TILER AllocFailed
We use DM8168 and DVRRDK 03.00.00.00. based software stack.
We get warnings "TILER AllocFailed"
2 questings: Is it dangerous, how can we avoid this ?
PFA log file.
U-Boot 2010.06-svn616 (Apr 25 2014 - 10:27:19)
TI8168-GP rev 2.1
ARM clk: 1000MHz
DDR clk: 796MHz
HDVICP clk: 600MHz
L3 Fast clk: 560MHz
HDVPSS clk: 280MHz
Ducati M3 clk: 280MHz
DSP clk: 800MHz
I2C:   ready
DRAM:  2 GiB
NAND:  HW ECC BCH8 Selected
1024 MiB
MMC:   OMAP SD/MMC: 0
Net:   Ethernet PHY: GENERIC @ 0x01
DaVinci EMAC
Initializing USB ...
musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 2.0
musb-hdrc: setup fifo_mode 4
musb-hdrc: 2
TI8168-GP rev 2.1
ARM clk: 1000MHz
DDR clk: 796MHz
HDVICP clk: 600MHz
L3 Fast clk: 560MHz
HDVPSS clk: 280MHz
DSP clk: 800MHz
I2C:   ready
DRAM:  2 GiB
1024 MiB
MMC:   OMAP SD/MMC: 0
DaVinci EMAC
musb-hdrc: 28/31 max ep, 16384/16384 memory
USB Host mode controller at 47401000 using PIO, IRQ 0
Hit any key to stop autoboot:  1  0
Read WEB update notify area
NAND read: 0x80757B84 device 0 offset 0xcf60000, size 0x8
 8 bytes read: OK
NO firmware update via WEB interface was launched, continue...
USB0:   scanning bus 0 for devices... 2 USB Device(s) found
0 Storage Device(s) found
NO USB device found
NO USB storage device attachedConnect speed 100M Full
Using DaVinci EMAC device
host 192.168.72.100 is alive
TFTP from server 192.168.72.100; our IP address is 192.168.72.200
Filename 'uImage_DM816X_DVR'.
Load address: 0x81000000
Loading: *#################################################################
done
Bytes transferred = 2519652 (0x267264)
## Booting kernel from Legacy Image at 81000000 ...
   Image Name:   Linux-2.6.37+
   Created:      2014-05-26  14:51:43 UTC
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    2519588 Bytes = 2.4 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Linux version 2.6.37+ (heb@heb) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #4 Mon May 26 16:51:35 CEST 2014
CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: ti8168_dvr
vram size = 20971520 at 0x0
reserved size = 20971520 at 0x0
FB: Reserving 20971520 bytes SDRAM for VRAM
Memory policy: ECC disabled, Data cache writeback
OMAP chip is TI8168 2.0
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 145488
Kernel command line: rootdelay=2 console=ttyO2,115200n8 init=/linuxrc root=/dev/nfs rw nfsroot=192.168.72.100:/home/heb/tftpboot/rfs_816x ip=192.168.72.200:192.168.72.100:192.168.1.1:255.255.255.0::eth0:off vram=20M notifyk.vpssm3_sva=0xBEE00000 mem=128M mem=472M@0xC0000000 vmalloc=580M
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 128MB 452MB = 580MB total
Memory: 583264k/583264k available, 31136k reserved, 139264K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xffc00000 - 0xffe00000   (   2 MB)
    vmalloc : 0xd4000000 - 0xf8000000   ( 576 MB)
    lowmem  : 0x80000000 - 0xd3c00000   (1340 MB)
    pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
    modules : 0x7f000000 - 0x7fe00000   (  14 MB)
      .init : 0x80008000 - 0x8003a000   ( 200 kB)
      .text : 0x8003a000 - 0x804c2000   (4640 kB)
      .data : 0x804c2000 - 0x8050e000   ( 304 kB)
SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:407
IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
Total of 128 interrupts on 1 active controller
GPMC revision 6.0
Trying to install interrupt handler for IRQ400
Trying to install interrupt handler for IRQ401
Trying to install interrupt handler for IRQ402
Trying to install interrupt handler for IRQ403
Trying to install interrupt handler for IRQ404
Trying to install interrupt handler for IRQ405
Trying to install interrupt handler for IRQ406
Trying to install type control for IRQ407
Trying to set irq flags for IRQ407
OMAP clockevent source: GPTIMER1 at 27000000 Hz
Console: colour dummy device 80x30
Calibrating delay loop... 999.42 BogoMIPS (lpj=4997120)
pid_max: default: 32768 minimum: 301
Security Framework initialized
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
devtmpfs: initialized
omap_voltage_early_init: voltage driver support not added
regulator: core version 0.5
regulator: dummy:
NET: Registered protocol family 16
omap_voltage_domain_lookup: Voltage driver init not yet happened.Faulting!
omap_voltage_add_dev: VDD specified does not exist!
OMAP GPIO hardware version 0.1
 drivers/spi/spi.c spi_init
omap_mux_init: Add partition: #1: core, flags: 0
3-wired eeprom init done. (H/W ver:ffff)
_omap_mux_get_by_name: Could not find signal i2c2_scl.i2c2_scl
_omap_mux_get_by_name: Could not find signal i2c2_sda.i2c2_sda
registered ti816x_sr device
pm_dbg_init: only OMAP3 supported
registered ti81xx_vpss device
registered ti81xx_vidout device
registered ti81xx on-chip HDMI device
registered ti81xx_fb device
ti81xx_pcie: Invoking PCI BIOS...
ti81xx_pcie: Setting up Host Controller...
ti81xx_pcie: Register base mapped @0xd4020000
ti81xx_pcie: Starting PCI scan...
PCI: bus0: Fast back to back transfers disabled
PCI: bus1: Fast back to back transfers disabled
pci 0000:00:00.0: BAR 8: assigned [mem 0x20000000-0x200fffff]
pci 0000:01:00.0: BAR 0: assigned [mem 0x20000000-0x20001fff 64bit]
pci 0000:01:00.0: BAR 0: set to [mem 0x20000000-0x20001fff 64bit] (PCI address [0x20000000-0x20001fff])
pci 0000:00:00.0: PCI bridge to [bus 01-01]
pci 0000:00:00.0:   bridge window [io  disabled]
pci 0000:00:00.0:   bridge window [mem 0x20000000-0x200fffff]
pci 0000:00:00.0:   bridge window [mem pref disabled]
PCI: enabling device 0000:00:00.0 (0140 -> 0143)
bio: create slab <bio-0> at 0
vgaarb: loaded
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
USBSS revision 4ea20809
registerd cppi-dma Intr @ IRQ 17
Cppi41 Init Done
omap_i2c omap_i2c.1: bus 1 rev4.0 at 400 kHz
regulator: pmbus_vr: 800 <--> 1050 mV at 1000 mV
regulator: tps40400 probe done.
omap_i2c omap_i2c.2: bus 2 rev4.0 at 400 kHz
Advanced Linux Sound Architecture Driver Version 1.0.23.
Switching to clocksource gp timer
musb-hdrc: version 6.0, host, debug=0
musb-hdrc musb-hdrc.0: dma type: dma-cppi41
MUSB controller-0 revision 4ea20800
musb-hdrc musb-hdrc.0: MUSB HDRC host driver
musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: MUSB HDRC host driver
usb usb1: Manufacturer: Linux 2.6.37+ musb-hcd
usb usb1: SerialNumber: musb-hdrc.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
musb-hdrc musb-hdrc.0: USB Host mode controller at d401e000 using DMA, IRQ 18
musb-hdrc musb-hdrc.1: dma type: dma-cppi41
MUSB controller-1 revision 4ea20800
musb-hdrc musb-hdrc.1: MUSB HDRC host driver
musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: MUSB HDRC host driver
usb usb2: Manufacturer: Linux 2.6.37+ musb-hcd
usb usb2: SerialNumber: musb-hdrc.1
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
musb-hdrc musb-hdrc.1: USB Host mode controller at d4026800 using DMA, IRQ 19
NET: Registered protocol family 2
IP route cache hash table entries: 16384 (order: 4, 65536 bytes)
TCP established hash table entries: 65536 (order: 7, 524288 bytes)
TCP bind hash table entries: 65536 (order: 6, 262144 bytes)
TCP: Hash tables configured (established 65536 bind 65536)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
NetWinder Floating Point Emulator V0.97 (double precision)
PMU: registered new PMU device of type 0
omap-iommu omap-iommu.0: ducati registered
omap-iommu omap-iommu.1: sys registered
highmem bounce pool size: 64 pages
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 867
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0
omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
console [ttyO2] enabled
brd: module loaded
loop: module loaded
omap2-nand driver initializing
ONFI flash detected
NAND device: Maf ID: 0x2c, Chip ID: 0xb3 (Micron, )
 erasesize: 0x20000, writesize: 2048, oobsize: 64
Creating 11 MTD partitions on "omap2-nand.0":
0x000000000000-0x000000240000 : "U-Boot"
0x000000240000-0x000000280000 : "U-Boot Env"
0x000000280000-0x000000580000 : "Boot Splash"
0x000000580000-0x0000009c0000 : "Kernel"
0x0000009c0000-0x0000086c0000 : "File System"
0x0000086c0000-0x00000cee0000 : "Firmware Upload"
0x00000cee0000-0x00000cf20000 : "BOP Keys"
0x00000cf20000-0x00000cf60000 : "BOP Config"
0x00000cf60000-0x00000cfa0000 : "Web update notify"
0x00000cfa0000-0x00000d2c0000 : "Update header"
0x00000d2c0000-0x000040000000 : "Reserved"
davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
davinci_mdio davinci_mdio.0: detected phy mask fffffffd
usb 1-1: new high speed USB device using musb-hdrc and address 2
davinci_mdio.0: probed
davinci_mdio davinci_mdio.0: phy[1]: device 0:01, driver unknown
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver dm9601
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver usbserial
USB Serial support registered for generic
usb 1-1: New USB device found, idVendor=0409, idProduct=005a
usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial Driver core
USB Serial support registered for FTDI USB Serial Device
usbcore: registered new interface driver ftdi_sio
ftdi_sio: v1.6.0:USB FTDI Serial Converters Driver
USB Serial support registered for pl2303
usbcore: registered new interface driver pl2303
pl2303: Prolific PL2303 USB to serial adaptor driver
mice: PS/2 mouse device common for all mice
rtc-ds1307 1-0068: rtc core: registered ds1337 as rtc0
omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc1
i2c /dev entries driver
Linux video capture interface: v2.00
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v1.0.0)
OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
notify_init : notify drivercreated  for  remote proc id 2 at physical Address 0xbee00000
usbcore: registered new interface driver snd-usb-audio
Registered tvp5158 audio codec
asoc: tvp5158-hifi <-> davinci-mcasp.0 mapping ok
asoc: tlv320aic3x-hifi <-> davinci-mcasp.2 mapping ok
asoc: HDMI-DAI-CODEC <-> hdmi-dai mapping ok
ALSA device list:
  #0: TI81XX DVR
TCP cubic registered
NET: Registered protocol family 17
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
omap_voltage_late_init: Voltage driver support not added
Power Management for TI81XX.
smartreflex-ti816x: ti816x_sr_probe done!
rtc-ds1307 1-0068: setting system clock to 2014-05-27 06:26:02 UTC (1401171962)
usb 1-1.4: new high speed USB device using musb-hdrc and address 3
usb 1-1.4: New USB device found, idVendor=0b95, idProduct=772a
usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-1.4: Product: AX88772
usb 1-1.4: Manufacturer: ASIX Elec. Corp.
usb 1-1.4: SerialNumber: 000001
davinci_mdio davinci_mdio.0: resetting idled controller
net eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0:01, id=2430d91)
IP-Config: Gateway not on directly connected network.
Waiting 2sec before mounting root device...
PHY: 0:01 - Link is Up - 100/Full
VFS: Mounted root (nfs filesystem) on device 0:15.
devtmpfs: mounted
Freeing init memory: 200K
May 27 08:26:16 192 user.notice root: #### -- init_816x.sh - START
*** Bootargs Validated for mem param ***
*** Bootargs Validated for notifyk.vpssm3 params ***
Kernel bootargs validated
numid=101,iface=MIXER,name='Left DAC Mux'
  ; type=ENUMERATED,access=rw------,values=1,items=3
  ; Item #0 'DAC_L1'
  ; Item #1 'DAC_L3'
  ; Item #2 'DAC_L2'
  : values=2
numid=99,iface=MIXER,name='Right DAC Mux'
  ; Item #0 'DAC_R1'
  ; Item #1 'DAC_R3'
  ; Item #2 'DAC_R2'
  : values=2
May 27 08:26:18 192 user.notice root: DMP ./init.sh - insmod syslink.ko
 [c6xdsp ] Remote Debug Shared Memory @ 0xbf000000
 [m3video] Remote Debug Shared Memory @ 0xbf005020
 [m3vpss ] Remote Debug Shared Memory @ 0xbf00a040
SysLink version : 2.10.02.17
SysLink module created on Date:Apr 24 2014 Time:17:37:03
Trace enabled
Trace SetFailureReason enabled
./init.sh: line 43: LoggerClear: not found
May 27 08:26:20 bd-10310013 syslog.info syslogd started: BusyBox v1.19.4
 Setting DMM priority for [DUCATI  ] to [0] ( 0x4e000624 = 0x08000000 )
 Setting DMM priority for [HDVICP0 ] to [2] ( 0x4e000634 = 0x0000000a )
 Setting DMM priority for [HDVICP1 ] to [2] ( 0x4e000634 = 0x000a0000 )
 Setting DMM priority for [HDVICP2 ] to [2] ( 0x4e000634 = 0x00a00000 )
Attached to slave procId 2.
Loaded file ../firmware/dvr_rdk_fw_m3vpss.xem3 on slave procId 2.
Started slave procId 2.
After Ipc_loadcallback status [0x00000000]
After Ipc_startcallback status [0x097d2000]
May 27 08:26:21 bd-10310013 user.info : [m3vpss ] ***** SYSTEM  : Frequency <ORG> - 250000000, <NEW> - 250000000
May 27 08:26:21 bd-10310013 user.info : [m3vpss ] notify_attach  rtnVal  0
May 27 08:26:21 bd-10310013 user.info : [m3vpss ] initProxyServer  rtnVal  0
May 27 08:26:21 bd-10310013 user.info : [m3vpss ]  *** UTILS: CPU KHz = 500000 Khz ***
May 27 08:26:21 bd-10310013 user.info : [m3vpss ]  48: SYSTEM: IPC init in progress !!!
May 27 08:26:21 bd-10310013 user.info : [m3vpss ]  48: SYSTEM: Attaching to [HOST] ...
May 27 08:26:21 bd-10310013 user.info : [m3vpss ]  1047: SYSTEM: Attaching to [HOST] ...
May 27 08:26:21 bd-10310013 user.info : [m3vpss ]  1049: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
May 27 08:26:21 bd-10310013 user.info : [m3vpss ]  1049: SYSTEM: Attaching to [DSP] ...
Attached to slave procId 1.
Loaded file ../firmware/dvr_rdk_fw_m3video.xem3 on slave procId 1.
Started slave procId 1.
After Ipc_startcallback status [0x00000000]
May 27 08:26:23 bd-10310013 user.info : [m3video] ***** SYSTEM  : Frequency <ORG> - 250000000, <NEW> - 250000000
May 27 08:26:23 bd-10310013 user.info : [m3vpss ]  2049: SYSTEM: Attaching to [DSP] ...
May 27 08:26:23 bd-10310013 user.info : [m3video]  *** UTILS: CPU KHz = 500000 Khz ***
May 27 08:26:23 bd-10310013 user.info : [m3video]  1618: SYSTEM: IPC init in progress !!!
May 27 08:26:23 bd-10310013 user.info : [m3video]  1618: SYSTEM: Attaching to [HOST] ...
May 27 08:26:23 bd-10310013 user.info : [m3video]  2617: SYSTEM: Attaching to [HOST] ...
May 27 08:26:23 bd-10310013 user.info : [m3video]  2619: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
May 27 08:26:23 bd-10310013 user.info : [m3video]  2619: SYSTEM: Attaching to [DSP] ...
Attached to slave procId 0.
Loaded file ../firmware/dvr_rdk_fw_c6xdsp.xe674 on slave procId 0.
Started slave procId 0.
May 27 08:26:24 bd-10310013 user.info : [c6xdsp ] ***** SYSTEM  : Frequency <ORG> - 800000000, <NEW> - 800000000
May 27 08:26:24 bd-10310013 user.info : [m3video]  3619: SYSTEM: Attaching to [DSP] ...
May 27 08:26:24 bd-10310013 user.info : [m3vpss ]  3049: SYSTEM: Attaching to [DSP] ...
May 27 08:26:24 bd-10310013 user.info : [c6xdsp ]  *** UTILS: CPU KHz = 800000 Khz ***
May 27 08:26:24 bd-10310013 user.info : [c6xdsp ]  5: SYSTEM: IPC init in progress !!!
May 27 08:26:24 bd-10310013 user.info : [c6xdsp ]  5: SYSTEM: Attaching to [HOST] ...
May 27 08:26:24 bd-10310013 user.info : [c6xdsp ]  1012: SYSTEM: Attaching to [HOST] ...DMA: Module install successful, device major num = 251
May 27 08:26:DRV: Module install successful
24 bd-10310013 uDRV: Module built on May 26 2014 16:45:08
ser.info : [c6xdsp ]  1014: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
May 27 08:26:24 bd-10310013 user.info : [c6xdsp ]  1014: SYSTEM: Attaching to [VIDEO-M3] ...
May 27 08:26:24 bd-10310013 user.info : [m3vpss ]  4049: SYSTEM: Attaching to [DSP] ...
May 27 08:26:24 bd-10310013 user.info kernel: DMA: Module install successful, device major num = 251
May 27 08:26:24 bd-10310013 user.info kernel: DRV: Module install successful
May 27 08:26:24 bd-10310013 user.info kernel: DRV: Module built on May 26 2014 16:45:08
May 27 08:26:25 bd-10310013 user.info : [m3video]  4619: SYSTEM: Attaching to [DSP] ...
May 27 08:26:25 bd-10310013 user.info : [m3vpss ]  5049: SYSTEM: Attaching to [DSP] ...
May 27 08:26:25 bd-10310013 user.info : [c6xdsp ]  2021: SYSTEM: Attaching to [VIDEO-M3] ...
May 27 08:26:26 bd-10310013 user.info : [c6xdsp ]  2500: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
May 27 08:26:26 bd-10310013 user.info : [m3video]  5619: SYSTEM: Attaching to [DSP] ...
May 27 08:26:26 bd-10310013 user.info : [c6xdsp ]  2500: SYSTEM: Attaching to [VPSS-M3] ...
May 27 08:26:26 bd-10310013 user.info : [m3video]  5619: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
May 27 08:26:26 bd-10310013 user.info : [m3video]  5619: SYSTEM: Attaching to [VPSS-M3] ...
May 27 08:26:26 bd-10310013 user.info : [m3vpss ]  6049: SYSTEM: Attaching to [DSP] ...
May 27 08:26:26 bd-10310013 user.info : [m3video]  6619: SYSTEM: Attaching to [VPSS-M3] ...
May 27 08:26:27 bd-10310013 user.info : [c6xdsp ]  3507: SYSTEM: Attaching to [VPSS-M3] ...
May 27 08:26:27 bd-10310013 user.info : [c6xdsp ]  3777: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
May 27 08:26:27 bd-10310013 user.info : [m3vpss ]  7049: SYSTEM: Attaching to [DSP] ...
May 27 08:26:27 bd-10310013 user.info : [c6xdsp ]  3777: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
May 27 08:26:27 bd-10310013 user.info : [m3vpss ]  7049: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
May 27 08:26:27 bd-10310013 user.info : [m3vpss ]  7050: SYSTEM: Attaching to [VIDEO-M3] ...
May 27 08:26:27 bd-10310013 user.info : [m3video]  7619: SYSTEM: Attaching to [VPSS-M3] ...
May 27 08:26:28 bd-10310013 user.info : [m3video]  8050: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
May 27 08:26:28 bd-10310013 user.info : [m3vpss ]  8049: SYSTEM: Attaching to [VIDEO-M3] ...
May 27 08:26:28 bd-10310013 user.info : [m3video]  8050: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
May 27 08:26:28 bd-10310013 user.info : [m3vpss ]  8050: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
May 27 08:26:28 bd-10310013 user.info : [m3video]  8050: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
May 27 08:26:28 bd-10310013 user.info : [m3vpss ]  8050: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
May 27 08:26:28 bd-10310013 user.info : [m3video]  8050: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
May 27 08:26:28 bd-10310013 user.info : [m3vpss ]  8050: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
May 27 08:26:28 bd-10310013 user.info : [m3video]  8052: SYSTEM: Notify register to [HOST] line 0, event 15 ...
May 27 08:26:28 bd-10310013 user.info : [m3vpss ]  8050: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
May 27 08:26:28 bd-10310013 user.info : [m3video]  8052: SYSTEM: Notify register to [DSP] line 0, event 15 ...
May 27 08:26:28 bd-10310013 user.info : [m3vpss ]  8052: SYSTEM: Notify register to [HOST] line 0, event 15 ...
May 27 08:26:28 bd-10310013 user.info : [m3video]  8052: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
May 27 08:26:28 bd-10310013 user.info : [m3vpss ]  8052: SYSTEM: Notify register to [DSP] line 0, event 15 ...
May 27 08:26:28 bd-10310013 user.info : [m3video]  8052: SYSTEM: IPC init DONE !!!
May 27 08:26:28 bd-10310013 user.info : [m3vpss ]  8052: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
May 27 08:26:28 bd-10310013 user.info : [m3video]  8059: MEM: Shared Region 2: Base = 0xb0000000, Length = 0x0e9c0000 (233 MB)
May 27 08:26:28 bd-10310013 user.info : [m3vpss ]  8052: SYSTEM: IPC init DONE !!!
May 27 08:26:28 bd-10310013 user.info : [m3video]  8059: MEM: Shared Region 1: Base = 0x88000000, Length = 0x15000000 (336 MB)
May 27 08:26:28 bd-10310013 user.info : [m3vpss ]  8058: MEM: Shared Region 2: Base = 0xb0000000, Length = 0x0e9c0000 (233 MB)
May 27 08:26:28 bd-10310013 user.info : [m3vpss ]  8059: MEM: Shared Region 1: Base = 0x88000000, Length = 0x15000000 (336 MB)
May 27 08:26:28 bd-10310013 user.info : [m3vpss ] === HDVPSS Clocks are enabled ===
May 27 08:26:28 bd-10310013 user.info : [m3vpss ] === HDVPSS is fully functional ===
May 27 08:26:28 bd-10310013 user.info : [m3vpss ] === HDVPSS module is not in standby ===
May 27 08:26:28 bd-10310013 user.info : [m3vpss ] === I2C1 Clk is active ===
May 27 08:26:28 bd-10310013 user.info : [m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to VPS_PLATFORM_CPU_REV_2_0
May 27 08:26:28 bd-10310013 user.info : [m3video]  8089: HDVICP: Doing PRCM for IVAHD[0] ...
May 27 08:26:28 bd-10310013 user.info : [m3video]  8089: HDVICP: PRCM for IVAHD[0] ... DONE.
May 27 08:26:28 bd-10310013 user.info : [m3video]  8089: HDVICP: Doing PRCM for IVAHD[1] ...
May 27 08:26:28 bd-10310013 user.info : [m3video]  8089: HDVICP: PRCM for IVAHD[1] ... DONE.
May 27 08:26:28 bd-10310013 user.info : [m3video]  8089: HDVICP: Doing PRCM for IVAHD[2] ...
May 27 08:26:28 bd-10310013 user.info : [m3video]  8089: HDVICP: PRCM for IVAHD[2] ... DONE.
May 27 08:26:28 bd-10310013 user.info : [m3video]  8090: SYSTEM  : Initializing Links !!!
May 27 08:26:28 bd-10310013 user.info : [m3video]  8122: SYSTEM  : Initializing Links ... DONE !!!
May 27 08:26:28 bd-10310013 user.info : [c6xdsp ]  4784: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
May 27 08:26:28 bd-10310013 user.info : [m3vpss ] initPrms.isI2cInitReq = 0
May 27 08:26:28 bd-10310013 user.info : [c6xdsp ]  4784: SYSTEM: Creating MsgQ [DSP_MSGQ] ...
May 27 08:26:28 bd-10310013 user.info : [c6xdsp ]  4784: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ...
May 27 08:26:28 bd-10310013 user.info : [c6xdsp ]  4784: SYSTEM: Notify register to [HOST] line 0, event 15 ...
May 27 08:26:28 bd-10310013 user.info : [c6xdsp ]  4784: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
May 27 08:26:28 bd-10310013 user.info : [c6xdsp ]  4785: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
May 27 08:26:28 bd-10310013 user.info : [c6xdsp ]  4785: SYSTEM: IPC init DONE !!!
May 27 08:26:28 bd-10310013 user.info : [c6xdsp ]  4787: MEM: Shared Region 2: Base = 0xb0000000, Length = 0x0e9c0000 (233 MB)
Ma[module] vpss probe done.
y 27 08:26:28 bd-10310013 user.info : [c6xdsp ]  4787: MEM: Shared Region 1: Base = 0x88000000, Length = 0x15000000 (336 MB)
May 27 08:26:28 bd-10310013 user.info : [c6xdsp ]  4748: SYSTEM  : RpeServer_init() done... Ret Val 0!!!
May 27 08:26:28 bd-10310013 user.info : [c6xdsp ] !!WARNING.Resource already registered:2
May 27 08:26:28 bd-10310013 user.info : [c6xdsp ]  4754: SYSTEM  : Initializing Links !!!
May 27 08:26:28 bd-10310013 user.info : [c6xdsp ]  4764: SYSTEM  : Initializing Links ... DONE !!!
May 27 08:26:28 bd-10310013 user.info : [m3vpss ]  8306: UTILS: DMA: HWI Cr[module] ti81xxfb probe done.
eate for INT63 !!!
May 27 08:26:28 bd-10310013 user.info : [m3vpss ]  8306: SYSTEM  : Initializing Links !!!
May 27 08:26:28 bd-10310013 user.info : [m3vpss ]  8420: SYSTEM  : Initializing Links ... DONE !!!
 [m3vpss ] Received character 's'
May 27 08:26:28 bd-10310013 user.info : [m3vpss ]  8420: SYSTEM  : Set Static L3 pressure for HDVPSS as HDMI W1 rev 2.0
High
 [m3vpss ] Remote Debug Shared Mem[module] ti81xx_hdmi probe done.
ory @ 0xbf00a040
 [m3video] Received character 's'
 [c6xdsp ] Received character 's'
/opt/ti816x
May 27 08:26:28 bd-10310013 user.warn kernel: [module] vpss probe done.
May 27 08:26:28 bd-10310013 user.warn kernel: [module] ti81xxfb probe done.
May 27 08:26:28 bd-10310013 user.info kernel: HDMI W1 rev 2.0
May 27 08:26:28 bd-10310013 user.warn kernel: [module] ti81xx_hdmi probe done.
May 27 08:26:28 bd-10310013 user.debug kernel: found best resolution: 1400x1050 (30)
 MEM_RDWR_writeMem: ORG 0x46c00524: 0
 MEM_RDWR_writeMem: NEW 0x46c00524: 2
May 27 08:26:30 bd-10310013 user.notice root: #### -- init_816x.sh - READY
May 27 06:27:15 bd-10310013 user.info DMP : dmp_SetDisplayMosaicCombination: 0
May 27 06:27:15 bd-10310013 user.info SAA7129 : SAA7129 detected
May 27 06:27:15 bd-10310013 user.info DMP_VCAP_VENC_VDEC_VDIS : VcapVencVdecVdis_start: Channel details: Capture = 16 / Primary Encoder = 18 / Secondary Encoder = 17 / Decoder = 16 / Display = 32
May 27 06:27:15 bd-10310013 user.notice [host] :  0: SYSTEM: IPC init in progress !!!
May 27 06:27:15 bd-10310013 user.debug [host] : System_ipcMsgQTaskMain: TID=2080
May 27 06:27:15 bd-10310013 user.notice [host] :  31: SYSTEM: Notify register to [DSP] line 0, event 15 ...
May 27 06:27:15 bd-10310013 user.notice [host] :  32: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
May 27 06:27:15 bd-10310013 user.notice [host] :  33: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
May 27 06:27:15 bd-10310013 user.notice [host] :  33: SYSTEM: IPC init DONE !!!
May 27 06:27:15 bd-10310013 user.debug [host] : IpcBitsInLink_init: Task IpcBitsInLink_tskMain 0 created
May 27 06:27:15 bd-10310013 user.debug [host] : IpcBitsInLink_init: Task IpcBitsInLink_tskMain 1 created
May 27 06:27:15 bd-10310013 user.notice [host] :  36: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
May 27 06:27:15 bd-10310013 user.debug [host] : IpcBitsOutLink_init: Task IpcBitsOutLink_tskMain 0 created
May 27 06:27:15 bd-10310013 user.notice [host] :  41: SYSTEM: Creating ListMP [HOST_IPC_OUT_26] in region 0 ...
May 27 06:27:15 bd-10310013 user.debug [host] : IpcBitsOutLink_init: Task IpcBitsOutLink_tskMain 1 created
May 27 06:27:15 bd-10310013 user.debug [host] : IpcFramesInLink_init: Task IpcFramesInLink_tskMain 0 created
May 27 06:27:15 bd-10310013 user.debug [host] : IpcFramesInLink_init: Task IpcFramesInLink_tskMain 1 created
May 27 06:27:15 bd-10310013 user.notice [host] :  48: SYSTEM: Creating ListMP [HOST_IPC_OUT_20] in region 0 ...
May 27 06:27:15 bd-10310013 user.debug [host] : IpcFramesOutLink_init: Task IpcFramesOutLink_tskMain 0 created
May 27 06:27:15 bd-10310013 user.notice [host] :  54: SYSTEM: Creating ListMP [HOST_IPC_OUT_21] in region 0 ...
May 27 06:27:15 bd-10310013 user.debug [host] : IpcFramesOutLink_init: Task IpcFramesOutLink_tskMain 1 created
May 27 06:27:15 bd-10310013 user.notice [host] :  62: SYSTEM: Creating ListMP [HOST_IPC_OUT_22] in region 0 ...
May 27 06:27:15 bd-10310013 user.debug [host] : IpcFramesOutLink_init: Task IpcFramesOutLink_tskMain 2 created
May 27 06:27:15 bd-10310013 user.debug [host] : SystemLink_init: Task SystemLink_tskMain created
May 27 06:27:16 bd-10310013 user.debug DMP_VIDEO_RECORD : VcapVenc_Thread: TID=2107
May 27 06:27:16 bd-10310013 user.info MULTICH_PROGRESSIVE_VCAP_VENC_VDEC_VDIS : Entered usecase 16CH Progressive <816x> Cap/Enc/Dec/Dis
May 27 06:27:16 bd-10310013 user.notice TI_VCAP :  Vcap_configVideoDecoder: TVP5158-0 (0x5c): Detected video (720x288@50Hz, 1)
May 27 06:27:16 bd-10310013 user.notice TI_VCAP :  Vcap_configVideoDecoder: TVP5158-1 (0x5d):  NO Video Detected
May 27 06:27:16 bd-10310013 user.notice TI_VCAP :  Vcap_configVideoDecoder: TVP5158-2 (0x5e):  NO Video Detected
May 27 06:27:16 bd-10310013 user.notice TI_VCAP :  Vcap_configVideoDecoder: TVP5158-3 (0x5f):  NO Video Detected
May 27 08:27:21 bd-10310013 user.info : [m3vpss ]  67946: CAPTURE: VIP0 PortA capture mode is [ 8-bit, Pixel-mux Embedded Sync] !!!
May 27 08:27:21 bd-10310013 user.info : [m3vpss ]  68033: CAPTURE: VIP0 PortB capture mode is [ 8-bit, Pixel-mux Embedded Sync] !!!
May 27 08:27:21 bd-10310013 user.info : [m3vpss ]  68121: CAPTURE: VIP1 PortA capture mode is [ 8-bit, Pixel-mux Embedded Sync] !!!
May 27 08:27:21 bd-10310013 user.info : [m3vpss ]  68208: CAPTURE: VIP1 PortB capture mode is [ 8-bit, Pixel-mux Embedded Sync] !!!
May 27 08:27:21 bd-10310013 user.info : [m3vpss ]  68308: CAPTURE: 0: 0xb48c0c80, 736 x 288, 00067800 B --> Extra Frames
May 27 08:27:21 bd-10310013 user.info : [m3vpss ]  68308: CAPTURE: 1: 0xb4928480, 736 x 288, 00067800 B --> Extra Frames
May 27 08:27:21 bd-10310013 user.info : [m3vpss ]  68308: CAPTURE: 2: 0xb498fc80, 736 x 288, 00067800 B --> Extra Frames
May 27 08:27:21 bd-10310013 user.info : [m3vpss ]  68308: CAPTURE: 3: 0xb49f7480, 736 x 288, 00067800 B --> Extra Frames
May 27 08:27:21 bd-10310013 user.info : [m3vpss ]  68308: CAPTURE: 4: 0xb4a5ec80, 736 x 288, 00067800 B --> Extra Frames
May 27 08:27:21 bd-10310013 user.info : [m3vpss ]  68309: CAPTURE: 5: 0xb4ac6480, 736 x 288, 00067800 B --> Extra Frames
May 27 08:27:21 bd-10310013 user.info : [m3vpss ]  UTILS: DMA: Allocated CH (TCC) = 58 (58)
May 27 08:27:22 bd-10310013 user.info : [m3vpss ]  68663: DEI     : Loading Up-scaling Co-effs
May 27 08:27:22 bd-10310013 user.info : [m3vpss ]  68663: DEI     : Co-effs Loading ... DONE !!!
May 27 08:27:22 bd-10310013 user.info : [c6xdsp ]  59105: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
May 27 08:27:22 bd-10310013 user.info : [m3vpss ]  69013: DEI     : Loading Up-scaling Co-effs
May 27 08:27:22 bd-10310013 user.info : [m3vpss ]  69013: DEI     : Co-effs Loading ... DONE !!!
May 27 08:27:22 bd-10310013 user.info : [c6xdsp ]  59108: ALG : Create in progress !!!
May 27 08:27:22 bd-10310013 user.info : [c6xdsp ]  59115: ALG : Create Done !!!
May 27 06:27:22 bd-10310013 user.debug [host] : IpcBitsOutLink_tskMain: TID=2083
May 27 06:27:22 bd-10310013 user.debug [host] : IpcBitsOutLink_periodicTaskFxn: TID=2391
May 27 08:27:22 bd-10310013 user.info : [m3video]  69044: SYSTEM: Opening MsgQ [HOST_MSGQ] ...
May 27 08:27:22 bd-10310013 user.info : [m3video]  69071: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
May 27 08:27:23 bd-10310013 user.info : [m3vpss ]  69517: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
May 27 08:27:23 bd-10310013 user.info : [m3vpss ]  UTILS: DMA: Allocated CH (TCC) = 59 (59)
May 27 08:27:23 bd-10310013 user.info : [m3vpss ]  UTILS: DMA: Allocated CH (TCC) = 60 (60)
May 27 08:27:23 bd-10310013 user.info : [m3vpss ] SWMS: instance 0, sc id 5, start win 0 end win 17
May 27 08:27:23 bd-10310013 user.info : [m3vpss ]  UTILS: DMA: Allocated CH (TCC) = 61 (61)
May 27 08:27:23 bd-10310013 user.info : [m3vpss ]  UTILS: DMA: Allocated CH (TCC) = 62 (62)
May 27 08:27:23 bd-10310013 user.info : [m3video] ENCLINK:INFO: !!!Number of output buffers for ch[35] set to [1]
May 27 08:27:23 bd-10310013 user.info : [m3vpss ] 69847:WARN
May 27 08:27:23 bd-10310013 user.info : [m3vpss ] 69847:TILER AllocFailed:CntMode:0,Width=896,Height=640
May 27 08:27:23 bd-10310013 user.info : [m3vpss ] 69969:WARN
May 27 08:27:23 bd-10310013 user.info : [m3vpss ] 69969:TILER AllocFailed:CntMode:0,Width=896,Height=640
May 27 08:27:23 bd-10310013 user.info : [m3vpss ] 69973:WARN
May 27 08:27:23 bd-10310013 user.info : [m3vpss ] 69973:TILER AllocFailed:CntMode:0,Width=896,Height=640
May 27 08:27:23 bd-10310013 user.info : [m3vpss ] 69980:WARN
May 27 08:27:23 bd-10310013 user.info : [m3vpss ] 69980:TILER AllocFailed:CntMode:0,Width=896,Height=640
May 27 08:27:23 bd-10310013 user.info : [m3vpss ] 69984:WARN
May 27 08:27:23 bd-10310013 user.info : [m3vpss ] 69984:TILER AllocFailed:CntMode:0,Width=896,Height=640
May 27 08:27:23 bd-10310013 user.info : [m3vpss ] 69991:WARN
May 27 08:27:23 bd-10310013 user.info : [m3vpss ] 69991:TILER AllocFailed:CntMode:0,Width=896,Height=640
May 27 06:27:23 bd-10310013 user.debug [host] : IpcBitsInLink_tskMain: TID=2081
May 27 06:27:23 bd-10310013 user.notice [host] :  7629: IPC_BITS_IN   : ListMPOpen start !!!
May 27 08:27:23 bd-10310013 user.info : [m3vpss ] 69995:WARN
May 27 08:27:23 bd-10310013 user.info : [m3vpss ] 69995:TILER AllocFailed:CntMode:0,Width=896,Height=640
May 27 06:27:23 bd-10310013 user.notice [host] :  7634: IPC_BITS_IN   : ListMPOpen done !!!
May 27 06:27:23 bd-10310013 user.notice [host] :  7636: IPC_BITS_IN   : System_linkGetInfo done !!!
May 27 06:27:23 bd-10310013 user.debug [host] : IpcBitsInLink_periodicTaskFxn: TID=2430
May 27 08:27:23 bd-10310013 user.info : [m3vpss ] ==============FVID2_SETFMT STARTING===================
May 27 08:27:23 bd-10310013 user.info : [m3vpss ] ==============FVID2_SETFMT STARTED===================
May 27 06:27:23 bd-10310013 user.debug OSD_CAPTURE : OSD_Capture_Process_Thread: TID=2434
May 27 08:27:23 bd-10310013 user.info : [m3vpss ]  70110: DISPLAY: HDDAC(BP0) : 20 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
May 27 08:27:23 bd-10310013 user.info : [m3vpss ]  70110: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 0, HDDAC(BP0) 1, DVO2(BP1) 1, SDDAC(SEC1) 0
May 27 08:27:23 bd-10310013 user.info : [m3vpss ]  70199: DISPLAY: SDDAC(SEC1): 11 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
May 27 06:27:23 bd-10310013 user.info DMP_VCAP_VENC_VDEC_VDIS : Set default encoder sample aspect ratio
May 27 06:27:23 bd-10310013 user.warn DMP_ENCODE : dmp_EncodeSetAspectRatio: Set default SAR for 4:3, channel 16
May 27 06:27:23 bd-10310013 user.debug DMP_VIDEO_PLAYBACK : VdecVdis_VideoPlayback_Thread: TID=2448
May 27 06:27:23 bd-10310013 user.debug DMP_CAMERA : Camera_Check_Process_Thread: TID=2449
May 27 06:27:24 bd-10310013 user.debug AVSERVER_MAIN_THREAD : AVSERVER_tskMain: TID=2468
May 27 06:27:24 bd-10310013 user.debug AVSERVER_MEM_MANAGER : MemMng_Init: Memory layout done, totalsize 106956928 0x6600880
kernel.shmmax = 0x8000000
May 27 06:27:24 bd-10310013 user.debug AVSERVER_STREAM : Msg_CTRL_Thread: TID=2471
May 27 06:27:24 bd-10310013 user.info AVSERVER_API : AVSERVER_rtspServerStart: Start wis-streamer
May 27 06:27:24 bd-10310013 user.notice WIS_STREAMER : Play stream Channel  0 using URL rtsp://0.0.0.0:8551/h264_ch1
May 27 06:27:24 bd-10310013 user.notice WIS_STREAMER : Play stream Channel  6 using URL rtsp://0.0.0.0:8557/h264_ch7
May 27 06:27:24 bd-10310013 user.notice WIS_STREAMER : Play stream Channel  7 using URL rtsp://0.0.0.0:8558/h264_ch8
May 27 06:27:24 bd-10310013 user.notice WIS_STREAMER : Play stream Channel 11 using URL rtsp://0.0.0.0:8562/h264_ch12
May 27 06:27:24 bd-10310013 user.notice WIS_STREAMER : Play stream Channel 15 using URL rtsp://0.0.0.0:8566/h264_ch16
May 27 06:27:24 bd-10310013 user.notice WIS_STREAMER : Play stream Channel  4 using URL rtsp://0.0.0.0:8555/h264_ch5
May 27 06:27:24 bd-10310013 user.notice WIS_STREAMER : Play stream Channel 16 using URL rtsp://0.0.0.0:8567/h264_ch17
May 27 06:27:24 bd-10310013 user.notice WIS_STREAMER : Play stream Channel 10 using URL rtsp://0.0.0.0:8561/h264_ch11
May 27 06:27:24 bd-10310013 user.notice WIS_STREAMER : Play stream Channel  9 using URL rtsp://0.0.0.0:8560/h264_ch10
May 27 06:27:24 bd-10310013 user.notice WIS_STREAMER : Play stream Channel 14 using URL rtsp://0.0.0.0:8565/h264_ch15
May 27 06:27:24 bd-10310013 user.notice WIS_STREAMER : Play stream Channel  8 using URL rtsp://0.0.0.0:8559/h264_ch9
May 27 06:27:24 bd-10310013 user.notice WIS_STREAMER : Play stream Channel  5 using URL rtsp://0.0.0.0:8556/h264_ch6
May 27 06:27:24 bd-10310013 user.notice WIS_STREAMER : Play stream Channel  1 using URL rtsp://0.0.0.0:8552/h264_ch2
May 27 06:27:24 bd-10310013 user.notice WIS_STREAMER : Play stream Channel  3 using URL rtsp://0.0.0.0:8554/h264_ch4
May 27 06:27:24 bd-10310013 user.notice WIS_STREAMER : Play stream Channel 12 using URL rtsp://0.0.0.0:8563/h264_ch13
May 27 06:27:24 bd-10310013 user.notice WIS_STREAMER : Play stream Channel  2 using URL rtsp://0.0.0.0:8553/h264_ch3
May 27 06:27:24 bd-10310013 user.notice WIS_STREAMER : Play stream Channel 13 using URL rtsp://0.0.0.0:8564/h264_ch14
May 27 06:27:25 bd-10310013 user.info DMP : dmp-module started successfully.
May 27 08:27:25 bd-10310013 user.info : [c6xdsp ]  61576: Core is active
May 27 08:27:25 bd-10310013 user.info : [m3video]  71784: Core is active
May 27 08:27:25 bd-10310013 user.info : [m3vpss ]  71784: Core is active
  • The warning indicates allocation of tiled memory failed.
    It appears encoder is trying to allocate tiled memory for reference buffers which is failing.
    The warning is not serious.On tiler allocation failure it will retry allocating from non-tiled memory.
    If you want to eliminate the warning you can try setting previous link output format as non-tiled.
    Note that disabling tiler for all encode channels will degrade performance by upto 20% so tiler disable should be done only for required channel or you can ignore the warning.
  • Thanks for the information, we keep tiler, ignore warning.
