invalid project path
I am using CCS 5.5.
I installed TI RTOS 1_12_00_09.
When I compile, I get
Description Resource Path Location Type
Invalid project path: Include path not found (C:\ti\tirtos_1_21_00_09\products\bios_6_35_01_29\packages). ti_rtos  pathentry Path Entry Problem
Invalid project path: Include path not found (C:\ti\tirtos_1_21_00_09\products\uia_1_03_00_02\packages). ti_rtos  pathentry Path Entry Problem
Invalid project path: Include path not found (C:\ti\tirtos_1_21_00_09\products\ndk_2_22_03_20\packages). ti_rtos  pathentry Path Entry Problem
Invalid project path: Include path not found (C:\ti\tirtos_1_21_00_09\products\ipc_1_25_03_15\packages). ti_rtos  pathentry Path Entry Problem
HOw do I resolve this?
  • Shital,
    What project are you building?  Is it your own project that you’ve imported?  If yes, have the include paths been set properly?  This page might help: http://processors.wiki.ti.com/index.php/Include_paths_and_options
    Or is it one of the bundled example projects where you are seeing this?  If not, can you try building one of those and see if there is any issue with that?
    Scott
