc/encLink_common.c:2018] Elasped Time           : 0 secs
 [m3video] [links_m3video/iva_enc/encLink_common.c:2019]
 [m3video] [links_m3video/iva_enc/encLink_common.c:2020]
 [m3video] [links_m3video/iva_enc/encLink_common.c:2021] CH  | In Recv In Skip In User  Out Latency
 [m3video] [links_m3video/iva_enc/encLink_common.c:2022] Num | FPS     FPS     Skip FPS FPS Min / Max
 [m3video] [links_m3video/iva_enc/encLink_common.c:2023] --------------------------------------------
 [m3video] [links_m3video/iva_enc/encLink_common.c:2031]   0 |      33       0        0  33 255 / 48225
 [m3video] [links_m3video/iva_enc/encLink_common.c:2031]   1 |      33       0        0  33 255 / 48237
 [m3video] [links_m3video/iva_enc/encLink_common.c:2031]   2 |       0       0        0   0 255 / 48226
 [m3video] [links_m3video/iva_enc/encLink_common.c:2031]   3 |       0       0        0   0 255 / 48239
 [m3video] [links_m3video/iva_enc/encLink_common.c:2031]   4 |       0       0        0   0 255 / 48239
 [m3video] [links_m3video/iva_enc/encLink_common.c:2031]   5 |       0       0        0   0 255 / 48238
 [m3video]
 [m3video] Multi Channel Encode Average Submit Batch Size
 [m3video] Max Submit Batch Size : 24
 [m3video] IVAHD_0 Average Batch Size : 1
 [m3video] IVAHD_0 Max achieved Batch Size : 1
 [m3video] IVAHD_1 Average Batch Size : 1
 [m3video] IVAHD_1 Max achieved Batch Size : 1
 [m3video] IVAHD_2 Average Batch Size : 1
 [m3video] IVAHD_2 Max achieved Batch Size : 1
 [m3video]
 [m3video] Multi Channel Encode Batch break Stats
 [m3video] Total Number of Batches created: 3220
 [m3video] All numbers are based off total number of Batches created
 [m3video]       Batch breaks due to batch sizeexceeding limit: 100 %
 [m3video]       Batch breaks due to ReqObj Que being empty: 0 %
 [m3video]       Batch breaks due to changed resolution class: 0 %
 [m3video]       Batch breaks due to interlace and progressivecontent mix: 0 %
 [m3video]       Batch breaks due to channel repeat: 0 %
 [m3video]       Batch breaks due to different codec: 0 %
 [m3video] Total Number of Batches created: 4
