Hi,All
I have a custom board.Cpu is TI's AM3505, and NT5TU64M16GG-3C ddr2 (SDRAM). cpu run normal.When debug in SRAM with x-load, evrything is ok. Normal output appears on the uart1.But when I want to debug in SDRAM ,some problems happend .
Jlink gdb code print:
Reading all registers
WARNING: Failed to read memory @ address 0x00000000
Read 4 bytes @ address 0x00000000 (Data = 0xAAAAAAAA)
Read 4 bytes @ address 0xFFFFFFFC (Data = 0xFFFFFFFF)
Target interface speed set to 30 kHz
Target endianess set to "little endian"
Resetting target
Writing 0x00000020 @ address 0x48004C10
Writing 0x00000020 @ address 0x48004C00
Sleep 10ms
Writing 0x0000AAAA @ address 0x48314048
Sleep 10ms
Writing 0x00005555 @ address 0x48314048
Writing 0x00000003 @ address 0x48306D40
Target interface speed set to 1000 kHz
Writing 0x00110011 @ address 0x48004D00
Sleep 10ms
Writing 0x0000032A @ address 0x48004A40
Writing 0x094C1900 @ address 0x48004D40
Writing 0x00006019 @ address 0x48004D44
Writing 0x00000002 @ address 0x48004D48
Writing 0x00370037 @ address 0x48004D00
Sleep 100ms
Writing 0x00000015 @ address 0x48004904
Sleep 10ms
Writing 0x00000001 @ address 0x48004944
Writing 0x0010FA0C @ address 0x48004940
Writing 0x00000077 @ address 0x48004904
Sleep 100ms
GDB closed TCP/IP connection
Connected to 127.0.0.1
Read 4 bytes @ address 0x00014000 (Data = 0xEA000232)
WARNING: Failed to read memory @ address 0x00013FFC
Read 4 bytes @ address 0x00013FFC (Data = 0xAAAAAAAA)
Resetting target
Sleep 10ms
Sleep 10ms
Sleep 10ms
Sleep 100ms
Sleep 10ms
Sleep 100ms
Writing 0x00000000 @ address 0x48002264
Writing 0x00000006 @ address 0x6D0000E4
Writing 0x00000006 @ address 0x6D0000E8
Writing 0x00000000 @ address 0x6D0000EC
Writing 0x00002411 @ address 0x6D000060
Sleep 20ms
Read 4 bytes @ address 0x002006A8 (Data = 0x00550054)
Read 4 bytes @ address 0x002006A4 (Data = 0x00530052)
Writing 0x04446248 @ address 0x6D000018
Writing 0x04446248 @ address 0x6D00001C
Writing 0x141631CA @ address 0x6D000020
Writing 0x141631CA @ address 0x6D000024
Writing 0x00000157 @ address 0x6D000028
Writing 0x00000157 @ address 0x6D00002C
Writing 0x80000000 @ address 0x6D000038
Writing 0x80000000 @ address 0x6D00003C
Writing 0x0000050E @ address 0x6D000010
Writing 0x0000050E @ address 0x6D000014
Writing 0x48801632 @ address 0x6D000008
Downloading 6776 bytes @ address 0x80E80000
Downloading 157 bytes @ address 0x80E81A78
Downloading 20 bytes @ address 0x80E81B18
Writing register (PC = 0x80e80000)
Read 4 bytes @ address 0x80E810EC (Data = 0xFFFFFFFF)
Read 4 bytes @ address 0x80E80098 (Data = 0xFFFFFFFF)
Read 4 bytes @ address 0x80E8013C (Data = 0xFFFFFFFF)
Read 4 bytes @ address 0x80E800F4 (Data = 0xFFFFFFFF)
Read 4 bytes @ address 0x80E802BC (Data = 0xFFFFFFFF)
Read 4 bytes @ address 0x80E81084 (Data = 0xFFFFFFFF)
Read 4 bytes @ address 0x80E81008 (Data = 0xFFFFFFFF)
Read 4 bytes @ address 0x80E80050 (Data = 0xFFFFFFFF)
Read 4 bytes @ address 0x80E80000 (Data = 0xFFFFFFFF)
Firstly, gdb cann't read cpu register normal.Some strange address appeared.
Secondly, data in SDRAM is invalid.May be some errors in my configuration files.
Next is all code about SDRAM initialize:
minitor writeu32 0x48002584 = 0x00008600
monitor writeu32 0x6D000018 = 0x04446248
monitor writeu32 0x6D00001C = 0x04446248
monitor writeu32 0x6D000020 = 0x141631CA
monitor writeu32 0x6D000024 = 0x141631CA
monitor writeu32 0x6D000028 = 0x157
monitor writeu32 0x6D00002C = 0x157
monitor writeu32 0x6D000038 = 0x80000000
monitor writeu32 0x6D00003C = 0x80000000
monitor writeu32 0x6D000010 = 0x50E
monitor writeu32 0x6D000014 = 0x50E
monitor writeu32 0x6D000008 = 0x48801632
please help me ...
